path: root/init
2019-12-05fork: fix some -Wmissing-prototypes warningsYi Wang
[ Upstream commit fb5bf31722d0805a3f394f7d59f2e8cd07acccb7 ] We get a warning when building kernel with W=1: kernel/fork.c:167:13: warning: no previous prototype for `arch_release_thread_stack' [-Wmissing-prototypes] kernel/fork.c:779:13: warning: no previous prototype for `fork_init' [-Wmissing-prototypes] Add the missing declaration in head file to fix this. Also, remove arch_release_thread_stack() completely because no arch seems to implement it since bb9d81264 (arch: remove tile port). Link: http://lkml.kernel.org/r/1542170087-23645-1-git-send-email-wang.yi59@zte.com.cn Signed-off-by: Yi Wang <wang.yi59@zte.com.cn> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Mike Rapoport <rppt@linux.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-05-16init: initialize jump labels before command line option parsingDan Williams
[ Upstream commit 6041186a32585fc7a1d0f6cfe2f138b05fdc3c82 ] When a module option, or core kernel argument, toggles a static-key it requires jump labels to be initialized early. While x86, PowerPC, and ARM64 arrange for jump_label_init() to be called before parse_args(), ARM does not. Kernel command line: rdinit=/sbin/init page_alloc.shuffle=1 panic=-1 console=ttyAMA0,115200 page_alloc.shuffle=1 ------------[ cut here ]------------ WARNING: CPU: 0 PID: 0 at ./include/linux/jump_label.h:303 page_alloc_shuffle+0x12c/0x1ac static_key_enable(): static key 'page_alloc_shuffle_key+0x0/0x4' used before call to jump_label_init() Modules linked in: CPU: 0 PID: 0 Comm: swapper Not tainted 5.1.0-rc4-next-20190410-00003-g3367c36ce744 #1 Hardware name: ARM Integrator/CP (Device Tree) [<c0011c68>] (unwind_backtrace) from [<c000ec48>] (show_stack+0x10/0x18) [<c000ec48>] (show_stack) from [<c07e9710>] (dump_stack+0x18/0x24) [<c07e9710>] (dump_stack) from [<c001bb1c>] (__warn+0xe0/0x108) [<c001bb1c>] (__warn) from [<c001bb88>] (warn_slowpath_fmt+0x44/0x6c) [<c001bb88>] (warn_slowpath_fmt) from [<c0b0c4a8>] (page_alloc_shuffle+0x12c/0x1ac) [<c0b0c4a8>] (page_alloc_shuffle) from [<c0b0c550>] (shuffle_store+0x28/0x48) [<c0b0c550>] (shuffle_store) from [<c003e6a0>] (parse_args+0x1f4/0x350) [<c003e6a0>] (parse_args) from [<c0ac3c00>] (start_kernel+0x1c0/0x488) Move the fallback call to jump_label_init() to occur before parse_args(). The redundant calls to jump_label_init() in other archs are left intact in case they have static key toggling use cases that are even earlier than option parsing. Link: http://lkml.kernel.org/r/155544804466.1032396.13418949511615676665.stgit@dwillia2-desk3.amr.corp.intel.com Signed-off-by: Dan Williams <dan.j.williams@intel.com> Reported-by: Guenter Roeck <groeck@google.com> Reviewed-by: Kees Cook <keescook@chromium.org> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Mike Rapoport <rppt@linux.ibm.com> Cc: Russell King <rmk@armlinux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-03-23Revert "mm: use early_pfn_to_nid in page_ext_init"Qian Cai
[ Upstream commit 2f1ee0913ce58efe7f18fbd518bd54c598559b89 ] This reverts commit fe53ca54270a ("mm: use early_pfn_to_nid in page_ext_init"). When booting a system with "page_owner=on", start_kernel page_ext_init invoke_init_callbacks init_section_page_ext init_page_owner init_early_allocated_pages init_zones_in_node init_pages_in_zone lookup_page_ext page_to_nid The issue here is that page_to_nid() will not work since some page flags have no node information until later in page_alloc_init_late() due to DEFERRED_STRUCT_PAGE_INIT. Hence, it could trigger an out-of-bounds access with an invalid nid. UBSAN: Undefined behaviour in ./include/linux/mm.h:1104:50 index 7 is out of range for type 'zone [5]' Also, kernel will panic since flags were poisoned earlier with, CONFIG_DEBUG_VM_PGFLAGS=y CONFIG_NODE_NOT_IN_PAGE_FLAGS=n start_kernel setup_arch pagetable_init paging_init sparse_init sparse_init_nid memblock_alloc_try_nid_raw It did not handle it well in init_pages_in_zone() which ends up calling page_to_nid(). page:ffffea0004200000 is uninitialized and poisoned raw: ffffffffffffffff ffffffffffffffff ffffffffffffffff ffffffffffffffff raw: ffffffffffffffff ffffffffffffffff ffffffffffffffff ffffffffffffffff page dumped because: VM_BUG_ON_PAGE(PagePoisoned(p)) page_owner info is not active (free page?) kernel BUG at include/linux/mm.h:990! RIP: 0010:init_page_owner+0x486/0x520 This means that assumptions behind commit fe53ca54270a ("mm: use early_pfn_to_nid in page_ext_init") are incomplete. Therefore, revert the commit for now. A proper way to move the page_owner initialization to sooner is to hook into memmap initialization. Link: http://lkml.kernel.org/r/20190115202812.75820-1-cai@lca.pw Signed-off-by: Qian Cai <cai@lca.pw> Acked-by: Michal Hocko <mhocko@kernel.org> Cc: Pasha Tatashin <Pavel.Tatashin@microsoft.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Yang Shi <yang.shi@linaro.org> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2018-08-15init: rename and re-order boot_cpu_state_init()Linus Torvalds
commit b5b1404d0815894de0690de8a1ab58269e56eae6 upstream. This is purely a preparatory patch for upcoming changes during the 4.19 merge window. We have a function called "boot_cpu_state_init()" that isn't really about the bootup cpu state: that is done much earlier by the similarly named "boot_cpu_init()" (note lack of "state" in name). This function initializes some hotplug CPU state, and needs to run after the percpu data has been properly initialized. It even has a comment to that effect. Except it _doesn't_ actually run after the percpu data has been properly initialized. On x86 it happens to do that, but on at least arm and arm64, the percpu base pointers are initialized by the arch-specific 'smp_prepare_boot_cpu()' hook, which ran _after_ boot_cpu_state_init(). This had some unexpected results, and in particular we have a patch pending for the merge window that did the obvious cleanup of using 'this_cpu_write()' in the cpu hotplug init code: - per_cpu_ptr(&cpuhp_state, smp_processor_id())->state = CPUHP_ONLINE; + this_cpu_write(cpuhp_state.state, CPUHP_ONLINE); which is obviously the right thing to do. Except because of the ordering issue, it actually failed miserably and unexpectedly on arm64. So this just fixes the ordering, and changes the name of the function to be 'boot_cpu_hotplug_init()' to make it obvious that it's about cpu hotplug state, because the core CPU state was supposed to have already been done earlier. Marked for stable, since the (not yet merged) patch that will show this problem is marked for stable. Reported-by: Vlastimil Babka <vbabka@suse.cz> Reported-by: Mian Yousaf Kaukab <yousaf.kaukab@suse.com> Suggested-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Will Deacon <will.deacon@arm.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-21init: fix false positives in W+X checkingJeffrey Hugo
[ Upstream commit ae646f0b9ca135b87bc73ff606ef996c3029780a ] load_module() creates W+X mappings via __vmalloc_node_range() (from layout_and_allocate()->move_module()->module_alloc()) by using PAGE_KERNEL_EXEC. These mappings are later cleaned up via "call_rcu_sched(&freeinit->rcu, do_free_init)" from do_init_module(). This is a problem because call_rcu_sched() queues work, which can be run after debug_checkwx() is run, resulting in a race condition. If hit, the race results in a nasty splat about insecure W+X mappings, which results in a poor user experience as these are not the mappings that debug_checkwx() is intended to catch. This issue is observed on multiple arm64 platforms, and has been artificially triggered on an x86 platform. Address the race by flushing the queued work before running the arch-defined mark_rodata_ro() which then calls debug_checkwx(). Link: http://lkml.kernel.org/r/1525103946-29526-1-git-send-email-jhugo@codeaurora.org Fixes: e1a58320a38d ("x86/mm: Warn on W^X mappings") Signed-off-by: Jeffrey Hugo <jhugo@codeaurora.org> Reported-by: Timur Tabi <timur@codeaurora.org> Reported-by: Jan Glauber <jan.glauber@caviumnetworks.com> Acked-by: Kees Cook <keescook@chromium.org> Acked-by: Ingo Molnar <mingo@kernel.org> Acked-by: Will Deacon <will.deacon@arm.com> Acked-by: Laura Abbott <labbott@redhat.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-22kmemcheck: stop using GFP_NOTRACK and SLAB_NOTRACKLevin, Alexander (Sasha Levin)
commit 75f296d93bcebcfe375884ddac79e30263a31766 upstream. Convert all allocations that used a NOTRACK flag to stop using it. Link: http://lkml.kernel.org/r/20171007030159.22241-3-alexander.levin@verizon.com Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Cc: Alexander Potapenko <glider@google.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Tim Hansen <devtimhansen@gmail.com> Cc: Vegard Nossum <vegardno@ifi.uio.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-22kmemcheck: remove annotationsLevin, Alexander (Sasha Levin)
commit 4950276672fce5c241857540f8561c440663673d upstream. Patch series "kmemcheck: kill kmemcheck", v2. As discussed at LSF/MM, kill kmemcheck. KASan is a replacement that is able to work without the limitation of kmemcheck (single CPU, slow). KASan is already upstream. We are also not aware of any users of kmemcheck (or users who don't consider KASan as a suitable replacement). The only objection was that since KASAN wasn't supported by all GCC versions provided by distros at that time we should hold off for 2 years, and try again. Now that 2 years have passed, and all distros provide gcc that supports KASAN, kill kmemcheck again for the very same reasons. This patch (of 4): Remove kmemcheck annotations, and calls to kmemcheck from the kernel. [alexander.levin@verizon.com: correctly remove kmemcheck call from dma_map_sg_attrs] Link: http://lkml.kernel.org/r/20171012192151.26531-1-alexander.levin@verizon.com Link: http://lkml.kernel.org/r/20171007030159.22241-2-alexander.levin@verizon.com Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Cc: Alexander Potapenko <glider@google.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Tim Hansen <devtimhansen@gmail.com> Cc: Vegard Nossum <vegardno@ifi.uio.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-31bpf: introduce BPF_JIT_ALWAYS_ON configAlexei Starovoitov
[ upstream commit 290af86629b25ffd1ed6232c4e9107da031705cb ] The BPF interpreter has been used as part of the spectre 2 attack CVE-2017-5715. A quote from goolge project zero blog: "At this point, it would normally be necessary to locate gadgets in the host kernel code that can be used to actually leak data by reading from an attacker-controlled location, shifting and masking the result appropriately and then using the result of that as offset to an attacker-controlled address for a load. But piecing gadgets together and figuring out which ones work in a speculation context seems annoying. So instead, we decided to use the eBPF interpreter, which is built into the host kernel - while there is no legitimate way to invoke it from inside a VM, the presence of the code in the host kernel's text section is sufficient to make it usable for the attack, just like with ordinary ROP gadgets." To make attacker job harder introduce BPF_JIT_ALWAYS_ON config option that removes interpreter from the kernel in favor of JIT-only mode. So far eBPF JIT is supported by: x64, arm64, arm32, sparc64, s390, powerpc64, mips64 The start of JITed program is randomized and code page is marked as read-only. In addition "constant blinding" can be turned on with net.core.bpf_jit_harden v2->v3: - move __bpf_prog_ret0 under ifdef (Daniel) v1->v2: - fix init order, test_bpf and cBPF (Daniel's feedback) - fix offloaded bpf (Jakub's feedback) - add 'return 0' dummy in case something can invoke prog->bpf_func - retarget bpf tree. For bpf-next the patch would need one extra hunk. It will be sent when the trees are merged back to net-next Considered doing: int bpf_jit_enable __read_mostly = BPF_EBPF_JIT_DEFAULT; but it seems better to land the patch as-is and in bpf-next remove bpf_jit_enable global variable from all JITs, consolidate in one place and remove this jit_init() function. Signed-off-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-02x86/mm/pti: Add infrastructure for page table isolationThomas Gleixner
commit aa8c6248f8c75acfd610fe15d8cae23cf70d9d09 upstream. Add the initial files for kernel page table isolation, with a minimal init function and the boot time detection for this misfeature. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Borislav Petkov <bp@suse.de> Cc: Andy Lutomirski <luto@kernel.org> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: David Laight <David.Laight@aculab.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Eduardo Valentin <eduval@amazon.com> Cc: Greg KH <gregkh@linuxfoundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Juergen Gross <jgross@suse.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Will Deacon <will.deacon@arm.com> Cc: aliguori@amazon.com Cc: daniel.gruss@iaik.tugraz.at Cc: hughd@google.com Cc: keescook@google.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-29init: Invoke init_espfix_bsp() from mm_init()Thomas Gleixner
commit 613e396bc0d4c7604fba23256644e78454c68cf6 upstream. init_espfix_bsp() needs to be invoked before the page table isolation initialization. Move it into mm_init() which is the place where pti_init() will be added. While at it get rid of the #ifdeffery and provide proper stub functions. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Juergen Gross <jgross@suse.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-02Merge tag 'spdx_identifiers-4.14-rc8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull initial SPDX identifiers from Greg KH: "License cleanup: add SPDX license identifiers to some files Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" * tag 'spdx_identifiers-4.14-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: License cleanup: add SPDX license identifier to uapi header files with a license License cleanup: add SPDX license identifier to uapi header files with no license License cleanup: add SPDX GPL-2.0 license identifier to files with no license
2017-10-07kbuild: Fix optimization level choice defaultUlf Magnusson
The choice containing the CC_OPTIMIZE_FOR_PERFORMANCE symbol accidentally added a "CONFIG_" prefix when trying to make it the default, selecting an undefined symbol as the default. The mistake is harmless here: Since the default symbol is not visible, the choice falls back on using the visible symbol as the default instead, which is CC_OPTIMIZE_FOR_PERFORMANCE, as intended. A patch that makes Kconfig print a warning in this case has been submitted separately: http://www.spinics.net/lists/linux-kbuild/msg15566.html Signed-off-by: Ulf Magnusson <ulfalizer@gmail.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-09-14Merge branch 'work.mount' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull mount flag updates from Al Viro: "Another chunk of fmount preparations from dhowells; only trivial conflicts for that part. It separates MS_... bits (very grotty mount(2) ABI) from the struct super_block ->s_flags (kernel-internal, only a small subset of MS_... stuff). This does *not* convert the filesystems to new constants; only the infrastructure is done here. The next step in that series is where the conflicts would be; that's the conversion of filesystems. It's purely mechanical and it's better done after the merge, so if you could run something like list=$(for i in MS_RDONLY MS_NOSUID MS_NODEV MS_NOEXEC MS_SYNCHRONOUS MS_MANDLOCK MS_DIRSYNC MS_NOATIME MS_NODIRATIME MS_SILENT MS_POSIXACL MS_KERNMOUNT MS_I_VERSION MS_LAZYTIME; do git grep -l $i fs drivers/staging/lustre drivers/mtd ipc mm include/linux; done|sort|uniq|grep -v '^fs/namespace.c$') sed -i -e 's/\<MS_RDONLY\>/SB_RDONLY/g' \ -e 's/\<MS_NOSUID\>/SB_NOSUID/g' \ -e 's/\<MS_NODEV\>/SB_NODEV/g' \ -e 's/\<MS_NOEXEC\>/SB_NOEXEC/g' \ -e 's/\<MS_SYNCHRONOUS\>/SB_SYNCHRONOUS/g' \ -e 's/\<MS_MANDLOCK\>/SB_MANDLOCK/g' \ -e 's/\<MS_DIRSYNC\>/SB_DIRSYNC/g' \ -e 's/\<MS_NOATIME\>/SB_NOATIME/g' \ -e 's/\<MS_NODIRATIME\>/SB_NODIRATIME/g' \ -e 's/\<MS_SILENT\>/SB_SILENT/g' \ -e 's/\<MS_POSIXACL\>/SB_POSIXACL/g' \ -e 's/\<MS_KERNMOUNT\>/SB_KERNMOUNT/g' \ -e 's/\<MS_I_VERSION\>/SB_I_VERSION/g' \ -e 's/\<MS_LAZYTIME\>/SB_LAZYTIME/g' \ $list and commit it with something along the lines of 'convert filesystems away from use of MS_... constants' as commit message, it would save a quite a bit of headache next cycle" * 'work.mount' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: VFS: Differentiate mount flags (MS_*) from internal superblock flags VFS: Convert sb->s_flags & MS_RDONLY to sb_rdonly(sb) vfs: Add sb_rdonly(sb) to query the MS_RDONLY flag on s_flags
2017-09-14Merge branch 'work.ipc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull ipc compat cleanup and 64-bit time_t from Al Viro: "IPC copyin/copyout sanitizing, including 64bit time_t work from Deepa Dinamani" * 'work.ipc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: utimes: Make utimes y2038 safe ipc: shm: Make shmid_kernel timestamps y2038 safe ipc: sem: Make sem_array timestamps y2038 safe ipc: msg: Make msg_queue timestamps y2038 safe ipc: mqueue: Replace timespec with timespec64 ipc: Make sys_semtimedop() y2038 safe get rid of SYSVIPC_COMPAT on ia64 semtimedop(): move compat to native shmat(2): move compat to native msgrcv(2), msgsnd(2): move compat to native ipc(2): move compat to native ipc: make use of compat ipc_perm helpers semctl(): move compat to native semctl(): separate all layout-dependent copyin/copyout msgctl(): move compat to native msgctl(): split the actual work from copyin/copyout ipc: move compat shmctl to native shmctl: split the work from copyin/copyout
2017-09-08init/main.c: extract early boot entropy from the passed cmdlineDaniel Micay
Feed the boot command-line as to the /dev/random entropy pool Existing Android bootloaders usually pass data which may not be known by an external attacker on the kernel command-line. It may also be the case on other embedded systems. Sample command-line from a Google Pixel running CopperheadOS.... console=ttyHSL0,115200,n8 androidboot.console=ttyHSL0 androidboot.hardware=sailfish user_debug=31 ehci-hcd.park=3 lpm_levels.sleep_disabled=1 cma=32M@0-0xffffffff buildvariant=user veritykeyid=id:dfcb9db0089e5b3b4090a592415c28e1cb4545ab androidboot.bootdevice=624000.ufshc androidboot.verifiedbootstate=yellow androidboot.veritymode=enforcing androidboot.keymaster=1 androidboot.serialno=FA6CE0305299 androidboot.baseband=msm mdss_mdp.panel=1:dsi:0:qcom,mdss_dsi_samsung_ea8064tg_1080p_cmd:1:none:cfg:single_dsi androidboot.slot_suffix=_b fpsimd.fpsimd_settings=0 app_setting.use_app_setting=0 kernelflag=0x00000000 debugflag=0x00000000 androidboot.hardware.revision=PVT radioflag=0x00000000 radioflagex1=0x00000000 radioflagex2=0x00000000 cpumask=0x00000000 androidboot.hardware.ddr=4096MB,Hynix,LPDDR4 androidboot.ddrinfo=00000006 androidboot.ddrsize=4GB androidboot.hardware.color=GRA00 androidboot.hardware.ufs=32GB,Samsung androidboot.msm.hw_ver_id=268824801 androidboot.qf.st=2 androidboot.cid=11111111 androidboot.mid=G-2PW4100 androidboot.bootloader=8996-012001-1704121145 androidboot.oem_unlock_support=1 androidboot.fp_src=1 androidboot.htc.hrdump=detected androidboot.ramdump.opt=mem@2g:2g,mem@4g:2g androidboot.bootreason=reboot androidboot.ramdump_enable=0 ro root=/dev/dm-0 dm="system none ro,0 1 android-verity /dev/sda34" rootwait skip_initramfs init=/init androidboot.wificountrycode=US androidboot.boottime=1BLL:85,1BLE:669,2BLL:0,2BLE:1777,SW:6,KL:8136 Among other things, it contains a value unique to the device (androidboot.serialno=FA6CE0305299), unique to the OS builds for the device variant (veritykeyid=id:dfcb9db0089e5b3b4090a592415c28e1cb4545ab) and timings from the bootloader stages in milliseconds (androidboot.boottime=1BLL:85,1BLE:669,2BLL:0,2BLE:1777,SW:6,KL:8136). [tytso@mit.edu: changelog tweak] [labbott@redhat.com: line-wrapped command line] Link: http://lkml.kernel.org/r/20170816231458.2299-3-labbott@redhat.com Signed-off-by: Daniel Micay <danielmicay@gmail.com> Signed-off-by: Laura Abbott <labbott@redhat.com> Acked-by: Kees Cook <keescook@chromium.org> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Laura Abbott <lauraa@codeaurora.org> Cc: Nick Kralevich <nnk@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-09-08init: move stack canary initialization after setup_archLaura Abbott
Patch series "Command line randomness", v3. A series to add the kernel command line as a source of randomness. This patch (of 2): Stack canary intialization involves getting a random number. Getting this random number may involve accessing caches or other architectural specific features which are not available until after the architecture is setup. Move the stack canary initialization later to accommodate this. Link: http://lkml.kernel.org/r/20170816231458.2299-2-labbott@redhat.com Signed-off-by: Laura Abbott <lauraa@codeaurora.org> Signed-off-by: Laura Abbott <labbott@redhat.com> Acked-by: Kees Cook <keescook@chromium.org> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Daniel Micay <danielmicay@gmail.com> Cc: Nick Kralevich <nnk@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-09-06Merge branch 'for-4.14' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu Pull percpu updates from Tejun Heo: "A lot of changes for percpu this time around. percpu inherited the same area allocator from the original pre-virtual-address-mapped implementation. This was from the time when percpu allocator wasn't used all that much and the implementation was focused on simplicity, with the unfortunate computational complexity of O(number of areas allocated from the chunk) per alloc / free. With the increase in percpu usage, we're hitting cases where the lack of scalability is hurting. The most prominent one right now is bpf perpcu map creation / destruction which may allocate and free a lot of entries consecutively and it's likely that the problem will become more prominent in the future. To address the issue, Dennis replaced the area allocator with hinted bitmap allocator which is more consistent. While the new allocator does perform a bit worse in some cases, it outperforms the old allocator way more than an order of magnitude in other more common scenarios while staying mostly flat in CPU overhead and completely flat in memory consumption" * 'for-4.14' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (27 commits) percpu: update header to contain bitmap allocator explanation. percpu: update pcpu_find_block_fit to use an iterator percpu: use metadata blocks to update the chunk contig hint percpu: update free path to take advantage of contig hints percpu: update alloc path to only scan if contig hints are broken percpu: keep track of the best offset for contig hints percpu: skip chunks if the alloc does not fit in the contig hint percpu: add first_bit to keep track of the first free in the bitmap percpu: introduce bitmap metadata blocks percpu: replace area map allocator with bitmap percpu: generalize bitmap (un)populated iterators percpu: increase minimum percpu allocation size and align first regions percpu: introduce nr_empty_pop_pages to help empty page accounting percpu: change the number of pages marked in the first_chunk pop bitmap percpu: combine percpu address checks percpu: modify base_addr to be region specific percpu: setup_first_chunk rename schunk/dchunk to chunk percpu: end chunk area maps page aligned for the populated bitmap percpu: unify allocation of schunk and dchunk percpu: setup_first_chunk remove dyn_size and consolidate logic ...
2017-09-06mm, memory_hotplug: drop zone from build_all_zonelistsMichal Hocko
build_all_zonelists gets a zone parameter to initialize zone's pagesets. There is only a single user which gives a non-NULL zone parameter and that one doesn't really need the rest of the build_all_zonelists (see commit 6dcd73d7011b ("memory-hotplug: allocate zone's pcp before onlining pages")). Therefore remove setup_zone_pageset from build_all_zonelists and call it from its only user directly. This will also remove a pointless zonlists rebuilding which is always good. Link: http://lkml.kernel.org/r/20170721143915.14161-5-mhocko@kernel.org Signed-off-by: Michal Hocko <mhocko@suse.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Shaohua Li <shaohua.li@intel.com> Cc: Toshi Kani <toshi.kani@hpe.com> Cc: Wen Congyang <wency@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-09-06mm: add SLUB free list pointer obfuscationKees Cook
This SLUB free list pointer obfuscation code is modified from Brad Spengler/PaX Team's code in the last public patch of grsecurity/PaX based on my understanding of the code. Changes or omissions from the original code are mine and don't reflect the original grsecurity/PaX code. This adds a per-cache random value to SLUB caches that is XORed with their freelist pointer address and value. This adds nearly zero overhead and frustrates the very common heap overflow exploitation method of overwriting freelist pointers. A recent example of the attack is written up here: http://cyseclabs.com/blog/cve-2016-6187-heap-off-by-one-exploit and there is a section dedicated to the technique the book "A Guide to Kernel Exploitation: Attacking the Core". This is based on patches by Daniel Micay, and refactored to minimize the use of #ifdef. With 200-count cycles of "hackbench -g 20 -l 1000" I saw the following run times: before: mean 10.11882499999999999995 variance .03320378329145728642 stdev .18221905304181911048 after: mean 10.12654000000000000014 variance .04700556623115577889 stdev .21680767106160192064 The difference gets lost in the noise, but if the above is to be taken literally, using CONFIG_FREELIST_HARDENED is 0.07% slower. Link: http://lkml.kernel.org/r/20170802180609.GA66807@beast Signed-off-by: Kees Cook <keescook@chromium.org> Suggested-by: Daniel Micay <danielmicay@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Tycho Andersen <tycho@docker.com> Cc: Alexander Popov <alex.popov@linux.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-09-04Merge branch 'x86-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 mm changes from Ingo Molnar: "PCID support, 5-level paging support, Secure Memory Encryption support The main changes in this cycle are support for three new, complex hardware features of x86 CPUs: - Add 5-level paging support, which is a new hardware feature on upcoming Intel CPUs allowing up to 128 PB of virtual address space and 4 PB of physical RAM space - a 512-fold increase over the old limits. (Supercomputers of the future forecasting hurricanes on an ever warming planet can certainly make good use of more RAM.) Many of the necessary changes went upstream in previous cycles, v4.14 is the first kernel that can enable 5-level paging. This feature is activated via CONFIG_X86_5LEVEL=y - disabled by default. (By Kirill A. Shutemov) - Add 'encrypted memory' support, which is a new hardware feature on upcoming AMD CPUs ('Secure Memory Encryption', SME) allowing system RAM to be encrypted and decrypted (mostly) transparently by the CPU, with a little help from the kernel to transition to/from encrypted RAM. Such RAM should be more secure against various attacks like RAM access via the memory bus and should make the radio signature of memory bus traffic harder to intercept (and decrypt) as well. This feature is activated via CONFIG_AMD_MEM_ENCRYPT=y - disabled by default. (By Tom Lendacky) - Enable PCID optimized TLB flushing on newer Intel CPUs: PCID is a hardware feature that attaches an address space tag to TLB entries and thus allows to skip TLB flushing in many cases, even if we switch mm's. (By Andy Lutomirski) All three of these features were in the works for a long time, and it's coincidence of the three independent development paths that they are all enabled in v4.14 at once" * 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (65 commits) x86/mm: Enable RCU based page table freeing (CONFIG_HAVE_RCU_TABLE_FREE=y) x86/mm: Use pr_cont() in dump_pagetable() x86/mm: Fix SME encryption stack ptr handling kvm/x86: Avoid clearing the C-bit in rsvd_bits() x86/CPU: Align CR3 defines x86/mm, mm/hwpoison: Clear PRESENT bit for kernel 1:1 mappings of poison pages acpi, x86/mm: Remove encryption mask from ACPI page protection type x86/mm, kexec: Fix memory corruption with SME on successive kexecs x86/mm/pkeys: Fix typo in Documentation/x86/protection-keys.txt x86/mm/dump_pagetables: Speed up page tables dump for CONFIG_KASAN=y x86/mm: Implement PCID based optimization: try to preserve old TLB entries using PCID x86: Enable 5-level paging support via CONFIG_X86_5LEVEL=y x86/mm: Allow userspace have mappings above 47-bit x86/mm: Prepare to expose larger address space to userspace x86/mpx: Do not allow MPX if we have mappings above 47-bit x86/mm: Rename tasksize_32bit/64bit to task_size_32bit/64bit() x86/xen: Redefine XEN_ELFNOTE_INIT_P2M using PUD_SIZE * PTRS_PER_PUD x86/mm/dump_pagetables: Fix printout of p4d level x86/mm/dump_pagetables: Generalize address normalization x86/boot: Fix memremap() related build failure ...
2017-09-04Merge branch 'locking-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull locking updates from Ingo Molnar: - Add 'cross-release' support to lockdep, which allows APIs like completions, where it's not the 'owner' who releases the lock, to be tracked. It's all activated automatically under CONFIG_PROVE_LOCKING=y. - Clean up (restructure) the x86 atomics op implementation to be more readable, in preparation of KASAN annotations. (Dmitry Vyukov) - Fix static keys (Paolo Bonzini) - Add killable versions of down_read() et al (Kirill Tkhai) - Rework and fix jump_label locking (Marc Zyngier, Paolo Bonzini) - Rework (and fix) tlb_flush_pending() barriers (Peter Zijlstra) - Remove smp_mb__before_spinlock() and convert its usages, introduce smp_mb__after_spinlock() (Peter Zijlstra) * 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (56 commits) locking/lockdep/selftests: Fix mixed read-write ABBA tests sched/completion: Avoid unnecessary stack allocation for COMPLETION_INITIALIZER_ONSTACK() acpi/nfit: Fix COMPLETION_INITIALIZER_ONSTACK() abuse locking/pvqspinlock: Relax cmpxchg's to improve performance on some architectures smp: Avoid using two cache lines for struct call_single_data locking/lockdep: Untangle xhlock history save/restore from task independence locking/refcounts, x86/asm: Disable CONFIG_ARCH_HAS_REFCOUNT for the time being futex: Remove duplicated code and fix undefined behaviour Documentation/locking/atomic: Finish the document... locking/lockdep: Fix workqueue crossrelease annotation workqueue/lockdep: 'Fix' flush_work() annotation locking/lockdep/selftests: Add mixed read-write ABBA tests mm, locking/barriers: Clarify tlb_flush_pending() barriers locking/lockdep: Make CONFIG_LOCKDEP_CROSSRELEASE and CONFIG_LOCKDEP_COMPLETIONS truly non-interactive locking/lockdep: Explicitly initialize wq_barrier::done::map locking/lockdep: Rename CONFIG_LOCKDEP_COMPLETE to CONFIG_LOCKDEP_COMPLETIONS locking/lockdep: Reword title of LOCKDEP_CROSSRELEASE config locking/lockdep: Make CONFIG_LOCKDEP_CROSSRELEASE part of CONFIG_PROVE_LOCKING locking/refcounts, x86/asm: Implement fast refcount overflow protection locking/lockdep: Fix the rollback and overwrite detection logic in crossrelease ...
2017-09-04Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler updates from Ingo Molnar: "The main changes in this cycle were: - fix affine wakeups (Peter Zijlstra) - improve CPU onlining (and general bootup) scalability on systems with ridiculous number (thousands) of CPUs (Peter Zijlstra) - sched/numa updates (Rik van Riel) - sched/deadline updates (Byungchul Park) - sched/cpufreq enhancements and related cleanups (Viresh Kumar) - sched/debug enhancements (Xie XiuQi) - various fixes" * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (27 commits) sched/debug: Optimize sched_domain sysctl generation sched/topology: Avoid pointless rebuild sched/topology, cpuset: Avoid spurious/wrong domain rebuilds sched/topology: Improve comments sched/topology: Fix memory leak in __sdt_alloc() sched/completion: Document that reinit_completion() must be called after complete_all() sched/autogroup: Fix error reporting printk text in autogroup_create() sched/fair: Fix wake_affine() for !NUMA_BALANCING sched/debug: Intruduce task_state_to_char() helper function sched/debug: Show task state in /proc/sched_debug sched/debug: Use task_pid_nr_ns in /proc/$pid/sched sched/core: Remove unnecessary initialization init_idle_bootup_task() sched/deadline: Change return value of cpudl_find() sched/deadline: Make find_later_rq() choose a closer CPU in topology sched/numa: Scale scan period with tasks in group and shared/private sched/numa: Slow down scan rate if shared faults dominate sched/pelt: Fix false running accounting sched: Mark pick_next_task_dl() and build_sched_domain() as static sched/cpupri: Don't re-initialize 'struct cpupri' sched/deadline: Don't re-initialize 'struct cpudl' ...
2017-09-03utimes: Make utimes y2038 safeDeepa Dinamani
struct timespec is not y2038 safe on 32 bit machines. Replace timespec with y2038 safe struct timespec64. Note that the patch only changes the internals without modifying the syscall interfaces. This will be part of a separate series. Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2017-08-14debugobjects: Make kmemleak ignore debug objectsWaiman Long
The allocated debug objects are either on the free list or in the hashed bucket lists. So they won't get lost. However if both debug objects and kmemleak are enabled and kmemleak scanning is done while some of the debug objects are transitioning from one list to the others, false negative reporting of memory leaks may happen for those objects. For example, [38687.275678] kmemleak: 12 new suspected memory leaks (see /sys/kernel/debug/kmemleak) unreferenced object 0xffff92e98aabeb68 (size 40): comm "ksmtuned", pid 4344, jiffies 4298403600 (age 906.430s) hex dump (first 32 bytes): 00 00 00 00 00 00 00 00 d0 bc db 92 e9 92 ff ff ................ 01 00 00 00 00 00 00 00 38 36 8a 61 e9 92 ff ff ........86.a.... backtrace: [<ffffffff8fa5378a>] kmemleak_alloc+0x4a/0xa0 [<ffffffff8f47c019>] kmem_cache_alloc+0xe9/0x320 [<ffffffff8f62ed96>] __debug_object_init+0x3e6/0x400 [<ffffffff8f62ef01>] debug_object_activate+0x131/0x210 [<ffffffff8f330d9f>] __call_rcu+0x3f/0x400 [<ffffffff8f33117d>] call_rcu_sched+0x1d/0x20 [<ffffffff8f4a183c>] put_object+0x2c/0x40 [<ffffffff8f4a188c>] __delete_object+0x3c/0x50 [<ffffffff8f4a18bd>] delete_object_full+0x1d/0x20 [<ffffffff8fa535c2>] kmemleak_free+0x32/0x80 [<ffffffff8f47af07>] kmem_cache_free+0x77/0x350 [<ffffffff8f453912>] unlink_anon_vmas+0x82/0x1e0 [<ffffffff8f440341>] free_pgtables+0xa1/0x110 [<ffffffff8f44af91>] exit_mmap+0xc1/0x170 [<ffffffff8f29db60>] mmput+0x80/0x150 [<ffffffff8f2a7609>] do_exit+0x2a9/0xd20 The references in the debug objects may also hide a real memory leak. As there is no point in having kmemleak to track debug object allocations, kmemleak checking is now disabled for debug objects. Signed-off-by: Waiman Long <longman@redhat.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/1502718733-8527-1-git-send-email-longman@redhat.com
2017-08-10sched/core: Remove unnecessary initialization init_idle_bootup_task()Cheng Jian
init_idle_bootup_task( ) is called in rest_init( ) to switch the scheduling class of the boot thread to the idle class. the function only sets: idle->sched_class = &idle_sched_class; which has been set in init_idle() called by sched_init(): /* * The idle tasks have their own, simple scheduling class: */ idle->sched_class = &idle_sched_class; We've already set the boot thread to idle class in start_kernel()->sched_init()->init_idle() so it's unnecessary to set it again in start_kernel()->rest_init()->init_idle_bootup_task() Signed-off-by: Cheng Jian <cj.chengjian@huawei.com> Signed-off-by: Xie XiuQi <xiexiuqi@huawei.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: <akpm@linux-foundation.org> Cc: <huawei.libin@huawei.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1501838377-109720-1-git-send-email-cj.chengjian@huawei.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-08-01futex: Allow for compiling out PI supportNicolas Pitre
This makes it possible to preserve basic futex support and compile out the PI support when RT mutexes are not available. Signed-off-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Darren Hart <dvhart@infradead.org> Link: http://lkml.kernel.org/r/alpine.LFD.2.20.1708010024190.5981@knanqh.ubzr
2017-07-26percpu: replace area map allocator with bitmapDennis Zhou (Facebook)
The percpu memory allocator is experiencing scalability issues when allocating and freeing large numbers of counters as in BPF. Additionally, there is a corner case where iteration is triggered over all chunks if the contig_hint is the right size, but wrong alignment. This patch replaces the area map allocator with a basic bitmap allocator implementation. Each subsequent patch will introduce new features and replace full scanning functions with faster non-scanning options when possible. Implementation: This patchset removes the area map allocator in favor of a bitmap allocator backed by metadata blocks. The primary goal is to provide consistency in performance and memory footprint with a focus on small allocations (< 64 bytes). The bitmap removes the heavy memmove from the freeing critical path and provides a consistent memory footprint. The metadata blocks provide a bound on the amount of scanning required by maintaining a set of hints. In an effort to make freeing fast, the metadata is updated on the free path if the new free area makes a page free, a block free, or spans across blocks. This causes the chunk's contig hint to potentially be smaller than what it could allocate by up to the smaller of a page or a block. If the chunk's contig hint is contained within a block, a check occurs and the hint is kept accurate. Metadata is always kept accurate on allocation, so there will not be a situation where a chunk has a later contig hint than available. Evaluation: I have primarily done testing against a simple workload of allocation of 1 million objects (2^20) of varying size. Deallocation was done by in order, alternating, and in reverse. These numbers were collected after rebasing ontop of a80099a152. I present the worst-case numbers here: Area Map Allocator: Object Size | Alloc Time (ms) | Free Time (ms) ---------------------------------------------- 4B | 310 | 4770 16B | 557 | 1325 64B | 436 | 273 256B | 776 | 131 1024B | 3280 | 122 Bitmap Allocator: Object Size | Alloc Time (ms) | Free Time (ms) ---------------------------------------------- 4B | 490 | 70 16B | 515 | 75 64B | 610 | 80 256B | 950 | 100 1024B | 3520 | 200 This data demonstrates the inability for the area map allocator to handle less than ideal situations. In the best case of reverse deallocation, the area map allocator was able to perform within range of the bitmap allocator. In the worst case situation, freeing took nearly 5 seconds for 1 million 4-byte objects. The bitmap allocator dramatically improves the consistency of the free path. The small allocations performed nearly identical regardless of the freeing pattern. While it does add to the allocation latency, the allocation scenario here is optimal for the area map allocator. The area map allocator runs into trouble when it is allocating in chunks where the latter half is full. It is difficult to replicate this, so I present a variant where the pages are second half filled. Freeing was done sequentially. Below are the numbers for this scenario: Area Map Allocator: Object Size | Alloc Time (ms) | Free Time (ms) ---------------------------------------------- 4B | 4118 | 4892 16B | 1651 | 1163 64B | 598 | 285 256B | 771 | 158 1024B | 3034 | 160 Bitmap Allocator: Object Size | Alloc Time (ms) | Free Time (ms) ---------------------------------------------- 4B | 481 | 67 16B | 506 | 69 64B | 636 | 75 256B | 892 | 90 1024B | 3262 | 147 The data shows a parabolic curve of performance for the area map allocator. This is due to the memmove operation being the dominant cost with the lower object sizes as more objects are packed in a chunk and at higher object sizes, the traversal of the chunk slots is the dominating cost. The bitmap allocator suffers this problem as well. The above data shows the inability to scale for the allocation path with the area map allocator and that the bitmap allocator demonstrates consistent performance in general. The second problem of additional scanning can result in the area map allocator completing in 52 minutes when trying to allocate 1 million 4-byte objects with 8-byte alignment. The same workload takes approximately 16 seconds to complete for the bitmap allocator. V2: Fixed a bug in pcpu_alloc_first_chunk end_offset was setting the bitmap using bytes instead of bits. Added a comment to pcpu_cnt_pop_pages to explain bitmap_weight. Signed-off-by: Dennis Zhou <dennisszhou@gmail.com> Reviewed-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2017-07-18x86, swiotlb: Add memory encryption supportTom Lendacky
Since DMA addresses will effectively look like 48-bit addresses when the memory encryption mask is set, SWIOTLB is needed if the DMA mask of the device performing the DMA does not support 48-bits. SWIOTLB will be initialized to create decrypted bounce buffers for use by these devices. Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Cc: Alexander Potapenko <glider@google.com> Cc: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Borislav Petkov <bp@alien8.de> Cc: Brijesh Singh <brijesh.singh@amd.com> Cc: Dave Young <dyoung@redhat.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Larry Woodman <lwoodman@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Matt Fleming <matt@codeblueprint.co.uk> Cc: Michael S. Tsirkin <mst@redhat.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Radim Krčmář <rkrcmar@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Toshimitsu Kani <toshi.kani@hpe.com> Cc: kasan-dev@googlegroups.com Cc: kvm@vger.kernel.org Cc: linux-arch@vger.kernel.org Cc: linux-doc@vger.kernel.org Cc: linux-efi@vger.kernel.org Cc: linux-mm@kvack.org Link: http://lkml.kernel.org/r/aa2d29b78ae7d508db8881e46a3215231b9327a7.1500319216.git.thomas.lendacky@amd.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-07-17VFS: Differentiate mount flags (MS_*) from internal superblock flagsDavid Howells
Differentiate the MS_* flags passed to mount(2) from the internal flags set in the super_block's s_flags. s_flags are now called SB_*, with the names and the values for the moment mirroring the MS_* flags that they're equivalent to. In this patch, just the headers are altered and some kernel code where blind automated conversion isn't necessarily correct. Note that this shows up some interesting issues: (1) Some MS_* flags get translated to MNT_* flags (such as MS_NODEV -> MNT_NODEV) without passing this on to the filesystem, but some filesystems set such flags anyway. (2) The ->remount_fs() methods of some filesystems adjust the *flags argument by setting MS_* flags in it, such as MS_NOATIME - but these flags are then scrubbed by do_remount_sb() (only the occupants of MS_RMT_MASK are permitted: MS_RDONLY, MS_SYNCHRONOUS, MS_MANDLOCK, MS_I_VERSION and MS_LAZYTIME) I'm not sure what's the best way to solve all these cases. Suggested-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: David Howells <dhowells@redhat.com>
2017-07-17VFS: Convert sb->s_flags & MS_RDONLY to sb_rdonly(sb)David Howells
Firstly by applying the following with coccinelle's spatch: @@ expression SB; @@ -SB->s_flags & MS_RDONLY +sb_rdonly(SB) to effect the conversion to sb_rdonly(sb), then by applying: @@ expression A, SB; @@ ( -(!sb_rdonly(SB)) && A +!sb_rdonly(SB) && A | -A != (sb_rdonly(SB)) +A != sb_rdonly(SB) | -A == (sb_rdonly(SB)) +A == sb_rdonly(SB) | -!(sb_rdonly(SB)) +!sb_rdonly(SB) | -A && (sb_rdonly(SB)) +A && sb_rdonly(SB) | -A || (sb_rdonly(SB)) +A || sb_rdonly(SB) | -(sb_rdonly(SB)) != A +sb_rdonly(SB) != A | -(sb_rdonly(SB)) == A +sb_rdonly(SB) == A | -(sb_rdonly(SB)) && A +sb_rdonly(SB) && A | -(sb_rdonly(SB)) || A +sb_rdonly(SB) || A ) @@ expression A, B, SB; @@ ( -(sb_rdonly(SB)) ? 1 : 0 +sb_rdonly(SB) | -(sb_rdonly(SB)) ? A : B +sb_rdonly(SB) ? A : B ) to remove left over excess bracketage and finally by applying: @@ expression A, SB; @@ ( -(A & MS_RDONLY) != sb_rdonly(SB) +(bool)(A & MS_RDONLY) != sb_rdonly(SB) | -(A & MS_RDONLY) == sb_rdonly(SB) +(bool)(A & MS_RDONLY) == sb_rdonly(SB) ) to make comparisons against the result of sb_rdonly() (which is a bool) work correctly. Signed-off-by: David Howells <dhowells@redhat.com>
2017-07-12random: do not ignore early device randomnessKees Cook
The add_device_randomness() function would ignore incoming bytes if the crng wasn't ready. This additionally makes sure to make an early enough call to add_latent_entropy() to influence the initial stack canary, which is especially important on non-x86 systems where it stays the same through the life of the boot. Link: http://lkml.kernel.org/r/20170626233038.GA48751@beast Signed-off-by: Kees Cook <keescook@chromium.org> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jessica Yu <jeyu@redhat.com> Cc: Steven Rostedt (VMware) <rostedt@goodmis.org> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Tejun Heo <tj@kernel.org> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Cc: Nicholas Piggin <npiggin@gmail.com> Cc: AKASHI Takahiro <takahiro.akashi@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-07-06mm: allow slab_nomerge to be set at build timeKees Cook
Some hardened environments want to build kernels with slab_nomerge already set (so that they do not depend on remembering to set the kernel command line option). This is desired to reduce the risk of kernel heap overflows being able to overwrite objects from merged caches and changes the requirements for cache layout control, increasing the difficulty of these attacks. By keeping caches unmerged, these kinds of exploits can usually only damage objects in the same cache (though the risk to metadata exploitation is unchanged). Link: http://lkml.kernel.org/r/20170620230911.GA25238@beast Signed-off-by: Kees Cook <keescook@chromium.org> Cc: Daniel Micay <danielmicay@gmail.com> Cc: David Windsor <dave@nullcore.net> Cc: Eric Biggers <ebiggers3@gmail.com> Cc: Christoph Lameter <cl@linux.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Daniel Micay <danielmicay@gmail.com> Cc: David Windsor <dave@nullcore.net> Cc: Eric Biggers <ebiggers3@gmail.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: "Rafael J. Wysocki" <rafael.j.wysocki@intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@kernel.org> Cc: Mauro Carvalho Chehab <mchehab@kernel.org> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Andy Lutomirski <luto@kernel.org> Cc: Nicolas Pitre <nicolas.pitre@linaro.org> Cc: Tejun Heo <tj@kernel.org> Cc: Daniel Mack <daniel@zonque.org> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Helge Deller <deller@gmx.de> Cc: Rik van Riel <riel@redhat.com> Cc: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-07-06Merge branch 'for-4.13' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup changes from Tejun Heo: - Waiman made the debug controller work and a lot more useful on cgroup2 - There were a couple issues with cgroup subtree delegation. The documentation on delegating to a non-root user was missing some part and cgroup namespace support wasn't factoring in delegation at all. The documentation is updated and the now there is a mount option to make cgroup namespace fit for delegation * 'for-4.13' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: cgroup: implement "nsdelegate" mount option cgroup: restructure cgroup_procs_write_permission() cgroup: "cgroup.subtree_control" should be writeable by delegatee cgroup: fix lockdep warning in debug controller cgroup: refactor cgroup_masks_read() in the debug controller cgroup: make debug an implicit controller on cgroup2 cgroup: Make debug cgroup support v2 and thread mode cgroup: Make Kconfig prompt of debug cgroup more accurate cgroup: Move debug cgroup to its own file cgroup: Keep accurate count of tasks in each css_set
2017-07-03Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler updates from Ingo Molnar: "The main changes in this cycle were: - Add the SYSTEM_SCHEDULING bootup state to move various scheduler debug checks earlier into the bootup. This turns silent and sporadically deadly bugs into nice, deterministic splats. Fix some of the splats that triggered. (Thomas Gleixner) - A round of restructuring and refactoring of the load-balancing and topology code (Peter Zijlstra) - Another round of consolidating ~20 of incremental scheduler code history: this time in terms of wait-queue nomenclature. (I didn't get much feedback on these renaming patches, and we can still easily change any names I might have misplaced, so if anyone hates a new name, please holler and I'll fix it.) (Ingo Molnar) - sched/numa improvements, fixes and updates (Rik van Riel) - Another round of x86/tsc scheduler clock code improvements, in hope of making it more robust (Peter Zijlstra) - Improve NOHZ behavior (Frederic Weisbecker) - Deadline scheduler improvements and fixes (Luca Abeni, Daniel Bristot de Oliveira) - Simplify and optimize the topology setup code (Lauro Ramos Venancio) - Debloat and decouple scheduler code some more (Nicolas Pitre) - Simplify code by making better use of llist primitives (Byungchul Park) - ... plus other fixes and improvements" * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (103 commits) sched/cputime: Refactor the cputime_adjust() code sched/debug: Expose the number of RT/DL tasks that can migrate sched/numa: Hide numa_wake_affine() from UP build sched/fair: Remove effective_load() sched/numa: Implement NUMA node level wake_affine() sched/fair: Simplify wake_affine() for the single socket case sched/numa: Override part of migrate_degrades_locality() when idle balancing sched/rt: Move RT related code from sched/core.c to sched/rt.c sched/deadline: Move DL related code from sched/core.c to sched/deadline.c sched/cpuset: Only offer CONFIG_CPUSETS if SMP is enabled sched/fair: Spare idle load balancing on nohz_full CPUs nohz: Move idle balancer registration to the idle path sched/loadavg: Generalize "_idle" naming to "_nohz" sched/core: Drop the unused try_get_task_struct() helper function sched/fair: WARN() and refuse to set buddy when !se->on_rq sched/debug: Fix SCHED_WARN_ON() to return a value on !CONFIG_SCHED_DEBUG as well sched/wait: Disambiguate wq_entry->task_list and wq_head->task_list naming sched/wait: Move bit_wait_table[] and related functionality from sched/core.c to sched/wait_bit.c sched/wait: Split out the wait_bit*() APIs from <linux/wait.h> into <linux/wait_bit.h> sched/wait: Re-adjust macro line continuation backslashes in <linux/wait.h> ...
2017-06-23sched/cpuset: Only offer CONFIG_CPUSETS if SMP is enabledNicolas Pitre
Make CONFIG_CPUSETS=y depend on SMP as this feature makes no sense on UP. This allows for configuring out cpuset_cpumask_can_shrink() and task_can_attach() entirely, which shrinks the kernel a bit. Signed-off-by: Nicolas Pitre <nico@linaro.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20170614171926.8345-2-nicolas.pitre@linaro.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-06-14cgroup: Make Kconfig prompt of debug cgroup more accurateWaiman Long
The Kconfig prompt and description of the debug cgroup controller more accurate by saying that it is for debug purpose only and its interfaces are unstable. Signed-off-by: Waiman Long <longman@redhat.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2017-06-08rcu: Move RCU non-debug Kconfig options to kernel/rcuPaul E. McKenney
RCU's Kconfig options are scattered, and there are enough of them that it would be good for them to be more centralized. This commit therefore extracts RCU's Kconfig options from init/Kconfig into a new kernel/rcu/Kconfig file. Reported-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2017-06-08rcu: Eliminate NOCBs CPU-state Kconfig optionsPaul E. McKenney
The CONFIG_RCU_NOCB_CPU_ALL, CONFIG_RCU_NOCB_CPU_NONE, and CONFIG_RCU_NOCB_CPU_ZERO Kconfig options are used only in testing and are redundant with the rcu_nocbs= boot parameter. This commit therefore removes these three Kconfig options and adjusts the rcutorture scripts to use the boot parameter instead. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2017-06-08rcu: Remove debugfs tracingPaul E. McKenney
RCU's debugfs tracing used to be the only reasonable low-level debug information available, but ftrace and event tracing has since surpassed the RCU debugfs level of usefulness. This commit therefore removes RCU's debugfs tracing. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2017-06-08srcu: Remove Classic SRCUPaul E. McKenney
Classic SRCU was only ever intended to be a fallback in case of issues with Tree/Tiny SRCU, and the latter two are doing quite well in testing. This commit therefore removes Classic SRCU. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2017-06-08rcu: Remove the RCU_KTHREAD_PRIO Kconfig optionPaul E. McKenney
Anything that can be done with the RCU_KTHREAD_PRIO Kconfig option can also be done with the rcutree.kthread_prio kernel boot parameter. This commit therefore removes this Kconfig option. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Rik van Riel <riel@redhat.com>
2017-06-08srcu: Apply trivial callback lists to shrink Tiny SRCUPaul E. McKenney
The rcu_segcblist structure provides quite a bit of functionality, and Tiny SRCU needs almost none of it. So this commit replaces Tiny SRCU's uses of rcu_segcblist with a simple singly linked list with tail pointer. This change significantly reduces Tiny SRCU's memory footprint, more than making up for the growth caused by the creation of rcu_segcblist.c Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2017-06-08srcu: Make SRCU be once again optionalPaul E. McKenney
Commit d160a727c40e ("srcu: Make SRCU be built by default") in response to build errors, which were caused by code that included srcu.h despite !SRCU. However, srcutiny.o is almost 2K of code, which is not insignificant for those attempting to run the Linux kernel on IoT devices. This commit therefore makes SRCU be once again optional, and adjusts srcu.h to allow error-free inclusion in !SRCU kernel builds. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Nicolas Pitre <nico@linaro.org>
2017-05-23sched/core: Enable might_sleep() and smp_processor_id() checks earlyThomas Gleixner
might_sleep() and smp_processor_id() checks are enabled after the boot process is done. That hides bugs in the SMP bringup and driver initialization code. Enable it right when the scheduler starts working, i.e. when init task and kthreadd have been created and right before the idle task enables preemption. Tested-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Acked-by: Mark Rutland <mark.rutland@arm.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/20170516184736.272225698@linutronix.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-05-23init: Pin init task to the boot CPU, initiallyThomas Gleixner
Some of the boot code in init_kernel_freeable() which runs before SMP bringup assumes (rightfully) that it runs on the boot CPU and therefore can use smp_processor_id() in preemptible context. That works so far because the smp_processor_id() check starts to be effective after smp bringup. That's just wrong. Starting with SMP bringup and the ability to move threads around, smp_processor_id() in preemptible context is broken. Aside of that it does not make sense to allow init to run on all CPUs before sched_smp_init() has been run. Pin the init to the boot CPU so the existing code can continue to use smp_processor_id() without triggering the checks when the enabling of those checks starts earlier. Tested-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/20170516184734.943149935@linutronix.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-05-10Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull RCU updates from Ingo Molnar: "The main changes are: - Debloat RCU headers - Parallelize SRCU callback handling (plus overlapping patches) - Improve the performance of Tree SRCU on a CPU-hotplug stress test - Documentation updates - Miscellaneous fixes" * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (74 commits) rcu: Open-code the rcu_cblist_n_lazy_cbs() function rcu: Open-code the rcu_cblist_n_cbs() function rcu: Open-code the rcu_cblist_empty() function rcu: Separately compile large rcu_segcblist functions srcu: Debloat the <linux/rcu_segcblist.h> header srcu: Adjust default auto-expediting holdoff srcu: Specify auto-expedite holdoff time srcu: Expedite first synchronize_srcu() when idle srcu: Expedited grace periods with reduced memory contention srcu: Make rcutorture writer stalls print SRCU GP state srcu: Exact tracking of srcu_data structures containing callbacks srcu: Make SRCU be built by default srcu: Fix Kconfig botch when SRCU not selected rcu: Make non-preemptive schedule be Tasks RCU quiescent state srcu: Expedite srcu_schedule_cbs_snp() callback invocation srcu: Parallelize callback handling kvm: Move srcu_struct fields to end of struct kvm rcu: Fix typo in PER_RCU_NODE_PERIOD header comment rcu: Use true/false in assignment to bool rcu: Use bool value directly ...
2017-05-08Merge tag 'tty-4.12-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial updates from Greg KH: "Here is the "big" TTY/Serial patch updates for 4.12-rc1 Not a lot of new things here, the normal number of serial driver updates and additions, tiny bugs fixed, and some core files split up to make future changes a bit easier for Nicolas's "tiny-tty" work. All of these have been in linux-next for a while" * tag 'tty-4.12-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (62 commits) serial: small Makefile reordering tty: split job control support into a file of its own tty: move baudrate handling code to a file of its own console: move console_init() out of tty_io.c serial: 8250_early: Add earlycon support for Palmchip UART tty: pl011: use "qdf2400_e44" as the earlycon name for QDF2400 E44 vt: make mouse selection of non-ASCII consistent vt: set mouse selection word-chars to gpm's default imx-serial: Reduce RX DMA startup latency when opening for reading serial: omap: suspend device on probe errors serial: omap: fix runtime-pm handling on unbind tty: serial: omap: add UPF_BOOT_AUTOCONF flag for DT init serial: samsung: Remove useless spinlock serial: samsung: Add missing checks for dma_map_single failure serial: samsung: Use right device for DMA-mapping calls serial: imx: setup DCEDTE early and ensure DCD and RI irqs to be off tty: fix comment typo s/repsonsible/responsible/ tty: amba-pl011: Fix spurious TX interrupts serial: xuartps: Enable clocks in the pm disable case also serial: core: Re-use struct uart_port {name} field ...
2017-05-08initramfs: use vfs_stat/lstat directlyArnd Bergmann
sys_newlstat is a system call implementation that is meant for user space, and that copies kernel-internal data structure to the user format, which is not needed for in-kernel users. Further, as we rearrange the system call implementation so we can extend it with 64-bit time_t, the prototype for sys_newlstat changes. This changes the initramfs code to use vfs_lstat directly, to get it out of the way of the time_t changes, and make it slightly more efficient in the process. Along the same lines we also replace sys_stat and sys_stat64 with vfs_stat. Link: http://lkml.kernel.org/r/20170314214932.4052842-1-arnd@arndb.de Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-05-08initramfs: provide a way to ignore image provided by bootloaderDaniel Thompson
Many "embedded" architectures provide CMDLINE_FORCE to allow the kernel to override the command line provided by an inflexible bootloader. However there is currrently no way for the kernel to override the initramfs image provided by the bootloader meaning there are still ways for bootloaders to make things difficult for us. Fix this by introducing INITRAMFS_FORCE which can prevent the kernel from loading the bootloader supplied image. We use CMDLINE_FORCE (and its friend CMDLINE_EXTEND) to imply that the system has an inflexible bootloader. This allow us to avoid presenting this config option to users of systems where inflexible bootloaders aren't usually a problem. Link: http://lkml.kernel.org/r/20170217121940.30126-1-daniel.thompson@linaro.org Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
