path: root/ipc/namespace.c
2019-02-28ipc: Convert mqueue fs to fs_contextDavid Howells
Convert the mqueue filesystem to use the filesystem context stuff. Notes: (1) The relevant ipc namespace is selected in when the context is initialised (and it defaults to the current task's ipc namespace). The caller can override this before calling vfs_get_tree(). (2) Rather than simply calling kern_mount_data(), mq_init_ns() and mq_internal_mount() create a context, adjust it and then do the rest of the mount procedure. (3) The lazy mqueue mounting on creation of a new namespace is retained from a previous patch, but the avoidance of sget() if no superblock yet exists is reverted and the superblock is again keyed on the namespace pointer. Yes, there was a performance gain in not searching the superblock hash, but it's only paid once per ipc namespace - and only if someone uses mqueue within that namespace, so I'm not sure it's worth it, especially as calling sget() allows avoidance of recursion. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2018-08-22ipc: simplify ipc initializationDavidlohr Bueso
Now that we know that rhashtable_init() will not fail, we can get rid of a lot of the unnecessary cleanup paths when the call errored out. [manfred@colorfullife.com: variable name added to util.h to resolve checkpatch warning] Link: http://lkml.kernel.org/r/20180712185241.4017-11-manfred@colorfullife.com Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Kees Cook <keescook@chromium.org> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Michal Hocko <mhocko@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-08ipc: optimize semget/shmget/msgget for lots of keysGuillaume Knispel
ipc_findkey() used to scan all objects to look for the wanted key. This is slow when using a high number of keys. This change adds an rhashtable of kern_ipc_perm objects in ipc_ids, so that one lookup cease to be O(n). This change gives a 865% improvement of benchmark reaim.jobs_per_min on a 56 threads Intel(R) Xeon(R) CPU E5-2695 v3 @ 2.30GHz with 256G memory [1] Other (more micro) benchmark results, by the author: On an i5 laptop, the following loop executed right after a reboot took, without and with this change: for (int i = 0, k=0x424242; i < KEYS; ++i) semget(k++, 1, IPC_CREAT | 0600); total total max single max single KEYS without with call without call with 1 3.5 4.9 µs 3.5 4.9 10 7.6 8.6 µs 3.7 4.7 32 16.2 15.9 µs 4.3 5.3 100 72.9 41.8 µs 3.7 4.7 1000 5,630.0 502.0 µs * * 10000 1,340,000.0 7,240.0 µs * * 31900 17,600,000.0 22,200.0 µs * * *: unreliable measure: high variance The duration for a lookup-only usage was obtained by the same loop once the keys are present: total total max single max single KEYS without with call without call with 1 2.1 2.5 µs 2.1 2.5 10 4.5 4.8 µs 2.2 2.3 32 13.0 10.8 µs 2.3 2.8 100 82.9 25.1 µs * 2.3 1000 5,780.0 217.0 µs * * 10000 1,470,000.0 2,520.0 µs * * 31900 17,400,000.0 7,810.0 µs * * Finally, executing each semget() in a new process gave, when still summing only the durations of these syscalls: creation: total total KEYS without with 1 3.7 5.0 µs 10 32.9 36.7 µs 32 125.0 109.0 µs 100 523.0 353.0 µs 1000 20,300.0 3,280.0 µs 10000 2,470,000.0 46,700.0 µs 31900 27,800,000.0 219,000.0 µs lookup-only: total total KEYS without with 1 2.5 2.7 µs 10 25.4 24.4 µs 32 106.0 72.6 µs 100 591.0 352.0 µs 1000 22,400.0 2,250.0 µs 10000 2,510,000.0 25,700.0 µs 31900 28,200,000.0 115,000.0 µs [1] http://lkml.kernel.org/r/20170814060507.GE23258@yexl-desktop Link: http://lkml.kernel.org/r/20170815194954.ck32ta2z35yuzpwp@debix Signed-off-by: Guillaume Knispel <guillaume.knispel@supersonicimagine.com> Reviewed-by: Marc Pardo <marc.pardo@supersonicimagine.com> Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: Kees Cook <keescook@chromium.org> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: "Peter Zijlstra (Intel)" <peterz@infradead.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Serge Hallyn <serge@hallyn.com> Cc: Andrey Vagin <avagin@openvz.org> Cc: Guillaume Knispel <guillaume.knispel@supersonicimagine.com> Cc: Marc Pardo <marc.pardo@supersonicimagine.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-09-08ipc: convert ipc_namespace.count from atomic_t to refcount_tElena Reshetova
refcount_t type and corresponding API should be used instead of atomic_t when the variable is used as a reference counter. This allows to avoid accidental refcounter overflows that might lead to use-after-free situations. Link: http://lkml.kernel.org/r/1499417992-3238-2-git-send-email-elena.reshetova@intel.com Signed-off-by: Elena Reshetova <elena.reshetova@intel.com> Signed-off-by: Hans Liljestrand <ishkamiel@gmail.com> Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: David Windsor <dwindsor@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Serge Hallyn <serge@hallyn.com> Cc: <arozansk@redhat.com> Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-03-02sched/headers: Prepare to move the task_lock()/unlock() APIs to ↵Ingo Molnar
<linux/sched/task.h> But first update the code that uses these facilities with the new header. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-03-02sched/headers: Prepare to remove <linux/cred.h> inclusion from <linux/sched.h>Ingo Molnar
Add #include <linux/cred.h> dependencies to all .c files rely on sched.h doing that for them. Note that even if the count where we need to add extra headers seems high, it's still a net win, because <linux/sched.h> is included in over 2,200 files ... Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-09-22Merge branch 'nsfs-ioctls' into HEADEric W. Biederman
From: Andrey Vagin <avagin@openvz.org> Each namespace has an owning user namespace and now there is not way to discover these relationships. Pid and user namepaces are hierarchical. There is no way to discover parent-child relationships too. Why we may want to know relationships between namespaces? One use would be visualization, in order to understand the running system. Another would be to answer the question: what capability does process X have to perform operations on a resource governed by namespace Y? One more use-case (which usually called abnormal) is checkpoint/restart. In CRIU we are going to dump and restore nested namespaces. There [1] was a discussion about which interface to choose to determing relationships between namespaces. Eric suggested to add two ioctl-s [2]: > Grumble, Grumble. I think this may actually a case for creating ioctls > for these two cases. Now that random nsfs file descriptors are bind > mountable the original reason for using proc files is not as pressing. > > One ioctl for the user namespace that owns a file descriptor. > One ioctl for the parent namespace of a namespace file descriptor. Here is an implementaions of these ioctl-s. $ man man7/namespaces.7 ... Since Linux 4.X, the following ioctl(2) calls are supported for namespace file descriptors. The correct syntax is: fd = ioctl(ns_fd, ioctl_type); where ioctl_type is one of the following: NS_GET_USERNS Returns a file descriptor that refers to an owning user names‐ pace. NS_GET_PARENT Returns a file descriptor that refers to a parent namespace. This ioctl(2) can be used for pid and user namespaces. For user namespaces, NS_GET_PARENT and NS_GET_USERNS have the same meaning. In addition to generic ioctl(2) errors, the following specific ones can occur: EINVAL NS_GET_PARENT was called for a nonhierarchical namespace. EPERM The requested namespace is outside of the current namespace scope. [1] https://lkml.org/lkml/2016/7/6/158 [2] https://lkml.org/lkml/2016/7/9/101 Changes for v2: * don't return ENOENT for init_user_ns and init_pid_ns. There is nothing outside of the init namespace, so we can return EPERM in this case too. > The fewer special cases the easier the code is to get > correct, and the easier it is to read. // Eric Changes for v3: * rename ns->get_owner() to ns->owner(). get_* usually means that it grabs a reference. Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: "Michael Kerrisk (man-pages)" <mtk.manpages@gmail.com> Cc: "W. Trevor King" <wking@tremily.us> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Serge Hallyn <serge.hallyn@canonical.com>
2016-09-22kernel: add a helper to get an owning user namespace for a namespaceAndrey Vagin
Return -EPERM if an owning user namespace is outside of a process current user namespace. v2: In a first version ns_get_owner returned ENOENT for init_user_ns. This special cases was removed from this version. There is nothing outside of init_user_ns, so we can return EPERM. v3: rename ns->get_owner() to ns->owner(). get_* usually means that it grabs a reference. Acked-by: Serge Hallyn <serge@hallyn.com> Signed-off-by: Andrei Vagin <avagin@openvz.org> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2016-09-22userns: When the per user per user namespace limit is reached return ENOSPCEric W. Biederman
The current error codes returned when a the per user per user namespace limit are hit (EINVAL, EUSERS, and ENFILE) are wrong. I asked for advice on linux-api and it we made clear that those were the wrong error code, but a correct effor code was not suggested. The best general error code I have found for hitting a resource limit is ENOSPC. It is not perfect but as it is unambiguous it will serve until someone comes up with a better error code. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2016-08-08ipcns: Add a limit on the number of ipc namespacesEric W. Biederman
Acked-by: Kees Cook <keescook@chromium.org> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2016-08-02ipc: delete "nr_ipc_ns"Alexey Dobriyan
Write-only variable. Link: http://lkml.kernel.org/r/20160708214356.GA6785@p183.telecom.by Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-06-23ipc: Initialize ipc_namespace->user_ns early.Eric W. Biederman
Allow the ipc namespace initialization code to depend on ns->user_ns being set during initialization. In particular this allows mq_init_ns to use ns->user_ns for permission checks and initializating s_user_ns while the the mq filesystem is being mounted. Acked-by: Seth Forshee <seth.forshee@canonical.com> Suggested-by: Seth Forshee <seth.forshee@canonical.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2014-12-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile #2 from Al Viro: "Next pile (and there'll be one or two more). The large piece in this one is getting rid of /proc/*/ns/* weirdness; among other things, it allows to (finally) make nameidata completely opaque outside of fs/namei.c, making for easier further cleanups in there" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: coda_venus_readdir(): use file_inode() fs/namei.c: fold link_path_walk() call into path_init() path_init(): don't bother with LOOKUP_PARENT in argument fs/namei.c: new helper (path_cleanup()) path_init(): store the "base" pointer to file in nameidata itself make default ->i_fop have ->open() fail with ENXIO make nameidata completely opaque outside of fs/namei.c kill proc_ns completely take the targets of /proc/*/ns/* symlinks to separate fs bury struct proc_ns in fs/proc copy address of proc_ns_ops into ns_common new helpers: ns_alloc_inum/ns_free_inum make proc_ns_operations work with struct ns_common * instead of void * switch the rest of proc_ns_operations to working with &...->ns netns: switch ->get()/->put()/->install()/->inum() to working with &net->ns make mntns ->get()/->put()/->install()/->inum() work with &mnt_ns->ns common object embedded into various struct ....ns
2014-12-13ipc/msg: increase MSGMNI, remove scalingManfred Spraul
SysV can be abused to allocate locked kernel memory. For most systems, a small limit doesn't make sense, see the discussion with regards to SHMMAX. Therefore: increase MSGMNI to the maximum supported. And: If we ignore the risk of locking too much memory, then an automatic scaling of MSGMNI doesn't make sense. Therefore the logic can be removed. The code preserves auto_msgmni to avoid breaking any user space applications that expect that the value exists. Notes: 1) If an administrator must limit the memory allocations, then he can set MSGMNI as necessary. Or he can disable sysv entirely (as e.g. done by Android). 2) MSGMAX and MSGMNB are intentionally not increased, as these values are used to control latency vs. throughput: If MSGMNB is large, then msgsnd() just returns and more messages can be queued before a task switch to a task that calls msgrcv() is forced. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: Rafael Aquini <aquini@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-04copy address of proc_ns_ops into ns_commonAl Viro
2014-12-04new helpers: ns_alloc_inum/ns_free_inumAl Viro
take struct ns_common *, for now simply wrappers around proc_{alloc,free}_inum() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-12-04make proc_ns_operations work with struct ns_common * instead of void *Al Viro
We can do that now. And kill ->inum(), while we are at it - all instances are identical. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-12-04switch the rest of proc_ns_operations to working with &...->nsAl Viro
2014-12-04common object embedded into various struct ....nsAl Viro
for now - just move corresponding ->proc_inum instances over there Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-07-29namespaces: Use task_lock and not rcu to protect nsproxyEric W. Biederman
The synchronous syncrhonize_rcu in switch_task_namespaces makes setns a sufficiently expensive system call that people have complained. Upon inspect nsproxy no longer needs rcu protection for remote reads. remote reads are rare. So optimize for same process reads and write by switching using rask_lock instead. This yields a simpler to understand lock, and a faster setns system call. In particular this fixes a performance regression observed by Rafael David Tinoco <rafael.tinoco@canonical.com>. This is effectively a revert of Pavel Emelyanov's commit cf7b708c8d1d7a27736771bcf4c457b332b0f818 Make access to task's nsproxy lighter from 2007. The race this originialy fixed no longer exists as do_notify_parent uses task_active_pid_ns(parent) instead of parent->nsproxy. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-09-11ipc: drop ipc_lock_by_ptrDavidlohr Bueso
After previous cleanups and optimizations, this function is no longer heavily used and we don't have a good reason to keep it. Update the few remaining callers and get rid of it. Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11ipc: rename ids->rw_mutexDavidlohr Bueso
Since in some situations the lock can be shared for readers, we shouldn't be calling it a mutex, rename it to rwsem. Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-30userns: Kill nsown_capable it makes the wrong thing easyEric W. Biederman
nsown_capable is a special case of ns_capable essentially for just CAP_SETUID and CAP_SETGID. For the existing users it doesn't noticably simplify things and from the suggested patches I have seen it encourages people to do the wrong thing. So remove nsown_capable. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-05-01proc: Split the namespace stuff out into linux/proc_ns.hDavid Howells
Split the proc namespace stuff out into linux/proc_ns.h. Signed-off-by: David Howells <dhowells@redhat.com> cc: netdev@vger.kernel.org cc: Serge E. Hallyn <serge.hallyn@ubuntu.com> cc: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-12-14userns: Require CAP_SYS_ADMIN for most uses of setns.Eric W. Biederman
Andy Lutomirski <luto@amacapital.net> found a nasty little bug in the permissions of setns. With unprivileged user namespaces it became possible to create new namespaces without privilege. However the setns calls were relaxed to only require CAP_SYS_ADMIN in the user nameapce of the targed namespace. Which made the following nasty sequence possible. pid = clone(CLONE_NEWUSER | CLONE_NEWNS); if (pid == 0) { /* child */ system("mount --bind /home/me/passwd /etc/passwd"); } else if (pid != 0) { /* parent */ char path[PATH_MAX]; snprintf(path, sizeof(path), "/proc/%u/ns/mnt"); fd = open(path, O_RDONLY); setns(fd, 0); system("su -"); } Prevent this possibility by requiring CAP_SYS_ADMIN in the current user namespace when joing all but the user namespace. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-11-20proc: Usable inode numbers for the namespace file descriptors.Eric W. Biederman
Assign a unique proc inode to each namespace, and use that inode number to ensure we only allocate at most one proc inode for every namespace in proc. A single proc inode per namespace allows userspace to test to see if two processes are in the same namespace. This has been a long requested feature and only blocked because a naive implementation would put the id in a global space and would ultimately require having a namespace for the names of namespaces, making migration and certain virtualization tricks impossible. We still don't have per superblock inode numbers for proc, which appears necessary for application unaware checkpoint/restart and migrations (if the application is using namespace file descriptors) but that is now allowd by the design if it becomes important. I have preallocated the ipc and uts initial proc inode numbers so their structures can be statically initialized. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-11-20userns: Make create_new_namespaces take a user_ns parameterEric W. Biederman
Modify create_new_namespaces to explicitly take a user namespace parameter, instead of implicitly through the task_struct. This allows an implementation of unshare(CLONE_NEWUSER) where the new user namespace is not stored onto the current task_struct until after all of the namespaces are created. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-11-20userns: Allow unprivileged use of setns.Eric W. Biederman
- Push the permission check from the core setns syscall into the setns install methods where the user namespace of the target namespace can be determined, and used in a ns_capable call. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-04-07userns: Use cred->user_ns instead of cred->user->user_nsEric W. Biederman
Optimize performance and prepare for the removal of the user_ns reference from user_struct. Remove the slow long walk through cred->user->user_ns and instead go straight to cred->user_ns. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2011-05-10ns proc: Add support for the ipc namespaceEric W. Biederman
Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2011-03-25ipcns: fix use after free in free_ipc_ns()Xiaotian Feng
commit b515498 ("userns: add a user namespace owner of ipc ns") added a user namespace owner of ipc ns, but it also introduced a use after free in free_ipc_ns(). Signed-off-by: Xiaotian Feng <dfeng@redhat.com> Acked-by: "Serge E. Hallyn" <serge.hallyn@canonical.com> Acked-by: David Howells <dhowells@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Daniel Lezcano <daniel.lezcano@free.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23userns: user namespaces: convert several capable() callsSerge E. Hallyn
CAP_IPC_OWNER and CAP_IPC_LOCK can be checked against current_user_ns(), because the resource comes from current's own ipc namespace. setuid/setgid are to uids in own namespace, so again checks can be against current_user_ns(). Changelog: Jan 11: Use task_ns_capable() in place of sched_capable(). Jan 11: Use nsown_capable() as suggested by Bastian Blank. Jan 11: Clarify (hopefully) some logic in futex and sched.c Feb 15: use ns_capable for ipc, not nsown_capable Feb 23: let copy_ipcs handle setting ipc_ns->user_ns Feb 23: pass ns down rather than taking it from current [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23userns: add a user namespace owner of ipc nsSerge E. Hallyn
Changelog: Feb 15: Don't set new ipc->user_ns if we didn't create a new ipc_ns. Feb 23: Move extern declaration to ipc_namespace.h, and group fwd declarations at top. Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18ipcns: make free_ipc_ns() staticAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18ipcns: extract create_ipc_ns()Alexey Dobriyan
clone_ipc_ns() is misnamed, it doesn't clone anything and doesn't use passed parameter. Rename it. create_ipc_ns() will be used by C/R to create fresh ipcns. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18ipcns: remove useless get/put while CLONE_NEWIPCAlexey Dobriyan
copy_ipcs() doesn't actually copy anything. If new ipcns is created, it's created from scratch, in this case get/put on old ipcns isn't needed. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07namespaces: ipc namespaces: implement support for posix msqueuesSerge E. Hallyn
Implement multiple mounts of the mqueue file system, and link it to usage of CLONE_NEWIPC. Each ipc ns has a corresponding mqueuefs superblock. When a user does clone(CLONE_NEWIPC) or unshare(CLONE_NEWIPC), the unshare will cause an internal mount of a new mqueuefs sb linked to the new ipc ns. When a user does 'mount -t mqueue mqueue /dev/mqueue', he mounts the mqueuefs superblock. Posix message queues can be worked with both through the mq_* system calls (see mq_overview(7)), and through the VFS through the mqueue mount. Any usage of mq_open() and friends will work with the acting task's ipc namespace. Any actions through the VFS will work with the mqueuefs in which the file was created. So if a user doesn't remount mqueuefs after unshare(CLONE_NEWIPC), mq_open("/ab") will not be reflected in "ls /dev/mqueue". If task a mounts mqueue for ipc_ns:1, then clones task b with a new ipcns, ipcns:2, and then task a is the last task in ipc_ns:1 to exit, then (1) ipc_ns:1 will be freed, (2) it's superblock will live on until task b umounts the corresponding mqueuefs, and vfs actions will continue to succeed, but (3) sb->s_fs_info will be NULL for the sb corresponding to the deceased ipc_ns:1. To make this happen, we must protect the ipc reference count when a) a task exits and drops its ipcns->count, since it might be dropping it to 0 and freeing the ipcns b) a task accesses the ipcns through its mqueuefs interface, since it bumps the ipcns refcount and might race with the last task in the ipcns exiting. So the kref is changed to an atomic_t so we can use atomic_dec_and_lock(&ns->count,mq_lock), and every access to the ipcns through ns = mqueuefs_sb->s_fs_info is protected by the same lock. Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07namespaces: mqueue ns: move mqueue_mnt into struct ipc_namespaceSerge E. Hallyn
Move mqueue vfsmount plus a few tunables into the ipc_namespace struct. The CONFIG_IPC_NS boolean and the ipc_namespace struct will serve both the posix message queue namespaces and the SYSV ipc namespaces. The sysctl code will be fixed separately in patch 3. After just this patch, making a change to posix mqueue tunables always changes the values in the initial ipc namespace. Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29ipc: recompute msgmni on ipc namespace creation/removalNadia Derbey
Introduce a notification mechanism that aims at recomputing msgmni each time an ipc namespace is created or removed. The ipc namespace notifier chain already defined for memory hotplug management is used for that purpose too. Each time a new ipc namespace is allocated or an existing ipc namespace is removed, the ipcns notifier chain is notified. The callback routine for each registered ipc namespace is then activated in order to recompute msgmni for that namespace. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Mingming Cao <cmm@us.ibm.com> Cc: Pierre Peiffer <pierre.peiffer@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29ipc: recompute msgmni on memory add / removeNadia Derbey
Introduce the registration of a callback routine that recomputes msg_ctlmni upon memory add / remove. A single notifier block is registered in the hotplug memory chain for all the ipc namespaces. Since the ipc namespaces are not linked together, they have their own notification chain: one notifier_block is defined per ipc namespace. Each time an ipc namespace is created (removed) it registers (unregisters) its notifier block in (from) the ipcns chain. The callback routine registered in the memory chain invokes the ipcns notifier chain with the IPCNS_LOWMEM event. Each callback routine registered in the ipcns namespace, in turn, recomputes msgmni for the owning namespace. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Mingming Cao <cmm@us.ibm.com> Cc: Pierre Peiffer <pierre.peiffer@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29ipc: scale msgmni to the number of ipc namespacesNadia Derbey
Since all the namespaces see the same amount of memory (the total one) this patch introduces a new variable that counts the ipc namespaces and divides msg_ctlmni by this counter. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Mingming Cao <cmm@us.ibm.com> Cc: Pierre Peiffer <pierre.peiffer@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08IPC: consolidate sem_exit_ns(), msg_exit_ns() and shm_exit_ns()Pierre Peiffer
sem_exit_ns(), msg_exit_ns() and shm_exit_ns() are all called when an ipc_namespace is released to free all ipcs of each type. But in fact, they do the same thing: they loop around all ipcs to free them individually by calling a specific routine. This patch proposes to consolidate this by introducing a common function, free_ipcs(), that do the job. The specific routine to call on each individual ipcs is passed as parameter. For this, these ipc-specific 'free' routines are reworked to take a generic 'struct ipc_perm' as parameter. Signed-off-by: Pierre Peiffer <pierre.peiffer@bull.net> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08IPC: make struct ipc_ids static in ipc_namespacePierre Peiffer
Each ipc_namespace contains a table of 3 pointers to struct ipc_ids (3 for msg, sem and shm, structure used to store all ipcs) These 'struct ipc_ids' are dynamically allocated for each icp_namespace as the ipc_namespace itself (for the init namespace, they are initialized with pointers to static variables instead) It is so for historical reason: in fact, before the use of idr to store the ipcs, the ipcs were stored in tables of variable length, depending of the maximum number of ipc allowed. Now, these 'struct ipc_ids' have a fixed size. As they are allocated in any cases for each new ipc_namespace, there is no gain of memory in having them allocated separately of the struct ipc_namespace. This patch proposes to make this table static in the struct ipc_namespace. Thus, we can allocate all in once and get rid of all the code needed to allocate and free these ipc_ids separately. Signed-off-by: Pierre Peiffer <pierre.peiffer@bull.net> Acked-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08namespaces: move the IPC namespace under IPC_NS optionPavel Emelyanov
Currently the IPC namespace management code is spread over the ipc/*.c files. I moved this code into ipc/namespace.c file which is compiled out when needed. The linux/ipc_namespace.h file is used to store the prototypes of the functions in namespace.c and the stubs for NAMESPACES=n case. This is done so, because the stub for copy_ipc_namespace requires the knowledge of the CLONE_NEWIPC flag, which is in sched.h. But the linux/ipc.h file itself in included into many many .c files via the sys.h->sem.h sequence so adding the sched.h into it will make all these .c depend on sched.h which is not that good. On the other hand the knowledge about the namespaces stuff is required in 4 .c files only. Besides, this patch compiles out some auxiliary functions from ipc/sem.c, msg.c and shm.c files. It turned out that moving these functions into namespaces.c is not that easy because they use many other calls and macros from the original file. Moving them would make this patch complicated. On the other hand all these functions can be consolidated, so I will send a separate patch doing this a bit later. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Kirill Korotaev <dev@sw.ru> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
