path: root/init
2014-10-09init/Kconfig: Fix HAVE_FUTEX_CMPXCHG to not break up the EXPERT menuJosh Triplett
commit 62b4d2041117f35ab2409c9f5c4b8d3dc8e59d0f upstream. commit 03b8c7b623c80af264c4c8d6111e5c6289933666 ("futex: Allow architectures to skip futex_atomic_cmpxchg_inatomic() test") added the HAVE_FUTEX_CMPXCHG symbol right below FUTEX. This placed it right in the middle of the options for the EXPERT menu. However, HAVE_FUTEX_CMPXCHG does not depend on EXPERT or FUTEX, so Kconfig stops placing items in the EXPERT menu, and displays the remaining several EXPERT items (starting with EPOLL) directly in the General Setup menu. Since both users of HAVE_FUTEX_CMPXCHG only select it "if FUTEX", make HAVE_FUTEX_CMPXCHG itself depend on FUTEX. With this change, the subsequent items display as part of the EXPERT menu again; the EMBEDDED menu now appears as the next top-level item in the General Setup menu, which makes General Setup much shorter and more usable. Signed-off-by: Josh Triplett <josh@joshtriplett.org> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-08-07x86, espfix: Make espfix64 a Kconfig option, fix UMLH. Peter Anvin
commit 197725de65477bc8509b41388157c1a2283542bb upstream. Make espfix64 a hidden Kconfig option. This fixes the x86-64 UML build which had broken due to the non-existence of init_espfix_bsp() in UML: since UML uses its own Kconfig, this option does not appear in the UML build. This also makes it possible to make support for 16-bit segments a configuration option, for the people who want to minimize the size of the kernel. Reported-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: Richard Weinberger <richard@nod.at> Link: http://lkml.kernel.org/r/1398816946-3351-1-git-send-email-hpa@linux.intel.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-08-07x86-64, espfix: Don't leak bits 31:16 of %esp returning to 16-bit stackH. Peter Anvin
commit 3891a04aafd668686239349ea58f3314ea2af86b upstream. The IRET instruction, when returning to a 16-bit segment, only restores the bottom 16 bits of the user space stack pointer. This causes some 16-bit software to break, but it also leaks kernel state to user space. We have a software workaround for that ("espfix") for the 32-bit kernel, but it relies on a nonzero stack segment base which is not available in 64-bit mode. In checkin: b3b42ac2cbae x86-64, modify_ldt: Ban 16-bit segments on 64-bit kernels we "solved" this by forbidding 16-bit segments on 64-bit kernels, with the logic that 16-bit support is crippled on 64-bit kernels anyway (no V86 support), but it turns out that people are doing stuff like running old Win16 binaries under Wine and expect it to work. This works around this by creating percpu "ministacks", each of which is mapped 2^16 times 64K apart. When we detect that the return SS is on the LDT, we copy the IRET frame to the ministack and use the relevant alias to return to userspace. The ministacks are mapped readonly, so if IRET faults we promote #GP to #DF which is an IST vector and thus has its own stack; we then do the fixup in the #DF handler. (Making #GP an IST exception would make the msr_safe functions unsafe in NMI/MC context, and quite possibly have other effects.) Special thanks to: - Andy Lutomirski, for the suggestion of using very small stack slots and copy (as opposed to map) the IRET frame there, and for the suggestion to mark them readonly and let the fault promote to #DF. - Konrad Wilk for paravirt fixup and testing. - Borislav Petkov for testing help and useful comments. Reported-by: Brian Gerst <brgerst@gmail.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Link: http://lkml.kernel.org/r/1398816946-3351-1-git-send-email-hpa@linux.intel.com Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Andrew Lutomriski <amluto@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Dirk Hohndel <dirk@hohndel.org> Cc: Arjan van de Ven <arjan.van.de.ven@intel.com> Cc: comex <comexk@gmail.com> Cc: Alexander van Heukelum <heukelum@fastmail.fm> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-14futex: Allow architectures to skip futex_atomic_cmpxchg_inatomic() testHeiko Carstens
commit 03b8c7b623c80af264c4c8d6111e5c6289933666 upstream. If an architecture has futex_atomic_cmpxchg_inatomic() implemented and there is no runtime check necessary, allow to skip the test within futex_init(). This allows to get rid of some code which would always give the same result, and also allows the compiler to optimize a couple of if statements away. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Link: http://lkml.kernel.org/r/20140302120947.GA3641@osiris Signed-off-by: Thomas Gleixner <tglx@linutronix.de> [geert: Backported to v3.10..v3.13] Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18random: run random_int_secret_init() run after all late_initcallsTheodore Ts'o
commit 47d06e532e95b71c0db3839ebdef3fe8812fca2c upstream. The some platforms (e.g., ARM) initializes their clocks as late_initcalls for some unknown reason. So make sure random_int_secret_init() is run after all of the late_initcalls are run. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-10rcu: Don't call wakeup() with rcu_node structure ->lock heldSteven Rostedt
This commit fixes a lockdep-detected deadlock by moving a wake_up() call out from a rnp->lock critical section. Please see below for the long version of this story. On Tue, 2013-05-28 at 16:13 -0400, Dave Jones wrote: > [12572.705832] ====================================================== > [12572.750317] [ INFO: possible circular locking dependency detected ] > [12572.796978] 3.10.0-rc3+ #39 Not tainted > [12572.833381] ------------------------------------------------------- > [12572.862233] trinity-child17/31341 is trying to acquire lock: > [12572.870390] (rcu_node_0){..-.-.}, at: [<ffffffff811054ff>] rcu_read_unlock_special+0x9f/0x4c0 > [12572.878859] > but task is already holding lock: > [12572.894894] (&ctx->lock){-.-...}, at: [<ffffffff811390ed>] perf_lock_task_context+0x7d/0x2d0 > [12572.903381] > which lock already depends on the new lock. > > [12572.927541] > the existing dependency chain (in reverse order) is: > [12572.943736] > -> #4 (&ctx->lock){-.-...}: > [12572.960032] [<ffffffff810b9851>] lock_acquire+0x91/0x1f0 > [12572.968337] [<ffffffff816ebc90>] _raw_spin_lock+0x40/0x80 > [12572.976633] [<ffffffff8113c987>] __perf_event_task_sched_out+0x2e7/0x5e0 > [12572.984969] [<ffffffff81088953>] perf_event_task_sched_out+0x93/0xa0 > [12572.993326] [<ffffffff816ea0bf>] __schedule+0x2cf/0x9c0 > [12573.001652] [<ffffffff816eacfe>] schedule_user+0x2e/0x70 > [12573.009998] [<ffffffff816ecd64>] retint_careful+0x12/0x2e > [12573.018321] > -> #3 (&rq->lock){-.-.-.}: > [12573.034628] [<ffffffff810b9851>] lock_acquire+0x91/0x1f0 > [12573.042930] [<ffffffff816ebc90>] _raw_spin_lock+0x40/0x80 > [12573.051248] [<ffffffff8108e6a7>] wake_up_new_task+0xb7/0x260 > [12573.059579] [<ffffffff810492f5>] do_fork+0x105/0x470 > [12573.067880] [<ffffffff81049686>] kernel_thread+0x26/0x30 > [12573.076202] [<ffffffff816cee63>] rest_init+0x23/0x140 > [12573.084508] [<ffffffff81ed8e1f>] start_kernel+0x3f1/0x3fe > [12573.092852] [<ffffffff81ed856f>] x86_64_start_reservations+0x2a/0x2c > [12573.101233] [<ffffffff81ed863d>] x86_64_start_kernel+0xcc/0xcf > [12573.109528] > -> #2 (&p->pi_lock){-.-.-.}: > [12573.125675] [<ffffffff810b9851>] lock_acquire+0x91/0x1f0 > [12573.133829] [<ffffffff816ebe9b>] _raw_spin_lock_irqsave+0x4b/0x90 > [12573.141964] [<ffffffff8108e881>] try_to_wake_up+0x31/0x320 > [12573.150065] [<ffffffff8108ebe2>] default_wake_function+0x12/0x20 > [12573.158151] [<ffffffff8107bbf8>] autoremove_wake_function+0x18/0x40 > [12573.166195] [<ffffffff81085398>] __wake_up_common+0x58/0x90 > [12573.174215] [<ffffffff81086909>] __wake_up+0x39/0x50 > [12573.182146] [<ffffffff810fc3da>] rcu_start_gp_advanced.isra.11+0x4a/0x50 > [12573.190119] [<ffffffff810fdb09>] rcu_start_future_gp+0x1c9/0x1f0 > [12573.198023] [<ffffffff810fe2c4>] rcu_nocb_kthread+0x114/0x930 > [12573.205860] [<ffffffff8107a91d>] kthread+0xed/0x100 > [12573.213656] [<ffffffff816f4b1c>] ret_from_fork+0x7c/0xb0 > [12573.221379] > -> #1 (&rsp->gp_wq){..-.-.}: > [12573.236329] [<ffffffff810b9851>] lock_acquire+0x91/0x1f0 > [12573.243783] [<ffffffff816ebe9b>] _raw_spin_lock_irqsave+0x4b/0x90 > [12573.251178] [<ffffffff810868f3>] __wake_up+0x23/0x50 > [12573.258505] [<ffffffff810fc3da>] rcu_start_gp_advanced.isra.11+0x4a/0x50 > [12573.265891] [<ffffffff810fdb09>] rcu_start_future_gp+0x1c9/0x1f0 > [12573.273248] [<ffffffff810fe2c4>] rcu_nocb_kthread+0x114/0x930 > [12573.280564] [<ffffffff8107a91d>] kthread+0xed/0x100 > [12573.287807] [<ffffffff816f4b1c>] ret_from_fork+0x7c/0xb0 Notice the above call chain. rcu_start_future_gp() is called with the rnp->lock held. Then it calls rcu_start_gp_advance, which does a wakeup. You can't do wakeups while holding the rnp->lock, as that would mean that you could not do a rcu_read_unlock() while holding the rq lock, or any lock that was taken while holding the rq lock. This is because... (See below). > [12573.295067] > -> #0 (rcu_node_0){..-.-.}: > [12573.309293] [<ffffffff810b8d36>] __lock_acquire+0x1786/0x1af0 > [12573.316568] [<ffffffff810b9851>] lock_acquire+0x91/0x1f0 > [12573.323825] [<ffffffff816ebc90>] _raw_spin_lock+0x40/0x80 > [12573.331081] [<ffffffff811054ff>] rcu_read_unlock_special+0x9f/0x4c0 > [12573.338377] [<ffffffff810760a6>] __rcu_read_unlock+0x96/0xa0 > [12573.345648] [<ffffffff811391b3>] perf_lock_task_context+0x143/0x2d0 > [12573.352942] [<ffffffff8113938e>] find_get_context+0x4e/0x1f0 > [12573.360211] [<ffffffff811403f4>] SYSC_perf_event_open+0x514/0xbd0 > [12573.367514] [<ffffffff81140e49>] SyS_perf_event_open+0x9/0x10 > [12573.374816] [<ffffffff816f4dd4>] tracesys+0xdd/0xe2 Notice the above trace. perf took its own ctx->lock, which can be taken while holding the rq lock. While holding this lock, it did a rcu_read_unlock(). The perf_lock_task_context() basically looks like: rcu_read_lock(); raw_spin_lock(ctx->lock); rcu_read_unlock(); Now, what looks to have happened, is that we scheduled after taking that first rcu_read_lock() but before taking the spin lock. When we scheduled back in and took the ctx->lock, the following rcu_read_unlock() triggered the "special" code. The rcu_read_unlock_special() takes the rnp->lock, which gives us a possible deadlock scenario. CPU0 CPU1 CPU2 ---- ---- ---- rcu_nocb_kthread() lock(rq->lock); lock(ctx->lock); lock(rnp->lock); wake_up(); lock(rq->lock); rcu_read_unlock(); rcu_read_unlock_special(); lock(rnp->lock); lock(ctx->lock); **** DEADLOCK **** > [12573.382068] > other info that might help us debug this: > > [12573.403229] Chain exists of: > rcu_node_0 --> &rq->lock --> &ctx->lock > > [12573.424471] Possible unsafe locking scenario: > > [12573.438499] CPU0 CPU1 > [12573.445599] ---- ---- > [12573.452691] lock(&ctx->lock); > [12573.459799] lock(&rq->lock); > [12573.467010] lock(&ctx->lock); > [12573.474192] lock(rcu_node_0); > [12573.481262] > *** DEADLOCK *** > > [12573.501931] 1 lock held by trinity-child17/31341: > [12573.508990] #0: (&ctx->lock){-.-...}, at: [<ffffffff811390ed>] perf_lock_task_context+0x7d/0x2d0 > [12573.516475] > stack backtrace: > [12573.530395] CPU: 1 PID: 31341 Comm: trinity-child17 Not tainted 3.10.0-rc3+ #39 > [12573.545357] ffffffff825b4f90 ffff880219f1dbc0 ffffffff816e375b ffff880219f1dc00 > [12573.552868] ffffffff816dfa5d ffff880219f1dc50 ffff88023ce4d1f8 ffff88023ce4ca40 > [12573.560353] 0000000000000001 0000000000000001 ffff88023ce4d1f8 ffff880219f1dcc0 > [12573.567856] Call Trace: > [12573.575011] [<ffffffff816e375b>] dump_stack+0x19/0x1b > [12573.582284] [<ffffffff816dfa5d>] print_circular_bug+0x200/0x20f > [12573.589637] [<ffffffff810b8d36>] __lock_acquire+0x1786/0x1af0 > [12573.596982] [<ffffffff810918f5>] ? sched_clock_cpu+0xb5/0x100 > [12573.604344] [<ffffffff810b9851>] lock_acquire+0x91/0x1f0 > [12573.611652] [<ffffffff811054ff>] ? rcu_read_unlock_special+0x9f/0x4c0 > [12573.619030] [<ffffffff816ebc90>] _raw_spin_lock+0x40/0x80 > [12573.626331] [<ffffffff811054ff>] ? rcu_read_unlock_special+0x9f/0x4c0 > [12573.633671] [<ffffffff811054ff>] rcu_read_unlock_special+0x9f/0x4c0 > [12573.640992] [<ffffffff811390ed>] ? perf_lock_task_context+0x7d/0x2d0 > [12573.648330] [<ffffffff810b429e>] ? put_lock_stats.isra.29+0xe/0x40 > [12573.655662] [<ffffffff813095a0>] ? delay_tsc+0x90/0xe0 > [12573.662964] [<ffffffff810760a6>] __rcu_read_unlock+0x96/0xa0 > [12573.670276] [<ffffffff811391b3>] perf_lock_task_context+0x143/0x2d0 > [12573.677622] [<ffffffff81139070>] ? __perf_event_enable+0x370/0x370 > [12573.684981] [<ffffffff8113938e>] find_get_context+0x4e/0x1f0 > [12573.692358] [<ffffffff811403f4>] SYSC_perf_event_open+0x514/0xbd0 > [12573.699753] [<ffffffff8108cd9d>] ? get_parent_ip+0xd/0x50 > [12573.707135] [<ffffffff810b71fd>] ? trace_hardirqs_on_caller+0xfd/0x1c0 > [12573.714599] [<ffffffff81140e49>] SyS_perf_event_open+0x9/0x10 > [12573.721996] [<ffffffff816f4dd4>] tracesys+0xdd/0xe2 This commit delays the wakeup via irq_work(), which is what perf and ftrace use to perform wakeups in critical sections. Reported-by: Dave Jones <davej@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2013-05-05Merge branch 'timers-nohz-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull 'full dynticks' support from Ingo Molnar: "This tree from Frederic Weisbecker adds a new, (exciting! :-) core kernel feature to the timer and scheduler subsystems: 'full dynticks', or CONFIG_NO_HZ_FULL=y. This feature extends the nohz variable-size timer tick feature from idle to busy CPUs (running at most one task) as well, potentially reducing the number of timer interrupts significantly. This feature got motivated by real-time folks and the -rt tree, but the general utility and motivation of full-dynticks runs wider than that: - HPC workloads get faster: CPUs running a single task should be able to utilize a maximum amount of CPU power. A periodic timer tick at HZ=1000 can cause a constant overhead of up to 1.0%. This feature removes that overhead - and speeds up the system by 0.5%-1.0% on typical distro configs even on modern systems. - Real-time workload latency reduction: CPUs running critical tasks should experience as little jitter as possible. The last remaining source of kernel-related jitter was the periodic timer tick. - A single task executing on a CPU is a pretty common situation, especially with an increasing number of cores/CPUs, so this feature helps desktop and mobile workloads as well. The cost of the feature is mainly related to increased timer reprogramming overhead when a CPU switches its tick period, and thus slightly longer to-idle and from-idle latency. Configuration-wise a third mode of operation is added to the existing two NOHZ kconfig modes: - CONFIG_HZ_PERIODIC: [formerly !CONFIG_NO_HZ], now explicitly named as a config option. This is the traditional Linux periodic tick design: there's a HZ tick going on all the time, regardless of whether a CPU is idle or not. - CONFIG_NO_HZ_IDLE: [formerly CONFIG_NO_HZ=y], this turns off the periodic tick when a CPU enters idle mode. - CONFIG_NO_HZ_FULL: this new mode, in addition to turning off the tick when a CPU is idle, also slows the tick down to 1 Hz (one timer interrupt per second) when only a single task is running on a CPU. The .config behavior is compatible: existing !CONFIG_NO_HZ and CONFIG_NO_HZ=y settings get translated to the new values, without the user having to configure anything. CONFIG_NO_HZ_FULL is turned off by default. This feature is based on a lot of infrastructure work that has been steadily going upstream in the last 2-3 cycles: related RCU support and non-periodic cputime support in particular is upstream already. This tree adds the final pieces and activates the feature. The pull request is marked RFC because: - it's marked 64-bit only at the moment - the 32-bit support patch is small but did not get ready in time. - it has a number of fresh commits that came in after the merge window. The overwhelming majority of commits are from before the merge window, but still some aspects of the tree are fresh and so I marked it RFC. - it's a pretty wide-reaching feature with lots of effects - and while the components have been in testing for some time, the full combination is still not very widely used. That it's default-off should reduce its regression abilities and obviously there are no known regressions with CONFIG_NO_HZ_FULL=y enabled either. - the feature is not completely idempotent: there is no 100% equivalent replacement for a periodic scheduler/timer tick. In particular there's ongoing work to map out and reduce its effects on scheduler load-balancing and statistics. This should not impact correctness though, there are no known regressions related to this feature at this point. - it's a pretty ambitious feature that with time will likely be enabled by most Linux distros, and we'd like you to make input on its design/implementation, if you dislike some aspect we missed. Without flaming us to crisp! :-) Future plans: - there's ongoing work to reduce 1Hz to 0Hz, to essentially shut off the periodic tick altogether when there's a single busy task on a CPU. We'd first like 1 Hz to be exposed more widely before we go for the 0 Hz target though. - once we reach 0 Hz we can remove the periodic tick assumption from nr_running>=2 as well, by essentially interrupting busy tasks only as frequently as the sched_latency constraints require us to do - once every 4-40 msecs, depending on nr_running. I am personally leaning towards biting the bullet and doing this in v3.10, like the -rt tree this effort has been going on for too long - but the final word is up to you as usual. More technical details can be found in Documentation/timers/NO_HZ.txt" * 'timers-nohz-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (39 commits) sched: Keep at least 1 tick per second for active dynticks tasks rcu: Fix full dynticks' dependency on wide RCU nocb mode nohz: Protect smp_processor_id() in tick_nohz_task_switch() nohz_full: Add documentation. cputime_nsecs: use math64.h for nsec resolution conversion helpers nohz: Select VIRT_CPU_ACCOUNTING_GEN from full dynticks config nohz: Reduce overhead under high-freq idling patterns nohz: Remove full dynticks' superfluous dependency on RCU tree nohz: Fix unavailable tick_stop tracepoint in dynticks idle nohz: Add basic tracing nohz: Select wide RCU nocb for full dynticks nohz: Disable the tick when irq resume in full dynticks CPU nohz: Re-evaluate the tick for the new task after a context switch nohz: Prepare to stop the tick on irq exit nohz: Implement full dynticks kick nohz: Re-evaluate the tick from the scheduler IPI sched: New helper to prevent from stopping the tick in full dynticks sched: Kick full dynticks CPU that have more than one task enqueued. perf: New helper to prevent full dynticks CPUs from stopping tick perf: Kick full dynticks CPU if events rotation is needed ...
2013-05-04rcu: Fix full dynticks' dependency on wide RCU nocb modeFrederic Weisbecker
Commit 0637e029392386e6996f5d6574aadccee8315efa ("nohz: Select wide RCU nocb for full dynticks") intended to force CONFIG_RCU_NOCB_CPU_ALL=y when full dynticks is enabled. However this option is part of a choice menu and Kconfig's "select" instruction has no effect on such targets. Fix this by using reverse dependencies on the targets we don't want instead. Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Christoph Lameter <cl@linux.com> Cc: Hakan Akkan <hakanakkan@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Kevin Hilman <khilman@linaro.org> Cc: Li Zhong <zhong@linux.vnet.ibm.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de>
2013-05-02Merge commit '8700c95adb03' into timers/nohzFrederic Weisbecker
The full dynticks tree needs the latest RCU and sched upstream updates in order to fix some dependencies. Merge a common upstream merge point that has these updates. Conflicts: include/linux/perf_event.h kernel/rcutree.h kernel/rcutree_plugin.h Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS updates from Al Viro, Misc cleanups all over the place, mainly wrt /proc interfaces (switch create_proc_entry to proc_create(), get rid of the deprecated create_proc_read_entry() in favor of using proc_create_data() and seq_file etc). 7kloc removed. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits) don't bother with deferred freeing of fdtables proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h proc: Make the PROC_I() and PDE() macros internal to procfs proc: Supply a function to remove a proc entry by PDE take cgroup_open() and cpuset_open() to fs/proc/base.c ppc: Clean up scanlog ppc: Clean up rtas_flash driver somewhat hostap: proc: Use remove_proc_subtree() drm: proc: Use remove_proc_subtree() drm: proc: Use minor->index to label things, not PDE->name drm: Constify drm_proc_list[] zoran: Don't print proc_dir_entry data in debug reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show() proc: Supply an accessor for getting the data from a PDE's parent airo: Use remove_proc_subtree() rtl8192u: Don't need to save device proc dir PDE rtl8187se: Use a dir under /proc/net/r8180/ proc: Add proc_mkdir_data() proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h} proc: Move PDE_NET() to fs/proc/proc_net.c ...
2013-05-01proc: Split the namespace stuff out into linux/proc_ns.hDavid Howells
Split the proc namespace stuff out into linux/proc_ns.h. Signed-off-by: David Howells <dhowells@redhat.com> cc: netdev@vger.kernel.org cc: Serge E. Hallyn <serge.hallyn@ubuntu.com> cc: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-05-01init: Do not warn on non-zero initcall returnSteven Rostedt
Commit f91eb62f71b3 ("init: scream bloody murder if interrupts are enabled too early") added three new warnings. The first two seemed reasonable, but the third included a warning when an initcall returned non-zero. Although, the third WARN() does include an imbalanced preempt disabled, or irqs disable, it shouldn't warn if it only had an initcall that just returns non-zero. In fact, according to Linus, it shouldn't print at all. As it only prints with initcall_debug set, and that already shows enough information to fix things. Link: http://lkml.kernel.org/r/CA+55aFzaBC5SFi7=F2mfm+KWY5qTsBmOqgbbs8E+LUS8JK-sBg@mail.gmail.com Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Reported-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30init/Kconfig: re-order CONFIG_EXPERT options to fix menuconfig displayMike Frysinger
The kconfig language requires that dependent options all follow the menuconfig symbol in order to be collapsed below it. Recently some hidden options were added below the EXPERT menuconfig, but did not depend on EXPERT (because hidden options can't). This broke the display. So re-order all these options, and while we're here stick the PCI quirks under the EXPERT menu (since it isn't sitting with any related options). Before this commit, we get: [*] Configure standard kernel features (expert users) ---> [ ] Sysctl syscall support [*] Load all symbols for debugging/ksymoops ... [ ] Embedded system Now we get the older (and correct) behavior: [*] Configure standard kernel features (expert users) ---> [ ] Embedded system And if you go into the expert menu you get the expert options: [ ] Sysctl syscall support [*] Load all symbols for debugging/ksymoops ... Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Randy Dunlap <rdunlap@infradead.org> Cc: zhangwei(Jovi) <jovi.zhangwei@huawei.com> Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30usermodehelper: split remaining calls to call_usermodehelper_fns()Lucas De Marchi
These are the only users of call_usermodehelper_fns(). This function suffers from not being able to determine if the cleanup is called. Even if in this places the cleanup pointer is NULL, convert them to use the separate call_usermodehelper_setup() + call_usermodehelper_exec() functions so we can remove the _fns variant. Signed-off-by: Lucas De Marchi <lucas.demarchi@profusion.mobi> Cc: Oleg Nesterov <oleg@redhat.com> Cc: David Howells <dhowells@redhat.com> Cc: James Morris <james.l.morris@oracle.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Tejun Heo <tj@kernel.org> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core timer updates from Ingo Molnar: "The main changes in this cycle's merge are: - Implement shadow timekeeper to shorten in kernel reader side blocking, by Thomas Gleixner. - Posix timers enhancements by Pavel Emelyanov: - allocate timer ID per process, so that exact timer ID allocations can be re-created be checkpoint/restore code. - debuggability and tooling (/proc/PID/timers, etc.) improvements. - suspend/resume enhancements by Feng Tang: on certain new Intel Atom processors (Penwell and Cloverview), there is a feature that the TSC won't stop in S3 state, so the TSC value won't be reset to 0 after resume. This can be taken advantage of by the generic via the CLOCK_SOURCE_SUSPEND_NONSTOP flag: instead of using the RTC to recover/approximate sleep time, the main (and precise) clocksource can be used. - Fix /proc/timer_list for 4096 CPUs by Nathan Zimmer: on so many CPUs the file goes beyond 4MB of size and thus the current simplistic seqfile approach fails. Convert /proc/timer_list to a proper seq_file with its own iterator. - Cleanups and refactorings of the core timekeeping code by John Stultz. - International Atomic Clock time is managed by the NTP code internally currently but not exposed externally. Separate the TAI code out and add CLOCK_TAI support and TAI support to the hrtimer and posix-timer code, by John Stultz. - Add deep idle support enhacement to the broadcast clockevents core timer code, by Daniel Lezcano: add an opt-in CLOCK_EVT_FEAT_DYNIRQ clockevents feature (which will be utilized by future clockevents driver updates), which allows the use of IRQ affinities to avoid spurious wakeups of idle CPUs - the right CPU with an expiring timer will be woken. - Add new ARM bcm281xx clocksource driver, by Christian Daudt - ... various other fixes and cleanups" * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (52 commits) clockevents: Set dummy handler on CPU_DEAD shutdown timekeeping: Update tk->cycle_last in resume posix-timers: Remove unused variable clockevents: Switch into oneshot mode even if broadcast registered late timer_list: Convert timer list to be a proper seq_file timer_list: Split timer_list_show_tickdevices posix-timers: Show sigevent info in proc file posix-timers: Introduce /proc/PID/timers file posix timers: Allocate timer id per process (v2) timekeeping: Make sure to notify hrtimers when TAI offset changes hrtimer: Fix ktime_add_ns() overflow on 32bit architectures hrtimer: Add expiry time overflow check in hrtimer_interrupt timekeeping: Shorten seq_count region timekeeping: Implement a shadow timekeeper timekeeping: Delay update of clock->cycle_last timekeeping: Store cycle_last value in timekeeper struct as well ntp: Remove ntp_lock, using the timekeeping locks to protect ntp state timekeeping: Simplify tai updating from do_adjtimex timekeeping: Hold timekeepering locks in do_adjtimex and hardpps timekeeping: Move ADJ_SETOFFSET to top level do_adjtimex() ...
2013-04-30Merge branch 'smp-hotplug-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull SMP/hotplug changes from Ingo Molnar: "This is a pretty large, multi-arch series unifying and generalizing the various disjunct pieces of idle routines that architectures have historically copied from each other and have grown in random, wildly inconsistent and sometimes buggy directions: 101 files changed, 455 insertions(+), 1328 deletions(-) this went through a number of review and test iterations before it was committed, it was tested on various architectures, was exposed to linux-next for quite some time - nevertheless it might cause problems on architectures that don't read the mailing lists and don't regularly test linux-next. This cat herding excercise was motivated by the -rt kernel, and was brought to you by Thomas "the Whip" Gleixner." * 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (40 commits) idle: Remove GENERIC_IDLE_LOOP config switch um: Use generic idle loop ia64: Make sure interrupts enabled when we "safe_halt()" sparc: Use generic idle loop idle: Remove unused ARCH_HAS_DEFAULT_IDLE bfin: Fix typo in arch_cpu_idle() xtensa: Use generic idle loop x86: Use generic idle loop unicore: Use generic idle loop tile: Use generic idle loop tile: Enter idle with preemption disabled sh: Use generic idle loop score: Use generic idle loop s390: Use generic idle loop powerpc: Use generic idle loop parisc: Use generic idle loop openrisc: Use generic idle loop mn10300: Use generic idle loop mips: Use generic idle loop microblaze: Use generic idle loop ...
2013-04-30Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler changes from Ingo Molnar: "The main changes in this development cycle were: - full dynticks preparatory work by Frederic Weisbecker - factor out the cpu time accounting code better, by Li Zefan - multi-CPU load balancer cleanups and improvements by Joonsoo Kim - various smaller fixes and cleanups" * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (45 commits) sched: Fix init NOHZ_IDLE flag sched: Prevent to re-select dst-cpu in load_balance() sched: Rename load_balance_tmpmask to load_balance_mask sched: Move up affinity check to mitigate useless redoing overhead sched: Don't consider other cpus in our group in case of NEWLY_IDLE sched: Explicitly cpu_idle_type checking in rebalance_domains() sched: Change position of resched_cpu() in load_balance() sched: Fix wrong rq's runnable_avg update with rt tasks sched: Document task_struct::personality field sched/cpuacct/UML: Fix header file dependency bug on the UML build cgroup: Kill subsys.active flag sched/cpuacct: No need to check subsys active state sched/cpuacct: Initialize cpuacct subsystem earlier sched/cpuacct: Initialize root cpuacct earlier sched/cpuacct: Allocate per_cpu cpuusage for root cpuacct statically sched/cpuacct: Clean up cpuacct.h sched/cpuacct: Remove redundant NULL checks in cpuacct_acount_field() sched/cpuacct: Remove redundant NULL checks in cpuacct_charge() sched/cpuacct: Add cpuacct_acount_field() sched/cpuacct: Add cpuacct_init() ...
2013-04-30Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull RCU updates from Ingo Molnar: "The main changes in this cycle are mostly related to preparatory work for the full-dynticks work: - Remove restrictions on no-CBs CPUs, make RCU_FAST_NO_HZ take advantage of numbered callbacks, do callback accelerations based on numbered callbacks. Posted to LKML at https://lkml.org/lkml/2013/3/18/960 - RCU documentation updates. Posted to LKML at https://lkml.org/lkml/2013/3/18/570 - Miscellaneous fixes. Posted to LKML at https://lkml.org/lkml/2013/3/18/594" * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (24 commits) rcu: Make rcu_accelerate_cbs() note need for future grace periods rcu: Abstract rcu_start_future_gp() from rcu_nocb_wait_gp() rcu: Rename n_nocb_gp_requests to need_future_gp rcu: Push lock release to rcu_start_gp()'s callers rcu: Repurpose no-CBs event tracing to future-GP events rcu: Rearrange locking in rcu_start_gp() rcu: Make RCU_FAST_NO_HZ take advantage of numbered callbacks rcu: Accelerate RCU callbacks at grace-period end rcu: Export RCU_FAST_NO_HZ parameters to sysfs rcu: Distinguish "rcuo" kthreads by RCU flavor rcu: Add event tracing for no-CBs CPUs' grace periods rcu: Add event tracing for no-CBs CPUs' callback registration rcu: Introduce proper blocking to no-CBs kthreads GP waits rcu: Provide compile-time control for no-CBs CPUs rcu: Tone down debugging during boot-up and shutdown. rcu: Add softirq-stall indications to stall-warning messages rcu: Documentation update rcu: Make bugginess of code sample more evident rcu: Fix hlist_bl_set_first_rcu() annotation rcu: Delete unused rcu_node "wakemask" field ...
2013-04-29init/main.c: convert to pr_foo()Andrew Morton
Also enables cleanup of some 80-col trickery. Cc: Richard Weinberger <richard@nod.at> Cc: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29init: raise log levelRichard Weinberger
If the kernel was booted with the "quiet" boot option we have currently no chance to see why an initrd fails. Change KERN_WARNING to KERN_ERR to see what is going on. Signed-off-by: Richard Weinberger <richard@nod.at> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29init: scream bloody murder if interrupts are enabled too earlySteven Rostedt
As I was testing a lot of my code recently, and having several "successes", I accidentally noticed in the dmesg this little line: start_kernel(): bug: interrupts were enabled *very* early, fixing it Sure enough, one of my patches two commits ago enabled interrupts early. The sad part here is that I never noticed it, and I ran several tests with ktest too, and ktest did not notice this line. What ktest looks for (and so does many other automated testing scripts) is a back trace produced by a WARN_ON() or BUG(). As a back trace was never produced, my buggy patch could have slipped into linux-next, or even worse, mainline. Adding a WARN(!irqs_disabled()) makes this bug a little more obvious: PID hash table entries: 4096 (order: 3, 32768 bytes) __ex_table already sorted, skipping sort Checking aperture... No AGP bridge found Calgary: detecting Calgary via BIOS EBDA area Calgary: Unable to locate Rio Grande table in EBDA - bailing! Memory: 2003252k/2054848k available (4857k kernel code, 460k absent, 51136k reserved, 6210k data, 1096k init) ------------[ cut here ]------------ WARNING: at /home/rostedt/work/git/linux-trace.git/init/main.c:543 start_kernel+0x21e/0x415() Hardware name: To Be Filled By O.E.M. Interrupts were enabled *very* early, fixing it Modules linked in: Pid: 0, comm: swapper/0 Not tainted 3.8.0-test+ #286 Call Trace: warn_slowpath_common+0x83/0x9b warn_slowpath_fmt+0x46/0x48 start_kernel+0x21e/0x415 x86_64_start_reservations+0x10e/0x112 x86_64_start_kernel+0x102/0x111 ---[ end trace 007d8b0491b4f5d8 ]--- Preemptible hierarchical RCU implementation. RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. NR_IRQS:4352 nr_irqs:712 16 Console: colour VGA+ 80x25 console [ttyS0] enabled, bootconsole disabled Do you see it? The original version of this patch just slapped a WARN_ON() in there and kept the printk(). Ard van Breemen suggested using the WARN() interface, which makes the code a bit cleaner. Also, while examining other warnings in init/main.c, I found two other locations that deserve a bloody murder scream if their conditions are hit, and updated them accordingly. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Ard van Breemen <ard@telegraafnet.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-26nohz: Select VIRT_CPU_ACCOUNTING_GEN from full dynticks configFrederic Weisbecker
Turn the full dynticks passive dependency on VIRT_CPU_ACCOUNTING_GEN to an active one. The full dynticks Kconfig is currently hidden behind the full dynticks cputime accounting, which is an awkward and counter-intuitive layout: the user first has to select the dynticks cputime accounting in order to make the full dynticks feature to be visible. We definetly want it the other way around. The usual way to perform this kind of active dependency is use "select" on the depended target. Now we can't use the Kconfig "select" instruction when the target is a "choice". So this patch inspires on how the RCU subsystem Kconfig interact with its dependencies on SMP and PREEMPT: we make sure that cputime accounting can't propose another option than VIRT_CPU_ACCOUNTING_GEN when NO_HZ_FULL is selected by using the right "depends on" instruction for each cputime accounting choices. v2: Keep full dynticks cputime accounting available even without full dynticks, as per Paul McKenney's suggestion. Reported-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Christoph Lameter <cl@linux.com> Cc: Hakan Akkan <hakanakkan@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Kevin Hilman <khilman@linaro.org> Cc: Li Zhong <zhong@linux.vnet.ibm.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de>
2013-04-24Merge branch 'linus' into timers/coreThomas Gleixner
Reason: Get upstream fixes before adding conflicting code. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-04-19nohz: Ensure full dynticks CPUs are RCU nocbsFrederic Weisbecker
We need full dynticks CPU to also be RCU nocb so that we don't have to keep the tick to handle RCU callbacks. Make sure the range passed to nohz_full= boot parameter is a subset of rcu_nocbs= The CPUs that fail to meet this requirement will be excluded from the nohz_full range. This is checked early in boot time, before any CPU has the opportunity to stop its tick. Suggested-by: Steven Rostedt <rostedt@goodmis.org> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Christoph Lameter <cl@linux.com> Cc: Geoff Levand <geoff@infradead.org> Cc: Gilad Ben Yossef <gilad@benyossef.com> Cc: Hakan Akkan <hakanakkan@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Kevin Hilman <khilman@linaro.org> Cc: Li Zhong <zhong@linux.vnet.ibm.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de>
2013-04-10Merge branch 'rcu/next' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu into core/rcu Pull RCU updates from Paul E. McKenney: * Remove restrictions on no-CBs CPUs, make RCU_FAST_NO_HZ take advantage of numbered callbacks, do additional callback accelerations based on numbered callbacks. Posted to LKML at https://lkml.org/lkml/2013/3/18/960. * RCU documentation updates. Posted to LKML at https://lkml.org/lkml/2013/3/18/570. * Miscellaneous fixes. Posted to LKML at https://lkml.org/lkml/2013/3/18/594. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-04-08idle: Provide a generic entry point for the idle codeThomas Gleixner
For now this calls cpu_idle(), but in the long run we want to move the cpu bringup code to the core and therefor we add a state argument. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Reviewed-by: Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Magnus Damm <magnus.damm@gmail.com> Link: http://lkml.kernel.org/r/20130321215233.583190032@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-04-03nohz: Rename CONFIG_NO_HZ to CONFIG_NO_HZ_COMMONFrederic Weisbecker
We are planning to convert the dynticks Kconfig options layout into a choice menu. The user must be able to easily pick any of the following implementations: constant periodic tick, idle dynticks, full dynticks. As this implies a mutual exclusion, the two dynticks implementions need to converge on the selection of a common Kconfig option in order to ease the sharing of a common infrastructure. It would thus seem pretty natural to reuse CONFIG_NO_HZ to that end. It already implements all the idle dynticks code and the full dynticks depends on all that code for now. So ideally the choice menu would propose CONFIG_NO_HZ_IDLE and CONFIG_NO_HZ_EXTENDED then both would select CONFIG_NO_HZ. On the other hand we want to stay backward compatible: if CONFIG_NO_HZ is set in an older config file, we want to enable CONFIG_NO_HZ_IDLE by default. But we can't afford both at the same time or we run into a circular dependency: 1) CONFIG_NO_HZ_IDLE and CONFIG_NO_HZ_EXTENDED both select CONFIG_NO_HZ 2) If CONFIG_NO_HZ is set, we default to CONFIG_NO_HZ_IDLE We might be able to support that from Kconfig/Kbuild but it may not be wise to introduce such a confusing behaviour. So to solve this, create a new CONFIG_NO_HZ_COMMON option which gathers the common code between idle and full dynticks (that common code for now is simply the idle dynticks code) and select it from their referring Kconfig. Then we'll later create CONFIG_NO_HZ_IDLE and map CONFIG_NO_HZ to it for backward compatibility. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Christoph Lameter <cl@linux.com> Cc: Geoff Levand <geoff@infradead.org> Cc: Gilad Ben Yossef <gilad@benyossef.com> Cc: Hakan Akkan <hakanakkan@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Kevin Hilman <khilman@linaro.org> Cc: Li Zhong <zhong@linux.vnet.ibm.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de>
2013-03-26rcu: Make RCU_FAST_NO_HZ take advantage of numbered callbacksPaul E. McKenney
Because RCU callbacks are now associated with the number of the grace period that they must wait for, CPUs can now take advance callbacks corresponding to grace periods that ended while a given CPU was in dyntick-idle mode. This eliminates the need to try forcing the RCU state machine while entering idle, thus reducing the CPU intensiveness of RCU_FAST_NO_HZ, which should increase its energy efficiency. Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2013-03-26rcu: Distinguish "rcuo" kthreads by RCU flavorPaul E. McKenney
Currently, the per-no-CBs-CPU kthreads are named "rcuo" followed by the CPU number, for example, "rcuo". This is problematic given that there are either two or three RCU flavors, each of which gets a per-CPU kthread with exactly the same name. This commit therefore introduces a one-letter abbreviation for each RCU flavor, namely 'b' for RCU-bh, 'p' for RCU-preempt, and 's' for RCU-sched. This abbreviation is used to distinguish the "rcuo" kthreads, for example, for CPU 0 we would have "rcuob/0", "rcuop/0", and "rcuos/0". Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Tested-by: Dietmar Eggemann <dietmar.eggemann@arm.com>
2013-03-26rcu: Provide compile-time control for no-CBs CPUsPaul E. McKenney
Currently, the only way to specify no-CBs CPUs is via the rcu_nocbs kernel command-line parameter. This is inconvenient in some cases, particularly for randconfig testing, so this commit adds a new set of kernel configuration parameters. CONFIG_RCU_NOCB_CPU_NONE (the default) retains the old behavior, CONFIG_RCU_NOCB_CPU_ZERO offloads callback processing from CPU 0 (along with any other CPUs specified by the rcu_nocbs boot-time parameter), and CONFIG_RCU_NOCB_CPU_ALL offloads callback processing from all CPUs. Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2013-03-12final removal of CONFIG_EXPERIMENTALKees Cook
Remove "config EXPERIMENTAL" itself, now that every "depends on" it has been removed from the tree. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-12rcu: Remove restrictions on no-CBs CPUsPaul E. McKenney
Currently, CPU 0 is constrained to not be a no-CBs CPU, and furthermore at least one no-CBs CPU must remain online at any given time. These restrictions are problematic in some situations, such as cases where all CPUs must run a real-time workload that needs to be insulated from OS jitter and latencies due to RCU callback invocation. This commit therefore provides no-CBs CPUs a (very crude and energy-inefficient) way to start and to wait for grace periods independently of the normal RCU callback mechanisms. This approach allows any or all of the CPUs to be designated as no-CBs CPUs, and allows any proper subset of the CPUs (whether no-CBs CPUs or not) to be offlined. This commit also provides a fix for a locking bug spotted by Xie ChanglongX <changlongx.xie@intel.com>. Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2013-03-07context_tracking: Enable probes by default for selftestingFrederic Weisbecker
Until we provide the nohz_mask boot parameter, keeping the context tracking probes disabled by default is pointless since what we want is to runtime test this code anyway. It's furthermore confusing for the users which don't expect the probes to be off when they select RCU user mode or full dynticks cputime accounting. Let's enable these probes selftests by default for now. Suggested: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Li Zhong <zhong@linux.vnet.ibm.com> Cc: Kevin Hilman <khilman@linaro.org> Cc: Mats Liljegren <mats.liljegren@enea.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2013-03-07tick: Call tick_init lateThomas Gleixner
To convert the clockevents code to cpumask_var_t we need to move the init call after the allocator setup. Clockevents are earliest registered from time_init() as they need interrupts being set up, so this is safe. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20130306111537.304379448@linutronix.de Cc: Rusty Russell <rusty@rustcorp.com.au>
2013-03-02Merge tag 'arc-v3.9-rc1-late' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc Pull new ARC architecture from Vineet Gupta: "Initial ARC Linux port with some fixes on top for 3.9-rc1: I would like to introduce the Linux port to ARC Processors (from Synopsys) for 3.9-rc1. The patch-set has been discussed on the public lists since Nov and has received a fair bit of review, specially from Arnd, tglx, Al and other subsystem maintainers for DeviceTree, kgdb... The arch bits are in arch/arc, some asm-generic changes (acked by Arnd), a minor change to PARISC (acked by Helge). The series is a touch bigger for a new port for 2 main reasons: 1. It enables a basic kernel in first sub-series and adds ptrace/kgdb/.. later 2. Some of the fallout of review (DeviceTree support, multi-platform- image support) were added on top of orig series, primarily to record the revision history. This updated pull request additionally contains - fixes due to our GNU tools catching up with the new syscall/ptrace ABI - some (minor) cross-arch Kconfig updates." * tag 'arc-v3.9-rc1-late' of git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc: (82 commits) ARC: split elf.h into uapi and export it for userspace ARC: Fixup the current ABI version ARC: gdbserver using regset interface possibly broken ARC: Kconfig cleanup tracking cross-arch Kconfig pruning in merge window ARC: make a copy of flat DT ARC: [plat-arcfpga] DT arc-uart bindings change: "baud" => "current-speed" ARC: Ensure CONFIG_VIRT_TO_BUS is not enabled ARC: Fix pt_orig_r8 access ARC: [3.9] Fallout of hlist iterator update ARC: 64bit RTSC timestamp hardware issue ARC: Don't fiddle with non-existent caches ARC: Add self to MAINTAINERS ARC: Provide a default serial.h for uart drivers needing BASE_BAUD ARC: [plat-arcfpga] defconfig for fully loaded ARC Linux ARC: [Review] Multi-platform image #8: platform registers SMP callbacks ARC: [Review] Multi-platform image #7: SMP common code to use callbacks ARC: [Review] Multi-platform image #6: cpu-to-dma-addr optional ARC: [Review] Multi-platform image #5: NR_IRQS defined by ARC core ARC: [Review] Multi-platform image #4: Isolate platform headers ARC: [Review] Multi-platform image #3: switch to board callback ...
2013-02-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace and namespace infrastructure changes from Eric W Biederman: "This set of changes starts with a few small enhnacements to the user namespace. reboot support, allowing more arbitrary mappings, and support for mounting devpts, ramfs, tmpfs, and mqueuefs as just the user namespace root. I do my best to document that if you care about limiting your unprivileged users that when you have the user namespace support enabled you will need to enable memory control groups. There is a minor bug fix to prevent overflowing the stack if someone creates way too many user namespaces. The bulk of the changes are a continuation of the kuid/kgid push down work through the filesystems. These changes make using uids and gids typesafe which ensures that these filesystems are safe to use when multiple user namespaces are in use. The filesystems converted for 3.9 are ceph, 9p, afs, ocfs2, gfs2, ncpfs, nfs, nfsd, and cifs. The changes for these filesystems were a little more involved so I split the changes into smaller hopefully obviously correct changes. XFS is the only filesystem that remains. I was hoping I could get that in this release so that user namespace support would be enabled with an allyesconfig or an allmodconfig but it looks like the xfs changes need another couple of days before it they are ready." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (93 commits) cifs: Enable building with user namespaces enabled. cifs: Convert struct cifs_ses to use a kuid_t and a kgid_t cifs: Convert struct cifs_sb_info to use kuids and kgids cifs: Modify struct smb_vol to use kuids and kgids cifs: Convert struct cifsFileInfo to use a kuid cifs: Convert struct cifs_fattr to use kuid and kgids cifs: Convert struct tcon_link to use a kuid. cifs: Modify struct cifs_unix_set_info_args to hold a kuid_t and a kgid_t cifs: Convert from a kuid before printing current_fsuid cifs: Use kuids and kgids SID to uid/gid mapping cifs: Pass GLOBAL_ROOT_UID and GLOBAL_ROOT_GID to keyring_alloc cifs: Use BUILD_BUG_ON to validate uids and gids are the same size cifs: Override unmappable incoming uids and gids nfsd: Enable building with user namespaces enabled. nfsd: Properly compare and initialize kuids and kgids nfsd: Store ex_anon_uid and ex_anon_gid as kuids and kgids nfsd: Modify nfsd4_cb_sec to use kuids and kgids nfsd: Handle kuids and kgids in the nfs4acl to posix_acl conversion nfsd: Convert nfsxdr to use kuids and kgids nfsd: Convert nfs3xdr to use kuids and kgids ...
2013-02-25Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module update from Rusty Russell: "The sweeping change is to make add_taint() explicitly indicate whether to disable lockdep, but it's a mechanical change." * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: MODSIGN: Add option to not sign modules during modules_install MODSIGN: Add -s <signature> option to sign-file MODSIGN: Specify the hash algorithm on sign-file command line MODSIGN: Simplify Makefile with a Kconfig helper module: clean up load_module a little more. modpost: Ignore ARC specific non-alloc sections module: constify within_module_* taint: add explicit flag to show whether lock dep is still OK. module: printk message when module signature fail taints kernel.
2013-02-21Merge tag 'please-pull-misc-3.9' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux Pull misc ia64 bits from Tony Luck. * tag 'please-pull-misc-3.9' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux: MAINTAINERS: update SGI & ia64 Altix stuff sysctl: Enable IA64 "ignore-unaligned-usertrap" to be used cross-arch
2013-02-21Merge tag 'driver-core-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core patches from Greg Kroah-Hartman: "Here is the big driver core merge for 3.9-rc1 There are two major series here, both of which touch lots of drivers all over the kernel, and will cause you some merge conflicts: - add a new function called devm_ioremap_resource() to properly be able to check return values. - remove CONFIG_EXPERIMENTAL Other than those patches, there's not much here, some minor fixes and updates" Fix up trivial conflicts * tag 'driver-core-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (221 commits) base: memory: fix soft/hard_offline_page permissions drivercore: Fix ordering between deferred_probe and exiting initcalls backlight: fix class_find_device() arguments TTY: mark tty_get_device call with the proper const values driver-core: constify data for class_find_device() firmware: Ignore abort check when no user-helper is used firmware: Reduce ifdef CONFIG_FW_LOADER_USER_HELPER firmware: Make user-mode helper optional firmware: Refactoring for splitting user-mode helper code Driver core: treat unregistered bus_types as having no devices watchdog: Convert to devm_ioremap_resource() thermal: Convert to devm_ioremap_resource() spi: Convert to devm_ioremap_resource() power: Convert to devm_ioremap_resource() mtd: Convert to devm_ioremap_resource() mmc: Convert to devm_ioremap_resource() mfd: Convert to devm_ioremap_resource() media: Convert to devm_ioremap_resource() iommu: Convert to devm_ioremap_resource() drm: Convert to devm_ioremap_resource() ...
2013-02-19Merge branch 'for-3.9-async' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq Pull async changes from Tejun Heo: "These are followups for the earlier deadlock issue involving async ending up waiting for itself through block requesting module[1]. The following changes are made by these commits. - Instead of requesting default elevator on each request_queue init, block now requests it once early during boot. - Kmod triggers warning if invoked from an async worker. - Async synchronization implementation has been reimplemented. It's a lot simpler now." * 'for-3.9-async' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: async: initialise list heads to fix crash async: replace list of active domains with global list of pending items async: keep pending tasks on async_domain and remove async_pending async: use ULLONG_MAX for infinity cookie value async: bring sanity to the use of words domain and running async, kmod: warn on synchronous request_module() from async workers block: don't request module during elevator init init, block: try to load default elevator module early during boot
2013-02-19Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler changes from Ingo Molnar: "Main changes: - scheduler side full-dynticks (user-space execution is undisturbed and receives no timer IRQs) preparation changes that convert the cputime accounting code to be full-dynticks ready, from Frederic Weisbecker. - Initial sched.h split-up changes, by Clark Williams - select_idle_sibling() performance improvement by Mike Galbraith: " 1 tbench pair (worst case) in a 10 core + SMT package: pre 15.22 MB/sec 1 procs post 252.01 MB/sec 1 procs " - sched_rr_get_interval() ABI fix/change. We think this detail is not used by apps (so it's not an ABI in practice), but lets keep it under observation. - misc RT scheduling cleanups, optimizations" * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (24 commits) sched/rt: Add <linux/sched/rt.h> header to <linux/init_task.h> cputime: Remove irqsave from seqlock readers sched, powerpc: Fix sched.h split-up build failure cputime: Restore CPU_ACCOUNTING config defaults for PPC64 sched/rt: Move rt specific bits into new header file sched/rt: Add a tuning knob to allow changing SCHED_RR timeslice sched: Move sched.h sysctl bits into separate header sched: Fix signedness bug in yield_to() sched: Fix select_idle_sibling() bouncing cow syndrome sched/rt: Further simplify pick_rt_task() sched/rt: Do not account zero delta_exec in update_curr_rt() cputime: Safely read cputime of full dynticks CPUs kvm: Prepare to add generic guest entry/exit callbacks cputime: Use accessors to read task cputime stats cputime: Allow dynamic switch between tick/virtual based cputime accounting cputime: Generic on-demand virtual cputime accounting cputime: Move default nsecs_to_cputime() to jiffies based cputime file cputime: Librarize per nsecs resolution cputime definitions cputime: Avoid multiplication overflow on utime scaling context_tracking: Export context state for generic vtime ... Fix up conflict in kernel/context_tracking.c due to comment additions.
2013-02-19Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq core changes from Ingo Molnar: "The biggest changes are the IRQ-work and printk changes from Frederic Weisbecker, which prepare the code for 'full dynticks' (the ability to stop or slow down the periodic tick arbitrarily, not just in idle time as today): - Don't stop tick with irq works pending. This fix is generally useful and concerns archs that can't raise self IPIs. - Flush irq works before CPU offlining. - Introduce "lazy" irq works that can wait for the next tick to be executed, unless it's stopped. - Implement klogd wake up using irq work. This removes the ad-hoc printk_tick()/printk_needs_cpu() hooks and make it working even in dynticks mode. - Cleanups and fixes." * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: genirq: Export enable/disable_percpu_irq() arch Kconfig: Remove references to IRQ_PER_CPU irq_work: Remove return value from the irq_work_queue() function genirq: Avoid deadlock in spurious handling printk: Wake up klogd using irq_work irq_work: Make self-IPIs optable irq_work: Warn if there's still work on cpu_down irq_work: Flush work on CPU_DYING irq_work: Don't stop the tick with pending works nohz: Add API to check tick state irq_work: Remove CONFIG_HAVE_IRQ_WORK irq_work: Fix racy check on work pending flag irq_work: Fix racy IRQ_WORK_BUSY flag setting
2013-02-15sysctl: Enable PARISC "unaligned-trap" to be used cross-archVineet Gupta
PARISC defines /proc/sys/kernel/unaligned-trap to runtime toggle unaligned access emulation. The exact mechanics of enablig/disabling are still arch specific, we can make the sysctl usable by other arches. Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: Helge Deller <deller@gmx.de> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Helge Deller <deller@gmx.de> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Serge Hallyn <serge.hallyn@canonical.com>
2013-02-13cifs: Enable building with user namespaces enabled.Eric W. Biederman
Cc: Steve French <smfrench@gmail.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-13nfsd: Enable building with user namespaces enabled.Eric W. Biederman
Now that the kuids and kgids conversion have propogated through net/sunrpc/ and the fs/nfsd/ it is safe to enable building nfsd when user namespaces are enabled. Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-13nfs: Enable building with user namespaces enabled.Eric W. Biederman
Now that the kuids and kgids conversion have propogated through net/sunrpc/ and the fs/nfs/ it is safe to enable building nfs when user namespaces are enabled. Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-13ncpfs: Support interacting with multiple user namespacesEric W. Biederman
ncpfs does not natively support uids and gids so this conversion was simply a matter of updating the the type of the mounteduid, the uid and the gid on the superblock. Fixing the ioctls that read them, updating the mount option parser and the mount option printer. Cc: Petr Vandrovec <petr@vandrovec.name> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2013-02-13gfs2: Enable building with user namespaces enabledEric W. Biederman
Now that all of the necessary work has been done to push kuids and kgids throughout gfs2 and to convert between kuids and kgids when reading and writing the on disk structures it is safe to enable gfs2 when multiple user namespaces are enabled. Cc: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-13ocfs2: Enable building with user namespaces enabledEric W. Biederman
Now that ocfs2 has been converted to store uids and gids in kuid_t and kgid_t and all of the conversions have been added to the appropriate places it is safe to allow building and using ocfs2 with user namespace support enabled. Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-13coda: Allow coda to be built when user namespace support is enabledEric W. Biederman
Now that the coda kernel to userspace has been modified to convert between kuids and kgids and uids and gids, and all internal coda structures have be modified to store uids and gids as kuids and kgids it is safe to allow code to be built with user namespace support enabled. Cc: Jan Harkes <jaharkes@cs.cmu.edu> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
