path: root/ipc/mqueue.c
2009-06-29integrity: ima mq_open imbalance msg fixMimi Zohar
This patch fixes an imbalance message as reported by Sanchin Sant. As we don't need to measure the message queue, just increment the counters. Reported-by: Sanchin Sant <sanchinp@in.ibm.com> Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-04-07namespaces: mqueue namespace: adapt sysctlSerge E. Hallyn
Largely inspired from ipc/ipc_sysctl.c. This patch isolates the mqueue sysctl stuff in its own file. [akpm@linux-foundation.org: build fix] Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07namespaces: ipc namespaces: implement support for posix msqueuesSerge E. Hallyn
Implement multiple mounts of the mqueue file system, and link it to usage of CLONE_NEWIPC. Each ipc ns has a corresponding mqueuefs superblock. When a user does clone(CLONE_NEWIPC) or unshare(CLONE_NEWIPC), the unshare will cause an internal mount of a new mqueuefs sb linked to the new ipc ns. When a user does 'mount -t mqueue mqueue /dev/mqueue', he mounts the mqueuefs superblock. Posix message queues can be worked with both through the mq_* system calls (see mq_overview(7)), and through the VFS through the mqueue mount. Any usage of mq_open() and friends will work with the acting task's ipc namespace. Any actions through the VFS will work with the mqueuefs in which the file was created. So if a user doesn't remount mqueuefs after unshare(CLONE_NEWIPC), mq_open("/ab") will not be reflected in "ls /dev/mqueue". If task a mounts mqueue for ipc_ns:1, then clones task b with a new ipcns, ipcns:2, and then task a is the last task in ipc_ns:1 to exit, then (1) ipc_ns:1 will be freed, (2) it's superblock will live on until task b umounts the corresponding mqueuefs, and vfs actions will continue to succeed, but (3) sb->s_fs_info will be NULL for the sb corresponding to the deceased ipc_ns:1. To make this happen, we must protect the ipc reference count when a) a task exits and drops its ipcns->count, since it might be dropping it to 0 and freeing the ipcns b) a task accesses the ipcns through its mqueuefs interface, since it bumps the ipcns refcount and might race with the last task in the ipcns exiting. So the kref is changed to an atomic_t so we can use atomic_dec_and_lock(&ns->count,mq_lock), and every access to the ipcns through ns = mqueuefs_sb->s_fs_info is protected by the same lock. Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07namespaces: mqueue ns: move mqueue_mnt into struct ipc_namespaceSerge E. Hallyn
Move mqueue vfsmount plus a few tunables into the ipc_namespace struct. The CONFIG_IPC_NS boolean and the ipc_namespace struct will serve both the posix message queue namespaces and the SYSV ipc namespaces. The sysctl code will be fixed separately in patch 3. After just this patch, making a change to posix mqueue tunables always changes the values in the initial ipc namespace. Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-31New helper - current_umask()Al Viro
current->fs->umask is what most of fs_struct users are doing. Put that into a helper function. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-16Use f_lock to protect f_flagsJonathan Corbet
Traditionally, changes to struct file->f_flags have been done under BKL protection, or with no protection at all. This patch causes all f_flags changes after file open/creation time to be done under protection of f_lock. This allows the removal of some BKL usage and fixes a number of longstanding (if microscopic) races. Reviewed-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2009-01-14[CVE-2009-0029] System call wrappers part 26Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 25Heiko Carstens
2009-01-14[CVE-2009-0029] Convert all system calls to return a longHeiko Carstens
Convert all system calls to return a long. This should be a NOP since all converted types should have the same size anyway. With the exception of sys_exit_group which returned void. But that doesn't matter since the system call doesn't return. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2009-01-08mqueue: fix si_pid value in mqueue do_notify()Sukadev Bhattiprolu
If a process registers for asynchronous notification on a POSIX message queue, it gets a signal and a siginfo_t structure when a message arrives on the message queue. The si_pid in the siginfo_t structure is set to the PID of the process that sent the message to the message queue. The principle is the following: . when mq_notify(SIGEV_SIGNAL) is called, the caller registers for notification when a msg arrives. The associated pid structure is stroed into inode_info->notify_owner. Let's call this process P1. . when mq_send() is called by say P2, P2 sends a signal to P1 to notify him about msg arrival. The way .si_pid is set today is not correct, since it doesn't take into account the fact that the process that is sending the message might not be in the same namespace as the notified one. This patch proposes to set si_pid to the sender's pid into the notify_owner namespace. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Acked-by: Oleg Nesterov <oleg@redhat.com> Cc: Roland McGrath <roland@redhat.com> Cc: Bastian Blank <bastian@waldi.eu.org> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: inotify: fix type errors in interfaces fix breakage in reiserfs_new_inode() fix the treatment of jfs special inodes vfs: remove duplicate code in get_fs_type() add a vfs_fsync helper sys_execve and sys_uselib do not call into fsnotify zero i_uid/i_gid on inode allocation inode->i_op is never NULL ntfs: don't NULL i_op isofs check for NULL ->i_op in root directory is dead code affs: do not zero ->i_op kill suid bit only for regular files vfs: lseek(fd, 0, SEEK_CUR) race condition
2009-01-05zero i_uid/i_gid on inode allocationAl Viro
... and don't bother in callers. Don't bother with zeroing i_blocks, while we are at it - it's already been zeroed. i_mode is not worth the effort; it has no common default value. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-04sanitize audit_mq_open()Al Viro
* don't bother with allocations * don't do double copy_from_user() * don't duplicate parts of check for audit_dummy_context() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-04sanitize AUDIT_MQ_SENDRECVAl Viro
* logging the original value of *msg_prio in mq_timedreceive(2) is insane - the argument is write-only (i.e. syscall always ignores the original value and only overwrites it). * merge __audit_mq_timed{send,receive} * don't do copy_from_user() twice * don't mess with allocations in auditsc part * ... and don't bother checking !audit_enabled and !context in there - we'd already checked for audit_dummy_context(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-04sanitize audit_mq_notify()Al Viro
* don't copy_from_user() twice * don't bother with allocations * don't duplicate parts of audit_dummy_context() * make it return void Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-04sanitize audit_mq_getsetattr()Al Viro
* get rid of allocations * make it return void * don't duplicate parts of audit_dummy_context() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-11-14CRED: Pass credentials through dentry_open()David Howells
Pass credentials through dentry_open() so that the COW creds patch can have SELinux's flush_unauthorized_files() pass the appropriate creds back to itself when it opens its null chardev. The security_dentry_open() call also now takes a creds pointer, as does the dentry_open hook in struct security_operations. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Wrap current->cred and a few other accessorsDavid Howells
Wrap current->cred and a few other accessors to hide their actual implementation. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Separate task security context from task_structDavid Howells
Separate the task security context from task_struct. At this point, the security data is temporarily embedded in the task_struct with two pointers pointing to it. Note that the Alpha arch is altered as it refers to (E)UID and (E)GID in entry.S via asm-offsets. With comment fixes Signed-off-by: Marc Dionne <marc.c.dionne@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Wrap task credential accesses in the SYSV IPC subsystemDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-10-20message queues: increase range limitsJoe Korty
Increase the range of various posix message queue limits. Posix gives the message queue user the ability to 'trade off' the maximum size of messages with the number of possible messages that can be 'in flight'. Linux currently makes this trade off more restrictive than it needs to be. In particular, the maximum message size today can be made no smaller than 8192. This greatly restricts those applications that would like to have the ability to post large numbers of very small messages. So this task lowers the limit that the maximum message size can be set to, from 8192 to 128. It also lowers the limit that the maximum #number of messages in flight can be set to, from 10 to 1. With these changes the message queue user can make better trade offs between #messages and message size, in order to get everything to fit within the setrlimit(RLIMIT_MSGQUEUE) limit for that particular user. This patch also applies the values in /proc/sys/fs/mqueue/msg_max /proc/sys/fs/mqueue/msgsize_max as the defaults for the max #messages allowed and the max message size allowed, respectively, for those applications that do not supply these. Previously, the defaults were hardwired to 10 and 8192, respectively. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Joe Korty <joe.korty@ccur.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26[PATCH] kill nameidata passing to permission(), rename to inode_permission()Al Viro
Incidentally, the name that gives hundreds of false positives on grep is not a good idea... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26SL*B: drop kmem cache argument from constructorAlexey Dobriyan
Kmem cache passed to constructor is only needed for constructors that are themselves multiplexeres. Nobody uses this "feature", nor does anybody uses passed kmem cache in non-trivial way, so pass only pointer to object. Non-trivial places are: arch/powerpc/mm/init_64.c arch/powerpc/mm/hugetlbpage.c This is flag day, yes. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Jon Tollefson <kniht@linux.vnet.ibm.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Matt Mackall <mpm@selenic.com> [akpm@linux-foundation.org: fix arch/powerpc/mm/hugetlbpage.c] [akpm@linux-foundation.org: fix mm/slab.c] [akpm@linux-foundation.org: fix ubifs] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25ipc: use simple_read_from_buffer()Akinobu Mita
Also this patch kills unneccesary trailing NULL character. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Pierre Peiffer <peifferp@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-05netlink: Remove nonblock parameter from netlink_attachskbDenis V. Lunev
Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-03tiny mq_open optimizationUlrich Drepper
A very small cleanup for mq_open. We do not have to call set_close_on_exit if we create the file descriptor right away with the flag set. We have a function for this now. The resulting code is smaller and a tiny bit faster. Signed-off-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-19[PATCH] r/o bind mounts: elevate write count for open()sDave Hansen
This is the first really tricky patch in the series. It elevates the writer count on a mount each time a non-special file is opened for write. We used to do this in may_open(), but Miklos pointed out that __dentry_open() is used as well to create filps. This will cover even those cases, while a call in may_open() would not have. There is also an elevated count around the vfs_create() call in open_namei(). See the comments for more details, but we need this to fix a 'create, remount, fail r/w open()' race. Some filesystems forego the use of normal vfs calls to create struct files. Make sure that these users elevate the mnt writer count because they will get __fput(), and we need to make sure they're balanced. Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-19[PATCH] r/o bind mounts: elevate write count for rmdir and unlink.Dave Hansen
Elevate the write count during the vfs_rmdir() and vfs_unlink(). [AV: merged rmdir and unlink parts, added missing pieces in nfsd] Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-02-08Pidns: fix badly converted mqueues pid handlingPavel Emelyanov
When sending the pid namespaces patches I wrongly converted the tsk->tgid into task_pid_vnr(tsk) in mqueue-s (the git id of this patch is b488893a390edfe027bae7a46e9af8083e740668). The proper behavior is to get the task_tgid_vnr(tsk). This seem to be the only mistake of that kind. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08Pidns: make full use of xxx_vnr() callsPavel Emelyanov
Some time ago the xxx_vnr() calls (e.g. pid_vnr or find_task_by_vpid) were _all_ converted to operate on the current pid namespace. After this each call like xxx_nr_ns(foo, current->nsproxy->pid_ns) is nothing but a xxx_vnr(foo) one. Switch all the xxx_nr_ns() callers to use the xxx_vnr() calls where appropriate. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Reviewed-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-29ipc: lost unlock and fput in mqueue.c on error pathPavel Emelyanov
The error path in sys_mq_getsetattr() after the call to audit_mq_getsetattr() is wrong - the info->lock is not unlocked and the struct file *filp is not put. Fix them both. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Pierre Peiffer <pierre.peiffer@bull.net> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-07[NETLINK]: Fix unicast timeoutsPatrick McHardy
Commit ed6dcf4a in the history.git tree broke netlink_unicast timeouts by moving the schedule_timeout() call to a new function that doesn't propagate the remaining timeout back to the caller. This means on each retry we start with the full timeout again. ipc/mqueue.c seems to actually want to wait indefinitely so this behaviour is retained. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-21[PATCH] pass dentry to audit_inode()/audit_inode_child()Al Viro
makes caller simpler *and* allows to scan ancestors Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2007-10-19pid namespaces: changes to show virtual ids to userPavel Emelyanov
This is the largest patch in the set. Make all (I hope) the places where the pid is shown to or get from user operate on the virtual pids. The idea is: - all in-kernel data structures must store either struct pid itself or the pid's global nr, obtained with pid_nr() call; - when seeking the task from kernel code with the stored id one should use find_task_by_pid() call that works with global pids; - when showing pid's numerical value to the user the virtual one should be used, but however when one shows task's pid outside this task's namespace the global one is to be used; - when getting the pid from userspace one need to consider this as the virtual one and use appropriate task/pid-searching functions. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: nuther build fix] [akpm@linux-foundation.org: yet nuther build fix] [akpm@linux-foundation.org: remove unneeded casts] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Paul Menage <menage@google.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18sysctl mqueue: remove the binary sysctl numbersEric W. Biederman
Because of a conflict with FS_INODE_NR none of the binary sysctl numbers use by mqueue, were available to user space. So just remove them. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Alexey Dobriyan <adobriyan@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Slab API: remove useless ctor parameter and reorder parametersChristoph Lameter
Slab constructors currently have a flags parameter that is never used. And the order of the arguments is opposite to other slab functions. The object pointer is placed before the kmem_cache pointer. Convert ctor(void *object, struct kmem_cache *s, unsigned long flags) to ctor(struct kmem_cache *s, void *object) throughout the kernel [akpm@linux-foundation.org: coupla fixes] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-10[NET]: cleanup 3rd argument in netlink_sendskbDenis V. Lunev
netlink_sendskb does not use third argument. Clean it and save a couple of bytes. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-11[PATCH] complete message queue auditingAmy Griffis
Handle the edge cases for POSIX message queue auditing. Collect inode info when opening an existing mq, and for send/receive operations. Remove audit_inode_update() as it has really evolved into the equivalent of audit_inode(). Signed-off-by: Amy Griffis <amy.griffis@hp.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2007-03-06[PATCH] mqueue: nested locking annotationPeter Zijlstra
Fix http://bugzilla.kernel.org/show_bug.cgi?id=8130 Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: remove insert_at_head from register_sysctlEric W. Biederman
The semantic effect of insert_at_head is that it would allow new registered sysctl entries to override existing sysctl entries of the same name. Which is pain for caching and the proc interface never implemented. I have done an audit and discovered that none of the current users of register_sysctl care as (excpet for directories) they do not register duplicate sysctl entries. So this patch simply removes the support for overriding existing entries in the sys_sysctl interface since no one uses it or cares and it makes future enhancments harder. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Howells <dhowells@redhat.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Andi Kleen <ak@muc.de> Cc: Jens Axboe <axboe@kernel.dk> Cc: Corey Minyard <minyard@acm.org> Cc: Neil Brown <neilb@suse.de> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Jan Kara <jack@ucw.cz> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: David Chinner <dgc@sgi.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct inode_operations const 2Arjan van de Ven
2007-02-12[PATCH] mark struct file_operations const 7Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] struct path: convert ipcJosef Sipek
2006-10-03Michal Wronski: update contact infoMichal Wronski
My email has changed. Signed-Off-By: Michal Wronski <michal.wronski@gmail.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-02[PATCH] update mq_notify to use a struct pidCedric Le Goater
Message queues can signal a process waiting for a message. This patch replaces the pid_t value with a struct pid to avoid pid wrap around problems. Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Acked-by: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
