commit 2195d2818c37bdf263865f1e9effccdd9fc5f9d4 upstream.
My 353d5c30c666580347515da609dd74a2b8e9b828 "mm: fix hugetlb bug due to
user_shm_unlock call" broke the CONFIG_SYSVIPC !CONFIG_MMU build of both
2.6.31 and 2.6.30.6: "undefined reference to `user_shm_unlock'".
gcc didn't understand my comment! so couldn't figure out to optimize
away user_shm_unlock() from the error path in the hugetlb-less case, as
it does elsewhere. Help it to do so, in a language it understands.
Reported-by: Mike Frysinger <vapier@gentoo.org>
Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
2.6.30's commit 8a0bdec194c21c8fdef840989d0d7b742bb5d4bc removed
user_shm_lock() calls in hugetlb_file_setup() but left the
user_shm_unlock call in shm_destroy().
In detail:
Assume that can_do_hugetlb_shm() returns true and hence user_shm_lock()
is not called in hugetlb_file_setup(). However, user_shm_unlock() is
called in any case in shm_destroy() and in the following
atomic_dec_and_lock(&up->__count) in free_uid() is executed and if
up->__count gets zero, also cleanup_user_struct() is scheduled.
Note that sched_destroy_user() is empty if CONFIG_USER_SCHED is not set.
However, the ref counter up->__count gets unexpectedly non-positive and
the corresponding structs are freed even though there are live
references to them, resulting in a kernel oops after a lots of
shmget(SHM_HUGETLB)/shmctl(IPC_RMID) cycles and CONFIG_USER_SCHED set.
Hugh changed Stefan's suggested patch: can_do_hugetlb_shm() at the
time of shm_destroy() may give a different answer from at the time
of hugetlb_file_setup(). And fixed newseg()'s no_id error path,
which has missed user_shm_unlock() ever since it came in 2.6.9.
Reported-by: Stefan Huber <shuber2@gmail.com>
Tested-by: Stefan Huber <shuber2@gmail.com>
Cc: stable@kernel.org
The massive nommu update (8feae131) resulted in these warnings:
ipc/shm.c: In function `sys_shmdt':
ipc/shm.c:974: warning: unused variable `size'
ipc/shm.c:972: warning: unused variable `next'
Based on discussion on lkml (Andrew Morton and Eric Paris),
move ima_counts_get down a layer into shmem/hugetlb__file_setup().
Resolves drm shmem_file_setup() usage case as well.
HD comment:
I still think you're doing this at the wrong level, but recognize
that you probably won't be persuaded until a few more users of
alloc_file() emerge, all wanting your ima_counts_get().
Resolving GEM's shmem_file_setup() is an improvement, so I'll say
Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
Signed-off-by: James Morris <jmorris@namei.org>
- Add support in ima_path_check() for integrity checking without
incrementing the counts. (Required for nfsd.)
- rename and export opencount_get to ima_counts_get
- replace ima_shm_check calls with ima_counts_get
- export ima_path_check
shm_get_stat() assumes idr_find(&shm_ids(ns).ipcs_idr) returns "struct
shmid_kernel *"; all other callers assume that it returns "struct
kern_ipc_perm *". This works because "struct kern_ipc_perm" is currently
the first member of "struct shmid_kernel", but it would be better to use
container_of() to prevent future breakage.
Signed-off-by: Tony Battersby <tonyb@cybernetics.com>
Cc: Jiri Olsa <olsajiri@gmail.com>
Cc: Jiri Kosina <jkosina@suse.cz>
When overcommit is disabled, the core VM accounts for pages used by anonymous
shared, private mappings and special mappings. It keeps track of VMAs that
should be accounted for with VM_ACCOUNT and VMAs that never had a reserve
with VM_NORESERVE.
Overcommit for hugetlbfs is much riskier than overcommit for base pages
due to contiguity requirements. It avoids overcommiting on both shared and
private mappings using reservation counters that are checked and updated
during mmap(). This ensures (within limits) that hugepages exist in the
future when faults occurs or it is too easy to applications to be SIGKILLed.
As hugetlbfs makes its own reservations of a different unit to the base page
size, VM_ACCOUNT should never be set. Even if the units were correct, we would
double account for the usage in the core VM and hugetlbfs. VM_NORESERVE may
be set because an application can request no reserves be made for hugetlbfs
at the risk of getting killed later.
With commit fc8744adc870a8d4366908221508bb113d8b72ee, VM_NORESERVE and
VM_ACCOUNT are getting unconditionally set for hugetlbfs-backed mappings. This
breaks the accounting for both the core VM and hugetlbfs, can trigger an
OOM storm when hugepage pools are too small lockups and corrupted counters
otherwise are used. This patch brings hugetlbfs more in line with how the
core VM treats VM_NORESERVE but prevents VM_ACCOUNT being set.
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
fs/namei.c
Manually merged per:
diff --cc fs/namei.c
index 734f2b5,bbc15c2..0000000
--- a/fs/namei.c
+++ b/fs/namei.c
@@@ -860,9 -848,8 +849,10 @@@ static int __link_path_walk(const char
nd->flags |= LOOKUP_CONTINUE;
err = exec_permission_lite(inode);
if (err == -EAGAIN)
- err = vfs_permission(nd, MAY_EXEC);
+ err = inode_permission(nd->path.dentry->d_inode,
+ MAY_EXEC);
+ if (!err)
+ err = ima_path_check(&nd->path, MAY_EXEC);
if (err)
break;
@@@ -1525,14 -1506,9 +1509,14 @@@ int may_open(struct path *path, int acc
flag &= ~O_TRUNC;
- error = vfs_permission(nd, acc_mode);
+ error = inode_permission(inode, acc_mode);
if (error)
return error;
- error = ima_path_check(&nd->path,
++ error = ima_path_check(path,
+ acc_mode & (MAY_READ | MAY_WRITE | MAY_EXEC));
+ if (error)
+ return error;
* An append-only file must be opened in append mode for writing.
The number of calls to ima_path_check()/ima_file_free()
should be balanced. An extra call to fput(), indicates
the file could have been accessed without first being
measured.
Although f_count is incremented/decremented in places other
than fget/fput, like fget_light/fput_light and get_file, the
current task must already hold a file refcnt. The call to
__fput() is delayed until the refcnt becomes 0, resulting
in ima_file_free() flagging any changes.
- add hook to increment opencount for IPC shared memory(SYSV),
shmat files, and /dev/zero
- moved NULL iint test in opencount_get()
Acked-by: Serge Hallyn <serue@us.ibm.com>
shm_get_stat() assumes that the inode is a "struct shmem_inode_info",
which is incorrect for !CONFIG_SHMEM (see fs/ramfs/inode.c:
ramfs_get_inode() vs. mm/shmem.c: shmem_get_inode()).
This bad assumption can cause shmctl(SHM_INFO) to lockup when
shm_get_stat() tries to spin_lock(&info->lock). Users of !CONFIG_SHMEM
may encounter this lockup simply by invoking the 'ipcs' command.
Reported by Jiri Olsa back in February 2008:
http://lkml.org/lkml/2008/2/29/74
Reported-by: Jiri Olsa <olsajiri@gmail.com>
Cc: Hugh Dickins <hugh@veritas.com>
Cc: <stable@kernel.org> [2.6.everything]
The mmap_region() code would temporarily set the VM_ACCOUNT flag for
anonymous shared mappings just to inform shmem_zero_setup() that it
should enable accounting for the resulting shm object. It would then
clear the flag after calling ->mmap (for the /dev/zero case) or doing
shmem_zero_setup() (for the MAP_ANON case).
This just resulted in vma merge issues, but also made for just
unnecessary confusion. Use the already-existing VM_NORESERVE flag for
this instead, and let shmem_{zero|file}_setup() just figure it out from
that.
This also happens to make it obvious that the new DRI2 GEM layer uses a
non-reserving backing store for its object allocation - which is quite
possibly not intentional. But since I didn't want to change semantics
in this patch, I left it alone, and just updated the caller to use the
new flag semantics.
Make VMAs per mm_struct as for MMU-mode linux. This solves two problems:
(1) In SYSV SHM where nattch for a segment does not reflect the number of
shmat's (and forks) done.
(2) In mmap() where the VMA's vm_mm is set to point to the parent mm by an
exec'ing process when VM_EXECUTABLE is specified, regardless of the fact
that a VMA might be shared and already have its vm_mm assigned to another
process or a dead process.
A new struct (vm_region) is introduced to track a mapped region and to remember
the circumstances under which it may be shared and the vm_list_struct structure
is discarded as it's no longer required.
This patch makes the following additional changes:
(1) Regions are now allocated with alloc_pages() rather than kmalloc() and
with no recourse to __GFP_COMP, so the pages are not composite. Instead,
each page has a reference on it held by the region. Anything else that is
interested in such a page will have to get a reference on it to retain it.
When the pages are released due to unmapping, each page is passed to
put_page() and will be freed when the page usage count reaches zero.
(2) Excess pages are trimmed after an allocation as the allocation must be
made as a power-of-2 quantity of pages.
(3) VMAs are added to the parent MM's R/B tree and mmap lists. As an MM may
end up with overlapping VMAs within the tree, the VMA struct address is
appended to the sort key.
(4) Non-anonymous VMAs are now added to the backing inode's prio list.
(5) Holes may be punched in anonymous VMAs with munmap(), releasing parts of
the backing region. The VMA and region structs will be split if
necessary.
(6) sys_shmdt() only releases one attachment to a SYSV IPC shared memory
segment instead of all the attachments at that addresss. Multiple
shmat()'s return the same address under NOMMU-mode instead of different
virtual addresses as under MMU-mode.
(7) Core dumping for ELF-FDPIC requires fewer exceptions for NOMMU-mode.
(8) /proc/maps is now the global list of mapped regions, and may list bits
that aren't actually mapped anywhere.
(9) /proc/meminfo gains a line (tagged "MmapCopy") that indicates the amount
of RAM currently allocated by mmap to hold mappable regions that can't be
mapped directly. These are copies of the backing device or file if not
anonymous.
These changes make NOMMU mode more similar to MMU mode. The downside is that
NOMMU mode requires some extra memory to track things over NOMMU without this
patch (VMAs are no longer shared, and there are now region structs).
Tested-by: Mike Frysinger <vapier.adi@gmail.com>
Acked-by: Paul Mundt <lethal@linux-sh.org>
Use the macro shm_ids().
Remove useless check for a userspace pointer, because copy_to_user()
will check it.
Some style cleanups.
Signed-off-by: WANG Cong <wangcong@zeuux.org>
Cc: Nadia Derbey <Nadia.Derbey@bull.net>
Cc: Pierre Peiffer <peifferp@gmail.com>
* get rid of allocations
* make it return void
* simplify callers
Wrap current->cred and a few other accessors to hide their actual
implementation.
Acked-by: James Morris <jmorris@namei.org>
Separate the task security context from task_struct. At this point, the
security data is temporarily embedded in the task_struct with two pointers
pointing to it.
Note that the Alpha arch is altered as it refers to (E)UID and (E)GID in
entry.S via asm-offsets.
With comment fixes Signed-off-by: Marc Dionne <marc.c.dionne@gmail.com>
Wrap access to task credentials so that they can be separated more easily from
the task_struct during the introduction of COW creds.
Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id().
Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more
sense to use RCU directly rather than a convenient wrapper; these will be
addressed by later patches.
Reviewed-by: James Morris <jmorris@namei.org>
Shmem segments locked into memory via shmctl(SHM_LOCKED) should not be
kept on the normal LRU, since scanning them is a waste of time and might
throw off kswapd's balancing algorithms. Place them on the unevictable
LRU list instead.
Use the AS_UNEVICTABLE flag to mark address_space of SHM_LOCKed shared
memory regions as unevictable. Then these pages will be culled off the
normal LRU lists during vmscan.
Add new wrapper function to clear the mapping's unevictable state when/if
shared memory segment is munlocked.
Add 'scan_mapping_unevictable_page()' to mm/vmscan.c to scan all pages in
the shmem segment's mapping [struct address_space] for evictability now
that they're no longer locked. If so, move them to the appropriate zone
lru list.
Changes depend on [CONFIG_]UNEVICTABLE_LRU.
[kosaki.motohiro@jp.fujitsu.com: revert shm change]
Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com>
Signed-off-by: Rik van Riel <riel@redhat.com>
Signed-off-by: Kosaki Motohiro <kosaki.motohiro@jp.fujitsu.com>
Remove the ipc_lock_down() routines: they used to call idr_find() locklessly
(given that the ipc ids lock was already held), so they are not needed
anymore.
Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net>
Acked-by: "Paul E. McKenney" <paulmck@us.ibm.com>
Cc: Manfred Spraul <manfred@colorfullife.com>
Cc: Jim Houston <jim.houston@comcast.net>
The goal of this patchset is to support multiple hugetlb page sizes. This
is achieved by introducing a new struct hstate structure, which
encapsulates the important hugetlb state and constants (eg. huge page
size, number of huge pages currently allocated, etc).
The hstate structure is then passed around the code which requires these
fields, they will do the right thing regardless of the exact hstate they
are operating on.
This patch adds the hstate structure, with a single global instance of it
(default_hstate), and does the basic work of converting hugetlb to use the
hstate.
Future patches will add more hstate structures to allow for different
hugetlbfs mounts to have different page sizes.
Acked-by: Adam Litke <agl@us.ibm.com>
Acked-by: Nishanth Aravamudan <nacc@us.ibm.com>
Signed-off-by: Andi Kleen <ak@suse.de>
Signed-off-by: Nick Piggin <npiggin@suse.de>
sysvipc_shm_proc_show() picks between format strings (based on the
expected maximum length of a SHM segment) in a way that prevents gcc from
performing format checks on the seq_printf() parameters. This hid two
format errors - shp->shm_segsz and shp->shm_nattach are both unsigned
long, but were being printed as unsigned int and signed int respectively.
This leads to 32-bit truncation of SHM segment sizes reported in
/proc/sysvipc/shm. (And for nattach, but that's less of a problem for
most users).
This patch makes the format string directly visible to gcc's format
specifier checker, and fixes the two broken format specifiers.
Signed-off-by: Paul Menage <menage@google.com>
Found a silly double assignment of err is do_shmat. Silly, but good to
clean up the useless code.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
semctl_down(), msgctl_down() and shmctl_down() are used to handle the same set
of commands for each kind of IPC. They all start to do the same job (they
retrieve the ipc and do some permission checks) before handling the commands
on their own.
This patch proposes to consolidate this by moving these same pieces of code
into one common function called ipcctl_pre_down().
It simplifies a little these xxxctl_down() functions and increases a little
the maintainability.
Signed-off-by: Pierre Peiffer <pierre.peiffer@bull.net>
The IPC_SET command performs the same permission setting for all IPCs. This
patch introduces a common ipc_update_perm() function to update these
permissions and makes use of it for all IPCs.
All IPCs make use of an intermetiate *_setbuf structure to handle the IPC_SET
command. This is not really needed and, moreover, it complicates a little bit
the code.
This patch gets rid of the use of it and uses directly the semid64_ds/
msgid64_ds/shmid64_ds structure.
In addition of removing one struture declaration, it also simplifies and
improves a little bit the common 64-bits path.
Currently, the way the different commands are handled in sys_shmctl introduces
some duplicated code.
This patch introduces the shmctl_down function to handle all the commands
requiring the rwmutex to be taken in write mode (ie IPC_SET and IPC_RMID for
now). It is the equivalent function of semctl_down for shared memory.
This removes some duplicated code for handling these both commands and
harmonizes the way they are handled among all IPCs.
By continuing to consolidate a little the IPC code, each id can be built
directly in ipc_addid() instead of having it built from each callers of
ipc_addid()
And I also remove shm_addid() in order to have, as much as possible, the
same code for shm/sem/msg.
After further discussion with Christoph Lameter, it has become clear that my
earlier attempts to clean up the mempolicy reference counting were a bit of
overkill in some areas, resulting in superflous ref/unref in what are usually
fast paths. In other areas, further inspection reveals that I botched the
unref for interleave policies.
A separate patch, suitable for upstream/stable trees, fixes up the known
errors in the previous attempt to fix reference counting.
This patch reworks the memory policy referencing counting and, one hopes,
simplifies the code. Maybe I'll get it right this time.
See the update to the numa_memory_policy.txt document for a discussion of
memory policy reference counting that motivates this patch.
Summary:
Lookup of mempolicy, based on (vma, address) need only add a reference for
shared policy, and we need only unref the policy when finished for shared
policies. So, this patch backs out all of the unneeded extra reference
counting added by my previous attempt. It then unrefs only shared policies
when we're finished with them, using the mpol_cond_put() [conditional put]
helper function introduced by this patch.
Note that shmem_swapin() calls read_swap_cache_async() with a dummy vma
containing just the policy. read_swap_cache_async() can call alloc_page_vma()
multiple times, so we can't let alloc_page_vma() unref the shared policy in
this case. To avoid this, we make a copy of any non-null shared policy and
remove the MPOL_F_SHARED flag from the copy. This copy occurs before reading
a page [or multiple pages] from swap, so the overhead should not be an issue
here.
I introduced a new static inline function "mpol_cond_copy()" to copy the
shared policy to an on-stack policy and remove the flags that would require a
conditional free. The current implementation of mpol_cond_copy() assumes that
the struct mempolicy contains no pointers to dynamically allocated structures
that must be duplicated or reference counted during copy.
Cc: Christoph Lameter <clameter@sgi.com>
Cc: Andi Kleen <ak@suse.de>
get_vma_policy() is not handling fallback to task policy correctly when the
get_policy() vm_op returns NULL. The NULL overwrites the 'pol' variable that
was holding the fallback task mempolicy. So, it was falling back directly to
system default policy.
Fix get_vma_policy() to use only non-NULL policy returned from the vma
get_policy op.
shm_get_policy() was falling back to current task's mempolicy if the "backing
file system" [tmpfs vs hugetlbfs] does not support the get_policy vm_op and
the vma policy is null. This is incorrect for show_numa_maps() which is
likely querying the numa_maps of some task other than current. Remove this
fallback.
Address 3 known bugs in the current memory policy reference counting method.
I have a series of patches to rework the reference counting to reduce overhead
in the allocation path. However, that series will require testing in -mm once
I repost it.
1) alloc_page_vma() does not release the extra reference taken for
vma/shared mempolicy when the mode == MPOL_INTERLEAVE. This can result in
leaking mempolicy structures. This is probably occurring, but not being
noticed.
Fix: add the conditional release of the reference.
2) hugezonelist unconditionally releases a reference on the mempolicy when
mode == MPOL_INTERLEAVE. This can result in decrementing the reference
count for system default policy [should have no ill effect] or premature
freeing of task policy. If this occurred, the next allocation using task
mempolicy would use the freed structure and probably BUG out.
Fix: add the necessary check to the release.
3) The current reference counting method assumes that vma 'get_policy()'
methods automatically add an extra reference a non-NULL returned mempolicy.
This is true for shmem_get_policy() used by tmpfs mappings, including
regular page shm segments. However, SHM_HUGETLB shm's, backed by
hugetlbfs, just use the vma policy without the extra reference. This
results in freeing of the vma policy on the first allocation, with reuse of
the freed mempolicy structure on subsequent allocations.
Fix: Rather than add another condition to the conditional reference
release, which occur in the allocation path, just add a reference when
returning the vma policy in shm_get_policy() to match the assumptions.
Cc: Greg KH <greg@kroah.com>
Cc: <eric.whitney@hp.com>
sem_exit_ns(), msg_exit_ns() and shm_exit_ns() are all called when an
ipc_namespace is released to free all ipcs of each type. But in fact, they
do the same thing: they loop around all ipcs to free them individually by
calling a specific routine.
This patch proposes to consolidate this by introducing a common function,
free_ipcs(), that do the job. The specific routine to call on each
individual ipcs is passed as parameter. For this, these ipc-specific
'free' routines are reworked to take a generic 'struct ipc_perm' as
parameter.
Cc: Cedric Le Goater <clg@fr.ibm.com>
Cc: Pavel Emelyanov <xemul@openvz.org>
Each ipc_namespace contains a table of 3 pointers to struct ipc_ids (3 for
msg, sem and shm, structure used to store all ipcs) These 'struct ipc_ids'
are dynamically allocated for each icp_namespace as the ipc_namespace
itself (for the init namespace, they are initialized with pointers to
static variables instead)
It is so for historical reason: in fact, before the use of idr to store the
ipcs, the ipcs were stored in tables of variable length, depending of the
maximum number of ipc allowed. Now, these 'struct ipc_ids' have a fixed
size. As they are allocated in any cases for each new ipc_namespace, there
is no gain of memory in having them allocated separately of the struct
ipc_namespace.
This patch proposes to make this table static in the struct ipc_namespace.
Thus, we can allocate all in once and get rid of all the code needed to
allocate and free these ipc_ids separately.
Acked-by: Cedric Le Goater <clg@fr.ibm.com>
Currently the IPC namespace management code is spread over the ipc/*.c files.
I moved this code into ipc/namespace.c file which is compiled out when needed.
The linux/ipc_namespace.h file is used to store the prototypes of the
functions in namespace.c and the stubs for NAMESPACES=n case. This is done
so, because the stub for copy_ipc_namespace requires the knowledge of the
CLONE_NEWIPC flag, which is in sched.h. But the linux/ipc.h file itself in
included into many many .c files via the sys.h->sem.h sequence so adding the
sched.h into it will make all these .c depend on sched.h which is not that
good. On the other hand the knowledge about the namespaces stuff is required
in 4 .c files only.
Besides, this patch compiles out some auxiliary functions from ipc/sem.c,
msg.c and shm.c files. It turned out that moving these functions into
namespaces.c is not that easy because they use many other calls and macros
from the original file. Moving them would make this patch complicated. On
the other hand all these functions can be consolidated, so I will send a
separate patch doing this a bit later.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Herbert Poetzl <herbert@13thfloor.at>
Cc: Kirill Korotaev <dev@sw.ru>
Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com>
In the new implementation of the [sem|shm|msg]_lock[_check]() routines, we
use the return value of ipc_lock() in container_of() without any check.
But ipc_lock may return a errcode. The use of this errcode in
container_of() may alter this errcode, and we don't want this.
And in xxx_exit_ns, the pointer return by idr_find is of type 'struct
kern_ipc_per'...
Today, the code will work as is because the member used in these
container_of() is the first member of its container (offset == 0), the
errcode isn't changed then. But in the general case, we can't count on
this assumption and this may lead later to a real bug if we don't correct
this.
Again, the proposed solution is simple and correct. But, as pointed by
Nadia, with this solution, the same check will be done several times (in
all sub-callers...), what is not very funny/optimal...
With the use of idr to store the ipc, the case where the idr cache is
empty, when idr_get_new is called (this may happen even if we call
idr_pre_get() before), is not well handled: it lets
semget()/shmget()/msgget() return ENOSPC when this cache is empty, what 1.
does not reflect the facts and 2. does not conform to the man(s).
This patch fixes this by retrying the whole process of allocation in this case.
Remvoe the unneeded parameters from ipc_checkid() and ipc_buildid()
interfaces.
This is a patch that fixes the way idr_find() used to be called in ipc_lock():
in all the paths that don't imply an update of the ipcs idr, it was called
without the idr tree being locked.
The changes are:
. in ipc_ids, the mutex has been changed into a reader/writer semaphore.
. ipc_lock() now takes the mutex as a reader during the idr_find().
. a new routine ipc_lock_down() has been defined: it doesn't take the
mutex, assuming that it is being held by the caller. This is the routine
that is now called in all the update paths.
Acked-by: Jarek Poplawski <jarkao2@o2.pl>
This patch fixes the wrong / obsolete comments in the ipc code. Also adds
a missing lock around ipc_get_maxid() in shm_get_stat().
This patch converts casts of struct kern_ipc_perm to
. struct msg_queue
. struct sem_array
. struct shmid_kernel
into the equivalent container_of() macro. It improves code maintenance
because the code need not change if kern_ipc_perm is no longer at the
beginning of the containing struct.
This patch introduces a new ipc_lock_check() routine interface:
. each time ipc_checkid() is called, this is done after calling ipc_lock().
ipc_checkid() is now called from inside ipc_lock_check().
[akpm@linux-foundation.org: build fix]
[akpm@linux-foundation.org: fix RCU locking]
This is a trivial patch that removes the ipc_get() routine: it is replaced
by a call to idr_find().
This patch introduces a change into the sys_msgget(), sys_semget() and
sys_shmget() routines: they now share a common code, which is better for
maintainability.
This patch introduces ipcs storage into IDRs. The main changes are:
. This ipc_ids structure is changed: the entries array is changed into a
root idr structure.
. The grow_ary() routine is removed: it is not needed anymore when adding
an ipc structure, since we are now using the IDR facility.
. The ipc_rmid() routine interface is changed:
. there is no need for this routine to return the pointer passed in as
argument: it is now declared as a void
. since the id is now part of the kern_ipc_perm structure, no need to
have it as an argument to the routine
This is the largest patch in the set. Make all (I hope) the places where
the pid is shown to or get from user operate on the virtual pids.
The idea is:
- all in-kernel data structures must store either struct pid itself
or the pid's global nr, obtained with pid_nr() call;
- when seeking the task from kernel code with the stored id one
should use find_task_by_pid() call that works with global pids;
- when showing pid's numerical value to the user the virtual one
should be used, but however when one shows task's pid outside this
task's namespace the global one is to be used;
- when getting the pid from userspace one need to consider this as
the virtual one and use appropriate task/pid-searching functions.
[akpm@linux-foundation.org: nuther build fix]
[akpm@linux-foundation.org: yet nuther build fix]
[akpm@linux-foundation.org: remove unneeded casts]
Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org>
Cc: Oleg Nesterov <oleg@tv-sign.ru>
Cc: Paul Menage <menage@google.com>
Why do we need r/o bind mounts?
This feature allows a read-only view into a read-write filesystem. In the
process of doing that, it also provides infrastructure for keeping track of
the number of writers to any given mount.
This has a number of uses. It allows chroots to have parts of filesystems
writable. It will be useful for containers in the future because users may
have root inside a container, but should not be allowed to write to
somefilesystems. This also replaces patches that vserver has had out of the
tree for several years.
It allows security enhancement by making sure that parts of your filesystem
read-only (such as when you don't trust your FTP server), when you don't want
to have entire new filesystems mounted, or when you want atime selectively
updated. I've been using the following script to test that the feature is
working as desired. It takes a directory and makes a regular bind and a r/o
bind mount of it. It then performs some normal filesystem operations on the
three directories, including ones that are expected to fail, like creating a
file on the r/o mount.
This patch:
Some filesystems forego the vfs and may_open() and create their own 'struct
file's.
This patch creates a couple of helper functions which can be used by these
filesystems, and will provide a unified place which the r/o bind mount code
may patch.
Also, rename an existing, static-scope init_file() to a less generic name.
Signed-off-by: Dave Hansen <haveblue@us.ibm.com>
This patch makes two needlessly global functions static.
