path: root/ipc
2015-08-25ipc,sem: fix use after free on IPC_RMID after a task using same semaphore ↵Herton R. Krzesinski
set exits commit 602b8593d2b4138c10e922eeaafe306f6b51817b upstream. The current semaphore code allows a potential use after free: in exit_sem we may free the task's sem_undo_list while there is still another task looping through the same semaphore set and cleaning the sem_undo list at freeary function (the task called IPC_RMID for the same semaphore set). For example, with a test program [1] running which keeps forking a lot of processes (which then do a semop call with SEM_UNDO flag), and with the parent right after removing the semaphore set with IPC_RMID, and a kernel built with CONFIG_SLAB, CONFIG_SLAB_DEBUG and CONFIG_DEBUG_SPINLOCK, you can easily see something like the following in the kernel log: Slab corruption (Not tainted): kmalloc-64 start=ffff88003b45c1c0, len=64 000: 6b 6b 6b 6b 6b 6b 6b 6b 00 6b 6b 6b 6b 6b 6b 6b kkkkkkkk.kkkkkkk 010: ff ff ff ff 6b 6b 6b 6b ff ff ff ff ff ff ff ff ....kkkk........ Prev obj: start=ffff88003b45c180, len=64 000: 00 00 00 00 ad 4e ad de ff ff ff ff 5a 5a 5a 5a .....N......ZZZZ 010: ff ff ff ff ff ff ff ff c0 fb 01 37 00 88 ff ff ...........7.... Next obj: start=ffff88003b45c200, len=64 000: 00 00 00 00 ad 4e ad de ff ff ff ff 5a 5a 5a 5a .....N......ZZZZ 010: ff ff ff ff ff ff ff ff 68 29 a7 3c 00 88 ff ff ........h).<.... BUG: spinlock wrong CPU on CPU#2, test/18028 general protection fault: 0000 [#1] SMP Modules linked in: 8021q mrp garp stp llc nf_conntrack_ipv4 nf_defrag_ipv4 ip6t_REJECT nf_reject_ipv6 nf_conntrack_ipv6 nf_defrag_ipv6 xt_state nf_conntrack ip6table_filter ip6_tables binfmt_misc ppdev input_leds joydev parport_pc parport floppy serio_raw virtio_balloon virtio_rng virtio_console virtio_net iosf_mbi crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr qxl ttm drm_kms_helper drm snd_hda_codec_generic i2c_piix4 snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep snd_seq snd_seq_device snd_pcm snd_timer snd soundcore crc32c_intel virtio_pci virtio_ring virtio pata_acpi ata_generic [last unloaded: speedstep_lib] CPU: 2 PID: 18028 Comm: test Not tainted 4.2.0-rc5+ #1 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.8.1-20150318_183358- 04/01/2014 RIP: spin_dump+0x53/0xc0 Call Trace: spin_bug+0x30/0x40 do_raw_spin_unlock+0x71/0xa0 _raw_spin_unlock+0xe/0x10 freeary+0x82/0x2a0 ? _raw_spin_lock+0xe/0x10 semctl_down.clone.0+0xce/0x160 ? __do_page_fault+0x19a/0x430 ? __audit_syscall_entry+0xa8/0x100 SyS_semctl+0x236/0x2c0 ? syscall_trace_leave+0xde/0x130 entry_SYSCALL_64_fastpath+0x12/0x71 Code: 8b 80 88 03 00 00 48 8d 88 60 05 00 00 48 c7 c7 a0 2c a4 81 31 c0 65 8b 15 eb 40 f3 7e e8 08 31 68 00 4d 85 e4 44 8b 4b 08 74 5e <45> 8b 84 24 88 03 00 00 49 8d 8c 24 60 05 00 00 8b 53 04 48 89 RIP [<ffffffff810d6053>] spin_dump+0x53/0xc0 RSP <ffff88003750fd68> ---[ end trace 783ebb76612867a0 ]--- NMI watchdog: BUG: soft lockup - CPU#3 stuck for 22s! [test:18053] Modules linked in: 8021q mrp garp stp llc nf_conntrack_ipv4 nf_defrag_ipv4 ip6t_REJECT nf_reject_ipv6 nf_conntrack_ipv6 nf_defrag_ipv6 xt_state nf_conntrack ip6table_filter ip6_tables binfmt_misc ppdev input_leds joydev parport_pc parport floppy serio_raw virtio_balloon virtio_rng virtio_console virtio_net iosf_mbi crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr qxl ttm drm_kms_helper drm snd_hda_codec_generic i2c_piix4 snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep snd_seq snd_seq_device snd_pcm snd_timer snd soundcore crc32c_intel virtio_pci virtio_ring virtio pata_acpi ata_generic [last unloaded: speedstep_lib] CPU: 3 PID: 18053 Comm: test Tainted: G D 4.2.0-rc5+ #1 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.8.1-20150318_183358- 04/01/2014 RIP: native_read_tsc+0x0/0x20 Call Trace: ? delay_tsc+0x40/0x70 __delay+0xf/0x20 do_raw_spin_lock+0x96/0x140 _raw_spin_lock+0xe/0x10 sem_lock_and_putref+0x11/0x70 SYSC_semtimedop+0x7bf/0x960 ? handle_mm_fault+0xbf6/0x1880 ? dequeue_task_fair+0x79/0x4a0 ? __do_page_fault+0x19a/0x430 ? kfree_debugcheck+0x16/0x40 ? __do_page_fault+0x19a/0x430 ? __audit_syscall_entry+0xa8/0x100 ? do_audit_syscall_entry+0x66/0x70 ? syscall_trace_enter_phase1+0x139/0x160 SyS_semtimedop+0xe/0x10 SyS_semop+0x10/0x20 entry_SYSCALL_64_fastpath+0x12/0x71 Code: 47 10 83 e8 01 85 c0 89 47 10 75 08 65 48 89 3d 1f 74 ff 7e c9 c3 0f 1f 44 00 00 55 48 89 e5 e8 87 17 04 00 66 90 c9 c3 0f 1f 00 <55> 48 89 e5 0f 31 89 c1 48 89 d0 48 c1 e0 20 89 c9 48 09 c8 c9 Kernel panic - not syncing: softlockup: hung tasks I wasn't able to trigger any badness on a recent kernel without the proper config debugs enabled, however I have softlockup reports on some kernel versions, in the semaphore code, which are similar as above (the scenario is seen on some servers running IBM DB2 which uses semaphore syscalls). The patch here fixes the race against freeary, by acquiring or waiting on the sem_undo_list lock as necessary (exit_sem can race with freeary, while freeary sets un->semid to -1 and removes the same sem_undo from list_proc or when it removes the last sem_undo). After the patch I'm unable to reproduce the problem using the test case [1]. [1] Test case used below: #include <stdio.h> #include <sys/types.h> #include <sys/ipc.h> #include <sys/sem.h> #include <sys/wait.h> #include <stdlib.h> #include <time.h> #include <unistd.h> #include <errno.h> #define NSEM 1 #define NSET 5 int sid[NSET]; void thread() { struct sembuf op; int s; uid_t pid = getuid(); s = rand() % NSET; op.sem_num = pid % NSEM; op.sem_op = 1; op.sem_flg = SEM_UNDO; semop(sid[s], &op, 1); exit(EXIT_SUCCESS); } void create_set() { int i, j; pid_t p; union { int val; struct semid_ds *buf; unsigned short int *array; struct seminfo *__buf; } un; /* Create and initialize semaphore set */ for (i = 0; i < NSET; i++) { sid[i] = semget(IPC_PRIVATE , NSEM, 0644 | IPC_CREAT); if (sid[i] < 0) { perror("semget"); exit(EXIT_FAILURE); } } un.val = 0; for (i = 0; i < NSET; i++) { for (j = 0; j < NSEM; j++) { if (semctl(sid[i], j, SETVAL, un) < 0) perror("semctl"); } } /* Launch threads that operate on semaphore set */ for (i = 0; i < NSEM * NSET * NSET; i++) { p = fork(); if (p < 0) perror("fork"); if (p == 0) thread(); } /* Free semaphore set */ for (i = 0; i < NSET; i++) { if (semctl(sid[i], NSEM, IPC_RMID)) perror("IPC_RMID"); } /* Wait for forked processes to exit */ while (wait(NULL)) { if (errno == ECHILD) break; }; } int main(int argc, char **argv) { pid_t p; srand(time(NULL)); while (1) { p = fork(); if (p < 0) { perror("fork"); exit(EXIT_FAILURE); } if (p == 0) { create_set(); goto end; } /* Wait for forked processes to exit */ while (wait(NULL)) { if (errno == ECHILD) break; }; } end: return 0; } [akpm@linux-foundation.org: use normal comment layout] Signed-off-by: Herton R. Krzesinski <herton@redhat.com> Acked-by: Manfred Spraul <manfred@colorfullife.com> Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: Rafael Aquini <aquini@redhat.com> CC: Aristeu Rozanski <aris@redhat.com> Cc: David Jeffery <djeffery@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-08-25ipc/sem.c: update/correct memory barriersManfred Spraul
commit 3ed1f8a99d70ea1cd1508910eb107d0edcae5009 upstream. sem_lock() did not properly pair memory barriers: !spin_is_locked() and spin_unlock_wait() are both only control barriers. The code needs an acquire barrier, otherwise the cpu might perform read operations before the lock test. As no primitive exists inside <include/spinlock.h> and since it seems noone wants another primitive, the code creates a local primitive within ipc/sem.c. With regards to -stable: The change of sem_wait_array() is a bugfix, the change to sem_lock() is a nop (just a preprocessor redefinition to improve the readability). The bugfix is necessary for all kernels that use sem_wait_array() (i.e.: starting from 3.10). Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Reported-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Kirill Tkhai <ktkhai@parallels.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Davidlohr Bueso <dave@stgolabs.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-08-25ipc: modify message queue accounting to not take kernel data structures into ↵Marcus Gelderie
account commit de54b9ac253787c366bbfb28d901a31954eb3511 upstream. A while back, the message queue implementation in the kernel was improved to use btrees to speed up retrieval of messages, in commit d6629859b36d ("ipc/mqueue: improve performance of send/recv"). That patch introducing the improved kernel handling of message queues (using btrees) has, as a by-product, changed the meaning of the QSIZE field in the pseudo-file created for the queue. Before, this field reflected the size of the user-data in the queue. Since, it also takes kernel data structures into account. For example, if 13 bytes of user data are in the queue, on my machine the file reports a size of 61 bytes. There was some discussion on this topic before (for example https://lkml.org/lkml/2014/10/1/115). Commenting on a th lkml, Michael Kerrisk gave the following background (https://lkml.org/lkml/2015/6/16/74): The pseudofiles in the mqueue filesystem (usually mounted at /dev/mqueue) expose fields with metadata describing a message queue. One of these fields, QSIZE, as originally implemented, showed the total number of bytes of user data in all messages in the message queue, and this feature was documented from the beginning in the mq_overview(7) page. In 3.5, some other (useful) work happened to break the user-space API in a couple of places, including the value exposed via QSIZE, which now includes a measure of kernel overhead bytes for the queue, a figure that renders QSIZE useless for its original purpose, since there's no way to deduce the number of overhead bytes consumed by the implementation. (The other user-space breakage was subsequently fixed.) This patch removes the accounting of kernel data structures in the queue. Reporting the size of these data-structures in the QSIZE field was a breaking change (see Michael's comment above). Without the QSIZE field reporting the total size of user-data in the queue, there is no way to deduce this number. It should be noted that the resource limit RLIMIT_MSGQUEUE is counted against the worst-case size of the queue (in both the old and the new implementation). Therefore, the kernel overhead accounting in QSIZE is not necessary to help the user understand the limitations RLIMIT imposes on the processes. Signed-off-by: Marcus Gelderie <redmnic@gmail.com> Acked-by: Doug Ledford <dledford@redhat.com> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Davidlohr Bueso <dbueso@suse.de> Cc: David Howells <dhowells@redhat.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: John Duffy <jb_duffy@btinternet.com> Cc: Arto Bendiken <arto@bendiken.net> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-04-09shmdt: use i_size_read() instead of ->i_sizeDave Hansen
commit 07a46ed27dc6344de831a450df82336270a157a9 upstream. Andrew Morton noted http://lkml.kernel.org/r/20141104142027.a7a0d010772d84560b445f59@linux-foundation.org that the shmdt uses inode->i_size outside of i_mutex being held. There is one more case in shm.c in shm_destroy(). This converts both users over to use i_size_read(). Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Davidlohr Bueso <dave@stgolabs.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-04-09ipc/shm.c: fix overly aggressive shmdt() when calls span multiple segmentsDave Hansen
commit d3c97900b427b8d5a476fdfe484267f09df418d6 upstream. This is a highly-contrived scenario. But, a single shmdt() call can be induced in to unmapping memory from mulitple shm segments. Example code is here: http://www.sr71.net/~dave/intel/shmfun.c The fix is pretty simple: Record the 'struct file' for the first VMA we encounter and then stick to it. Decline to unmap anything not from the same file and thus the same segment. I found this by inspection and the odds of anyone hitting this in practice are pretty darn small. Lightly tested, but it's a pretty small patch. Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Cc: Manfred Spraul <manfred@colorfullife.com> Reviewed-by: Davidlohr Bueso <dave@stgolabs.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-04-09ipc/sem.c: fully initialize sem_array before making it visibleManfred Spraul
commit e8577d1f0329d4842e8302e289fb2c22156abef4 upstream. ipc_addid() makes a new ipc identifier visible to everyone. New objects start as locked, so that the caller can complete the initialization after the call. Within struct sem_array, at least sma->sem_base and sma->sem_nsems are accessed without any locks, therefore this approach doesn't work. Thus: Move the ipc_addid() to the end of the initialization. Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Reported-by: Rik van Riel <riel@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Davidlohr Bueso <dave@stgolabs.net> Acked-by: Rafael Aquini <aquini@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-16ipc/sem.c: change memory barrier in sem_lock() to smp_rmb()Manfred Spraul
commit 2e094abfd1f29a08a60523b42d4508281b8dee0e upstream. When I fixed bugs in the sem_lock() logic, I was more conservative than necessary. Therefore it is safe to replace the smp_mb() with smp_rmb(). And: With smp_rmb(), semop() syscalls are up to 10% faster. The race we must protect against is: sem->lock is free sma->complex_count = 0 sma->sem_perm.lock held by thread B thread A: A: spin_lock(&sem->lock) B: sma->complex_count++; (now 1) B: spin_unlock(&sma->sem_perm.lock); A: spin_is_locked(&sma->sem_perm.lock); A: XXXXX memory barrier A: if (sma->complex_count == 0) Thread A must read the increased complex_count value, i.e. the read must not be reordered with the read of sem_perm.lock done by spin_is_locked(). Since it's about ordering of reads, smp_rmb() is sufficient. [akpm@linux-foundation.org: update sem_lock() comment, from Davidlohr] Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Reviewed-by: Davidlohr Bueso <dave@stgolabs.net> Acked-by: Rafael Aquini <aquini@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-02ipc/compat_sys_msgrcv: change msgtyp type from long to compat_long_tHeiko Carstens
commit 291fdb0bcebd5e8db6af767c1fdc522167dad73d upstream. Change the type of compat_sys_msgrcv's msgtyp parameter from long to compat_long_t, since compat user space passes only a 32 bit signed value. Let the compat wrapper do proper sign extension to 64 bit of this parameter. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-02ipc: fix compat msgrcv with negative msgtypMateusz Guzik
commit e7ca2552369c1dfe0216c626baf82c3d83ec36bb upstream. Compat function takes msgtyp argument as u32 and passes it down to do_msgrcv which results in casting to long, thus the sign is lost and we get a big positive number instead. Cast the argument to signed type before passing it down. Signed-off-by: Mateusz Guzik <mguzik@redhat.com> Reported-by: Gabriellla Schmidt <gsc@bruker.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Davidlohr Bueso <davidlohr@hp.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-11-19ipc: always handle a new value of auto_msgmniAndrey Vagin
commit 1195d94e006b23c6292e78857e154872e33b6d7e upstream. proc_dointvec_minmax() returns zero if a new value has been set. So we don't need to check all charecters have been handled. Below you can find two examples. In the new value has not been handled properly. $ strace ./a.out open("/proc/sys/kernel/auto_msgmni", O_WRONLY) = 3 write(3, "0\n\0", 3) = 2 close(3) = 0 exit_group(0) $ cat /sys/kernel/debug/tracing/trace $strace ./a.out open("/proc/sys/kernel/auto_msgmni", O_WRONLY) = 3 write(3, "0\n", 2) = 2 close(3) = 0 $ cat /sys/kernel/debug/tracing/trace a.out-697 [000] .... 3280.998235: unregister_ipcns_notifier <-proc_ipcauto_dointvec_minmax Fixes: 9eefe520c814 ("ipc: do not use a negative value to re-enable msgmni automatic recomputin") Signed-off-by: Andrey Vagin <avagin@openvz.org> Cc: Mathias Krause <minipli@googlemail.com> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Joe Perches <joe@perches.com> Cc: Davidlohr Bueso <davidlohr@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-03-24ipc: Fix 2 bugs in msgrcv() MSG_COPY implementationMichael Kerrisk
commit 4f87dac386cc43d5525da7a939d4b4e7edbea22c upstream. While testing and documenting the msgrcv() MSG_COPY flag that Stanislav Kinsbursky added in commit 4a674f34ba04 ("ipc: introduce message queue copy feature" => kernel 3.8), I discovered a couple of bugs in the implementation. The two bugs concern MSG_COPY interactions with other msgrcv() flags, namely: (A) MSG_COPY + MSG_EXCEPT (B) MSG_COPY + !IPC_NOWAIT The bugs are distinct (and the fix for the first one is obvious), however my fix for both is a single-line patch, which is why I'm combining them in a single mail, rather than writing two mails+patches. ===== (A) MSG_COPY + MSG_EXCEPT ===== With the addition of the MSG_COPY flag, there are now two msgrcv() flags--MSG_COPY and MSG_EXCEPT--that modify the meaning of the 'msgtyp' argument in unrelated ways. Specifying both in the same call is a logical error that is currently permitted, with the effect that MSG_COPY has priority and MSG_EXCEPT is ignored. The call should give an error if both flags are specified. The patch below implements that behavior. ===== (B) (B) MSG_COPY + !IPC_NOWAIT ===== The test code that was submitted in commit 3a665531a3b7 ("selftests: IPC message queue copy feature test") shows MSG_COPY being used in conjunction with IPC_NOWAIT. In other words, if there is no message at the position 'msgtyp'. return immediately with the error in ENOMSG. What was not (fully) tested is the behavior if MSG_COPY is specified *without* IPC_NOWAIT, and there is an odd behavior. If the queue contains less than 'msgtyp' messages, then the call blocks until the next message is written to the queue. At that point, the msgrcv() call returns a copy of the newly added message, regardless of whether that message is at the ordinal position 'msgtyp'. This is clearly bogus, and problematic for applications that might want to make use of the MSG_COPY flag. I considered the following possible solutions to this problem: (1) Force the call to block until a message *does* appear at the position 'msgtyp'. (2) If the MSG_COPY flag is specified, the kernel should implicitly add IPC_NOWAIT, so that the call fails with ENOMSG for this case. (3) If the MSG_COPY flag is specified, but IPC_NOWAIT is not, generate an error (probably, EINVAL is the right one). I do not know if any application would really want to have the functionality of solution (1), especially since an application can determine in advance the number of messages in the queue using msgctl() IPC_STAT. Obviously, this solution would be the most work to implement. Solution (2) would have the effect of silently fixing any applications that tried to employ broken behavior. However, it would mean that if we later decided to implement solution (1), then user-space could not easily detect what the kernel supports (but, since I'm somewhat doubtful that solution (1) is needed, I'm not sure that this is much of a problem). Solution (3) would have the effect of informing broken applications that they are doing something broken. The downside is that this would cause a ABI breakage for any applications that are currently employing the broken behavior. However: a) Those applications are almost certainly not getting the results they expect. b) Possibly, those applications don't even exist, because MSG_COPY is currently hidden behind CONFIG_CHECKPOINT_RESTORE. The upside of solution (3) is that if we later decided to implement solution (1), user-space could determine what the kernel supports, via the error return. In my view, solution (3) is mildly preferable to solution (2), and solution (1) could still be done later if anyone really cares. The patch below implements solution (3). PS. For anyone out there still listening, it's the usual story: documenting an API (and the thinking about, and the testing of the API, that documentation entails) is the one of the single best ways of finding bugs in the API, as I've learned from a lot of experience. Best to do that documentation before releasing the API. Signed-off-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Cc: Stanislav Kinsbursky <skinsbursky@parallels.com> Cc: Serge Hallyn <serge.hallyn@canonical.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-03-05ipc,mqueue: remove limits for the amount of system-wide queuesDavidlohr Bueso
commit f3713fd9cff733d9df83116422d8e4af6e86b2bb upstream. Commit 93e6f119c0ce ("ipc/mqueue: cleanup definition names and locations") added global hardcoded limits to the amount of message queues that can be created. While these limits are per-namespace, reality is that it ends up breaking userspace applications. Historically users have, at least in theory, been able to create up to INT_MAX queues, and limiting it to just 1024 is way too low and dramatic for some workloads and use cases. For instance, Madars reports: "This update imposes bad limits on our multi-process application. As our app uses approaches that each process opens its own set of queues (usually something about 3-5 queues per process). In some scenarios we might run up to 3000 processes or more (which of-course for linux is not a problem). Thus we might need up to 9000 queues or more. All processes run under one user." Other affected users can be found in launchpad bug #1155695: https://bugs.launchpad.net/ubuntu/+source/manpages/+bug/1155695 Instead of increasing this limit, revert it entirely and fallback to the original way of dealing queue limits -- where once a user's resource limit is reached, and all memory is used, new queues cannot be created. Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Reported-by: Madars Vitolins <m@silodev.com> Acked-by: Doug Ledford <dledford@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2013-12-04ipc, msg: fix message length check for negative valuesMathias Krause
commit 4e9b45a19241354daec281d7a785739829b52359 upstream. On 64 bit systems the test for negative message sizes is bogus as the size, which may be positive when evaluated as a long, will get truncated to an int when passed to load_msg(). So a long might very well contain a positive value but when truncated to an int it would become negative. That in combination with a small negative value of msg_ctlmax (which will be promoted to an unsigned type for the comparison against msgsz, making it a big positive value and therefore make it pass the check) will lead to two problems: 1/ The kmalloc() call in alloc_msg() will allocate a too small buffer as the addition of alen is effectively a subtraction. 2/ The copy_from_user() call in load_msg() will first overflow the buffer with userland data and then, when the userland access generates an access violation, the fixup handler copy_user_handle_tail() will try to fill the remainder with zeros -- roughly 4GB. That almost instantly results in a system crash or reset. ,-[ Reproducer (needs to be run as root) ]-- | #include <sys/stat.h> | #include <sys/msg.h> | #include <unistd.h> | #include <fcntl.h> | | int main(void) { | long msg = 1; | int fd; | | fd = open("/proc/sys/kernel/msgmax", O_WRONLY); | write(fd, "-1", 2); | close(fd); | | msgsnd(0, &msg, 0xfffffff0, IPC_NOWAIT); | | return 0; | } '--- Fix the issue by preventing msgsz from getting truncated by consistently using size_t for the message length. This way the size checks in do_msgsnd() could still be passed with a negative value for msg_ctlmax but we would fail on the buffer allocation in that case and error out. Also change the type of m_ts from int to size_t to avoid similar nastiness in other code paths -- it is used in similar constructs, i.e. signed vs. unsigned checks. It should never become negative under normal circumstances, though. Setting msg_ctlmax to a negative value is an odd configuration and should be prevented. As that might break existing userland, it will be handled in a separate commit so it could easily be reverted and reworked without reintroducing the above described bug. Hardening mechanisms for user copy operations would have catched that bug early -- e.g. checking slab object sizes on user copy operations as the usercopy feature of the PaX patch does. Or, for that matter, detect the long vs. int sign change due to truncation, as the size overflow plugin of the very same patch does. [akpm@linux-foundation.org: fix i386 min() warnings] Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Pax Team <pageexec@freemail.hu> Cc: Davidlohr Bueso <davidlohr@hp.com> Cc: Brad Spengler <spender@grsecurity.net> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29ipc,shm: fix shm_file deletion racesGreg Thelen
commit a399b29dfbaaaf91162b2dc5a5875dd51bbfa2a1 upstream. When IPC_RMID races with other shm operations there's potential for use-after-free of the shm object's associated file (shm_file). Here's the race before this patch: TASK 1 TASK 2 ------ ------ shm_rmid() ipc_lock_object() shmctl() shp = shm_obtain_object_check() shm_destroy() shum_unlock() fput(shp->shm_file) ipc_lock_object() shmem_lock(shp->shm_file) <OOPS> The oops is caused because shm_destroy() calls fput() after dropping the ipc_lock. fput() clears the file's f_inode, f_path.dentry, and f_path.mnt, which causes various NULL pointer references in task 2. I reliably see the oops in task 2 if with shmlock, shmu This patch fixes the races by: 1) set shm_file=NULL in shm_destroy() while holding ipc_object_lock(). 2) modify at risk operations to check shm_file while holding ipc_object_lock(). Example workloads, which each trigger oops... Workload 1: while true; do id=$(shmget 1 4096) shm_rmid $id & shmlock $id & wait done The oops stack shows accessing NULL f_inode due to racing fput: _raw_spin_lock shmem_lock SyS_shmctl Workload 2: while true; do id=$(shmget 1 4096) shmat $id 4096 & shm_rmid $id & wait done The oops stack is similar to workload 1 due to NULL f_inode: touch_atime shmem_mmap shm_mmap mmap_region do_mmap_pgoff do_shmat SyS_shmat Workload 3: while true; do id=$(shmget 1 4096) shmlock $id shm_rmid $id & shmunlock $id & wait done The oops stack shows second fput tripping on an NULL f_inode. The first fput() completed via from shm_destroy(), but a racing thread did a get_file() and queued this fput(): locks_remove_flock __fput ____fput task_work_run do_notify_resume int_signal Fixes: c2c737a0461e ("ipc,shm: shorten critical region for shmat") Fixes: 2caacaa82a51 ("ipc,shm: shorten critical region for shmctl") Signed-off-by: Greg Thelen <gthelen@google.com> Cc: Davidlohr Bueso <davidlohr@hp.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29ipc,shm: correct error return value in shmctl (SHM_UNLOCK)Jesper Nilsson
commit 3a72660b07d86d60457ca32080b1ce8c2b628ee2 upstream. Commit 2caacaa82a51 ("ipc,shm: shorten critical region for shmctl") restructured the ipc shm to shorten critical region, but introduced a path where the return value could be -EPERM, even if the operation actually was performed. Before the commit, the err return value was reset by the return value from security_shm_shmctl() after the if (!ns_capable(...)) statement. Now, we still exit the if statement with err set to -EPERM, and in the case of SHM_UNLOCK, it is not reset at all, and used as the return value from shmctl. To fix this, we only set err when errors occur, leaving the fallthrough case alone. Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Davidlohr Bueso <davidlohr@hp.com> Cc: Rik van Riel <riel@redhat.com> Cc: Michel Lespinasse <walken@google.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-03ipc, msg: forbid negative values for "msg{max,mnb,mni}"Mathias Krause
Negative message lengths make no sense -- so don't do negative queue lenghts or identifier counts. Prevent them from getting negative. Also change the underlying data types to be unsigned to avoid hairy surprises with sign extensions in cases where those variables get evaluated in unsigned expressions with bigger data types, e.g size_t. In case a user still wants to have "unlimited" sizes she could just use INT_MAX instead. Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-16ipc/sem.c: synchronize semop and semctl with IPC_RMIDManfred Spraul
After acquiring the semlock spinlock, operations must test that the array is still valid. - semctl() and exit_sem() would walk stale linked lists (ugly, but should be ok: all lists are empty) - semtimedop() would sleep forever - and if woken up due to a signal - access memory after free. The patch also: - standardizes the tests for .deleted, so that all tests in one function leave the function with the same approach. - unconditionally tests for .deleted immediately after every call to sem_lock - even it it means that for semctl(GETALL), .deleted will be tested twice. Both changes make the review simpler: After every sem_lock, there must be a test of .deleted, followed by a goto to the cleanup code (if the function uses "goto cleanup"). The only exception is semctl_down(): If sem_ids().rwsem is locked, then the presence in ids->ipcs_idr is equivalent to !.deleted, thus no additional test is required. Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Cc: Mike Galbraith <efault@gmx.de> Acked-by: Davidlohr Bueso <davidlohr@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-16ipc: update locking scheme commentsDavidlohr Bueso
The initial documentation was a bit incomplete, update accordingly. [akpm@linux-foundation.org: make it more readable in 80 columns] Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Acked-by: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-30ipc,msg: prevent race with rmid in msgsnd,msgrcvDavidlohr Bueso
This fixes a race in both msgrcv() and msgsnd() between finding the msg and actually dealing with the queue, as another thread can delete shmid underneath us if we are preempted before acquiring the kern_ipc_perm.lock. Manfred illustrates this nicely: Assume a preemptible kernel that is preempted just after msq = msq_obtain_object_check(ns, msqid) in do_msgrcv(). The only lock that is held is rcu_read_lock(). Now the other thread processes IPC_RMID. When the first task is resumed, then it will happily wait for messages on a deleted queue. Fix this by checking for if the queue has been deleted after taking the lock. Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Reported-by: Manfred Spraul <manfred@colorfullife.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: <stable@vger.kernel.org> [3.11] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-30ipc/sem.c: update sem_otime for all operationsManfred Spraul
In commit 0a2b9d4c7967 ("ipc/sem.c: move wake_up_process out of the spinlock section"), the update of semaphore's sem_otime(last semop time) was moved to one central position (do_smart_update). But since do_smart_update() is only called for operations that modify the array, this means that wait-for-zero semops do not update sem_otime anymore. The fix is simple: Non-alter operations must update sem_otime. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Reported-by: Jia He <jiakernel@gmail.com> Tested-by: Jia He <jiakernel@gmail.com> Cc: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-30ipc/sem.c: synchronize the proc interfaceManfred Spraul
The proc interface is not aware of sem_lock(), it instead calls ipc_lock_object() directly. This means that simple semop() operations can run in parallel with the proc interface. Right now, this is uncritical, because the implementation doesn't do anything that requires a proper synchronization. But it is dangerous and therefore should be fixed. Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Cc: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-30ipc/sem.c: optimize sem_lock()Manfred Spraul
Operations that need access to the whole array must guarantee that there are no simple operations ongoing. Right now this is achieved by spin_unlock_wait(sem->lock) on all semaphores. If complex_count is nonzero, then this spin_unlock_wait() is not necessary, because it was already performed in the past by the thread that increased complex_count and even though sem_perm.lock was dropped inbetween, no simple operation could have started, because simple operations cannot start when complex_count is non-zero. Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Cc: Mike Galbraith <bitbucket@online.de> Cc: Rik van Riel <riel@redhat.com> Reviewed-by: Davidlohr Bueso <davidlohr@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-30ipc/sem.c: fix race in sem_lock()Manfred Spraul
The exclusion of complex operations in sem_lock() is insufficient: after acquiring the per-semaphore lock, a simple op must first check that sem_perm.lock is not locked and only after that test check complex_count. The current code does it the other way around - and that creates a race. Details are below. The patch is a complete rewrite of sem_lock(), based in part on the code from Mike Galbraith. It removes all gotos and all loops and thus the risk of livelocks. I have tested the patch (together with the next one) on my i3 laptop and it didn't cause any problems. The bug is probably also present in 3.10 and 3.11, but for these kernels it might be simpler just to move the test of sma->complex_count after the spin_is_locked() test. Details of the bug: Assume: - sma->complex_count = 0. - Thread 1: semtimedop(complex op that must sleep) - Thread 2: semtimedop(simple op). Pseudo-Trace: Thread 1: sem_lock(): acquire sem_perm.lock Thread 1: sem_lock(): check for ongoing simple ops Nothing ongoing, thread 2 is still before sem_lock(). Thread 1: try_atomic_semop() <<< preempted. Thread 2: sem_lock(): static inline int sem_lock(struct sem_array *sma, struct sembuf *sops, int nsops) { int locknum; again: if (nsops == 1 && !sma->complex_count) { struct sem *sem = sma->sem_base + sops->sem_num; /* Lock just the semaphore we are interested in. */ spin_lock(&sem->lock); /* * If sma->complex_count was set while we were spinning, * we may need to look at things we did not lock here. */ if (unlikely(sma->complex_count)) { spin_unlock(&sem->lock); goto lock_array; } <<<<<<<<< <<< complex_count is still 0. <<< <<< Here it is preempted <<<<<<<<< Thread 1: try_atomic_semop() returns, notices that it must sleep. Thread 1: increases sma->complex_count. Thread 1: drops sem_perm.lock Thread 2: /* * Another process is holding the global lock on the * sem_array; we cannot enter our critical section, * but have to wait for the global lock to be released. */ if (unlikely(spin_is_locked(&sma->sem_perm.lock))) { spin_unlock(&sem->lock); spin_unlock_wait(&sma->sem_perm.lock); goto again; } <<< sem_perm.lock already dropped, thus no "goto again;" locknum = sops->sem_num; Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Cc: Mike Galbraith <bitbucket@online.de> Cc: Rik van Riel <riel@redhat.com> Cc: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: <stable@vger.kernel.org> [3.10+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-24ipc: fix race with LSMsDavidlohr Bueso
Currently, IPC mechanisms do security and auditing related checks under RCU. However, since security modules can free the security structure, for example, through selinux_[sem,msg_queue,shm]_free_security(), we can race if the structure is freed before other tasks are done with it, creating a use-after-free condition. Manfred illustrates this nicely, for instance with shared mem and selinux: -> do_shmat calls rcu_read_lock() -> do_shmat calls shm_object_check(). Checks that the object is still valid - but doesn't acquire any locks. Then it returns. -> do_shmat calls security_shm_shmat (e.g. selinux_shm_shmat) -> selinux_shm_shmat calls ipc_has_perm() -> ipc_has_perm accesses ipc_perms->security shm_close() -> shm_close acquires rw_mutex & shm_lock -> shm_close calls shm_destroy -> shm_destroy calls security_shm_free (e.g. selinux_shm_free_security) -> selinux_shm_free_security calls ipc_free_security(&shp->shm_perm) -> ipc_free_security calls kfree(ipc_perms->security) This patch delays the freeing of the security structures after all RCU readers are done. Furthermore it aligns the security life cycle with that of the rest of IPC - freeing them based on the reference counter. For situations where we need not free security, the current behavior is kept. Linus states: "... the old behavior was suspect for another reason too: having the security blob go away from under a user sounds like it could cause various other problems anyway, so I think the old code was at least _prone_ to bugs even if it didn't have catastrophic behavior." I have tested this patch with IPC testcases from LTP on both my quad-core laptop and on a 64 core NUMA server. In both cases selinux is enabled, and tests pass for both voluntary and forced preemption models. While the mentioned races are theoretical (at least no one as reported them), I wanted to make sure that this new logic doesn't break anything we weren't aware of. Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Acked-by: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11ipc: drop ipc_lock_checkDavidlohr Bueso
No remaining users, we now use ipc_obtain_object_check(). Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11ipc, shm: drop shm_lock_checkDavidlohr Bueso
This function was replaced by a the lockless shm_obtain_object_check(), and no longer has any users. Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11ipc: drop ipc_lock_by_ptrDavidlohr Bueso
After previous cleanups and optimizations, this function is no longer heavily used and we don't have a good reason to keep it. Update the few remaining callers and get rid of it. Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11ipc, shm: guard against non-existant vma in shmdt(2)Davidlohr Bueso
When !CONFIG_MMU there's a chance we can derefence a NULL pointer when the VM area isn't found - check the return value of find_vma(). Also, remove the redundant -EINVAL return: retval is set to the proper return code and *only* changed to 0, when we actually unmap the segments. Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11ipc: document general ipc locking schemeDavidlohr Bueso
As suggested by Andrew, add a generic initial locking scheme used throughout all sysv ipc mechanisms. Documenting the ids rwsem, how rcu can be enough to do the initial checks and when to actually acquire the kern_ipc_perm.lock spinlock. I found that adding it to util.c was generic enough. Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11ipc,msg: drop msg_unlockDavidlohr Bueso
There is only one user left, drop this function and just call ipc_unlock_object() and rcu_read_unlock(). Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11ipc: rename ids->rw_mutexDavidlohr Bueso
Since in some situations the lock can be shared for readers, we shouldn't be calling it a mutex, rename it to rwsem. Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11ipc,shm: shorten critical region for shmatDavidlohr Bueso
Similar to other system calls, acquire the kern_ipc_perm lock after doing the initial permission and security checks. [sasha.levin@oracle.com: dont leave do_shmat with rcu lock held] Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11ipc,shm: cleanup do_shmat pastaDavidlohr Bueso
Clean up some of the messy do_shmat() spaghetti code, getting rid of out_free and out_put_dentry labels. This makes shortening the critical region of this function in the next patch a little easier to do and read. Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11ipc,shm: shorten critical region for shmctlDavidlohr Bueso
With the *_INFO, *_STAT, IPC_RMID and IPC_SET commands already optimized, deal with the remaining SHM_LOCK and SHM_UNLOCK commands. Take the shm_perm lock after doing the initial auditing and security checks. The rest of the logic remains unchanged. Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11ipc,shm: make shmctl_nolock locklessDavidlohr Bueso
While the INFO cmd doesn't take the ipc lock, the STAT commands do acquire it unnecessarily. We can do the permissions and security checks only holding the rcu lock. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11ipc,shm: introduce shmctl_nolockDavidlohr Bueso
Similar to semctl and msgctl, when calling msgctl, the *_INFO and *_STAT commands can be performed without acquiring the ipc object. Add a shmctl_nolock() function and move the logic of *_INFO and *_STAT out of msgctl(). Since we are just moving functionality, this change still takes the lock and it will be properly lockless in the next patch. Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11ipc: drop ipcctl_pre_downDavidlohr Bueso
Now that sem, msgque and shm, through *_down(), all use the lockless variant of ipcctl_pre_down(), go ahead and delete it. [akpm@linux-foundation.org: fix function name in kerneldoc, cleanups] Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11ipc,shm: shorten critical region in shmctl_downDavidlohr Bueso
Instead of holding the ipc lock for the entire function, use the ipcctl_pre_down_nolock and only acquire the lock for specific commands: RMID and SET. Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11ipc,shm: introduce lockless functions to obtain the ipc objectDavidlohr Bueso
This is the third and final patchset that deals with reducing the amount of contention we impose on the ipc lock (kern_ipc_perm.lock). These changes mostly deal with shared memory, previous work has already been done for semaphores and message queues: http://lkml.org/lkml/2013/3/20/546 (sems) http://lkml.org/lkml/2013/5/15/584 (mqueues) With these patches applied, a custom shm microbenchmark stressing shmctl doing IPC_STAT with 4 threads a million times, reduces the execution time by 50%. A similar run, this time with IPC_SET, reduces the execution time from 3 mins and 35 secs to 27 seconds. Patches 1-8: replaces blindly taking the ipc lock for a smarter combination of rcu and ipc_obtain_object, only acquiring the spinlock when updating. Patch 9: renames the ids rw_mutex to rwsem, which is what it already was. Patch 10: is a trivial mqueue leftover cleanup Patch 11: adds a brief lock scheme description, requested by Andrew. This patch: Add shm_obtain_object() and shm_obtain_object_check(), which will allow us to get the ipc object without acquiring the lock. Just as with other forms of ipc, these functions are basically wrappers around ipc_obtain_object*(). Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull namespace changes from Eric Biederman: "This is an assorted mishmash of small cleanups, enhancements and bug fixes. The major theme is user namespace mount restrictions. nsown_capable is killed as it encourages not thinking about details that need to be considered. A very hard to hit pid namespace exiting bug was finally tracked and fixed. A couple of cleanups to the basic namespace infrastructure. Finally there is an enhancement that makes per user namespace capabilities usable as capabilities, and an enhancement that allows the per userns root to nice other processes in the user namespace" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: userns: Kill nsown_capable it makes the wrong thing easy capabilities: allow nice if we are privileged pidns: Don't have unshare(CLONE_NEWPID) imply CLONE_THREAD userns: Allow PR_CAPBSET_DROP in a user namespace. namespaces: Simplify copy_namespaces so it is clear what is going on. pidns: Fix hang in zap_pid_ns_processes by sending a potentially extra wakeup sysfs: Restrict mounting sysfs userns: Better restrictions on when proc and sysfs can be mounted vfs: Don't copy mount bind mounts of /proc/<pid>/ns/mnt between namespaces kernel/nsproxy.c: Improving a snippet of code. proc: Restrict mounting the proc filesystem vfs: Lock in place mounts from more privileged users
2013-09-03ipc/msg.c: Fix lost wakeup in msgsnd().Manfred Spraul
The check if the queue is full and adding current to the wait queue of pending msgsnd() operations (ss_add()) must be atomic. Otherwise: - the thread that performs msgsnd() finds a full queue and decides to sleep. - the thread that performs msgrcv() first reads all messages from the queue and then sleeps, because the queue is empty. - the msgrcv() calls do not perform any wakeups, because the msgsnd() task has not yet called ss_add(). - then the msgsnd()-thread first calls ss_add() and then sleeps. Net result: msgsnd() and msgrcv() both sleep forever. Observed with msgctl08 from ltp with a preemptible kernel. Fix: Call ipc_lock_object() before performing the check. The patch also moves security_msg_queue_msgsnd() under ipc_lock_object: - msgctl(IPC_SET) explicitely mentions that it tries to expunge any pending operations that are not allowed anymore with the new permissions. If security_msg_queue_msgsnd() is called without locks, then there might be races. - it makes the patch much simpler. Reported-and-tested-by: Vineet Gupta <Vineet.Gupta1@synopsys.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: stable@vger.kernel.org # for 3.11 Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-30userns: Kill nsown_capable it makes the wrong thing easyEric W. Biederman
nsown_capable is a special case of ns_capable essentially for just CAP_SETUID and CAP_SETGID. For the existing users it doesn't noticably simplify things and from the suggested patches I have seen it encourages people to do the wrong thing. So remove nsown_capable. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-08-28IPC: bugfix for msgrcv with msgtyp < 0Svenning Sørensen
According to 'man msgrcv': "If msgtyp is less than 0, the first message of the lowest type that is less than or equal to the absolute value of msgtyp shall be received." Bug: The kernel only returns a message if its type is 1; other messages with type < abs(msgtype) will never get returned. Fix: After having traversed the list to find the first message with the lowest type, we need to actually return that message. This regression was introduced by commit daaf74cf0867 ("ipc: refactor msg list search into separate function") Signed-off-by: Svenning Soerensen <sss@secomea.dk> Reviewed-by: Peter Hurley <peter@hurleysoftware.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09ipc/sem.c: rename try_atomic_semop() to perform_atomic_semop(), docu updateManfred Spraul
Cleanup: Some minor points that I noticed while writing the previous patches 1) The name try_atomic_semop() is misleading: The function performs the operation (if it is possible). 2) Some documentation updates. No real code change, a rename and documentation changes. Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Cc: Rik van Riel <riel@redhat.com> Cc: Davidlohr Bueso <davidlohr.bueso@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09ipc/sem.c: replace shared sem_otime with per-semaphore valueManfred Spraul
sem_otime contains the time of the last semaphore operation that completed successfully. Every operation updates this value, thus access from multiple cpus can cause thrashing. Therefore the patch replaces the variable with a per-semaphore variable. The per-array sem_otime is only calculated when required. No performance improvement on a single-socket i3 - only important for larger systems. Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Cc: Rik van Riel <riel@redhat.com> Cc: Davidlohr Bueso <davidlohr.bueso@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09ipc/sem.c: always use only one queue for alter operationsManfred Spraul
There are two places that can contain alter operations: - the global queue: sma->pending_alter - the per-semaphore queues: sma->sem_base[].pending_alter. Since one of the queues must be processed first, this causes an odd priorization of the wakeups: complex operations have priority over simple ops. The patch restores the behavior of linux <=3.0.9: The longest waiting operation has the highest priority. This is done by using only one queue: - if there are complex ops, then sma->pending_alter is used. - otherwise, the per-semaphore queues are used. As a side effect, do_smart_update_queue() becomes much simpler: no more goto logic. Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Cc: Rik van Riel <riel@redhat.com> Cc: Davidlohr Bueso <davidlohr.bueso@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09ipc/sem: separate wait-for-zero and alter tasks into seperate queuesManfred Spraul
Introduce separate queues for operations that do not modify the semaphore values. Advantages: - Simpler logic in check_restart(). - Faster update_queue(): Right now, all wait-for-zero operations are always tested, even if the semaphore value is not 0. - wait-for-zero gets again priority, as in linux <=3.0.9 Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Cc: Rik van Riel <riel@redhat.com> Cc: Davidlohr Bueso <davidlohr.bueso@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09ipc/sem.c: cacheline align the semaphore structuresManfred Spraul
As now each semaphore has its own spinlock and parallel operations are possible, give each semaphore its own cacheline. On a i3 laptop, this gives up to 28% better performance: #semscale 10 | grep "interleave 2" - before: Cpus 1, interleave 2 delay 0: 36109234 in 10 secs Cpus 2, interleave 2 delay 0: 55276317 in 10 secs Cpus 3, interleave 2 delay 0: 62411025 in 10 secs Cpus 4, interleave 2 delay 0: 81963928 in 10 secs -after: Cpus 1, interleave 2 delay 0: 35527306 in 10 secs Cpus 2, interleave 2 delay 0: 70922909 in 10 secs <<< + 28% Cpus 3, interleave 2 delay 0: 80518538 in 10 secs Cpus 4, interleave 2 delay 0: 89115148 in 10 secs <<< + 8.7% i3, with 2 cores and with hyperthreading enabled. Interleave 2 in order use first the full cores. HT partially hides the delay from cacheline trashing, thus the improvement is "only" 8.7% if 4 threads are running. Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Cc: Rik van Riel <riel@redhat.com> Cc: Davidlohr Bueso <davidlohr.bueso@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09ipc/util.c, ipc_rcu_alloc: cacheline align allocationManfred Spraul
Enforce that ipc_rcu_alloc returns a cacheline aligned pointer on SMP. Rationale: The SysV sem code tries to move the main spinlock into a seperate cacheline (____cacheline_aligned_in_smp). This works only if ipc_rcu_alloc returns cacheline aligned pointers. vmalloc and kmalloc return cacheline algined pointers, the implementation of ipc_rcu_alloc breaks that. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Cc: Rik van Riel <riel@redhat.com> Cc: Davidlohr Bueso <davidlohr.bueso@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09ipc: remove unused functionsDavidlohr Bueso
We can now drop the msg_lock and msg_lock_check functions along with a bogus comment introduced previously in semctl_down. Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
