path: root/ipc
2009-01-04sanitize audit_ipc_set_perm()Al Viro
* get rid of allocations * make it return void * simplify callers Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-04sanitize audit_ipc_obj()Al Viro
2008-12-04Merge branch 'master' into nextJames Morris
Conflicts: fs/nfsd/nfs4recover.c Manually fixed above to use new creds API functions, e.g. nfs4_save_creds(). Signed-off-by: James Morris <jmorris@namei.org>
2008-11-19sysvipc: fix the ipc structures initializationNadia Derbey
A problem was found while reviewing the code after Bugzilla bug http://bugzilla.kernel.org/show_bug.cgi?id=11796. In ipc_addid(), the newly allocated ipc structure is inserted into the ipcs tree (i.e made visible to readers) without locking it. This is not correct since its initialization continues after it has been inserted in the tree. This patch moves the ipc structure lock initialization + locking before the actual insertion. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Reported-by: Clement Calmels <cboulte@gmail.com> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: <stable@kernel.org> [2.6.27.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-14CRED: Pass credentials through dentry_open()David Howells
Pass credentials through dentry_open() so that the COW creds patch can have SELinux's flush_unauthorized_files() pass the appropriate creds back to itself when it opens its null chardev. The security_dentry_open() call also now takes a creds pointer, as does the dentry_open hook in struct security_operations. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Wrap current->cred and a few other accessorsDavid Howells
Wrap current->cred and a few other accessors to hide their actual implementation. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Separate task security context from task_structDavid Howells
Separate the task security context from task_struct. At this point, the security data is temporarily embedded in the task_struct with two pointers pointing to it. Note that the Alpha arch is altered as it refers to (E)UID and (E)GID in entry.S via asm-offsets. With comment fixes Signed-off-by: Marc Dionne <marc.c.dionne@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Wrap task credential accesses in the SYSV IPC subsystemDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-10-21[PATCH] introduce fmode_t, do annotationsAl Viro
2008-10-20message queues: increase range limitsJoe Korty
Increase the range of various posix message queue limits. Posix gives the message queue user the ability to 'trade off' the maximum size of messages with the number of possible messages that can be 'in flight'. Linux currently makes this trade off more restrictive than it needs to be. In particular, the maximum message size today can be made no smaller than 8192. This greatly restricts those applications that would like to have the ability to post large numbers of very small messages. So this task lowers the limit that the maximum message size can be set to, from 8192 to 128. It also lowers the limit that the maximum #number of messages in flight can be set to, from 10 to 1. With these changes the message queue user can make better trade offs between #messages and message size, in order to get everything to fit within the setrlimit(RLIMIT_MSGQUEUE) limit for that particular user. This patch also applies the values in /proc/sys/fs/mqueue/msg_max /proc/sys/fs/mqueue/msgsize_max as the defaults for the max #messages allowed and the max message size allowed, respectively, for those applications that do not supply these. Previously, the defaults were hardwired to 10 and 8192, respectively. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Joe Korty <joe.korty@ccur.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20SHM_LOCKED pages are unevictableLee Schermerhorn
Shmem segments locked into memory via shmctl(SHM_LOCKED) should not be kept on the normal LRU, since scanning them is a waste of time and might throw off kswapd's balancing algorithms. Place them on the unevictable LRU list instead. Use the AS_UNEVICTABLE flag to mark address_space of SHM_LOCKed shared memory regions as unevictable. Then these pages will be culled off the normal LRU lists during vmscan. Add new wrapper function to clear the mapping's unevictable state when/if shared memory segment is munlocked. Add 'scan_mapping_unevictable_page()' to mm/vmscan.c to scan all pages in the shmem segment's mapping [struct address_space] for evictability now that they're no longer locked. If so, move them to the appropriate zone lru list. Changes depend on [CONFIG_]UNEVICTABLE_LRU. [kosaki.motohiro@jp.fujitsu.com: revert shm change] Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Kosaki Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16ipc/sem.c: make free_un() staticAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16sysctl: simplify ->strategyAlexey Dobriyan
name and nlen parameters passed to ->strategy hook are unused, remove them. In general ->strategy hook should know what it's doing, and don't do something tricky for which, say, pointer to original userspace array may be needed (name). Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> [ networking bits ] Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: Matt Mackall <mpm@selenic.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26[PATCH] kill nameidata passing to permission(), rename to inode_permission()Al Viro
Incidentally, the name that gives hundreds of false positives on grep is not a good idea... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26SL*B: drop kmem cache argument from constructorAlexey Dobriyan
Kmem cache passed to constructor is only needed for constructors that are themselves multiplexeres. Nobody uses this "feature", nor does anybody uses passed kmem cache in non-trivial way, so pass only pointer to object. Non-trivial places are: arch/powerpc/mm/init_64.c arch/powerpc/mm/hugetlbpage.c This is flag day, yes. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Jon Tollefson <kniht@linux.vnet.ibm.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Matt Mackall <mpm@selenic.com> [akpm@linux-foundation.org: fix arch/powerpc/mm/hugetlbpage.c] [akpm@linux-foundation.org: fix mm/slab.c] [akpm@linux-foundation.org: fix ubifs] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25ipc: do not use a negative value to re-enable msgmni automatic recomputingNadia Derbey
This patch proposes an alternative to the "magical positive-versus-negative number trick" Andrew complained about last week in http://lkml.org/lkml/2008/6/24/418. This had been introduced with the patches that scale msgmni to the amount of lowmem. With these patches, msgmni has a registered notification routine that recomputes msgmni value upon memory add/remove or ipc namespace creation/ removal. When msgmni is changed from user space (i.e. value written to the proc file), that notification routine is unregistered, and the way to make it registered back is to write a negative value into the proc file. This is the "magical positive-versus-negative number trick". To fix this, a new proc file is introduced: /proc/sys/kernel/auto_msgmni. This file acts as ON/OFF for msgmni automatic recomputing. With this patch, the process is the following: 1) kernel boots in "automatic recomputing mode" /proc/sys/kernel/msgmni contains the value that has been computed (depends on lowmem) /proc/sys/kernel/automatic_msgmni contains "1" 2) echo <val> > /proc/sys/kernel/msgmni . sets msg_ctlmni to <val> . de-activates automatic recomputing (i.e. if, say, some memory is added msgmni won't be recomputed anymore) . /proc/sys/kernel/automatic_msgmni now contains "0" 3) echo "0" > /proc/sys/kernel/automatic_msgmni . de-activates msgmni automatic recomputing this has the same effect as 2) except that msg_ctlmni's value stays blocked at its current value) 3) echo "1" > /proc/sys/kernel/automatic_msgmni . recomputes msgmni's value based on the current available memory size and number of ipc namespaces . re-activates automatic recomputing for msgmni. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Solofo Ramangalahy <Solofo.Ramangalahy@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25ipc: use simple_read_from_buffer()Akinobu Mita
Also this patch kills unneccesary trailing NULL character. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Pierre Peiffer <peifferp@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25ipc/sem.c: rewrite undo list lockingManfred Spraul
The attached patch: - reverses the locking order of ulp->lock and sem_lock: Previously, it was first ulp->lock, then inside sem_lock. Now it's the other way around. - converts the undo structure to rcu. Benefits: - With the old locking order, IPC_RMID could not kfree the undo structures. The stale entries remained in the linked lists and were released later. - The patch fixes a a race in semtimedop(): if both IPC_RMID and a semget() that recreates exactly the same id happen between find_alloc_undo() and sem_lock, then semtimedop() would access already kfree'd memory. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Reviewed-by: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Pierre Peiffer <peifferp@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25ipc/sem.c: convert sem_array.sem_pending to struct list_headManfred Spraul
sem_array.sem_pending is a double linked list, the attached patch converts it to struct list_head. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Reviewed-by: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Pierre Peiffer <peifferp@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25ipc/sem.c: remove unused entries from struct sem_queueManfred Spraul
sem_queue.sma and sem_queue.id were never used, the attached patch removes them. Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Reviewed-by: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Pierre Peiffer <peifferp@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25ipc/sem.c: convert undo structures to struct list_headManfred Spraul
The undo structures contain two linked lists, the attached patch replaces them with generic struct list_head lists. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Pierre Peiffer <peifferp@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25ipc: get rid of ipc_lock_down()Nadia Derbey
Remove the ipc_lock_down() routines: they used to call idr_find() locklessly (given that the ipc ids lock was already held), so they are not needed anymore. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Acked-by: "Paul E. McKenney" <paulmck@us.ibm.com> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Jim Houston <jim.houston@comcast.net> Cc: Pierre Peiffer <peifferp@gmail.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25ipc: call idr_find() without locking in ipc_lock()Nadia Derbey
Call idr_find() locklessly from ipc_lock(), since the idr tree is now RCU protected. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Acked-by: "Paul E. McKenney" <paulmck@us.ibm.com> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Jim Houston <jim.houston@comcast.net> Cc: Pierre Peiffer <peifferp@gmail.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24hugetlb: modular state for hugetlb page sizeAndi Kleen
The goal of this patchset is to support multiple hugetlb page sizes. This is achieved by introducing a new struct hstate structure, which encapsulates the important hugetlb state and constants (eg. huge page size, number of huge pages currently allocated, etc). The hstate structure is then passed around the code which requires these fields, they will do the right thing regardless of the exact hstate they are operating on. This patch adds the hstate structure, with a single global instance of it (default_hstate), and does the basic work of converting hugetlb to use the hstate. Future patches will add more hstate structures to allow for different hugetlbfs mounts to have different page sizes. [akpm@linux-foundation.org: coding-style fixes] Acked-by: Adam Litke <agl@us.ibm.com> Acked-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-13Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/smc911x.c
2008-06-12/proc/sysvipc/shm: fix 32-bit truncation of segment sizesPaul Menage
sysvipc_shm_proc_show() picks between format strings (based on the expected maximum length of a SHM segment) in a way that prevents gcc from performing format checks on the seq_printf() parameters. This hid two format errors - shp->shm_segsz and shp->shm_nattach are both unsigned long, but were being printed as unsigned int and signed int respectively. This leads to 32-bit truncation of SHM segment sizes reported in /proc/sysvipc/shm. (And for nattach, but that's less of a problem for most users). This patch makes the format string directly visible to gcc's format specifier checker, and fixes the two broken format specifiers. Signed-off-by: Paul Menage <menage@google.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Pierre Peiffer <peifferp@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-10shm: Remove silly double assignmentNeil Horman
Found a silly double assignment of err is do_shmat. Silly, but good to clean up the useless code. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06ipc: only output msgmni value at boot timeNadia Derbey
When posting: [PATCH 1/8] Scaling msgmni to the amount of lowmem (see http://lkml.org/lkml/2008/2/11/171), I have added a KERN_INFO message that is output each time msgmni is recomputed. In http://lkml.org/lkml/2008/4/29/575 Tony Luck complained that this message references an ipc namespace address that is useless. I first thought of using an audit_log instead of a printk, as suggested by Serge Hallyn. But unfortunately, we do not have any other information than the namespace address to provide here too. So I chose to move the message and output it only at boot time, removing the reference to the namespace. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Pierre Peiffer <peifferp@gmail.com> Cc: Manfred Spraul <manfred@colorfullife.com> Acked-by: Tony Luck <tony.luck@intel.com> Cc: "Serge E. Hallyn" <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-05netlink: Remove nonblock parameter from netlink_attachskbDenis V. Lunev
Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-03tiny mq_open optimizationUlrich Drepper
A very small cleanup for mq_open. We do not have to call set_close_on_exit if we create the file descriptor right away with the flag set. We have a function for this now. The resulting code is smaller and a tiny bit faster. Signed-off-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29sysvipc: use non-racy method for proc entries creationDenis V. Lunev
Use proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Pierre Peiffer <peifferp@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29ipc: sysvsem: implement sys_unshare(CLONE_SYSVSEM)Manfred Spraul
sys_unshare(CLONE_NEWIPC) doesn't handle the undo lists properly, this can cause a kernel memory corruption. CLONE_NEWIPC must detach from the existing undo lists. Fix, part 1: add support for sys_unshare(CLONE_SYSVSEM) The original reason to not support it was the potential (inevitable?) confusion due to the fact that sys_unshare(CLONE_SYSVSEM) has the inverse meaning of clone(CLONE_SYSVSEM). Our two most reasonable options then appear to be (1) fully support CLONE_SYSVSEM, or (2) continue to refuse explicit CLONE_SYSVSEM, but always do it anyway on unshare(CLONE_SYSVSEM). This patch does (1). Changelog: Apr 16: SEH: switch to Manfred's alternative patch which removes the unshare_semundo() function which always refused CLONE_SYSVSEM. Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: Pierre Peiffer <peifferp@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29ipc: add definitions of USHORT_MAX and othersZhang, Yanmin
Add definitions of USHORT_MAX and others into kernel. ipc uses it and slub implementation might also use it. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Zhang Yanmin <yanmin.zhang@intel.com> Reviewed-by: Christoph Lameter <clameter@sgi.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Cc: "Pierre Peiffer" <peifferp@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29IPC: consolidate all xxxctl_down() functionsPierre Peiffer
semctl_down(), msgctl_down() and shmctl_down() are used to handle the same set of commands for each kind of IPC. They all start to do the same job (they retrieve the ipc and do some permission checks) before handling the commands on their own. This patch proposes to consolidate this by moving these same pieces of code into one common function called ipcctl_pre_down(). It simplifies a little these xxxctl_down() functions and increases a little the maintainability. Signed-off-by: Pierre Peiffer <pierre.peiffer@bull.net> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29IPC: introduce ipc_update_perm()Pierre Peiffer
The IPC_SET command performs the same permission setting for all IPCs. This patch introduces a common ipc_update_perm() function to update these permissions and makes use of it for all IPCs. Signed-off-by: Pierre Peiffer <pierre.peiffer@bull.net> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29IPC: get rid of the use *_setbuf structure.Pierre Peiffer
All IPCs make use of an intermetiate *_setbuf structure to handle the IPC_SET command. This is not really needed and, moreover, it complicates a little bit the code. This patch gets rid of the use of it and uses directly the semid64_ds/ msgid64_ds/shmid64_ds structure. In addition of removing one struture declaration, it also simplifies and improves a little bit the common 64-bits path. Signed-off-by: Pierre Peiffer <pierre.peiffer@bull.net> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29IPC/semaphores: remove one unused parameter from semctl_down()Pierre Peiffer
semctl_down() takes one unused parameter: semnum. This patch proposes to get rid of it. Signed-off-by: Pierre Peiffer <pierre.peiffer@bull.net> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29IPC/semaphores: move the rwmutex handling inside semctl_downPierre Peiffer
semctl_down is called with the rwmutex (the one which protects the list of ipcs) taken in write mode. This patch moves this rwmutex taken in write-mode inside semctl_down. This has the advantages of reducing a little bit the window during which this rwmutex is taken, clarifying sys_semctl, and finally of having a coherent behaviour with [shm|msg]ctl_down Signed-off-by: Pierre Peiffer <pierre.peiffer@bull.net> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29IPC/message queues: introduce msgctl_downPierre Peiffer
Currently, sys_msgctl is not easy to read. This patch tries to improve that by introducing the msgctl_down function to handle all commands requiring the rwmutex to be taken in write mode (ie IPC_SET and IPC_RMID for now). It is the equivalent function of semctl_down for message queues. This greatly changes the readability of sys_msgctl and also harmonizes the way these commands are handled among all IPCs. Signed-off-by: Pierre Peiffer <pierre.peiffer@bull.net> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29IPC/shared memory: introduce shmctl_downPierre Peiffer
Currently, the way the different commands are handled in sys_shmctl introduces some duplicated code. This patch introduces the shmctl_down function to handle all the commands requiring the rwmutex to be taken in write mode (ie IPC_SET and IPC_RMID for now). It is the equivalent function of semctl_down for shared memory. This removes some duplicated code for handling these both commands and harmonizes the way they are handled among all IPCs. Signed-off-by: Pierre Peiffer <pierre.peiffer@bull.net> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29IPC/semaphores: code factorisationPierre Peiffer
Trivial patch which adds some small locking functions and makes use of them to factorize some part of the code and to make it cleaner. Signed-off-by: Pierre Peiffer <pierre.peiffer@bull.net> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29ipc: re-enable msgmni automatic recomputing msgmni if set to negativeNadia Derbey
The enhancement as asked for by Yasunori: if msgmni is set to a negative value, register it back into the ipcns notifier chain. A new interface has been added to the notification mechanism: notifier_chain_cond_register() registers a notifier block only if not already registered. With that new interface we avoid taking care of the states changes in procfs. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Mingming Cao <cmm@us.ibm.com> Cc: Pierre Peiffer <pierre.peiffer@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29ipc: do not recompute msgmni anymore if explicitly set by userNadia Derbey
Make msgmni not recomputed anymore upon ipc namespace creation / removal or memory add/remove, as soon as it has been set from userland. As soon as msgmni is explicitly set via procfs or sysctl(), the associated callback routine is unregistered from the ipc namespace notifier chain. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Mingming Cao <cmm@us.ibm.com> Cc: Pierre Peiffer <pierre.peiffer@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29ipc: recompute msgmni on ipc namespace creation/removalNadia Derbey
Introduce a notification mechanism that aims at recomputing msgmni each time an ipc namespace is created or removed. The ipc namespace notifier chain already defined for memory hotplug management is used for that purpose too. Each time a new ipc namespace is allocated or an existing ipc namespace is removed, the ipcns notifier chain is notified. The callback routine for each registered ipc namespace is then activated in order to recompute msgmni for that namespace. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Mingming Cao <cmm@us.ibm.com> Cc: Pierre Peiffer <pierre.peiffer@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29ipc: invoke the ipcns notifier chain as a work itemNadia Derbey
Make the memory hotplug chain's mutex held for a shorter time: when memory is offlined or onlined a work item is added to the global workqueue. When the work item is run, it notifies the ipcns notifier chain with the IPCNS_MEMCHANGED event. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Mingming Cao <cmm@us.ibm.com> Cc: Pierre Peiffer <pierre.peiffer@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29ipc: recompute msgmni on memory add / removeNadia Derbey
Introduce the registration of a callback routine that recomputes msg_ctlmni upon memory add / remove. A single notifier block is registered in the hotplug memory chain for all the ipc namespaces. Since the ipc namespaces are not linked together, they have their own notification chain: one notifier_block is defined per ipc namespace. Each time an ipc namespace is created (removed) it registers (unregisters) its notifier block in (from) the ipcns chain. The callback routine registered in the memory chain invokes the ipcns notifier chain with the IPCNS_LOWMEM event. Each callback routine registered in the ipcns namespace, in turn, recomputes msgmni for the owning namespace. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Mingming Cao <cmm@us.ibm.com> Cc: Pierre Peiffer <pierre.peiffer@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29ipc: scale msgmni to the number of ipc namespacesNadia Derbey
Since all the namespaces see the same amount of memory (the total one) this patch introduces a new variable that counts the ipc namespaces and divides msg_ctlmni by this counter. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Mingming Cao <cmm@us.ibm.com> Cc: Pierre Peiffer <pierre.peiffer@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29ipc: scale msgmni to the amount of lowmemNadia Derbey
On large systems we'd like to allow a larger number of message queues. In some cases up to 32K. However simply setting MSGMNI to a larger value may cause problems for smaller systems. The first patch of this series introduces a default maximum number of message queue ids that scales with the amount of lowmem. Since msgmni is per namespace and there is no amount of memory dedicated to each namespace so far, the second patch of this series scales msgmni to the number of ipc namespaces too. Since msgmni depends on the amount of memory, it becomes necessary to recompute it upon memory add/remove. In the 4th patch, memory hotplug management is added: a notifier block is registered into the memory hotplug notifier chain for the ipc subsystem. Since the ipc namespaces are not linked together, they have their own notification chain: one notifier_block is defined per ipc namespace. Each time an ipc namespace is created (removed) it registers (unregisters) its notifier block in (from) the ipcns chain. The callback routine registered in the memory chain invokes the ipcns notifier chain with the IPCNS_MEMCHANGE event. Each callback routine registered in the ipcns namespace, in turn, recomputes msgmni for the owning namespace. The 5th patch makes it possible to keep the memory hotplug notifier chain's lock for a lesser amount of time: instead of directly notifying the ipcns notifier chain upon memory add/remove, a work item is added to the global workqueue. When activated, this work item is the one who notifies the ipcns notifier chain. Since msgmni depends on the number of ipc namespaces, it becomes necessary to recompute it upon ipc namespace creation / removal. The 6th patch uses the ipc namespace notifier chain for that purpose: that chain is notified each time an ipc namespace is created or removed. This makes it possible to recompute msgmni for all the namespaces each time one of them is created or removed. When msgmni is explicitely set from userspace, we should avoid recomputing it upon memory add/remove or ipcns creation/removal. This is what the 7th patch does: it simply unregisters the ipcns callback routine as soon as msgmni has been changed from procfs or sysctl(). Even if msgmni is set by hand, it should be possible to make it back automatically recomputed upon memory add/remove or ipcns creation/removal. This what is achieved in patch 8: if set to a negative value, msgmni is added back to the ipcns notifier chain, making it automatically recomputed again. This patch: Compute msg_ctlmni to make it scale with the amount of lowmem. msg_ctlmni is now set to make the message queues occupy 1/32 of the available lowmem. Some cleaning has also been done for the MSGPOOL constant: the msgctl man page says it's not used, but it also defines it as a size in bytes (the code expresses it in Kbytes). Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Mingming Cao <cmm@us.ibm.com> Cc: Pierre Peiffer <pierre.peiffer@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29IPC: use ipc_buildid() directly from ipc_addid()Pierre Peiffer
By continuing to consolidate a little the IPC code, each id can be built directly in ipc_addid() instead of having it built from each callers of ipc_addid() And I also remove shm_addid() in order to have, as much as possible, the same code for shm/sem/msg. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Pierre Peiffer <pierre.peiffer@bull.net> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mempolicy: rework mempolicy Reference Counting [yet again]Lee Schermerhorn
After further discussion with Christoph Lameter, it has become clear that my earlier attempts to clean up the mempolicy reference counting were a bit of overkill in some areas, resulting in superflous ref/unref in what are usually fast paths. In other areas, further inspection reveals that I botched the unref for interleave policies. A separate patch, suitable for upstream/stable trees, fixes up the known errors in the previous attempt to fix reference counting. This patch reworks the memory policy referencing counting and, one hopes, simplifies the code. Maybe I'll get it right this time. See the update to the numa_memory_policy.txt document for a discussion of memory policy reference counting that motivates this patch. Summary: Lookup of mempolicy, based on (vma, address) need only add a reference for shared policy, and we need only unref the policy when finished for shared policies. So, this patch backs out all of the unneeded extra reference counting added by my previous attempt. It then unrefs only shared policies when we're finished with them, using the mpol_cond_put() [conditional put] helper function introduced by this patch. Note that shmem_swapin() calls read_swap_cache_async() with a dummy vma containing just the policy. read_swap_cache_async() can call alloc_page_vma() multiple times, so we can't let alloc_page_vma() unref the shared policy in this case. To avoid this, we make a copy of any non-null shared policy and remove the MPOL_F_SHARED flag from the copy. This copy occurs before reading a page [or multiple pages] from swap, so the overhead should not be an issue here. I introduced a new static inline function "mpol_cond_copy()" to copy the shared policy to an on-stack policy and remove the flags that would require a conditional free. The current implementation of mpol_cond_copy() assumes that the struct mempolicy contains no pointers to dynamically allocated structures that must be duplicated or reference counted during copy. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
