path: root/ipc/sem.c
2006-01-15correct email address of Manfred SpraulChristian Kujau
I tried to send the forcedeth maintainer an email, but it came back with: "The mail address manfreds@colorfullife.com is not read anymore. Please resent your mail to manfred@ instead of manfreds@." This patch fixes this. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-01-11[PATCH] move capable() to capability.hRandy.Dunlap
- Move capable() from sched.h to capability.h; - Use <linux/capability.h> where capable() is used (in include/, block/, ipc/, kernel/, a few drivers/, mm/, security/, & sound/; many more drivers/ to go) Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-24Fix silly typo ("smb" vs "smp")Linus Torvalds
Introduced by commit 6003a93e7bf6c02f33c02976ff364785d4273295
2005-12-24[PATCH] add missing memory barriers to ipc/sem.cManfred Spraul
Two smp_wmb() statements are missing in the sysv sem code: This could cause stack corruptions. The attached patch adds them. Signed-Off-By: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] ipc: convert /proc/sysvipc/* to generic seq_file interfaceMike Waychison
Change the /proc/sysvipc/shm|sem|msg files to use the generic seq_file implementation for struct ipc_ids. Signed-off-by: Mike Waychison <mikew@google.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-05[PATCH] Fix semundo lock leakageIngo Molnar
semundo->lock can leak if semundo->refcount goes from 2 to 1 while another thread has it locked. This causes major problems for PREEMPT kernels. The simplest fix for now is to undo the single-thread optimization. This bug was found via relentless testing by Dominik Karall. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] ipcsem: remove superflous decrease variable from sys_semtimedopManfred Spraul
Patrick noticed that the initial scan of the semaphore operations logs decrease and increase operations seperately, but then both cases are or'ed together and decrease is never used. The attached patch removes the decrease parameter - it shrinks sys_semtimedop() by 56 bytes. Signed-Of-By: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
