Commit abf917cd91cb ("cputime: Generic on-demand virtual cputime
accounting") inadvertantly changed the default CPU_ACCOUNTING
config for PPC64. Repair that.
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
Cc: Li Zhong <zhong@linux.vnet.ibm.com>
Cc: Namhyung Kim <namhyung.kim@lge.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: ppc-dev <linuxppc-dev@lists.ozlabs.org>
Link: http://lkml.kernel.org/r/20130208141938.f31b7b9e1acac5bbe769ee4c@canb.auug.org.au
Move rt scheduler definitions out of include/linux/sched.h into
new file include/linux/sched/rt.h
Signed-off-by: Clark Williams <williams@redhat.com>
Link: http://lkml.kernel.org/r/20130207094707.7b9f825f@riff.lan
Move the sysctl-related bits from include/linux/sched.h into
a new file: include/linux/sched/sysctl.h. Then update source
files requiring access to those bits by including the new
header file.
Link: http://lkml.kernel.org/r/20130207094659.06dced96@riff.lan
All in-kernel users of class_find_device() don't really need mutable
data for match callback.
In two places (kernel/power/suspend_test.c, drivers/scsi/osd/osd_uld.c)
this patch changes match callbacks to use const search data.
The const is propagated to rtc_class_open() and power_supply_get_by_name()
parameters.
Note that there's a dev reference leak in suspend_test.c that's not
touched in this patch.
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/linux-dynticks into sched/core
Pull full-dynticks (user-space execution is undisturbed and
receives no timer IRQs) preparation changes that convert the
cputime accounting code to be full-dynticks ready,
from Frederic Weisbecker:
"This implements the cputime accounting on full dynticks CPUs.
Typical cputime stats infrastructure relies on the timer tick and
its periodic polling on the CPU to account the amount of time
spent by the CPUs and the tasks per high level domains such as
userspace, kernelspace, guest, ...
Now we are preparing to implement full dynticks capability on
Linux for Real Time and HPC users who want full CPU isolation.
This feature requires a cputime accounting that doesn't depend
on the timer tick.
To implement it, this new cputime infrastructure plugs into
kernel/user/guest boundaries to take snapshots of cputime and
flush these to the stats when needed. This performs pretty
much like CONFIG_VIRT_CPU_ACCOUNTING except that context location
and cputime snaphots are synchronized between write and read
side such that the latter can safely retrieve the pending tickless
cputime of a task and add it to its latest cputime snapshot to
return the correct result to the user."
kernel/irq_work.c
Add support for printk in full dynticks CPU.
* Don't stop tick with irq works pending. This
fix is generally useful and concerns archs that
can't raise self IPIs.
* Flush irq works before CPU offlining.
* Introduce "lazy" irq works that can wait for the
next tick to be executed, unless it's stopped.
* Implement klogd wake up using irq work. This
removes the ad-hoc printk_tick()/printk_needs_cpu()
hooks and make it working even in dynticks mode.
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu into core/rcu
Pull RCU updates from Paul E. McKenney:
1. Changes to rcutorture and to RCU documentation. Posted to LKML at
https://lkml.org/lkml/2013/1/26/188.
2. Enhancements to uniprocessor handling in tiny RCU. Posted to LKML
at https://lkml.org/lkml/2013/1/27/2.
3. Tag RCU callbacks with grace-period number to simplify callback
advancement. Posted to LKML at https://lkml.org/lkml/2013/1/26/203.
4. Miscellaneous fixes. Posted to LKML at https://lkml.org/lkml/2013/1/26/204.
Pull x86 fixes from Peter Anvin:
"This is a collection of miscellaneous fixes, the most important one is
the fix for the Samsung laptop bricking issue (auto-blacklisting the
samsung-laptop driver); the efi_enabled() changes you see below are
prerequisites for that fix.
The other issues fixed are booting on OLPC XO-1.5, an UV fix, NMI
debugging, and requiring CAP_SYS_RAWIO for MSR references, just as
with I/O port references."
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
samsung-laptop: Disable on EFI hardware
efi: Make 'efi_enabled' a function to query EFI facilities
smp: Fix SMP function call empty cpu mask race
x86/msr: Add capabilities check
x86/dma-debug: Bump PREALLOC_DMA_DEBUG_ENTRIES
x86/olpc: Fix olpc-xo1-sci.c build errors
arch/x86/platform/uv: Fix incorrect tlb flush all issue
x86-64: Fix unwind annotations in recent NMI changes
x86-32: Start out cr0 clean, disable paging before modifying cr3/4
Originally 'efi_enabled' indicated whether a kernel was booted from
EFI firmware. Over time its semantics have changed, and it now
indicates whether or not we are booted on an EFI machine with
bit-native firmware, e.g. 64-bit kernel with 64-bit firmware.
The immediate motivation for this patch is the bug report at,
https://bugs.launchpad.net/ubuntu-cdimage/+bug/1040557
which details how running a platform driver on an EFI machine that is
designed to run under BIOS can cause the machine to become
bricked. Also, the following report,
https://bugzilla.kernel.org/show_bug.cgi?id=47121
details how running said driver can also cause Machine Check
Exceptions. Drivers need a new means of detecting whether they're
running on an EFI machine, as sadly the expression,
if (!efi_enabled)
hasn't been a sufficient condition for quite some time.
Users actually want to query 'efi_enabled' for different reasons -
what they really want access to is the list of available EFI
facilities.
For instance, the x86 reboot code needs to know whether it can invoke
the ResetSystem() function provided by the EFI runtime services, while
the ACPI OSL code wants to know whether the EFI config tables were
mapped successfully. There are also checks in some of the platform
driver code to simply see if they're running on an EFI machine (which
would make it a bad idea to do BIOS-y things).
This patch is a prereq for the samsung-laptop fix patch.
Cc: David Airlie <airlied@linux.ie>
Cc: Corentin Chary <corentincj@iksaif.net>
Cc: Matthew Garrett <mjg59@srcf.ucam.org>
Cc: Dave Jiang <dave.jiang@intel.com>
Cc: Olof Johansson <olof@lixom.net>
Cc: Peter Jones <pjones@redhat.com>
Cc: Colin Ian King <colin.king@canonical.com>
Cc: Steve Langasek <steve.langasek@canonical.com>
Cc: Konrad Rzeszutek Wilk <konrad@kernel.org>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
Cc: <stable@vger.kernel.org>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
The TINY_PREEMPT_RCU is complex, does not provide that much memory
savings, and therefore TREE_PREEMPT_RCU should be used instead. The
systems where the difference between TINY_PREEMPT_RCU and TREE_PREEMPT_RCU
are quite small compared to the memory footprint of CONFIG_PREEMPT.
This commit therefore takes a first step towards eliminating
TINY_PREEMPT_RCU by allowing TREE_PREEMPT_RCU to be configured on !SMP
systems.
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Tiny RCU has historically omitted RCU CPU stall warnings in order to
reduce memory requirements, however, lack of these warnings caused
Thomas Gleixner some debugging pain recently. Therefore, this commit
adds RCU CPU stall warnings to tiny RCU if RCU_TRACE=y. This keeps
the memory footprint small, while still enabling CPU stall warnings
in kernels built to enable them.
Updated to include Josh Triplett's suggested use of RCU_STALL_COMMON
config variable to simplify #if expressions.
Reported-by: Thomas Gleixner <tglx@linutronix.de>
Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org>
If we want to stop the tick further idle, we need to be
able to account the cputime without using the tick.
Virtual based cputime accounting solves that problem by
hooking into kernel/user boundaries.
However implementing CONFIG_VIRT_CPU_ACCOUNTING require
low level hooks and involves more overhead. But we already
have a generic context tracking subsystem that is required
for RCU needs by archs which plan to shut down the tick
outside idle.
This patch implements a generic virtual based cputime
accounting that relies on these generic kernel/user hooks.
There are some upsides of doing this:
- This requires no arch code to implement CONFIG_VIRT_CPU_ACCOUNTING
if context tracking is already built (already necessary for RCU in full
tickless mode).
- We can rely on the generic context tracking subsystem to dynamically
(de)activate the hooks, so that we can switch anytime between virtual
and tick based accounting. This way we don't have the overhead
of the virtual accounting when the tick is running periodically.
And one downside:
- There is probably more overhead than a native virtual based cputime
accounting. But this relies on hooks that are already set anyway.
In the help text describing user namespaces recommend use of memory
control groups. In many cases memory control groups are the only
mechanism there is to limit how much memory a user who can create
user namespaces can use.
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
This resolves a gpio driver merge issue pointed out in linux-next.
To allow the builder to sign only a subset of modules, or to sign the
modules using a key that is not available on the build machine, add
CONFIG_MODULE_SIG_ALL. If this option is unset, no modules will be
signed during build. The default is 'y', to preserve the current
behavior.
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/linux-dynticks into irq/core
irq_work fixes and cleanups, in preparation for full dyntics support.
To receive f56c3196f251012de9b3ebaff55732a9074fdaae ("async: fix
__lowest_in_progress()").
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal
Pull misc syscall fixes from Al Viro:
- compat syscall fixes (discussed back in December)
- a couple of "make life easier for sigaltstack stuff by reducing
inter-tree dependencies"
- fix up compiler/asmlinkage calling convention disagreement of
sys_clone()
- misc
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal:
sys_clone() needs asmlinkage_protect
make sure that /linuxrc has std{in,out,err}
x32: fix sigtimedwait
x32: fix waitid()
switch compat_sys_wait4() and compat_sys_waitid() to COMPAT_SYSCALL_DEFINE
switch compat_sys_sigaltstack() to COMPAT_SYSCALL_DEFINE
CONFIG_GENERIC_SIGALTSTACK build breakage with asm-generic/syscalls.h
Ensure that kernel_init_freeable() is not inlined into non __init code
This patch adds default module loading and uses it to load the default
block elevator. During boot, it's called right after initramfs or
initrd is made available and right before control is passed to
userland. This ensures that as long as the modules are available in
the usual places in initramfs, initrd or the root filesystem, the
default modules are loaded as soon as possible.
This will replace the on-demand elevator module loading from elevator
init path.
v2: Fixed build breakage when !CONFIG_BLOCK. Reported by kbuild test
robot.
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Alex Riesen <raa.lkml@gmail.com>
Cc: Fengguang We <fengguang.wu@intel.com>
This is to fix up a build problem with a wireless driver due to the
dynamic-debug patches in this branch.
In commit 281dc5c5ec0f ("Give up on pushing CC_OPTIMIZE_FOR_SIZE") we
already changed the actual default value, but the help-text still
suggested 'y'. Fix the help text too, for all the same reasons.
Sadly, -Os keeps on generating some very suboptimal code for certain
cases, to the point where any I$ miss upside is swamped by the downside.
The main ones are:
- using "rep movsb" for memcpy, even on CPU's where that is
horrendously bad for performance.
- not honoring branch prediction information, so any I$ footprint you
win from smaller code, you lose from less code density in the I$.
- using divide instructions when that is very expensive.
Signed-off-by: Kirill Smelkov <kirr@mns.spb.ru>
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a
while now and is almost always enabled by default. As agreed during the
Linux kernel summit, remove it from any "depends on" lines in Kconfigs.
CC: "Eric W. Biederman" <ebiederm@xmission.com>
CC: Serge Hallyn <serge.hallyn@canonical.com>
CC: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
CC: Andrew Morton <akpm@linux-foundation.org>
CC: Frederic Weisbecker <fweisbec@gmail.com>
Acked-by: Serge Hallyn <serge.hallyn@ubuntu.com>
This config item has not carried much meaning for a while now and is
almost always enabled by default (especially in distro builds). As agreed
during the Linux kernel summit, it should be removed. As a first step,
remove it from being listed, and default it to on. Once it has been
removed from all subsystem Kconfigs, it will be dropped entirely.
For items that really are experimental, maintainers should use "default
n", optionally include "(EXPERIMENTAL)" in the title, and add language to
the help text indicating why the item should be considered experimental.
For items that are dangerously experimental, the maintainer is encouraged
to follow the above title recommendation, add stronger language to the
help text, and optionally use (depending on the extent of the danger,
from least to most dangerous): printk(), add_taint(TAINT_WARN),
add_taint(TAINT_CRAP), WARN_ON(1), and CONFIG_BROKEN.
CC: Greg KH <gregkh@linuxfoundation.org>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
IA64 defines /proc/sys/kernel/ignore-unaligned-usertrap to control
verbose warnings on unaligned access emulation.
Although the exact mechanics of what to do with sysctl (ignore/shout)
are arch specific, this change enables the sysctl to be usable cross-arch.
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Serge Hallyn <serge.hallyn@canonical.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
Commit d6b2123802d "make sure that we always have a return path from
kernel_execve()" reshuffled kernel_init()/init_post() to ensure that
kernel_execve() has a caller to return to.
It removed __init annotation for kernel_init() and introduced/calls a
new routine kernel_init_freeable(). Latter however is inlined by any
reasonable compiler (ARC gcc 4.4 in this case), causing slight code
bloat.
This patch forces kernel_init_freeable() as noinline reducing the .text
bloat-o-meter vmlinux vmlinux_new
add/remove: 1/0 grow/shrink: 0/1 up/down: 374/-334 (40)
function old new delta
kernel_init_freeable - 374 +374 (.init.text)
kernel_init 628 294 -334 (.text)
Pull signal handling cleanups from Al Viro:
"sigaltstack infrastructure + conversion for x86, alpha and um,
COMPAT_SYSCALL_DEFINE infrastructure.
Note that there are several conflicts between "unify
SS_ONSTACK/SS_DISABLE definitions" and UAPI patches in mainline;
resolution is trivial - just remove definitions of SS_ONSTACK and
SS_DISABLED from arch/*/uapi/asm/signal.h; they are all identical and
include/uapi/linux/signal.h contains the unified variant."
Fixed up conflicts as per Al.
alpha: switch to generic sigaltstack
new helpers: __save_altstack/__compat_save_altstack, switch x86 and um to those
generic compat_sys_sigaltstack()
introduce generic sys_sigaltstack(), switch x86 and um to it
new helper: compat_user_stack_pointer()
new helper: restore_altstack()
unify SS_ONSTACK/SS_DISABLE definitions
new helper: current_user_stack_pointer()
missing user_stack_pointer() instances
Bury the conditionals from kernel_thread/kernel_execve series
COMPAT_SYSCALL_DEFINE: infrastructure
All architectures have
CONFIG_GENERIC_KERNEL_THREAD
CONFIG_GENERIC_KERNEL_EXECVE
__ARCH_WANT_SYS_EXECVE
None of them have __ARCH_WANT_KERNEL_EXECVE and there are only two callers
of kernel_execve() (which is a trivial wrapper for do_execve() now) left.
Kill the conditionals and make both callers use do_execve().
The page allocator is able to bind a page to a memcg when it is
allocated. But for the caches, we'd like to have as many objects as
possible in a page belonging to the same cache.
This is done in this patch by calling memcg_kmem_get_cache in the
beginning of every allocation function. This function is patched out by
static branches when kernel memory controller is not being used.
It assumes that the task allocating, which determines the memcg in the
page allocator, belongs to the same cgroup throughout the whole process.
Misaccounting can happen if the task calls memcg_kmem_get_cache() while
belonging to a cgroup, and later on changes. This is considered
acceptable, and should only happen upon task migration.
Before the cache is created by the memcg core, there is also a possible
imbalance: the task belongs to a memcg, but the cache being allocated from
is the global cache, since the child cache is not yet guaranteed to be
ready. This case is also fine, since in this case the GFP_KMEMCG will not
be passed and the page allocator will not attempt any cgroup accounting.
Signed-off-by: Glauber Costa <glommer@parallels.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Frederic Weisbecker <fweisbec@redhat.com>
Cc: JoonSoo Kim <js1304@gmail.com>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
Cc: Suleiman Souhlal <suleiman@google.com>
Cc: Tejun Heo <tj@kernel.org>
Add the basic infrastructure for the accounting of kernel memory. To
control that, the following files are created:
* memory.kmem.usage_in_bytes
* memory.kmem.limit_in_bytes
* memory.kmem.failcnt
* memory.kmem.max_usage_in_bytes
They have the same meaning of their user memory counterparts. They
reflect the state of the "kmem" res_counter.
Per cgroup kmem memory accounting is not enabled until a limit is set for
the group. Once the limit is set the accounting cannot be disabled for
that group. This means that after the patch is applied, no behavioral
changes exists for whoever is still using memcg to control their memory
usage, until memory.kmem.limit_in_bytes is set for the first time.
We always account to both user and kernel resource_counters. This
effectively means that an independent kernel limit is in place when the
limit is set to a lower value than the user memory. A equal or higher
value means that the user limit will always hit first, meaning that kmem
is effectively unlimited.
People who want to track kernel memory but not limit it, can set this
limit to a very high number (like RESOURCE_MAX - 1page - that no one will
ever hit, or equal to the user memory)
[akpm@linux-foundation.org: MEMCG_MMEM only works with slab and slub]
Acked-by: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull user namespace changes from Eric Biederman:
"While small this set of changes is very significant with respect to
containers in general and user namespaces in particular. The user
space interface is now complete.
This set of changes adds support for unprivileged users to create user
namespaces and as a user namespace root to create other namespaces.
The tyranny of supporting suid root preventing unprivileged users from
using cool new kernel features is broken.
This set of changes completes the work on setns, adding support for
the pid, user, mount namespaces.
This set of changes includes a bunch of basic pid namespace
cleanups/simplifications. Of particular significance is the rework of
the pid namespace cleanup so it no longer requires sending out
tendrils into all kinds of unexpected cleanup paths for operation. At
least one case of broken error handling is fixed by this cleanup.
The files under /proc/<pid>/ns/ have been converted from regular files
to magic symlinks which prevents incorrect caching by the VFS,
ensuring the files always refer to the namespace the process is
currently using and ensuring that the ptrace_mayaccess permission
checks are always applied.
The files under /proc/<pid>/ns/ have been given stable inode numbers
so it is now possible to see if different processes share the same
namespaces.
Through the David Miller's net tree are changes to relax many of the
permission checks in the networking stack to allowing the user
namespace root to usefully use the networking stack. Similar changes
for the mount namespace and the pid namespace are coming through my
tree.
Two small changes to add user namespace support were commited here adn
in David Miller's -net tree so that I could complete the work on the
/proc/<pid>/ns/ files in this tree.
Work remains to make it safe to build user namespaces and 9p, afs,
ceph, cifs, coda, gfs2, ncpfs, nfs, nfsd, ocfs2, and xfs so the
Kconfig guard remains in place preventing that user namespaces from
being built when any of those filesystems are enabled.
Future design work remains to allow root users outside of the initial
user namespace to mount more than just /proc and /sys."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (38 commits)
proc: Usable inode numbers for the namespace file descriptors.
proc: Fix the namespace inode permission checks.
proc: Generalize proc inode allocation
userns: Allow unprivilged mounts of proc and sysfs
userns: For /proc/self/{uid,gid}_map derive the lower userns from the struct file
procfs: Print task uids and gids in the userns that opened the proc file
userns: Implement unshare of the user namespace
userns: Implent proc namespace operations
userns: Kill task_user_ns
userns: Make create_new_namespaces take a user_ns parameter
userns: Allow unprivileged use of setns.
userns: Allow unprivileged users to create new namespaces
userns: Allow setting a userns mapping to your current uid.
userns: Allow chown and setgid preservation
userns: Allow unprivileged users to create user namespaces.
userns: Ignore suid and sgid on binaries if the uid or gid can not be mapped
userns: fix return value on mntns_install() failure
vfs: Allow unprivileged manipulation of the mount namespace.
vfs: Only support slave subtrees across different user namespaces
vfs: Add a user namespace reference from struct mnt_namespace
Pull block driver update from Jens Axboe:
"Now that the core bits are in, here are the driver bits for 3.8. The
branch contains:
- A huge pile of drbd bits that were dumped from the 3.7 merge
window. Following that, it was both made perfectly clear that
there is going to be no more over-the-wall pulls and how the
situation on individual pulls can be improved.
- A few cleanups from Akinobu Mita for drbd and cciss.
- Queue improvement for loop from Lukas. This grew into adding a
generic interface for waiting/checking an even with a specific
lock, allowing this to be pulled out of md and now loop and drbd is
also using it.
- A few fixes for xen back/front block driver from Roger Pau Monne.
- Partition improvements from Stephen Warren, allowing partiion UUID
to be used as an identifier."
* 'for-3.8/drivers' of git://git.kernel.dk/linux-block: (609 commits)
drbd: update Kconfig to match current dependencies
drbd: Fix drbdsetup wait-connect, wait-sync etc... commands
drbd: close race between drbd_set_role and drbd_connect
drbd: respect no-md-barriers setting also when changed online via disk-options
drbd: Remove obsolete check
drbd: fixup after wait_even_lock_irq() addition to generic code
loop: Limit the number of requests in the bio list
wait: add wait_event_lock_irq() interface
xen-blkfront: free allocated page
xen-blkback: move free persistent grants code
block: partition: msdos: provide UUIDs for partitions
init: reduce PARTUUID min length to 1 from 36
block: store partition_meta_info.uuid as a string
cciss: use check_signature()
cciss: cleanup bitops usage
drbd: use copy_highpage
drbd: if the replication link breaks during handshake, keep retrying
drbd: check return of kmalloc in receive_uuids
drbd: Broadcast sync progress no more often than once per second
drbd: don't try to clear bits once the disk has failed
git://git.kernel.org/pub/scm/linux/kernel/git/mel/linux-balancenuma
Pull Automatic NUMA Balancing bare-bones from Mel Gorman:
"There are three implementations for NUMA balancing, this tree
(balancenuma), numacore which has been developed in tip/master and
autonuma which is in aa.git.
In almost all respects balancenuma is the dumbest of the three because
its main impact is on the VM side with no attempt to be smart about
scheduling. In the interest of getting the ball rolling, it would be
desirable to see this much merged for 3.8 with the view to building
scheduler smarts on top and adapting the VM where required for 3.9.
The most recent set of comparisons available from different people are
mel: https://lkml.org/lkml/2012/12/9/108
mingo: https://lkml.org/lkml/2012/12/7/331
tglx: https://lkml.org/lkml/2012/12/10/437
srikar: https://lkml.org/lkml/2012/12/10/397
The results are a mixed bag. In my own tests, balancenuma does
reasonably well. It's dumb as rocks and does not regress against
mainline. On the other hand, Ingo's tests shows that balancenuma is
incapable of converging for this workloads driven by perf which is bad
but is potentially explained by the lack of scheduler smarts. Thomas'
results show balancenuma improves on mainline but falls far short of
numacore or autonuma. Srikar's results indicate we all suffer on a
large machine with imbalanced node sizes.
My own testing showed that recent numacore results have improved
dramatically, particularly in the last week but not universally.
We've butted heads heavily on system CPU usage and high levels of
migration even when it shows that overall performance is better.
There are also cases where it regresses. Of interest is that for
specjbb in some configurations it will regress for lower numbers of
warehouses and show gains for higher numbers which is not reported by
the tool by default and sometimes missed in treports. Recently I
reported for numacore that the JVM was crashing with
NullPointerExceptions but currently it's unclear what the source of
this problem is. Initially I thought it was in how numacore batch
handles PTEs but I'm no longer think this is the case. It's possible
numacore is just able to trigger it due to higher rates of migration.
These reports were quite late in the cycle so I/we would like to start
with this tree as it contains much of the code we can agree on and has
not changed significantly over the last 2-3 weeks."
* tag 'balancenuma-v11' of git://git.kernel.org/pub/scm/linux/kernel/git/mel/linux-balancenuma: (50 commits)
mm/rmap, migration: Make rmap_walk_anon() and try_to_unmap_anon() more scalable
mm/rmap: Convert the struct anon_vma::mutex to an rwsem
mm: migrate: Account a transhuge page properly when rate limiting
mm: numa: Account for failed allocations and isolations as migration failures
mm: numa: Add THP migration for the NUMA working set scanning fault case build fix
mm: numa: Add THP migration for the NUMA working set scanning fault case.
mm: sched: numa: Delay PTE scanning until a task is scheduled on a new node
mm: sched: numa: Control enabling and disabling of NUMA balancing if !SCHED_DEBUG
mm: sched: Adapt the scanning rate if a NUMA hinting fault does not migrate
mm: numa: Use a two-stage filter to restrict pages being migrated for unlikely task<->node relationships
mm: numa: migrate: Set last_nid on newly allocated page
mm: numa: split_huge_page: Transfer last_nid on tail page
mm: numa: Introduce last_nid to the page frame
sched: numa: Slowly increase the scanning period as NUMA faults are handled
mm: numa: Rate limit setting of pte_numa if node is saturated
mm: numa: Rate limit the amount of memory that is migrated between nodes
mm: numa: Structures for Migrate On Fault per NUMA migration rate limiting
mm: numa: Migrate pages handled during a pmd_numa hinting fault
mm: numa: Migrate on reference policy
This reverts commit bd52276fa1d4 ("x86-64/efi: Use EFI to deal with
platform wall clock (again)"), and the two supporting commits:
da5a108d05b4: "x86/kernel: remove tboot 1:1 page table creation code"
185034e72d59: "x86, efi: 1:1 pagetable mapping for virtual EFI calls")
as they all depend semantically on commit 53b87cf088e2 ("x86, mm:
Include the entire kernel memory map in trampoline_pgd") that got
reverted earlier due to the problems it caused.
This was pointed out by Yinghai Lu, and verified by me on my Macbook Air
that uses EFI.
Pointed-out-by: Yinghai Lu <yinghai@kernel.org>
Pull x86 EFI update from Peter Anvin:
"EFI tree, from Matt Fleming. Most of the patches are the new efivarfs
filesystem by Matt Garrett & co. The balance are support for EFI
wallclock in the absence of a hardware-specific driver, and various
fixes and cleanups."
* 'core-efi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (24 commits)
efivarfs: Make efivarfs_fill_super() static
x86, efi: Check table header length in efi_bgrt_init()
efivarfs: Use query_variable_info() to limit kmalloc()
efivarfs: Fix return value of efivarfs_file_write()
efivarfs: Return a consistent error when efivarfs_get_inode() fails
efivarfs: Make 'datasize' unsigned long
efivarfs: Add unique magic number
efivarfs: Replace magic number with sizeof(attributes)
efivarfs: Return an error if we fail to read a variable
efi: Clarify GUID length calculations
efivarfs: Implement exclusive access for {get,set}_variable
efivarfs: efivarfs_fill_super() ensure we clean up correctly on error
efivarfs: efivarfs_fill_super() ensure we free our temporary name
efivarfs: efivarfs_fill_super() fix inode reference counts
efivarfs: efivarfs_create() ensure we drop our reference on inode on error
efivarfs: efivarfs_file_read ensure we free data in error paths
x86-64/efi: Use EFI to deal with platform wall clock (again)
x86, mm: Include the entire kernel memory map in trampoline_pgd
N_HIGH_MEMORY stands for the nodes that has normal or high memory.
N_MEMORY stands for the nodes that has any memory.
The code here need to handle with the nodes which have memory, we should
use N_MEMORY instead.
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Signed-off-by: Wen Congyang <wency@cn.fujitsu.com>
Cc: Hillf Danton <dhillf@gmail.com>
Cc: Lin Feng <linfeng@cn.fujitsu.com>
This patch adds Kconfig options and kernel parameters to allow the
enabling and disabling of automatic NUMA balancing. The existance
of such a switch was and is very important when debugging problems
related to transparent hugepages and we should have the same for
automatic NUMA placement.
Implement pte_numa and pmd_numa.
We must atomically set the numa bit and clear the present bit to
define a pte_numa or pmd_numa.
Once a pte or pmd has been set as pte_numa or pmd_numa, the next time
a thread touches a virtual address in the corresponding virtual range,
a NUMA hinting page fault will trigger. The NUMA hinting page fault
will clear the NUMA bit and set the present bit again to resolve the
page fault.
The expectation is that a NUMA hinting page fault is used as part
of a placement policy that decides if a page should remain on the
current node or migrated to a different node.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
arch/x86/kernel/ptrace.c
Pull the latest RCU tree from Paul E. McKenney:
" The major features of this series are:
1. A first version of no-callbacks CPUs. This version prohibits
offlining CPU 0, but only when enabled via CONFIG_RCU_NOCB_CPU=y.
Relaxing this constraint is in progress, but not yet ready
for prime time. These commits were posted to LKML at
https://lkml.org/lkml/2012/10/30/724, and are at branch rcu/nocb.
2. Changes to SRCU that allows statically initialized srcu_struct
structures. These commits were posted to LKML at
https://lkml.org/lkml/2012/10/30/296, and are at branch rcu/srcu.
3. Restructuring of RCU's debugfs output. These commits were posted
to LKML at https://lkml.org/lkml/2012/10/30/341, and are at
branch rcu/tracing.
4. Additional CPU-hotplug/RCU improvements, posted to LKML at
https://lkml.org/lkml/2012/10/30/327, and are at branch rcu/hotplug.
Note that the commit eliminating __stop_machine() was judged to
be too-high of risk, so is deferred to 3.9.
5. Changes to RCU's idle interface, most notably a new module
parameter that redirects normal grace-period operations to
their expedited equivalents. These were posted to LKML at
https://lkml.org/lkml/2012/10/30/739, and are at branch rcu/idle.
6. Additional diagnostics for RCU's CPU stall warning facility,
posted to LKML at https://lkml.org/lkml/2012/10/30/315, and
are at branch rcu/stall. The most notable change reduces the
default RCU CPU stall-warning time from 60 seconds to 21 seconds,
so that it once again happens sooner than the softlockup timeout.
7. Documentation updates, which were posted to LKML at
https://lkml.org/lkml/2012/10/30/280, and are at branch rcu/doc.
A couple of late-breaking changes were posted at
https://lkml.org/lkml/2012/11/16/634 and
https://lkml.org/lkml/2012/11/16/547.
8. Miscellaneous fixes, which were posted to LKML at
https://lkml.org/lkml/2012/10/30/309, along with a late-breaking
change posted at Fri, 16 Nov 2012 11:26:25 -0800 with message-ID
<20121116192625.GA447@linux.vnet.ibm.com>, but which lkml.org
seems to have missed. These are at branch rcu/fixes.
9. Finally, a fix for an lockdep-RCU splat was posted to LKML
at https://lkml.org/lkml/2012/11/7/486. This is at rcu/next. "
Create a new subsystem that probes on kernel boundaries
to keep track of the transitions between level contexts
with two basic initial contexts: user or kernel.
This is an abstraction of some RCU code that use such tracking
to implement its userspace extended quiescent state.
We need to pull this up from RCU into this new level of indirection
because this tracking is also going to be used to implement an "on
demand" generic virtual cputime accounting. A necessary step to
shutdown the tick while still accounting the cputime.
Cc: Gilad Ben-Yossef <gilad@benyossef.com>
Reviewed-by: Steven Rostedt <rostedt@goodmis.org>
[ paulmck: fix whitespace error and email address. ]
The MSDOS/MBR partition table includes a 32-bit unique ID, often referred
to as the NT disk signature. When combined with a partition number within
the table, this can form a unique ID similar in concept to EFI/GPT's
partition UUID. Constructing and recording this value in struct
partition_meta_info allows MSDOS partitions to be referred to on the
kernel command-line using the following syntax:
root=PARTUUID=0002dd75-01
Cc: Will Drewry <wad@chromium.org>
Cc: Kay Sievers <kay.sievers@vrfy.org>
Reduce the minimum length for a root=PARTUUID= parameter to be considered
valid from 36 to 1. EFI/GPT partition UUIDs are always exactly 36
characters long, hence the previous limit. However, the next patch will
support DOS/MBR UUIDs too, which have a different, shorter, format.
Instead of validating any particular length, just ensure that at least
some non-empty value was given by the user.
Also, consider a missing UUID value to be a parsing error, in the same
vein as if /PARTNROFF exists and can't be parsed. As such, make both
error cases print a message and disable rootwait. Convert to pr_err while
we're at it.
This will allow other types of UUID to be stored here, aside from true
UUIDs. This also simplifies code that uses this field, since it's usually
constructed from a, used as a, or compared to other, strings.
Note: A simplistic approach here would be to set uuid_str[36]=0 whenever a
/PARTNROFF option was found to be present. However, this modifies the
input string, and causes subsequent calls to devt_from_partuuid() not to
see the /PARTNROFF option, which causes different results. In order to
avoid misleading future maintainers, this parameter is marked const.
Assign a unique proc inode to each namespace, and use that
inode number to ensure we only allocate at most one proc
inode for every namespace in proc.
A single proc inode per namespace allows userspace to test
to see if two processes are in the same namespace.
This has been a long requested feature and only blocked because
a naive implementation would put the id in a global space and
would ultimately require having a namespace for the names of
namespaces, making migration and certain virtualization tricks
impossible.
We still don't have per superblock inode numbers for proc, which
appears necessary for application unaware checkpoint/restart and
migrations (if the application is using namespace file descriptors)
but that is now allowd by the design if it becomes important.
I have preallocated the ipc and uts initial proc inode numbers so
their structures can be statically initialized.
Instead of setting child_reaper and SIGNAL_UNKILLABLE one way
for the system init process, and another way for pid namespace
init processes test pid->nr == 1 and use the same code for both.
For the global init this results in SIGNAL_UNKILLABLE being set
much earlier in the initialization process.
This is a small cleanup and it paves the way for allowing unshare and
enter of the pid namespace as that path like our global init also will
not set CLONE_NEWPID.
klogd is woken up asynchronously from the tick in order
to do it safely.
However if printk is called when the tick is stopped, the reader
won't be woken up until the next interrupt, which might not fire
for a while. As a result, the user may miss some message.
To fix this, lets implement the printk tick using a lazy irq work.
This subsystem takes care of the timer tick state and can
fix up accordingly.
Acked-by: Steven Rostedt <rostedt@goodmis.org>
irq work can run on any arch even without IPI
support because of the hook on update_process_times().
So lets remove HAVE_IRQ_WORK because it doesn't reflect
any backend requirement.
RCU callback execution can add significant OS jitter and also can
degrade both scheduling latency and, in asymmetric multiprocessors,
energy efficiency. This commit therefore adds the ability for selected
CPUs ("rcu_nocbs=" boot parameter) to have their callbacks offloaded
to kthreads. If the "rcu_nocb_poll" boot parameter is also specified,
these kthreads will do polling, removing the need for the offloaded
CPUs to do wakeups. At least one CPU must be doing normal callback
processing: currently CPU 0 cannot be selected as a no-CBs CPU.
In addition, attempts to offline the last normal-CBs CPU will fail.
This feature was inspired by Jim Houston's and Joe Korty's JRCU, and
this commit includes fixes to problems located by Fengguang Wu's
kbuild test robot.
[ paulmck: Added gfp.h include file as suggested by Fengguang Wu. ]
Use kuid_t and kgid_t in struct fuse_conn and struct fuse_mount_data.
The connection between between a fuse filesystem and a fuse daemon is
established when a fuse filesystem is mounted and provided with a file
descriptor the fuse daemon created by opening /dev/fuse.
For now restrict the communication of uids and gids between the fuse
filesystem and the fuse daemon to the initial user namespace. Enforce
this by verifying the file descriptor passed to the mount of fuse was
opened in the initial user namespace. Ensuring the mount happens in
the initial user namespace is not necessary as mounts from non-initial
user namespaces are not yet allowed.
In fuse_req_init_context convert the currrent fsuid and fsgid into the
initial user namespace for the request that will be sent to the fuse
daemon.
In fuse_fill_attr convert the uid and gid passed from the fuse daemon
from the initial user namespace into kuids and kgids.
In iattr_to_fattr called from fuse_setattr convert kuids and kgids
into the uids and gids in the initial user namespace before passing
them to the fuse filesystem.
In fuse_change_attributes_common called from fuse_dentry_revalidate,
fuse_permission, fuse_geattr, and fuse_setattr, and fuse_iget convert
the uid and gid from the fuse daemon into a kuid and a kgid to store
on the fuse inode.
By default fuse mounts are restricted to task whose uid, suid, and
euid matches the fuse user_id and whose gid, sgid, and egid matches
the fuse group id. Convert the user_id and group_id mount options
into kuids and kgids at mount time, and use uid_eq and gid_eq to
compare the in fuse_allow_task.
Cc: Miklos Szeredi <miklos@szeredi.hu>
