path: root/init
2006-02-10[PATCH] remove bogus comment from init/main.cHeiko Carstens
Remove bogus comment from init function which could lead to the assumption that cpu_possible_map is setup in smp_prepare_cpus(). Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-10[PATCH] kexec: fix in free initrd when overlapped with crashkernel regionHaren Myneni
It is possible that the reserved crashkernel region can be overlapped with initrd since the bootloader sets the initrd location. When the initrd region is freed, the second kernel memory will not be contiguous. The Kexec_load can cause an oops since there is no contiguous memory to write the second kernel or this memory could be used in the first kernel itself and may not be part of the dump. For example, on powerpc, the initrd is located at 36MB and the crashkernel starts at 32MB. The kexec_load caused panic since writing into non-allocated memory (after 36MB). We could see the similar issue even on other archs. One possibility is to move the initrd outside of crashkernel region. But, the initrd region will be freed anyway before the system is up. This patch fixes this issue and frees only regions that are not part of crashkernel memory in case overlaps. Signed-off-by: Haren Myneni <haren@us.ibm.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-07[PATCH] selinux: require AUDITStephen Smalley
Make SELinux depend on AUDIT as it requires the basic audit support to log permission denials at all. Note that AUDITSYSCALL remains optional for SELinux, although it can be useful in providing further information upon denials. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-03[PATCH] don't allow users to set CONFIG_BROKEN=yAdrian Bunk
Do not allow people to create configurations with CONFIG_BROKEN=y. The sole reason for CONFIG_BROKEN=y would be if you are working on fixing a broken driver, but in this case editing the Kconfig file is trivial. Never ever should a user enable CONFIG_BROKEN. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-16[PATCH] build kernel/intermodule.c only when requiredAdrian Bunk
Build kernel/intermodule.c only when required. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
2006-01-14[PATCH] abandon gcc 295x main.c tidyCoywolf Qi Hunt
After abandon-gcc-295x.patch, this relocates the error-out-early comment. Signed-off-by: Coywolf Qi Hunt <qiyong@fc-cn.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-15Spelling fix in init/Kconfig for the help of CONFIG_SWAPJesper Juhl
Trivial spelling fix s/socalled/so called/ Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-01-11[PATCH] i386: Move DOUBLEFAULT config to arch/i386/KconfigAndi Kleen
It has no business being elsewhere and x86-64 doesn't need/want it. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: hrtimer core codeThomas Gleixner
hrtimer subsystem core. It is initialized at bootup and expired by the timer interrupt, but is otherwise not utilized by any other subsystem yet. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] "tiny-make-id16-support-optional" fixesAdrian Bunk
It seems the "make UID16 support optional" patch was checked when it edited the -tiny tree some time ago, but it wasn't checked whether it still matches the current situation when it was submitted for inclusion in -mm. This patch fixes the following bugs: - ARCH_S390X does no longer exist, nowadays this has to be expressed through (S390 && 64BIT) - in five architecture specific Kconfig files the UID16 options weren't removed Additionally, it changes the fragile negative dependencies of UID16 to positive dependencies (new architectures are more likely to not require UID16 support). Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] Make vm86 support optionalMatt Mackall
This adds an option to remove vm86 support under CONFIG_EMBEDDED. Saves about 5k. This version eliminates most of the #ifdefs of the previous version and instead uses function stubs in vm86.h. Also, release_vm86_irqs is moved from asm-i386/irq.h to a more appropriate home in vm86.h so that the stubs can live together. $ size vmlinux-baseline vmlinux-novm86 text data bss dec hex filename 2920821 523232 190652 3634705 377611 vmlinux-baseline 2916268 523100 190492 3629860 376324 vmlinux-novm86 Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] tiny: Configure ELF core dump supportMatt Mackall
configurable support for ELF core dumps text data bss dec hex filename 3330172 529036 190556 4049764 3dcb64 vmlinux-baseline 3325552 528912 190556 4045020 3db8dc vmlinux-no-elf add/remove: 0/8 grow/shrink: 0/0 up/down: 0/-4424 (-4424) function old new delta fill_note 32 - -32 maydump 58 - -58 dump_seek 67 - -67 writenote 180 - -180 elf_dump_thread_status 274 - -274 fill_psinfo 308 - -308 fill_prstatus 466 - -466 elf_core_dump 3039 - -3039 Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] tiny: Make *[ug]id16 support optionalMatt Mackall
Configurable 16-bit UID and friends support This allows turning off the legacy 16 bit UID interfaces on embedded platforms. text data bss dec hex filename 3330172 529036 190556 4049764 3dcb64 vmlinux-baseline 3328268 529040 190556 4047864 3dc3f8 vmlinux From: Adrian Bunk <bunk@stusta.de> UID16 was accidentially disabled for !EMBEDDED. Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] tiny: Make x86 doublefault handling optionalMatt Mackall
This adds configurable support for doublefault reporting on x86 add/remove: 0/3 grow/shrink: 0/1 up/down: 0/-13048 (-13048) function old new delta cpu_init 846 786 -60 doublefault_fn 188 - -188 doublefault_stack 4096 - -4096 doublefault_tss 8704 - -8704 Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] Abandon gcc-2.95.xAndrew Morton
There's one scsi driver which doesn't compile due to weird __VA_ARGS__ tricks and the rather useful scsi/sd.c is currently getting an ICE. None of the new SAS code compiles, due to extensive use of anonymous unions. The V4L guys are very good at exploiting the gcc-2.95.x macro expansion bug (_why_ does each driver need to implement its own debug macros?) and various people keep on sneaking in anonymous unions, which are rather nice. Plus anonymous unions are rather useful. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] cpuset: remove test for null cpuset from alloc code pathPaul Jackson
Remove a couple of more lines of code from the cpuset hooks in the page allocation code path. There was a check for a NULL cpuset pointer in the routine cpuset_update_task_memory_state() that was only needed during system boot, after the memory subsystem was initialized, before the cpuset subsystem was initialized, to catch a NULL task->cpuset pointer. Add a cpuset_init_early() routine, just before the mem_init() call in init/main.c, that sets up just enough of the init tasks cpuset structure to render cpuset_update_task_memory_state() calls harmless. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] slob: introduce the SLOB allocatorMatt Mackall
configurable replacement for slab allocator This adds a CONFIG_SLAB option under CONFIG_EMBEDDED. When CONFIG_SLAB is disabled, the kernel falls back to using the 'SLOB' allocator. SLOB is a traditional K&R/UNIX allocator with a SLAB emulation layer, similar to the original Linux kmalloc allocator that SLAB replaced. It's signicantly smaller code and is more memory efficient. But like all similar allocators, it scales poorly and suffers from fragmentation more than SLAB, so it's only appropriate for small systems. It's been tested extensively in the Linux-tiny tree. I've also stress-tested it with make -j 8 compiles on a 3G SMP+PREEMPT box (not recommended). Here's a comparison for otherwise identical builds, showing SLOB saving nearly half a megabyte of RAM: $ size vmlinux* text data bss dec hex filename 3336372 529360 190812 4056544 3de5e0 vmlinux-slab 3323208 527948 190684 4041840 3dac70 vmlinux-slob $ size mm/{slab,slob}.o text data bss dec hex filename 13221 752 48 14021 36c5 mm/slab.o 1896 52 8 1956 7a4 mm/slob.o /proc/meminfo: SLAB SLOB delta MemTotal: 27964 kB 27980 kB +16 kB MemFree: 24596 kB 25092 kB +496 kB Buffers: 36 kB 36 kB 0 kB Cached: 1188 kB 1188 kB 0 kB SwapCached: 0 kB 0 kB 0 kB Active: 608 kB 600 kB -8 kB Inactive: 808 kB 812 kB +4 kB HighTotal: 0 kB 0 kB 0 kB HighFree: 0 kB 0 kB 0 kB LowTotal: 27964 kB 27980 kB +16 kB LowFree: 24596 kB 25092 kB +496 kB SwapTotal: 0 kB 0 kB 0 kB SwapFree: 0 kB 0 kB 0 kB Dirty: 4 kB 12 kB +8 kB Writeback: 0 kB 0 kB 0 kB Mapped: 560 kB 556 kB -4 kB Slab: 1756 kB 0 kB -1756 kB CommitLimit: 13980 kB 13988 kB +8 kB Committed_AS: 4208 kB 4208 kB 0 kB PageTables: 28 kB 28 kB 0 kB VmallocTotal: 1007312 kB 1007312 kB 0 kB VmallocUsed: 48 kB 48 kB 0 kB VmallocChunk: 1007264 kB 1007264 kB 0 kB (this work has been sponsored in part by CELF) From: Ingo Molnar <mingo@elte.hu> Fix 32-bitness bugs in mm/slob.c. Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: remove personality numbering from mdNeilBrown
md supports multiple different RAID level, each being implemented by a 'personality' (which is often in a separate module). These personalities have fairly artificial 'numbers'. The numbers are use to: 1- provide an index into an array where the various personalities are recorded 2- identify the module (via an alias) which implements are particular personality. Neither of these uses really justify the existence of personality numbers. The array can be replaced by a linked list which is searched (array lookup only happens very rarely). Module identification can be done using an alias based on level rather than 'personality' number. The current 'raid5' modules support two level (4 and 5) but only one personality. This slight awkwardness (which was handled in the mapping from level to personality) can be better handled by allowing raid5 to register 2 personalities. With this change in place, the core md module does not need to have an exhaustive list of all possible personalities, so other personalities can be added independently. This patch also moves the check for chunksize being non-zero into the ->run routines for the personalities that need it, rather than having it in core-md. This has a side effect of allowing 'faulty' and 'linear' not to have a chunk-size set. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] s390: cleanup KconfigMartin Schwidefsky
Sanitize some s390 Kconfig options. We have ARCH_S390, ARCH_S390X, ARCH_S390_31, 64BIT, S390_SUPPORT and COMPAT. Replace these 6 options by S390, 64BIT and COMPAT. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] x86/x86_64: mark rodata section read only: generic infrastructureArjan van de Ven
Generic prep-work for marking the .rodata section readonly: * Align the rodata section at 4Kb boundary * call the mark_rodata_ro() function when available Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] NOMMU: Make SYSV IPC SHM use ramfs facilities on NOMMUDavid Howells
The attached patch makes the SYSV IPC shared memory facilities use the new ramfs facilities on a no-MMU kernel. The following changes are made: (1) There are now shmem_mmap() and shmem_get_unmapped_area() functions to allow the IPC SHM facilities to commune with the tiny-shmem and shmem code. (2) ramfs files now need resizing using do_truncate() rather than by modifying the inode size directly (see shmem_file_setup()). This causes ramfs to attempt to bind a block of pages of sufficient size to the inode. (3) CONFIG_SYSVIPC is no longer contingent on CONFIG_MMU. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
Trivial manual merge fixup for usb_find_interface clashes.
2006-01-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
2006-01-04[PATCH] HOTPLUG: always enable the .config option, unless EMBEDDEDGreg Kroah-Hartman
With modules, dynamic /dev, and uevents, people really want CONFIG_HOTPLUG to be enabled in their kernels. If not, they can still disable it, but it is discouraged. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] remove CONFIG_KOBJECT_UEVENT optionKay Sievers
It makes zero sense to have hotplug, but not the netlink events enabled today. Remove this option and merge the kobject_uevent.h header into the kobject.h header file. Signed-off-by: Kay Sievers <kay.sievers@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-03[NET]: Small cleanup to socket initializationAndi Kleen
sock_init can be done as a core_initcall instead of calling it directly in init/main.c Also I removed an out of date #ifdef. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-12-26kbuild: remove EXPERIMENTAL tag from Module versioningSam Ravnborg
Module versioning support has been stable for a loong time so let's get rid of the EXPERIMENTAL tag. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-12-20[SPARC64]: Stop putting -finline-limit=XXX into CFLAGSDavid S. Miller
It was a stupid workaround for the "static inline" vs. "extern inline" issues of long ago, and it is what causes schedule() to be inlined like crazy into kernel/sched.c when -Os is specified. MIPS and S390 should probably do the same. Now CC_OPTIMIZE_FOR_SIZE can be safely used on sparc64 once more. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-12-14Move size optimization option outside of EMBEDDED menu, mark it EXPERIMENTALLinus Torvalds
Also, disable on sparc64 - a number of people report breakage. Probably a compiler bug, but it's quite possible that it tickles some latent kernel problem too. It still defaults to 'y' everywhere else (when enabled through EXPERIMENTAL), and Dave Jones points out that Fedora (and RHEL4) has been building with size optimizations for a long time on x86, x86-64, ia64, s390, s390x, ppc32 and ppc64. So it is really only moderately experimental, but the sparc64 breakage certainly shows that it can trigger "issues". Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-13Expose "Optimize for size" option for everybodyLinus Torvalds
Let's put my money where my mouth is. Smaller code is almost always faster, if only because a single I$ miss ends up leaving a lot of cycles to make up for. And system software - kernels in particular - are known for taking more cache misses than most other kinds. On my random config, this made the kernel about 10% smaller, and lmbench seems to say that it's pretty uniformly faster too. Your milage may vary. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-13[PATCH] allow KOBJECT_UEVENT=n only if EMBEDDEDAdrian Bunk
KOBJECT_UEVENT=n seems to be a common pitfall for udev users in 2.6.14 . -mm already contains a bigger patch removing this option that is IMHO too big for being applied now to 2.6.15-rc. This patch simply allows KOBJECT_UEVENT=n only if EMBEDDED. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] sched: disable preempt in idle tasksNick Piggin
Run idle threads with preempt disabled. Also corrected a bugs in arm26's cpu_idle (make it actually call schedule()). How did it ever work before? Might fix the CPU hotplugging hang which Nigel Cunningham noted. We think the bug hits if the idle thread is preempted after checking need_resched() and before going to sleep, then the CPU offlined. After calling stop_machine_run, the CPU eventually returns from preemption and into the idle thread and goes to sleep. The CPU will continue executing previous idle and have no chance to call play_dead. By disabling preemption until we are ready to explicitly schedule, this bug is fixed and the idle threads generally become more robust. From: alexs <ashepard@u.washington.edu> PPC build fix From: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> MIPS build fix Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-04[BLOCK] Move all core block layer code to new block/ directoryJens Axboe
drivers/block/ is right now a mix of core and driver parts. Lets move the core parts to a new top level directory. Al will move the fs/ related block parts to block/ next. Signed-off-by: Jens Axboe <axboe@suse.de>
2005-10-31Revert "i386: move apic init in init_IRQs"Linus Torvalds
Commit f2b36db692b7ff6972320ad9839ae656a3b0ee3e causes a bootup hang on at least one machine. Revert for now until we understand why. The old code may be ugly, but it works. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] clarify help text for INIT_ENV_ARG_LIMITRandy Dunlap
Try to make the INIT_ENV_ARG_LIMIT help text more readable and understandable. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] i386: move apic init in init_IRQsEric W. Biederman
All kinds of ugliness exists because we don't initialize the apics during init_IRQs. - We calibrate jiffies in non apic mode even when we are using apics. - We have to have special code to initialize the apics when non-smp. - The legacy i8259 must exist and be setup correctly, even when we won't use it past initialization. - The kexec on panic code must restore the state of the io_apics. - init/main.c needs a special case for !smp smp_init on x86 In addition to pure code movement I needed a couple of non-obvious changes: - Move setup_boot_APIC_clock into APIC_late_time_init for simplicity. - Use cpu_khz to generate a better approximation of loops_per_jiffies so I can verify the timer interrupt is working. - Call setup_apic_nmi_watchdog again after cpu_khz is initialized on the boot cpu. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-13[PATCH] free initrd mem adjustmentJan Beulich
Besides freeing initrd memory, also clear out the now dangling pointers to it, to make sure accidental late use attempts can be detected. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] Add rdinit parameter to pick early userspace initOlof Johansson
Since early userspace was added, there's no way to override which init to run from it. Some people tack on an extra cpio archive with a link from /init depending on what they want to run, but that's sometimes impractical. Changing the "init=" to also override the early userspace isn't feasible, since it is still used to indicate what init to run from disk when early userspace has completed doing whatever it's doing (i.e. load filesystem modules and drivers). Instead, introduce "rdinit=" and make it override the default "/init" if specified. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] Add warning `init=' to init/main.cAvery, Brian
I passed init=/mylinuxrc to the kernel on the command line. The kernel silently dropped down to exec /sbin/init. It turned out that /mylinuxrc had improper permissions. Without any warning message from the kernel that something was wrong it took awhile to find the issue. The patch below adds a warning. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] detect soft lockupsIngo Molnar
This patch adds a new kernel debug feature: CONFIG_DETECT_SOFTLOCKUP. When enabled then per-CPU watchdog threads are started, which try to run once per second. If they get delayed for more than 10 seconds then a callback from the timer interrupt detects this condition and prints out a warning message and a stack dump (once per lockup incident). The feature is otherwise non-intrusive, it doesnt try to unlock the box in any way, it only gets the debug info out, automatically, and on all CPUs affected by the lockup. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-Off-By: Matthias Urlichs <smurf@smurf.noris.de> Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-06Merge master.kernel.org:/pub/scm/linux/kernel/git/sam/kbuild Linus Torvalds
2005-09-02[PATCH] remove driverfs references from init/do_mounts.cRolf Eike Beer
This patch is against 2.6.10, but still applies cleanly. It's just s/driverfs/sysfs/ in this file. Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-29[NET]: Fix sparse warningsArnaldo Carvalho de Melo
Of this type, mostly: CHECK net/ipv6/netfilter.c net/ipv6/netfilter.c:96:12: warning: symbol 'ipv6_netfilter_init' was not declared. Should it be static? net/ipv6/netfilter.c:101:6: warning: symbol 'ipv6_netfilter_fini' was not declared. Should it be static? Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-10[PATCH] kbuild: automatically append a short string to the version based ↵Ryan Anderson
upon the git commit If CONFIG_AUTO_LOCALVERSION is set, the user is using a git-based tree, and the current HEAD is not referred to by any tags in .git/refs/tags/, append -g and the first 8 characters of the commit to the version string. This makes it easier to use git-bisect, and/or to do a daily build, without trampling on your older, working builds, or accidentally setting up conflicting sets of modules. Signed-off-by: Ryan Anderson <ryan@michonline.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-08-10kconfig: move initramfs options to General SetupSam Ravnborg
Move initramfs options from Device Drivers | Block Drivers to General Setup This is a more natural place for this option. Furthermore separate out intramfs options to usr/Kconfig Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-07-28[PATCH] x86_64: Some cleanup in setup64.cAndi Kleen
Minor cleanup. Move things into their include files, remove obsolete includes, fix indentation, remove obsolete special cases etc. I also added the per cpu section to asm-generic/sections.h and fixed init/main.c to use it. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] kernel/cpuset.c: add kerneldoc, fix typosRandy Dunlap
Add kerneldoc to kernel/cpuset.c Fix cpuset typos in init/Kconfig Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-26[PATCH] kallsyms: clarify KALLSYMS_ALL help textJesper Juhl
Clarify the KALLSYMS_ALL help text slightly. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
2005-07-14kbuild: "PREEMPT" in UTS_VERSIONSam Ravnborg
From: Matt Mackall <mpm@selenic.com> Add PREEMPT to UTS_VERSION where enabled as is done for SMP to make preempt kernels easily identifiable. Added SMP PREEMPT as comment in compile.h to force it to be updated when they change (sam). Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
