path: root/ipc/compat.c
2006-03-26[PATCH] sem2mutex: ipc, id.semIngo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] compat: be more consistent about [ug]id_tStephen Rothwell
When I first wrote the compat layer patches, I was somewhat cavalier about the definition of compat_uid_t and compat_gid_t (or maybe I just misunderstood :-)). This patch makes the compat types much more consistent with the types we are being compatible with and hopefully will fix a few bugs along the way. compat type type in compat arch __compat_[ug]id_t __kernel_[ug]id_t __compat_[ug]id32_t __kernel_[ug]id32_t compat_[ug]id_t [ug]id_t The difference is that compat_uid_t is always 32 bits (for the archs we care about) but __compat_uid_t may be 16 bits on some. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] put_compat_shminfo() warning fixJesse Millan
GCC 4 complains because the function put_compat_shminfo() can't get to its return statement if there is no error... If the function does not return -EFAULT, it doesn't return anything at all. Looks like a typo. Signed-off-by: Jesse Millan <jessem@cs.pdx.edu> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
