This should make the help text of SYSFS_DEPRECATED more clear, that this
is _not_ about (what some people think it is) suppressing a few symlinks
and variables, but a different sysfs _layout_ with new features.
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Add missing printk loglevel in start_kernel
Signed-off-by: Ron Lee <ron@debian.org>
Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
Impact: Bug fix (we should not show this menu on irrelevant architectures)
Make the config machinery to drive the gzip/bzip2/lzma selection
dependent on the architecture advertising HAVE_KERNEL_* so that we
don't display this for architectures where it doesn't matter.
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Impact: Code simplification
Instead of open-coding testing for initramfs compression formats, use
a table.
Impact: New code for initramfs decompression, new features
This is the second part of the bzip2/lzma patch
The bzip patch is based on an idea by Christian Ludwig, includes support for
compressing the kernel with bzip2 or lzma rather than gzip. Both
compressors give smaller sizes than gzip. Lzma's decompresses faster
than bzip2.
It also supports ramdisks and initramfs' compressed using these two
compressors.
The functionality has been successfully used for a couple of years by
the udpcast project
This version applies to "tip" kernel 2.6.28
This part contains:
- support for new compressions (bzip2 and lzma) in initramfs and
old-style ramdisk
- config dialog for kernel compression (but new kernel compressions
not yet supported)
Signed-off-by: Alain Knaff <alain@knaff.lu>
Now that nothing depends on it any more, remove CONFIG_KMOD.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
* 'cpus4096-for-linus-3' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (77 commits)
x86: setup_per_cpu_areas() cleanup
cpumask: fix compile error when CONFIG_NR_CPUS is not defined
cpumask: use alloc_cpumask_var_node where appropriate
cpumask: convert shared_cpu_map in acpi_processor* structs to cpumask_var_t
x86: use cpumask_var_t in acpi/boot.c
x86: cleanup some remaining usages of NR_CPUS where s/b nr_cpu_ids
sched: put back some stack hog changes that were undone in kernel/sched.c
x86: enable cpus display of kernel_max and offlined cpus
ia64: cpumask fix for is_affinity_mask_valid()
cpumask: convert RCU implementations, fix
xtensa: define __fls
mn10300: define __fls
m32r: define __fls
h8300: define __fls
frv: define __fls
cris: define __fls
cpumask: CONFIG_DISABLE_OBSOLETE_CPUMASK_FUNCTIONS
cpumask: zero extra bits in alloc_cpumask_var_node
cpumask: replace for_each_cpu_mask_nr with for_each_cpu in kernel/time/
cpumask: convert mm/
* 'cpus4096-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (66 commits)
x86: export vector_used_by_percpu_irq
x86: use logical apicid in x2apic_cluster's x2apic_cpu_mask_to_apicid_and()
sched: nominate preferred wakeup cpu, fix
x86: fix lguest used_vectors breakage, -v2
x86: fix warning in arch/x86/kernel/io_apic.c
sched: fix warning in kernel/sched.c
sched: move test_sd_parent() to an SMP section of sched.h
sched: add SD_BALANCE_NEWIDLE at MC and CPU level for sched_mc>0
sched: activate active load balancing in new idle cpus
sched: bias task wakeups to preferred semi-idle packages
sched: favour lower logical cpu number for sched_mc balance
sched: framework for sched_mc/smt_power_savings=N
sched: convert BALANCE_FOR_xx_POWER to inline functions
x86: use possible_cpus=NUM to extend the possible cpus allowed
x86: fix cpu_mask_to_apicid_and to include cpu_online_mask
x86: update io_apic.c to the new cpumask code
x86: Introduce topology_core_cpumask()/topology_thread_cpumask()
x86: xen: use smp_call_function_many()
x86: use work_on_cpu in x86/kernel/cpu/mcheck/mce_amd_64.c
Fixed up trivial conflict in kernel/time/tick-sched.c manually
Impact: cleanup
We now have a cleaner check for gcc 4.1.0/4.1.1 trouble in
include/linux/compiler-gcc4.h, so remove the 4.1.0 quirk from
init/main.c.
Reported-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Acked-by: Sam Ravnborg <sam@ravnborg.org>
Impact: cleanup
There's one obvious place to use it: to find the highest possible cpu.
Impact: use new API
cpu_*_map are going away in favour of cpu_*_mask, but const pointers.
So we have accessors where we really do want to frob them. Archs
will also need the (trivial) conversion before we can finally remove
cpu_*_map.
Signed-off-by: Mike Travis <travis@sgi.com>
* 'irq-fixes-for-linus-4' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
sparseirq: move __weak symbols into separate compilation unit
sparseirq: work around __weak alias bug
sparseirq: fix hang with !SPARSE_IRQ
sparseirq: set lock_class for legacy irq when sparse_irq is selected
sparseirq: work around compiler optimizing away __weak functions
sparseirq: fix desc->lock init
sparseirq: do not printk when migrating IRQ descriptors
sparseirq: remove duplicated arch_early_irq_init()
irq: simplify for_each_irq_desc() usage
proc: remove ifdef CONFIG_SPARSE_IRQ from stat.c
irq: for_each_irq_desc() move to irqnr.h
hrtimer: remove #include <linux/irq.h>
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
arch/x86/include/asm/pda.h
kernel/fork.c
mm/slub.c
* 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, sparseirq: clean up Kconfig entry
x86: turn CONFIG_SPARSE_IRQ off by default
sparseirq: fix numa_migrate_irq_desc dependency and comments
sparseirq: add kernel-doc notation for new member in irq_desc, -v2
locking, irq: enclose irq_desc_lock_class in CONFIG_LOCKDEP
sparseirq, xen: make sure irq_desc is allocated for interrupts
sparseirq: fix !SMP building, #2
x86, sparseirq: move irq_desc according to smp_affinity, v7
proc: enclose desc variable of show_stat() in CONFIG_SPARSE_IRQ
sparse irqs: add irqnr.h to the user headers list
sparse irqs: handle !GENIRQ platforms
sparseirq: fix !SMP && !PCI_MSI && !HT_IRQ build
sparseirq: fix Alpha build failure
sparseirq: fix typo in !CONFIG_IO_APIC case
x86, MSI: pass irq_cfg and irq_desc
x86: MSI start irq numbering from nr_irqs_gsi
x86: use NR_IRQS_LEGACY
sparse irq_desc[] array: core kernel and x86 changes
genirq: record IRQ_LEVEL in irq_desc[]
irq.h: remove padding from irq_desc on 64bits
* 'core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (63 commits)
stacktrace: provide save_stack_trace_tsk() weak alias
rcu: provide RCU options on non-preempt architectures too
printk: fix discarding message when recursion_bug
futex: clean up futex_(un)lock_pi fault handling
"Tree RCU": scalable classic RCU implementation
futex: rename field in futex_q to clarify single waiter semantics
x86/swiotlb: add default swiotlb_arch_range_needs_mapping
x86/swiotlb: add default phys<->bus conversion
x86: unify pci iommu setup and allow swiotlb to compile for 32 bit
x86: add swiotlb allocation functions
swiotlb: consolidate swiotlb info message printing
swiotlb: support bouncing of HighMem pages
swiotlb: factor out copy to/from device
swiotlb: add arch hook to force mapping
swiotlb: allow architectures to override phys<->bus<->phys conversions
swiotlb: add comment where we handle the overflow of a dma mask on 32 bit
rcu: fix rcutorture behavior during reboot
resources: skip sanity check of busy resources
swiotlb: move some definitions to header
swiotlb: allow architectures to override swiotlb pool allocation
Fix up trivial conflicts in
arch/x86/kernel/Makefile
arch/x86/mm/init_32.c
include/linux/hardirq.h
as per Ingo's suggestions.
Impact: new tracer plugin
This patch adapts kmemtrace raw events tracing to the unified tracing API.
To enable and use this tracer, just do the following:
echo kmemtrace > /debugfs/tracing/current_tracer
cat /debugfs/tracing/trace
You will have the following output:
# tracer: kmemtrace
# ALLOC TYPE REQ GIVEN FLAGS POINTER NODE CALLER
# FREE | | | | | | | |
type_id 1 call_site 18446744071565527833 ptr 18446612134395152256
type_id 0 call_site 18446744071565585597 ptr 18446612134405955584 bytes_req 4096 bytes_alloc 4096 gfp_flags 208 node -1
type_id 1 call_site 18446744071565585534 ptr 18446612134405955584
type_id 0 call_site 18446744071565636711 ptr 18446612134345164672 bytes_req 240 bytes_alloc 240 gfp_flags 208 node -1
type_id 0 call_site 18446744071565636711 ptr 18446612134345164912 bytes_req 240 bytes_alloc 240 gfp_flags 208 node -1
type_id 0 call_site 18446744071565636711 ptr 18446612134345165152 bytes_req 240 bytes_alloc 240 gfp_flags 208 node -1
type_id 0 call_site 18446744071566144042 ptr 18446612134346191680 bytes_req 1304 bytes_alloc 1312 gfp_flags 208 node -1
That was to stay backward compatible with the format output produced in
inux/tracepoint.h.
This is the default ouput, but note that I tried something else.
If you change an option:
echo kmem_minimalistic > /debugfs/trace_options
and then cat /debugfs/trace, you will have the following output:
# tracer: kmemtrace
- C 0xffff88007c088780 file_free_rcu
+ K 4096 4096 000000d0 0xffff88007cad6000 -1 getname
- C 0xffff88007cad6000 putname
+ K 240 240 000000d0 0xffff8800790dc780 -1 d_alloc
+ K 240 240 000000d0 0xffff8800790dc870 -1 d_alloc
+ K 240 240 000000d0 0xffff8800790dc960 -1 d_alloc
+ K 1304 1312 000000d0 0xffff8800791d7340 -1 reiserfs_alloc_inode
+ K 992 1000 000000d0 0xffff880079045b58 -1 alloc_inode
+ K 768 1024 000080d0 0xffff88007c096400 -1 alloc_pipe_info
+ K 240 240 000000d0 0xffff8800790dca50 -1 d_alloc
+ K 272 320 000080d0 0xffff88007c088780 -1 get_empty_filp
+ K 272 320 000080d0 0xffff88007c088000 -1 get_empty_filp
Yeah I shall confess kmem_minimalistic should be: kmem_alternative.
Whatever, I find it more readable but this a personal opinion of course.
We can drop it if you want.
On the ALLOC/FREE column, + means an allocation and - a free.
On the type column, you have K = kmalloc, C = cache, P = page
I would like the flags to be GFP_* strings but that would not be easy to not
break the column with strings....
About the node...it seems to always be -1. I don't know why but that shouldn't
be difficult to find.
I moved linux/tracepoint.h to trace/tracepoint.h as well. I think that would
be more easy to find the tracer headers if they are all in their common
directory.
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6 into tracing/kmemtrace
kmemtrace provides tracing for slab allocator functions, such as kmalloc,
kfree, kmem_cache_alloc, kmem_cache_free etc.. Collected data is then fed
to the userspace application in order to analyse allocation hotspots,
internal fragmentation and so on, making it possible to see how well an
allocator performs, as well as debug and profile kernel code.
Signed-off-by: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro>
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
GCC has a bug with __weak alias functions: if the functions are in
the same compilation unit as their call site, GCC can decide to
inline them - and thus rob the linker of the opportunity to override
the weak alias with the real thing.
So move all the IRQ handling related __weak symbols to kernel/irq/chip.c.
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next: (25 commits)
allow stripping of generated symbols under CONFIG_KALLSYMS_ALL
kbuild: strip generated symbols from *.ko
kbuild: simplify use of genksyms
kernel-doc: check for extra kernel-doc notations
kbuild: add headerdep used to detect inclusion cycles in header files
kbuild: fix string equality testing in tags.sh
kbuild: fix make tags/cscope
kbuild: fix make incompatibility
kbuild: remove TAR_IGNORE
setlocalversion: add git-svn support
setlocalversion: print correct subversion revision
scripts: improve the decodecode script
scripts/package: allow custom options to rpm
genksyms: allow to ignore symbol checksum changes
genksyms: track symbol checksum changes
tags and cscope support really belongs in a shell script
kconfig: fix options to check-lxdialog.sh
kbuild: gen_init_cpio expands shell variables in file names
remove bashisms from scripts/extract-ikconfig
kbuild: teach mkmakfile to be silent
* 'tracing-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (241 commits)
sched, trace: update trace_sched_wakeup()
tracing/ftrace: don't trace on early stage of a secondary cpu boot, v3
Revert "x86: disable X86_PTRACE_BTS"
ring-buffer: prevent false positive warning
ring-buffer: fix dangling commit race
ftrace: enable format arguments checking
x86, bts: memory accounting
x86, bts: add fork and exit handling
ftrace: introduce tracing_reset_online_cpus() helper
tracing: fix warnings in kernel/trace/trace_sched_switch.c
tracing: fix warning in kernel/trace/trace.c
tracing/ring-buffer: remove unused ring_buffer size
trace: fix task state printout
ftrace: add not to regex on filtering functions
trace: better use of stack_trace_enabled for boot up code
trace: add a way to enable or disable the stack tracer
x86: entry_64 - introduce FTRACE_ frame macro v2
tracing/ftrace: add the printk-msg-only option
tracing/ftrace: use preempt_enable_no_resched_notrace in ring_buffer_time_stamp()
x86, bts: correctly report invalid bts records
Fixed up trivial conflict in scripts/recordmcount.pl due to SH bits
being already partly merged by the SH merge.
Impact: fix panic on null pointer with sparseirq
Some GCC versions seem to inline the weak global function,
when that function is empty.
Work it around, by making the functions return a (dummy) integer.
Signed-off-by: Yinghai <yinghai@kernel.org>
Impact: build fix
Some old architectures still do not use kernel/Kconfig.preempt, so the
moving of the RCU options there broke their build:
In file included from /home/mingo/tip/include/linux/sem.h:81,
from /home/mingo/tip/include/linux/sched.h:69,
from /home/mingo/tip/arch/alpha/kernel/asm-offsets.c:9:
/home/mingo/tip/include/linux/rcupdate.h:62:2: error: #error "Unknown RCU implementation specified to kernel configuration"
Move these options back to init/Kconfig, which every architecture
includes.
Building upon parts of the module stripping patch, this patch
introduces similar stripping for vmlinux when CONFIG_KALLSYMS_ALL=y.
Using CONFIG_KALLSYMS_STRIP_GENERATED reduces the overhead of
CONFIG_KALLSYMS_ALL from 245k/310k to 65k/80k for the (i386/x86-64)
kernels I tested with.
The patch also does away with the need to special case the kallsyms-
internal symbols by making them available even in the first linking
stage.
While it is a generated file, the patch includes the changes to
scripts/genksyms/keywords.c_shipped, as I'm unsure what the procedure
here is.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
This patch fixes a long-standing performance bug in classic RCU that
results in massive internal-to-RCU lock contention on systems with
more than a few hundred CPUs. Although this patch creates a separate
flavor of RCU for ease of review and patch maintenance, it is intended
to replace classic RCU.
This patch still handles stress better than does mainline, so I am still
calling it ready for inclusion. This patch is against the -tip tree.
Nevertheless, experience on an actual 1000+ CPU machine would still be
most welcome.
Most of the changes noted below were found while creating an rcutiny
(which should permit ejecting the current rcuclassic) and while doing
detailed line-by-line documentation.
Updates from v9 (http://lkml.org/lkml/2008/12/2/334):
o Fixes from remainder of line-by-line code walkthrough,
including comment spelling, initialization, undesirable
narrowing due to type conversion, removing redundant memory
barriers, removing redundant local-variable initialization,
and removing redundant local variables.
I do not believe that any of these fixes address the CPU-hotplug
issues that Andi Kleen was seeing, but please do give it a whirl
in case the machine is smarter than I am.
A writeup from the walkthrough may be found at the following
URL, in case you are suffering from terminal insomnia or
masochism:
http://www.kernel.org/pub/linux/kernel/people/paulmck/tmp/rcutree-walkthrough.2008.12.16a.pdf
o Made rcutree tracing use seq_file, as suggested some time
ago by Lai Jiangshan.
o Added a .csv variant of the rcudata debugfs trace file, to allow
people having thousands of CPUs to drop the data into
a spreadsheet. Tested with oocalc and gnumeric. Updated
documentation to suit.
Updates from v8 (http://lkml.org/lkml/2008/11/15/139):
o Fix a theoretical race between grace-period initialization and
force_quiescent_state() that could occur if more than three
jiffies were required to carry out the grace-period
initialization. Which it might, if you had enough CPUs.
o Apply Ingo's printk-standardization patch.
o Substitute local variables for repeated accesses to global
variables.
o Fix comment misspellings and redundant (but harmless) increments
of ->n_rcu_pending (this latter after having explicitly added it).
o Apply checkpatch fixes.
Updates from v7 (http://lkml.org/lkml/2008/10/10/291):
o Fixed a number of problems noted by Gautham Shenoy, including
the cpu-stall-detection bug that he was having difficulty
convincing me was real. ;-)
o Changed cpu-stall detection to wait for ten seconds rather than
three in order to reduce false positive, as suggested by Ingo
Molnar.
o Produced a design document (http://lwn.net/Articles/305782/).
The act of writing this document uncovered a number of both
theoretical and "here and now" bugs as noted below.
o Fix dynticks_nesting accounting confusion, simplify WARN_ON()
condition, fix kerneldoc comments, and add memory barriers
in dynticks interface functions.
o Add more data to tracing.
o Remove unused "rcu_barrier" field from rcu_data structure.
o Count calls to rcu_pending() from scheduling-clock interrupt
to use as a surrogate timebase should jiffies stop counting.
o Fix a theoretical race between force_quiescent_state() and
grace-period initialization. Yes, initialization does have to
go on for some jiffies for this race to occur, but given enough
CPUs...
Updates from v6 (http://lkml.org/lkml/2008/9/23/448):
o Fix a number of checkpatch.pl complaints.
o Apply review comments from Ingo Molnar and Lai Jiangshan
on the stall-detection code.
o Fix several bugs in !CONFIG_SMP builds.
o Fix a misspelled config-parameter name so that RCU now announces
at boot time if stall detection is configured.
o Run tests on numerous combinations of configurations parameters,
which after the fixes above, now build and run correctly.
Updates from v5 (http://lkml.org/lkml/2008/9/15/92, bad subject line):
o Fix a compiler error in the !CONFIG_FANOUT_EXACT case (blew a
changeset some time ago, and finally got around to retesting
this option).
o Fix some tracing bugs in rcupreempt that caused incorrect
totals to be printed.
o I now test with a more brutal random-selection online/offline
script (attached). Probably more brutal than it needs to be
on the people reading it as well, but so it goes.
o A number of optimizations and usability improvements:
o Make rcu_pending() ignore the grace-period timeout when
there is no grace period in progress.
o Make force_quiescent_state() avoid going for a global
lock in the case where there is no grace period in
progress.
o Rearrange struct fields to improve struct layout.
o Make call_rcu() initiate a grace period if RCU was
idle, rather than waiting for the next scheduling
clock interrupt.
o Invoke rcu_irq_enter() and rcu_irq_exit() only when
idle, as suggested by Andi Kleen. I still don't
completely trust this change, and might back it out.
o Make CONFIG_RCU_TRACE be the single config variable
manipulated for all forms of RCU, instead of the prior
confusion.
o Document tracing files and formats for both rcupreempt
and rcutree.
Updates from v4 for those missing v5 given its bad subject line:
o Separated dynticks interface so that NMIs and irqs call separate
functions, greatly simplifying it. In particular, this code
no longer requires a proof of correctness. ;-)
o Separated dynticks state out into its own per-CPU structure,
avoiding the duplicated accounting.
o The case where a dynticks-idle CPU runs an irq handler that
invokes call_rcu() is now correctly handled, forcing that CPU
out of dynticks-idle mode.
o Review comments have been applied (thank you all!!!).
For but one example, fixed the dynticks-ordering issue that
Manfred pointed out, saving me much debugging. ;-)
o Adjusted rcuclassic and rcupreempt to handle dynticks changes.
Attached is an updated patch to Classic RCU that applies a hierarchy,
greatly reducing the contention on the top-level lock for large machines.
This passes 10-hour concurrent rcutorture and online-offline testing on
128-CPU ppc64 without dynticks enabled, and exposes some timekeeping
bugs in presence of dynticks (exciting working on a system where
"sleep 1" hangs until interrupted...), which were fixed in the
2.6.27 kernel. It is getting more reliable than mainline by some
measures, so the next version will be against -tip for inclusion.
See also Manfred Spraul's recent patches (or his earlier work from
2004 at http://marc.info/?l=linux-kernel&m=108546384711797&w=2).
We will converge onto a common patch in the fullness of time, but are
currently exploring different regions of the design space. That said,
I have already gratefully stolen quite a few of Manfred's ideas.
This patch provides CONFIG_RCU_FANOUT, which controls the bushiness
of the RCU hierarchy. Defaults to 32 on 32-bit machines and 64 on
64-bit machines. If CONFIG_NR_CPUS is less than CONFIG_RCU_FANOUT,
there is no hierarchy. By default, the RCU initialization code will
adjust CONFIG_RCU_FANOUT to balance the hierarchy, so strongly NUMA
architectures may choose to set CONFIG_RCU_FANOUT_EXACT to disable
this balancing, allowing the hierarchy to be exactly aligned to the
underlying hardware. Up to two levels of hierarchy are permitted
(in addition to the root node), allowing up to 16,384 CPUs on 32-bit
systems and up to 262,144 CPUs on 64-bit systems. I just know that I
am going to regret saying this, but this seems more than sufficient
for the foreseeable future. (Some architectures might wish to set
CONFIG_RCU_FANOUT=4, which would limit such architectures to 64 CPUs.
If this becomes a real problem, additional levels can be added, but I
doubt that it will make a significant difference on real hardware.)
In the common case, a given CPU will manipulate its private rcu_data
structure and the rcu_node structure that it shares with its immediate
neighbors. This can reduce both lock and memory contention by multiple
orders of magnitude, which should eliminate the need for the strange
manipulations that are reported to be required when running Linux on
very large systems.
Some shortcomings:
o More bugs will probably surface as a result of an ongoing
line-by-line code inspection.
Patches will be provided as required.
o There are probably hangs, rcutorture failures, &c. Seems
quite stable on a 128-CPU machine, but that is kind of small
compared to 4096 CPUs. However, seems to do better than
mainline.
o The memory footprint of this version is several KB larger
than rcuclassic.
A separate UP-only rcutiny patch will be provided, which will
reduce the memory footprint significantly, even compared
to the old rcuclassic. One such patch passes light testing,
and has a memory footprint smaller even than rcuclassic.
Initial reaction from various embedded guys was "it is not
worth it", so am putting it aside.
Credits:
o Manfred Spraul for ideas, review comments, and bugs spotted,
as well as some good friendly competition. ;-)
o Josh Triplett, Ingo Molnar, Peter Zijlstra, Mathieu Desnoyers,
Lai Jiangshan, Andi Kleen, Andy Whitcroft, and Andrew Morton
for reviews and comments.
o Thomas Gleixner for much-needed help with some timer issues
(see patches below).
o Jon M. Tollefson, Tim Pepper, Andrew Theurer, Jose R. Santos,
Andy Whitcroft, Darrick Wong, Nishanth Aravamudan, Anton
Blanchard, Dave Kleikamp, and Nathan Lynch for keeping machines
alive despite my heavy abuse^Wtesting.
kernel/sched.c
kernel/sched_stats.h
Impact: cleanup
Each SMP arch defines these themselves. Move them to a central
location.
Twists:
1) Some archs (m32, parisc, s390) set possible_map to all 1, so we add a
CONFIG_INIT_ALL_POSSIBLE for this rather than break them.
2) mips and sparc32 '#define cpu_possible_map phys_cpu_present_map'.
Those archs simply have phys_cpu_present_map replaced everywhere.
3) Alpha defined cpu_possible_map to cpu_present_map; this is tricky
so I just manipulate them both in sync.
4) IA64, cris and m32r have gratuitous 'extern cpumask_t cpu_possible_map'
declarations.
Reviewed-by: Grant Grundler <grundler@parisc-linux.org>
Tested-by: Tony Luck <tony.luck@intel.com>
Cc: Mike Travis <travis@sgi.com>
Cc: ink@jurassic.park.msu.ru
Cc: rmk@arm.linux.org.uk
Cc: starvik@axis.com
Cc: tony.luck@intel.com
Cc: takata@linux-m32r.org
Cc: ralf@linux-mips.org
Cc: grundler@parisc-linux.org
Cc: paulus@samba.org
Cc: schwidefsky@de.ibm.com
Cc: lethal@linux-sh.org
Cc: wli@holomorphy.com
Cc: davem@davemloft.net
Cc: jdike@addtoit.com
Cc: mingo@redhat.com
We merge the irq/sparseirq, x86/quirks and x86/reboot trees into the
cpus4096 tree because the io-apic changes in the sparseirq change
conflict with the cpumask changes in the cpumask tree, and we
want to resolve those.
Impact: new feature
Problem on distro kernels: irq_desc[NR_IRQS] takes megabytes of RAM with
NR_CPUS set to large values. The goal is to be able to scale up to much
larger NR_IRQS value without impacting the (important) common case.
To solve this, we generalize irq_desc[NR_IRQS] to an (optional) array of
irq_desc pointers.
When CONFIG_SPARSE_IRQ=y is used, we use kzalloc_node to get irq_desc,
this also makes the IRQ descriptors NUMA-local (to the site that calls
request_irq()).
This gets rid of the irq_cfg[] static array on x86 as well: irq_cfg now
uses desc->chip_data for x86 to store irq_cfg.
fs/nfsd/nfs4recover.c
Manually fixed above to use new creds API functions, e.g.
nfs4_save_creds().
Signed-off-by: James Morris <jmorris@namei.org>
Impact: fix initcall debug output on non-scalar ktime platforms (32-bit embedded)
The initcall_debug code access the tv64 member of ktime. This won't work
correctly for large deltas on platforms that don't use the scalar ktime
implementation.
Signed-off-by: Will Newton <will.newton@gmail.com>
Acked-by: Tim Bird <tim.bird@am.sony.com>
kernel/trace/ftrace.c
[ We conflicted here because we backported a few fixes to
tracing/urgent - which has different internal APIs. ]
* 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
cpuset: fix regression when failed to generate sched domains
sched, signals: fix the racy usage of ->signal in account_group_xxx/run_posix_cpu_timers
sched: fix kernel warning on /proc/sched_debug access
sched: correct sched-rt-group.txt pathname in init/Kconfig
Impact: new API
Add a new API trace_mark_tp(), which declares a marker within a
tracepoint probe. When the marker is activated, the tracepoint is
automatically enabled.
No branch test is used at the marker site, because it would be a
duplicate of the branch already present in the tracepoint.
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
security/keys/internal.h
security/keys/process_keys.c
security/keys/request_key.c
Fixed conflicts above by using the non 'tsk' versions.
Inaugurate copy-on-write credentials management. This uses RCU to manage the
credentials pointer in the task_struct with respect to accesses by other tasks.
A process may only modify its own credentials, and so does not need locking to
access or modify its own credentials.
A mutex (cred_replace_mutex) is added to the task_struct to control the effect
of PTRACE_ATTACHED on credential calculations, particularly with respect to
execve().
With this patch, the contents of an active credentials struct may not be
changed directly; rather a new set of credentials must be prepared, modified
and committed using something like the following sequence of events:
struct cred *new = prepare_creds();
int ret = blah(new);
if (ret < 0) {
abort_creds(new);
return ret;
return commit_creds(new);
There are some exceptions to this rule: the keyrings pointed to by the active
credentials may be instantiated - keyrings violate the COW rule as managing
COW keyrings is tricky, given that it is possible for a task to directly alter
the keys in a keyring in use by another task.
To help enforce this, various pointers to sets of credentials, such as those in
the task_struct, are declared const. The purpose of this is compile-time
discouragement of altering credentials through those pointers. Once a set of
credentials has been made public through one of these pointers, it may not be
modified, except under special circumstances:
(1) Its reference count may incremented and decremented.
(2) The keyrings to which it points may be modified, but not replaced.
The only safe way to modify anything else is to create a replacement and commit
using the functions described in Documentation/credentials.txt (which will be
added by a later patch).
This patch and the preceding patches have been tested with the LTP SELinux
testsuite.
This patch makes several logical sets of alteration:
(1) execve().
This now prepares and commits credentials in various places in the
security code rather than altering the current creds directly.
(2) Temporary credential overrides.
do_coredump() and sys_faccessat() now prepare their own credentials and
temporarily override the ones currently on the acting thread, whilst
preventing interference from other threads by holding cred_replace_mutex
on the thread being dumped.
This will be replaced in a future patch by something that hands down the
credentials directly to the functions being called, rather than altering
the task's objective credentials.
(3) LSM interface.
A number of functions have been changed, added or removed:
(*) security_capset_check(), ->capset_check()
(*) security_capset_set(), ->capset_set()
Removed in favour of security_capset().
(*) security_capset(), ->capset()
New. This is passed a pointer to the new creds, a pointer to the old
creds and the proposed capability sets. It should fill in the new
creds or return an error. All pointers, barring the pointer to the
new creds, are now const.
(*) security_bprm_apply_creds(), ->bprm_apply_creds()
Changed; now returns a value, which will cause the process to be
killed if it's an error.
(*) security_task_alloc(), ->task_alloc_security()
Removed in favour of security_prepare_creds().
(*) security_cred_free(), ->cred_free()
New. Free security data attached to cred->security.
(*) security_prepare_creds(), ->cred_prepare()
New. Duplicate any security data attached to cred->security.
(*) security_commit_creds(), ->cred_commit()
New. Apply any security effects for the upcoming installation of new
security by commit_creds().
(*) security_task_post_setuid(), ->task_post_setuid()
Removed in favour of security_task_fix_setuid().
(*) security_task_fix_setuid(), ->task_fix_setuid()
Fix up the proposed new credentials for setuid(). This is used by
cap_set_fix_setuid() to implicitly adjust capabilities in line with
setuid() changes. Changes are made to the new credentials, rather
than the task itself as in security_task_post_setuid().
(*) security_task_reparent_to_init(), ->task_reparent_to_init()
Removed. Instead the task being reparented to init is referred
directly to init's credentials.
NOTE! This results in the loss of some state: SELinux's osid no
longer records the sid of the thread that forked it.
(*) security_key_alloc(), ->key_alloc()
(*) security_key_permission(), ->key_permission()
Changed. These now take cred pointers rather than task pointers to
refer to the security context.
(4) sys_capset().
This has been simplified and uses less locking. The LSM functions it
calls have been merged.
(5) reparent_to_kthreadd().
This gives the current thread the same credentials as init by simply using
commit_thread() to point that way.
(6) __sigqueue_alloc() and switch_uid()
__sigqueue_alloc() can't stop the target task from changing its creds
beneath it, so this function gets a reference to the currently applicable
user_struct which it then passes into the sigqueue struct it returns if
successful.
switch_uid() is now called from commit_creds(), and possibly should be
folded into that. commit_creds() should take care of protecting
__sigqueue_alloc().
(7) [sg]et[ug]id() and co and [sg]et_current_groups.
The set functions now all use prepare_creds(), commit_creds() and
abort_creds() to build and check a new set of credentials before applying
it.
security_task_set[ug]id() is called inside the prepared section. This
guarantees that nothing else will affect the creds until we've finished.
The calling of set_dumpable() has been moved into commit_creds().
Much of the functionality of set_user() has been moved into
commit_creds().
The get functions all simply access the data directly.
(8) security_task_prctl() and cap_task_prctl().
security_task_prctl() has been modified to return -ENOSYS if it doesn't
want to handle a function, or otherwise return the return value directly
rather than through an argument.
Additionally, cap_task_prctl() now prepares a new set of credentials, even
if it doesn't end up using it.
(9) Keyrings.
A number of changes have been made to the keyrings code:
(a) switch_uid_keyring(), copy_keys(), exit_keys() and suid_keys() have
all been dropped and built in to the credentials functions directly.
They may want separating out again later.
(b) key_alloc() and search_process_keyrings() now take a cred pointer
rather than a task pointer to specify the security context.
(c) copy_creds() gives a new thread within the same thread group a new
thread keyring if its parent had one, otherwise it discards the thread
keyring.
(d) The authorisation key now points directly to the credentials to extend
the search into rather pointing to the task that carries them.
(e) Installing thread, process or session keyrings causes a new set of
credentials to be created, even though it's not strictly necessary for
process or session keyrings (they're shared).
(10) Usermode helper.
The usermode helper code now carries a cred struct pointer in its
subprocess_info struct instead of a new session keyring pointer. This set
of credentials is derived from init_cred and installed on the new process
after it has been cloned.
call_usermodehelper_setup() allocates the new credentials and
call_usermodehelper_freeinfo() discards them if they haven't been used. A
special cred function (prepare_usermodeinfo_creds()) is provided
specifically for call_usermodehelper_setup() to call.
call_usermodehelper_setkeys() adjusts the credentials to sport the
supplied keyring as the new session keyring.
(11) SELinux.
SELinux has a number of changes, in addition to those to support the LSM
interface changes mentioned above:
(a) selinux_setprocattr() no longer does its check for whether the
current ptracer can access processes with the new SID inside the lock
that covers getting the ptracer's SID. Whilst this lock ensures that
the check is done with the ptracer pinned, the result is only valid
until the lock is released, so there's no point doing it inside the
lock.
(12) is_single_threaded().
This function has been extracted from selinux_setprocattr() and put into
a file of its own in the lib/ directory as join_session_keyring() now
wants to use it too.
The code in SELinux just checked to see whether a task shared mm_structs
with other tasks (CLONE_VM), but that isn't good enough. We really want
to know if they're part of the same thread group (CLONE_THREAD).
(13) nfsd.
The NFS server daemon now has to use the COW credentials to set the
credentials it is going to use. It really needs to pass the credentials
down to the functions it calls, but it can't do that until other patches
in this series have been applied.
Acked-by: James Morris <jmorris@namei.org>
In 2007, a0acd820807680d2ccc4ef3448387fcdbf152c73 changed the default
slab allocator to SLUB, but the SLAB help text still says SLAB is the
default. This change fixes that.
Signed-off-by: Simon Arlott <simon@fire.lp0.eu>
init/Kconfig directs the user to Documentation/sched-rt-group.txt, but
the file is actually in Documentation/scheduler/sched-rt-group.txt.
This patch corrects the pathname mentioned in init/Kconfig.
Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de>
Impact: Split the boot tracer entries in two parts: call and return
Now that we are using the sched tracer from the boot tracer, we want
to use the same timestamp than the ring-buffer to have consistent time
captures between sched events and initcall events.
So we get rid of the old time capture by the boot tracer and split the
initcall events in two parts: call and return. This way we have the
ring buffer timestamp of both.
An example trace:
[ 27.904149584] calling net_ns_init+0x0/0x1c0 @ 1
[ 27.904429624] initcall net_ns_init+0x0/0x1c0 returned 0 after 0 msecs
[ 27.904575926] calling reboot_init+0x0/0x20 @ 1
[ 27.904655399] initcall reboot_init+0x0/0x20 returned 0 after 0 msecs
[ 27.904800228] calling sysctl_init+0x0/0x30 @ 1
[ 27.905142914] initcall sysctl_init+0x0/0x30 returned 0 after 0 msecs
[ 27.905287211] calling ksysfs_init+0x0/0xb0 @ 1
##### CPU 0 buffer started ####
init-1 [000] 27.905395: 1:120:R + [001] 11:115:S
##### CPU 1 buffer started ####
<idle>-0 [001] 27.905425: 0:140:R ==> [001] 11:115:R
init-1 [000] 27.905426: 1:120:D ==> [000] 0:140:R
<idle>-0 [000] 27.905431: 0:140:R + [000] 4:115:S
<idle>-0 [000] 27.905451: 0:140:R ==> [000] 4:115:R
ksoftirqd/0-4 [000] 27.905456: 4:115:S ==> [000] 0:140:R
udevd-11 [001] 27.905458: 11:115:R + [001] 14:115:R
<idle>-0 [000] 27.905459: 0:140:R + [000] 4:115:S
<idle>-0 [000] 27.905462: 0:140:R ==> [000] 4:115:R
udevd-11 [001] 27.905462: 11:115:R ==> [001] 14:115:R
ksoftirqd/0-4 [000] 27.905467: 4:115:S ==> [000] 0:140:R
<idle>-0 [000] 27.905470: 0:140:R + [000] 4:115:S
<idle>-0 [000] 27.905473: 0:140:R ==> [000] 4:115:R
ksoftirqd/0-4 [000] 27.905476: 4:115:S ==> [000] 0:140:R
<idle>-0 [000] 27.905479: 0:140:R + [000] 4:115:S
<idle>-0 [000] 27.905482: 0:140:R ==> [000] 4:115:R
ksoftirqd/0-4 [000] 27.905486: 4:115:S ==> [000] 0:140:R
udevd-14 [001] 27.905499: 14:120:X ==> [001] 11:115:R
udevd-11 [001] 27.905506: 11:115:R + [000] 1:120:D
<idle>-0 [000] 27.905515: 0:140:R ==> [000] 1:120:R
udevd-11 [001] 27.905517: 11:115:S ==> [001] 0:140:R
[ 27.905557107] initcall ksysfs_init+0x0/0xb0 returned 0 after 3906 msecs
[ 27.905705736] calling init_jiffies_clocksource+0x0/0x10 @ 1
[ 27.905779239] initcall init_jiffies_clocksource+0x0/0x10 returned 0 after 0 msecs
[ 27.906769814] calling pm_init+0x0/0x30 @ 1
[ 27.906853627] initcall pm_init+0x0/0x30 returned 0 after 0 msecs
[ 27.906997803] calling pm_disk_init+0x0/0x20 @ 1
[ 27.907076946] initcall pm_disk_init+0x0/0x20 returned 0 after 0 msecs
[ 27.907222556] calling swsusp_header_init+0x0/0x30 @ 1
[ 27.907294325] initcall swsusp_header_init+0x0/0x30 returned 0 after 0 msecs
[ 27.907439620] calling stop_machine_init+0x0/0x50 @ 1
init-1 [000] 27.907485: 1:120:R + [000] 2:115:S
init-1 [000] 27.907490: 1:120:D ==> [000] 2:115:R
kthreadd-2 [000] 27.907507: 2:115:R + [001] 15:115:R
<idle>-0 [001] 27.907517: 0:140:R ==> [001] 15:115:R
kthreadd-2 [000] 27.907517: 2:115:D ==> [000] 0:140:R
<idle>-0 [000] 27.907521: 0:140:R + [000] 4:115:S
<idle>-0 [000] 27.907524: 0:140:R ==> [000] 4:115:R
udevd-15 [001] 27.907527: 15:115:D + [000] 2:115:D
ksoftirqd/0-4 [000] 27.907537: 4:115:S ==> [000] 2:115:R
udevd-15 [001] 27.907537: 15:115:D ==> [001] 0:140:R
kthreadd-2 [000] 27.907546: 2:115:R + [000] 1:120:D
kthreadd-2 [000] 27.907550: 2:115:S ==> [000] 1:120:R
init-1 [000] 27.907584: 1:120:R + [000] 15: 0:D
init-1 [000] 27.907589: 1:120:R + [000] 2:115:S
init-1 [000] 27.907593: 1:120:D ==> [000] 15: 0:R
udevd-15 [000] 27.907601: 15: 0:S ==> [000] 2:115:R
kthreadd-2 [000] 27.907616: 2:115:R + [001] 16:115:R
<idle>-0 [001] 27.907620: 0:140:R ==> [001] 16:115:R
kthreadd-2 [000] 27.907621: 2:115:D ==> [000] 0:140:R
udevd-16 [001] 27.907625: 16:115:D + [000] 2:115:D
<idle>-0 [000] 27.907628: 0:140:R + [000] 4:115:S
udevd-16 [001] 27.907629: 16:115:D ==> [001] 0:140:R
<idle>-0 [000] 27.907631: 0:140:R ==> [000] 4:115:R
ksoftirqd/0-4 [000] 27.907636: 4:115:S ==> [000] 2:115:R
kthreadd-2 [000] 27.907644: 2:115:R + [000] 1:120:D
kthreadd-2 [000] 27.907647: 2:115:S ==> [000] 1:120:R
init-1 [000] 27.907657: 1:120:R + [001] 16: 0:D
<idle>-0 [001] 27.907666: 0:140:R ==> [001] 16: 0:R
[ 27.907703862] initcall stop_machine_init+0x0/0x50 returned 0 after 0 msecs
[ 27.907850704] calling filelock_init+0x0/0x30 @ 1
[ 27.907926573] initcall filelock_init+0x0/0x30 returned 0 after 0 msecs
[ 27.908071327] calling init_script_binfmt+0x0/0x10 @ 1
[ 27.908165195] initcall init_script_binfmt+0x0/0x10 returned 0 after 0 msecs
[ 27.908309461] calling init_elf_binfmt+0x0/0x10 @ 1
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Impact: Cleanups on the boot tracer and ftrace
This patch bring some cleanups about the boot tracer headers. The
functions and structures of this tracer have nothing related to ftrace
and should have so their own header file.
Impact: modify boot tracer
We used to disable the initcall tracing at a specified time (IE: end
of builtin initcalls). But we don't need it anymore. It will be
stopped when initcalls are finished.
However we want two things:
_Start this tracing only after pre-smp initcalls are finished.
_Since we are planning to trace sched_switches at the same time, we
want to enable them only during the initcall execution.
For this purpose, this patch introduce two functions to enable/disable
the sched_switch tracing during boot.
Removed duplicated #include <linux/delay.h> in init/do_mounts_md.c.
The same compile error ("error: implicit declaration of function
'msleep'") got fixed twice:
- f8b77d39397e1510b1a3bcfd385ebd1a45aae77f ("init/do_mounts_md.c:
msleep compile fix")
- 73b4a24f5ff09389ba6277c53a266b142f655ed2 ("init/do_mounts_md.c must
#include <linux/delay.h>")
by people adding the <linux/delay.h> include in two slightly different
places. Andrew's quilt scripts happily ignore the fuzz, and will
re-apply the patch even though they had conflicts.
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com>
page_cgroup is now allocated at boot and memmap doesn't includes pointer
for page_cgroup. Fix the menu help text.
Reviewed-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Signed-off-by: KAMEZAWA hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
init/do_mounts_md.c:285: error: implicit declaration of function 'msleep'
