path: root/init
2005-05-28[PATCH] uml: add modversions supportPaolo 'Blaisorblade' Giarrusso
Actually, the real support was added by some earlier patches. Now we simply re-enable the config. option. I've actually tested it and it works well. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-03Merge with master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6.gitDavid Woodhouse
2005-05-03[AUDIT] Update UML audit-syscall-{entry,exit} calls to new prototypesJeff Dike
This patch is for -mm only. It should probably be included in git-audit, and should be forwarded to Linus iff git-audit is. It updates the audit-syscall-{entry,exit} calls to current -mm. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-05-01[PATCH] clean up kernel messagesMatt Mackall
Arrange for all kernel printks to be no-ops. Only available if CONFIG_EMBEDDED. This patch saves about 375k on my laptop config and nearly 100k on minimal configs. Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] remove all kernel BUGsMatt Mackall
This patch eliminates all kernel BUGs, trims about 35k off the typical kernel, and makes the system slightly faster. Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
