path: root/ipc/mqueue.c
2006-03-28[PATCH] mqueue comment typo fixSerge E. Hallyn
(akpm: I don't do comment typos patches. This one snuck through by accident) Signed-off-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] one ipc/sem.c->mutex.c converstion too many..Manfred Spraul
Ingo's sem2mutex patch incorrectly replaced one reference to ipc/sem.c with ipc/mutex.c in a comment. Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] sem2mutex: ipc, id.semIngo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22Remove superfluous NOTIFY_COOKIE_LEN defineMichal Wronski
NOTIFY_COOKIE_LEN is defined in mqueue.h as well as mqueue.c This patch removes redundant definition from mqueue.c Signed-off-by: Michal Wronski <Michal.Wronski@motorola.com> Signed-Off-By: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-02-09[NETLINK]: Fix a severe bugAlexey Kuznetsov
netlink overrun was broken while improvement of netlink. Destination socket is used in the place where it was meant to be source socket, so that now overrun is never sent to user netlink sockets, when it should be, and it even can be set on kernel socket, which results in complete deadlock of rtnetlink. Suggested fix is to restore status quo passing source socket as additional argument to netlink_attachskb(). A little explanation: overrun is set on a socket, when it failed to receive some message and sender of this messages does not or even have no way to handle this error. This happens in two cases: 1. when kernel sends something. Kernel never retransmits and cannot wait for buffer space. 2. when user sends a broadcast and the message was not delivered to some recipients. Signed-off-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-14[PATCH] Fix double decrement of mqueue_mnt->mnt_count in sys_mq_openAlexander Viro
Fixed the refcounting on failure exits in sys_mq_open() and cleaned the logics up. Rules are actually pretty simple - dentry_open() expects vfsmount and dentry to be pinned down and it either transfers them into created struct file or drops them. Old code had been very confused in that area - if dentry_open() had failed either in do_open() or do_create(), we ended up dentry and mqueue_mnt dropped twice, once by dentry_open() cleanup and then by sys_mq_open(). Fix consists of making the rules for do_create() and do_open() same as for dentry_open() and updating the sys_mq_open() accordingly; that actually leads to more straightforward code and less work on normal path. Signed-off-by: Al Viro <aviro@redhat.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[PATCH] move capable() to capability.hRandy.Dunlap
- Move capable() from sched.h to capability.h; - Use <linux/capability.h> where capable() is used (in include/, block/, ipc/, kernel/, a few drivers/, mm/, security/, & sound/; many more drivers/ to go) Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2005-11-06Update Michal Wronski contact infoMichal Wronski
2005-09-27[PATCH] Make POSIX message queue sys_mq_open() honor umaskKrzysztof Benedyczak
We ignored umask when creating new queues via mq_open (when creating with open() on mqueue fs it is ok of course). According to the specification this a bug. This trivial patch fixes this. Signed-off-by: Krzysztof Benedyczak <golbi@mat.uni.torun.pl> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-10[PATCH] merge some from Rusty's trivial patchesAdrian Bunk
This patch contains the most trivial from Rusty's trivial patches: - spelling fixes - remove duplicate includes Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] convert that currently tests _NSIG directly to use valid_signal()Jesper Juhl
Convert most of the current code that uses _NSIG directly to instead use valid_signal(). This avoids gcc -W warnings and off-by-one errors. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] use smp_mb/wmb/rmb where possibleakpm@osdl.org
Replace a number of memory barriers with smp_ variants. This means we won't take the unnecessary hit on UP machines. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
