path: root/init
2011-01-15Merge branches 'core-fixes-for-linus', 'x86-fixes-for-linus', ↵Linus Torvalds
'timers-fixes-for-linus' and 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: rcu: avoid pointless blocked-task warnings rcu: demote SRCU_SYNCHRONIZE_DELAY from kernel-parameter status rtmutex: Fix comment about why new_owner can be NULL in wake_futex_pi() * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, olpc: Add missing Kconfig dependencies x86, mrst: Set correct APB timer IRQ affinity for secondary cpu x86: tsc: Fix calibration refinement conditionals to avoid divide by zero x86, ia64, acpi: Clean up x86-ism in drivers/acpi/numa.c * 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: timekeeping: Make local variables static time: Rename misnamed minsec argument of clocks_calc_mult_shift() * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: tracing: Remove syscall_exit_fields tracing: Only process module tracepoints once perf record: Add "nodelay" mode, disabled by default perf sched: Fix list of events, dropping unsupported ':r' modifier Revert "perf tools: Emit clearer message for sys_perf_event_open ENOENT return" perf top: Fix annotate segv perf evsel: Fix order of event list deletion
2011-01-14Merge branch 'rcu/next' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-2.6-rcu into core/urgent
2011-01-14rcu: demote SRCU_SYNCHRONIZE_DELAY from kernel-parameter statusPaul E. McKenney
Because the adaptive synchronize_srcu_expedited() approach has worked very well in testing, remove the kernel parameter and replace it by a C-preprocessor macro. If someone finds problems with this approach, a more complex and aggressively adaptive approach might be required. Longer term, SRCU will be merged with the other RCU implementations, at which point synchronize_srcu_expedited() will be event driven, just as synchronize_sched_expedited() currently is. At that point, there will be no need for this adaptive approach. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2011-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) Documentation/trace/events.txt: Remove obsolete sched_signal_send. writeback: fix global_dirty_limits comment runtime -> real-time ppc: fix comment typo singal -> signal drivers: fix comment typo diable -> disable. m68k: fix comment typo diable -> disable. wireless: comment typo fix diable -> disable. media: comment typo fix diable -> disable. remove doc for obsolete dynamic-printk kernel-parameter remove extraneous 'is' from Documentation/iostats.txt Fix spelling milisec -> ms in snd_ps3 module parameter description Fix spelling mistakes in comments Revert conflicting V4L changes i7core_edac: fix typos in comments mm/rmap.c: fix comment sound, ca0106: Fix assignment to 'channel'. hrtimer: fix a typo in comment init/Kconfig: fix typo anon_inodes: fix wrong function name in comment fix comment typos concerning "consistent" poll: fix a typo in comment ... Fix up trivial conflicts in: - drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c) - fs/ext4/ext4.h Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
2011-01-13decompressors: add boot-time XZ supportLasse Collin
This implements the API defined in <linux/decompress/generic.h> which is used for kernel, initramfs, and initrd decompression. This patch together with the first patch is enough for XZ-compressed initramfs and initrd; XZ-compressed kernel will need arch-specific changes. The buffering requirements described in decompress_unxz.c are stricter than with gzip, so the relevant changes should be done to the arch-specific code when adding support for XZ-compressed kernel. Similarly, the heap size in arch-specific pre-boot code may need to be increased (30 KiB is enough). The XZ decompressor needs memmove(), memeq() (memcmp() == 0), and memzero() (memset(ptr, 0, size)), which aren't available in all arch-specific pre-boot environments. I'm including simple versions in decompress_unxz.c, but a cleaner solution would naturally be nicer. Signed-off-by: Lasse Collin <lasse.collin@tukaani.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Alain Knaff <alain@knaff.lu> Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Phillip Lougher <phillip@lougher.demon.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-07Merge branch 'for-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
* 'for-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (33 commits) usb: don't use flush_scheduled_work() speedtch: don't abuse struct delayed_work media/video: don't use flush_scheduled_work() media/video: explicitly flush request_module work ioc4: use static work_struct for ioc4_load_modules() init: don't call flush_scheduled_work() from do_initcalls() s390: don't use flush_scheduled_work() rtc: don't use flush_scheduled_work() mmc: update workqueue usages mfd: update workqueue usages dvb: don't use flush_scheduled_work() leds-wm8350: don't use flush_scheduled_work() mISDN: don't use flush_scheduled_work() macintosh/ams: don't use flush_scheduled_work() vmwgfx: don't use flush_scheduled_work() tpm: don't use flush_scheduled_work() sonypi: don't use flush_scheduled_work() hvsi: don't use flush_scheduled_work() xen: don't use flush_scheduled_work() gdrom: don't use flush_scheduled_work() ... Fixed up trivial conflict in drivers/media/video/bt8xx/bttv-input.c as per Tejun.
2011-01-06Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (30 commits) sched: Change wait_for_completion_*_timeout() to return a signed long sched, autogroup: Fix reference leak sched, autogroup: Fix potential access to freed memory sched: Remove redundant CONFIG_CGROUP_SCHED ifdef sched: Fix interactivity bug by charging unaccounted run-time on entity re-weight sched: Move periodic share updates to entity_tick() printk: Use this_cpu_{read|write} api on printk_pending sched: Make pushable_tasks CONFIG_SMP dependant sched: Add 'autogroup' scheduling feature: automated per session task groups sched: Fix unregister_fair_sched_group() sched: Remove unused argument dest_cpu to migrate_task() mutexes, sched: Introduce arch_mutex_cpu_relax() sched: Add some clock info to sched_debug cpu: Remove incorrect BUG_ON cpu: Remove unused variable sched: Fix UP build breakage sched: Make task dump print all 15 chars of proc comm sched: Update tg->shares after cpu.shares write sched: Allow update_cfs_load() to update global load sched: Implement demand based update_cfs_load() ...
2011-01-06Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (146 commits) tools, perf: Documentation for the power events API perf: Add calls to suspend trace point perf script: Make some lists static perf script: Use the default lost event handler perf session: Warn about errors when processing pipe events too perf tools: Fix perf_event.h header usage perf test: Clarify some error reports in the open syscall test x86, NMI: Add touch_nmi_watchdog to io_check_error delay x86: Avoid calling arch_trigger_all_cpu_backtrace() at the same time x86: Only call smp_processor_id in non-preempt cases perf timechart: Adjust perf timechart to the new power events perf: Clean up power events by introducing new, more generic ones perf: Do not export power_frequency, but power_start event perf test: Add test for counting open syscalls perf evsel: Auto allocate resources needed for some methods perf evsel: Use {cpu,thread}_map to shorten list of parameters perf tools: Refactor all_tids to hold nr and the map perf tools: Refactor cpumap to hold nr and the map perf evsel: Introduce per cpu and per thread open helpers perf evsel: Steal the counter reading routines from stat ...
2011-01-06Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: rcu: remove unused __list_for_each_rcu() macro rculist: fix borked __list_for_each_rcu() macro rcu: reduce __call_rcu()-induced contention on rcu_node structures rcu: limit rcu_node leaf-level fanout rcu: fine-tune grace-period begin/end checks rcu: Keep gpnum and completed fields synchronized rcu: Stop chasing QS if another CPU did it for us rcu: increase synchronize_sched_expedited() batching rcu: Make synchronize_srcu_expedited() fast if running readers rcu: fix race condition in synchronize_sched_expedited() rcu: update documentation/comments for Lai's adoption patch rcu,cleanup: simplify the code when cpu is dying rcu,cleanup: move synchronize_sched_expedited() out of sched.c rcu: get rid of obsolete "classic" names in TREE_RCU tracing rcu: Distinguish between boosting and boosted rcu: document TINY_RCU and TINY_PREEMPT_RCU tracing. rcu: add tracing for TINY_RCU and TINY_PREEMPT_RCU rcu: priority boosting for TINY_PREEMPT_RCU rcu: move TINY_RCU from softirq to kthread rcu: add priority-inversion testing to rcutorture
2011-01-05Merge commit 'v2.6.37' into perf/coreIngo Molnar
Merge reason: Add the final .37 tree. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-05Merge commit 'v2.6.37' into sched/coreIngo Molnar
Merge reason: Merge the final .37 tree. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-03name_to_dev_t() must not call __init codeJan Beulich
The function can't be __init itself (being called from some sysfs handler), and hence none of the functions it calls can be either. Signed-off-by: Jan Beulich <jbeulich@novell.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-24init: don't call flush_scheduled_work() from do_initcalls()Tejun Heo
The call to flush_scheduled_work() in do_initcalls() is there to make sure all works queued to system_wq by initcalls finish before the init sections are dropped. However, the call doesn't make much sense at this point - there already are multiple different workqueues and different subsystems are free to create and use their own. Ordering requirements are and should be expressed explicitly. Drop the call to prepare for the deprecation and removal of flush_scheduled_work(). Andrew suggested adding sanity check where the workqueue code checks whether any pending or running work has the work function in the init text section. However, checking this for running works requires the worker to keep track of the current function being executed, and checking only the pending works will miss most cases. As a violation will almost always be caught by the usual page fault mechanism, I don't think it would be worthwhile to make the workqueue code track extra state just for this. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org>
2010-12-23Merge branch 'rcu/next' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-2.6-rcu into core/rcu
2010-12-22init/Kconfig: fix typoJim Cromie
Signed-off-by:  Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-12-16init: Initialized IDR earlierPeter Zijlstra
perf_event_init() wants to start using IDR trees, its needs in turn are satisfied by mm_init(). Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20101117222056.206992649@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-12-16perf: Move perf_event_init() into main.cPeter Zijlstra
Currently we call perf_event_init() from sched_init(). In order to make it more obvious move it to the cannnonical location. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20101117222056.093629821@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-12-08Merge branch 'linus' into sched/coreIngo Molnar
Merge reason: we want to queue up dependent cleanup Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-12-07Merge commit 'v2.6.37-rc5' into perf/coreIngo Molnar
Merge reason: Pick up the latest -rc. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-11-30sched: Add 'autogroup' scheduling feature: automated per session task groupsMike Galbraith
A recurring complaint from CFS users is that parallel kbuild has a negative impact on desktop interactivity. This patch implements an idea from Linus, to automatically create task groups. Currently, only per session autogroups are implemented, but the patch leaves the way open for enhancement. Implementation: each task's signal struct contains an inherited pointer to a refcounted autogroup struct containing a task group pointer, the default for all tasks pointing to the init_task_group. When a task calls setsid(), a new task group is created, the process is moved into the new task group, and a reference to the preveious task group is dropped. Child processes inherit this task group thereafter, and increase it's refcount. When the last thread of a process exits, the process's reference is dropped, such that when the last process referencing an autogroup exits, the autogroup is destroyed. At runqueue selection time, IFF a task has no cgroup assignment, its current autogroup is used. Autogroup bandwidth is controllable via setting it's nice level through the proc filesystem: cat /proc/<pid>/autogroup Displays the task's group and the group's nice level. echo <nice level> > /proc/<pid>/autogroup Sets the task group's shares to the weight of nice <level> task. Setting nice level is rate limited for !admin users due to the abuse risk of task group locking. The feature is enabled from boot by default if CONFIG_SCHED_AUTOGROUP=y is selected, but can be disabled via the boot option noautogroup, and can also be turned on/off on the fly via: echo [01] > /proc/sys/kernel/sched_autogroup_enabled ... which will automatically move tasks to/from the root task group. Signed-off-by: Mike Galbraith <efault@gmx.de> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Markus Trippelsdorf <markus@trippelsdorf.de> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: Paul Turner <pjt@google.com> Cc: Oleg Nesterov <oleg@redhat.com> [ Removed the task_group_path() debug code, and fixed !EVENTFD build failure. ] Signed-off-by: Ingo Molnar <mingo@elte.hu> LKML-Reference: <1290281700.28711.9.camel@maggy.simson.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-11-29rcu: Make synchronize_srcu_expedited() fast if running readersPaul E. McKenney
The synchronize_srcu_expedited() function is currently quick if there are no active readers, but will delay a full jiffy if there are any. If these readers leave their SRCU read-side critical sections quickly, this is way too long to wait. So this commit first waits ten microseconds, and only then falls back to jiffy-at-a-time waiting. Reported-by: Avi Kivity <avi@redhat.com> Reported-by: Marcelo Tosatti <mtosatti@redhat.com> Tested-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-11-29rcu: add tracing for TINY_RCU and TINY_PREEMPT_RCUPaul E. McKenney
Add tracing for the tiny RCU implementations, including statistics on boosting in the case of TINY_PREEMPT_RCU and RCU_BOOST. Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-11-29rcu: priority boosting for TINY_PREEMPT_RCUPaul E. McKenney
Add priority boosting, but only for TINY_PREEMPT_RCU. This is enabled by the default-off RCU_BOOST kernel parameter. The priority to which to boost preempted RCU readers is controlled by the RCU_BOOST_PRIO kernel parameter (defaulting to real-time priority 1) and the time to wait before boosting the readers blocking a given grace period is controlled by the RCU_BOOST_DELAY kernel parameter (defaulting to 500 milliseconds). Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-11-26perf, arch: Cleanup perf-pmu init vs lockup-detectorPeter Zijlstra
The perf hardware pmu got initialized at various points in the boot, some before early_initcall() some after (notably arch_initcall). The problem is that the NMI lockup detector is ran from early_initcall() and expects the hardware pmu to be present. Sanitize this by moving all architecture hardware pmu implementations to initialize at early_initcall() and move the lockup detector to an explicit initcall right after that. Cc: paulus <paulus@samba.org> Cc: davem <davem@davemloft.net> Cc: Michael Cree <mcree@orcon.net.nz> Cc: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1290707759.2145.119.camel@laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-11-25cgroups: make swap accounting default behavior configurableMichal Hocko
Swap accounting can be configured by CONFIG_CGROUP_MEM_RES_CTLR_SWAP configuration option and then it is turned on by default. There is a boot option (noswapaccount) which can disable this feature. This makes it hard for distributors to enable the configuration option as this feature leads to a bigger memory consumption and this is a no-go for general purpose distribution kernel. On the other hand swap accounting may be very usuful for some workloads. This patch adds a new configuration option which controls the default behavior (CGROUP_MEM_RES_CTLR_SWAP_ENABLED). If the option is selected then the feature is turned on by default. It also adds a new boot parameter swapaccount[=1|0] which enhances the original noswapaccount parameter semantic by means of enable/disable logic (defaults to 1 if no value is provided to be still consistent with noswapaccount). The default behavior is unchanged (if CONFIG_CGROUP_MEM_RES_CTLR_SWAP is enabled then CONFIG_CGROUP_MEM_RES_CTLR_SWAP_ENABLED is enabled as well) Signed-off-by: Michal Hocko <mhocko@suse.cz> Acked-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-17BKL: remove extraneous #include <smp_lock.h>Arnd Bergmann
The big kernel lock has been removed from all these files at some point, leaving only the #include. Remove this too as a cleanup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-28Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: initramfs: Fix build break on symbol-prefixed archs initramfs: fix initramfs size calculation initramfs: generalize initramfs_data.xxx.S variants scripts/kallsyms: Enable error messages while hush up unnecessary warnings scripts/setlocalversion: update comment kbuild: Use a single clean rule for kernel and external modules kbuild: Do not run make clean in $(srctree) scripts/mod/modpost.c: fix commentary accordingly to last changes kbuild: Really don't clean bounds.h and asm-offsets.h
2010-10-27namespaces Kconfig: move namespace menu location after the cgroupDaniel Lezcano
We have the namespaces as a menuconfig like the cgroup. The cgroup and the namespace are two base bricks for the containers. It is more logical to put the namespace menu right after the cgroup menu. Signed-off-by: Daniel Lezcano <daniel.lezcano@free.fr> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: "Serge E. Hallyn" <serue@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27namespaces Kconfig: remove the cgroup device whitelist experimental tagDaniel Lezcano
This subsystem is merged since a long time now, I think we can consider it mature enough. Signed-off-by: Daniel Lezcano <daniel.lezcano@free.fr> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: "Serge E. Hallyn" <serue@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27namespaces Kconfig: remove pointless cgroup dependencyDaniel Lezcano
The different cgroup subsystems are under the cgroup submenu. The dependency between the cgroups and the menu subsystems is pointless. Signed-off-by: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Cc: "Serge E. Hallyn" <serue@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27namespaces Kconfig: make namespace a submenuDaniel Lezcano
Make the namespaces config option a submenu. Signed-off-by: Daniel Lezcano <daniel.lezcano@free.fr> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: "Serge E. Hallyn" <serue@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27namespaces: default all the namespaces to 'yes' when CONFIG_NAMESPACES is ↵Daniel Lezcano
selected As the different namespaces depend on 'CONFIG_NAMESPACES', it is logical to enable all the namespaces when we enable NAMESPACES. Signed-off-by: Daniel Lezcano <daniel.lezcano@free.fr> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: David Miller <davem@davemloft.net> Acked-By: Matt Helsley <matthltc@us.ibm.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27namespaces: remove pid_ns and net_ns experimental statusDaniel Lezcano
The pid namespace is in the kernel since 2.6.27 and the net_ns since 2.6.29. They are enabled in the distro by default and used by userspace component. They are mature enough to remove the 'experimental' label. Signed-off-by: Daniel Lezcano <daniel.lezcano@free.fr> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26init: mark __user address space on string literalsNamhyung Kim
When calling syscall service routines in kernel, some of arguments should be user pointers but were missing __user markup on string literals. Add it. Removes some sparse warnings. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Phillip Lougher <phillip@lougher.demon.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-25Merge branch 'nfs-for-2.6.37' of ↵Linus Torvalds
git://git.linux-nfs.org/projects/trondmy/nfs-2.6 * 'nfs-for-2.6.37' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: (67 commits) SUNRPC: Cleanup duplicate assignment in rpcauth_refreshcred nfs: fix unchecked value Ask for time_delta during fsinfo probe Revalidate caches on lock SUNRPC: After calling xprt_release(), we must restart from call_reserve NFSv4: Fix up the 'dircount' hint in encode_readdir NFSv4: Clean up nfs4_decode_dirent NFSv4: nfs4_decode_dirent must clear entry->fattr->valid NFSv4: Fix a regression in decode_getfattr NFSv4: Fix up decode_attr_filehandle() to handle the case of empty fh pointer NFS: Ensure we check all allocation return values in new readdir code NFS: Readdir plus in v4 NFS: introduce generic decode_getattr function NFS: check xdr_decode for errors NFS: nfs_readdir_filler catch all errors NFS: readdir with vmapped pages NFS: remove page size checking code NFS: decode_dirent should use an xdr_stream SUNRPC: Add a helper function xdr_inline_peek NFS: remove readdir plus limit ...
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (31 commits) driver core: Display error codes when class suspend fails Driver core: Add section count to memory_block struct Driver core: Add mutex for adding/removing memory blocks Driver core: Move find_memory_block routine hpilo: Despecificate driver from iLO generation driver core: Convert link_mem_sections to use find_memory_block_hinted. driver core: Introduce find_memory_block_hinted which utilizes kset_find_obj_hinted. kobject: Introduce kset_find_obj_hinted. driver core: fix build for CONFIG_BLOCK not enabled driver-core: base: change to new flag variable sysfs: only access bin file vm_ops with the active lock sysfs: Fail bin file mmap if vma close is implemented. FW_LOADER: fix kconfig dependency warning on HOTPLUG uio: Statically allocate uio_class and use class .dev_attrs. uio: Support 2^MINOR_BITS minors uio: Cleanup irq handling. uio: Don't clear driver data uio: Fix lack of locking in init_uio_class SYSFS: Allow boot time switching between deprecated and modern sysfs layout driver core: remove CONFIG_SYSFS_DEPRECATED_V2 but keep it for block devices ...
2010-10-22Merge branch 'for-2.6.37/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.37/core' of git://git.kernel.dk/linux-2.6-block: (39 commits) cfq-iosched: Fix a gcc 4.5 warning and put some comments block: Turn bvec_k{un,}map_irq() into static inline functions block: fix accounting bug on cross partition merges block: Make the integrity mapped property a bio flag block: Fix double free in blk_integrity_unregister block: Ensure physical block size is unsigned int blkio-throttle: Fix possible multiplication overflow in iops calculations blkio-throttle: limit max iops value to UINT_MAX blkio-throttle: There is no need to convert jiffies to milli seconds blkio-throttle: Fix link failure failure on i386 blkio: Recalculate the throttled bio dispatch time upon throttle limit change blkio: Add root group to td->tg_list blkio: deletion of a cgroup was causes oops blkio: Do not export throttle files if CONFIG_BLK_DEV_THROTTLING=n block: set the bounce_pfn to the actual DMA limit rather than to max memory block: revert bad fix for memory hotplug causing bounces Fix compile error in blk-exec.c for !CONFIG_DETECT_HUNG_TASK block: set the bounce_pfn to the actual DMA limit rather than to max memory block: Prevent hang_check firing during long I/O cfq: improve fsync performance for small files ... Fix up trivial conflicts due to __rcu sparse annotation in include/linux/genhd.h
2010-10-22Merge branch 'config' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'config' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: BKL: introduce CONFIG_BKL. dabusb: remove the BKL sunrpc: remove the big kernel lock init/main.c: remove BKL notations blktrace: remove the big kernel lock rtmutex-tester: make it build without BKL dvb-core: kill the big kernel lock dvb/bt8xx: kill the big kernel lock tlclk: remove big kernel lock fix rawctl compat ioctls breakage on amd64 and itanic uml: kill big kernel lock parisc: remove big kernel lock cris: autoconvert trivial BKL users alpha: kill big kernel lock isapnp: BKL removal s390/block: kill the big kernel lock hpet: kill BKL, add compat_ioctl
2010-10-22SYSFS: Allow boot time switching between deprecated and modern sysfs layoutAndi Kleen
I have some systems which need legacy sysfs due to old tools that are making assumptions that a directory can never be a symlink to another directory, and it's a big hazzle to compile separate kernels for them. This patch turns CONFIG_SYSFS_DEPRECATED into a run time option that can be switched on/off the kernel command line. This way the same binary can be used in both cases with just a option on the command line. The old CONFIG_SYSFS_DEPRECATED_V2 option is still there to set the default. I kept the weird name to not break existing config files. Also the compat code can be still completely disabled by undefining CONFIG_SYSFS_DEPRECATED_SWITCH -- just the optimizer takes care of this now instead of lots of ifdefs. This makes the code look nicer. v2: This is an updated version on top of Kay's patch to only handle the block devices. I tested it on my old systems and that seems to work. Cc: axboe@kernel.dk Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22driver core: remove CONFIG_SYSFS_DEPRECATED_V2 but keep it for block devicesKay Sievers
This patch removes the old CONFIG_SYSFS_DEPRECATED_V2 config option, but it keeps the logic around to handle block devices in the old manner as some people like to run new kernel versions on old (pre 2007/2008) distros. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: "James E.J. Bottomley" <James.Bottomley@suse.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Tejun Heo <tj@kernel.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jaroslav Kysela <perex@perex.cz> Cc: Takashi Iwai <tiwai@suse.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-21Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (96 commits) apic, x86: Use BIOS settings for IBS and MCE threshold interrupt LVT offsets apic, x86: Check if EILVT APIC registers are available (AMD only) x86: ioapic: Call free_irte only if interrupt remapping enabled arm: Use ARCH_IRQ_INIT_FLAGS genirq, ARM: Fix boot on ARM platforms genirq: Fix CONFIG_GENIRQ_NO_DEPRECATED=y build x86: Switch sparse_irq allocations to GFP_KERNEL genirq: Switch sparse_irq allocator to GFP_KERNEL genirq: Make sparse_lock a mutex x86: lguest: Use new irq allocator genirq: Remove the now unused sparse irq leftovers genirq: Sanitize dynamic irq handling genirq: Remove arch_init_chip_data() x86: xen: Sanitise sparse_irq handling x86: Use sane enumeration x86: uv: Clean up the direct access to irq_desc x86: Make io_apic.c local functions static genirq: Remove irq_2_iommu x86: Speed up the irq_remapped check in hot pathes intr_remap: Simplify the code further ... Fix up trivial conflicts in arch/x86/Kconfig
2010-10-21Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (163 commits) tracing: Fix compile issue for trace_sched_wakeup.c [S390] hardirq: remove pointless header file includes [IA64] Move local_softirq_pending() definition perf, powerpc: Fix power_pmu_event_init to not use event->ctx ftrace: Remove recursion between recordmcount and scripts/mod/empty jump_label: Add COND_STMT(), reducer wrappery perf: Optimize sw events perf: Use jump_labels to optimize the scheduler hooks jump_label: Add atomic_t interface jump_label: Use more consistent naming perf, hw_breakpoint: Fix crash in hw_breakpoint creation perf: Find task before event alloc perf: Fix task refcount bugs perf: Fix group moving irq_work: Add generic hardirq context callbacks perf_events: Fix transaction recovery in group_sched_in() perf_events: Fix bogus AMD64 generic TLB events perf_events: Fix bogus context time tracking tracing: Remove parent recording in latency tracer graph options tracing: Use one prologue for the preempt irqs off tracer function tracers ...
2010-10-21BKL: introduce CONFIG_BKL.Arnd Bergmann
With all the patches we have queued in the BKL removal tree, only a few dozen modules are left that actually rely on the BKL, and even there are lots of low-hanging fruit. We need to decide what to do about them, this patch illustrates one of the options: Every user of the BKL is marked as 'depends on BKL' in Kconfig, and the CONFIG_BKL becomes a user-visible option. If it gets disabled, no BKL using module can be built any more and the BKL code itself is compiled out. The one exception is file locking, which is practically always enabled and does a 'select BKL' instead. This effectively forces CONFIG_BKL to be enabled until we have solved the fs/lockd mess and can apply the patch that removes the BKL from fs/locks.c. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-10-19init/main.c: remove BKL notationsNamhyung Kim
According to commit 5e3d20a68f63fc5a310687d81956c3b96e488b84 (init: Remove the BKL from startup code) these sparse notations should be removed also. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-10-18irq_work: Add generic hardirq context callbacksPeter Zijlstra
Provide a mechanism that allows running code in IRQ context. It is most useful for NMI code that needs to interact with the rest of the system -- like wakeup a task to drain buffers. Perf currently has such a mechanism, so extract that and provide it as a generic feature, independent of perf so that others may also benefit. The IRQ context callback is generated through self-IPIs where possible, or on architectures like powerpc the decrementer (the built-in timer facility) is set to generate an interrupt immediately. Architectures that don't have anything like this get to do with a callback from the timer tick. These architectures can call irq_work_run() at the tail of any IRQ handlers that might enqueue such work (like the perf IRQ handler) to avoid undue latencies in processing the work. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [ various fixes ] Signed-off-by: Huang Ying <ying.huang@intel.com> LKML-Reference: <1287036094.7768.291.camel@yhuang-dev> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-10-12genirq: Remove early_init_irq_lock_class()Thomas Gleixner
early_init_irq_lock_class() is called way before anything touches the irq descriptors. In case of SPARSE_IRQ=y this is a NOP operation because the radix tree is empty at this point. For the SPARSE_IRQ=n case it's sufficient to set the lock class in early_init_irq(). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-04genirq: Provide KconfigThomas Gleixner
The generic irq Kconfig options are copied around all archs. Provide a generic Kconfig file which can be included. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20100927121843.217333624@linutronix.de> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-09-29initramfs: fix initramfs size calculationHendrik Brueckner
The size of a built-in initramfs is calculated in init/initramfs.c by "__initramfs_end - __initramfs_start". Those symbols are defined in the linker script include/asm-generic/vmlinux.lds.h: #define INIT_RAM_FS \ . = ALIGN(PAGE_SIZE); \ VMLINUX_SYMBOL(__initramfs_start) = .; \ *(.init.ramfs) \ VMLINUX_SYMBOL(__initramfs_end) = .; If the initramfs file has an odd number of bytes, the "__initramfs_end" symbol points to an odd address, for example, the symbols in the System.map might look like: 0000000000572000 T __initramfs_start 00000000005bcd05 T __initramfs_end <-- odd address At least on s390 this causes a problem: Certain s390 instructions, especially instructions for loading addresses (larl) or branch addresses must be on even addresses. The compiler loads the symbol addresses with the "larl" instruction. This instruction sets the last bit to 0 and, therefore, for odd size files, the calculated size is one byte less than it should be: 0000000000540a9c <populate_rootfs>: 540a9c: eb cf f0 78 00 24 stmg %r12,%r15,120(%r15), 540aa2: c0 10 00 01 8a af larl %r1,572000 <__initramfs_start> 540aa8: c0 c0 00 03 e1 2e larl %r12,5bcd04 <initramfs_end> (Instead of 5bcd05) ... 540abe: 1b c1 sr %r12,%r1 To fix the problem, this patch introduces the global variable __initramfs_size, which is calculated in the "usr/initramfs_data.S" file. The populate_rootfs() function can then use the start marker of the .init.ramfs section and the value of __initramfs_size for loading the initramfs. Because the start marker and size is sufficient, the __initramfs_end symbol is no longer needed and is removed. Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com> Acked-by: Michal Marek <mmarek@suse.cz> Acked-by: "H. Peter Anvin" <hpa@zytor.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-09-17NFS: Use super.c for NFSROOT mount option parsingChuck Lever
Replace duplicate code in NFSROOT for mounting an NFS server on '/' with logic that uses the existing mainline text-based logic in the NFS client. Add documenting comments where appropriate. Note that this means NFSROOT mounts now use the same default settings as v2/v3 mounts done via mount(2) from user space. vers=3,tcp,rsize=<negotiated default>,wsize=<negotiated default> As before, however, no version/protocol negotiation with the server is done. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
