path: root/ipc
2007-06-16shm: fix the filename of hugetlb sysv shared memoryEric W. Biederman
Some user space tools need to identify SYSV shared memory when examining /proc/<pid>/maps. To do so they look for a block device with major zero, a dentry named SYSV<sysv key>, and having the minor of the internal sysv shared memory kernel mount. To help these tools and to make it easier for people just browsing /proc/<pid>/maps this patch modifies hugetlb sysv shared memory to use the SYSV<key> dentry naming convention. User space tools will still have to be aware that hugetlb sysv shared memory lives on a different internal kernel mount and so has a different block device minor number from the rest of sysv shared memory. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: "Serge E. Hallyn" <serge@hallyn.com> Cc: Albert Cahalan <acahalan@gmail.com> Cc: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-16hugetlb: fix get_policy for stacked shared memory filesAdam Litke
Here's another breakage as a result of shared memory stacked files :( The NUMA policy for a VMA is determined by checking the following (in the order given): 1) vma->vm_ops->get_policy() (if defined) 2) vma->vm_policy (if defined) 3) task->mempolicy (if defined) 4) Fall back to default_policy By switching to stacked files for shared memory, get_policy() is now always set to shm_get_policy which is a wrapper function. This causes us to stop at step 1, which yields NULL for hugetlb instead of task->mempolicy which was the previous (and correct) result. This patch modifies the shm_get_policy() wrapper to maintain steps 1-3 for the wrapped vm_ops. (akpm: the refcounting of mempolicies is busted and this patch does nothing to improve it) Signed-off-by: Adam Litke <agl@us.ibm.com> Acked-by: William Irwin <bill.irwin@oracle.com> Cc: dean gaudet <dean@arctic.org> Cc: Christoph Lameter <clameter@sgi.com> Cc: Andi Kleen <ak@suse.de> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-16Restore shmid as inode# to fix /proc/pid/maps ABI breakageBadari Pulavarty
shmid used to be stored as inode# for shared memory segments. Some of the proc-ps tools use this from /proc/pid/maps. Recent cleanups to newseg() changed it. This patch sets inode number back to shared memory id to fix breakage. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Cc: "Albert Cahalan" <acahalan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11[PATCH] complete message queue auditingAmy Griffis
Handle the edge cases for POSIX message queue auditing. Collect inode info when opening an existing mq, and for send/receive operations. Remove audit_inode_update() as it has really evolved into the equivalent of audit_inode(). Signed-off-by: Amy Griffis <amy.griffis@hp.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2007-05-08Merge sys_clone()/sys_unshare() nsproxy and namespace handlingBadari Pulavarty
sys_clone() and sys_unshare() both makes copies of nsproxy and its associated namespaces. But they have different code paths. This patch merges all the nsproxy and its associated namespace copy/clone handling (as much as possible). Posted on container list earlier for feedback. - Create a new nsproxy and its associated namespaces and pass it back to caller to attach it to right process. - Changed all copy_*_ns() routines to return a new copy of namespace instead of attaching it to task->nsproxy. - Moved the CAP_SYS_ADMIN checks out of copy_*_ns() routines. - Removed unnessary !ns checks from copy_*_ns() and added BUG_ON() just incase. - Get rid of all individual unshare_*_ns() routines and make use of copy_*_ns() instead. [akpm@osdl.org: cleanups, warning fix] [clg@fr.ibm.com: remove dup_namespaces() declaration] [serue@us.ibm.com: fix CONFIG_IPC_NS=n, clone(CLONE_NEWIPC) retval] [akpm@linux-foundation.org: fix build with CONFIG_SYSVIPC=n] Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Serge Hallyn <serue@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: <containers@lists.osdl.org> Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Cap shmmax at INT_MAX in compat shminfoGuy Streeter
The value of shmmax may be larger than will fit in the struct used by the 32bit compat version of sys_shmctl. This change mirrors what the normal sys_shmctl does when called with the old IPC_INFO command. Signed-off-by: Guy Streeter <streeter@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-27[PATCH] ipcns: fix !CONFIG_IPC_NS behaviorSerge E. Hallyn
When CONFIG_IPC_NS=n, clone(CLONE_NEWIPC) claims success, but did not actually clone a new IPC namespace. Fix this to return -EINVAL so the caller knows his request was denied. Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-06[PATCH] mqueue: nested locking annotationPeter Zijlstra
Fix http://bugzilla.kernel.org/show_bug.cgi?id=8130 Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-01[PATCH] Fix get_unmapped_area and fsync for hugetlb shm segmentsAdam Litke
This patch provides the following hugetlb-related fixes to the recent stacked shm files changes: - Update is_file_hugepages() so it will reconize hugetlb shm segments. - get_unmapped_area must be called with the nested file struct to handle the sfd->file->f_ops->get_unmapped_area == NULL case. - The fsync f_op must be wrapped since it is specified in the hugetlbfs f_ops. This is based on proposed fixes from Eric Biederman that were debugged and tested by me. Without it, attempting to use hugetlb shared memory segments on powerpc (and likely ia64) will kill your box. Signed-off-by: Adam Litke <agl@us.ibm.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Andrew Morton <akpm@linux-foundation.org> Acked-by: William Irwin <bill.irwin@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-01[PATCH] make ipc/shm.c:shm_nopage() staticAdrian Bunk
shm_nopage() can become static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-20[PATCH] shm: make sysv ipc shared memory use stacked filesEric W. Biederman
The current ipc shared memory code runs into several problems because it does not quite use files like the rest of the kernel. With the option of backing ipc shared memory with either hugetlbfs or ordinary shared memory the problems got worse. With the added support for ipc namespaces things behaved so unexpected that we now have several bad namespace reference counting bugs when using what appears at first glance to be a reasonable idiom. So to attack these problems and hopefully make the code more maintainable this patch simply uses the files provided by other parts of the kernel and builds it's own files out of them. The shm files are allocated in do_shmat and freed when their reference count drops to zero with their last unmap. The file and vm operations that we don't want to implement or we don't implement completely we just delegate to the operations of our backing file. This means that we now get an accurate shm_nattch count for we have a hugetlbfs inode for backing store, and the shm accounting of last attach and last detach time work as well. This means that getting a reference to the ipc namespace when we create the file and dropping the referenece in the release method is now safe and correct. This means we no longer need a special case for clearing VM_MAYWRITE as our file descriptor now only has write permissions when we have requested write access when calling shmat. Although VM_SHARED is now cleared as well which I believe is harmless and is mostly likely a minor bug fix. By using the same set of operations for both the hugetlb case and regular shared memory case shmdt is not simplified and made slightly more correct as now the test "vma->vm_ops == &shm_vm_ops" is 100% accurate in spotting all shared memory regions generated from sysvipc shared memory. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: remove insert_at_head from register_sysctlEric W. Biederman
The semantic effect of insert_at_head is that it would allow new registered sysctl entries to override existing sysctl entries of the same name. Which is pain for caching and the proc interface never implemented. I have done an audit and discovered that none of the current users of register_sysctl care as (excpet for directories) they do not register duplicate sysctl entries. So this patch simply removes the support for overriding existing entries in the sys_sysctl interface since no one uses it or cares and it makes future enhancments harder. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Howells <dhowells@redhat.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Andi Kleen <ak@muc.de> Cc: Jens Axboe <axboe@kernel.dk> Cc: Corey Minyard <minyard@acm.org> Cc: Neil Brown <neilb@suse.de> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Jan Kara <jack@ucw.cz> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: David Chinner <dgc@sgi.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: move SYSV IPC sysctls to their own fileEric W. Biederman
This is just a simple cleanup to keep kernel/sysctl.c from getting to crowded with special cases, and by keeping all of the ipc logic to together it makes the code a little more readable. [gcoady.lk@gmail.com: build fix] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Serge E. Hallyn <serue@us.ibm.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Kirill Korotaev <dev@sw.ru> Signed-off-by: Grant Coady <gcoady.lk@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct inode_operations const 2Arjan van de Ven
2007-02-12[PATCH] mark struct file_operations const 7Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] ipc: save the ipc namespace while reading proc filesEric W. Biederman
The problem we were assuming that current->nsproxy->ipc_ns would never change while someone has our file in /proc/sysvipc/ file open. Given that this can change with both unshare and by passing the file descriptor to another process that assumption is occasionally wrong. Therefore this patch causes /proc/sysvipc/* to cache the namespace and increment it's count when we open the file and to decrement the count when we close the file, ensuring consistent operation with no surprises. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Serge E. Hallyn <serue@us.ibm.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Kirill Korotaev <dev@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Numerous fixes to kernel-doc info in source files.Robert P. J. Day
A variety of (mostly) innocuous fixes to the embedded kernel-doc content in source files, including: * make multi-line initial descriptions single line * denote some function names, constants and structs as such * change erroneous opening '/*' to '/**' in a few places * reword some text for clarity Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-23[PATCH] correct sys_shmget allocation checkGuy Streeter
As written, sys_shmget will return ENOSPC when one page is still available for allocation. This patch corrects the test. Signed-off-by: Guy Streeter <guy.streeter+lkml@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> --
2006-12-13[PATCH] getting rid of all casts of k[cmz]alloc() callsRobert P. J. Day
Run this: #!/bin/sh for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do echo "De-casting $f..." perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f done And then go through and reinstate those cases where code is casting pointers to non-pointers. And then drop a few hunks which conflicted with outstanding work. Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Greg KH <greg@kroah.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Karsten Keil <kkeil@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Ian Kent <raven@themaw.net> Cc: Steven French <sfrench@us.ibm.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] struct path: convert ipcJosef Sipek
2006-12-07[PATCH] kernel core: replace kmalloc+memset with kzallocBurman Yan
2006-12-07[PATCH] Fix the size limit of compat space msgsizesuzuki
Currently we allocate 64k space on the user stack and use it the msgbuf for sys_{msgrcv,msgsnd} for compat and the results are later copied in user [ by copy_in_user]. This patch introduces helper routines for sys_{msgrcv,msgsnd} as below: do_msgsnd() : Accepts the mtype and user space ptr to the buffer along with the msqid and msgflg. do_msgrcv() : Accepts a kernel space ptr to mtype and a userspace ptr to the buffer. The mtype has to be copied back the user space msgbuf by the caller. These changes avoid the need to allocate the msgsize on the userspace ( thus removing the size limt ) and the overhead of an extra copy_in_user(). Signed-off-by: Suzuki K P <suzuki@in.ibm.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-22WorkStruct: Pass the work_struct pointer instead of context dataDavid Howells
Pass the work_struct pointer to the work function rather than context data. The work function can use container_of() to work out the data. For the cases where the container of the work_struct may go away the moment the pending bit is cleared, it is made possible to defer the release of the structure by deferring the clearing of the pending bit. To make this work, an extra flag is introduced into the management side of the work_struct. This governs auto-release of the structure upon execution. Ordinarily, the work queue executor would release the work_struct for further scheduling or deallocation by clearing the pending bit prior to jumping to the work function. This means that, unless the driver makes some guarantee itself that the work_struct won't go away, the work function may not access anything else in the work_struct or its container lest they be deallocated.. This is a problem if the auxiliary data is taken away (as done by the last patch). However, if the pending bit is *not* cleared before jumping to the work function, then the work function *may* access the work_struct and its container with no problems. But then the work function must itself release the work_struct by calling work_release(). In most cases, automatic release is fine, so this is the default. Special initiators exist for the non-auto-release case (ending in _NAR). Signed-Off-By: David Howells <dhowells@redhat.com>
2006-11-04Revert unintentional "volatile" changes in ipc/msg.cLinus Torvalds
Commit 5a06a363ef48444186f18095ae1b932dddbbfa89 ("[PATCH] ipc/msg.c: clean up coding style") breaks fakeroot on Alpha (variously hangs or oopses), according to a report by Falk Hueffner. The fact that the code seems to rely on compiler access ordering through the use of "volatile" is a pretty certain sign that the code has locking problems, and we should fix those properly and then remove the whole "volatile" entirely. But in the meantime, the movement of "volatile" was unintentional, and should be reverted. Cc: Falk Hueffner <falk@debian.org> Cc: Andrew Morton <akpm@osdl.org> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-03[PATCH] Fix ipc entries removalPavel Emelianov
Fix two issuses related to ipc_ids->entries freeing. 1. When freeing ipc namespace we need to free entries allocated with ipc_init_ids(). 2. When removing old entries in grow_ary() ipc_rcu_putref() may be called on entries set to &ids->nullentry earlier in ipc_init_ids(). This is almost impossible without namespaces, but with them this situation becomes possible. Found during OpenVZ testing after obvious leaks in beancounters. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Cc: Kirill Korotaev <dev@openvz.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03Michal Wronski: update contact infoMichal Wronski
My email has changed. Signed-Off-By: Michal Wronski <michal.wronski@gmail.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-02[PATCH] ipc: replace kmalloc and memset in get_undo_list with kzallocMatt Helsley
Simplify get_undo_list() by dropping the unnecessary cast, removing the size variable, and switching to kzalloc() instead of a kmalloc() followed by a memset(). This cleanup was split then modified from Jes Sorenson's Task Notifiers patches. Signed-off-by: Matt Helsley <matthltc@us.ibm.com> Cc: Jes Sorensen <jes@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] IPC namespace - shmKirill Korotaev
IPC namespace support for IPC shm code. Signed-off-by: Pavel Emelianiov <xemul@openvz.org> Signed-off-by: Kirill Korotaev <dev@openvz.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] IPC namespace - semKirill Korotaev
IPC namespace support for IPC sem code. Signed-off-by: Pavel Emelianiov <xemul@openvz.org> Signed-off-by: Kirill Korotaev <dev@openvz.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] IPC namespace - msgKirill Korotaev
IPC namespace support for IPC msg code. Signed-off-by: Pavel Emelianiov <xemul@openvz.org> Signed-off-by: Kirill Korotaev <dev@openvz.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] IPC namespace - utilsKirill Korotaev
This patch adds basic IPC namespace functionality to IPC utils: - init_ipc_ns - copy/clone/unshare/free IPC ns - /proc preparations Signed-off-by: Pavel Emelianov <xemul@openvz.org> Signed-off-by: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] update mq_notify to use a struct pidCedric Le Goater
Message queues can signal a process waiting for a message. This patch replaces the pid_t value with a struct pid to avoid pid wrap around problems. Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Acked-by: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] r/o bind mount prepwork: inc_nlink() helperDave Hansen
This is mostly included for parity with dec_nlink(), where we will have some more hooks. This one should stay pretty darn straightforward for now. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] r/o bind mounts: unlink: monitor i_nlinkDave Hansen
When a filesystem decrements i_nlink to zero, it means that a write must be performed in order to drop the inode from the filesystem. We're shortly going to have keep filesystems from being remounted r/o between the time that this i_nlink decrement and that write occurs. So, add a little helper function to do the decrements. We'll tie into it in a bit to note when i_nlink hits zero. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] Really ignore kmem_cache_destroy return valueAlexey Dobriyan
* Rougly half of callers already do it by not checking return value * Code in drivers/acpi/osl.c does the following to be sure: (void)kmem_cache_destroy(cache); * Those who check it printk something, however, slab_error already printed the name of failed cache. * XFS BUGs on failed kmem_cache_destroy which is not the decision low-level filesystem driver should make. Converted to ignore. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] ipc/msg.c: clean up coding styleIngo Molnar
Clean up ipc/msg.c to conform to Documentation/CodingStyle. (before it was an inconsistent hodepodge of various coding styles) Verified that the before/after .o's are identical. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] vfs: add lock owner argument to flush operationMiklos Szeredi
Pass the POSIX lock owner ID to the flush operation. This is useful for filesystems which don't want to store any locking state in inode->i_flock but want to handle locking/unlocking POSIX locks internally. FUSE is one such filesystem but I think it possible that some network filesystems would need this also. Also add a flag to indicate that a POSIX locking request was generated by close(), so filesystems using the above feature won't send an extra locking request in this case. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] remove unused o_flags from do_shmatHugh Dickins
Remove the unused variable o_flags from do_shmat. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to override root dentry on mountDavid Howells
Extend the get_sb() filesystem operation to take an extra argument that permits the VFS to pass in the target vfsmount that defines the mountpoint. The filesystem is then required to manually set the superblock and root dentry pointers. For most filesystems, this should be done with simple_set_mnt() which will set the superblock pointer and then set the root dentry to the superblock's s_root (as per the old default behaviour). The get_sb() op now returns an integer as there's now no need to return the superblock pointer. This patch permits a superblock to be implicitly shared amongst several mount points, such as can be done with NFS to avoid potential inode aliasing. In such a case, simple_set_mnt() would not be called, and instead the mnt_root and mnt_sb would be set directly. The patch also makes the following changes: (*) the get_sb_*() convenience functions in the core kernel now take a vfsmount pointer argument and return an integer, so most filesystems have to change very little. (*) If one of the convenience function is not used, then get_sb() should normally call simple_set_mnt() to instantiate the vfsmount. This will always return 0, and so can be tail-called from get_sb(). (*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the dcache upon superblock destruction rather than shrink_dcache_anon(). This is required because the superblock may now have multiple trees that aren't actually bound to s_root, but that still need to be cleaned up. The currently called functions assume that the whole tree is rooted at s_root, and that anonymous dentries are not the roots of trees which results in dentries being left unculled. However, with the way NFS superblock sharing are currently set to be implemented, these assumptions are violated: the root of the filesystem is simply a dummy dentry and inode (the real inode for '/' may well be inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries with child trees. [*] Anonymous until discovered from another tree. (*) The documentation has been adjusted, including the additional bit of changing ext2_* into foo_* in the documentation. [akpm@osdl.org: convert ipath_fs, do other stuff] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-20[PATCH] Audit of POSIX Message Queue Syscalls v.2George C. Wilson
This patch adds audit support to POSIX message queues. It applies cleanly to the lspp.b15 branch of Al Viro's git tree. There are new auxiliary data structures, and collection and emission routines in kernel/auditsc.c. New hooks in ipc/mqueue.c collect arguments from the syscalls. I tested the patch by building the examples from the POSIX MQ library tarball. Build them -lrt, not against the old MQ library in the tarball. Here's the URL: http://www.geocities.com/wronski12/posix_ipc/libmqueue-4.41.tar.gz Do auditctl -a exit,always -S for mq_open, mq_timedsend, mq_timedreceive, mq_notify, mq_getsetattr. mq_unlink has no new hooks. Please see the corresponding userspace patch to get correct output from auditd for the new record types. [fixes folded] Signed-off-by: George Wilson <ltcgcw@us.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-06-20[PATCH] update of IPC audit record cleanupLinda Knippers
The following patch addresses most of the issues with the IPC_SET_PERM records as described in: https://www.redhat.com/archives/linux-audit/2006-May/msg00010.html and addresses the comments I received on the record field names. To summarize, I made the following changes: 1. Changed sys_msgctl() and semctl_down() so that an IPC_SET_PERM record is emitted in the failure case as well as the success case. This matches the behavior in sys_shmctl(). I could simplify the code in sys_msgctl() and semctl_down() slightly but it would mean that in some error cases we could get an IPC_SET_PERM record without an IPC record and that seemed odd. 2. No change to the IPC record type, given no feedback on the backward compatibility question. 3. Removed the qbytes field from the IPC record. It wasn't being set and when audit_ipc_obj() is called from ipcperms(), the information isn't available. If we want the information in the IPC record, more extensive changes will be necessary. Since it only applies to message queues and it isn't really permission related, it doesn't seem worth it. 4. Removed the obj field from the IPC_SET_PERM record. This means that the kern_ipc_perm argument is no longer needed. 5. Removed the spaces and renamed the IPC_SET_PERM field names. Replaced iuid and igid fields with ouid and ogid in the IPC record. I tested this with the lspp.22 kernel on an x86_64 box. I believe it applies cleanly on the latest kernel. -- ljk Signed-off-by: Linda Knippers <linda.knippers@hp.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-05-01[PATCH] Rework of IPC auditingSteve Grubb
1) The audit_ipc_perms() function has been split into two different functions: - audit_ipc_obj() - audit_ipc_set_perm() There's a key shift here... The audit_ipc_obj() collects the uid, gid, mode, and SElinux context label of the current ipc object. This audit_ipc_obj() hook is now found in several places. Most notably, it is hooked in ipcperms(), which is called in various places around the ipc code permforming a MAC check. Additionally there are several places where *checkid() is used to validate that an operation is being performed on a valid object while not necessarily having a nearby ipcperms() call. In these locations, audit_ipc_obj() is called to ensure that the information is captured by the audit system. The audit_set_new_perm() function is called any time the permissions on the ipc object changes. In this case, the NEW permissions are recorded (and note that an audit_ipc_obj() call exists just a few lines before each instance). 2) Support for an AUDIT_IPC_SET_PERM audit message type. This allows for separate auxiliary audit records for normal operations on an IPC object and permissions changes. Note that the same struct audit_aux_data_ipcctl is used and populated, however there are separate audit_log_format statements based on the type of the message. Finally, the AUDIT_IPC block of code in audit_free_aux() was extended to handle aux messages of this new type. No more mem leaks I hope ;-) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
