path: root/ipc/util.h
2007-10-19ipc: remove unneeded parametersNadia Derbey
Remvoe the unneeded parameters from ipc_checkid() and ipc_buildid() interfaces. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19fix idr_find() lockingNadia Derbey
This is a patch that fixes the way idr_find() used to be called in ipc_lock(): in all the paths that don't imply an update of the ipcs idr, it was called without the idr tree being locked. The changes are: . in ipc_ids, the mutex has been changed into a reader/writer semaphore. . ipc_lock() now takes the mutex as a reader during the idr_find(). . a new routine ipc_lock_down() has been defined: it doesn't take the mutex, assuming that it is being held by the caller. This is the routine that is now called in all the update paths. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Acked-by: Jarek Poplawski <jarkao2@o2.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19ipc: fix wrong commentsNadia Derbey
This patch fixes the wrong / obsolete comments in the ipc code. Also adds a missing lock around ipc_get_maxid() in shm_get_stat(). Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19ipc: inline ipc_buildid()Nadia Derbey
This is a trivial patch that changes the ipc_buildid() routine into a static inline. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19ipc: introduce the ipcid_to_idx macroNadia Derbey
This is a trivial patch that changes all the (id % SEQ_MULTIPLIER) into a call to the ipcid_to_idx(id) macro. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Storing ipcs into IDRsNadia Derbey
This patch converts casts of struct kern_ipc_perm to . struct msg_queue . struct sem_array . struct shmid_kernel into the equivalent container_of() macro. It improves code maintenance because the code need not change if kern_ipc_perm is no longer at the beginning of the containing struct. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19ipc: integrate ipc_checkid() into ipc_lock()Nadia Derbey
This patch introduces a new ipc_lock_check() routine interface: . each time ipc_checkid() is called, this is done after calling ipc_lock(). ipc_checkid() is now called from inside ipc_lock_check(). [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix RCU locking] Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19ipc: remove the ipc_get() routineNadia Derbey
This is a trivial patch that removes the ipc_get() routine: it is replaced by a call to idr_find(). Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19ipc: unify the syscalls codeNadia Derbey
This patch introduces a change into the sys_msgget(), sys_semget() and sys_shmget() routines: they now share a common code, which is better for maintainability. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19ipc: store ipcs into IDRsNadia Derbey
This patch introduces ipcs storage into IDRs. The main changes are: . This ipc_ids structure is changed: the entries array is changed into a root idr structure. . The grow_ary() routine is removed: it is not needed anymore when adding an ipc structure, since we are now using the IDR facility. . The ipc_rmid() routine interface is changed: . there is no need for this routine to return the pointer passed in as argument: it is now declared as a void . since the id is now part of the kern_ipc_perm structure, no need to have it as an argument to the routine Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16remove CONFIG_UTS_NS and CONFIG_IPC_NSCedric Le Goater
CONFIG_UTS_NS and CONFIG_IPC_NS have very little value as they only deactivate the unshare of the uts and ipc namespaces and do not improve performance. Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Acked-by: "Serge E. Hallyn" <serue@us.ibm.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Pavel Emelianov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-11-03[PATCH] Fix ipc entries removalPavel Emelianov
Fix two issuses related to ipc_ids->entries freeing. 1. When freeing ipc namespace we need to free entries allocated with ipc_init_ids(). 2. When removing old entries in grow_ary() ipc_rcu_putref() may be called on entries set to &ids->nullentry earlier in ipc_init_ids(). This is almost impossible without namespaces, but with them this situation becomes possible. Found during OpenVZ testing after obvious leaks in beancounters. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Cc: Kirill Korotaev <dev@openvz.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] IPC namespace - utilsKirill Korotaev
This patch adds basic IPC namespace functionality to IPC utils: - init_ipc_ns - copy/clone/unshare/free IPC ns - /proc preparations Signed-off-by: Pavel Emelianov <xemul@openvz.org> Signed-off-by: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] sem2mutex: ipc, id.semIngo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-15correct email address of Manfred SpraulChristian Kujau
I tried to send the forcedeth maintainer an email, but it came back with: "The mail address manfreds@colorfullife.com is not read anymore. Please resent your mail to manfred@ instead of manfreds@." This patch fixes this. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-09-07[PATCH] ipc: add generic struct ipc_ids seq_file iterationMike Waychison
The following two patches convert /proc/sysvipc/* to use seq_file. This gives us the following: - Self-consistent IPC records in proc. - O(n) reading of the files themselves. This patch: Add a generic method for ipc types to be displayed using seq_file. This patch abstracts out seq_file iterating over struct ipc_ids into ipc/util.c Signed-off-by: Mike Waychison <mikew@google.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[PATCH] xtensa: remove old syscallsChris Zankel
This patch fixes some minor bugs introduced by the previous patch (remove old syscalls). Both patches remove the obsolete syscalls. The changes in this patch were suggested by Arnd Bergmann. The vmlinux.lds.S changes are required for the latest gcc/binutils. Signed-off-by: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
