[ Upstream commit f075faa300acc4f6301e348acde0a4580ed5f77c ]
In order for load/store tearing prevention to work, _all_ accesses to
the variable in question need to be done around READ and WRITE_ONCE()
macros. Ensure everyone does so for q->status variable for
semtimedop().
Link: http://lkml.kernel.org/r/20180717052654.676-1-dave@stgolabs.net
Signed-off-by: Davidlohr Bueso <dbueso@suse.de>
Cc: Manfred Spraul <manfred@colorfullife.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Pull ipc compat cleanup and 64-bit time_t from Al Viro:
"IPC copyin/copyout sanitizing, including 64bit time_t work from Deepa
Dinamani"
* 'work.ipc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
utimes: Make utimes y2038 safe
ipc: shm: Make shmid_kernel timestamps y2038 safe
ipc: sem: Make sem_array timestamps y2038 safe
ipc: msg: Make msg_queue timestamps y2038 safe
ipc: mqueue: Replace timespec with timespec64
ipc: Make sys_semtimedop() y2038 safe
get rid of SYSVIPC_COMPAT on ia64
semtimedop(): move compat to native
shmat(2): move compat to native
msgrcv(2), msgsnd(2): move compat to native
ipc(2): move compat to native
ipc: make use of compat ipc_perm helpers
semctl(): move compat to native
semctl(): separate all layout-dependent copyin/copyout
msgctl(): move compat to native
msgctl(): split the actual work from copyin/copyout
ipc: move compat shmctl to native
shmctl: split the work from copyin/copyout
ipc_findkey() used to scan all objects to look for the wanted key. This
is slow when using a high number of keys. This change adds an rhashtable
of kern_ipc_perm objects in ipc_ids, so that one lookup cease to be O(n).
This change gives a 865% improvement of benchmark reaim.jobs_per_min on a
56 threads Intel(R) Xeon(R) CPU E5-2695 v3 @ 2.30GHz with 256G memory [1]
Other (more micro) benchmark results, by the author: On an i5 laptop, the
following loop executed right after a reboot took, without and with this
change:
for (int i = 0, k=0x424242; i < KEYS; ++i)
semget(k++, 1, IPC_CREAT | 0600);
total total max single max single
KEYS without with call without call with
1 3.5 4.9 µs 3.5 4.9
10 7.6 8.6 µs 3.7 4.7
32 16.2 15.9 µs 4.3 5.3
100 72.9 41.8 µs 3.7 4.7
1000 5,630.0 502.0 µs * *
10000 1,340,000.0 7,240.0 µs * *
31900 17,600,000.0 22,200.0 µs * *
*: unreliable measure: high variance
The duration for a lookup-only usage was obtained by the same loop once
the keys are present:
1 2.1 2.5 µs 2.1 2.5
10 4.5 4.8 µs 2.2 2.3
32 13.0 10.8 µs 2.3 2.8
100 82.9 25.1 µs * 2.3
1000 5,780.0 217.0 µs * *
10000 1,470,000.0 2,520.0 µs * *
31900 17,400,000.0 7,810.0 µs * *
Finally, executing each semget() in a new process gave, when still
summing only the durations of these syscalls:
creation:
total total
KEYS without with
1 3.7 5.0 µs
10 32.9 36.7 µs
32 125.0 109.0 µs
100 523.0 353.0 µs
1000 20,300.0 3,280.0 µs
10000 2,470,000.0 46,700.0 µs
31900 27,800,000.0 219,000.0 µs
lookup-only:
total total
KEYS without with
1 2.5 2.7 µs
10 25.4 24.4 µs
32 106.0 72.6 µs
100 591.0 352.0 µs
1000 22,400.0 2,250.0 µs
10000 2,510,000.0 25,700.0 µs
31900 28,200,000.0 115,000.0 µs
[1] http://lkml.kernel.org/r/20170814060507.GE23258@yexl-desktop
Link: http://lkml.kernel.org/r/20170815194954.ck32ta2z35yuzpwp@debix
Signed-off-by: Guillaume Knispel <guillaume.knispel@supersonicimagine.com>
Reviewed-by: Marc Pardo <marc.pardo@supersonicimagine.com>
Cc: Davidlohr Bueso <dave@stgolabs.net>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: "Peter Zijlstra (Intel)" <peterz@infradead.org>
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: Serge Hallyn <serge@hallyn.com>
Cc: Andrey Vagin <avagin@openvz.org>
Cc: Guillaume Knispel <guillaume.knispel@supersonicimagine.com>
Cc: Marc Pardo <marc.pardo@supersonicimagine.com>
Replacing semop()'s kmalloc for kvmalloc was originally proposed by
Manfred on the premise that it can be called for large (than order-1)
sizes. For example, while Oracle recommends setting SEMOPM to a _minimum_
of 100, some distros[1] encourage the setting to be a factor of the amount
of db tasks (PROCESSES), which can get fishy for large systems (easily
going beyond 1000).
[1] An Example of Semaphore Settings
https://access.redhat.com/documentation/en-US/Red_Hat_Enterprise_Linux/5/html/Tuning_and_Optimizing_Red_Hat_Enterprise_Linux_for_Oracle_9i_and_10g_Databases/sect-Oracle_9i_and_10g_Tuning_Guide-Setting_Semaphores-An_Example_of_Semaphore_Settings.html
So let's just convert this to kvmalloc, just like the rest of the
allocations we do in ipc. While the fallback vmalloc obviously involves
more overhead, this by far the uncommon path, and it's better for the user
than just erroring out with kmalloc.
Link: http://lkml.kernel.org/r/20170803184136.13855-2-dave@stgolabs.net
... 'tis not used.
Link: http://lkml.kernel.org/r/20170803184136.13855-1-dave@stgolabs.net
refcount_t type and corresponding API should be used instead of atomic_t
when the variable is used as a reference counter. This allows to avoid
accidental refcounter overflows that might lead to use-after-free
situations.
Link: http://lkml.kernel.org/r/1499417992-3238-3-git-send-email-elena.reshetova@intel.com
Signed-off-by: Elena Reshetova <elena.reshetova@intel.com>
Signed-off-by: Hans Liljestrand <ishkamiel@gmail.com>
Signed-off-by: David Windsor <dwindsor@gmail.com>
Cc: <arozansk@redhat.com>
time_t is not y2038 safe. Replace all uses of
time_t by y2038 safe time64_t.
Similarly, replace the calls to get_seconds() with
y2038 safe ktime_get_real_seconds().
Note that this preserves fast access on 64 bit systems,
but 32 bit systems need sequence counters.
The syscall interface themselves are not changed as part of
the patch. They will be part of a different series.
Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
struct timespec is not y2038 safe on 32 bit machines.
Replace timespec with y2038 safe struct timespec64.
Note that the patch only changes the internals without
modifying the syscall interface. This will be part
of a separate series.
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu into core/rcu
Pull RCU updates from Paul E. McKenney:
- Removal of spin_unlock_wait()
- SRCU updates
- Torture-test updates
- Documentation updates
- Miscellaneous fixes
- CPU-hotplug fixes
- Miscellaneous non-RCU fixes
There is no agreed-upon definition of spin_unlock_wait()'s semantics,
and it appears that all callers could do just as well with a lock/unlock
pair. This commit therefore replaces the spin_unlock_wait() call in
exit_sem() with spin_lock() followed immediately by spin_unlock().
This should be safe from a performance perspective because exit_sem()
is rarely invoked in production.
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Andrea Parri <parri.andrea@gmail.com>
Acked-by: Manfred Spraul <manfred@colorfullife.com>
When building with the randstruct gcc plugin, the layout of the IPC
structs will be randomized, which requires any sub-structure accesses to
use container_of(). The proc display handlers were missing the needed
container_of()s since the iterator is passing in the top-level struct
kern_ipc_perm.
This would lead to crashes when running the "lsipc" program after the
system had IPC registered (e.g. after starting up Gnome):
general protection fault: 0000 [#1] PREEMPT SMP
RIP: 0010:shm_add_rss_swap.isra.1+0x13/0xa0
Call Trace:
sysvipc_shm_proc_show+0x5e/0x150
sysvipc_proc_show+0x1a/0x30
seq_read+0x2e9/0x3f0
Link: http://lkml.kernel.org/r/20170730205950.GA55841@beast
Fixes: 3859a271a003 ("randstruct: Mark various structs for randomization")
Reported-by: Dominik Brodowski <linux@dominikbrodowski.net>
Acked-by: Davidlohr Bueso <dave@stgolabs.net>
... and finally kill the sodding compat_convert_timespec()
The remaining users of __sem_free() can simply call kvfree() instead for
better readability.
[manfred@colorfullife.com: Rediff to keep rcu protection for security_sem_alloc()]
Link: http://lkml.kernel.org/r/20170525185107.12869-20-manfred@colorfullife.com
Signed-off-by: Manfred Spraul <manfred@colorfullife.com>
Only after ipc_addid() has succeeded will refcounting be used, so move
initialization into ipc_addid() and remove from open-coded *_alloc()
routines.
Link: http://lkml.kernel.org/r/20170525185107.12869-17-manfred@colorfullife.com
Loosely based on a patch from Kees Cook <keescook@chromium.org>:
- id and retval can be merged
- if ipc_addid() fails, then use call_rcu() directly.
The difference is that call_rcu is used for failed ipc_addid() calls, to
continue to guaranteed an rcu delay for security_sem_free().
Link: http://lkml.kernel.org/r/20170525185107.12869-14-manfred@colorfullife.com
Instead of using ipc_rcu_alloc() which only performs the refcount bump,
open code it to perform better sem-specific checks. This also allows
for sem_array structure layout to be randomized in the future.
[manfred@colorfullife.com: Rediff, because the memset was temporarily inside ipc_rcu_alloc()]
Link: http://lkml.kernel.org/r/20170525185107.12869-10-manfred@colorfullife.com
Avoid using ipc_rcu_free, since it just re-finds the original structure
pointer. For the pre-list-init failure path, there is no RCU needed,
since it was just allocated. It can be directly freed.
Link: http://lkml.kernel.org/r/20170525185107.12869-6-manfred@colorfullife.com
The only users of ipc_alloc() were ipc_rcu_alloc() and the on-heap
sem_io fall-back memory. Better to just open-code these to make things
easier to read.
[manfred@colorfullife.com: Rediff due to inclusion of memset() into ipc_rcu_alloc()]
Link: http://lkml.kernel.org/r/20170525185107.12869-5-manfred@colorfullife.com
ipc has two management structures that exist for every id:
- struct kern_ipc_perm, it contains e.g. the permissions.
- struct ipc_rcu, it contains the rcu head for rcu handling and the
refcount.
The patch merges both structures.
As a bonus, we may save one cacheline, because both structures are
cacheline aligned. In addition, it reduces the number of casts, instead
most codepaths can use container_of.
To simplify code, the ipc_rcu_alloc initializes the allocation to 0.
[manfred@colorfullife.com: really include the memset() into ipc_alloc_rcu()]
Link: http://lkml.kernel.org/r/564f8612-0601-b267-514f-a9f650ec9b32@colorfullife.com
Link: http://lkml.kernel.org/r/20170525185107.12869-3-manfred@colorfullife.com
sma->sem_base is initialized with
sma->sem_base = (struct sem *) &sma[1];
The current code has four problems:
- There is an unnecessary pointer dereference - sem_base is not needed.
- Alignment for struct sem only works by chance.
- The current code causes false positive for static code analysis.
- This is a cast between different non-void types, which the future
randstruct GCC plugin warns on.
And, as bonus, the code size gets smaller:
Before:
0 .text 00003770
After:
0 .text 0000374e
[manfred@colorfullife.com: s/[0]/[]/, per hch]
Link: http://lkml.kernel.org/r/20170525185107.12869-2-manfred@colorfullife.com
Link: http://lkml.kernel.org/r/20170515171912.6298-2-manfred@colorfullife.com
Cc: <1vier1@web.de>
Cc: Fabian Frederick <fabf@skynet.be>
<linux/sched/wake_q.h>
We are going to split <linux/sched/wake_q.h> out of <linux/sched.h>, which
will have to be picked up from other headers and a couple of .c files.
Create a trivial placeholder <linux/sched/wake_q.h> file that just
maps to <linux/sched.h> to make this patch obviously correct and
bisectable.
Include the new header in the files that are going to need it.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
sysv sem has two lock modes: One with per-semaphore locks, one lock mode
with a single global lock for the whole array. When switching from the
per-semaphore locks to the global lock, all per-semaphore locks must be
scanned for ongoing operations.
The patch adds a hysteresis for switching from the global lock to the
per semaphore locks. This reduces how often the per-semaphore locks
must be scanned.
Compared to the initial patch, this is a simplified solution: Setting
USE_GLOBAL_LOCK_HYSTERESIS to 1 restores the current behavior.
In theory, a workload with exactly 10 simple sops and then one complex
op now scales a bit worse, but this is pure theory: If there is
concurrency, the it won't be exactly 10:1:10:1:10:1:... If there is no
concurrency, then there is no need for scalability.
Link: http://lkml.kernel.org/r/1476851896-3590-3-git-send-email-manfred@colorfullife.com
Cc: <1vier1@web.de>
Cc: kernel test robot <xiaolong.ye@intel.com>
Cc: <felixh@informatik.uni-bremen.de>
a) The ACQUIRE in spin_lock() applies to the read, not to the store, at
least for powerpc. This forces to add a smp_mb() into the fast path.
b) The memory barrier provided by spin_unlock_wait() is right now arch
dependent.
Therefore: Use spin_lock()/spin_unlock() instead of spin_unlock_wait().
Advantage: faster single op semop calls(), observed +8.9% on x86. (the
other solution would be arch dependencies in ipc/sem).
Disadvantage: slower complex op semop calls, if (and only if) there are
no sleeping operations.
The next patch adds hysteresis, this further reduces the probability
that the slow path is used.
Link: http://lkml.kernel.org/r/1476851896-3590-2-git-send-email-manfred@colorfullife.com
Cc: <1vier1@web.de>
Based on the syzcaller test case from dvyukov:
https://gist.githubusercontent.com/dvyukov/d0e5efefe4d7d6daed829f5c3ca26a40/raw/08d0a261fe3c987bed04fbf267e08ba04bd533ea/gistfile1.txt
The slow (i.e.: failure to acquire) syscall exit from semtimedop()
incorrectly assumed that the the same lock is acquired as it was at the
initial syscall entry.
This is wrong:
- thread A: single semop semop(), sleeps
- thread B: multi semop semop(), sleeps
- thread A: woken up by signal/timeout
With this sequence, the initial sem_lock() call locks the per-semaphore
spinlock, and it is unlocked with sem_unlock(). The call at the syscall
return locks the global spinlock. Because locknum is not updated, the
following sem_unlock() call unlocks the per-semaphore spinlock, which is
actually not locked.
The fix is trivial: Use the return value from sem_lock.
Fixes: 370b262c896e ("ipc/sem: avoid idr tree lookup for interrupted semop")
Link: http://lkml.kernel.org/r/1482215645-22328-1-git-send-email-manfred@colorfullife.com
Reported-by: Johanna Abrahamsson <johanna@mjao.org>
Tested-by: Johanna Abrahamsson <johanna@mjao.org>
We can avoid the idr tree lookup (albeit possibly avoiding
idr_find_fast()) when being awoken in EINTR, as the semid will not
change in this context while blocked. Use the sma pointer directly and
take the sem_lock, then re-check for RMID races. We continue to
re-check the queue.status with the lock held such that we can detect
situations where we where are dealing with a spurious wakeup but another
task that holds the sem_lock updated the queue.status while we were
spinning for it. Once we take the lock it obviously won't change again.
Being the only caller, get rid of sem_obtain_lock() altogether.
Link: http://lkml.kernel.org/r/1478708774-28826-3-git-send-email-dave@stgolabs.net
Instead of using the reverse goto, we can simplify the flow and make it
more language natural by just doing do-while instead. One would hope
this is the standard way (or obviously just with a while bucle) that we
do wait/wakeup handling in the kernel. The exact same logic is kept,
just more indented.
Link: http://lkml.kernel.org/r/1478708774-28826-2-git-send-email-dave@stgolabs.net
... saves some LoC and looks cleaner than re-implementing the calls.
Link: http://lkml.kernel.org/r/1474225896-10066-6-git-send-email-dave@stgolabs.net
The compiler already does this, but make it explicit. This helper is
really small and also used in update_queue's main loop, which is O(N^2)
scanning. Inline and avoid the function overhead.
Link: http://lkml.kernel.org/r/1474225896-10066-5-git-send-email-dave@stgolabs.net
This is the main workhorse that deals with semop user calls such that
the waitforzero or semval update operations, on the set, can complete on
not as the sma currently stands. Currently, the set is iterated twice
(setting semval, then backwards for the sempid value). Slowpaths, and
particularly SEM_UNDO calls, must undo any altered sem when it is
detected that the caller must block or has errored-out.
With larger sets, there can occur situations where this involves a lot
of cycles and can obviously be a suboptimal use of cached resources in
shared memory. Ie, discarding CPU caches that are also calling semop
and have the sembuf cached (and can complete), while the current lock
holder doing the semop will block, error, or does a waitforzero
operation.
This patch proposes still iterating the set twice, but the first scan is
read-only, and we perform the actual updates afterward, once we know
that the call will succeed. In order to not suffer from the overhead of
dealing with sops that act on the same sem_num, such (rare) cases use
perform_atomic_semop_slow(), which is exactly what we have now.
Duplicates are detected before grabbing sem_lock, and uses simple a
32/64-bit hash array variable to based on the sem_num we are working on.
In addition add some comments to when we expect to the caller to block.
[colin.king@canonical.com: ensure we left shift a ULL rather than a 32 bit integer]
Link: http://lkml.kernel.org/r/20161028181129.7311-1-colin.king@canonical.com
Link: http://lkml.kernel.org/r/20160921194603.GB21438@linux-80c1.suse
Our sysv sems have been using the notion of lockless wakeups for a
while, ever since commit 0a2b9d4c7967 ("ipc/sem.c: move wake_up_process
out of the spinlock section"), in order to reduce the sem_lock hold
times. This in-house pending queue can be replaced by wake_q (just like
all the rest of ipc now), in that it provides the following advantages:
o Simplifies and gets rid of unnecessary code.
o We get rid of the IN_WAKEUP complexities. Given that wake_q_add()
grabs reference to the task, if awoken due to an unrelated event,
between the wake_q_add() and wake_up_q() window, we cannot race with
sys_exit and the imminent call to wake_up_process().
o By not spinning IN_WAKEUP, we no longer need to disable preemption.
In consequence, the wakeup paths (after schedule(), that is) must
acknowledge an external signal/event, as well spurious wakeup occurring
during the pending wakeup window. Obviously no changes in semantics
that could be visible to the user. The fastpath is _only_ for when we
know for sure that we were awoken due to a the waker's successful semop
call (queue.status is not -EINTR).
On a 48-core Haswell, running the ipcscale 'waitforzero' test, the
following is seen with increasing thread counts:
v4.8-rc5 v4.8-rc5
semopv2
Hmean sembench-sem-2 574733.00 ( 0.00%) 578322.00 ( 0.62%)
Hmean sembench-sem-8 811708.00 ( 0.00%) 824689.00 ( 1.59%)
Hmean sembench-sem-12 842448.00 ( 0.00%) 845409.00 ( 0.35%)
Hmean sembench-sem-21 933003.00 ( 0.00%) 977748.00 ( 4.80%)
Hmean sembench-sem-48 935910.00 ( 0.00%) 1004759.00 ( 7.36%)
Hmean sembench-sem-79 937186.00 ( 0.00%) 983976.00 ( 4.99%)
Hmean sembench-sem-234 974256.00 ( 0.00%) 1060294.00 ( 8.83%)
Hmean sembench-sem-265 975468.00 ( 0.00%) 1016243.00 ( 4.18%)
Hmean sembench-sem-296 991280.00 ( 0.00%) 1042659.00 ( 5.18%)
Hmean sembench-sem-327 975415.00 ( 0.00%) 1029977.00 ( 5.59%)
Hmean sembench-sem-358 1014286.00 ( 0.00%) 1049624.00 ( 3.48%)
Hmean sembench-sem-389 972939.00 ( 0.00%) 1043127.00 ( 7.21%)
Hmean sembench-sem-420 981909.00 ( 0.00%) 1056747.00 ( 7.62%)
Hmean sembench-sem-451 990139.00 ( 0.00%) 1051609.00 ( 6.21%)
Hmean sembench-sem-482 965735.00 ( 0.00%) 1040313.00 ( 7.72%)
[sfr@canb.auug.org.au: merge fix for WAKE_Q to DEFINE_WAKE_Q rename]
Link: http://lkml.kernel.org/r/20161122210410.5eca9fc2@canb.auug.org.au
Link: http://lkml.kernel.org/r/1474225896-10066-3-git-send-email-dave@stgolabs.net
obviously be paired with its _prepare()
counterpart. At least whenever possible, as there is no harm in calling
it bogusly as we do now in a few places. Immediate error semop(2) paths
that are far from ever having the task block can be simplified and avoid
a few unnecessary loads on their way out of the call as it is not deeply
nested.
Link: http://lkml.kernel.org/r/1474225896-10066-2-git-send-email-dave@stgolabs.net
In CONFIG_PREEMPT=n kernel a softlockup was observed while the for loop in
exit_sem. Apparently it's possible for the loop to take quite a long time
and it doesn't have a scheduling point in it. Since the codes is
executing under an rcu read section this may also cause rcu stalls, which
in turn block synchronize_rcu operations, which more or less de-stabilises
the whole system.
Fix this by introducing a cond_resched() at the beginning of the loop.
So this patch fixes the following:
NMI watchdog: BUG: soft lockup - CPU#10 stuck for 23s! [httpd:18119]
CPU: 10 PID: 18119 Comm: httpd Tainted: G O 4.4.20-clouder2 #6
Hardware name: Supermicro X10DRi/X10DRi, BIOS 1.1 04/14/2015
task: ffff88348d695280 ti: ffff881c95550000 task.ti: ffff881c95550000
RIP: 0010:[<ffffffff81614bc7>] [<ffffffff81614bc7>] _raw_spin_lock+0x17/0x30
RSP: 0018:ffff881c95553e40 EFLAGS: 00000246
RAX: 0000000000000000 RBX: ffff883161b1eea8 RCX: 000000000000000d
RDX: 0000000000000001 RSI: 000000000000000e RDI: ffff883161b1eea4
RBP: ffff881c95553ea0 R08: ffff881c95553e68 R09: ffff883fef376f88
R10: ffff881fffb58c20 R11: ffffea0072556600 R12: ffff883161b1eea0
R13: ffff88348d695280 R14: ffff883dec427000 R15: ffff8831621672a0
FS: 0000000000000000(0000) GS:ffff881fffb40000(0000) knlGS:0000000000000000
CR2: 00007f3b3723e020 CR3: 0000000001c0a000 CR4: 00000000001406e0
Call Trace:
? exit_sem+0x7c/0x280
do_exit+0x338/0xb40
do_group_exit+0x43/0xd0
SyS_exit_group+0x14/0x20
entry_SYSCALL_64_fastpath+0x16/0x6e
Link: http://lkml.kernel.org/r/1475154992-6363-1-git-send-email-kernel@kyup.com
Signed-off-by: Nikolay Borisov <kernel@kyup.com>
Cc: Herton R. Krzesinski <herton@redhat.com>
Commit 6d07b68ce16a ("ipc/sem.c: optimize sem_lock()") introduced a
race:
sem_lock has a fast path that allows parallel simple operations.
There are two reasons why a simple operation cannot run in parallel:
- a non-simple operations is ongoing (sma->sem_perm.lock held)
- a complex operation is sleeping (sma->complex_count != 0)
As both facts are stored independently, a thread can bypass the current
checks by sleeping in the right positions. See below for more details
(or kernel bugzilla 105651).
The patch fixes that by creating one variable (complex_mode)
that tracks both reasons why parallel operations are not possible.
The patch also updates stale documentation regarding the locking.
With regards to stable kernels:
The patch is required for all kernels that include the
commit 6d07b68ce16a ("ipc/sem.c: optimize sem_lock()") (3.10?)
The alternative is to revert the patch that introduced the race.
The patch is safe for backporting, i.e. it makes no assumptions
about memory barriers in spin_unlock_wait().
Background:
Here is the race of the current implementation:
Thread A: (simple op)
- does the first "sma->complex_count == 0" test
Thread B: (complex op)
- does sem_lock(): This includes an array scan. But the scan can't
find Thread A, because Thread A does not own sem->lock yet.
- the thread does the operation, increases complex_count,
drops sem_lock, sleeps
Thread A:
- spin_lock(&sem->lock), spin_is_locked(sma->sem_perm.lock)
- sleeps before the complex_count test
Thread C: (complex op)
- does sem_lock (no array scan, complex_count==1)
- wakes up Thread B.
- decrements complex_count
Thread A:
- does the complex_count test
Bug:
Now both thread A and thread C operate on the same array, without
any synchronization.
Fixes: 6d07b68ce16a ("ipc/sem.c: optimize sem_lock()")
Link: http://lkml.kernel.org/r/1469123695-5661-1-git-send-email-manfred@colorfullife.com
Reported-by: <felixh@informatik.uni-bremen.de>
Cc: <1vier1@web.de>
Cc: <stable@vger.kernel.org> [3.10+]
Commit 53dad6d3a8e5 ("ipc: fix race with LSMs") updated ipc_rcu_putref()
to receive rcu freeing function but used generic ipc_rcu_free() instead
of msg_rcu_free() which does security cleaning.
Running LTP msgsnd06 with kmemleak gives the following:
cat /sys/kernel/debug/kmemleak
unreferenced object 0xffff88003c0a11f8 (size 8):
comm "msgsnd06", pid 1645, jiffies 4294672526 (age 6.549s)
hex dump (first 8 bytes):
1b 00 00 00 01 00 00 00 ........
backtrace:
kmemleak_alloc+0x23/0x40
kmem_cache_alloc_trace+0xe1/0x180
selinux_msg_queue_alloc_security+0x3f/0xd0
security_msg_queue_alloc+0x2e/0x40
newque+0x4e/0x150
ipcget+0x159/0x1b0
SyS_msgget+0x39/0x40
entry_SYSCALL_64_fastpath+0x13/0x8f
Manfred Spraul suggested to fix sem.c as well and Davidlohr Bueso to
only use ipc_rcu_free in case of security allocation failure in newary()
Fixes: 53dad6d3a8e ("ipc: fix race with LSMs")
Link: http://lkml.kernel.org/r/1470083552-22966-1-git-send-email-fabf@skynet.be
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Cc: Davidlohr Bueso <dbueso@suse.de>
Cc: <stable@vger.kernel.org> [3.12+]
With the modified semantics of spin_unlock_wait() a number of
explicit barriers can be removed. Also update the comment for the
do_exit() usecase, as that was somewhat stale/obscure.
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Introduce smp_acquire__after_ctrl_dep(), this construct is not
uncommon, but the lack of this barrier is.
Use it to better express smp_rmb() uses in WRITE_ONCE(), the IPC
semaphore code and the qspinlock code.
As indicated by bug#112271, Linux sets the sempid value upon semctl, and
not only for semop calls. However, within semctl we only do this for
SETVAL, leaving SETALL without updating the field, and therefore rather
inconsistent behavior when compared to other Unices.
There is really no documentation regarding this and therefore users
should not make assumptions. With this patch, along with updating
semctl.2 manpages, this scenario should become less ambiguous As such,
set sempid on SETALL cmd.
Also update some in-code documentation, specifying where the sempid is
set.
Passes ltp and custom testcase where a child (fork) does SETALL to the
set.
Reported-by: Philip Semanchuk <linux_kernel.20.ick@spamgourmet.com>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: PrasannaKumar Muralidharan <prasannatsmkumar@gmail.com>
There are many locations that do
if (memory_was_allocated_by_vmalloc)
vfree(ptr);
else
kfree(ptr);
but kvfree() can handle both kmalloc()ed memory and vmalloc()ed memory
using is_vmalloc_addr(). Unless callers have special reasons, we can
replace this branch with kvfree(). Please check and reply if you found
problems.
Acked-by: Jan Kara <jack@suse.com>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Reviewed-by: Andreas Dilger <andreas.dilger@intel.com>
Acked-by: "Rafael J. Wysocki" <rjw@rjwysocki.net>
Acked-by: David Rientjes <rientjes@google.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Oleg Drokin <oleg.drokin@intel.com>
Cc: Boris Petkov <bp@suse.de>
sem_lock() did not properly pair memory barriers:
!spin_is_locked() and spin_unlock_wait() are both only control barriers.
The code needs an acquire barrier, otherwise the cpu might perform read
operations before the lock test.
As no primitive exists inside <include/spinlock.h> and since it seems
noone wants another primitive, the code creates a local primitive within
ipc/sem.c.
With regards to -stable:
The change of sem_wait_array() is a bugfix, the change to sem_lock() is a
nop (just a preprocessor redefinition to improve the readability). The
bugfix is necessary for all kernels that use sem_wait_array() (i.e.:
starting from 3.10).
Reported-by: Oleg Nesterov <oleg@redhat.com>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Kirill Tkhai <ktkhai@parallels.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
After we acquire the sma->sem_perm lock in exit_sem(), we are protected
against a racing IPC_RMID operation. Also at that point, we are the last
user of sem_undo_list. Therefore it isn't required that we acquire or use
ulp->lock.
Signed-off-by: Herton R. Krzesinski <herton@redhat.com>
Cc: Rafael Aquini <aquini@redhat.com>
CC: Aristeu Rozanski <aris@redhat.com>
Cc: David Jeffery <djeffery@redhat.com>
set exits
The current semaphore code allows a potential use after free: in
exit_sem we may free the task's sem_undo_list while there is still
another task looping through the same semaphore set and cleaning the
sem_undo list at freeary function (the task called IPC_RMID for the same
semaphore set).
For example, with a test program [1] running which keeps forking a lot
of processes (which then do a semop call with SEM_UNDO flag), and with
the parent right after removing the semaphore set with IPC_RMID, and a
kernel built with CONFIG_SLAB, CONFIG_SLAB_DEBUG and
CONFIG_DEBUG_SPINLOCK, you can easily see something like the following
in the kernel log:
Slab corruption (Not tainted): kmalloc-64 start=ffff88003b45c1c0, len=64
000: 6b 6b 6b 6b 6b 6b 6b 6b 00 6b 6b 6b 6b 6b 6b 6b kkkkkkkk.kkkkkkk
010: ff ff ff ff 6b 6b 6b 6b ff ff ff ff ff ff ff ff ....kkkk........
Prev obj: start=ffff88003b45c180, len=64
000: 00 00 00 00 ad 4e ad de ff ff ff ff 5a 5a 5a 5a .....N......ZZZZ
010: ff ff ff ff ff ff ff ff c0 fb 01 37 00 88 ff ff ...........7....
Next obj: start=ffff88003b45c200, len=64
010: ff ff ff ff ff ff ff ff 68 29 a7 3c 00 88 ff ff ........h).<....
BUG: spinlock wrong CPU on CPU#2, test/18028
general protection fault: 0000 [#1] SMP
Modules linked in: 8021q mrp garp stp llc nf_conntrack_ipv4 nf_defrag_ipv4 ip6t_REJECT nf_reject_ipv6 nf_conntrack_ipv6 nf_defrag_ipv6 xt_state nf_conntrack ip6table_filter ip6_tables binfmt_misc ppdev input_leds joydev parport_pc parport floppy serio_raw virtio_balloon virtio_rng virtio_console virtio_net iosf_mbi crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr qxl ttm drm_kms_helper drm snd_hda_codec_generic i2c_piix4 snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep snd_seq snd_seq_device snd_pcm snd_timer snd soundcore crc32c_intel virtio_pci virtio_ring virtio pata_acpi ata_generic [last unloaded: speedstep_lib]
CPU: 2 PID: 18028 Comm: test Not tainted 4.2.0-rc5+ #1
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.8.1-20150318_183358- 04/01/2014
RIP: spin_dump+0x53/0xc0
Call Trace:
spin_bug+0x30/0x40
do_raw_spin_unlock+0x71/0xa0
_raw_spin_unlock+0xe/0x10
freeary+0x82/0x2a0
? _raw_spin_lock+0xe/0x10
semctl_down.clone.0+0xce/0x160
? __do_page_fault+0x19a/0x430
? __audit_syscall_entry+0xa8/0x100
SyS_semctl+0x236/0x2c0
? syscall_trace_leave+0xde/0x130
entry_SYSCALL_64_fastpath+0x12/0x71
Code: 8b 80 88 03 00 00 48 8d 88 60 05 00 00 48 c7 c7 a0 2c a4 81 31 c0 65 8b 15 eb 40 f3 7e e8 08 31 68 00 4d 85 e4 44 8b 4b 08 74 5e <45> 8b 84 24 88 03 00 00 49 8d 8c 24 60 05 00 00 8b 53 04 48 89
RIP [<ffffffff810d6053>] spin_dump+0x53/0xc0
RSP <ffff88003750fd68>
---[ end trace 783ebb76612867a0 ]---
NMI watchdog: BUG: soft lockup - CPU#3 stuck for 22s! [test:18053]
CPU: 3 PID: 18053 Comm: test Tainted: G D 4.2.0-rc5+ #1
RIP: native_read_tsc+0x0/0x20
Call Trace:
? delay_tsc+0x40/0x70
__delay+0xf/0x20
do_raw_spin_lock+0x96/0x140
sem_lock_and_putref+0x11/0x70
SYSC_semtimedop+0x7bf/0x960
? handle_mm_fault+0xbf6/0x1880
? dequeue_task_fair+0x79/0x4a0
? kfree_debugcheck+0x16/0x40
? do_audit_syscall_entry+0x66/0x70
? syscall_trace_enter_phase1+0x139/0x160
SyS_semtimedop+0xe/0x10
SyS_semop+0x10/0x20
Code: 47 10 83 e8 01 85 c0 89 47 10 75 08 65 48 89 3d 1f 74 ff 7e c9 c3 0f 1f 44 00 00 55 48 89 e5 e8 87 17 04 00 66 90 c9 c3 0f 1f 00 <55> 48 89 e5 0f 31 89 c1 48 89 d0 48 c1 e0 20 89 c9 48 09 c8 c9
Kernel panic - not syncing: softlockup: hung tasks
I wasn't able to trigger any badness on a recent kernel without the
proper config debugs enabled, however I have softlockup reports on some
kernel versions, in the semaphore code, which are similar as above (the
scenario is seen on some servers running IBM DB2 which uses semaphore
syscalls).
The patch here fixes the race against freeary, by acquiring or waiting
on the sem_undo_list lock as necessary (exit_sem can race with freeary,
while freeary sets un->semid to -1 and removes the same sem_undo from
list_proc or when it removes the last sem_undo).
After the patch I'm unable to reproduce the problem using the test case
[1].
[1] Test case used below:
#include <stdio.h>
#include <sys/types.h>
#include <sys/ipc.h>
#include <sys/sem.h>
#include <sys/wait.h>
#include <stdlib.h>
#include <time.h>
#include <unistd.h>
#include <errno.h>
#define NSEM 1
#define NSET 5
int sid[NSET];
void thread()
struct sembuf op;
int s;
uid_t pid = getuid();
s = rand() % NSET;
op.sem_num = pid % NSEM;
op.sem_op = 1;
op.sem_flg = SEM_UNDO;
semop(sid[s], &op, 1);
exit(EXIT_SUCCESS);
void create_set()
int i, j;
pid_t p;
union {
int val;
struct semid_ds *buf;
unsigned short int *array;
struct seminfo *__buf;
} un;
/* Create and initialize semaphore set */
for (i = 0; i < NSET; i++) {
sid[i] = semget(IPC_PRIVATE , NSEM, 0644 | IPC_CREAT);
if (sid[i] < 0) {
perror("semget");
exit(EXIT_FAILURE);
un.val = 0;
for (j = 0; j < NSEM; j++) {
if (semctl(sid[i], j, SETVAL, un) < 0)
perror("semctl");
/* Launch threads that operate on semaphore set */
for (i = 0; i < NSEM * NSET * NSET; i++) {
p = fork();
if (p < 0)
perror("fork");
if (p == 0)
thread();
/* Free semaphore set */
if (semctl(sid[i], NSEM, IPC_RMID))
perror("IPC_RMID");
/* Wait for forked processes to exit */
while (wait(NULL)) {
if (errno == ECHILD)
break;
int main(int argc, char **argv)
pid_t p;
srand(time(NULL));
while (1) {
p = fork();
if (p < 0) {
perror("fork");
exit(EXIT_FAILURE);
if (p == 0) {
create_set();
goto end;
break;
end:
return 0;
[akpm@linux-foundation.org: use normal comment layout]
... to ipc_obtain_object_idr, which is more meaningful and makes the code
slightly easier to follow.
The seq_printf return value, because it's frequently misused,
will eventually be converted to void.
See: commit 1f33c41c03da ("seq_file: Rename seq_overflow() to
seq_has_overflowed() and make public")
Call __set_current_state() instead of assigning the new state directly.
These interfaces also aid CONFIG_DEBUG_ATOMIC_SLEEP environments, keeping
track of who changed the state.
When I fixed bugs in the sem_lock() logic, I was more conservative than
necessary. Therefore it is safe to replace the smp_mb() with smp_rmb().
And: With smp_rmb(), semop() syscalls are up to 10% faster.
The race we must protect against is:
sem->lock is free
sma->complex_count = 0
sma->sem_perm.lock held by thread B
thread A:
A: spin_lock(&sem->lock)
B: sma->complex_count++; (now 1)
B: spin_unlock(&sma->sem_perm.lock);
A: spin_is_locked(&sma->sem_perm.lock);
A: XXXXX memory barrier
A: if (sma->complex_count == 0)
Thread A must read the increased complex_count value, i.e. the read must
not be reordered with the read of sem_perm.lock done by spin_is_locked().
Since it's about ordering of reads, smp_rmb() is sufficient.
[akpm@linux-foundation.org: update sem_lock() comment, from Davidlohr]
Reviewed-by: Davidlohr Bueso <dave@stgolabs.net>
Acked-by: Rafael Aquini <aquini@redhat.com>
ipc_addid() makes a new ipc identifier visible to everyone. New objects
start as locked, so that the caller can complete the initialization
after the call. Within struct sem_array, at least sma->sem_base and
sma->sem_nsems are accessed without any locks, therefore this approach
doesn't work.
Thus: Move the ipc_addid() to the end of the initialization.
Reported-by: Rik van Riel <riel@redhat.com>
The actual Linux implementation for semctl(GETNCNT) and semctl(GETZCNT)
always (since 0.99.10) reported a thread as sleeping on all semaphores
that are listed in the semop() call.
The documented behavior (both in the Linux man page and in the Single
Unix Specification) is that a task should be reported on exactly one
semaphore: The semaphore that caused the thread to got to sleep.
This patch adds a pr_info_once() that is triggered if a thread hits the
relevant case.
The code triggers slightly too often, otherwise it would be necessary to
replicate the old code. As there are no known users of GETNCNT or
GETZCNT, this is done to prevent unnecessary bloat.
The task that triggered is reported with name (tsk->comm) and pid.
Acked-by: Davidlohr Bueso <davidlohr@hp.com>
Cc: Joe Perches <joe@perches.com>
