[ Upstream commit b9a532277938798b53178d5a66af6e2915cb27cf ]
As reported by Dmitry Vyukov, we really shouldn't do ipc_addid() before
having initialized the IPC object state. Yes, we initialize the IPC
object in a locked state, but with all the lockless RCU lookup work,
that IPC object lock no longer means that the state cannot be seen.
We already did this for the IPC semaphore code (see commit e8577d1f0329:
"ipc/sem.c: fully initialize sem_array before making it visible") but we
clearly forgot about msg and shm.
Cc: Manfred Spraul <manfred@colorfullife.com>
Cc: Davidlohr Bueso <dbueso@suse.de>
Cc: stable@vger.kernel.org
[ Upstream commit 3ed1f8a99d70ea1cd1508910eb107d0edcae5009 ]
sem_lock() did not properly pair memory barriers:
!spin_is_locked() and spin_unlock_wait() are both only control barriers.
The code needs an acquire barrier, otherwise the cpu might perform read
operations before the lock test.
As no primitive exists inside <include/spinlock.h> and since it seems
noone wants another primitive, the code creates a local primitive within
ipc/sem.c.
With regards to -stable:
The change of sem_wait_array() is a bugfix, the change to sem_lock() is a
nop (just a preprocessor redefinition to improve the readability). The
bugfix is necessary for all kernels that use sem_wait_array() (i.e.:
starting from 3.10).
Signed-off-by: Manfred Spraul <manfred@colorfullife.com>
Reported-by: Oleg Nesterov <oleg@redhat.com>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Kirill Tkhai <ktkhai@parallels.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Davidlohr Bueso <dave@stgolabs.net>
Cc: <stable@vger.kernel.org> [3.10+]
set exits
[ Upstream commit 602b8593d2b4138c10e922eeaafe306f6b51817b ]
The current semaphore code allows a potential use after free: in
exit_sem we may free the task's sem_undo_list while there is still
another task looping through the same semaphore set and cleaning the
sem_undo list at freeary function (the task called IPC_RMID for the same
semaphore set).
For example, with a test program [1] running which keeps forking a lot
of processes (which then do a semop call with SEM_UNDO flag), and with
the parent right after removing the semaphore set with IPC_RMID, and a
kernel built with CONFIG_SLAB, CONFIG_SLAB_DEBUG and
CONFIG_DEBUG_SPINLOCK, you can easily see something like the following
in the kernel log:
Slab corruption (Not tainted): kmalloc-64 start=ffff88003b45c1c0, len=64
000: 6b 6b 6b 6b 6b 6b 6b 6b 00 6b 6b 6b 6b 6b 6b 6b kkkkkkkk.kkkkkkk
010: ff ff ff ff 6b 6b 6b 6b ff ff ff ff ff ff ff ff ....kkkk........
Prev obj: start=ffff88003b45c180, len=64
000: 00 00 00 00 ad 4e ad de ff ff ff ff 5a 5a 5a 5a .....N......ZZZZ
010: ff ff ff ff ff ff ff ff c0 fb 01 37 00 88 ff ff ...........7....
Next obj: start=ffff88003b45c200, len=64
010: ff ff ff ff ff ff ff ff 68 29 a7 3c 00 88 ff ff ........h).<....
BUG: spinlock wrong CPU on CPU#2, test/18028
general protection fault: 0000 [#1] SMP
Modules linked in: 8021q mrp garp stp llc nf_conntrack_ipv4 nf_defrag_ipv4 ip6t_REJECT nf_reject_ipv6 nf_conntrack_ipv6 nf_defrag_ipv6 xt_state nf_conntrack ip6table_filter ip6_tables binfmt_misc ppdev input_leds joydev parport_pc parport floppy serio_raw virtio_balloon virtio_rng virtio_console virtio_net iosf_mbi crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr qxl ttm drm_kms_helper drm snd_hda_codec_generic i2c_piix4 snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep snd_seq snd_seq_device snd_pcm snd_timer snd soundcore crc32c_intel virtio_pci virtio_ring virtio pata_acpi ata_generic [last unloaded: speedstep_lib]
CPU: 2 PID: 18028 Comm: test Not tainted 4.2.0-rc5+ #1
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.8.1-20150318_183358- 04/01/2014
RIP: spin_dump+0x53/0xc0
Call Trace:
spin_bug+0x30/0x40
do_raw_spin_unlock+0x71/0xa0
_raw_spin_unlock+0xe/0x10
freeary+0x82/0x2a0
? _raw_spin_lock+0xe/0x10
semctl_down.clone.0+0xce/0x160
? __do_page_fault+0x19a/0x430
? __audit_syscall_entry+0xa8/0x100
SyS_semctl+0x236/0x2c0
? syscall_trace_leave+0xde/0x130
entry_SYSCALL_64_fastpath+0x12/0x71
Code: 8b 80 88 03 00 00 48 8d 88 60 05 00 00 48 c7 c7 a0 2c a4 81 31 c0 65 8b 15 eb 40 f3 7e e8 08 31 68 00 4d 85 e4 44 8b 4b 08 74 5e <45> 8b 84 24 88 03 00 00 49 8d 8c 24 60 05 00 00 8b 53 04 48 89
RIP [<ffffffff810d6053>] spin_dump+0x53/0xc0
RSP <ffff88003750fd68>
---[ end trace 783ebb76612867a0 ]---
NMI watchdog: BUG: soft lockup - CPU#3 stuck for 22s! [test:18053]
CPU: 3 PID: 18053 Comm: test Tainted: G D 4.2.0-rc5+ #1
RIP: native_read_tsc+0x0/0x20
Call Trace:
? delay_tsc+0x40/0x70
__delay+0xf/0x20
do_raw_spin_lock+0x96/0x140
sem_lock_and_putref+0x11/0x70
SYSC_semtimedop+0x7bf/0x960
? handle_mm_fault+0xbf6/0x1880
? dequeue_task_fair+0x79/0x4a0
? kfree_debugcheck+0x16/0x40
? do_audit_syscall_entry+0x66/0x70
? syscall_trace_enter_phase1+0x139/0x160
SyS_semtimedop+0xe/0x10
SyS_semop+0x10/0x20
Code: 47 10 83 e8 01 85 c0 89 47 10 75 08 65 48 89 3d 1f 74 ff 7e c9 c3 0f 1f 44 00 00 55 48 89 e5 e8 87 17 04 00 66 90 c9 c3 0f 1f 00 <55> 48 89 e5 0f 31 89 c1 48 89 d0 48 c1 e0 20 89 c9 48 09 c8 c9
Kernel panic - not syncing: softlockup: hung tasks
I wasn't able to trigger any badness on a recent kernel without the
proper config debugs enabled, however I have softlockup reports on some
kernel versions, in the semaphore code, which are similar as above (the
scenario is seen on some servers running IBM DB2 which uses semaphore
syscalls).
The patch here fixes the race against freeary, by acquiring or waiting
on the sem_undo_list lock as necessary (exit_sem can race with freeary,
while freeary sets un->semid to -1 and removes the same sem_undo from
list_proc or when it removes the last sem_undo).
After the patch I'm unable to reproduce the problem using the test case
[1].
[1] Test case used below:
#include <stdio.h>
#include <sys/types.h>
#include <sys/ipc.h>
#include <sys/sem.h>
#include <sys/wait.h>
#include <stdlib.h>
#include <time.h>
#include <unistd.h>
#include <errno.h>
#define NSEM 1
#define NSET 5
int sid[NSET];
void thread()
struct sembuf op;
int s;
uid_t pid = getuid();
s = rand() % NSET;
op.sem_num = pid % NSEM;
op.sem_op = 1;
op.sem_flg = SEM_UNDO;
semop(sid[s], &op, 1);
exit(EXIT_SUCCESS);
void create_set()
int i, j;
pid_t p;
union {
int val;
struct semid_ds *buf;
unsigned short int *array;
struct seminfo *__buf;
} un;
/* Create and initialize semaphore set */
for (i = 0; i < NSET; i++) {
sid[i] = semget(IPC_PRIVATE , NSEM, 0644 | IPC_CREAT);
if (sid[i] < 0) {
perror("semget");
exit(EXIT_FAILURE);
un.val = 0;
for (j = 0; j < NSEM; j++) {
if (semctl(sid[i], j, SETVAL, un) < 0)
perror("semctl");
/* Launch threads that operate on semaphore set */
for (i = 0; i < NSEM * NSET * NSET; i++) {
p = fork();
if (p < 0)
perror("fork");
if (p == 0)
thread();
/* Free semaphore set */
if (semctl(sid[i], NSEM, IPC_RMID))
perror("IPC_RMID");
/* Wait for forked processes to exit */
while (wait(NULL)) {
if (errno == ECHILD)
break;
int main(int argc, char **argv)
pid_t p;
srand(time(NULL));
while (1) {
p = fork();
if (p < 0) {
perror("fork");
exit(EXIT_FAILURE);
if (p == 0) {
create_set();
goto end;
break;
end:
return 0;
[akpm@linux-foundation.org: use normal comment layout]
Signed-off-by: Herton R. Krzesinski <herton@redhat.com>
Acked-by: Manfred Spraul <manfred@colorfullife.com>
Cc: Rafael Aquini <aquini@redhat.com>
CC: Aristeu Rozanski <aris@redhat.com>
Cc: David Jeffery <djeffery@redhat.com>
account
[ Upstream commit de54b9ac253787c366bbfb28d901a31954eb3511 ]
A while back, the message queue implementation in the kernel was
improved to use btrees to speed up retrieval of messages, in commit
d6629859b36d ("ipc/mqueue: improve performance of send/recv").
That patch introducing the improved kernel handling of message queues
(using btrees) has, as a by-product, changed the meaning of the QSIZE
field in the pseudo-file created for the queue. Before, this field
reflected the size of the user-data in the queue. Since, it also takes
kernel data structures into account. For example, if 13 bytes of user
data are in the queue, on my machine the file reports a size of 61
bytes.
There was some discussion on this topic before (for example
https://lkml.org/lkml/2014/10/1/115). Commenting on a th lkml, Michael
Kerrisk gave the following background
(https://lkml.org/lkml/2015/6/16/74):
The pseudofiles in the mqueue filesystem (usually mounted at
/dev/mqueue) expose fields with metadata describing a message
queue. One of these fields, QSIZE, as originally implemented,
showed the total number of bytes of user data in all messages in
the message queue, and this feature was documented from the
beginning in the mq_overview(7) page. In 3.5, some other (useful)
work happened to break the user-space API in a couple of places,
including the value exposed via QSIZE, which now includes a measure
of kernel overhead bytes for the queue, a figure that renders QSIZE
useless for its original purpose, since there's no way to deduce
the number of overhead bytes consumed by the implementation.
(The other user-space breakage was subsequently fixed.)
This patch removes the accounting of kernel data structures in the
queue. Reporting the size of these data-structures in the QSIZE field
was a breaking change (see Michael's comment above). Without the QSIZE
field reporting the total size of user-data in the queue, there is no
way to deduce this number.
It should be noted that the resource limit RLIMIT_MSGQUEUE is counted
against the worst-case size of the queue (in both the old and the new
implementation). Therefore, the kernel overhead accounting in QSIZE is
not necessary to help the user understand the limitations RLIMIT imposes
on the processes.
Signed-off-by: Marcus Gelderie <redmnic@gmail.com>
Acked-by: Doug Ledford <dledford@redhat.com>
Acked-by: Michael Kerrisk <mtk.manpages@gmail.com>
Acked-by: Davidlohr Bueso <dbueso@suse.de>
Cc: John Duffy <jb_duffy@btinternet.com>
Cc: Arto Bendiken <arto@bendiken.net>
ipc_addid() makes a new ipc identifier visible to everyone. New objects
start as locked, so that the caller can complete the initialization
after the call. Within struct sem_array, at least sma->sem_base and
sma->sem_nsems are accessed without any locks, therefore this approach
doesn't work.
Thus: Move the ipc_addid() to the end of the initialization.
Reported-by: Rik van Riel <riel@redhat.com>
Acked-by: Davidlohr Bueso <dave@stgolabs.net>
Acked-by: Rafael Aquini <aquini@redhat.com>
Resolve some shadow warnings produced in W=2 builds by changing the name
of some parameters and local variables. Change instances of "s64"
because that clashes with the well-known typedef. Also change a local
variable with the name "up" because that clashes with the name of of the
"up" function for semaphores. These are hazards so eliminate the
hazards by renaming them.
Signed-off-by: Mark Rustad <mark.d.rustad@intel.com>
Using __seq_open_private() removes boilerplate code from
sysvipc_proc_open().
The resultant code is shorter and easier to follow.
However, please note that __seq_open_private() call kzalloc() rather than
kmalloc() which may affect timing due to the memory initialisation
overhead.
Signed-off-by: Rob Jones <rob.jones@codethink.co.uk>
do_shmat() is the only user of ->start_stack (proc just reports its
value), and this check looks ugly and wrong.
The reason for this check is not clear at all, and it wrongly assumes that
the stack can only grow down.
But the main problem is that in general mm->start_stack has nothing to do
with stack_vma->vm_start. Not only the application can switch to another
stack and even unmap this area, setup_arg_pages() expands the stack
without updating mm->start_stack during exec(). This means that in the
likely case "addr > start_stack - size - PAGE_SIZE * 5" is simply
impossible after find_vma_intersection() == F, or the stack can't grow
anyway because of RLIMIT_STACK.
Many thanks to Hugh for his explanations.
Cc: Cyrill Gorcunov <gorcunov@gmail.com>
Cc: Davidlohr Bueso <davidlohr.bueso@hp.com>
proc_dointvec_minmax() returns zero if a new value has been set. So we
don't need to check all charecters have been handled.
Below you can find two examples. In the new value has not been handled
properly.
$ strace ./a.out
open("/proc/sys/kernel/auto_msgmni", O_WRONLY) = 3
write(3, "0\n\0", 3) = 2
close(3) = 0
exit_group(0)
$ cat /sys/kernel/debug/tracing/trace
$strace ./a.out
write(3, "0\n", 2) = 2
close(3) = 0
a.out-697 [000] .... 3280.998235: unregister_ipcns_notifier <-proc_ipcauto_dointvec_minmax
Fixes: 9eefe520c814 ("ipc: do not use a negative value to re-enable msgmni automatic recomputin")
Signed-off-by: Andrey Vagin <avagin@openvz.org>
Cc: Mathias Krause <minipli@googlemail.com>
Cc: Joe Perches <joe@perches.com>
Cc: Davidlohr Bueso <davidlohr@hp.com>
Pull "trivial tree" updates from Jiri Kosina:
"Usual pile from trivial tree everyone is so eagerly waiting for"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Remove MN10300_PROC_MN2WS0038
mei: fix comments
treewide: Fix typos in Kconfig
kprobes: update jprobe_example.c for do_fork() change
Documentation: change "&" to "and" in Documentation/applying-patches.txt
Documentation: remove obsolete pcmcia-cs from Changes
Documentation: update links in Changes
Documentation: Docbook: Fix generated DocBook/kernel-api.xml
score: Remove GENERIC_HAS_IOMAP
gpio: fix 'CONFIG_GPIO_IRQCHIP' comments
tty: doc: Fix grammar in serial/tty
dma-debug: modify check_for_stack output
treewide: fix errors in printk
genirq: fix reference in devm_request_threaded_irq comment
treewide: fix synchronize_rcu() in comments
checkstack.pl: port to AArch64
doc: queue-sysfs: minor fixes
init/do_mounts: better syntax description
MIPS: fix comment spelling
powerpc/simpleboot: fix comment
This patch fix spelling typo found in DocBook/kernel-api.xml.
It is because the file is generated from the source comments,
I have to fix the comments in source codes.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Acked-by: Randy Dunlap <rdunlap@infradead.org>
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull namespace updates from Eric Biederman:
"This is a bunch of small changes built against 3.16-rc6. The most
significant change for users is the first patch which makes setns
drmatically faster by removing unneded rcu handling.
The next chunk of changes are so that "mount -o remount,.." will not
allow the user namespace root to drop flags on a mount set by the
system wide root. Aks this forces read-only mounts to stay read-only,
no-dev mounts to stay no-dev, no-suid mounts to stay no-suid, no-exec
mounts to stay no exec and it prevents unprivileged users from messing
with a mounts atime settings. I have included my test case as the
last patch in this series so people performing backports can verify
this change works correctly.
The next change fixes a bug in NFS that was discovered while auditing
nsproxy users for the first optimization. Today you can oops the
kernel by reading /proc/fs/nfsfs/{servers,volumes} if you are clever
with pid namespaces. I rebased and fixed the build of the
!CONFIG_NFS_FS case yesterday when a build bot caught my typo. Given
that no one to my knowledge bases anything on my tree fixing the typo
in place seems more responsible that requiring a typo-fix to be
backported as well.
The last change is a small semantic cleanup introducing
/proc/thread-self and pointing /proc/mounts and /proc/net at it. This
prevents several kinds of problemantic corner cases. It is a
user-visible change so it has a minute chance of causing regressions
so the change to /proc/mounts and /proc/net are individual one line
commits that can be trivially reverted. Unfortunately I lost and
could not find the email of the original reporter so he is not
credited. From at least one perspective this change to /proc/net is a
refgression fix to allow pthread /proc/net uses that were broken by
the introduction of the network namespace"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace:
proc: Point /proc/mounts at /proc/thread-self/mounts instead of /proc/self/mounts
proc: Point /proc/net at /proc/thread-self/net instead of /proc/self/net
proc: Implement /proc/thread-self to point at the directory of the current thread
proc: Have net show up under /proc/<tgid>/task/<tid>
NFS: Fix /proc/fs/nfsfs/servers and /proc/fs/nfsfs/volumes
mnt: Add tests for unprivileged remount cases that have found to be faulty
mnt: Change the default remount atime from relatime to the existing value
mnt: Correct permission checks in do_remount
mnt: Move the test for MNT_LOCK_READONLY from change_mount_flags into do_remount
mnt: Only change user settable mount flags in remount
namespaces: Use task_lock and not rcu to protect nsproxy
If shm_rmid_force (the default state) is not set then the shmids are only
marked as orphaned and does not require any add, delete, or locking of the
tree structure.
Seperate the sysctl on and off case, and only obtain the read lock. The
newly added list head can be deleted under the read lock because we are
only called with current and will only change the semids allocated by this
task and not manipulate the list.
This commit assumes that up_read includes a sufficient memory barrier for
the writes to be seen my others that later obtain a write lock.
Signed-off-by: Milton Miller <miltonm@bga.com>
Signed-off-by: Jack Miller <millerjo@us.ibm.com>
This is small set of patches our team has had kicking around for a few
versions internally that fixes tasks getting hung on shm_exit when there
are many threads hammering it at once.
Anton wrote a simple test to cause the issue:
http://ozlabs.org/~anton/junkcode/bust_shm_exit.c
Before applying this patchset, this test code will cause either hanging
tracebacks or pthread out of memory errors.
After this patchset, it will still produce output like:
root@somehost:~# ./bust_shm_exit 1024 160
INFO: rcu_sched detected stalls on CPUs/tasks: {} (detected by 116, t=2111 jiffies, g=241, c=240, q=7113)
INFO: Stall ended before state dump start
But the task will continue to run along happily, so we consider this an
improvement over hanging, even if it's a bit noisy.
This patch (of 3):
exit_shm obtains the ipc_ns shm rwsem for write and holds it while it
walks every shared memory segment in the namespace. Thus the amount of
work is related to the number of shm segments in the namespace not the
number of segments that might need to be cleaned.
In addition, this occurs after the task has been notified the thread has
exited, so the number of tasks waiting for the ns shm rwsem can grow
without bound until memory is exausted.
Add a list to the task struct of all shmids allocated by this task. Init
the list head in copy_process. Use the ns->rwsem for locking. Add
segments after id is added, remove before removing from id.
On unshare of NEW_IPCNS orphan any ids as if the task had exited, similar
to handling of semaphore undo.
I chose a define for the init sequence since its a simple list init,
otherwise it would require a function call to avoid include loops between
the semaphore code and the task struct. Converting the list_del to
list_del_init for the unshare cases would remove the exit followed by
init, but I left it blow up if not inited.
The synchronous syncrhonize_rcu in switch_task_namespaces makes setns
a sufficiently expensive system call that people have complained.
Upon inspect nsproxy no longer needs rcu protection for remote reads.
remote reads are rare. So optimize for same process reads and write
by switching using rask_lock instead.
This yields a simpler to understand lock, and a faster setns system call.
In particular this fixes a performance regression observed
by Rafael David Tinoco <rafael.tinoco@canonical.com>.
This is effectively a revert of Pavel Emelyanov's commit
cf7b708c8d1d7a27736771bcf4c457b332b0f818 Make access to task's nsproxy lighter
from 2007. The race this originialy fixed no longer exists as
do_notify_parent uses task_active_pid_ns(parent) instead of
parent->nsproxy.
This typedef is unnecessary and should just be removed.
The actual Linux implementation for semctl(GETNCNT) and semctl(GETZCNT)
always (since 0.99.10) reported a thread as sleeping on all semaphores
that are listed in the semop() call.
The documented behavior (both in the Linux man page and in the Single
Unix Specification) is that a task should be reported on exactly one
semaphore: The semaphore that caused the thread to got to sleep.
This patch adds a pr_info_once() that is triggered if a thread hits the
relevant case.
The code triggers slightly too often, otherwise it would be necessary to
replicate the old code. As there are no known users of GETNCNT or
GETZCNT, this is done to prevent unnecessary bloat.
The task that triggered is reported with name (tsk->comm) and pid.
Acked-by: Davidlohr Bueso <davidlohr@hp.com>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
SUSv4 clearly defines how semncnt and semzcnt must be calculated: A task
waits on exactly one semaphore: The semaphore from the first operation
in the sop array that cannot proceed.
The Linux implementation never followed the standard, it tried to count
all semaphores that might be the reason why a task sleeps.
This patch fixes that.
Note:
a) The implementation assumes that GETNCNT and GETZCNT are rare operations,
therefore the code counts them only on demand.
(If they wouldn't be rare, then the non-compliance would have
been found earlier)
b) compared to the initial version of the patch, the BUG_ONs were removed
and it was clarified that the new behavior conforms to SUS.
Back-compatibility concerns:
Manfred:
: - there is no application in Fedora that uses GETNCNT or GETZCNT.
: - application that use only single-sop semop() are also safe, the
: difference only affects complex apps.
: - portable application are also safe, the new behavior is standard
: compliant.
: But that's it. The old behavior existed in Linux from 0.99.something
: until now.
Michael:
: * These operations seem to be very little used. Grepping the public
: source that is contained Fedora 20 source DVD, there appear to be no
: uses. Of course, this says nothing about uses in private /
: non-mainstream FOSS code, but it seems likely that the same pattern
: is followed there.
: * The existing behavior is hard enough to understand that I suspect
: that no one understood it well enough to rely on it anyway
: (especially as that behavior contradicted both man page and POSIX).
: So, there's a chance of breakage, but I estimate that it's minute.
Preparation for the next patch:
In the slow-path of perform_atomic_semop(), store a pointer to the
operation that caused the operation to block.
Right now, perform_atomic_semop gets the content of sem_queue as
individual fields. Changes that, instead pass a pointer to sem_queue.
This is a preparation for the next patch: it uses sem_queue to store the
reason why a task must sleep.
count_semzcnt and count_semncnt are more of less identical. The patch
creates a single function that either counts the number of tasks waiting
for zero or waiting due to a decrease operation.
Compared to the initial version, the BUG_ONs were removed.
GETZCNT is supposed to return the number of threads that wait until a
semaphore value becomes 0.
The current implementation overlooks complex operations that contain
both wait-for-zero operation and operations that alter at least one
semaphore.
The patch fixes that. It's intentionally copy&paste, this will be
cleaned up in the next patch.
The need for volatile is not obvious, document it.
Signed-off-by: Davidlohr Bueso <davidlohr@hp.com>
Cc: Aswin Chandramouleeswaran <aswin@hp.com>
Nothing big and no logical changes, just get rid of some redundant
function declarations. Move msg_[init/exit]_ns down the end of the
file.
Call __set_current_state() instead of assigning the new state directly.
Signed-off-by: Manfred Spraul <manfred@colorfullif.com>
SHMMAX is the upper limit for the size of a shared memory segment, counted
in bytes. The actual allocation is that size, rounded up to the next full
page.
Add a check that prevents the creation of segments where the rounded up
size causes an integer overflow.
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
shm_tot counts the total number of pages used by shm segments.
If SHMALL is ULONG_MAX (or nearly ULONG_MAX), then the number can
overflow. Subsequent calls to shmctl(,SHM_INFO,) would return wrong
values for shm_tot.
The patch adds a detection for overflows.
The increase of SHMMAX/SHMALL is a 4 patch series.
The change itself is trivial, the only problem are interger overflows.
The overflows are not new, but if we make huge values the default, then
the code should be free from overflows.
SHMMAX:
- shmmem_file_setup places a hard limit on the segment size:
MAX_LFS_FILESIZE.
On 32-bit, the limit is > 1 TB, i.e. 4 GB-1 byte segments are
possible. Rounded up to full pages the actual allocated size
is 0. --> must be fixed, patch 3
- shmat:
- find_vma_intersection does not handle overflows properly.
--> must be fixed, patch 1
- the rest is fine, do_mmap_pgoff limits mappings to TASK_SIZE
and checks for overflows (i.e.: map 2 GB, starting from
addr=2.5GB fails).
SHMALL:
- after creating 8192 segments size (1L<<63)-1, shm_tot overflows and
returns 0. --> must be fixed, patch 2.
Userspace:
- Obviously, there could be overflows in userspace. There is nothing
we can do, only use values smaller than ULONG_MAX.
I ended with "ULONG_MAX - 1L<<24":
- TASK_SIZE cannot be used because it is the size of the current
task. Could be 4G if it's a 32-bit task on a 64-bit kernel.
- The maximum size is not standardized across archs:
I found TASK_MAX_SIZE, TASK_SIZE_MAX and TASK_SIZE_64.
- Just in case some arch revives a 4G/4G split, nearly
ULONG_MAX is a valid segment size.
- Using "0" as a magic value for infinity is even worse, because
right now 0 means 0, i.e. fail all allocations.
This patch (of 4):
find_vma_intersection() does not work as intended if addr+size overflows.
The patch adds a manual check before the call to find_vma_intersection.
trailing whitespace
Signed-off-by: Paul McQuade <paulmcquad@gmail.com>
Use #include <linux/uaccess.h> instead of <asm/uaccess.h>
Use #include <linux/types.h> instead of <asm/types.h>
There is no need to recreate the very same ipc_ops structure on every
kernel entry for msgget/semget/shmget. Just declare it static and be
done with it. While at it, constify it as we don't modify the structure
at runtime.
Found in the PaX patch, written by the PaX Team.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: PaX Team <pageexec@freemail.hu>
... since __initcall is now deprecated.
This macro appears to have been introduced back in the 2.5 era for
semtimedop32 backward compatibility on ia32:
https://lkml.org/lkml/2003/4/28/78
Nowadays, this syscall in compat just defaults back to the code found in
sem.c, so it is no longer used and can thus be removed:
long compat_sys_semtimedop(int semid, struct sembuf __user *tsems,
unsigned nsops, const struct compat_timespec __user *timeout)
struct timespec __user *ts64;
if (compat_convert_timespec(&ts64, timeout))
return -EFAULT;
return sys_semtimedop(semid, tsems, nsops, ts64);
Furthermore, there are no users in compat.c. After this change, kernel
builds just fine with both CONFIG_SYSVIPC_COMPAT and CONFIG_SYSVIPC.
Pull compat time conversion changes from Peter Anvin:
"Despite the branch name this is really neither an x86 nor an
x32-specific patchset, although it the implementation of the
discussions that followed the x32 security hole a few months ago.
This removes get/put_compat_timespec/val() and replaces them with
compat_get/put_timespec/val() which are savvy as to the current status
of COMPAT_USE_64BIT_TIME.
It removes several unused and/or incorrect/misleading functions (like
compat_put_timeval_convert which doesn't in fact do any conversion)
and also replaces several open-coded implementations what is now
called compat_convert_timespec() with that function"
* 'x86-x32-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
compat: Fix sparse address space warnings
compat: Get rid of (get|put)_compat_time(val|spec)
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 compat wrapper rework from Heiko Carstens:
"S390 compat system call wrapper simplification work.
The intention of this work is to get rid of all hand written assembly
compat system call wrappers on s390, which perform proper sign or zero
extension, or pointer conversion of compat system call parameters.
Instead all of this should be done with C code eg by using Al's
COMPAT_SYSCALL_DEFINEx() macro.
Therefore all common code and s390 specific compat system calls have
been converted to the COMPAT_SYSCALL_DEFINEx() macro.
In order to generate correct code all compat system calls may only
have eg compat_ulong_t parameters, but no unsigned long parameters.
Those patches which change parameter types from unsigned long to
compat_ulong_t parameters are separate in this series, but shouldn't
cause any harm.
The only compat system calls which intentionally have 64 bit
parameters (preadv64 and pwritev64) in support of the x86/32 ABI
haven't been changed, but are now only available if an architecture
defines __ARCH_WANT_COMPAT_SYS_PREADV64/PWRITEV64.
System calls which do not have a compat variant but still need proper
zero extension on s390, like eg "long sys_brk(unsigned long brk)" will
get a proper wrapper function with the new s390 specific
COMPAT_SYSCALL_WRAPx() macro:
COMPAT_SYSCALL_WRAP1(brk, unsigned long, brk);
which generates the following code (simplified):
asmlinkage long sys_brk(unsigned long brk);
asmlinkage long compat_sys_brk(long brk)
return sys_brk((u32)brk);
Given that the C file which contains all the COMPAT_SYSCALL_WRAP lines
includes both linux/syscall.h and linux/compat.h, it will generate
build errors, if the declaration of sys_brk() doesn't match, or if
there exists a non-matching compat_sys_brk() declaration.
In addition this will intentionally result in a link error if
somewhere else a compat_sys_brk() function exists, which probably
should have been used instead. Two more BUILD_BUG_ONs make sure the
size and type of each compat syscall parameter can be handled
correctly with the s390 specific macros.
I converted the compat system calls step by step to verify the
generated code is correct and matches the previous code. In fact it
did not always match, however that was always a bug in the hand
written asm code.
In result we get less code, less bugs, and much more sanity checking"
* 'compat' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (44 commits)
s390/compat: add copyright statement
compat: include linux/unistd.h within linux/compat.h
s390/compat: get rid of compat wrapper assembly code
s390/compat: build error for large compat syscall args
mm/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter types
kexec/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter types
net/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter types
ipc/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter types
fs/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter types
security/compat: convert to COMPAT_SYSCALL_DEFINE
kernel/compat: convert to COMPAT_SYSCALL_DEFINE
fs/compat: optional preadv64/pwrite64 compat system calls
ipc/compat_sys_msgrcv: change msgtyp type from long to compat_long_t
s390/compat: partial parameter conversion within syscall wrappers
s390/compat: automatic zero, sign and pointer conversion of syscalls
s390/compat: add sync_file_range and fallocate compat syscalls
While testing and documenting the msgrcv() MSG_COPY flag that Stanislav
Kinsbursky added in commit 4a674f34ba04 ("ipc: introduce message queue
copy feature" => kernel 3.8), I discovered a couple of bugs in the
implementation. The two bugs concern MSG_COPY interactions with other
msgrcv() flags, namely:
(A) MSG_COPY + MSG_EXCEPT
(B) MSG_COPY + !IPC_NOWAIT
The bugs are distinct (and the fix for the first one is obvious),
however my fix for both is a single-line patch, which is why I'm
combining them in a single mail, rather than writing two mails+patches.
===== (A) MSG_COPY + MSG_EXCEPT =====
With the addition of the MSG_COPY flag, there are now two msgrcv()
flags--MSG_COPY and MSG_EXCEPT--that modify the meaning of the 'msgtyp'
argument in unrelated ways. Specifying both in the same call is a
logical error that is currently permitted, with the effect that MSG_COPY
has priority and MSG_EXCEPT is ignored. The call should give an error
if both flags are specified. The patch below implements that behavior.
===== (B) (B) MSG_COPY + !IPC_NOWAIT =====
The test code that was submitted in commit 3a665531a3b7 ("selftests: IPC
message queue copy feature test") shows MSG_COPY being used in
conjunction with IPC_NOWAIT. In other words, if there is no message at
the position 'msgtyp'. return immediately with the error in ENOMSG.
What was not (fully) tested is the behavior if MSG_COPY is specified
*without* IPC_NOWAIT, and there is an odd behavior. If the queue
contains less than 'msgtyp' messages, then the call blocks until the
next message is written to the queue. At that point, the msgrcv() call
returns a copy of the newly added message, regardless of whether that
message is at the ordinal position 'msgtyp'. This is clearly bogus, and
problematic for applications that might want to make use of the MSG_COPY
flag.
I considered the following possible solutions to this problem:
(1) Force the call to block until a message *does* appear at the
position 'msgtyp'.
(2) If the MSG_COPY flag is specified, the kernel should implicitly add
IPC_NOWAIT, so that the call fails with ENOMSG for this case.
(3) If the MSG_COPY flag is specified, but IPC_NOWAIT is not, generate
an error (probably, EINVAL is the right one).
I do not know if any application would really want to have the
functionality of solution (1), especially since an application can
determine in advance the number of messages in the queue using msgctl()
IPC_STAT. Obviously, this solution would be the most work to implement.
Solution (2) would have the effect of silently fixing any applications
that tried to employ broken behavior. However, it would mean that if we
later decided to implement solution (1), then user-space could not
easily detect what the kernel supports (but, since I'm somewhat doubtful
that solution (1) is needed, I'm not sure that this is much of a
problem).
Solution (3) would have the effect of informing broken applications that
they are doing something broken. The downside is that this would cause
a ABI breakage for any applications that are currently employing the
broken behavior. However:
a) Those applications are almost certainly not getting the results they
expect.
b) Possibly, those applications don't even exist, because MSG_COPY is
currently hidden behind CONFIG_CHECKPOINT_RESTORE.
The upside of solution (3) is that if we later decided to implement
solution (1), user-space could determine what the kernel supports, via
the error return.
In my view, solution (3) is mildly preferable to solution (2), and
solution (1) could still be done later if anyone really cares. The
patch below implements solution (3).
PS. For anyone out there still listening, it's the usual story:
documenting an API (and the thinking about, and the testing of the API,
that documentation entails) is the one of the single best ways of
finding bugs in the API, as I've learned from a lot of experience. Best
to do that documentation before releasing the API.
Signed-off-by: Michael Kerrisk <mtk.manpages@gmail.com>
Acked-by: Stanislav Kinsbursky <skinsbursky@parallels.com>
Cc: Stanislav Kinsbursky <skinsbursky@parallels.com>
Cc: Serge Hallyn <serge.hallyn@canonical.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
In order to allow the COMPAT_SYSCALL_DEFINE macro generate code that
performs proper zero and sign extension convert all 64 bit parameters
to their corresponding 32 bit compat counterparts.
Convert all compat system call functions where all parameter types
have a size of four or less than four bytes, or are pointer types
to COMPAT_SYSCALL_DEFINE.
The implicit casts within COMPAT_SYSCALL_DEFINE will perform proper
zero and sign extension to 64 bit of all parameters if needed.
Change the type of compat_sys_msgrcv's msgtyp parameter from long
to compat_long_t, since compat user space passes only a 32 bit signed
value.
Let the compat wrapper do proper sign extension to 64 bit of this
parameter.
Commit 93e6f119c0ce ("ipc/mqueue: cleanup definition names and
locations") added global hardcoded limits to the amount of message
queues that can be created. While these limits are per-namespace,
reality is that it ends up breaking userspace applications.
Historically users have, at least in theory, been able to create up to
INT_MAX queues, and limiting it to just 1024 is way too low and dramatic
for some workloads and use cases. For instance, Madars reports:
"This update imposes bad limits on our multi-process application. As
our app uses approaches that each process opens its own set of queues
(usually something about 3-5 queues per process). In some scenarios
we might run up to 3000 processes or more (which of-course for linux
is not a problem). Thus we might need up to 9000 queues or more. All
processes run under one user."
Other affected users can be found in launchpad bug #1155695:
https://bugs.launchpad.net/ubuntu/+source/manpages/+bug/1155695
Instead of increasing this limit, revert it entirely and fallback to the
original way of dealing queue limits -- where once a user's resource
limit is reached, and all memory is used, new queues cannot be created.
Reported-by: Madars Vitolins <m@silodev.com>
Cc: <stable@vger.kernel.org> [3.5+]
We have two APIs for compatiblity timespec/val, with confusingly
similar names. compat_(get|put)_time(val|spec) *do* handle the case
where COMPAT_USE_64BIT_TIME is set, whereas
(get|put)_compat_time(val|spec) do not. This is an accident waiting
to happen.
Clean it up by favoring the full-service version; the limited version
is replaced with double-underscore versions static to kernel/compat.c.
A common pattern is to convert a struct timespec to kernel format in
an allocation on the user stack. Unfortunately it is open-coded in
several places. Since this allocation isn't actually needed if
COMPAT_USE_64BIT_TIME is true (since user format == kernel format)
encapsulate that whole pattern into the function
compat_convert_timespec(). An equivalent function should be written
for struct timeval if it is needed in the future.
Finally, get rid of compat_(get|put)_timeval_convert(): each was only
used once, and the latter was not even doing what the function said
(no conversion actually was being done.) Moving the conversion into
compat_sys_settimeofday() itself makes the code much more similar to
sys_settimeofday() itself.
v3: Remove unused compat_convert_timeval().
v2: Drop bogus "const" in the destination argument for
compat_convert_time*().
Cc: Mauro Carvalho Chehab <m.chehab@samsung.com>
Cc: Hans Verkuil <hans.verkuil@cisco.com>
Cc: Mateusz Guzik <mguzik@redhat.com>
Cc: Dan Carpenter <dan.carpenter@oracle.com>
Tested-by: H.J. Lu <hjl.tools@gmail.com>
Compat function takes msgtyp argument as u32 and passes it down to
do_msgrcv which results in casting to long, thus the sign is lost and we
get a big positive number instead.
Cast the argument to signed type before passing it down.
Signed-off-by: Mateusz Guzik <mguzik@redhat.com>
Reported-by: Gabriellla Schmidt <gsc@bruker.de>
Both expunge_all() and pipeline_send() rely on both a nil msg value and
a full barrier to guarantee the correct ordering when waking up a task.
While its counterpart at the receiving end is well documented for the
lockless recv algorithm, we still need to document these specific
smp_mb() calls.
[akpm@linux-foundation.org: fix typo, per Mike]
[akpm@linux-foundation.org: mroe tpyos]
This field is only used to reset the ids seq number if it exceeds the
smaller of INT_MAX/SEQ_MULTIPLIER and USHRT_MAX, and can therefore be
moved out of the structure and into its own macro. Since each
ipc_namespace contains a table of 3 pointers to struct ipc_ids we can
save space in instruction text:
56232 2348 24 58604 e4ec ipc/built-in.o
56216 2348 24 58588 e4dc ipc/built-in.o-after
Reviewed-by: Jonathan Gonzalez <jgonzalez@linets.cl>
Get rid of silly/useless label jumping.
Only found in ipc_rmid().
Deal with checkpatch messages:
WARNING: braces {} are not necessary for single statement blocks
IPC commenting style is all over the place, *specially* in util.c. This
patch orders things a bit.
The ipc code does not adhere the typical linux coding style.
This patch fixes lots of simple whitespace errors.
- mostly autogenerated by
scripts/checkpatch.pl -f --fix \
--types=pointer_location,spacing,space_before_tab
- one manual fixup (keep structure members tab-aligned)
- removal of additional space_before_tab that were not found by --fix
Tested with some of my msg and sem test apps.
Andrew: Could you include it in -mm and move it towards Linus' tree?
Suggested-by: Li Bin <huawei.libin@huawei.com>
struct kern_ipc_perm.deleted is meant to be used as a boolean toggle, and
the changes introduced by this patch are just to make the case explicit.
Signed-off-by: Rafael Aquini <aquini@redhat.com>
