commit 785107923a83d8456bbd8564e288a24d84109a46 upstream.
Some new ACPI 5.0 tables reference resources stored in boot services
memory, so keep that memory around until we have ACPI and can extract
data from it.
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
Link: http://lkml.kernel.org/r/baaa6d44bdc4eb0c58e5d1b4ccd2c729f854ac55.1348876882.git.josh@joshtriplett.org
Cc: Matt Fleming <matt@console-pimps.org>
commit ae82fdb1406ad41d68f07027fe31f2d35ba22a90 upstream.
Commit 026cee0086fe1df4cf74691cf273062cc769617d "params:
<level>_initcall-like kernel parameters" set old-style module
parameters to level 0. And we call those level 0 calls where we used
to, early in start_kernel().
We also loop through the initcall levels and call the levelled
module_params before the corresponding initcall. Unfortunately level
0 is early_init(), so we call the standard module_param calls twice.
(Turns out most things don't care, but at least ubi.mtd does).
Change the level to -1 for standard module_param calls.
Reported-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
commit 31a67102f4762df5544bc2dfb34a931233d2a5b2 upstream.
During early boot, when the scheduler hasn't really been fully set up,
we really can't do blocking allocations because with certain (dubious)
configurations the "might_resched()" calls can actually result in
scheduling events.
We could just make such users always use GFP_ATOMIC, but quite often the
code that does the allocation isn't really aware of the fact that the
scheduler isn't up yet, and forcing that kind of random knowledge on the
initialization code is just annoying and not good for anybody.
And we actually have a the 'gfp_allowed_mask' exactly for this reason:
it's just that the kernel init sequence happens to set it to allow
blocking allocations much too early.
So move the 'gfp_allowed_mask' initialization from 'start_kernel()'
(which is some of the earliest init code, and runs with preemption
disabled for good reasons) into 'kernel_init()'. kernel_init() is run
in the newly created thread that will become the 'init' process, as
opposed to the early startup code that runs within the context of what
will be the first idle thread.
So by the time we reach 'kernel_init()', we know that the scheduler must
be at least limping along, because we've already scheduled from the idle
thread into the init thread.
Reported-by: Steven Rostedt <rostedt@goodmis.org>
Commit 026cee0086f had the side-effect of dropping the '=' from
the unknown boot arguments that are passed to init as environment
variables. This is because parse_args() puts a NUL in the string
where the '=' was when it passes the "param" and "val" pointers
to the parsing subfunctions. Previously, unknown_bootoption() was
the last parse_args() subfunction to run, and it carefully put back
the '=' character. Now the ignore_unknown_bootoption() is the last
one to run, and it wasn't doing the necessary repair, so the
envp params ended up with the embedded NUL and were no longer
seen as valid environment variables by init.
Tested-by: Woody Suwalski <terraluna977@gmail.com>
Acked-by: Pawel Moll <pawel.moll@arm.com>
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system
Pull "Disintegrate and delete asm/system.h" from David Howells:
"Here are a bunch of patches to disintegrate asm/system.h into a set of
separate bits to relieve the problem of circular inclusion
dependencies.
I've built all the working defconfigs from all the arches that I can
and made sure that they don't break.
The reason for these patches is that I recently encountered a circular
dependency problem that came about when I produced some patches to
optimise get_order() by rewriting it to use ilog2().
This uses bitops - and on the SH arch asm/bitops.h drags in
asm-generic/get_order.h by a circuituous route involving asm/system.h.
The main difficulty seems to be asm/system.h. It holds a number of
low level bits with no/few dependencies that are commonly used (eg.
memory barriers) and a number of bits with more dependencies that
aren't used in many places (eg. switch_to()).
These patches break asm/system.h up into the following core pieces:
(1) asm/barrier.h
Move memory barriers here. This already done for MIPS and Alpha.
(2) asm/switch_to.h
Move switch_to() and related stuff here.
(3) asm/exec.h
Move arch_align_stack() here. Other process execution related bits
could perhaps go here from asm/processor.h.
(4) asm/cmpxchg.h
Move xchg() and cmpxchg() here as they're full word atomic ops and
frequently used by atomic_xchg() and atomic_cmpxchg().
(5) asm/bug.h
Move die() and related bits.
(6) asm/auxvec.h
Move AT_VECTOR_SIZE_ARCH here.
Other arch headers are created as needed on a per-arch basis."
Fixed up some conflicts from other header file cleanups and moving code
around that has happened in the meantime, so David's testing is somewhat
weakened by that. We'll find out anything that got broken and fix it..
* tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits)
Delete all instances of asm/system.h
Remove all #inclusions of asm/system.h
Add #includes needed to permit the removal of asm/system.h
Move all declarations of free_initmem() to linux/mm.h
Disintegrate asm/system.h for OpenRISC
Split arch_align_stack() out from asm-generic/system.h
Split the switch_to() wrapper out of asm-generic/system.h
Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h
Create asm-generic/barrier.h
Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h
Disintegrate asm/system.h for Xtensa
Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt]
Disintegrate asm/system.h for Tile
Disintegrate asm/system.h for Sparc
Disintegrate asm/system.h for SH
Disintegrate asm/system.h for Score
Disintegrate asm/system.h for S390
Disintegrate asm/system.h for PowerPC
Disintegrate asm/system.h for PA-RISC
Disintegrate asm/system.h for MN10300
Move all declarations of free_initmem() to linux/mm.h so that there's only one
and it's used by everything.
cc: linux-c6x-dev@linux-c6x.org
cc: microblaze-uclinux@itee.uq.edu.au
cc: linux-sh@vger.kernel.org
cc: sparclinux@vger.kernel.org
cc: x86@kernel.org
cc: linux-mm@kvack.org
This patch adds a set of macros that can be used to declare
kernel parameters to be parsed _before_ initcalls at a chosen
level are executed. We rename the now-unused "flags" field of
struct kernel_param as the level. It's signed, for when we
use this for early params as well, in future.
Linker macro collating init calls had to be modified in order
to add additional symbols between levels that are later used
by the init code to split the calls into blocks.
Signed-off-by: Pawel Moll <pawel.moll@arm.com>
Pull trivial tree from Jiri Kosina:
"It's indeed trivial -- mostly documentation updates and a bunch of
typo fixes from Masanari.
There are also several linux/version.h include removals from Jesper."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (101 commits)
kcore: fix spelling in read_kcore() comment
constify struct pci_dev * in obvious cases
Revert "char: Fix typo in viotape.c"
init: fix wording error in mm_init comment
usb: gadget: Kconfig: fix typo for 'different'
Revert "power, max8998: Include linux/module.h just once in drivers/power/max8998_charger.c"
writeback: fix fn name in writeback_inodes_sb_nr_if_idle() comment header
writeback: fix typo in the writeback_control comment
Documentation: Fix multiple typo in Documentation
tpm_tis: fix tis_lock with respect to RCU
Revert "media: Fix typo in mixer_drv.c and hdmi_drv.c"
Doc: Update numastat.txt
qla4xxx: Add missing spaces to error messages
compiler.h: Fix typo
security: struct security_operations kerneldoc fix
Documentation: broken URL in libata.tmpl
Documentation: broken URL in filesystems.tmpl
mtd: simplify return logic in do_map_probe()
mm: fix comment typo of truncate_inode_pages_range
power: bq27x00: Fix typos in comment
s/countinuous/contiguous/, reword sentence.
Signed-off-by: Jim Cromie <jim.cromie@gmail.com>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Coccinelle based conversion.
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Link: http://lkml.kernel.org/n/tip-24swm5zut3h9c4a6s46x8rws@git.kernel.org
module_param(bool) used to counter-intuitively take an int. In
fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy
trick.
It's time to remove the int/unsigned int option. For this version
it'll simply give a warning, but it'll break next kernel version.
* 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/numa: Add constraints check for nid parameters
mm, x86: Remove debug_pagealloc_enabled
x86/mm: Initialize high mem before free_all_bootmem()
arch/x86/kernel/e820.c: quiet sparse noise about plain integer as NULL pointer
arch/x86/kernel/e820.c: Eliminate bubble sort from sanitize_e820_map()
x86: Fix mmap random address range
x86, mm: Unify zone_sizes_init()
x86, mm: Prepare zone_sizes_init() for unification
x86, mm: Use max_low_pfn for ZONE_NORMAL on 64-bit
x86, mm: Wrap ZONE_DMA32 with CONFIG_ZONE_DMA32
x86, mm: Use max_pfn instead of highend_pfn
x86, mm: Move zone init from paging_init() on 64-bit
x86, mm: Use MAX_DMA_PFN for ZONE_DMA on 32-bit
When (no)bootmem finish operation, it pass pages to buddy
allocator. Since debug_pagealloc_enabled is not set, we will do
not protect pages, what is not what we want with
CONFIG_DEBUG_PAGEALLOC=y.
To fix remove debug_pagealloc_enabled. That variable was
introduced by commit 12d6f21e "x86: do not PSE on
CONFIG_DEBUG_PAGEALLOC=y" to get more CPA (change page
attribude) code testing. But currently we have CONFIG_CPA_DEBUG,
which test CPA.
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
Cc: linux-mm@kvack.org
Link: http://lkml.kernel.org/r/1322582711-14571-1-git-send-email-sgruszka@redhat.com
This patch fixes a lockdep warning on ARM platforms:
[ 0.000000] WARNING: lockdep init error! Arch code didn't call lockdep_init() early enough?
[ 0.000000] Call stack leading to lockdep invocation was:
[ 0.000000] [<c00164bc>] save_stack_trace_tsk+0x0/0x90
[ 0.000000] [<ffffffff>] 0xffffffff
The warning is caused by printk inside smp_setup_processor_id().
It is safe to do this because lockdep_init() doesn't depend on
smp_setup_processor_id(), so improve things that printk can be
called as early as possible without lockdep complaint.
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
Reviewed-by: Yong Zhang <yong.zhang0@gmail.com>
Link: http://lkml.kernel.org/r/1321508072-23853-1-git-send-email-tom.leiming@gmail.com
git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen
* 'upstream/jump-label-noearly' of git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen:
jump-label: initialize jump-label subsystem much earlier
x86/jump_label: add arch_jump_label_transform_static()
s390/jump-label: add arch_jump_label_transform_static()
jump_label: add arch_jump_label_transform_static() to optimise non-live code updates
sparc/jump_label: drop arch_jump_label_text_poke_early()
x86/jump_label: drop arch_jump_label_text_poke_early()
jump_label: if a key has already been initialized, don't nop it out
stop_machine: make stop_machine safe and efficient to call early
jump_label: use proper atomic_t initializer
- arch/x86/kernel/jump_label.c
Added __init_or_module to arch_jump_label_text_poke_early vs
removal of that function entirely
- kernel/stop_machine.c
same patch ("stop_machine: make stop_machine safe and efficient
to call early") merged twice, with whitespace fix in one version
The user may use "foo-bar" for a kernel parameter defined as "foo_bar".
Make sure it works the other way around too.
Apply the equality of dashes and underscores on early_params and __setup
params as well.
The example given in Documentation/kernel-parameters.txt indicates that
this is the intended behaviour.
With the patch the kernel accepts "log-buf-len=1M" as expected.
https://bugzilla.redhat.com/show_bug.cgi?id=744545
Signed-off-by: Michal Schmidt <mschmidt@redhat.com>
Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (neatened implementations)
Initialize jump_labels much, much earlier, so they're available for use
during system setup.
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Commit d5767c53535a ("bootup: move 'usermodehelper_enable()' to the end
of do_basic_setup()") moved 'usermodehelper_enable()' to end of
do_basic_setup() to after the initcalls. But then I get failed to let
uvesafb work on my computer, and lose the splash boot.
So maybe we could start usermodehelper_enable a little early to make
some task work that need eary init with the help of user mode.
[ I would *really* prefer that initcalls not call into user space - even
the real 'init' hasn't been execve'd yet, after all! But for uvesafb
it really does look like we don't have much choice.
I considered doing this when we mount the root filesystem, but
depending on config options that is in multiple places. We could do
the usermode helper enable as a rootfs_initcall()..
So I'm just using wang yanqing's trivial patch. It's not wonderful,
but it's simple and should work. We should revisit this some day,
though. - Linus ]
Doing it just before starting to call into cpu_idle() made a sick kind
of sense only because the original bug we fixed (see commit
288d5abec831: "Boot up with usermodehelper disabled") was about problems
with some scheduler data structures not being initialized, and they had
better be initialized at that point.
But it really didn't make any other conceptual sense, and doing it after
the initial "schedule()" call for the idle thread actually opened up a
race: what if the main initialization thread did everything without
needing to sleep, and got all the way into user land too? Without
actually having scheduled back to the idle thread?
Now, in normal circumstances that doesn't ever happen, but it looks like
Richard Cochran triggered exactly that on his ARM IXP4xx machines:
"I have some ARM IXP4xx based machines that use the two on chip MAC
ports (aka NPEs). The NPE needs a firmware in order to function.
Ever since the following commit [that 288d5abec831 one], it is no
longer possible to bring up the interfaces during the init scripts."
with a call trace showing an ioctl coming from user space. Richard says:
"The init is busybox, and the startup script does mount, syslogd, and
then ifup, so that all can go by quickly."
The fix is to move the usermodehelper_enable() into the main 'init'
thread, and just put it after we've done all our initcalls. By then,
everything really should be up, but we've obviously not actually started
the user-mode portion of init yet.
Reported-and-tested-by: Richard Cochran <richardcochran@gmail.com>
When a malformed loglevel value (for example "${abc}") is passed on the
kernel cmdline, the loglevel itself is being set to 0.
That then suppresses all following messages, including all the errors
and crashes caused by other malformed cmdline options. This could make
debugging process quite tricky.
This patch leaves the previous value of loglevel if the new value is
incorrect and reports an error code in this case.
Signed-off-by: Alexander Sverdlin <alexander.sverdlin@sysgo.com>
The core device layer sends tons of uevent notifications for each device
it finds, and if the kernel has been built with a non-empty
CONFIG_UEVENT_HELPER_PATH that will make us try to execute the usermode
helper binary for all these events very early in the boot.
Not only won't the root filesystem even be mounted at that point, we
literally won't have necessarily even initialized all the process
handling data structures at that point, which causes no end of silly
problems even when the usermode helper doesn't actually succeed in
executing.
So just use our existing infrastructure to disable the usermodehelpers
to make the kernel start out with them disabled. We enable them when
we've at least initialized stuff a bit.
Problems related to an uninitialized
init_ipc_ns.ids[IPC_SHM_IDS].rw_mutex
reported by various people.
Reported-by: Manuel Lauss <manuel.lauss@googlemail.com>
Reported-by: Richard Weinberger <richard@nod.at>
Reported-by: Marc Zyngier <maz@misterjones.org>
Acked-by: Kay Sievers <kay.sievers@vrfy.org>
Cc: Vasiliy Kulikov <segoon@openwall.com>
Cc: Greg KH <greg@kroah.com>
While it's at its least, make a number of boring nitpicky cleanups to
shmem.c, mostly for consistency of variable naming. Things like "swap"
instead of "entry", "pgoff_t index" instead of "unsigned long idx".
And since everything else here is prefixed "shmem_", better change
init_tmpfs() to shmem_init().
enabling interrupts
There is a problem that kdump(2nd kernel) sometimes hangs up due
to a pending IPI from 1st kernel. Kernel panic occurs because IPI
comes before call_single_queue is initialized.
To fix the crash, rename init_call_single_data() to call_function_init()
and call it in start_kernel() so that call_single_queue can be
initialized before enabling interrupts.
The details of the crash are:
(1) 2nd kernel boots up
(2) A pending IPI from 1st kernel comes when irqs are first enabled
in start_kernel().
(3) Kernel tries to handle the interrupt, but call_single_queue
is not initialized yet at this point. As a result, in the
generic_smp_call_function_single_interrupt(), NULL pointer
dereference occurs when list_replace_init() tries to access
&q->list.next.
Therefore this patch changes the name of init_call_single_data()
to call_function_init() and calls it before local_irq_enable()
in start_kernel().
Signed-off-by: Takao Indoh <indou.takao@jp.fujitsu.com>
Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com>
Acked-by: Vivek Goyal <vgoyal@redhat.com>
Cc: Milton Miller <miltonm@bga.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: kexec@lists.infradead.org
Link: http://lkml.kernel.org/r/D6CBEE2F420741indou.takao@jp.fujitsu.com
Thomas Gleixner reports that we now have a boot crash triggered by
CONFIG_CPUMASK_OFFSTACK=y:
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<c11ae035>] find_next_bit+0x55/0xb0
Call Trace:
[<c11addda>] cpumask_any_but+0x2a/0x70
[<c102396b>] flush_tlb_mm+0x2b/0x80
[<c1022705>] pud_populate+0x35/0x50
[<c10227ba>] pgd_alloc+0x9a/0xf0
[<c103a3fc>] mm_init+0xec/0x120
[<c103a7a3>] mm_alloc+0x53/0xd0
which was introduced by commit de03c72cfce5 ("mm: convert
mm->cpu_vm_cpumask into cpumask_var_t"), and is due to wrong ordering of
mm_init() vs mm_init_cpumask
Thomas wrote a patch to just fix the ordering of initialization, but I
hate the new double allocation in the fork path, so I ended up instead
doing some more radical surgery to clean it all up.
Reported-by: Thomas Gleixner <tglx@linutronix.de>
Reported-by: Ingo Molnar <mingo@elte.hu>
On larger systems, because of the numerous ACPI, Bootmem and EFI messages,
the static log buffer overflows before the larger one specified by the
log_buf_len param is allocated. Minimize the overflow by allocating the
new log buffer as soon as possible.
On kernels without memblock, a later call to setup_log_buf from
kernel/init.c is the fallback.
[akpm@linux-foundation.org: fix CONFIG_PRINTK=n build]
Signed-off-by: Mike Travis <travis@sgi.com>
Cc: Yinghai Lu <yhlu.kernel@gmail.com>
Cc: Jack Steiner <steiner@sgi.com>
cpumask_t is very big struct and cpu_vm_mask is placed wrong position.
It might lead to reduce cache hit ratio.
This patch has two change.
1) Move the place of cpumask into last of mm_struct. Because usually cpumask
is accessed only front bits when the system has cpu-hotplug capability
2) Convert cpu_vm_mask into cpumask_var_t. It may help to reduce memory
footprint if cpumask_size() will use nr_cpumask_bits properly in future.
In addition, this patch change the name of cpu_vm_mask with cpu_vm_mask_var.
It may help to detect out of tree cpu_vm_mask users.
This patch has no functional change.
[akpm@linux-foundation.org: build fix]
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Kmemleak frees objects via RCU and when CONFIG_DEBUG_OBJECTS_RCU_HEAD
is enabled, the RCU callback triggers a call to free_object() in
lib/debugobjects.c. Since kmemleak is initialised before debug objects
initialisation, it may result in a kernel panic during booting. This
patch moves the kmemleak_init() call after debug_objects_mem_init().
Reported-by: Marcin Slusarz <marcin.slusarz@gmail.com>
Tested-by: Tejun Heo <tj@kernel.org>
Cc: <stable@kernel.org>
This patchset is a cleanup and a preparation to unshare the pid namespace.
These prerequisites prepare for Eric's patchset to give a file descriptor
to a namespace and join an existing namespace.
This patch:
It turns out that the existing assignment in copy_process of the
child_reaper can handle the initial assignment of child_reaper we just
need to generalize the test in kernel/fork.c
Signed-off-by: Daniel Lezcano <daniel.lezcano@free.fr>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Acked-by: Serge E. Hallyn <serge@hallyn.com>
Move setup_nr_cpu_ids(), smp_init() and some other SMP boot parameter
setup functions from init/main.c to kenrel/smp.c, saves some #ifdef
CONFIG_SMP.
Signed-off-by: WANG Cong <amwang@redhat.com>
Cc: Rakib Mullick <rakib.mullick@gmail.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Akinobu Mita <akinobu.mita@gmail.com>
During early boot, local IRQ is disabled until IRQ subsystem is
properly initialized. During this time, no one should enable
local IRQ and some operations which usually are not allowed with
IRQ disabled, e.g. operations which might sleep or require
communications with other processors, are allowed.
lockdep tracked this with early_boot_irqs_off/on() callbacks.
As other subsystems need this information too, move it to
init/main.c and make it generally available. While at it,
toggle the boolean to early_boot_irqs_disabled instead of
enabled so that it can be initialized with %false and %true
indicates the exceptional condition.
Acked-by: Pekka Enberg <penberg@kernel.org>
LKML-Reference: <20110120110635.GB6036@htj.dyndns.org>
* 'for-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (33 commits)
usb: don't use flush_scheduled_work()
speedtch: don't abuse struct delayed_work
media/video: don't use flush_scheduled_work()
media/video: explicitly flush request_module work
ioc4: use static work_struct for ioc4_load_modules()
init: don't call flush_scheduled_work() from do_initcalls()
s390: don't use flush_scheduled_work()
rtc: don't use flush_scheduled_work()
mmc: update workqueue usages
mfd: update workqueue usages
dvb: don't use flush_scheduled_work()
leds-wm8350: don't use flush_scheduled_work()
mISDN: don't use flush_scheduled_work()
macintosh/ams: don't use flush_scheduled_work()
vmwgfx: don't use flush_scheduled_work()
tpm: don't use flush_scheduled_work()
sonypi: don't use flush_scheduled_work()
hvsi: don't use flush_scheduled_work()
xen: don't use flush_scheduled_work()
gdrom: don't use flush_scheduled_work()
Fixed up trivial conflict in drivers/media/video/bt8xx/bttv-input.c
as per Tejun.
The call to flush_scheduled_work() in do_initcalls() is there to make
sure all works queued to system_wq by initcalls finish before the init
sections are dropped.
However, the call doesn't make much sense at this point - there
already are multiple different workqueues and different subsystems are
free to create and use their own. Ordering requirements are and
should be expressed explicitly.
Drop the call to prepare for the deprecation and removal of
flush_scheduled_work().
Andrew suggested adding sanity check where the workqueue code checks
whether any pending or running work has the work function in the init
text section. However, checking this for running works requires the
worker to keep track of the current function being executed, and
checking only the pending works will miss most cases. As a violation
will almost always be caught by the usual page fault mechanism, I
don't think it would be worthwhile to make the workqueue code track
extra state just for this.
perf_event_init() wants to start using IDR trees, its needs in turn
are satisfied by mm_init().
LKML-Reference: <20101117222056.206992649@chello.nl>
Currently we call perf_event_init() from sched_init(). In order to
make it more obvious move it to the cannnonical location.
LKML-Reference: <20101117222056.093629821@chello.nl>
The perf hardware pmu got initialized at various points in the boot,
some before early_initcall() some after (notably arch_initcall).
The problem is that the NMI lockup detector is ran from early_initcall()
and expects the hardware pmu to be present.
Sanitize this by moving all architecture hardware pmu implementations to
initialize at early_initcall() and move the lockup detector to an explicit
initcall right after that.
Cc: paulus <paulus@samba.org>
Cc: davem <davem@davemloft.net>
Cc: Michael Cree <mcree@orcon.net.nz>
Cc: Deng-Cheng Zhu <dengcheng.zhu@gmail.com>
Acked-by: Paul Mundt <lethal@linux-sh.org>
Acked-by: Will Deacon <will.deacon@arm.com>
LKML-Reference: <1290707759.2145.119.camel@laptop>
The big kernel lock has been removed from all these files at some point,
leaving only the #include.
Remove this too as a cleanup.
* 'config' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl:
BKL: introduce CONFIG_BKL.
dabusb: remove the BKL
sunrpc: remove the big kernel lock
init/main.c: remove BKL notations
blktrace: remove the big kernel lock
rtmutex-tester: make it build without BKL
dvb-core: kill the big kernel lock
dvb/bt8xx: kill the big kernel lock
tlclk: remove big kernel lock
fix rawctl compat ioctls breakage on amd64 and itanic
uml: kill big kernel lock
parisc: remove big kernel lock
cris: autoconvert trivial BKL users
alpha: kill big kernel lock
isapnp: BKL removal
s390/block: kill the big kernel lock
hpet: kill BKL, add compat_ioctl
According to commit 5e3d20a68f63fc5a310687d81956c3b96e488b84
(init: Remove the BKL from startup code) these sparse notations
should be removed also.
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
early_init_irq_lock_class() is called way before anything touches the
irq descriptors. In case of SPARSE_IRQ=y this is a NOP operation
because the radix tree is empty at this point. For the SPARSE_IRQ=n
case it's sufficient to set the lock class in early_init_irq().
Reviewed-by: Ingo Molnar <mingo@elte.hu>
Make do_execve() take a const filename pointer so that kernel_execve() compiles
correctly on ARM:
arch/arm/kernel/sys_arm.c:88: warning: passing argument 1 of 'do_execve' discards qualifiers from pointer target type
This also requires the argv and envp arguments to be consted twice, once for
the pointer array and once for the strings the array points to. This is
because do_execve() passes a pointer to the filename (now const) to
copy_strings_kernel(). A simpler alternative would be to cast the filename
pointer in do_execve() when it's passed to copy_strings_kernel().
do_execve() may not change any of the strings it is passed as part of the argv
or envp lists as they are some of them in .rodata, so marking these strings as
const should be fine.
Further kernel_execve() and sys_execve() need to be changed to match.
This has been test built on x86_64, frv, arm and mips.
Tested-by: Ralf Baechle <ralf@linux-mips.org>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Since this section can be read-only (they're in .rodata), they should
always have been const. Minor flow-through various functions.
Tested-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
Andrew Morton suggested that the do_one_initcall and do_one_initcall_debug
functions can be marked __init_or_module such that they can be discarded
for the CONFIG_MODULES=N case.
Signed-off-by: Kevin Winchester <kjwinchester@gmail.com>
Using:
gcc (GCC) 4.5.0 20100610 (prerelease)
The following warning appears:
init/main.c: In function `do_one_initcall':
init/main.c:730:10: warning: `calltime.tv64' may be used uninitialized in this function
This warning is actually correct, as the global initcall_debug could
arguably be changed by the initcall.
Correct this warning by extracting a new function, do_one_initcall_debug,
that performs the initcall for the debug case.
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing
* 'bkl/core' of git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing:
do_coredump: Do not take BKL
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (55 commits)
workqueue: mark init_workqueues() as early_initcall()
workqueue: explain for_each_*cwq_cpu() iterators
fscache: fix build on !CONFIG_SYSCTL
slow-work: kill it
gfs2: use workqueue instead of slow-work
drm: use workqueue instead of slow-work
cifs: use workqueue instead of slow-work
fscache: drop references to slow-work
fscache: convert operation to use workqueue instead of slow-work
fscache: convert object to use workqueue instead of slow-work
workqueue: fix how cpu number is stored in work->data
workqueue: fix mayday_mask handling on UP
workqueue: fix build problem on !CONFIG_SMP
workqueue: fix locking in retry path of maybe_create_worker()
async: use workqueue for worker pool
workqueue: remove WQ_SINGLE_CPU and use WQ_UNBOUND instead
workqueue: implement unbound workqueue
workqueue: prepare for WQ_UNBOUND implementation
libata: take advantage of cmwq and remove concurrency limitations
workqueue: fix worker management invocation without pending works
Fixed up conflicts in fs/cifs/* as per Tejun. Other trivial conflicts in
include/linux/workqueue.h, kernel/trace/Kconfig and kernel/workqueue.c
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (162 commits)
tracing/kprobes: unregister_trace_probe needs to be called under mutex
perf: expose event__process function
perf events: Fix mmap offset determination
perf, powerpc: fsl_emb: Restore setting perf_sample_data.period
perf, powerpc: Convert the FSL driver to use local64_t
perf tools: Don't keep unreferenced maps when unmaps are detected
perf session: Invalidate last_match when removing threads from rb_tree
perf session: Free the ref_reloc_sym memory at the right place
x86,mmiotrace: Add support for tracing STOS instruction
perf, sched migration: Librarize task states and event headers helpers
perf, sched migration: Librarize the GUI class
perf, sched migration: Make the GUI class client agnostic
perf, sched migration: Make it vertically scrollable
perf, sched migration: Parameterize cpu height and spacing
perf, sched migration: Fix key bindings
perf, sched migration: Ignore unhandled task states
perf, sched migration: Handle ignored migrate out events
perf: New migration tool overview
tracing: Drop cpparg() macro
perf: Use tracepoint_synchronize_unregister() to flush any pending tracepoint call
Fix up trivial conflicts in Makefile and drivers/cpufreq/cpufreq.c
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu:
percpu: allow limited allocation before slab is online
percpu: make @dyn_size always mean min dyn_size in first chunk init functions
Mark init_workqueues() as early_initcall() and thus it will be initialized
before smp bringup. init_workqueues() registers for the hotcpu notifier
and thus it should cope with the processors that are brought online after
the workqueues are initialized.
x86 smp bringup code uses workqueues and uses a workaround for the
cold boot process (as the workqueues are initialized post smp_init()).
Marking init_workqueues() as early_initcall() will pave the way for
cleaning up this code.
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
I have shown by code review that no driver takes
the BKL at init time any more, so whatever the
init code was locking against is no longer there
and it is now safe to remove the BKL there.
Acked-by: Steven Rostedt <rostedt@goodmis>
Merge reason: Pick up the latest perf fixes
