path: root/init
2012-10-14Merge branch 'modules-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module signing support from Rusty Russell: "module signing is the highlight, but it's an all-over David Howells frenzy..." Hmm "Magrathea: Glacier signing key". Somebody has been reading too much HHGTTG. * 'modules-next' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (37 commits) X.509: Fix indefinite length element skip error handling X.509: Convert some printk calls to pr_devel asymmetric keys: fix printk format warning MODSIGN: Fix 32-bit overflow in X.509 certificate validity date checking MODSIGN: Make mrproper should remove generated files. MODSIGN: Use utf8 strings in signer's name in autogenerated X.509 certs MODSIGN: Use the same digest for the autogen key sig as for the module sig MODSIGN: Sign modules during the build process MODSIGN: Provide a script for generating a key ID from an X.509 cert MODSIGN: Implement module signature checking MODSIGN: Provide module signing public keys to the kernel MODSIGN: Automatically generate module signing keys if missing MODSIGN: Provide Kconfig options MODSIGN: Provide gitignore and make clean rules for extra files MODSIGN: Add FIPS policy module: signature checking hook X.509: Add a crypto key parser for binary (DER) X.509 certificates MPILIB: Provide a function to read raw data into an MPI X.509: Add an ASN.1 decoder X.509: Add simple ASN.1 grammar compiler ...
2012-10-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull third pile of kernel_execve() patches from Al Viro: "The last bits of infrastructure for kernel_thread() et.al., with alpha/arm/x86 use of those. Plus sanitizing the asm glue and do_notify_resume() on alpha, fixing the "disabled irq while running task_work stuff" breakage there. At that point the rest of kernel_thread/kernel_execve/sys_execve work can be done independently for different architectures. The only pending bits that do depend on having all architectures converted are restrictred to fs/* and kernel/* - that'll obviously have to wait for the next cycle. I thought we'd have to wait for all of them done before we start eliminating the longjump-style insanity in kernel_execve(), but it turned out there's a very simple way to do that without flagday-style changes." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: alpha: switch to saner kernel_execve() semantics arm: switch to saner kernel_execve() semantics x86, um: convert to saner kernel_execve() semantics infrastructure for saner ret_from_kernel_thread semantics make sure that kernel_thread() callbacks call do_exit() themselves make sure that we always have a return path from kernel_execve() ppc: eeh_event should just use kthread_run() don't bother with kernel_thread/kernel_execve for launching linuxrc alpha: get rid of switch_stack argument of do_work_pending() alpha: don't bother passing switch_stack separately from regs alpha: take SIGPENDING/NOTIFY_RESUME loop into signal.c alpha: simplify TIF_NEED_RESCHED handling
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull third pile of VFS updates from Al Viro: "Stuff from Jeff Layton, mostly. Sanitizing interplay between audit and namei, removing a lot of insanity from audit_inode() mess and getting things ready for his ESTALE patchset." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: procfs: don't need a PATH_MAX allocation to hold a string representation of an int vfs: embed struct filename inside of names_cache allocation if possible audit: make audit_inode take struct filename vfs: make path_openat take a struct filename pointer vfs: turn do_path_lookup into wrapper around struct filename variant audit: allow audit code to satisfy getname requests from its names_list vfs: define struct filename and have getname() return it vfs: unexport getname and putname symbols acct: constify the name arg to acct_on vfs: allocate page instead of names_cache buffer in mount_block_root audit: overhaul __audit_inode_child to accomodate retrying audit: optimize audit_compare_dname_path audit: make audit_compare_dname_path use parent_len helper audit: remove dirlen argument to audit_compare_dname_path audit: set the name_len in audit_inode for parent lookups audit: add a new "type" field to audit_names struct audit: reverse arguments to audit_inode_child audit: no need to walk list in audit_inode if name is NULL audit: pass in dentry to audit_copy_inode wherever possible audit: remove unnecessary NULL ptr checks from do_path_lookup
2012-10-12infrastructure for saner ret_from_kernel_thread semanticsAl Viro
* allow kernel_execve() leave the actual return to userland to caller (selected by CONFIG_GENERIC_KERNEL_EXECVE). Callers updated accordingly. * architecture that does select GENERIC_KERNEL_EXECVE in its Kconfig should have its ret_from_kernel_thread() do this: call schedule_tail call the callback left for it by copy_thread(); if it ever returns, that's because it has just done successful kernel_execve() jump to return from syscall IOW, its only difference from ret_from_fork() is that it does call the callback. * such an architecture should also get rid of ret_from_kernel_execve() and __ARCH_WANT_KERNEL_EXECVE This is the last part of infrastructure patches in that area - from that point on work on different architectures can live independently. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-12Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull RCU fixes from Ingo Molnar: "This tree includes a shutdown/cpu-hotplug deadlock fix and a documentation fix." * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: rcu: Advise most users not to enable RCU user mode rcu: Grace-period initialization excludes only RCU notifier
2012-10-12vfs: allocate page instead of names_cache buffer in mount_block_rootJeff Layton
First, it's incorrect to call putname() after __getname_gfp() since the bare __getname_gfp() call skips the auditing code, while putname() doesn't. mount_block_root allocates a PATH_MAX buffer via __getname_gfp, and then calls get_fs_names to fill the buffer. That function can call get_filesystem_list which assumes that that buffer is a full page in size. On arches where PAGE_SIZE != 4k, then this could potentially overrun. In practice, it's hard to imagine the list of filesystem names even approaching 4k, but it's best to be safe. Just allocate a page for this purpose instead. With this, we can also remove the __getname_gfp() definition since there are no more callers. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-11make sure that we always have a return path from kernel_execve()Al Viro
The only place where kernel_execve() is called without a way to return to the caller of kernel_thread() callback is kernel_post(). Reorganize kernel_init()/kernel_post() - instead of the former calling the latter in the end (and getting freed by it), have the latter *begin* with calling the former (and turn the latter into kernel_thread() callback, of course). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-11don't bother with kernel_thread/kernel_execve for launching linuxrcAl Viro
exec_usermodehelper_fns() will do just fine... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-10rcu: Advise most users not to enable RCU user modeFrederic Weisbecker
Discourage distros from enabling CONFIG_RCU_USER_QS because it brings overhead for no benefits yet. It's not a useful feature on its own until we can fully run an adaptive tickless kernel. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2012-10-10MODSIGN: Implement module signature checkingDavid Howells
Check the signature on the module against the keys compiled into the kernel or available in a hardware key store. Currently, only RSA keys are supported - though that's easy enough to change, and the signature is expected to contain raw components (so not a PGP or PKCS#7 formatted blob). The signature blob is expected to consist of the following pieces in order: (1) The binary identifier for the key. This is expected to match the SubjectKeyIdentifier from an X.509 certificate. Only X.509 type identifiers are currently supported. (2) The signature data, consisting of a series of MPIs in which each is in the format of a 2-byte BE word sizes followed by the content data. (3) A 12 byte information block of the form: struct module_signature { enum pkey_algo algo : 8; enum pkey_hash_algo hash : 8; enum pkey_id_type id_type : 8; u8 __pad; __be32 id_length; __be32 sig_length; }; The three enums are defined in crypto/public_key.h. 'algo' contains the public-key algorithm identifier (0->DSA, 1->RSA). 'hash' contains the digest algorithm identifier (0->MD4, 1->MD5, 2->SHA1, etc.). 'id_type' contains the public-key identifier type (0->PGP, 1->X.509). '__pad' should be 0. 'id_length' should contain in the binary identifier length in BE form. 'sig_length' should contain in the signature data length in BE form. The lengths are in BE order rather than CPU order to make dealing with cross-compilation easier. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (minor Kconfig fix)
2012-10-10MODSIGN: Provide Kconfig optionsDavid Howells
Provide kernel configuration options for module signing. The following configuration options are added: CONFIG_MODULE_SIG_SHA1 CONFIG_MODULE_SIG_SHA224 CONFIG_MODULE_SIG_SHA256 CONFIG_MODULE_SIG_SHA384 CONFIG_MODULE_SIG_SHA512 These select the cryptographic hash used to digest the data prior to signing. Additionally, the crypto module selected will be built into the kernel as it won't be possible to load it as a module without incurring a circular dependency when the kernel tries to check its signature. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-10module: signature checking hookRusty Russell
We do a very simple search for a particular string appended to the module (which is cache-hot and about to be SHA'd anyway). There's both a config option and a boot parameter which control whether we accept or fail with unsigned modules and modules that are signed with an unknown key. If module signing is enabled, the kernel will be tainted if a module is loaded that is unsigned or has a signature for which we don't have the key. (Useful feedback and tweaks by David Howells <dhowells@redhat.com>) Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-09prio_tree: removeMichel Lespinasse
After both prio_tree users have been converted to use red-black trees, there is no need to keep around the prio tree library anymore. Signed-off-by: Michel Lespinasse <walken@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09Kconfig: clean up the "#if defined(arch)" list for exception-trace sysctl entryCatalin Marinas
Introduce SYSCTL_EXCEPTION_TRACE config option and selec it in the architectures requiring support for the "exception-trace" debug_table entry in kernel/sysctl.c. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09Kconfig: clean up the long arch list for the UID16 config optionCatalin Marinas
Introduce HAVE_UID16 config option and select it in corresponding architecture Kconfig files. UID16 now only depends on HAVE_UID16. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-08X.509: Add simple ASN.1 grammar compilerDavid Howells
Add a simple ASN.1 grammar compiler. This produces a bytecode output that can be fed to a decoder to inform the decoder how to interpret the ASN.1 stream it is trying to parse. Action functions can be specified in the grammar by interpolating: ({ foo }) after a type, for example: SubjectPublicKeyInfo ::= SEQUENCE { algorithm AlgorithmIdentifier, subjectPublicKey BIT STRING ({ do_key_data }) } The decoder is expected to call these after matching this type and parsing the contents if it is a constructed type. The grammar compiler does not currently support the SET type (though it does support SET OF) as I can't see a good way of tracking which members have been encountered yet without using up extra stack space. Currently, the grammar compiler will fail if more than 256 bytes of bytecode would be produced or more than 256 actions have been specified as it uses 8-bit jump values and action indices to keep space usage down. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-06coredump: make core dump functionality optionalAlex Kelly
Adds an expert Kconfig option, CONFIG_COREDUMP, which allows disabling of core dump. This saves approximately 2.6k in the compiled kernel, and complements CONFIG_ELF_CORE, which now depends on it. CONFIG_COREDUMP also disables coredump-related sysctls, except for suid_dumpable and related functions, which are necessary for ptrace. [akpm@linux-foundation.org: fix binfmt_aout.c build] Signed-off-by: Alex Kelly <alex.page.kelly@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Acked-by: Kees Cook <keescook@chromium.org> Cc: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06sections: disable const sections for PA-RISC v2Andi Kleen
The PA-RISC tool chain seems to have some problem with correct read/write attributes on sections. This causes problems when the const sections are fixed up for other architecture to only contain truly read-only data. Disable const sections for PA-RISC This can cause a bit of noise with modpost. Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Helge Deller <deller@gmx.de> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace changes from Eric Biederman: "This is a mostly modest set of changes to enable basic user namespace support. This allows the code to code to compile with user namespaces enabled and removes the assumption there is only the initial user namespace. Everything is converted except for the most complex of the filesystems: autofs4, 9p, afs, ceph, cifs, coda, fuse, gfs2, ncpfs, nfs, ocfs2 and xfs as those patches need a bit more review. The strategy is to push kuid_t and kgid_t values are far down into subsystems and filesystems as reasonable. Leaving the make_kuid and from_kuid operations to happen at the edge of userspace, as the values come off the disk, and as the values come in from the network. Letting compile type incompatible compile errors (present when user namespaces are enabled) guide me to find the issues. The most tricky areas have been the places where we had an implicit union of uid and gid values and were storing them in an unsigned int. Those places were converted into explicit unions. I made certain to handle those places with simple trivial patches. Out of that work I discovered we have generic interfaces for storing quota by projid. I had never heard of the project identifiers before. Adding full user namespace support for project identifiers accounts for most of the code size growth in my git tree. Ultimately there will be work to relax privlige checks from "capable(FOO)" to "ns_capable(user_ns, FOO)" where it is safe allowing root in a user names to do those things that today we only forbid to non-root users because it will confuse suid root applications. While I was pushing kuid_t and kgid_t changes deep into the audit code I made a few other cleanups. I capitalized on the fact we process netlink messages in the context of the message sender. I removed usage of NETLINK_CRED, and started directly using current->tty. Some of these patches have also made it into maintainer trees, with no problems from identical code from different trees showing up in linux-next. After reading through all of this code I feel like I might be able to win a game of kernel trivial pursuit." Fix up some fairly trivial conflicts in netfilter uid/git logging code. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (107 commits) userns: Convert the ufs filesystem to use kuid/kgid where appropriate userns: Convert the udf filesystem to use kuid/kgid where appropriate userns: Convert ubifs to use kuid/kgid userns: Convert squashfs to use kuid/kgid where appropriate userns: Convert reiserfs to use kuid and kgid where appropriate userns: Convert jfs to use kuid/kgid where appropriate userns: Convert jffs2 to use kuid and kgid where appropriate userns: Convert hpfs to use kuid and kgid where appropriate userns: Convert btrfs to use kuid/kgid where appropriate userns: Convert bfs to use kuid/kgid where appropriate userns: Convert affs to use kuid/kgid wherwe appropriate userns: On alpha modify linux_to_osf_stat to use convert from kuids and kgids userns: On ia64 deal with current_uid and current_gid being kuid and kgid userns: On ppc convert current_uid from a kuid before printing. userns: Convert s390 getting uid and gid system calls to use kuid and kgid userns: Convert s390 hypfs to use kuid and kgid where appropriate userns: Convert binder ipc to use kuids userns: Teach security_path_chown to take kuids and kgids userns: Add user namespace support to IMA userns: Convert EVM to deal with kuids and kgids in it's hmac computation ...
2012-10-01Merge tag 'driver-core-3.6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core merge from Greg Kroah-Hartman: "Here is the big driver core update for 3.7-rc1. A number of firmware_class.c updates (as you saw a month or so ago), and some hyper-v updates and some printk fixes as well. All patches that are outside of the drivers/base area have been acked by the respective maintainers, and have all been in the linux-next tree for a while. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" * tag 'driver-core-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (95 commits) memory: tegra{20,30}-mc: Fix reading incorrect register in mc_readl() device.h: Add missing inline to #ifndef CONFIG_PRINTK dev_vprintk_emit memory: emif: Add ifdef CONFIG_DEBUG_FS guard for emif_debugfs_[init|exit] Documentation: Fixes some translation error in Documentation/zh_CN/gpio.txt Documentation: Remove 3 byte redundant code at the head of the Documentation/zh_CN/arm/booting Documentation: Chinese translation of Documentation/video4linux/omap3isp.txt device and dynamic_debug: Use dev_vprintk_emit and dev_printk_emit dev: Add dev_vprintk_emit and dev_printk_emit netdev_printk/netif_printk: Remove a superfluous logging colon netdev_printk/dynamic_netdev_dbg: Directly call printk_emit dev_dbg/dynamic_debug: Update to use printk_emit, optimize stack driver-core: Shut up dev_dbg_reatelimited() without DEBUG tools/hv: Parse /etc/os-release tools/hv: Check for read/write errors tools/hv: Fix exit() error code tools/hv: Fix file handle leak Tools: hv: Implement the KVP verb - KVP_OP_GET_IP_INFO Tools: hv: Rename the function kvp_get_ip_address() Tools: hv: Implement the KVP verb - KVP_OP_SET_IP_INFO Tools: hv: Add an example script to configure an interface ...
2012-10-01Merge tag 'arm64-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64 Pull arm64 support from Catalin Marinas: "Linux support for the 64-bit ARM architecture (AArch64) Features currently supported: - 39-bit address space for user and kernel (each) - 4KB and 64KB page configurations - Compat (32-bit) user applications (ARMv7, EABI only) - Flattened Device Tree (mandated for all AArch64 platforms) - ARM generic timers" * tag 'arm64-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64: (35 commits) arm64: ptrace: remove obsolete ptrace request numbers from user headers arm64: Do not set the SMP/nAMP processor bit arm64: MAINTAINERS update arm64: Build infrastructure arm64: Miscellaneous header files arm64: Generic timers support arm64: Loadable modules arm64: Miscellaneous library functions arm64: Performance counters support arm64: Add support for /proc/sys/debug/exception-trace arm64: Debugging support arm64: Floating point and SIMD arm64: 32-bit (compat) applications support arm64: User access library functions arm64: Signal handling support arm64: VDSO support arm64: System calls handling arm64: ELF definitions arm64: SMP support arm64: DMA mapping API ...
2012-10-01Merge branch 'x86-efi-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86/EFI changes from Ingo Molnar: "EFI loader robustness enhancements plus smaller fixes" * 'x86-efi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: efi: Fix the ACPI BGRT driver for images located in EFI boot services memory efi: Add a function to look up existing IO memory mappings efi: Defer freeing boot services memory until after ACPI init x86, EFI: Calculate the EFI framebuffer size instead of trusting the firmware efifb: Skip DMI checks if the bootloader knows what it's doing efi: initialize efi.runtime_version to make query_variable_info/update_capsule workable efi: Build EFI stub with EFI-appropriate options X86: Improve GOP detection in the EFI boot stub
2012-10-01Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler changes from Ingo Molnar: "Continued quest to clean up and enhance the cputime code by Frederic Weisbecker, in preparation for future tickless kernel features. Other than that, smallish changes." Fix up trivial conflicts due to additions next to each other in arch/{x86/}Kconfig * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (24 commits) cputime: Make finegrained irqtime accounting generally available cputime: Gather time/stats accounting config options into a single menu ia64: Reuse system and user vtime accounting functions on task switch ia64: Consolidate user vtime accounting vtime: Consolidate system/idle context detection cputime: Use a proper subsystem naming for vtime related APIs sched: cpu_power: enable ARCH_POWER sched/nohz: Clean up select_nohz_load_balancer() sched: Fix load avg vs. cpu-hotplug sched: Remove __ARCH_WANT_INTERRUPTS_ON_CTXSW sched: Fix nohz_idle_balance() sched: Remove useless code in yield_to() sched: Add time unit suffix to sched sysctl knobs sched/debug: Limit sd->*_idx range on sysctl sched: Remove AFFINE_WAKEUPS feature flag s390: Remove leftover account_tick_vtime() header cputime: Consolidate vtime handling on context switch sched: Move cputime code to its own file cputime: Generalize CONFIG_VIRT_CPU_ACCOUNTING tile: Remove SD_PREFER_LOCAL leftover ...
2012-09-29efi: Fix the ACPI BGRT driver for images located in EFI boot services memoryJosh Triplett
The ACPI BGRT driver accesses the BIOS logo image when it initializes. However, ACPI 5.0 (which introduces the BGRT) recommends putting the logo image in EFI boot services memory, so that the OS can reclaim that memory. Production systems follow this recommendation, breaking the ACPI BGRT driver. Move the bulk of the BGRT code to run during a new EFI late initialization phase, which occurs after switching EFI to virtual mode, and after initializing ACPI, but before freeing boot services memory. Copy the BIOS logo image to kernel memory at that point, and make it accessible to the BGRT driver. Rework the existing ACPI BGRT driver to act as a simple wrapper exposing that image (and the properties from the BGRT) via sysfs. Signed-off-by: Josh Triplett <josh@joshtriplett.org> Link: http://lkml.kernel.org/r/93ce9f823f1c1f3bb88bdd662cce08eee7a17f5d.1348876882.git.josh@joshtriplett.org Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2012-09-29efi: Defer freeing boot services memory until after ACPI initJosh Triplett
Some new ACPI 5.0 tables reference resources stored in boot services memory, so keep that memory around until we have ACPI and can extract data from it. Signed-off-by: Josh Triplett <josh@joshtriplett.org> Link: http://lkml.kernel.org/r/baaa6d44bdc4eb0c58e5d1b4ccd2c729f854ac55.1348876882.git.josh@joshtriplett.org Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2012-09-26rcu: Userspace RCU extended QS selftestFrederic Weisbecker
Provide a config option that enables the userspace RCU extended quiescent state on every CPUs by default. This is for testing purpose. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Alessio Igor Bogani <abogani@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Avi Kivity <avi@redhat.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Christoph Lameter <cl@linux.com> Cc: Geoff Levand <geoff@infradead.org> Cc: Gilad Ben Yossef <gilad@benyossef.com> Cc: Hakan Akkan <hakanakkan@gmail.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Kevin Hilman <khilman@ti.com> Cc: Max Krasnyansky <maxk@qualcomm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Sven-Thorsten Dietrich <thebigcorporation@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2012-09-26rcu: Settle config for userspace extended quiescent stateFrederic Weisbecker
Create a new config option under the RCU menu that put CPUs under RCU extended quiescent state (as in dynticks idle mode) when they run in userspace. This require some contribution from architectures to hook into kernel and userspace boundaries. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Alessio Igor Bogani <abogani@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Avi Kivity <avi@redhat.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Christoph Lameter <cl@linux.com> Cc: Geoff Levand <geoff@infradead.org> Cc: Gilad Ben Yossef <gilad@benyossef.com> Cc: Hakan Akkan <hakanakkan@gmail.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Kevin Hilman <khilman@ti.com> Cc: Max Krasnyansky <maxk@qualcomm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Sven-Thorsten Dietrich <thebigcorporation@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2012-09-25cputime: Make finegrained irqtime accounting generally availableFrederic Weisbecker
There is no known reason for this option to be unavailable on other archs than x86. They just need to call enable_sched_clock_irqtime() if they have a sufficiently finegrained clock to make it working. Move it to the general option and let the user choose between it and pure tick based or virtual cputime accounting. Note that virtual cputime accounting already performs a finegrained irqtime accounting. CONFIG_IRQ_TIME_ACCOUNTING is a kind of middle ground between tick and virtual based accounting. So CONFIG_IRQ_TIME_ACCOUNTING and CONFIG_VIRT_CPU_ACCOUNTING are mutually exclusive choices. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org>
2012-09-25cputime: Gather time/stats accounting config options into a single menuFrederic Weisbecker
This debloats a bit the general config menu and make these config options easier to find. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org>
2012-09-21userns: Convert the ufs filesystem to use kuid/kgid where appropriateEric W. Biederman
Cc: Evgeniy Dushistov <dushistov@mail.ru> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-09-21userns: Convert the udf filesystem to use kuid/kgid where appropriateEric W. Biederman
Cc: Jan Kara <jack@suse.cz> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-09-21userns: Convert ubifs to use kuid/kgidEric W. Biederman
Cc: Artem Bityutskiy <dedekind1@gmail.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-09-21userns: Convert squashfs to use kuid/kgid where appropriateEric W. Biederman
Cc: Phillip Lougher <phillip@squashfs.org.uk> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-09-21userns: Convert reiserfs to use kuid and kgid where appropriateEric W. Biederman
Cc: reiserfs-devel@vger.kernel.org Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-09-21userns: Convert jfs to use kuid/kgid where appropriateEric W. Biederman
Cc: Dave Kleikamp <shaggy@kernel.org> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-09-21userns: Convert jffs2 to use kuid and kgid where appropriateEric W. Biederman
- General routine uid/gid conversion work - When storing posix acls treat ACL_USER and ACL_GROUP separately so I can call from_kuid or from_kgid as appropriate. - When reading posix acls treat ACL_USER and ACL_GROUP separately so I can call make_kuid or make_kgid as appropriate. Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-09-21userns: Convert hpfs to use kuid and kgid where appropriateEric W. Biederman
Cc: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-09-21userns: Convert btrfs to use kuid/kgid where appropriateEric W. Biederman
Cc: Chris Mason <chris.mason@fusionio.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-09-21userns: Convert bfs to use kuid/kgid where appropriateEric W. Biederman
Cc: "Tigran A. Aivazian" <tigran@aivazian.fsnet.co.uk> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-09-21userns: Convert affs to use kuid/kgid wherwe appropriateEric W. Biederman
2012-09-21userns: Convert binder ipc to use kuidsEric W. Biederman
Cc: Arve Hjønnevåg <arve@android.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-09-21userns: Add user namespace support to IMAEric W. Biederman
Use kuid's in the IMA rules. When reporting the current uid in audit logs use from_kuid to get a usable value. Cc: Mimi Zohar <zohar@us.ibm.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-09-21userns: Convert EVM to deal with kuids and kgids in it's hmac computationEric W. Biederman
2012-09-21userns: Convert hostfs to use kuid and kgid where appropriateEric W. Biederman
Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-09-21userns: Convert tomoyo to use kuid and kgid where appropriateEric W. Biederman
Acked-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-09-21userns: Convert apparmor to use kuid and kgid where appropriateEric W. Biederman
Cc: John Johansen <john.johansen@canonical.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-09-21userns: Convert loop to use kuid_t instead of uid_tEric W. Biederman
Cc: Jens Axboe <jaxboe@fusionio.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-09-21userns: Convert ipathfs to use GLOBAL_ROOT_UID and GLOBAL_ROOT_GIDEric W. Biederman
Acked-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-09-21userns: Convert freevxfs to use kuid/kgid where appropriateEric W. Biederman
Cc: Christoph Hellwig <hch@infradead.org> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-09-21userns: Convert the sysv filesystem to use kuid/kgid where appropriateEric W. Biederman
