commit df37bd156dcb4f5441beaf5bde444adac974e9a0 upstream.
The unpack routine fails to handle the decompress_method() returning
unrecognised decompressor (compress_name == NULL). This results in the
routine looping eventually oopsing on an out of bounds memory access.
Note this bug is usually hidden, only triggering on trailing junk after
one or more correct compressed blocks. The case of the compressed archive
being complete junk is (by accident?) caught by the if (state != Reset)
check because state is initialised to Start, but not updated due to the
decompressor not having been called. Obviously if the junk is trailing a
correctly decompressed buffer, state == Reset from the previous call to
the decompressor.
Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
Reported-by: Aaro Koskinen <aaro.koskinen@iki.fi>
commit 5ab116c9349ef52d6fbd2e2917a53f13194b048e upstream.
cpuset_mem_spread_node() returns an offline node, and causes an oops.
This patch fixes it by initializing task->mems_allowed to
node_states[N_HIGH_MEMORY], and updating task->mems_allowed when doing
memory hotplug.
Signed-off-by: Miao Xie <miaox@cn.fujitsu.com>
Acked-by: David Rientjes <rientjes@google.com>
Reported-by: Nick Piggin <npiggin@suse.de>
Tested-by: Nick Piggin <npiggin@suse.de>
Cc: Paul Menage <menage@google.com>
Cc: Li Zefan <lizf@cn.fujitsu.com>
ima wants to create an inode information struct (iint) when inodes are
allocated. This means that at least the part of ima which does this
allocation (the allocation is filled with information later) should
before any inodes are created. To accomplish this we split the ima
initialization routine placing the kmem cache allocator inside a
security_initcall() function. Since this makes use of radix trees we also
need to make sure that is initialized before security_initcall().
Signed-off-by: Eric Paris <eparis@redhat.com>
Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
This patch series adds generic support for creating and extracting
LZO-compressed kernel images, as well as support for using such images on
the x86 and ARM architectures, and support for creating and using
LZO-compressed initrd and initramfs images.
Russell King said:
: Testing on a Cortex A9 model:
: - lzo decompressor is 65% of the time gzip takes to decompress a kernel
: - lzo kernel is 9% larger than a gzip kernel
: which I'm happy to say confirms your figures when comparing the two.
: However, when comparing your new gzip code to the old gzip code:
: - new is 99% of the size of the old code
: - new takes 42% of the time to decompress than the old code
: What this means is that for a proper comparison, the results get even better:
: - lzo is 7.5% larger than the old gzip'd kernel image
: - lzo takes 28% of the time that the old gzip code took
: So the expense seems definitely worth the effort. The only reason I
: can think of ever using gzip would be if you needed the additional
: compression (eg, because you have limited flash to store the image.)
: I would argue that the default for ARM should therefore be LZO.
This patch:
The lzo compressor is worse than gzip at compression, but faster at
extraction. Here are some figures for an ARM board I'm working on:
Uncompressed size: 3.24Mo
gzip 1.61Mo 0.72s
lzo 1.75Mo 0.48s
So for a compression ratio that is still relatively close to gzip, it's
much faster to extract, at least in that case.
This part contains:
- Makefile routine to support lzo compression
- Fixes to the existing lzo compressor so that it can be used in
compressed kernels
- wrapper around the existing lzo1x_decompress, as it only extracts one
block at a time, while we need to extract a whole file here
- config dialog for kernel compression
[akpm@linux-foundation.org: cleanup]
Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com>
Tested-by: Wu Zhangjin <wuzhangjin@gmail.com>
Acked-by: "H. Peter Anvin" <hpa@zytor.com>
Tested-by: Russell King <rmk@arm.linux.org.uk>
Acked-by: Russell King <rmk@arm.linux.org.uk>
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, irq: Allow 0xff for /proc/irq/[n]/smp_affinity on an 8-cpu system
Makefile: Unexport LC_ALL instead of clearing it
x86: Fix objdump version check in arch/x86/tools/chkobjdump.awk
x86: Reenable TSC sync check at boot, even with NONSTOP_TSC
x86: Don't use POSIX character classes in gen-insn-attr-x86.awk
Makefile: set LC_CTYPE, LC_COLLATE, LC_NUMERIC to C
x86: Increase MAX_EARLY_RES; insufficient on 32-bit NUMA
x86: Fix checking of SRAT when node 0 ram is not from 0
x86, cpuid: Add "volatile" to asm in native_cpuid()
x86, msr: msrs_alloc/free for CONFIG_SMP=n
x86, amd: Get multi-node CPU info from NodeId MSR instead of PCI config space
x86: Add IA32_TSC_AUX MSR and use it
x86, msr/cpuid: Register enough minors for the MSR and CPUID drivers
initramfs: add missing decompressor error check
bzip2: Add missing checks for malloc returning NULL
bzip2/lzma/gzip: pre-boot malloc doesn't return NULL on failure
* 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (25 commits)
sched: Fix broken assertion
sched: Assert task state bits at build time
sched: Update task_state_arraypwith new states
sched: Add missing state chars to TASK_STATE_TO_CHAR_STR
sched: Move TASK_STATE_TO_CHAR_STR near the TASK_state bits
sched: Teach might_sleep() about preemptible RCU
sched: Make warning less noisy
sched: Simplify set_task_cpu()
sched: Remove the cfs_rq dependency from set_task_cpu()
sched: Add pre and post wakeup hooks
sched: Move kthread_bind() back to kthread.c
sched: Fix select_task_rq() vs hotplug issues
sched: Fix sched_exec() balancing
sched: Ensure set_task_cpu() is never called on blocked tasks
sched: Use TASK_WAKING for fork wakups
sched: Select_task_rq_fair() must honour SD_LOAD_BALANCE
sched: Fix task_hot() test order
sched: Fix set_cpu_active() in cpu_down()
sched: Mark boot-cpu active before smp_init()
sched: Fix cpu_clock() in NMIs, on !CONFIG_HAVE_UNSTABLE_SCHED_CLOCK
* 'for-33' of git://repo.or.cz/linux-kbuild: (29 commits)
net: fix for utsrelease.h moving to generated
gen_init_cpio: fixed fwrite warning
kbuild: fix make clean after mismerge
kbuild: generate modules.builtin
genksyms: properly consider EXPORT_UNUSED_SYMBOL{,_GPL}()
score: add asm/asm-offsets.h wrapper
unifdef: update to upstream revision 1.190
kbuild: specify absolute paths for cscope
kbuild: create include/generated in silentoldconfig
scripts/package: deb-pkg: use fakeroot if available
scripts/package: add KBUILD_PKG_ROOTCMD variable
scripts/package: tar-pkg: use tar --owner=root
Kbuild: clean up marker
net: add net_tstamp.h to headers_install
kbuild: move utsrelease.h to include/generated
kbuild: move autoconf.h to include/generated
drop explicit include of autoconf.h
kbuild: move compile.h to include/generated
kbuild: drop include/asm
kbuild: do not check for include/asm-$ARCH
Fixed non-conflicting clean merge of modpost.c as per comments from
Stephen Rothwell (modpost.c had grown an include of linux/autoconf.h
that needed to be changed to generated/autoconf.h)
A UP machine has 1 active cpu, not having the boot-cpu in the
active map when starting the scheduler confuses things.
LKML-Reference: <20091216170517.423469527@chello.nl>
The decompressors return error by calling a supplied error function, and/or
by returning an error return value. The initramfs code, however, fails to
check the exit code returned by the decompressor, and only checks the error
status set by calling the error function.
This patch adds a return code check and calls the error function.
LKML-Reference: <4b26b1ef.0+ZWxT6886olqcSc%phillip@lougher.demon.co.uk>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
The symbol 'call' is a static symbol used for initcall_debug. This same
symbol name is used locally by a couple functions and produces the
following sparse warnings:
warning: symbol 'call' shadows an earlier one
Fix this noise by renaming the local symbols.
The NOMMU code currently clears all anonymous mmapped memory. While this
is what we want in the default case, all memory allocation from userspace
under NOMMU has to go through this interface, including malloc() which is
allowed to return uninitialized memory. This can easily be a significant
performance penalty. So for constrained embedded systems were security is
irrelevant, allow people to avoid clearing memory unnecessarily.
This also alters the ELF-FDPIC binfmt such that it obtains uninitialised
memory for the brk and stack region.
Signed-off-by: Jie Zhang <jie.zhang@analog.com>
Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org>
Acked-by: Paul Mundt <lethal@linux-sh.org>
Acked-by: Greg Ungerer <gerg@snapgear.com>
Fix up all users of utsrelease.h
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
* 'timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
timers, init: Limit the number of per cpu calibration bootup messages
posix-cpu-timers: optimize and document timer_create callback
clockevents: Add missing include to pacify sparse
x86: vmiclock: Fix printk format
x86: Fix printk format due to variable type change
sparc: fix printk for change of variable type
clocksource/events: Fix fallout of generic code changes
nohz: Allow 32-bit machines to sleep for more than 2.15 seconds
nohz: Track last do_timer() cpu
nohz: Prevent clocksource wrapping during idle
nohz: Type cast printk argument
mips: Use generic mult/shift factor calculation for clocks
clocksource: Provide a generic mult/shift factor calculation
clockevents: Use u32 for mult and shift factors
nohz: Introduce arch_needs_cpu
nohz: Reuse ktime in sub-functions of tick_check_idle.
time: Remove xtime_cache
time: Implement logarithmic time accumulation
Cc: Greg KH <gregkh@suse.de>
Cc: Kay Sievers <kay.sievers@vrfy.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/sysctl-2.6: (43 commits)
security/tomoyo: Remove now unnecessary handling of security_sysctl.
security/tomoyo: Add a special case to handle accesses through the internal proc mount.
sysctl: Drop & in front of every proc_handler.
sysctl: Remove CTL_NONE and CTL_UNNUMBERED
sysctl: kill dead ctl_handler definitions.
sysctl: Remove the last of the generic binary sysctl support
sysctl net: Remove unused binary sysctl code
sysctl security/tomoyo: Don't look at ctl_name
sysctl arm: Remove binary sysctl support
sysctl x86: Remove dead binary sysctl support
sysctl sh: Remove dead binary sysctl support
sysctl powerpc: Remove dead binary sysctl support
sysctl ia64: Remove dead binary sysctl support
sysctl s390: Remove dead sysctl binary support
sysctl frv: Remove dead binary sysctl support
sysctl mips/lasat: Remove dead binary sysctl support
sysctl drivers: Remove dead binary sysctl support
sysctl crypto: Remove dead binary sysctl support
sysctl security/keys: Remove dead binary sysctl support
sysctl kernel: Remove binary sysctl logic
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (31 commits)
rcu: Make RCU's CPU-stall detector be default
rcu: Add expedited grace-period support for preemptible RCU
rcu: Enable fourth level of TREE_RCU hierarchy
rcu: Rename "quiet" functions
rcu: Re-arrange code to reduce #ifdef pain
rcu: Eliminate unneeded function wrapping
rcu: Fix grace-period-stall bug on large systems with CPU hotplug
rcu: Eliminate __rcu_pending() false positives
rcu: Further cleanups of use of lastcomp
rcu: Simplify association of forced quiescent states with grace periods
rcu: Accelerate callback processing on CPUs not detecting GP end
rcu: Mark init-time-only rcu_bootup_announce() as __init
rcu: Simplify association of quiescent states with grace periods
rcu: Rename dynticks_completed to completed_fqs
rcu: Enable synchronize_sched_expedited() fastpath
rcu: Remove inline from forward-referenced functions
rcu: Fix note_new_gpnum() uses of ->gpnum
rcu: Fix synchronization for rcu_process_gp_end() uses of ->completed counter
rcu: Prepare for synchronization fixes: clean up for non-NO_HZ handling of ->completed counter
rcu: Cleanup: balance rcu_irq_enter()/rcu_irq_exit() calls
* 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
mutex: Fix missing conditions to build mutex_spin_on_owner()
mutex: Better control mutex adaptive spinning config
locking, task_struct: Reduce size on TRACE_IRQFLAGS and 64bit
locking: Use __[SPIN|RW]_LOCK_UNLOCKED in [spin|rw]_lock_init()
locking: Remove unused prototype
locking: Reduce ifdefs in kernel/spinlock.c
locking: Make inlining decision Kconfig based
Jon confirms that recent modprobe will look in /proc/cmdline, so these
cmdline options can still be used.
See http://bugzilla.kernel.org/show_bug.cgi?id=14164
Reported-by: Adam Williamson <awilliam@redhat.com>
Cc: stable@kernel.org
The SYSFS_DEPRECATED_V2 says "remove" older, deprecated features, but it
actually enables them, so correct this confusing, backwards text.
Cc: Greg KH <greg@kroah.com>
Move slow_work's debugging proc file to debugfs.
Requested-and-acked-by: Ingo Molnar <mingo@elte.hu>
Limit the number of per cpu calibration messages by only
printing out results for the first cpu to boot.
Also, don't print "CPUx is down" as this is expected, and we
don't need 4096 reminders... ;-)
Signed-off-by: Mike Travis <travis@sgi.com>
Cc: Roland Dreier <rdreier@cisco.com>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Cc: Tejun Heo <tj@kernel.org>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Yinghai Lu <yhlu.kernel@gmail.com>
Cc: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
Cc: Jack Steiner <steiner@sgi.com>
LKML-Reference: <20091118002219.889552000@alcatraz.americas.sgi.com>
Allow the executing and queued work items to be viewed through a /proc file
for debugging purposes. The contents look something like the following:
THR PID ITEM ADDR FL MARK DESC
0 3005 ffff880023f52348 a 952ms FSC: OBJ17d3: LOOK
1 3006 ffff880024e33668 2 160ms FSC: OBJ17e5 OP60d3b: Write1/Store fl=2
2 3165 ffff8800296dd180 a 424ms FSC: OBJ17e4: LOOK
3 4089 ffff8800262c8d78 a 212ms FSC: OBJ17ea: CRTN
4 4090 ffff88002792bed8 2 388ms FSC: OBJ17e8 OP60d36: Write1/Store fl=2
5 4092 ffff88002a0ef308 2 388ms FSC: OBJ17e7 OP60d2e: Write1/Store fl=2
6 4094 ffff88002abaf4b8 2 132ms FSC: OBJ17e2 OP60d4e: Write1/Store fl=2
7 4095 ffff88002bb188e0 a 388ms FSC: OBJ17e9: CRTN
vsq - ffff880023d99668 1 308ms FSC: OBJ17e0 OP60f91: Write1/EnQ fl=2
vsq - ffff8800295d1740 1 212ms FSC: OBJ16be OP4d4b6: Write1/EnQ fl=2
vsq - ffff880025ba3308 1 160ms FSC: OBJ179a OP58dec: Write1/EnQ fl=2
vsq - ffff880024ec83e0 1 160ms FSC: OBJ17ae OP599f2: Write1/EnQ fl=2
vsq - ffff880026618e00 1 160ms FSC: OBJ17e6 OP60d33: Write1/EnQ fl=2
vsq - ffff880025a2a4b8 1 132ms FSC: OBJ16a2 OP4d583: Write1/EnQ fl=2
vsq - ffff880023cbe6d8 9 212ms FSC: OBJ17eb: LOOK
vsq - ffff880024d37590 9 212ms FSC: OBJ17ec: LOOK
vsq - ffff880027746cb0 9 212ms FSC: OBJ17ed: LOOK
vsq - ffff880024d37ae8 9 212ms FSC: OBJ17ee: LOOK
vsq - ffff880024d37cb0 9 212ms FSC: OBJ17ef: LOOK
vsq - ffff880025036550 9 212ms FSC: OBJ17f0: LOOK
vsq - ffff8800250368e0 9 212ms FSC: OBJ17f1: LOOK
vsq - ffff880025036aa8 9 212ms FSC: OBJ17f2: LOOK
In the 'THR' column, executing items show the thread they're occupying and
queued threads indicate which queue they're on. 'PID' shows the process ID of
a slow-work thread that's executing something. 'FL' shows the work item flags.
'MARK' indicates how long since an item was queued or began executing. Lastly,
the 'DESC' column permits the owner of an item to give some information.
Resolve the conflict between v2.6.32-rc7 where dn_def_dev_handler
gets a small bug fix and the sysctl tree where I am removing all
sysctl strategy routines.
commit 892a7c67 (locking: Allow arch-inlined spinlocks) implements the
selection of which lock functions are inlined based on defines in
arch/.../spinlock.h: #define __always_inline__LOCK_FUNCTION
Despite of the name __always_inline__* the lock functions can be built
out of line depending on config options. Also if the arch does not set
some inline defines the generic code might set them; again depending on
config options.
This makes it unnecessary hard to figure out when and which lock
functions are inlined. Aside of that it makes it way harder and
messier for -rt to manipulate the lock functions.
Convert the inlining decision to CONFIG switches. Each lock function
is inlined depending on CONFIG_INLINE_*. The configs implement the
existing dependencies. The architecture code can select ARCH_INLINE_*
to signal that it wants the corresponding lock function inlined.
ARCH_INLINE_* is necessary as Kconfig ignores "depends on"
restrictions when a config element is selected.
No functional change.
LKML-Reference: <20091109151428.504477141@linutronix.de>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com>
Reviewed-by: Ingo Molnar <mingo@elte.hu>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
perf tools: Fix permission checks
perf_events: Fix some typo in the perf events config description
To simply maintenance and to be able to remove all of the binary
sysctl support from various subsystems I have rewritten the binary
sysctl code as a compatibility wrapper around proc/sys.
The code is built around a hard coded table based on the table
in sysctl_check.c that lists all of our current binary sysctls
and provides enough information to convert from the sysctl
binary input into into ascii and back again. New in this
patch is the realization that the only dynamic entries
that need to be handled have ifname as the asscii string
and ifindex as their ctl_name.
When a sys_sysctl is called the code now looks in the
translation table converting the binary name to the
path under /proc where the value is to be found. Opens
that file, and calls into a format conversion wrapper
that calls fop->read and then fop->write as appropriate.
Since in practice the practically no one uses or tests
sys_sysctl rewritting the code to be beautiful is a little
silly. The redeeming merit of this work is it allows us to
rip out all of the binary sysctl syscall support from
everywhere else in the tree. Allowing us to remove
a lot of dead (after this patch) and barely maintained code.
In addition it becomes much easier to optimize the sysctl
implementation for being the backing store of /proc/sys,
without having to worry about sys_sysctl.
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com>
Cc: trivial@kernel.org
LKML-Reference: <1256938346-8230-1-git-send-email-cascardo@holoscopio.com>
We dont need to depend on PPC64 explicitly as all powerpc platforms
(32-bit and 64-bit) define PPC now.
This patch is a version of RCU designed for !SMP provided for a
small-footprint RCU implementation. In particular, the
implementation of synchronize_rcu() is extremely lightweight and
high performance. It passes rcutorture testing in each of the
four relevant configurations (combinations of NO_HZ and PREEMPT)
on x86. This saves about 1K bytes compared to old Classic RCU
(which is no longer in mainline), and more than three kilobytes
compared to Hierarchical RCU (updated to 2.6.30):
CONFIG_TREE_RCU:
text data bss dec filename
183 4 0 187 kernel/rcupdate.o
2783 520 36 3339 kernel/rcutree.o
3526 Total (vs 4565 for v7)
CONFIG_TREE_PREEMPT_RCU:
263 4 0 267 kernel/rcupdate.o
4594 776 52 5422 kernel/rcutree.o
5689 Total (6155 for v7)
CONFIG_TINY_RCU:
96 4 0 100 kernel/rcupdate.o
734 24 0 758 kernel/rcutiny.o
858 Total (vs 848 for v7)
The above is for x86. Your mileage may vary on other platforms.
Further compression is possible, but is being procrastinated.
Changes from v7 (http://lkml.org/lkml/2009/10/9/388)
o Apply Lai Jiangshan's review comments (aside from
might_sleep() in synchronize_sched(), which is covered by SMP builds).
o Fix up expedited primitives.
Changes from v6 (http://lkml.org/lkml/2009/9/23/293).
o Forward ported to put it into the 2.6.33 stream.
o Added lockdep support.
o Make lightweight rcu_barrier.
Changes from v5 (http://lkml.org/lkml/2009/6/23/12).
o Ported to latest pre-2.6.32 merge window kernel.
- Renamed rcu_qsctr_inc() to rcu_sched_qs().
- Renamed rcu_bh_qsctr_inc() to rcu_bh_qs().
- Provided trivial rcu_cpu_notify().
- Provided trivial exit_rcu().
- Provided trivial rcu_needs_cpu().
- Fixed up the rcu_*_enter/exit() functions in linux/hardirq.h.
o Removed the dependence on EMBEDDED, with a view to making
TINY_RCU default for !SMP at some time in the future.
o Added (trivial) support for expedited grace periods.
Changes from v4 (http://lkml.org/lkml/2009/5/2/91) include:
o Squeeze the size down a bit further by removing the
->completed field from struct rcu_ctrlblk.
o This permits synchronize_rcu() to become the empty function.
Previous concerns about rcutorture were unfounded, as
rcutorture correctly handles a constant value from
rcu_batches_completed() and rcu_batches_completed_bh().
Changes from v3 (http://lkml.org/lkml/2009/3/29/221) include:
o Changed rcu_batches_completed(), rcu_batches_completed_bh()
rcu_enter_nohz(), rcu_exit_nohz(), rcu_nmi_enter(), and
rcu_nmi_exit(), to be static inlines, as suggested by David
Howells. Doing this saves about 100 bytes from rcutiny.o.
(The numbers between v3 and this v4 of the patch are not directly
comparable, since they are against different versions of Linux.)
Changes from v2 (http://lkml.org/lkml/2009/2/3/333) include:
o Fix whitespace issues.
o Change short-circuit "||" operator to instead be "+" in order
to fix performance bug noted by "kraai" on LWN.
(http://lwn.net/Articles/324348/)
Changes from v1 (http://lkml.org/lkml/2009/1/13/440) include:
o This version depends on EMBEDDED as well as !SMP, as suggested
by Ingo.
o Updated rcu_needs_cpu() to unconditionally return zero,
permitting the CPU to enter dynticks-idle mode at any time.
This works because callbacks can be invoked upon entry to
dynticks-idle mode.
o Paul is now OK with this being included, based on a poll at
the Kernel Miniconf at linux.conf.au, where about ten people said
that they cared about saving 900 bytes on single-CPU systems.
o Applies to both mainline and tip/core/rcu.
Acked-by: Josh Triplett <josh@joshtriplett.org>
Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: dipankar@in.ibm.com
Cc: mathieu.desnoyers@polymtl.ca
Cc: dvhltc@us.ibm.com
Cc: niv@us.ibm.com
Cc: peterz@infradead.org
Cc: rostedt@goodmis.org
Cc: Valdis.Kletnieks@vt.edu
Cc: avi@redhat.com
Cc: mtosatti@redhat.com
LKML-Reference: <12565226351355-git-send-email->
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
futex: fix requeue_pi key imbalance
futex: Fix typo in FUTEX_WAIT/WAKE_BITSET_PRIVATE definitions
rcu: Place root rcu_node structure in separate lockdep class
rcu: Make hot-unplugged CPU relinquish its own RCU callbacks
rcu: Move rcu_barrier() to rcutree
futex: Move exit_pi_state() call to release_mm()
futex: Nullify robust lists after cleanup
futex: Fix locking imbalance
panic: Fix panic message visibility by calling bust_spinlocks(0) before dying
rcu: Replace the rcu_barrier enum with pointer to call_rcu*() function
rcu: Clean up code based on review feedback from Josh Triplett, part 4
rcu: Clean up code based on review feedback from Josh Triplett, part 3
rcu: Fix rcu_lock_map build failure on CONFIG_PROVE_LOCKING=y
rcu: Clean up code to address Ingo's checkpatch feedback
rcu: Clean up code based on review feedback from Josh Triplett, part 2
Some architectures such as Sparc, ARM and MIPS (basically
everything with flush_dcache_page()) need to deal with dcache
aliases by carefully placing pages in both kernel and user maps.
These architectures typically have to use vmalloc_user() for this.
However, on other architectures, vmalloc() is not needed and has
the downsides of being more restricted and slower than regular
allocations.
Acked-by: David Miller <davem@davemloft.net>
Cc: Jens Axboe <jens.axboe@oracle.com>
LKML-Reference: <1254830228.21044.272.camel@laptop>
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: (39 commits)
cpumask: Move deprecated functions to end of header.
cpumask: remove unused deprecated functions, avoid accusations of insanity
cpumask: use new-style cpumask ops in mm/quicklist.
cpumask: use mm_cpumask() wrapper: x86
cpumask: use mm_cpumask() wrapper: um
cpumask: use mm_cpumask() wrapper: mips
cpumask: use mm_cpumask() wrapper: mn10300
cpumask: use mm_cpumask() wrapper: m32r
cpumask: use mm_cpumask() wrapper: arm
cpumask: Use accessors for cpu_*_mask: um
cpumask: Use accessors for cpu_*_mask: powerpc
cpumask: Use accessors for cpu_*_mask: mips
cpumask: Use accessors for cpu_*_mask: m32r
cpumask: remove arch_send_call_function_ipi
cpumask: arch_send_call_function_ipi_mask: s390
cpumask: arch_send_call_function_ipi_mask: powerpc
cpumask: arch_send_call_function_ipi_mask: mips
cpumask: arch_send_call_function_ipi_mask: m32r
cpumask: arch_send_call_function_ipi_mask: alpha
cpumask: remove obsolete topology_core_siblings and topology_thread_siblings: ia64
* remove asm/atomic.h inclusion from linux/utsname.h --
not needed after kref conversion
* remove linux/utsname.h inclusion from files which do not need it
NOTE: it looks like fs/binfmt_elf.c do not need utsname.h, however
due to some personality stuff it _is_ needed -- cowardly leave ELF-related
headers and files alone.
It's only defined for NR_CPUS > BITS_PER_LONG; cpu_all_mask is always
defined (and const).
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next: (30 commits)
Use macros for .data.page_aligned section.
Use macros for .bss.page_aligned section.
Use new __init_task_data macro in arch init_task.c files.
kbuild: Don't define ALIGN and ENTRY when preprocessing linker scripts.
arm, cris, mips, sparc, powerpc, um, xtensa: fix build with bash 4.0
kbuild: add static to prototypes
kbuild: fail build if recordmcount.pl fails
kbuild: set -fconserve-stack option for gcc 4.5
kbuild: echo the record_mcount command
gconfig: disable "typeahead find" search in treeviews
kbuild: fix cc1 options check to ensure we do not use -fPIC when compiling
checkincludes.pl: add option to remove duplicates in place
markup_oops: use modinfo to avoid confusion with underscored module names
checkincludes.pl: provide usage helper
checkincludes.pl: close file as soon as we're done with it
ctags: usability fix
kernel hacking: move STRIP_ASM_SYMS from General
gitignore usr/initramfs_data.cpio.bz2 and usr/initramfs_data.cpio.lzma
kbuild: Check if linker supports the -X option
kbuild: introduce ld-option
Fix trivial conflict in scripts/basic/fixdep.c
These issues identified during an old-fashioned face-to-face code
review extending over many hours.
o Add comments for tricky parts of code, and correct comments
that have passed their sell-by date.
o Get rid of the vestiges of rcu_init_sched(), which is no
longer needed now that PREEMPT_RCU is gone.
o Move the #include of rcutree_plugin.h to the end of
rcutree.c, which means that, rather than having a random
collection of forward declarations, the new set of forward
declarations document the set of plugins. The new home for
this #include also allows __rcu_init_preempt() to move into
rcutree_plugin.h.
o Fix rcu_preempt_check_callbacks() to be static.
Suggested-by: Josh Triplett <josh@joshtriplett.org>
Cc: laijs@cn.fujitsu.com
Cc: akpm@linux-foundation.org
Cc: josh@joshtriplett.org
Cc: niv@us.ibm.com
Cc: dhowells@redhat.com
LKML-Reference: <12537246443924-git-send-email->
Peter Zijlstra <peterz@infradead.org>
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-sfi-2.6
* 'sfi-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-sfi-2.6:
SFI: remove unneeded includes
sfi: Remove unused code
SFI: Hook PCI MMCONFIG
x86: add arch-specific SFI support
SFI: add capability to parse ACPI tables
SFI: add platform-independent core support
SFI: create linux/sfi.h
SFI: Simple Firmware Interface - MAINTAINERS, Kconfig
Sizing of memory allocations shouldn't depend on the number of physical
pages found in a system, as that generally includes (perhaps a huge amount
of) non-RAM pages. The amount of what actually is usable as storage
should instead be used as a basis here.
Some of the calculations (i.e. those not intending to use high memory)
should likely even use (totalram_pages - totalhigh_pages).
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
Cc: Dave Airlie <airlied@linux.ie>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Cc: Patrick McHardy <kaber@trash.net>
* 'perfcounters-rename-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
perf: Tidy up after the big rename
perf: Do the big rename: Performance Counters -> Performance Events
perf_counter: Rename 'event' to event_id/hw_event
perf_counter: Rename list_entry -> group_entry, counter_list -> group_list
Manually resolved some fairly trivial conflicts with the tracing tree in
include/trace/ftrace.h and kernel/trace/trace_syscalls.c.
rcu: Fix whitespace inconsistencies
rcu: Fix thinko, actually initialize full tree
rcu: Apply results of code inspection of kernel/rcutree_plugin.h
rcu: Add WARN_ON_ONCE() consistency checks covering state transitions
rcu: Fix synchronize_rcu() for TREE_PREEMPT_RCU
rcu: Simplify rcu_read_unlock_special() quiescent-state accounting
rcu: Add debug checks to TREE_PREEMPT_RCU for premature grace periods
rcu: Kconfig help needs to say that TREE_PREEMPT_RCU scales down
rcutorture: Occasionally delay readers enough to make RCU force_quiescent_state
rcu: Initialize multi-level RCU grace periods holding locks
rcu: Need to update rnp->gpnum if preemptable RCU is to be reliable
- provide compatibility Kconfig entry for existing PERF_COUNTERS .config's
- provide courtesy copy of old perf_counter.h, for user-space projects
- small indentation fixups
- fix up MAINTAINERS
- fix small x86 printout fallout
- fix up small PowerPC comment fallout (use 'counter' as in register)
Reviewed-by: Arjan van de Ven <arjan@linux.intel.com>
LKML-Reference: <new-submission>
Bye-bye Performance Counters, welcome Performance Events!
In the past few months the perfcounters subsystem has grown out its
initial role of counting hardware events, and has become (and is
becoming) a much broader generic event enumeration, reporting, logging,
monitoring, analysis facility.
Naming its core object 'perf_counter' and naming the subsystem
'perfcounters' has become more and more of a misnomer. With pending
code like hw-breakpoints support the 'counter' name is less and
less appropriate.
All in one, we've decided to rename the subsystem to 'performance
events' and to propagate this rename through all fields, variables
and API names. (in an ABI compatible fashion)
The word 'event' is also a bit shorter than 'counter' - which makes
it slightly more convenient to write/handle as well.
Thanks goes to Stephane Eranian who first observed this misnomer and
suggested a rename.
User-space tooling and ABI compatibility is not affected - this patch
should be function-invariant. (Also, defconfigs were not touched to
keep the size down.)
This patch has been generated via the following script:
FILES=$(find * -type f | grep -vE 'oprofile|[^K]config')
sed -i \
-e 's/PERF_EVENT_/PERF_RECORD_/g' \
-e 's/PERF_COUNTER/PERF_EVENT/g' \
-e 's/perf_counter/perf_event/g' \
-e 's/nb_counters/nb_events/g' \
-e 's/swcounter/swevent/g' \
-e 's/tpcounter_event/tp_event/g' \
$FILES
for N in $(find . -name perf_counter.[ch]); do
M=$(echo $N | sed 's/perf_counter/perf_event/g')
mv $N $M
done
FILES=$(find . -name perf_event.*)
sed -i \
-e 's/COUNTER_MASK/REG_MASK/g' \
-e 's/COUNTER/EVENT/g' \
-e 's/\<event\>/event_id/g' \
-e 's/counter/event/g' \
-e 's/Counter/Event/g' \
$FILES
... to keep it as correct as possible. This script can also be
used by anyone who has pending perfcounters patches - it converts
a Linux kernel tree over to the new naming. We tried to time this
change to the point in time where the amount of pending patches
is the smallest: the end of the merge window.
Namespace clashes were fixed up in a preparatory patch - and some
stylistic fallout will be fixed up in a subsequent patch.
( NOTE: 'counters' are still the proper terminology when we deal
with hardware registers - and these sed scripts are a bit
over-eager in renaming them. I've undone some of that, but
in case there's something left where 'counter' would be
better than 'event' we can undo that on an individual basis
instead of touching an otherwise nicely automated patch. )
Suggested-by: Stephane Eranian <eranian@google.com>
Acked-by: Paul Mackerras <paulus@samba.org>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: <linux-arch@vger.kernel.org>
Sam suggested moving STRIP_ASM_SYMS into the Kernel hacking menu
from the General Setup menu. It makes more sense there.
arch/x86/kernel/setup.c
drivers/acpi/power.c
init/main.c
Signed-off-by: Len Brown <len.brown@intel.com>
Now that the last users of markers have migrated to the event
tracer we can kill off the (now orphan) support code.
Acked-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
LKML-Reference: <20090917173527.GA1699@lst.de>
To quote Valdis:
This leaves somebody who has a laptop wondering which
choice is best for a system with only one or two cores that
has CONFIG_PREEMPT defined. One choice says it scales down
nicely, the other explicitly has a 'depends on PREEMPT'
attached to it...
So add "scales down nicely" to TREE_PREEMPT_RCU to match that of
TREE_RCU.
Suggested-by: Valdis Kletnieks <Valdis.Kletnieks@vt.edu>
Cc: niv@us.ibm.com
LKML-Reference: <12528585112362-git-send-email->
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6:
Driver Core: devtmpfs - kernel-maintained tmpfs-based /dev
debugfs: Modify default debugfs directory for debugging pktcdvd.
debugfs: Modified default dir of debugfs for debugging UHCI.
debugfs: Change debugfs directory of IWMC3200
debugfs: Change debuhgfs directory of trace-events-sample.h
debugfs: Fix mount directory of debugfs by default in events.txt
hpilo: add poll f_op
hpilo: add interrupt handler
hpilo: staging for interrupt handling
driver core: platform_device_add_data(): use kmemdup()
Driver core: Add support for compatibility classes
uio: add generic driver for PCI 2.3 devices
driver-core: move dma-coherent.c from kernel to driver/base
mem_class: fix bug
mem_class: use minor as index instead of searching the array
driver model: constify attribute groups
UIO: remove 'default n' from Kconfig
Driver core: Add accessor for device platform data
Driver core: move dev_get/set_drvdata to drivers/base/dd.c
Driver core: add new device to bus's list before probing
Devtmpfs lets the kernel create a tmpfs instance called devtmpfs
very early at kernel initialization, before any driver-core device
is registered. Every device with a major/minor will provide a
device node in devtmpfs.
Devtmpfs can be changed and altered by userspace at any time,
and in any way needed - just like today's udev-mounted tmpfs.
Unmodified udev versions will run just fine on top of it, and will
recognize an already existing kernel-created device node and use it.
The default node permissions are root:root 0600. Proper permissions
and user/group ownership, meaningful symlinks, all other policy still
needs to be applied by userspace.
If a node is created by devtmps, devtmpfs will remove the device node
when the device goes away. If the device node was created by
userspace, or the devtmpfs created node was replaced by userspace, it
will no longer be removed by devtmpfs.
If it is requested to auto-mount it, it makes init=/bin/sh work
without any further userspace support. /dev will be fully populated
and dynamic, and always reflect the current device state of the kernel.
With the commonly used dynamic device numbers, it solves the problem
where static devices nodes may point to the wrong devices.
It is intended to make the initial bootup logic simpler and more robust,
by de-coupling the creation of the inital environment, to reliably run
userspace processes, from a complex userspace bootstrap logic to provide
a working /dev.
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Signed-off-by: Jan Blunck <jblunck@suse.de>
Tested-By: Harald Hoyer <harald@redhat.com>
Tested-By: Scott James Remnant <scott@ubuntu.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (46 commits)
powerpc64: convert to dynamic percpu allocator
sparc64: use embedding percpu first chunk allocator
percpu: kill lpage first chunk allocator
x86,percpu: use embedding for 64bit NUMA and page for 32bit NUMA
percpu: update embedding first chunk allocator to handle sparse units
percpu: use group information to allocate vmap areas sparsely
vmalloc: implement pcpu_get_vm_areas()
vmalloc: separate out insert_vmalloc_vm()
percpu: add chunk->base_addr
percpu: add pcpu_unit_offsets[]
percpu: introduce pcpu_alloc_info and pcpu_group_info
percpu: move pcpu_lpage_build_unit_map() and pcpul_lpage_dump_cfg() upward
percpu: add @align to pcpu_fc_alloc_fn_t
percpu: make @dyn_size mandatory for pcpu_setup_first_chunk()
percpu: drop @static_size from first chunk allocators
percpu: generalize first chunk allocator selection
percpu: build first chunk allocators selectively
percpu: rename 4k first chunk allocator to page
percpu: improve boot messages
percpu: fix pcpu_reclaim() locking
Fix trivial conflict as by Tejun Heo in kernel/sched.c
