path: root/init/version.c
2017-01-14locking/atomic, kref: Add KREF_INIT()Peter Zijlstra
Since we need to change the implementation, stop exposing internals. Provide KREF_INIT() to allow static initialization of struct kref. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-12-04copy address of proc_ns_ops into ns_commonAl Viro
2014-12-04common object embedded into various struct ....nsAl Viro
for now - just move corresponding ->proc_inum instances over there Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-05-01proc: Split the namespace stuff out into linux/proc_ns.hDavid Howells
Split the proc namespace stuff out into linux/proc_ns.h. Signed-off-by: David Howells <dhowells@redhat.com> cc: netdev@vger.kernel.org cc: Serge E. Hallyn <serge.hallyn@ubuntu.com> cc: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-11-20proc: Usable inode numbers for the namespace file descriptors.Eric W. Biederman
Assign a unique proc inode to each namespace, and use that inode number to ensure we only allocate at most one proc inode for every namespace in proc. A single proc inode per namespace allows userspace to test to see if two processes are in the same namespace. This has been a long requested feature and only blocked because a naive implementation would put the id in a global space and would ultimately require having a namespace for the names of namespaces, making migration and certain virtualization tricks impossible. We still don't have per superblock inode numbers for proc, which appears necessary for application unaware checkpoint/restart and migrations (if the application is using namespace file descriptors) but that is now allowd by the design if it becomes important. I have preallocated the ipc and uts initial proc inode numbers so their structures can be statically initialized. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2011-03-23userns: add a user_namespace as creator/owner of uts_namespaceSerge E. Hallyn
The expected course of development for user namespaces targeted capabilities is laid out at https://wiki.ubuntu.com/UserNamespace. Goals: - Make it safe for an unprivileged user to unshare namespaces. They will be privileged with respect to the new namespace, but this should only include resources which the unprivileged user already owns. - Provide separate limits and accounting for userids in different namespaces. Status: Currently (as of 2.6.38) you can clone with the CLONE_NEWUSER flag to get a new user namespace if you have the CAP_SYS_ADMIN, CAP_SETUID, and CAP_SETGID capabilities. What this gets you is a whole new set of userids, meaning that user 500 will have a different 'struct user' in your namespace than in other namespaces. So any accounting information stored in struct user will be unique to your namespace. However, throughout the kernel there are checks which - simply check for a capability. Since root in a child namespace has all capabilities, this means that a child namespace is not constrained. - simply compare uid1 == uid2. Since these are the integer uids, uid 500 in namespace 1 will be said to be equal to uid 500 in namespace 2. As a result, the lxc implementation at lxc.sf.net does not use user namespaces. This is actually helpful because it leaves us free to develop user namespaces in such a way that, for some time, user namespaces may be unuseful. Bugs aside, this patchset is supposed to not at all affect systems which are not actively using user namespaces, and only restrict what tasks in child user namespace can do. They begin to limit privilege to a user namespace, so that root in a container cannot kill or ptrace tasks in the parent user namespace, and can only get world access rights to files. Since all files currently belong to the initila user namespace, that means that child user namespaces can only get world access rights to *all* files. While this temporarily makes user namespaces bad for system containers, it starts to get useful for some sandboxing. I've run the 'runltplite.sh' with and without this patchset and found no difference. This patch: copy_process() handles CLONE_NEWUSER before the rest of the namespaces. So in the case of clone(CLONE_NEWUSER|CLONE_NEWUTS) the new uts namespace will have the new user namespace as its owner. That is what we want, since we want root in that new userns to be able to have privilege over it. Changelog: Feb 15: don't set uts_ns->user_ns if we didn't create a new uts_ns. Feb 23: Move extern init_user_ns declaration from init/version.c to utsname.h. Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-12kbuild: move utsrelease.h to include/generatedSam Ravnborg
Fix up all users of utsrelease.h Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-12kbuild: move compile.h to include/generatedSam Ravnborg
2008-07-25init/version.c: define version_string only if CONFIG_KALLSYMS is not definedDaniel Guilak
int Version_* is only used with ksymoops, which is only needed (according to README and Documentation/Changes) if CONFIG_KALLSYMS is NOT defined. Therefore this patch defines version_string only if CONFIG_KALLSYMS is not defined. Signed-off-by: Daniel Guilak <daniel@danielguilak.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25init/version.c: silence sparse warning by declaring the version stringDaniel Guilak
2007-01-11Don't put "linux_banner" in the .init sectionLinus Torvalds
It might save a few bytes after bootup, but it causes the string to be linked in at the end of the final vmlinux image, which defeats the whole point of doing all this, namely allowing some broken user-space binaries to search for the kernel version string in the kernel binary. So just remove the __init specifier. Cc: Olaf Hering <olaf@aepfle.de> Cc: Jean Delvare <khali@linux-fr.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Andrey Borzenkov <arvidjaar@mail.ru> Cc: Andrew Morton <akpm@osdl.org> Acked-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2007-01-10[PATCH] fix linux banner format stringRoman Zippel
Revert previous attempts at messing with the linux banner string and simply use a separate format string for proc. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Acked-by: Olaf Hering <olaf@aepfle.de> Acked-by: Jean Delvare <khali@linux-fr.org> Cc: Andrey Borzenkov <arvidjaar@mail.ru> Cc: Andrew Morton <akpm@osdl.org> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Herbert Poetzl <herbert@13thfloor.at> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-11Make SLES9 "get_kernel_version" work on the kernel binary againLinus Torvalds
As reported by Andy Whitcroft, at least the SLES9 initrd build process depends on getting the kernel version from the kernel binary. It does that by simply trawling the binary and looking for the signature of the "linux_banner" string (the string "Linux version " to be exact. Which is really broken in itself, but whatever..) That got broken when the string was changed to allow /proc/version to change the UTS release information dynamically, and "get_kernel_version" thus returned "%s" (see commit a2ee8649ba6d71416712e798276bf7c40b64e6e5: "[PATCH] Fix linux banner utsname information"). This just restores "linux_banner" as a static string, which should fix the version finding. And /proc/version simply uses a different string. To avoid wasting even that miniscule amount of memory, the early boot string should really be marked __initdata, but that just causes the same bug in SLES9 to re-appear, since it will then find other occurrences of "Linux version " first. Cc: Andy Whitcroft <apw@shadowen.org> Acked-by: Herbert Poetzl <herbert@13thfloor.at> Cc: Andi Kleen <ak@suse.de> Cc: Andrew Morton <akpm@osdl.org> Cc: Steve Fox <drfickle@us.ibm.com> Acked-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] Fix linux banner utsname informationHerbert Poetzl
utsname information is shown in the linux banner, which also is used for /proc/version (which can have different utsname values inside a uts namespaces). this patch makes the varying data arguments and changes the string to a format string, using those arguments. Signed-off-by: Herbert Poetzl <herbert@13thfloor.at> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] namespaces: utsname: implement utsname namespacesSerge E. Hallyn
This patch defines the uts namespace and some manipulators. Adds the uts namespace to task_struct, and initializes a system-wide init namespace. It leaves a #define for system_utsname so sysctl will compile. This define will be removed in a separate patch. [akpm@osdl.org: build fix, cleanup] Signed-off-by: Serge Hallyn <serue@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Andrey Savochkin <saw@sw.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03kbuild: introduce utsrelease.hSam Ravnborg
include/linux/version.h contained both actual KERNEL version and UTS_RELEASE that contains a subset from git SHA1 for when kernel was compiled as part of a git repository. This had the unfortunate side-effect that all files including version.h would be recompiled when some git changes was made due to changes SHA1. Split it out so we keep independent parts in separate files. Also update checkversion.pl script to no longer check for UTS_RELEASE. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
