path: root/init
2007-05-19init/main: use __init_refok to fix section mismatchSam Ravnborg
Kill a special case in modpost by introducing the __init_refok marker. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-17SLUB: Remove depends on EXPERIMENTAL and !ARCH_USES_SLAB_PAGE_STRUCTChristoph Lameter
No arch sets ARCH_USES_SLAB_PAGE_STRUCT anymore. Remove the experimental dependency as well since we want to have it as a real alternative to SLAB. It all comes down to killing a single line from init/Kconfig. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-17slob: implement RCU freeingNick Piggin
The SLOB allocator should implement SLAB_DESTROY_BY_RCU correctly, because even on UP, RCU freeing semantics are not equivalent to simply freeing immediately. This also allows SLOB to be used on SMP. Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11signal/timer/event: eventfd coreDavide Libenzi
This is a very simple and light file descriptor, that can be used as event wait/dispatch by userspace (both wait and dispatch) and by the kernel (dispatch only). It can be used instead of pipe(2) in all cases where those would simply be used to signal events. Their kernel overhead is much lower than pipes, and they do not consume two fds. When used in the kernel, it can offer an fd-bridge to enable, for example, functionalities like KAIO or syslets/threadlets to signal to an fd the completion of certain operations. But more in general, an eventfd can be used by the kernel to signal readiness, in a POSIX poll/select way, of interfaces that would otherwise be incompatible with it. The API is: int eventfd(unsigned int count); The eventfd API accepts an initial "count" parameter, and returns an eventfd fd. It supports poll(2) (POLLIN, POLLOUT, POLLERR), read(2) and write(2). The POLLIN flag is raised when the internal counter is greater than zero. The POLLOUT flag is raised when at least a value of "1" can be written to the internal counter. The POLLERR flag is raised when an overflow in the counter value is detected. The write(2) operation can never overflow the counter, since it blocks (unless O_NONBLOCK is set, in which case -EAGAIN is returned). But the eventfd_signal() function can do it, since it's supposed to not sleep during its operation. The read(2) function reads the __u64 counter value, and reset the internal value to zero. If the value read is equal to (__u64) -1, an overflow happened on the internal counter (due to 2^64 eventfd_signal() posts that has never been retired - unlickely, but possible). The write(2) call writes an __u64 count value, and adds it to the current counter. The eventfd fd supports O_NONBLOCK also. On the kernel side, we have: struct file *eventfd_fget(int fd); int eventfd_signal(struct file *file, unsigned int n); The eventfd_fget() should be called to get a struct file* from an eventfd fd (this is an fget() + check of f_op being an eventfd fops pointer). The kernel can then call eventfd_signal() every time it wants to post an event to userspace. The eventfd_signal() function can be called from any context. An eventfd() simple test and bench is available here: http://www.xmailserver.org/eventfd-bench.c This is the eventfd-based version of pipetest-4 (pipe(2) based): http://www.xmailserver.org/pipetest-4.c Not that performance matters much in the eventfd case, but eventfd-bench shows almost as double as performance than pipetest-4. [akpm@linux-foundation.org: fix i386 build] [akpm@linux-foundation.org: add sys_eventfd to sys_ni.c] Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11signal/timer/event: timerfd coreDavide Libenzi
This patch introduces a new system call for timers events delivered though file descriptors. This allows timer event to be used with standard POSIX poll(2), select(2) and read(2). As a consequence of supporting the Linux f_op->poll subsystem, they can be used with epoll(2) too. The system call is defined as: int timerfd(int ufd, int clockid, int flags, const struct itimerspec *utmr); The "ufd" parameter allows for re-use (re-programming) of an existing timerfd w/out going through the close/open cycle (same as signalfd). If "ufd" is -1, s new file descriptor will be created, otherwise the existing "ufd" will be re-programmed. The "clockid" parameter is either CLOCK_MONOTONIC or CLOCK_REALTIME. The time specified in the "utmr->it_value" parameter is the expiry time for the timer. If the TFD_TIMER_ABSTIME flag is set in "flags", this is an absolute time, otherwise it's a relative time. If the time specified in the "utmr->it_interval" is not zero (.tv_sec == 0, tv_nsec == 0), this is the period at which the following ticks should be generated. The "utmr->it_interval" should be set to zero if only one tick is requested. Setting the "utmr->it_value" to zero will disable the timer, or will create a timerfd without the timer enabled. The function returns the new (or same, in case "ufd" is a valid timerfd descriptor) file, or -1 in case of error. As stated before, the timerfd file descriptor supports poll(2), select(2) and epoll(2). When a timer event happened on the timerfd, a POLLIN mask will be returned. The read(2) call can be used, and it will return a u32 variable holding the number of "ticks" that happened on the interface since the last call to read(2). The read(2) call supportes the O_NONBLOCK flag too, and EAGAIN will be returned if no ticks happened. A quick test program, shows timerfd working correctly on my amd64 box: http://www.xmailserver.org/timerfd-test.c [akpm@linux-foundation.org: add sys_timerfd to sys_ni.c] Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11signal/timer/event: signalfd coreDavide Libenzi
This patch series implements the new signalfd() system call. I took part of the original Linus code (and you know how badly it can be broken :), and I added even more breakage ;) Signals are fetched from the same signal queue used by the process, so signalfd will compete with standard kernel delivery in dequeue_signal(). If you want to reliably fetch signals on the signalfd file, you need to block them with sigprocmask(SIG_BLOCK). This seems to be working fine on my Dual Opteron machine. I made a quick test program for it: http://www.xmailserver.org/signafd-test.c The signalfd() system call implements signal delivery into a file descriptor receiver. The signalfd file descriptor if created with the following API: int signalfd(int ufd, const sigset_t *mask, size_t masksize); The "ufd" parameter allows to change an existing signalfd sigmask, w/out going to close/create cycle (Linus idea). Use "ufd" == -1 if you want a brand new signalfd file. The "mask" allows to specify the signal mask of signals that we are interested in. The "masksize" parameter is the size of "mask". The signalfd fd supports the poll(2) and read(2) system calls. The poll(2) will return POLLIN when signals are available to be dequeued. As a direct consequence of supporting the Linux poll subsystem, the signalfd fd can use used together with epoll(2) too. The read(2) system call will return a "struct signalfd_siginfo" structure in the userspace supplied buffer. The return value is the number of bytes copied in the supplied buffer, or -1 in case of error. The read(2) call can also return 0, in case the sighand structure to which the signalfd was attached, has been orphaned. The O_NONBLOCK flag is also supported, and read(2) will return -EAGAIN in case no signal is available. If the size of the buffer passed to read(2) is lower than sizeof(struct signalfd_siginfo), -EINVAL is returned. A read from the signalfd can also return -ERESTARTSYS in case a signal hits the process. The format of the struct signalfd_siginfo is, and the valid fields depends of the (->code & __SI_MASK) value, in the same way a struct siginfo would: struct signalfd_siginfo { __u32 signo; /* si_signo */ __s32 err; /* si_errno */ __s32 code; /* si_code */ __u32 pid; /* si_pid */ __u32 uid; /* si_uid */ __s32 fd; /* si_fd */ __u32 tid; /* si_fd */ __u32 band; /* si_band */ __u32 overrun; /* si_overrun */ __u32 trapno; /* si_trapno */ __s32 status; /* si_status */ __s32 svint; /* si_int */ __u64 svptr; /* si_ptr */ __u64 utime; /* si_utime */ __u64 stime; /* si_stime */ __u64 addr; /* si_addr */ }; [akpm@linux-foundation.org: fix signalfd_copyinfo() on i386] Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11signal/timer/event fds: anonymous inode sourceDavide Libenzi
This patch add an anonymous inode source, to be used for files that need and inode only in order to create a file*. We do not care of having an inode for each file, and we do not even care of having different names in the associated dentries (dentry names will be same for classes of file*). This allow code reuse, and will be used by epoll, signalfd and timerfd (and whatever else there'll be). Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11Explicitly set pgid and sid of init processSukadev Bhattiprolu
Explicitly set pgid and sid of init process to 1. Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Serge Hallyn <serue@us.ibm.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: <containers@lists.osdl.org> Acked-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-10SLUB: SLUB_DEBUG must depend on SLUBChristoph Lameter
Otherwise people get asked about SLUB_DEBUG even if they have another slab allocator enabled. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: (25 commits) sound: convert "sound" subdirectory to UTF-8 MAINTAINERS: Add cxacru website/mailing list include files: convert "include" subdirectory to UTF-8 general: convert "kernel" subdirectory to UTF-8 documentation: convert the Documentation directory to UTF-8 Convert the toplevel files CREDITS and MAINTAINERS to UTF-8. remove broken URLs from net drivers' output Magic number prefix consistency change to Documentation/magic-number.txt trivial: s/i_sem /i_mutex/ fix file specification in comments drivers/base/platform.c: fix small typo in doc misc doc and kconfig typos Remove obsolete fat_cvf help text Fix occurrences of "the the " Fix minor typoes in kernel/module.c Kconfig: Remove reference to external mqueue library Kconfig: A couple of grammatical fixes in arch/i386/Kconfig Correct comments in genrtc.c to refer to correct /proc file. Fix more "deprecated" spellos. Fix "deprecated" typoes. ... Fix trivial comment conflict in kernel/relay.c.
2007-05-09kthread: don't depend on work queuesEric W. Biederman
Currently there is a circular reference between work queue initialization and kthread initialization. This prevents the kthread infrastructure from initializing until after work queues have been initialized. We want the properties of tasks created with kthread_create to be as close as possible to the init_task and to not be contaminated by user processes. The later we start our kthreadd that creates these tasks the harder it is to avoid contamination from user processes and the more of a mess we have to clean up because the defaults have changed on us. So this patch modifies the kthread support to not use work queues but to instead use a simple list of structures, and to have kthreadd start from init_task immediately after our kernel thread that execs /sbin/init. By being a true child of init_task we only have to change those process settings that we want to have different from init_task, such as our process name, the cpus that are allowed, blocking all signals and setting SIGCHLD to SIG_IGN so that all of our children are reaped automatically. By being a true child of init_task we also naturally get our ppid set to 0 and do not wind up as a child of PID == 1. Ensuring that tasks generated by kthread_create will not slow down the functioning of the wait family of functions. [akpm@linux-foundation.org: use interruptible sleeps] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09Display all possible partitions when the root filesystem failed to mountDave Gilbert
Display all possible partitions when the root filesystem is not mounted. This helps to track spell'o's and missing drivers. Updated to work with newer kernels. Example output: VFS: Cannot open root device "foobar" or unknown-block(0,0) Please append a correct "root=" boot option; here are the available partitions: 0800 8388608 sda driver: sd 0801 192748 sda1 0802 8193150 sda2 0810 4194304 sdb driver: sd Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) [akpm@linux-foundation.org: cleanups, fix printk warnings] Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Cc: Dave Gilbert <linux@treblig.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09Fix spellings of slab allocator section in init/KconfigChristoph Lameter
Fix some of the spelling issues. Fix sentences. Discourage SLOB use since SLUB can pack objects denser. Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09SLUB: add CONFIG_SLUB_DEBUGChristoph Lameter
CONFIG_SLUB_DEBUG can be used to switch off the debugging and sysfs components of SLUB. Thus SLUB will be able to replace SLOB. SLUB can arrange objects in a denser way than SLOB and the code size should be minimal without debugging and sysfs support. Note that CONFIG_SLUB_DEBUG is materially different from CONFIG_SLAB_DEBUG. CONFIG_SLAB_DEBUG is used to enable slab debugging in SLAB. SLUB enables debugging via a boot parameter. SLUB debug code should always be present. CONFIG_SLUB_DEBUG can be modified in the embedded config section. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09Kconfig: Remove reference to external mqueue libraryRobert P. J. Day
Remove the reference to an external mqueue library since that was merged into glibc in 2004. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-09Fix trivial typos in Kconfig* filesDavid Sterba
Fix several typos in help text in Kconfig* files. Signed-off-by: David Sterba <dave@jikos.cz> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-08Move LOG_BUF_SHIFT to a more sensible placeAlistair John Strachan
Several people have observed that perhaps LOG_BUF_SHIFT should be in a more obvious place than under DEBUG_KERNEL. Under some circumstances (such as the PARISC architecture), DEBUG_KERNEL can increase kernel size, which is an undesirable trade off for something as trivial as increasing the kernel log buffer size. Instead, move LOG_BUF_SHIFT into "General Setup", so that people are more likely to be able to change it such a circumstance that the default buffer size is insufficient. Signed-off-by: Alistair John Strachan <s0348365@sms.ed.ac.uk> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08enhance initcall_debug, measure latencyIngo Molnar
enhance the initcall_debug boot option: - measure the time the initcall took to execute and report it in units of milliseconds. - show the return code of initcalls (useful to see failures and to make sure that an initcall hung) [akpm@linux-foundation.org: fix printk warning] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08init/do_mounts.c: proper prepare_namespace() prototypeAdrian Bunk
Add a proper protype for prepare_namespace() in include/linux/init.h. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07freezer: remove PF_NOFREEZE from handle_initrdRafael J. Wysocki
Make handle_initrd() call try_to_freeze() in a suitable place instead of setting PF_NOFREEZE for the current task. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Nigel Cunningham <nigel@nigel.suspend2.net> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07blackfin architectureBryan Wu
This adds support for the Analog Devices Blackfin processor architecture, and currently supports the BF533, BF532, BF531, BF537, BF536, BF534, and BF561 (Dual Core) devices, with a variety of development platforms including those avaliable from Analog Devices (BF533-EZKit, BF533-STAMP, BF537-STAMP, BF561-EZKIT), and Bluetechnix! Tinyboards. The Blackfin architecture was jointly developed by Intel and Analog Devices Inc. (ADI) as the Micro Signal Architecture (MSA) core and introduced it in December of 2000. Since then ADI has put this core into its Blackfin processor family of devices. The Blackfin core has the advantages of a clean, orthogonal,RISC-like microprocessor instruction set. It combines a dual-MAC (Multiply/Accumulate), state-of-the-art signal processing engine and single-instruction, multiple-data (SIMD) multimedia capabilities into a single instruction-set architecture. The Blackfin architecture, including the instruction set, is described by the ADSP-BF53x/BF56x Blackfin Processor Programming Reference http://blackfin.uclinux.org/gf/download/frsrelease/29/2549/Blackfin_PRM.pdf The Blackfin processor is already supported by major releases of gcc, and there are binary and source rpms/tarballs for many architectures at: http://blackfin.uclinux.org/gf/project/toolchain/frs There is complete documentation, including "getting started" guides available at: http://docs.blackfin.uclinux.org/ which provides links to the sources and patches you will need in order to set up a cross-compiling environment for bfin-linux-uclibc This patch, as well as the other patches (toolchain, distribution, uClibc) are actively supported by Analog Devices Inc, at: http://blackfin.uclinux.org/ We have tested this on LTP, and our test plan (including pass/fails) can be found at: http://docs.blackfin.uclinux.org/doku.php?id=testing_the_linux_kernel [m.kozlowski@tuxland.pl: balance parenthesis in blackfin header files] Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Aubrey Li <aubrey.li@analog.com> Signed-off-by: Jie Zhang <jie.zhang@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07SLUB coreChristoph Lameter
This is a new slab allocator which was motivated by the complexity of the existing code in mm/slab.c. It attempts to address a variety of concerns with the existing implementation. A. Management of object queues A particular concern was the complex management of the numerous object queues in SLAB. SLUB has no such queues. Instead we dedicate a slab for each allocating CPU and use objects from a slab directly instead of queueing them up. B. Storage overhead of object queues SLAB Object queues exist per node, per CPU. The alien cache queue even has a queue array that contain a queue for each processor on each node. For very large systems the number of queues and the number of objects that may be caught in those queues grows exponentially. On our systems with 1k nodes / processors we have several gigabytes just tied up for storing references to objects for those queues This does not include the objects that could be on those queues. One fears that the whole memory of the machine could one day be consumed by those queues. C. SLAB meta data overhead SLAB has overhead at the beginning of each slab. This means that data cannot be naturally aligned at the beginning of a slab block. SLUB keeps all meta data in the corresponding page_struct. Objects can be naturally aligned in the slab. F.e. a 128 byte object will be aligned at 128 byte boundaries and can fit tightly into a 4k page with no bytes left over. SLAB cannot do this. D. SLAB has a complex cache reaper SLUB does not need a cache reaper for UP systems. On SMP systems the per CPU slab may be pushed back into partial list but that operation is simple and does not require an iteration over a list of objects. SLAB expires per CPU, shared and alien object queues during cache reaping which may cause strange hold offs. E. SLAB has complex NUMA policy layer support SLUB pushes NUMA policy handling into the page allocator. This means that allocation is coarser (SLUB does interleave on a page level) but that situation was also present before 2.6.13. SLABs application of policies to individual slab objects allocated in SLAB is certainly a performance concern due to the frequent references to memory policies which may lead a sequence of objects to come from one node after another. SLUB will get a slab full of objects from one node and then will switch to the next. F. Reduction of the size of partial slab lists SLAB has per node partial lists. This means that over time a large number of partial slabs may accumulate on those lists. These can only be reused if allocator occur on specific nodes. SLUB has a global pool of partial slabs and will consume slabs from that pool to decrease fragmentation. G. Tunables SLAB has sophisticated tuning abilities for each slab cache. One can manipulate the queue sizes in detail. However, filling the queues still requires the uses of the spin lock to check out slabs. SLUB has a global parameter (min_slab_order) for tuning. Increasing the minimum slab order can decrease the locking overhead. The bigger the slab order the less motions of pages between per CPU and partial lists occur and the better SLUB will be scaling. G. Slab merging We often have slab caches with similar parameters. SLUB detects those on boot up and merges them into the corresponding general caches. This leads to more effective memory use. About 50% of all caches can be eliminated through slab merging. This will also decrease slab fragmentation because partial allocated slabs can be filled up again. Slab merging can be switched off by specifying slub_nomerge on boot up. Note that merging can expose heretofore unknown bugs in the kernel because corrupted objects may now be placed differently and corrupt differing neighboring objects. Enable sanity checks to find those. H. Diagnostics The current slab diagnostics are difficult to use and require a recompilation of the kernel. SLUB contains debugging code that is always available (but is kept out of the hot code paths). SLUB diagnostics can be enabled via the "slab_debug" option. Parameters can be specified to select a single or a group of slab caches for diagnostics. This means that the system is running with the usual performance and it is much more likely that race conditions can be reproduced. I. Resiliency If basic sanity checks are on then SLUB is capable of detecting common error conditions and recover as best as possible to allow the system to continue. J. Tracing Tracing can be enabled via the slab_debug=T,<slabcache> option during boot. SLUB will then protocol all actions on that slabcache and dump the object contents on free. K. On demand DMA cache creation. Generally DMA caches are not needed. If a kmalloc is used with __GFP_DMA then just create this single slabcache that is needed. For systems that have no ZONE_DMA requirement the support is completely eliminated. L. Performance increase Some benchmarks have shown speed improvements on kernbench in the range of 5-10%. The locking overhead of slub is based on the underlying base allocation size. If we can reliably allocate larger order pages then it is possible to increase slub performance much further. The anti-fragmentation patches may enable further performance increases. Tested on: i386 UP + SMP, x86_64 UP + SMP + NUMA emulation, IA64 NUMA + Simulator SLUB Boot options slub_nomerge Disable merging of slabs slub_min_order=x Require a minimum order for slab caches. This increases the managed chunk size and therefore reduces meta data and locking overhead. slub_min_objects=x Mininum objects per slab. Default is 8. slub_max_order=x Avoid generating slabs larger than order specified. slub_debug Enable all diagnostics for all caches slub_debug=<options> Enable selective options for all caches slub_debug=<o>,<cache> Enable selective options for a certain set of caches Available Debug options F Double Free checking, sanity and resiliency R Red zoning P Object / padding poisoning U Track last free / alloc T Trace all allocs / frees (only use for individual slabs). To use SLUB: Apply this patch and then select SLUB as the default slab allocator. [hugh@veritas.com: fix an oops-causing locking error] [akpm@linux-foundation.org: various stupid cleanups and small fixes] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07Safer nr_node_ids and nr_node_ids determination and initial valuesChristoph Lameter
The nr_cpu_ids value is currently only calculated in smp_init. However, it may be needed before (SLUB needs it on kmem_cache_init!) and other kernel components may also want to allocate dynamically sized per cpu array before smp_init. So move the determination of possible cpus into sched_init() where we already loop over all possible cpus early in boot. Also initialize both nr_node_ids and nr_cpu_ids with the highest value they could take. If we have accidental users before these values are determined then the current valud of 0 may cause too small per cpu and per node arrays to be allocated. If it is set to the maximum possible then we only waste some memory for early boot users. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild: (38 commits) kconfig: fix mconf segmentation fault kbuild: enable use of code from a different dir kconfig: error out if recursive dependencies are found kbuild: scripts/basic/fixdep segfault on pathological string-o-death kconfig: correct minor typo in Kconfig warning message. kconfig: fix path to modules.txt in Kconfig help usr/Kconfig: fix typo kernel-doc: alphabetically-sorted entries in index.html of 'htmldocs' kbuild: be more explicit on missing .config file kbuild: clarify the creation of the LOCALVERSION_AUTO string. kbuild: propagate errors from find in scripts/gen_initramfs_list.sh kconfig: refer to qt3 if we cannot find qt libraries kbuild: handle compressed cpio initramfs-es kbuild: ignore section mismatch warning for references from .paravirtprobe to .init.text kbuild: remove stale comment in modpost.c kbuild/mkuboot.sh: allow spaces in CROSS_COMPILE kbuild: fix make mrproper for Documentation/DocBook/man kbuild: remove kconfig binaries during make mrproper kconfig/menuconfig: do not hardcode '.config' kbuild: override build timestamp & version ...
2007-05-02kbuild: clarify the creation of the LOCALVERSION_AUTO string.Robert P. J. Day
Clarify the creation of the LOCALVERSION_AUTO string during kernel configuration, and fix a couple typoes while we're there. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-02kbuild: whitelist section mismatch in init/main.cSam Ravnborg
In init/main.c we have a reference from rest_init() to .init.text which is intentional. Rename the function 'init' to 'kernel_init' to make it a kernel wide unique symbol and whitelist the reference. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-02[PATCH] x86: Allow percpu variables to be page-alignedJeremy Fitzhardinge
Let's allow page-alignment in general for per-cpu data (wanted by Xen, and Ingo suggested KVM as well). Because larger alignments can use more room, we increase the max per-cpu memory to 64k rather than 32k: it's getting a little tight. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Andi Kleen <ak@suse.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2007-03-06[PATCH] initramfs should not depend on CONFIG_BLOCKDimitri Gorokhovik
initramfs ended up depending on BLOCK: INITRAMFS_SOURCE <-- BLK_DEV_INITRD <-- BLOCK This inhibits use of customized-initramfs-over-ramfs without block layer (ramfs would still be enabled), useful in embedded applications. Move BLK_DEV_INITRD out of 'drivers/block/Kconfig' and into 'init/Kconfig', make it unconditional. Signed-off-by: Dimitri Gorokhovik <dimitri.gorokhovik@free.fr> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-20[PATCH] Convert highest_possible_processor_id to nr_cpu_idsChristoph Lameter
We frequently need the maximum number of possible processors in order to allocate arrays for all processors. So far this was done using highest_possible_processor_id(). However, we do need the number of processors not the highest id. Moreover the number was so far dynamically calculated on each invokation. The number of possible processors does not change when the system is running. We can therefore calculate that number once. Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Frederik Deweerdt <frederik.deweerdt@gmail.com> Cc: Neil Brown <neilb@suse.de> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-19[PATCH] Declare init_irq_proc before we use it.Andrew Morton
powerpc gets: init/main.c: In function `do_basic_setup': init/main.c:714: warning: implicit declaration of function `init_irq_proc' but we cannot include linux/irq.h in generic code. Fix it by moving the declaration into linux/interrupt.h instead. And make sure all code that defines init_irq_proc() is including linux/interrupt.h. And nuke an ifdef-in-C Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] tick-management: core functionalityThomas Gleixner
With Ingo Molnar <mingo@elte.hu> The tick-management code is the first user of the clockevents layer. It takes clock event devices from the clock events core and uses them to provide the periodic tick. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14Merge branch 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6Linus Torvalds
* 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6: (94 commits) [PATCH] x86-64: Remove mk_pte_phys() [PATCH] i386: Fix broken CONFIG_COMPAT_VDSO on i386 [PATCH] i386: fix 32-bit ioctls on x64_32 [PATCH] x86: Unify pcspeaker platform device code between i386/x86-64 [PATCH] i386: Remove extern declaration from mm/discontig.c, put in header. [PATCH] i386: Rename cpu_gdt_descr and remove extern declaration from smpboot.c [PATCH] i386: Move mce_disabled to asm/mce.h [PATCH] i386: paravirt unhandled fallthrough [PATCH] x86_64: Wire up compat epoll_pwait [PATCH] x86: Don't require the vDSO for handling a.out signals [PATCH] i386: Fix Cyrix MediaGX detection [PATCH] i386: Fix warning in cpu initialization [PATCH] i386: Fix warning in microcode.c [PATCH] x86: Enable NMI watchdog for AMD Family 0x10 CPUs [PATCH] x86: Add new CPUID bits for AMD Family 10 CPUs in /proc/cpuinfo [PATCH] i386: Remove fastcall in paravirt.[ch] [PATCH] x86-64: Fix wrong gcc check in bitops.h [PATCH] x86-64: survive having no irq mapping for a vector [PATCH] i386: geode configuration fixes [PATCH] i386: add option to show more code in oops reports ...
2007-02-14[PATCH] sysctl: reimplement the sysctl proc supportEric W. Biederman
With this change the sysctl inodes can be cached and nothing needs to be done when removing a sysctl table. For a cost of 2K code we will save about 4K of static tables (when we remove de from ctl_table) and 70K in proc_dir_entries that we will not allocate, or about half that on a 32bit arch. The speed feels about the same, even though we can now cache the sysctl dentries :( We get the core advantage that we don't need to have a 1 to 1 mapping between ctl table entries and proc files. Making it possible to have /proc/sys vary depending on the namespace you are in. The currently merged namespaces don't have an issue here but the network namespace under /proc/sys/net needs to have different directories depending on which network adapters are visible. By simply being a cache different directories being visible depending on who you are is trivial to implement. [akpm@osdl.org: fix uninitialised var] [akpm@osdl.org: fix ARM build] [bunk@stusta.de: make things static] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: move SYSV IPC sysctls to their own fileEric W. Biederman
This is just a simple cleanup to keep kernel/sysctl.c from getting to crowded with special cases, and by keeping all of the ipc logic to together it makes the code a little more readable. [gcoady.lk@gmail.com: build fix] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Serge E. Hallyn <serue@us.ibm.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Kirill Korotaev <dev@sw.ru> Signed-off-by: Grant Coady <gcoady.lk@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: move init_irq_proc into init/main where it belongsEric W. Biederman
Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-13[PATCH] generic: Break init() in two parts to avoid MODPOST warningsVivek Goyal
o init() is a non __init function in .text section but it calls many functions which are in .init.text section. Hence MODPOST generates lots of cross reference warnings on i386 if compiled with CONFIG_RELOCATABLE=y WARNING: vmlinux - Section mismatch: reference to .init.text:smp_prepare_cpus from .text between 'init' (at offset 0xc0101049) and 'rest_init' WARNING: vmlinux - Section mismatch: reference to .init.text:migration_init from .text between 'init' (at offset 0xc010104e) and 'rest_init' WARNING: vmlinux - Section mismatch: reference to .init.text:spawn_ksoftirqd from .text between 'init' (at offset 0xc0101053) and 'rest_init' o This patch breaks down init() in two parts. One part which can go in .init.text section and can be freed and other part which has to be non __init(init_post()). Now init() calls init_post() and init_post() does not call any functions present in .init sections. Hence getting rid of warnings. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Andi Kleen <ak@suse.de>
2007-02-12[PATCH] Dynamic kernel command-line: commonAlon Bar-Lev
Current implementation stores a static command-line buffer allocated to COMMAND_LINE_SIZE size. Most architectures stores two copies of this buffer, one for future reference and one for parameter parsing. Current kernel command-line size for most architecture is much too small for module parameters, video settings, initramfs paramters and much more. The problem is that setting COMMAND_LINE_SIZE to a grater value, allocates static buffers. In order to allow a greater command-line size, these buffers should be dynamically allocated or marked as init disposable buffers, so unused memory can be released. This patch renames the static saved_command_line variable into boot_command_line adding __initdata attribute, so that it can be disposed after initialization. This rename is required so applications that use saved_command_line will not be affected by this change. It reintroduces saved_command_line as dynamically allocated buffer to match the data in boot_command_line. It also mark secondary command-line buffer as __initdata, and copies it to dynamically allocated static_command_line buffer components may hold reference to it after initialization. This patch is for linux-2.6.20-rc4-mm1 and is divided to target each architecture. I could not check this in any architecture so please forgive me if I got it wrong. The per-architecture modification is very simple, use boot_command_line in place of saved_command_line. The common code is the change into dynamic command-line. This patch: 1. Rename saved_command_line into boot_command_line, mark as init disposable. 2. Add dynamic allocated saved_command_line. 3. Add dynamic allocated static_command_line. 4. During startup copy: boot_command_line into saved_command_line. arch command_line into static_command_line. 5. Parse static_command_line and not arch command_line, so arch command_line may be freed. Signed-off-by: Alon Bar-Lev <alon.barlev@gmail.com> Cc: Andi Kleen <ak@muc.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Chris Zankel <chris@zankel.net> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Move TASK_XACCT, TASK_IO_ACCOUNTING up in menusAlexey Dobriyan
Since they depends on TASKSTATS, it would be nice to move them closer to another options depending on TASKSTATS. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Remove final reference to superfluous smp_commence()Robert P. J. Day
Remove the last (and commented out) invocation of the obsolete smp_commence() call. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Acked-by: Ingo Molnar <mingo@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] disable init/initramfs.cJean-Paul Saman
The file init/initramfs.c is always compiled and linked in the kernel vmlinux even when BLK_DEV_RAM and BLK_DEV_INITRD are disabled and the system isn't using any form of an initramfs or initrd. In this situation the code is only used to unpack a (static) default initial rootfilesystem. The current init/initramfs.c code. usr/initramfs_data.o compiles to a size of ~15 kbytes. Disabling BLK_DEV_RAM and BLK_DEV_INTRD shrinks the kernel code size with ~60 Kbytes. This patch avoids compiling in the code and data for initramfs support if CONFIG_BLK_DEV_INITRD is not defined. Instead of the initramfs code and data it uses a small routine in init/noinitramfs.c to setup an initial static default environment for mounting a rootfilesystem later on in the kernel initialisation process. The new code is: 164 bytes of size. The patch is separated in two parts: 1) doesn't compile initramfs code when CONFIG_BLK_DEV_INITRD is not set 2) changing all plaforms vmlinux.lds.S files to not reserve an area of PAGE_SIZE when CONFIG_BLK_DEV_INITRD is not set. [deweerdt@free.fr: warning fix] Signed-off-by: Jean-Paul Saman <jean-paul.saman@nxp.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Frederik Deweerdt <frederik.deweerdt@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Add retain_initrd boot optionMichael Neuling
Add retain_initrd option to control freeing of initrd memory after extraction. By default, free memory as previously. The first boot will need to hold a copy of the in memory fs for the second boot. This image can be large (much larger than the kernel), hence we can save time when the memory loader is slow. Also, it reduces the memory footprint while extracting the first boot since you don't need another copy of the fs. Signed-off-by: Michael Neuling <mikey@neuling.org> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-11Don't put "linux_banner" in the .init sectionLinus Torvalds
It might save a few bytes after bootup, but it causes the string to be linked in at the end of the final vmlinux image, which defeats the whole point of doing all this, namely allowing some broken user-space binaries to search for the kernel version string in the kernel binary. So just remove the __init specifier. Cc: Olaf Hering <olaf@aepfle.de> Cc: Jean Delvare <khali@linux-fr.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Andrey Borzenkov <arvidjaar@mail.ru> Cc: Andrew Morton <akpm@osdl.org> Acked-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2007-01-11[PATCH] i386: Convert some functions to __init to avoid MODPOST warningsVivek Goyal
o Some functions which should have been in init sections as they are called only once. Put them in init sections. Otherwise MODPOST generates warning as these functions are placed in .text and they end up accessing something in init sections. WARNING: vmlinux - Section mismatch: reference to .init.text:migration_init from .text between 'do_pre_smp_initcalls' (at offset 0xc01000d1) and 'run_init_process' Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Andi Kleen <ak@suse.de>
2007-01-10[PATCH] fix linux banner format stringRoman Zippel
Revert previous attempts at messing with the linux banner string and simply use a separate format string for proc. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Acked-by: Olaf Hering <olaf@aepfle.de> Acked-by: Jean Delvare <khali@linux-fr.org> Cc: Andrey Borzenkov <arvidjaar@mail.ru> Cc: Andrew Morton <akpm@osdl.org> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Herbert Poetzl <herbert@13thfloor.at> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2007-01-05[PATCH] start_kernel: test if irq's got enabled early, barf, and disable ↵Ard van Breemen
them again The calls made by parse_parms to other initialization code might enable interrupts again way too early. Having interrupts on this early can make systems PANIC when they initialize the IRQ controllers (which happens later in the code). This patch detects that irq's are enabled again, barfs about it and disables them again as a safety net. [akpm@osdl.org: cleanups] Signed-off-by: Ard van Breemen <ard@telegraafnet.nl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-22[PATCH] build compile.h earlierAndrew Morton
compile.h is created super-late in the build. But proc_misc.c want to include it, and it's generally not sane to have a header file in include/linux be created at the end of the build: it's either not present or, worse, wrong for most of the build. So the patch arranges for compile.h to be built at the start of the build process. It also consolidates the compile.h rules with those for version.h and utsname.h, so they all get built together. I hope. My chances of having got this right are about 2%. Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-22[PATCH] handle SLOB with sparsemenYasunori Goto
This is to disallow to make SLOB with SMP or SPARSEMEM. This avoids latent troubles of SLOB with SLAB_DESTROY_BY_RCU. And fix compile error. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-22[PATCH] CONFIG_VM_EVENT_COUNTER comment decrustifyPaul Jackson
The VM event counters, enabled by CONFIG_VM_EVENT_COUNTERS, which provides VM event counters in /proc/vmstat, has become more essential to non-EMBEDDED kernel configurations than they were in the past. Comments in the code and the Kconfig configuration explanation were stale, downplaying their role excessively. Refresh those comments to correctly reflect the current role of VM event counters. Signed-off-by: Paul Jackson <pj@sgi.com> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-20Driver core: proper prototype for drivers/base/init.c:driver_init()Adrian Bunk
Add a prototype for driver_init() in include/linux/device.h. Also remove a static function of the same name in drivers/acpi/ibm_acpi.c to ibm_acpi_driver_init() to fix the namespace collision. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
