path: root/init
2009-03-10menu: fix embedded menu snafuRandy Dunlap
The COMPAT_BRK kconfig symbol does not depend on EMBEDDED, but it is in the midst of the EMBEDDED menu symbols, so it mucks up the EMBEDDED menu. Fix by moving it to just after all of the EMBEDDED menu symbols. Also, ANON_INODES has a similar problem, so move it to just above the EMBEDDED menu items since it is used in the EMBEDDED menu. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-26rcu: Teach RCU that idle task is not quiscent state at bootPaul E. McKenney
This patch fixes a bug located by Vegard Nossum with the aid of kmemcheck, updated based on review comments from Nick Piggin, Ingo Molnar, and Andrew Morton. And cleans up the variable-name and function-name language. ;-) The boot CPU runs in the context of its idle thread during boot-up. During this time, idle_cpu(0) will always return nonzero, which will fool Classic and Hierarchical RCU into deciding that a large chunk of the boot-up sequence is a big long quiescent state. This in turn causes RCU to prematurely end grace periods during this time. This patch changes the rcutree.c and rcuclassic.c rcu_check_callbacks() function to ignore the idle task as a quiescent state until the system has started up the scheduler in rest_init(), introducing a new non-API function rcu_idle_now_means_idle() to inform RCU of this transition. RCU maintains an internal rcu_idle_cpu_truthful variable to track this state, which is then used by rcu_check_callback() to determine if it should believe idle_cpu(). Because this patch has the effect of disallowing RCU grace periods during long stretches of the boot-up sequence, this patch also introduces Josh Triplett's UP-only optimization that makes synchronize_rcu() be a no-op if num_online_cpus() returns 1. This allows boot-time code that calls synchronize_rcu() to proceed normally. Note, however, that RCU callbacks registered by call_rcu() will likely queue up until later in the boot sequence. Although rcuclassic and rcutree can also use this same optimization after boot completes, rcupreempt must restrict its use of this optimization to the portion of the boot sequence before the scheduler starts up, given that an rcupreempt RCU read-side critical section may be preeempted. In addition, this patch takes Nick Piggin's suggestion to make the system_state global variable be __read_mostly. Changes since v4: o Changes the name of the introduced function and variable to be less emotional. ;-) Changes since v3: o WARN_ON(nr_context_switches() > 0) to verify that RCU switches out of boot-time mode before the first context switch, as suggested by Nick Piggin. Changes since v2: o Created rcu_blocking_is_gp() internal-to-RCU API that determines whether a call to synchronize_rcu() is itself a grace period. o The definition of rcu_blocking_is_gp() for rcuclassic and rcutree checks to see if but a single CPU is online. o The definition of rcu_blocking_is_gp() for rcupreempt checks to see both if but a single CPU is online and if the system is still in early boot. This allows rcupreempt to again work correctly if running on a single CPU after booting is complete. o Added check to rcupreempt's synchronize_sched() for there being but one online CPU. Tested all three variants both SMP and !SMP, booted fine, passed a short rcutorture test on both x86 and Power. Located-by: Vegard Nossum <vegard.nossum@gmail.com> Tested-by: Vegard Nossum <vegard.nossum@gmail.com> Tested-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-21Consolidate driver_probe_done() loops into one placeArjan van de Ven
there's a few places that currently loop over driver_probe_done(), and I'm about to add another one. This patch abstracts it into a helper to reduce duplication. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Len Brown <lenb@kernel.org> Acked-by: Greg KH <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixesLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixes: kbuild: fix kbuild.txt typos kbuild: print usage with no arguments in scripts/config Revert "kbuild: strip generated symbols from *.ko"
2009-01-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (92 commits) gianfar: Revive VLAN support vlan: Export symbols as non GPL symbols. bnx2x: tx_has_work should not wait for FW netxen: reduce memory footprint netxen: fix vlan tso/checksum offload net: Fix linux/if_frad.h's suitability for userspace. net: Move config NET_NS to from net/Kconfig to init/Kconfig isdn: Fix missing ifdef in isdn_ppp networking: document "nc" in addition to "netcat" in netconsole.txt e1000e: workaround hw errata af_key: initialize xfrm encap_oa virtio_net: Fix MAX_PACKET_LEN to support 802.1Q VLANs lcs: fix compilation for !CONFIG_IP_MULTICAST rtl8187: Add termination packet to prevent stall iwlwifi: fix rs_get_rate WARN_ON() p54usb: fix packet loss with first generation devices sctp: Fix another socket race during accept/peeloff sctp: Properly timestamp outgoing data chunks for rtx purposes sctp: Correctly start rtx timer on new packet transmissions. sctp: Fix crc32c calculations on big-endian arhes. ...
2009-01-26net: Move config NET_NS to from net/Kconfig to init/KconfigMatt Helsley
Make NET_NS available underneath the generic Namespaces config option since all of the other namespace options are there. Signed-off-by: Matt Helsley <matthltc@us.ibm.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-22Merge branch 'core/debugobjects' into core/urgentThomas Gleixner
2009-01-15cgroups: consolidate cgroup documentsLi Zefan
Move Documentation/cpusets.txt and Documentation/controllers/* to Documentation/cgroups/ Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-15cgroups: clean up KconfigLi Zefan
- move CONFIG_PROC_PID_CPUSET into cgroup menu - move MM_OWNER to the bottom for better menu indent - fix typos - use tabs not spaces Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-15rcu: move Kconfig menuMike Travis
Move RCU Kconfig options from top-level menu to an "RCU Subsystem" menu under the "General Setup" menu. Signed-off-by: Mike Travis <travis@sgi.com> Tested-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-14Revert "kbuild: strip generated symbols from *.ko"Sam Ravnborg
This reverts commit ad7a953c522ceb496611d127e51e278bfe0ff483. And commit: ("allow stripping of generated symbols under CONFIG_KALLSYMS_ALL") 9bb482476c6c9d1ae033306440c51ceac93ea80c These stripping patches has caused a set of issues: 1) People have reported compatibility issues with binutils due to lack of support for `--strip-unneeded-symbols' with objcopy 2.15.92.0.2 Reported by: Wenji 2) ccache and distcc no longer works as expeced Reported by: Ted, Roland, + others 3) The installed modules increased a lot in size Reported by: Ted, Davej + others Reported-by: Wenji Huang <wenji.huang@oracle.com> Reported-by: "Theodore Ts'o" <tytso@mit.edu> Reported-by: Dave Jones <davej@redhat.com> Reported-by: Roland McGrath <roland@redhat.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-01-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/pkl/squashfs-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/pkl/squashfs-linus: MAINTAINERS: squashfs entry Squashfs: documentation Squashfs: initrd support Squashfs: Kconfig entry Squashfs: Makefiles Squashfs: header files Squashfs: block operations Squashfs: cache operations Squashfs: uid/gid lookup operations Squashfs: fragment block operations Squashfs: export operations Squashfs: super block operations Squashfs: symlink operations Squashfs: regular file operations Squashfs: directory readdir operations Squashfs: directory lookup operations Squashfs: inode operations
2009-01-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-nommuLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-nommu: NOMMU: Support XIP on initramfs NOMMU: Teach kobjsize() about VMA regions. FLAT: Don't attempt to expand the userspace stack to fill the space allocated FDPIC: Don't attempt to expand the userspace stack to fill the space allocated NOMMU: Improve procfs output using per-MM VMAs NOMMU: Make mmap allocation page trimming behaviour configurable. NOMMU: Make VMAs per MM as for MMU-mode linux NOMMU: Delete askedalloc and realalloc variables NOMMU: Rename ARM's struct vm_region NOMMU: Fix cleanup handling in ramfs_nommu_get_umapped_area()
2009-01-08memcg: mem+swap controller KconfigKAMEZAWA Hiroyuki
Config and control variable for mem+swap controller. This patch adds CONFIG_CGROUP_MEM_RES_CTLR_SWAP (memory resource controller swap extension.) For accounting swap, it's obvious that we have to use additional memory to remember "who uses swap". This adds more overhead. So, it's better to offer "choice" to users. This patch adds 2 choices. This patch adds 2 parameters to enable swap extension or not. - CONFIG - boot option Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: fix a typo in KconfigLi Zefan
s/contoller/controller/ Signed-of-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08cgroups: make cgroup config a submenuKAMEZAWA Hiroyuki
Making CGROUP related configs be a sub-menu. This patch make CGROUP related configs be a sub-menu and makes 1st level configs of "General Setup" shorter. including following additional changes - add help comment about CGROUPS and GROUP_SCHED. - moved MM_OWNER config to the bottom. (for good indent in menuconfig) Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08NOMMU: Support XIP on initramfsDavid Howells
Support XIP on files unpacked from the initramfs image on NOMMU systems. This simply requires the length of the file to be preset so that the ramfs fs can attempt to garner sufficient contiguous storage to store the file (NOMMU mmap can only map contiguous RAM). All the other bits to do XIP on initramfs files are present: (1) ramfs's truncate attempts to allocate a contiguous run of pages when a file is truncated upwards from nothing. (2) ramfs sets BDI on its files to indicate direct mapping is possible, and that its files can be mapped for read, write and exec. (3) NOMMU mmap() will use the above bits to determine that it can do XIP. Possibly this needs better controls, because it will _always_ try and do XIP. One disadvantage of this very simplistic approach is that sufficient space will be allocated to store the whole file, and not just the bit that would be XIP'd. To deal with this, though, the initramfs unpacker would have to be able to parse the file contents. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Paul Mundt <lethal@linux-sh.org>
2009-01-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/arjan/linux-2.6-asyncLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/arjan/linux-2.6-async: async: don't do the initcall stuff post boot bootchart: improve output based on Dave Jones' feedback async: make the final inode deletion an asynchronous event fastboot: Make libata initialization even more async fastboot: make the libata port scan asynchronous fastboot: make scsi probes asynchronous async: Asynchronous function calls to speed up kernel boot
2009-01-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (24 commits) trivial: chack -> check typo fix in main Makefile trivial: Add a space (and a comma) to a printk in 8250 driver trivial: Fix misspelling of "firmware" in docs for ncr53c8xx/sym53c8xx trivial: Fix misspelling of "firmware" in powerpc Makefile trivial: Fix misspelling of "firmware" in usb.c trivial: Fix misspelling of "firmware" in qla1280.c trivial: Fix misspelling of "firmware" in a100u2w.c trivial: Fix misspelling of "firmware" in megaraid.c trivial: Fix misspelling of "firmware" in ql4_mbx.c trivial: Fix misspelling of "firmware" in acpi_memhotplug.c trivial: Fix misspelling of "firmware" in ipw2100.c trivial: Fix misspelling of "firmware" in atmel.c trivial: Fix misspelled firmware in Kconfig trivial: fix an -> a typos in documentation and comments trivial: fix then -> than typos in comments and documentation trivial: update Jesper Juhl CREDITS entry with new email trivial: fix singal -> signal typo trivial: Fix incorrect use of "loose" in event.c trivial: printk: fix indentation of new_text_line declaration trivial: rtc-stk17ta8: fix sparse warning ...
2009-01-07async: Asynchronous function calls to speed up kernel bootArjan van de Ven
Right now, most of the kernel boot is strictly synchronous, such that various hardware delays are done sequentially. In order to make the kernel boot faster, this patch introduces infrastructure to allow doing some of the initialization steps asynchronously, which will hide significant portions of the hardware delays in practice. In order to not change device order and other similar observables, this patch does NOT do full parallel initialization. Rather, it operates more in the way an out of order CPU does; the work may be done out of order and asynchronous, but the observable effects (instruction retiring for the CPU) are still done in the original sequence. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
2009-01-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (60 commits) uio: make uio_info's name and version const UIO: Documentation for UIO ioport info handling UIO: Pass information about ioports to userspace (V2) UIO: uio_pdrv_genirq: allow custom irq_flags UIO: use pci_ioremap_bar() in drivers/uio arm: struct device - replace bus_id with dev_name(), dev_set_name() libata: struct device - replace bus_id with dev_name(), dev_set_name() avr: struct device - replace bus_id with dev_name(), dev_set_name() block: struct device - replace bus_id with dev_name(), dev_set_name() chris: struct device - replace bus_id with dev_name(), dev_set_name() dmi: struct device - replace bus_id with dev_name(), dev_set_name() gadget: struct device - replace bus_id with dev_name(), dev_set_name() gpio: struct device - replace bus_id with dev_name(), dev_set_name() gpu: struct device - replace bus_id with dev_name(), dev_set_name() hwmon: struct device - replace bus_id with dev_name(), dev_set_name() i2o: struct device - replace bus_id with dev_name(), dev_set_name() IA64: struct device - replace bus_id with dev_name(), dev_set_name() i7300_idle: struct device - replace bus_id with dev_name(), dev_set_name() infiniband: struct device - replace bus_id with dev_name(), dev_set_name() ISDN: struct device - replace bus_id with dev_name(), dev_set_name() ...
2009-01-06init/main.c: mark late_time_init as __initdataJan Beulich
Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06autodetect_raid: add missing __init markingMike Frysinger
The function autodetect_raid is only used by __init functions, and it refers to __initdata, so it needs __init markings. Fixes this error: The function autodetect_raid() references the variable __initdata raid_noautodetect. This is often because autodetect_raid lacks a __initdata annotation or the annotation of raid_noautodetect is wrong. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06Remove remaining unwinder codeAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Gabor Gombas <gombasg@sztaki.hu> Cc: Jan Beulich <jbeulich@novell.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Ingo Molnar <mingo@elte.hu>, Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06do_mounts: add device info to mount messageMarton Balint
In the past, I used the root=... command line parameter to specify the root filesystem to the kernel. Now it seems that specifying it is not necessary. The kernel detects the root filesystem even if the kernel command line is empty. My root fs is on a raid1 device by the way, and I am not using initrd for the boot process. If the kernel detects the root filesystem somehow, I think it should print out the result of this detection, otherwise I will not know which device has the root filesystem. Or is there an easy way to get this information on a running system? I had a quick look at the /proc and /sys filesystems, but haven't found anything useful there. Signed-off-by: Marton Balint <cus@fazekas.hu> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06init: properly placing noinline keywordRakib Mullick
checkpatch warns about 'static void noinline'. It wants `static noinline void'. Both are permissible, but the kernel consistently uses `static inline' and `static noinline', and consistency is good. Hence let's keep the checkpatch warning and fix up this code site. [akpm@linux-foundation.org: rewrote changelog] Signed-off-by: Md.Rakib H. Mullick <rakib.mullick@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06shmem: unify regular and tiny shmemMatt Mackall
tiny-shmem shares most of its 130 lines of code with shmem and tends to break when particular bits of shmem get modified. Unifying saves code and makes keeping these two in sync much easier. before: 14367 392 24 14783 39bf mm/shmem.o 396 72 8 476 1dc mm/tiny-shmem.o after: 14367 392 24 14783 39bf mm/shmem.o 412 72 8 492 1ec mm/shmem.o tiny Signed-off-by: Matt Mackall <mpm@selenic.com> Acked-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06sysfs: clarify SYSFS_DEPRECATED help textKay Sievers
This should make the help text of SYSFS_DEPRECATED more clear, that this is _not_ about (what some people think it is) suppressing a few symlinks and variables, but a different sysfs _layout_ with new features. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-06trivial: add missing printk loglevel in start_kernelRon Lee
Add missing printk loglevel in start_kernel Signed-off-by: Ron Lee <ron@debian.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-01-05Squashfs: initrd supportPhillip Lougher
Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2009-01-05remove CONFIG_KMODJohannes Berg
Now that nothing depends on it any more, remove CONFIG_KMOD. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-01-03Merge branch 'cpus4096-for-linus-3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'cpus4096-for-linus-3' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (77 commits) x86: setup_per_cpu_areas() cleanup cpumask: fix compile error when CONFIG_NR_CPUS is not defined cpumask: use alloc_cpumask_var_node where appropriate cpumask: convert shared_cpu_map in acpi_processor* structs to cpumask_var_t x86: use cpumask_var_t in acpi/boot.c x86: cleanup some remaining usages of NR_CPUS where s/b nr_cpu_ids sched: put back some stack hog changes that were undone in kernel/sched.c x86: enable cpus display of kernel_max and offlined cpus ia64: cpumask fix for is_affinity_mask_valid() cpumask: convert RCU implementations, fix xtensa: define __fls mn10300: define __fls m32r: define __fls h8300: define __fls frv: define __fls cris: define __fls cpumask: CONFIG_DISABLE_OBSOLETE_CPUMASK_FUNCTIONS cpumask: zero extra bits in alloc_cpumask_var_node cpumask: replace for_each_cpu_mask_nr with for_each_cpu in kernel/time/ cpumask: convert mm/ ...
2009-01-02Merge branch 'cpus4096-for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'cpus4096-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (66 commits) x86: export vector_used_by_percpu_irq x86: use logical apicid in x2apic_cluster's x2apic_cpu_mask_to_apicid_and() sched: nominate preferred wakeup cpu, fix x86: fix lguest used_vectors breakage, -v2 x86: fix warning in arch/x86/kernel/io_apic.c sched: fix warning in kernel/sched.c sched: move test_sd_parent() to an SMP section of sched.h sched: add SD_BALANCE_NEWIDLE at MC and CPU level for sched_mc>0 sched: activate active load balancing in new idle cpus sched: bias task wakeups to preferred semi-idle packages sched: nominate preferred wakeup cpu sched: favour lower logical cpu number for sched_mc balance sched: framework for sched_mc/smt_power_savings=N sched: convert BALANCE_FOR_xx_POWER to inline functions x86: use possible_cpus=NUM to extend the possible cpus allowed x86: fix cpu_mask_to_apicid_and to include cpu_online_mask x86: update io_apic.c to the new cpumask code x86: Introduce topology_core_cpumask()/topology_thread_cpumask() x86: xen: use smp_call_function_many() x86: use work_on_cpu in x86/kernel/cpu/mcheck/mce_amd_64.c ... Fixed up trivial conflict in kernel/time/tick-sched.c manually
2009-01-02kbuild: Remove gcc 4.1.0 quirk from init/main.cIngo Molnar
Impact: cleanup We now have a cleaner check for gcc 4.1.0/4.1.1 trouble in include/linux/compiler-gcc4.h, so remove the 4.1.0 quirk from init/main.c. Reported-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-01cpumask: Use find_last_bit()Rusty Russell
Impact: cleanup There's one obvious place to use it: to find the highest possible cpu. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-01-01cpumask: Use accessors code in coreRusty Russell
Impact: use new API cpu_*_map are going away in favour of cpu_*_mask, but const pointers. So we have accessors where we really do want to frob them. Archs will also need the (trivial) conversion before we can finally remove cpu_*_map. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Mike Travis <travis@sgi.com>
2008-12-31Merge branch 'irq-fixes-for-linus-4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-fixes-for-linus-4' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sparseirq: move __weak symbols into separate compilation unit sparseirq: work around __weak alias bug sparseirq: fix hang with !SPARSE_IRQ sparseirq: set lock_class for legacy irq when sparse_irq is selected sparseirq: work around compiler optimizing away __weak functions sparseirq: fix desc->lock init sparseirq: do not printk when migrating IRQ descriptors sparseirq: remove duplicated arch_early_irq_init() irq: simplify for_each_irq_desc() usage proc: remove ifdef CONFIG_SPARSE_IRQ from stat.c irq: for_each_irq_desc() move to irqnr.h hrtimer: remove #include <linux/irq.h>
2008-12-31Merge branch 'master' of ↵Rusty Russell
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: arch/x86/kernel/io_apic.c
2008-12-30Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, sparseirq: clean up Kconfig entry x86: turn CONFIG_SPARSE_IRQ off by default sparseirq: fix numa_migrate_irq_desc dependency and comments sparseirq: add kernel-doc notation for new member in irq_desc, -v2 locking, irq: enclose irq_desc_lock_class in CONFIG_LOCKDEP sparseirq, xen: make sure irq_desc is allocated for interrupts sparseirq: fix !SMP building, #2 x86, sparseirq: move irq_desc according to smp_affinity, v7 proc: enclose desc variable of show_stat() in CONFIG_SPARSE_IRQ sparse irqs: add irqnr.h to the user headers list sparse irqs: handle !GENIRQ platforms sparseirq: fix !SMP && !PCI_MSI && !HT_IRQ build sparseirq: fix Alpha build failure sparseirq: fix typo in !CONFIG_IO_APIC case x86, MSI: pass irq_cfg and irq_desc x86: MSI start irq numbering from nr_irqs_gsi x86: use NR_IRQS_LEGACY sparse irq_desc[] array: core kernel and x86 changes genirq: record IRQ_LEVEL in irq_desc[] irq.h: remove padding from irq_desc on 64bits
2008-12-30Merge branch 'core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (63 commits) stacktrace: provide save_stack_trace_tsk() weak alias rcu: provide RCU options on non-preempt architectures too printk: fix discarding message when recursion_bug futex: clean up futex_(un)lock_pi fault handling "Tree RCU": scalable classic RCU implementation futex: rename field in futex_q to clarify single waiter semantics x86/swiotlb: add default swiotlb_arch_range_needs_mapping x86/swiotlb: add default phys<->bus conversion x86: unify pci iommu setup and allow swiotlb to compile for 32 bit x86: add swiotlb allocation functions swiotlb: consolidate swiotlb info message printing swiotlb: support bouncing of HighMem pages swiotlb: factor out copy to/from device swiotlb: add arch hook to force mapping swiotlb: allow architectures to override phys<->bus<->phys conversions swiotlb: add comment where we handle the overflow of a dma mask on 32 bit rcu: fix rcutorture behavior during reboot resources: skip sanity check of busy resources swiotlb: move some definitions to header swiotlb: allow architectures to override swiotlb pool allocation ... Fix up trivial conflicts in arch/x86/kernel/Makefile arch/x86/mm/init_32.c include/linux/hardirq.h as per Ingo's suggestions.
2008-12-30Merge branch 'master' of ↵Rusty Russell
2008-12-29sparseirq: move __weak symbols into separate compilation unitYinghai Lu
GCC has a bug with __weak alias functions: if the functions are in the same compilation unit as their call site, GCC can decide to inline them - and thus rob the linker of the opportunity to override the weak alias with the real thing. So move all the IRQ handling related __weak symbols to kernel/irq/chip.c. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-nextLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next: (25 commits) allow stripping of generated symbols under CONFIG_KALLSYMS_ALL kbuild: strip generated symbols from *.ko kbuild: simplify use of genksyms kernel-doc: check for extra kernel-doc notations kbuild: add headerdep used to detect inclusion cycles in header files kbuild: fix string equality testing in tags.sh kbuild: fix make tags/cscope kbuild: fix make incompatibility kbuild: remove TAR_IGNORE setlocalversion: add git-svn support setlocalversion: print correct subversion revision scripts: improve the decodecode script scripts/package: allow custom options to rpm genksyms: allow to ignore symbol checksum changes genksyms: track symbol checksum changes tags and cscope support really belongs in a shell script kconfig: fix options to check-lxdialog.sh kbuild: gen_init_cpio expands shell variables in file names remove bashisms from scripts/extract-ikconfig kbuild: teach mkmakfile to be silent ...
2008-12-28Merge branch 'tracing-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (241 commits) sched, trace: update trace_sched_wakeup() tracing/ftrace: don't trace on early stage of a secondary cpu boot, v3 Revert "x86: disable X86_PTRACE_BTS" ring-buffer: prevent false positive warning ring-buffer: fix dangling commit race ftrace: enable format arguments checking x86, bts: memory accounting x86, bts: add fork and exit handling ftrace: introduce tracing_reset_online_cpus() helper tracing: fix warnings in kernel/trace/trace_sched_switch.c tracing: fix warning in kernel/trace/trace.c tracing/ring-buffer: remove unused ring_buffer size trace: fix task state printout ftrace: add not to regex on filtering functions trace: better use of stack_trace_enabled for boot up code trace: add a way to enable or disable the stack tracer x86: entry_64 - introduce FTRACE_ frame macro v2 tracing/ftrace: add the printk-msg-only option tracing/ftrace: use preempt_enable_no_resched_notrace in ring_buffer_time_stamp() x86, bts: correctly report invalid bts records ... Fixed up trivial conflict in scripts/recordmcount.pl due to SH bits being already partly merged by the SH merge.
2008-12-27sparseirq: work around compiler optimizing away __weak functionsYinghai Lu
Impact: fix panic on null pointer with sparseirq Some GCC versions seem to inline the weak global function, when that function is empty. Work it around, by making the functions return a (dummy) integer. Signed-off-by: Yinghai <yinghai@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-25rcu: provide RCU options on non-preempt architectures tooIngo Molnar
Impact: build fix Some old architectures still do not use kernel/Kconfig.preempt, so the moving of the RCU options there broke their build: In file included from /home/mingo/tip/include/linux/sem.h:81, from /home/mingo/tip/include/linux/sched.h:69, from /home/mingo/tip/arch/alpha/kernel/asm-offsets.c:9: /home/mingo/tip/include/linux/rcupdate.h:62:2: error: #error "Unknown RCU implementation specified to kernel configuration" Move these options back to init/Kconfig, which every architecture includes. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-19allow stripping of generated symbols under CONFIG_KALLSYMS_ALLJan Beulich
Building upon parts of the module stripping patch, this patch introduces similar stripping for vmlinux when CONFIG_KALLSYMS_ALL=y. Using CONFIG_KALLSYMS_STRIP_GENERATED reduces the overhead of CONFIG_KALLSYMS_ALL from 245k/310k to 65k/80k for the (i386/x86-64) kernels I tested with. The patch also does away with the need to special case the kallsyms- internal symbols by making them available even in the first linking stage. While it is a generated file, the patch includes the changes to scripts/genksyms/keywords.c_shipped, as I'm unsure what the procedure here is. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-12-18"Tree RCU": scalable classic RCU implementationPaul E. McKenney
This patch fixes a long-standing performance bug in classic RCU that results in massive internal-to-RCU lock contention on systems with more than a few hundred CPUs. Although this patch creates a separate flavor of RCU for ease of review and patch maintenance, it is intended to replace classic RCU. This patch still handles stress better than does mainline, so I am still calling it ready for inclusion. This patch is against the -tip tree. Nevertheless, experience on an actual 1000+ CPU machine would still be most welcome. Most of the changes noted below were found while creating an rcutiny (which should permit ejecting the current rcuclassic) and while doing detailed line-by-line documentation. Updates from v9 (http://lkml.org/lkml/2008/12/2/334): o Fixes from remainder of line-by-line code walkthrough, including comment spelling, initialization, undesirable narrowing due to type conversion, removing redundant memory barriers, removing redundant local-variable initialization, and removing redundant local variables. I do not believe that any of these fixes address the CPU-hotplug issues that Andi Kleen was seeing, but please do give it a whirl in case the machine is smarter than I am. A writeup from the walkthrough may be found at the following URL, in case you are suffering from terminal insomnia or masochism: http://www.kernel.org/pub/linux/kernel/people/paulmck/tmp/rcutree-walkthrough.2008.12.16a.pdf o Made rcutree tracing use seq_file, as suggested some time ago by Lai Jiangshan. o Added a .csv variant of the rcudata debugfs trace file, to allow people having thousands of CPUs to drop the data into a spreadsheet. Tested with oocalc and gnumeric. Updated documentation to suit. Updates from v8 (http://lkml.org/lkml/2008/11/15/139): o Fix a theoretical race between grace-period initialization and force_quiescent_state() that could occur if more than three jiffies were required to carry out the grace-period initialization. Which it might, if you had enough CPUs. o Apply Ingo's printk-standardization patch. o Substitute local variables for repeated accesses to global variables. o Fix comment misspellings and redundant (but harmless) increments of ->n_rcu_pending (this latter after having explicitly added it). o Apply checkpatch fixes. Updates from v7 (http://lkml.org/lkml/2008/10/10/291): o Fixed a number of problems noted by Gautham Shenoy, including the cpu-stall-detection bug that he was having difficulty convincing me was real. ;-) o Changed cpu-stall detection to wait for ten seconds rather than three in order to reduce false positive, as suggested by Ingo Molnar. o Produced a design document (http://lwn.net/Articles/305782/). The act of writing this document uncovered a number of both theoretical and "here and now" bugs as noted below. o Fix dynticks_nesting accounting confusion, simplify WARN_ON() condition, fix kerneldoc comments, and add memory barriers in dynticks interface functions. o Add more data to tracing. o Remove unused "rcu_barrier" field from rcu_data structure. o Count calls to rcu_pending() from scheduling-clock interrupt to use as a surrogate timebase should jiffies stop counting. o Fix a theoretical race between force_quiescent_state() and grace-period initialization. Yes, initialization does have to go on for some jiffies for this race to occur, but given enough CPUs... Updates from v6 (http://lkml.org/lkml/2008/9/23/448): o Fix a number of checkpatch.pl complaints. o Apply review comments from Ingo Molnar and Lai Jiangshan on the stall-detection code. o Fix several bugs in !CONFIG_SMP builds. o Fix a misspelled config-parameter name so that RCU now announces at boot time if stall detection is configured. o Run tests on numerous combinations of configurations parameters, which after the fixes above, now build and run correctly. Updates from v5 (http://lkml.org/lkml/2008/9/15/92, bad subject line): o Fix a compiler error in the !CONFIG_FANOUT_EXACT case (blew a changeset some time ago, and finally got around to retesting this option). o Fix some tracing bugs in rcupreempt that caused incorrect totals to be printed. o I now test with a more brutal random-selection online/offline script (attached). Probably more brutal than it needs to be on the people reading it as well, but so it goes. o A number of optimizations and usability improvements: o Make rcu_pending() ignore the grace-period timeout when there is no grace period in progress. o Make force_quiescent_state() avoid going for a global lock in the case where there is no grace period in progress. o Rearrange struct fields to improve struct layout. o Make call_rcu() initiate a grace period if RCU was idle, rather than waiting for the next scheduling clock interrupt. o Invoke rcu_irq_enter() and rcu_irq_exit() only when idle, as suggested by Andi Kleen. I still don't completely trust this change, and might back it out. o Make CONFIG_RCU_TRACE be the single config variable manipulated for all forms of RCU, instead of the prior confusion. o Document tracing files and formats for both rcupreempt and rcutree. Updates from v4 for those missing v5 given its bad subject line: o Separated dynticks interface so that NMIs and irqs call separate functions, greatly simplifying it. In particular, this code no longer requires a proof of correctness. ;-) o Separated dynticks state out into its own per-CPU structure, avoiding the duplicated accounting. o The case where a dynticks-idle CPU runs an irq handler that invokes call_rcu() is now correctly handled, forcing that CPU out of dynticks-idle mode. o Review comments have been applied (thank you all!!!). For but one example, fixed the dynticks-ordering issue that Manfred pointed out, saving me much debugging. ;-) o Adjusted rcuclassic and rcupreempt to handle dynticks changes. Attached is an updated patch to Classic RCU that applies a hierarchy, greatly reducing the contention on the top-level lock for large machines. This passes 10-hour concurrent rcutorture and online-offline testing on 128-CPU ppc64 without dynticks enabled, and exposes some timekeeping bugs in presence of dynticks (exciting working on a system where "sleep 1" hangs until interrupted...), which were fixed in the 2.6.27 kernel. It is getting more reliable than mainline by some measures, so the next version will be against -tip for inclusion. See also Manfred Spraul's recent patches (or his earlier work from 2004 at http://marc.info/?l=linux-kernel&m=108546384711797&w=2). We will converge onto a common patch in the fullness of time, but are currently exploring different regions of the design space. That said, I have already gratefully stolen quite a few of Manfred's ideas. This patch provides CONFIG_RCU_FANOUT, which controls the bushiness of the RCU hierarchy. Defaults to 32 on 32-bit machines and 64 on 64-bit machines. If CONFIG_NR_CPUS is less than CONFIG_RCU_FANOUT, there is no hierarchy. By default, the RCU initialization code will adjust CONFIG_RCU_FANOUT to balance the hierarchy, so strongly NUMA architectures may choose to set CONFIG_RCU_FANOUT_EXACT to disable this balancing, allowing the hierarchy to be exactly aligned to the underlying hardware. Up to two levels of hierarchy are permitted (in addition to the root node), allowing up to 16,384 CPUs on 32-bit systems and up to 262,144 CPUs on 64-bit systems. I just know that I am going to regret saying this, but this seems more than sufficient for the foreseeable future. (Some architectures might wish to set CONFIG_RCU_FANOUT=4, which would limit such architectures to 64 CPUs. If this becomes a real problem, additional levels can be added, but I doubt that it will make a significant difference on real hardware.) In the common case, a given CPU will manipulate its private rcu_data structure and the rcu_node structure that it shares with its immediate neighbors. This can reduce both lock and memory contention by multiple orders of magnitude, which should eliminate the need for the strange manipulations that are reported to be required when running Linux on very large systems. Some shortcomings: o More bugs will probably surface as a result of an ongoing line-by-line code inspection. Patches will be provided as required. o There are probably hangs, rcutorture failures, &c. Seems quite stable on a 128-CPU machine, but that is kind of small compared to 4096 CPUs. However, seems to do better than mainline. Patches will be provided as required. o The memory footprint of this version is several KB larger than rcuclassic. A separate UP-only rcutiny patch will be provided, which will reduce the memory footprint significantly, even compared to the old rcuclassic. One such patch passes light testing, and has a memory footprint smaller even than rcuclassic. Initial reaction from various embedded guys was "it is not worth it", so am putting it aside. Credits: o Manfred Spraul for ideas, review comments, and bugs spotted, as well as some good friendly competition. ;-) o Josh Triplett, Ingo Molnar, Peter Zijlstra, Mathieu Desnoyers, Lai Jiangshan, Andi Kleen, Andy Whitcroft, and Andrew Morton for reviews and comments. o Thomas Gleixner for much-needed help with some timer issues (see patches below). o Jon M. Tollefson, Tim Pepper, Andrew Theurer, Jose R. Santos, Andy Whitcroft, Darrick Wong, Nishanth Aravamudan, Anton Blanchard, Dave Kleikamp, and Nathan Lynch for keeping machines alive despite my heavy abuse^Wtesting. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-13Merge ../linux-2.6-x86Rusty Russell
Conflicts: arch/x86/kernel/io_apic.c kernel/sched.c kernel/sched_stats.h
2008-12-13cpumask: centralize cpu_online_map and cpu_possible_mapRusty Russell
Impact: cleanup Each SMP arch defines these themselves. Move them to a central location. Twists: 1) Some archs (m32, parisc, s390) set possible_map to all 1, so we add a CONFIG_INIT_ALL_POSSIBLE for this rather than break them. 2) mips and sparc32 '#define cpu_possible_map phys_cpu_present_map'. Those archs simply have phys_cpu_present_map replaced everywhere. 3) Alpha defined cpu_possible_map to cpu_present_map; this is tricky so I just manipulate them both in sync. 4) IA64, cris and m32r have gratuitous 'extern cpumask_t cpu_possible_map' declarations. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Grant Grundler <grundler@parisc-linux.org> Tested-by: Tony Luck <tony.luck@intel.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Mike Travis <travis@sgi.com> Cc: ink@jurassic.park.msu.ru Cc: rmk@arm.linux.org.uk Cc: starvik@axis.com Cc: tony.luck@intel.com Cc: takata@linux-m32r.org Cc: ralf@linux-mips.org Cc: grundler@parisc-linux.org Cc: paulus@samba.org Cc: schwidefsky@de.ibm.com Cc: lethal@linux-sh.org Cc: wli@holomorphy.com Cc: davem@davemloft.net Cc: jdike@addtoit.com Cc: mingo@redhat.com
