Change-Id: Ib3b69ffc5ac3e07c9cc44cc49e9142088eec477e
This takes care of leaking uninitialized kernel stack memory to
userspace from non-zeroed fields in structs in compat ipc functions.
Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com>
Cc: Manfred Spraul <manfred@colorfullife.com>
Cc: <stable@kernel.org>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
When calling a semctl(IPC_STAT) without IPC_64 the check if the memory is
unevaluated. This patch fixes this.
The value of shmmax may be larger than will fit in the struct used by
the 32bit compat version of sys_shmctl. This change mirrors what the
normal sys_shmctl does when called with the old IPC_INFO command.
Signed-off-by: Guy Streeter <streeter@redhat.com>
Currently we allocate 64k space on the user stack and use it the msgbuf for
sys_{msgrcv,msgsnd} for compat and the results are later copied in user [
by copy_in_user]. This patch introduces helper routines for
sys_{msgrcv,msgsnd} as below:
do_msgsnd() : Accepts the mtype and user space ptr to the buffer along with
the msqid and msgflg.
do_msgrcv() : Accepts a kernel space ptr to mtype and a userspace ptr to
the buffer. The mtype has to be copied back the user space msgbuf by the
caller.
These changes avoid the need to allocate the msgsize on the userspace (
thus removing the size limt ) and the overhead of an extra copy_in_user().
Signed-off-by: Suzuki K P <suzuki@in.ibm.com>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
Semaphore to mutex conversion.
The conversion was generated via scripts, and the result was validated
automatically via a script as well.
Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com>
When I first wrote the compat layer patches, I was somewhat cavalier about
the definition of compat_uid_t and compat_gid_t (or maybe I just
misunderstood :-)). This patch makes the compat types much more consistent
with the types we are being compatible with and hopefully will fix a few
bugs along the way.
compat type type in compat arch
__compat_[ug]id_t __kernel_[ug]id_t
__compat_[ug]id32_t __kernel_[ug]id32_t
compat_[ug]id_t [ug]id_t
The difference is that compat_uid_t is always 32 bits (for the archs we
care about) but __compat_uid_t may be 16 bits on some.
GCC 4 complains because the function put_compat_shminfo() can't get to its
return statement if there is no error... If the function does not return
-EFAULT, it doesn't return anything at all. Looks like a typo.
Signed-off-by: Jesse Millan <jessem@cs.pdx.edu>
Signed-off-by: Domen Puncer <domen@coderock.org>
infrastructure for it.
Let it rip!
