path: root/ipc/sem.c
2008-04-29ipc: sysvsem: implement sys_unshare(CLONE_SYSVSEM)Manfred Spraul
sys_unshare(CLONE_NEWIPC) doesn't handle the undo lists properly, this can cause a kernel memory corruption. CLONE_NEWIPC must detach from the existing undo lists. Fix, part 1: add support for sys_unshare(CLONE_SYSVSEM) The original reason to not support it was the potential (inevitable?) confusion due to the fact that sys_unshare(CLONE_SYSVSEM) has the inverse meaning of clone(CLONE_SYSVSEM). Our two most reasonable options then appear to be (1) fully support CLONE_SYSVSEM, or (2) continue to refuse explicit CLONE_SYSVSEM, but always do it anyway on unshare(CLONE_SYSVSEM). This patch does (1). Changelog: Apr 16: SEH: switch to Manfred's alternative patch which removes the unshare_semundo() function which always refused CLONE_SYSVSEM. Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: Pierre Peiffer <peifferp@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29IPC: consolidate all xxxctl_down() functionsPierre Peiffer
semctl_down(), msgctl_down() and shmctl_down() are used to handle the same set of commands for each kind of IPC. They all start to do the same job (they retrieve the ipc and do some permission checks) before handling the commands on their own. This patch proposes to consolidate this by moving these same pieces of code into one common function called ipcctl_pre_down(). It simplifies a little these xxxctl_down() functions and increases a little the maintainability. Signed-off-by: Pierre Peiffer <pierre.peiffer@bull.net> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29IPC: introduce ipc_update_perm()Pierre Peiffer
The IPC_SET command performs the same permission setting for all IPCs. This patch introduces a common ipc_update_perm() function to update these permissions and makes use of it for all IPCs. Signed-off-by: Pierre Peiffer <pierre.peiffer@bull.net> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29IPC: get rid of the use *_setbuf structure.Pierre Peiffer
All IPCs make use of an intermetiate *_setbuf structure to handle the IPC_SET command. This is not really needed and, moreover, it complicates a little bit the code. This patch gets rid of the use of it and uses directly the semid64_ds/ msgid64_ds/shmid64_ds structure. In addition of removing one struture declaration, it also simplifies and improves a little bit the common 64-bits path. Signed-off-by: Pierre Peiffer <pierre.peiffer@bull.net> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29IPC/semaphores: remove one unused parameter from semctl_down()Pierre Peiffer
semctl_down() takes one unused parameter: semnum. This patch proposes to get rid of it. Signed-off-by: Pierre Peiffer <pierre.peiffer@bull.net> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29IPC/semaphores: move the rwmutex handling inside semctl_downPierre Peiffer
semctl_down is called with the rwmutex (the one which protects the list of ipcs) taken in write mode. This patch moves this rwmutex taken in write-mode inside semctl_down. This has the advantages of reducing a little bit the window during which this rwmutex is taken, clarifying sys_semctl, and finally of having a coherent behaviour with [shm|msg]ctl_down Signed-off-by: Pierre Peiffer <pierre.peiffer@bull.net> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29IPC/semaphores: code factorisationPierre Peiffer
Trivial patch which adds some small locking functions and makes use of them to factorize some part of the code and to make it cleaner. Signed-off-by: Pierre Peiffer <pierre.peiffer@bull.net> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29IPC: use ipc_buildid() directly from ipc_addid()Pierre Peiffer
By continuing to consolidate a little the IPC code, each id can be built directly in ipc_addid() instead of having it built from each callers of ipc_addid() And I also remove shm_addid() in order to have, as much as possible, the same code for shm/sem/msg. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Pierre Peiffer <pierre.peiffer@bull.net> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08IPC: consolidate sem_exit_ns(), msg_exit_ns() and shm_exit_ns()Pierre Peiffer
sem_exit_ns(), msg_exit_ns() and shm_exit_ns() are all called when an ipc_namespace is released to free all ipcs of each type. But in fact, they do the same thing: they loop around all ipcs to free them individually by calling a specific routine. This patch proposes to consolidate this by introducing a common function, free_ipcs(), that do the job. The specific routine to call on each individual ipcs is passed as parameter. For this, these ipc-specific 'free' routines are reworked to take a generic 'struct ipc_perm' as parameter. Signed-off-by: Pierre Peiffer <pierre.peiffer@bull.net> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08IPC: make struct ipc_ids static in ipc_namespacePierre Peiffer
Each ipc_namespace contains a table of 3 pointers to struct ipc_ids (3 for msg, sem and shm, structure used to store all ipcs) These 'struct ipc_ids' are dynamically allocated for each icp_namespace as the ipc_namespace itself (for the init namespace, they are initialized with pointers to static variables instead) It is so for historical reason: in fact, before the use of idr to store the ipcs, the ipcs were stored in tables of variable length, depending of the maximum number of ipc allowed. Now, these 'struct ipc_ids' have a fixed size. As they are allocated in any cases for each new ipc_namespace, there is no gain of memory in having them allocated separately of the struct ipc_namespace. This patch proposes to make this table static in the struct ipc_namespace. Thus, we can allocate all in once and get rid of all the code needed to allocate and free these ipc_ids separately. Signed-off-by: Pierre Peiffer <pierre.peiffer@bull.net> Acked-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08IPC/semaphores: consolidate SEM_STAT and IPC_STAT commandsPierre Peiffer
These commands (SEM_STAT and IPC_STAT) are rather doing the same things (only the meaning of the id given as input and the return value differ). However, for the semaphores, they are handled in two different places (two different functions). This patch consolidates this for clarification by handling these both commands in the same place in semctl_nolock(). It also removes one unused parameter for this function. Signed-off-by: Pierre Peiffer <pierre.peiffer@bull.net> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08namespaces: move the IPC namespace under IPC_NS optionPavel Emelyanov
Currently the IPC namespace management code is spread over the ipc/*.c files. I moved this code into ipc/namespace.c file which is compiled out when needed. The linux/ipc_namespace.h file is used to store the prototypes of the functions in namespace.c and the stubs for NAMESPACES=n case. This is done so, because the stub for copy_ipc_namespace requires the knowledge of the CLONE_NEWIPC flag, which is in sched.h. But the linux/ipc.h file itself in included into many many .c files via the sys.h->sem.h sequence so adding the sched.h into it will make all these .c depend on sched.h which is not that good. On the other hand the knowledge about the namespaces stuff is required in 4 .c files only. Besides, this patch compiles out some auxiliary functions from ipc/sem.c, msg.c and shm.c files. It turned out that moving these functions into namespaces.c is not that easy because they use many other calls and macros from the original file. Moving them would make this patch complicated. On the other hand all these functions can be consolidated, so I will send a separate patch doing this a bit later. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Kirill Korotaev <dev@sw.ru> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06IPC: fix error check in all new xxx_lock() and xxx_exit_ns() functionsPierre Peiffer
In the new implementation of the [sem|shm|msg]_lock[_check]() routines, we use the return value of ipc_lock() in container_of() without any check. But ipc_lock may return a errcode. The use of this errcode in container_of() may alter this errcode, and we don't want this. And in xxx_exit_ns, the pointer return by idr_find is of type 'struct kern_ipc_per'... Today, the code will work as is because the member used in these container_of() is the first member of its container (offset == 0), the errcode isn't changed then. But in the general case, we can't count on this assumption and this may lead later to a real bug if we don't correct this. Again, the proposed solution is simple and correct. But, as pointed by Nadia, with this solution, the same check will be done several times (in all sub-callers...), what is not very funny/optimal... Signed-off-by: Pierre Peiffer <pierre.peiffer@bull.net> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19IPC: fix error case when idr-cache is empty in ipcget()Pierre Peiffer
With the use of idr to store the ipc, the case where the idr cache is empty, when idr_get_new is called (this may happen even if we call idr_pre_get() before), is not well handled: it lets semget()/shmget()/msgget() return ENOSPC when this cache is empty, what 1. does not reflect the facts and 2. does not conform to the man(s). This patch fixes this by retrying the whole process of allocation in this case. Signed-off-by: Pierre Peiffer <pierre.peiffer@bull.net> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19IPC: cleanup some code and wrong comments about semundo list managmentPierre Peiffer
Some comments about sem_undo_list seem wrong. About the comment above unlock_semundo: "... If task2 now exits before task1 releases the lock (by calling unlock_semundo()), then task1 will never call spin_unlock(). ..." This is just wrong, I see no reason for which task1 will not call spin_unlock... The rest of this comment is also wrong... Unless I miss something (of course). Finally, (un)lock_semundo functions are useless, so remove them for simplification. (this avoids an useless if statement) Signed-off-by: Pierre Peiffer <pierre.peiffer@bull.net> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19ipc: remove unneeded parametersNadia Derbey
Remvoe the unneeded parameters from ipc_checkid() and ipc_buildid() interfaces. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19fix idr_find() lockingNadia Derbey
This is a patch that fixes the way idr_find() used to be called in ipc_lock(): in all the paths that don't imply an update of the ipcs idr, it was called without the idr tree being locked. The changes are: . in ipc_ids, the mutex has been changed into a reader/writer semaphore. . ipc_lock() now takes the mutex as a reader during the idr_find(). . a new routine ipc_lock_down() has been defined: it doesn't take the mutex, assuming that it is being held by the caller. This is the routine that is now called in all the update paths. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Acked-by: Jarek Poplawski <jarkao2@o2.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19ipc: fix wrong commentsNadia Derbey
This patch fixes the wrong / obsolete comments in the ipc code. Also adds a missing lock around ipc_get_maxid() in shm_get_stat(). Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Storing ipcs into IDRsNadia Derbey
This patch converts casts of struct kern_ipc_perm to . struct msg_queue . struct sem_array . struct shmid_kernel into the equivalent container_of() macro. It improves code maintenance because the code need not change if kern_ipc_perm is no longer at the beginning of the containing struct. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19ipc: integrate ipc_checkid() into ipc_lock()Nadia Derbey
This patch introduces a new ipc_lock_check() routine interface: . each time ipc_checkid() is called, this is done after calling ipc_lock(). ipc_checkid() is now called from inside ipc_lock_check(). [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix RCU locking] Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19ipc: unify the syscalls codeNadia Derbey
This patch introduces a change into the sys_msgget(), sys_semget() and sys_shmget() routines: they now share a common code, which is better for maintainability. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19ipc: store ipcs into IDRsNadia Derbey
This patch introduces ipcs storage into IDRs. The main changes are: . This ipc_ids structure is changed: the entries array is changed into a root idr structure. . The grow_ary() routine is removed: it is not needed anymore when adding an ipc structure, since we are now using the IDR facility. . The ipc_rmid() routine interface is changed: . there is no need for this routine to return the pointer passed in as argument: it is now declared as a void . since the id is now part of the kern_ipc_perm structure, no need to have it as an argument to the routine Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19pid namespaces: changes to show virtual ids to userPavel Emelyanov
This is the largest patch in the set. Make all (I hope) the places where the pid is shown to or get from user operate on the virtual pids. The idea is: - all in-kernel data structures must store either struct pid itself or the pid's global nr, obtained with pid_nr() call; - when seeking the task from kernel code with the stored id one should use find_task_by_pid() call that works with global pids; - when showing pid's numerical value to the user the virtual one should be used, but however when one shows task's pid outside this task's namespace the global one is to be used; - when getting the pid from userspace one need to consider this as the virtual one and use appropriate task/pid-searching functions. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: nuther build fix] [akpm@linux-foundation.org: yet nuther build fix] [akpm@linux-foundation.org: remove unneeded casts] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Paul Menage <menage@google.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17arch/i386/* fs/* ipc/*: mark variables with uninitialized_var()Jeff Garzik
Mark variables with uninitialized_var() if such a warning appears, and analysis proves that the var is initialized properly on all paths it is used. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-16remove CONFIG_UTS_NS and CONFIG_IPC_NSCedric Le Goater
CONFIG_UTS_NS and CONFIG_IPC_NS have very little value as they only deactivate the unshare of the uts and ipc namespaces and do not improve performance. Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Acked-by: "Serge E. Hallyn" <serue@us.ibm.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Pavel Emelianov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] kernel core: replace kmalloc+memset with kzallocBurman Yan
Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-03[PATCH] Fix ipc entries removalPavel Emelianov
Fix two issuses related to ipc_ids->entries freeing. 1. When freeing ipc namespace we need to free entries allocated with ipc_init_ids(). 2. When removing old entries in grow_ary() ipc_rcu_putref() may be called on entries set to &ids->nullentry earlier in ipc_init_ids(). This is almost impossible without namespaces, but with them this situation becomes possible. Found during OpenVZ testing after obvious leaks in beancounters. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Cc: Kirill Korotaev <dev@openvz.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] ipc: replace kmalloc and memset in get_undo_list with kzallocMatt Helsley
Simplify get_undo_list() by dropping the unnecessary cast, removing the size variable, and switching to kzalloc() instead of a kmalloc() followed by a memset(). This cleanup was split then modified from Jes Sorenson's Task Notifiers patches. Signed-off-by: Matt Helsley <matthltc@us.ibm.com> Cc: Jes Sorensen <jes@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] IPC namespace - semKirill Korotaev
IPC namespace support for IPC sem code. Signed-off-by: Pavel Emelianiov <xemul@openvz.org> Signed-off-by: Kirill Korotaev <dev@openvz.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-20[PATCH] update of IPC audit record cleanupLinda Knippers
The following patch addresses most of the issues with the IPC_SET_PERM records as described in: https://www.redhat.com/archives/linux-audit/2006-May/msg00010.html and addresses the comments I received on the record field names. To summarize, I made the following changes: 1. Changed sys_msgctl() and semctl_down() so that an IPC_SET_PERM record is emitted in the failure case as well as the success case. This matches the behavior in sys_shmctl(). I could simplify the code in sys_msgctl() and semctl_down() slightly but it would mean that in some error cases we could get an IPC_SET_PERM record without an IPC record and that seemed odd. 2. No change to the IPC record type, given no feedback on the backward compatibility question. 3. Removed the qbytes field from the IPC record. It wasn't being set and when audit_ipc_obj() is called from ipcperms(), the information isn't available. If we want the information in the IPC record, more extensive changes will be necessary. Since it only applies to message queues and it isn't really permission related, it doesn't seem worth it. 4. Removed the obj field from the IPC_SET_PERM record. This means that the kern_ipc_perm argument is no longer needed. 5. Removed the spaces and renamed the IPC_SET_PERM field names. Replaced iuid and igid fields with ouid and ogid in the IPC record. I tested this with the lspp.22 kernel on an x86_64 box. I believe it applies cleanly on the latest kernel. -- ljk Signed-off-by: Linda Knippers <linda.knippers@hp.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-05-01[PATCH] Rework of IPC auditingSteve Grubb
1) The audit_ipc_perms() function has been split into two different functions: - audit_ipc_obj() - audit_ipc_set_perm() There's a key shift here... The audit_ipc_obj() collects the uid, gid, mode, and SElinux context label of the current ipc object. This audit_ipc_obj() hook is now found in several places. Most notably, it is hooked in ipcperms(), which is called in various places around the ipc code permforming a MAC check. Additionally there are several places where *checkid() is used to validate that an operation is being performed on a valid object while not necessarily having a nearby ipcperms() call. In these locations, audit_ipc_obj() is called to ensure that the information is captured by the audit system. The audit_set_new_perm() function is called any time the permissions on the ipc object changes. In this case, the NEW permissions are recorded (and note that an audit_ipc_obj() call exists just a few lines before each instance). 2) Support for an AUDIT_IPC_SET_PERM audit message type. This allows for separate auxiliary audit records for normal operations on an IPC object and permissions changes. Note that the same struct audit_aux_data_ipcctl is used and populated, however there are separate audit_log_format statements based on the type of the message. Finally, the AUDIT_IPC block of code in audit_free_aux() was extended to handle aux messages of this new type. No more mem leaks I hope ;-) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-03-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: drivers/char/ftape/lowlevel/fdc-io.c: Correct a comment Kconfig help: MTD_JEDECPROBE already supports Intel Remove ugly debugging stuff do_mounts.c: Minor ROOT_DEV comment cleanup BUG_ON() Conversion in drivers/s390/block/dasd_devmap.c BUG_ON() Conversion in mm/mempool.c BUG_ON() Conversion in mm/memory.c BUG_ON() Conversion in kernel/fork.c BUG_ON() Conversion in ipc/sem.c BUG_ON() Conversion in fs/ext2/ BUG_ON() Conversion in fs/hfs/ BUG_ON() Conversion in fs/dcache.c BUG_ON() Conversion in fs/buffer.c BUG_ON() Conversion in input/serio/hp_sdc_mlc.c BUG_ON() Conversion in md/dm-table.c BUG_ON() Conversion in md/dm-path-selector.c BUG_ON() Conversion in drivers/isdn BUG_ON() Conversion in drivers/char BUG_ON() Conversion in drivers/mtd/
2006-03-26[PATCH] sem2mutex: ipc, id.semIngo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26BUG_ON() Conversion in ipc/sem.cEric Sesterhenn
this changes if() BUG(); constructs to BUG_ON() which is cleaner, contains unlikely() and can better optimized away. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-20[PATCH] Capture selinux subject/object context information.Dustin Kirkland
This patch extends existing audit records with subject/object context information. Audit records associated with filesystem inodes, ipc, and tasks now contain SELinux label information in the field "subj" if the item is performing the action, or in "obj" if the item is the receiver of an action. These labels are collected via hooks in SELinux and appended to the appropriate record in the audit code. This additional information is required for Common Criteria Labeled Security Protection Profile (LSPP). [AV: fixed kmalloc flags use] [folded leak fixes] [folded cleanup from akpm (kfree(NULL)] [folded audit_inode_context() leak fix] [folded akpm's fix for audit_ipc_perm() definition in case of !CONFIG_AUDIT] Signed-off-by: Dustin Kirkland <dustin.kirkland@us.ibm.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-01-15correct email address of Manfred SpraulChristian Kujau
I tried to send the forcedeth maintainer an email, but it came back with: "The mail address manfreds@colorfullife.com is not read anymore. Please resent your mail to manfred@ instead of manfreds@." This patch fixes this. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-01-11[PATCH] move capable() to capability.hRandy.Dunlap
- Move capable() from sched.h to capability.h; - Use <linux/capability.h> where capable() is used (in include/, block/, ipc/, kernel/, a few drivers/, mm/, security/, & sound/; many more drivers/ to go) Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-24Fix silly typo ("smb" vs "smp")Linus Torvalds
Introduced by commit 6003a93e7bf6c02f33c02976ff364785d4273295
2005-12-24[PATCH] add missing memory barriers to ipc/sem.cManfred Spraul
Two smp_wmb() statements are missing in the sysv sem code: This could cause stack corruptions. The attached patch adds them. Signed-Off-By: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] ipc: convert /proc/sysvipc/* to generic seq_file interfaceMike Waychison
Change the /proc/sysvipc/shm|sem|msg files to use the generic seq_file implementation for struct ipc_ids. Signed-off-by: Mike Waychison <mikew@google.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-05[PATCH] Fix semundo lock leakageIngo Molnar
semundo->lock can leak if semundo->refcount goes from 2 to 1 while another thread has it locked. This causes major problems for PREEMPT kernels. The simplest fix for now is to undo the single-thread optimization. This bug was found via relentless testing by Dominik Karall. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] ipcsem: remove superflous decrease variable from sys_semtimedopManfred Spraul
Patrick noticed that the initial scan of the semaphore operations logs decrease and increase operations seperately, but then both cases are or'ed together and decrease is never used. The attached patch removes the decrease parameter - it shrinks sys_semtimedop() by 56 bytes. Signed-Of-By: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
