path: root/ipc
2010-12-09sys_semctl: fix kernel stack leakageDan Rosenberg
commit 982f7c2b2e6a28f8f266e075d92e19c0dd4c6e56 upstream. The semctl syscall has several code paths that lead to the leakage of uninitialized kernel stack memory (namely the IPC_INFO, SEM_INFO, IPC_STAT, and SEM_STAT commands) during the use of the older, obsolete version of the semid_ds struct. The copy_semid_to_user() function declares a semid_ds struct on the stack and copies it back to the user without initializing or zeroing the "sem_base", "sem_pending", "sem_pending_last", and "undo" pointers, allowing the leakage of 16 bytes of kernel stack memory. The code is still reachable on 32-bit systems - when calling semctl() newer glibc's automatically OR the IPC command with the IPC_64 flag, but invoking the syscall directly allows users to use the older versions of the struct. Signed-off-by: Dan Rosenberg <dan.j.rosenberg@gmail.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09ipc: shm: fix information leak to userlandVasiliy Kulikov
commit 3af54c9bd9e6f14f896aac1bb0e8405ae0bc7a44 upstream. The shmid_ds structure is copied to userland with shm_unused{,2,3} fields unitialized. It leads to leaking of contents of kernel stack memory. Signed-off-by: Vasiliy Kulikov <segooon@gmail.com> Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09ipc: initialize structure memory to zero for compat functionsDan Rosenberg
commit 03145beb455cf5c20a761e8451e30b8a74ba58d9 upstream. This takes care of leaking uninitialized kernel stack memory to userspace from non-zeroed fields in structs in compat ipc functions. Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01mqueue: fix mq_open() file descriptor leak on user-space processesAndré Goddard Rosa
commit 4294a8eedb17bbc45e1e7447c2a4d05332943248 upstream. We leak fd on lookup_one_len() failure Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-28ipc ns: fix memory leak (idr)Serge E. Hallyn
commit 7d6feeb287c61aafa88f06345387b1188edf4b86 upstream. We have apparently had a memory leak since 7ca7e564e049d8b350ec9d958ff25eaa24226352 "ipc: store ipcs into IDRs" in 2007. The idr of which 3 exist for each ipc namespace is never freed. This patch simply frees them when the ipcns is freed. I don't believe any idr_remove() are done from rcu (and could therefore be delayed until after this idr_destroy()), so the patch should be safe. Some quick testing showed no harm, and the memory leak fixed. Caught by kmemleak. Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-18untangle the do_mremap() messAl Viro
This backports the following upstream commits all as one patch: 54f5de709984bae0d31d823ff03de755f9dcac54 ecc1a8993751de4e82eb18640d631dae1f626bd6 1a0ef85f84feb13f07b604fcf5b90ef7c2b5c82f f106af4e90eadd76cfc0b5325f659619e08fb762 097eed103862f9c6a97f2e415e21d1134017b135 935874141df839c706cd6cdc438e85eb69d1525e 0ec62d290912bb4b989be7563851bc364ec73b56 c4caa778157dbbf04116f0ac2111e389b5cd7a29 2ea1d13f64efdf49319e86c87d9ba38c30902782 570dcf2c15463842e384eb597a87c1e39bead99b 564b3bffc619dcbdd160de597b0547a7017ea010 0067bd8a55862ac9dd212bd1c4f6f5bff1ca1301 f8b7256096a20436f6d0926747e3ac3d64c81d24 8c7b49b3ecd48923eb64ff57e07a1cdb74782970 9206de95b1ea68357996ec02be5db0638a0de2c1 2c6a10161d0b5fc047b5bd81b03693b9af99fab5 05d72faa6d13c9d857478a5d35c85db9adada685 bb52d6694002b9d632bb355f64daa045c6293a4e e77414e0aad6a1b063ba5e5750c582c75327ea6a aa65607373a4daf2010e8c3867b6317619f3c1a3 Backport done by Greg Kroah-Hartman. Only minor tweaks were needed. Cc: David S. Miller <davem@davemloft.net> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-27const: mark struct vm_struct_operationsAlexey Dobriyan
* mark struct vm_area_struct::vm_ops as const * mark vm_ops in AGP code But leave TTM code alone, something is fishy there with global vm_ops being used. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24sysctl: remove "struct file *" argument of ->proc_handlerAlexey Dobriyan
It's unused. It isn't needed -- read or write flag is already passed and sysctl shouldn't care about the rest. It _was_ used in two places at arch/frv for some reason. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: David Howells <dhowells@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23seq_file: constify seq_operationsJames Morris
Make all seq_operations structs const, to help mitigate against revectoring user-triggerable function pointers. This is derived from the grsecurity patch, although generated from scratch because it's simpler than extracting the changes from there. Signed-off-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22hugetlbfs: allow the creation of files suitable for MAP_PRIVATE on the vfs ↵Eric B Munson
internal mount This patchset adds a flag to mmap that allows the user to request that an anonymous mapping be backed with huge pages. This mapping will borrow functionality from the huge page shm code to create a file on the kernel internal mount and use it to approximate an anonymous mapping. The MAP_HUGETLB flag is a modifier to MAP_ANONYMOUS and will not work without both flags being preset. A new flag is necessary because there is no other way to hook into huge pages without creating a file on a hugetlbfs mount which wouldn't be MAP_ANONYMOUS. To userspace, this mapping will behave just like an anonymous mapping because the file is not accessible outside of the kernel. This patchset is meant to simplify the programming model. Presently there is a large chunk of boiler platecode, contained in libhugetlbfs, required to create private, hugepage backed mappings. This patch set would allow use of hugepages without linking to libhugetlbfs or having hugetblfs mounted. Unification of the VM code would provide these same benefits, but it has been resisted each time that it has been suggested for several reasons: it would break PAGE_SIZE assumptions across the kernel, it makes page-table abstractions really expensive, and it does not provide any benefit on architectures that do not support huge pages, incurring fast path penalties without providing any benefit on these architectures. This patch: There are two means of creating mappings backed by huge pages: 1. mmap() a file created on hugetlbfs 2. Use shm which creates a file on an internal mount which essentially maps it MAP_SHARED The internal mount is only used for shared mappings but there is very little that stops it being used for private mappings. This patch extends hugetlbfs_file_setup() to deal with the creation of files that will be mapped MAP_PRIVATE on the internal hugetlbfs mount. This extended API is used in a subsequent patch to implement the MAP_HUGETLB mmap() flag. Signed-off-by: Eric Munson <ebmunson@us.ibm.com> Acked-by: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Adam Litke <agl@us.ibm.com> Cc: David Gibson <david@gibson.dropbear.id.au> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22const: mark remaining super_operations constAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-14fix undefined reference to user_shm_unlockHugh Dickins
My 353d5c30c666580347515da609dd74a2b8e9b828 "mm: fix hugetlb bug due to user_shm_unlock call" broke the CONFIG_SYSVIPC !CONFIG_MMU build of both 2.6.31 and 2.6.30.6: "undefined reference to `user_shm_unlock'". gcc didn't understand my comment! so couldn't figure out to optimize away user_shm_unlock() from the error path in the hugetlb-less case, as it does elsewhere. Help it to do so, in a language it understands. Reported-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-24mm: fix hugetlb bug due to user_shm_unlock callHugh Dickins
2.6.30's commit 8a0bdec194c21c8fdef840989d0d7b742bb5d4bc removed user_shm_lock() calls in hugetlb_file_setup() but left the user_shm_unlock call in shm_destroy(). In detail: Assume that can_do_hugetlb_shm() returns true and hence user_shm_lock() is not called in hugetlb_file_setup(). However, user_shm_unlock() is called in any case in shm_destroy() and in the following atomic_dec_and_lock(&up->__count) in free_uid() is executed and if up->__count gets zero, also cleanup_user_struct() is scheduled. Note that sched_destroy_user() is empty if CONFIG_USER_SCHED is not set. However, the ref counter up->__count gets unexpectedly non-positive and the corresponding structs are freed even though there are live references to them, resulting in a kernel oops after a lots of shmget(SHM_HUGETLB)/shmctl(IPC_RMID) cycles and CONFIG_USER_SCHED set. Hugh changed Stefan's suggested patch: can_do_hugetlb_shm() at the time of shm_destroy() may give a different answer from at the time of hugetlb_file_setup(). And fixed newseg()'s no_id error path, which has missed user_shm_unlock() ever since it came in 2.6.9. Reported-by: Stefan Huber <shuber2@gmail.com> Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Tested-by: Stefan Huber <shuber2@gmail.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-29integrity: ima mq_open imbalance msg fixMimi Zohar
This patch fixes an imbalance message as reported by Sanchin Sant. As we don't need to measure the message queue, just increment the counters. Reported-by: Sanchin Sant <sanchinp@in.ibm.com> Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-06-21ipc: unbreak 32-bit shmctl/semctl/msgctlJohannes Weiner
31a985f "ipc: use __ARCH_WANT_IPC_PARSE_VERSION in ipc/util.h" would choose the implementation of ipc_parse_version() based on a symbol defined in <asm/unistd.h>. But it failed to also include this header and thus broke IPC_64-passing 32-bit userspace because the flag wasn't masked out properly anymore and the command not understood. Include <linux/unistd.h> to give the architecture a chance to ask for the no-no-op ipc_parse_version(). Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18ipcns: move free_ipcs() protoAlexey Dobriyan
Function is really private to ipc/ and avoid struct kern_ipc_perm forward declaration. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18ipcns: make free_ipc_ns() staticAlexey Dobriyan
2009-06-18ipcns: extract create_ipc_ns()Alexey Dobriyan
clone_ipc_ns() is misnamed, it doesn't clone anything and doesn't use passed parameter. Rename it. create_ipc_ns() will be used by C/R to create fresh ipcns. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18ipcns: remove useless get/put while CLONE_NEWIPCAlexey Dobriyan
copy_ipcs() doesn't actually copy anything. If new ipcns is created, it's created from scratch, in this case get/put on old ipcns isn't needed. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18ipc: use __ARCH_WANT_IPC_PARSE_VERSION in ipc/util.hArnd Bergmann
The definition of ipc_parse_version depends on __ARCH_WANT_IPC_PARSE_VERSION, but the header file declares it conditionally based on the architecture. Use the macro consistently to make it easier to add new architectures. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (44 commits) nommu: Provide mmap_min_addr definition. TOMOYO: Add description of lists and structures. TOMOYO: Remove unused field. integrity: ima audit dentry_open failure TOMOYO: Remove unused parameter. security: use mmap_min_addr indepedently of security models TOMOYO: Simplify policy reader. TOMOYO: Remove redundant markers. SELinux: define audit permissions for audit tree netlink messages TOMOYO: Remove unused mutex. tomoyo: avoid get+put of task_struct smack: Remove redundant initialization. integrity: nfsd imbalance bug fix rootplug: Remove redundant initialization. smack: do not beyond ARRAY_SIZE of data integrity: move ima_counts_get integrity: path_check update IMA: Add __init notation to ima functions IMA: Minimal IMA policy and boot param for TCB IMA policy selinux: remove obsolete read buffer limit from sel_read_bool ...
2009-06-10Merge branch 'rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: rcu: rcu_sched_grace_period(): kill the bogus flush_signals() rculist: use list_entry_rcu in places where it's appropriate rculist.h: introduce list_entry_rcu() and list_first_entry_rcu() rcu: Update RCU tracing documentation for __rcu_pending rcu: Add __rcu_pending tracing to hierarchical RCU RCU: make treercu be default
2009-06-11Merge branch 'next' into for-linusJames Morris
2009-06-09shm: fix unused warnings on nommuMike Frysinger
The massive nommu update (8feae131) resulted in these warnings: ipc/shm.c: In function `sys_shmdt': ipc/shm.c:974: warning: unused variable `size' ipc/shm.c:972: warning: unused variable `next' Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-22integrity: move ima_counts_getMimi Zohar
Based on discussion on lkml (Andrew Morton and Eric Paris), move ima_counts_get down a layer into shmem/hugetlb__file_setup(). Resolves drm shmem_file_setup() usage case as well. HD comment: I still think you're doing this at the wrong level, but recognize that you probably won't be persuaded until a few more users of alloc_file() emerge, all wanting your ima_counts_get(). Resolving GEM's shmem_file_setup() is an improvement, so I'll say Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-05-22integrity: path_check updateMimi Zohar
- Add support in ima_path_check() for integrity checking without incrementing the counts. (Required for nfsd.) - rename and export opencount_get to ima_counts_get - replace ima_shm_check calls with ima_counts_get - export ima_path_check Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-04-15rculist: use list_entry_rcu in places where it's appropriateJiri Pirko
Use previously introduced list_entry_rcu instead of an open-coded list_entry + rcu_dereference combination. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: dipankar@in.ibm.com LKML-Reference: <20090414181715.GA3634@psychotron.englab.brq.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-13namespaces: move get_mq() inside #ifdef CONFIG_SYSCTLGeert Uytterhoeven
| ipc/mq_sysctl.c:26: warning: 'get_mq' defined but not used Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07namespaces: mqueue namespace: adapt sysctlSerge E. Hallyn
Largely inspired from ipc/ipc_sysctl.c. This patch isolates the mqueue sysctl stuff in its own file. [akpm@linux-foundation.org: build fix] Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07namespaces: ipc namespaces: implement support for posix msqueuesSerge E. Hallyn
Implement multiple mounts of the mqueue file system, and link it to usage of CLONE_NEWIPC. Each ipc ns has a corresponding mqueuefs superblock. When a user does clone(CLONE_NEWIPC) or unshare(CLONE_NEWIPC), the unshare will cause an internal mount of a new mqueuefs sb linked to the new ipc ns. When a user does 'mount -t mqueue mqueue /dev/mqueue', he mounts the mqueuefs superblock. Posix message queues can be worked with both through the mq_* system calls (see mq_overview(7)), and through the VFS through the mqueue mount. Any usage of mq_open() and friends will work with the acting task's ipc namespace. Any actions through the VFS will work with the mqueuefs in which the file was created. So if a user doesn't remount mqueuefs after unshare(CLONE_NEWIPC), mq_open("/ab") will not be reflected in "ls /dev/mqueue". If task a mounts mqueue for ipc_ns:1, then clones task b with a new ipcns, ipcns:2, and then task a is the last task in ipc_ns:1 to exit, then (1) ipc_ns:1 will be freed, (2) it's superblock will live on until task b umounts the corresponding mqueuefs, and vfs actions will continue to succeed, but (3) sb->s_fs_info will be NULL for the sb corresponding to the deceased ipc_ns:1. To make this happen, we must protect the ipc reference count when a) a task exits and drops its ipcns->count, since it might be dropping it to 0 and freeing the ipcns b) a task accesses the ipcns through its mqueuefs interface, since it bumps the ipcns refcount and might race with the last task in the ipcns exiting. So the kref is changed to an atomic_t so we can use atomic_dec_and_lock(&ns->count,mq_lock), and every access to the ipcns through ns = mqueuefs_sb->s_fs_info is protected by the same lock. Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07namespaces: mqueue ns: move mqueue_mnt into struct ipc_namespaceSerge E. Hallyn
Move mqueue vfsmount plus a few tunables into the ipc_namespace struct. The CONFIG_IPC_NS boolean and the ipc_namespace struct will serve both the posix message queue namespaces and the SYSV ipc namespaces. The sysctl code will be fixed separately in patch 3. After just this patch, making a change to posix mqueue tunables always changes the values in the initial ipc namespace. Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: Remove two unneeded exports and make two symbols static in fs/mpage.c Cleanup after commit 585d3bc06f4ca57f975a5a1f698f65a45ea66225 Trim includes of fdtable.h Don't crap into descriptor table in binfmt_som Trim includes in binfmt_elf Don't mess with descriptor table in load_elf_binary() Get rid of indirect include of fs_struct.h New helper - current_umask() check_unsafe_exec() doesn't care about signal handlers sharing New locking/refcounting for fs_struct Take fs_struct handling to new file (fs/fs_struct.c) Get rid of bumping fs_struct refcount in pivot_root(2) Kill unsharing fs_struct in __set_personality()
2009-04-02proc_sysctl: use CONFIG_PROC_SYSCTL around ipc and utsname proc_handlersSerge E. Hallyn
As pointed out by Cedric Le Goater (in response to Alexey's original comment wrt mqns), ipc_sysctl.c and utsname_sysctl.c are using CONFIG_PROC_FS, not CONFIG_PROC_SYSCTL, to determine whether to define the proc_handlers. Change that. Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Acked-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02ipc: make shm_get_stat() more robustTony Battersby
shm_get_stat() assumes idr_find(&shm_ids(ns).ipcs_idr) returns "struct shmid_kernel *"; all other callers assume that it returns "struct kern_ipc_perm *". This works because "struct kern_ipc_perm" is currently the first member of "struct shmid_kernel", but it would be better to use container_of() to prevent future breakage. Signed-off-by: Tony Battersby <tonyb@cybernetics.com> Cc: Jiri Olsa <olsajiri@gmail.com> Cc: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-31New helper - current_umask()Al Viro
current->fs->umask is what most of fs_struct users are doing. Put that into a helper function. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-26Merge branch 'bkl-removal' of git://git.lwn.net/linux-2.6Linus Torvalds
* 'bkl-removal' of git://git.lwn.net/linux-2.6: Rationalize fasync return values Move FASYNC bit handling to f_op->fasync() Use f_lock to protect f_flags Rename struct file->f_ep_lock
2009-03-24Merge branch 'master' into nextJames Morris
2009-03-16Use f_lock to protect f_flagsJonathan Corbet
Traditionally, changes to struct file->f_flags have been done under BKL protection, or with no protection at all. This patch causes all f_flags changes after file open/creation time to be done under protection of f_lock. This allows the removal of some BKL usage and fixes a number of longstanding (if microscopic) races. Reviewed-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2009-02-10Do not account for the address space used by hugetlbfs using VM_ACCOUNTMel Gorman
When overcommit is disabled, the core VM accounts for pages used by anonymous shared, private mappings and special mappings. It keeps track of VMAs that should be accounted for with VM_ACCOUNT and VMAs that never had a reserve with VM_NORESERVE. Overcommit for hugetlbfs is much riskier than overcommit for base pages due to contiguity requirements. It avoids overcommiting on both shared and private mappings using reservation counters that are checked and updated during mmap(). This ensures (within limits) that hugepages exist in the future when faults occurs or it is too easy to applications to be SIGKILLed. As hugetlbfs makes its own reservations of a different unit to the base page size, VM_ACCOUNT should never be set. Even if the units were correct, we would double account for the usage in the core VM and hugetlbfs. VM_NORESERVE may be set because an application can request no reserves be made for hugetlbfs at the risk of getting killed later. With commit fc8744adc870a8d4366908221508bb113d8b72ee, VM_NORESERVE and VM_ACCOUNT are getting unconditionally set for hugetlbfs-backed mappings. This breaks the accounting for both the core VM and hugetlbfs, can trigger an OOM storm when hugepage pools are too small lockups and corrupted counters otherwise are used. This patch brings hugetlbfs more in line with how the core VM treats VM_NORESERVE but prevents VM_ACCOUNT being set. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-06Merge branch 'master' into nextJames Morris
Conflicts: fs/namei.c Manually merged per: diff --cc fs/namei.c index 734f2b5,bbc15c2..0000000 --- a/fs/namei.c +++ b/fs/namei.c @@@ -860,9 -848,8 +849,10 @@@ static int __link_path_walk(const char nd->flags |= LOOKUP_CONTINUE; err = exec_permission_lite(inode); if (err == -EAGAIN) - err = vfs_permission(nd, MAY_EXEC); + err = inode_permission(nd->path.dentry->d_inode, + MAY_EXEC); + if (!err) + err = ima_path_check(&nd->path, MAY_EXEC); if (err) break; @@@ -1525,14 -1506,9 +1509,14 @@@ int may_open(struct path *path, int acc flag &= ~O_TRUNC; } - error = vfs_permission(nd, acc_mode); + error = inode_permission(inode, acc_mode); if (error) return error; + - error = ima_path_check(&nd->path, ++ error = ima_path_check(path, + acc_mode & (MAY_READ | MAY_WRITE | MAY_EXEC)); + if (error) + return error; /* * An append-only file must be opened in append mode for writing. */ Signed-off-by: James Morris <jmorris@namei.org>
2009-02-06Integrity: IMA file free imbalanceMimi Zohar
The number of calls to ima_path_check()/ima_file_free() should be balanced. An extra call to fput(), indicates the file could have been accessed without first being measured. Although f_count is incremented/decremented in places other than fget/fput, like fget_light/fput_light and get_file, the current task must already hold a file refcnt. The call to __fput() is delayed until the refcnt becomes 0, resulting in ima_file_free() flagging any changes. - add hook to increment opencount for IPC shared memory(SYSV), shmat files, and /dev/zero - moved NULL iint test in opencount_get() Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-02-05shm: fix shmctl(SHM_INFO) lockup with !CONFIG_SHMEMTony Battersby
shm_get_stat() assumes that the inode is a "struct shmem_inode_info", which is incorrect for !CONFIG_SHMEM (see fs/ramfs/inode.c: ramfs_get_inode() vs. mm/shmem.c: shmem_get_inode()). This bad assumption can cause shmctl(SHM_INFO) to lockup when shm_get_stat() tries to spin_lock(&info->lock). Users of !CONFIG_SHMEM may encounter this lockup simply by invoking the 'ipcs' command. Reported by Jiri Olsa back in February 2008: http://lkml.org/lkml/2008/2/29/74 Signed-off-by: Tony Battersby <tonyb@cybernetics.com> Cc: Jiri Kosina <jkosina@suse.cz> Reported-by: Jiri Olsa <olsajiri@gmail.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: <stable@kernel.org> [2.6.everything] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-31Stop playing silly games with the VM_ACCOUNT flagLinus Torvalds
The mmap_region() code would temporarily set the VM_ACCOUNT flag for anonymous shared mappings just to inform shmem_zero_setup() that it should enable accounting for the resulting shm object. It would then clear the flag after calling ->mmap (for the /dev/zero case) or doing shmem_zero_setup() (for the MAP_ANON case). This just resulted in vma merge issues, but also made for just unnecessary confusion. Use the already-existing VM_NORESERVE flag for this instead, and let shmem_{zero|file}_setup() just figure it out from that. This also happens to make it obvious that the new DRI2 GEM layer uses a non-reserving backing store for its object allocation - which is quite possibly not intentional. But since I didn't want to change semantics in this patch, I left it alone, and just updated the caller to use the new flag semantics. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-14[CVE-2009-0029] System call wrappers part 26Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 25Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 24Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrapper special casesHeiko Carstens
System calls with an unsigned long long argument can't be converted with the standard wrappers since that would include a cast to long, which in turn means that we would lose the upper 32 bit on 32 bit architectures. Also semctl can't use the standard wrapper since it has a 'union' parameter. So we handle them as special case and add some extra wrappers instead. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2009-01-14[CVE-2009-0029] Convert all system calls to return a longHeiko Carstens
Convert all system calls to return a long. This should be a NOP since all converted types should have the same size anyway. With the exception of sys_exit_group which returned void. But that doesn't matter since the system call doesn't return. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2009-01-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-nommuLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-nommu: NOMMU: Support XIP on initramfs NOMMU: Teach kobjsize() about VMA regions. FLAT: Don't attempt to expand the userspace stack to fill the space allocated FDPIC: Don't attempt to expand the userspace stack to fill the space allocated NOMMU: Improve procfs output using per-MM VMAs NOMMU: Make mmap allocation page trimming behaviour configurable. NOMMU: Make VMAs per MM as for MMU-mode linux NOMMU: Delete askedalloc and realalloc variables NOMMU: Rename ARM's struct vm_region NOMMU: Fix cleanup handling in ramfs_nommu_get_umapped_area()
2009-01-08mqueue: fix si_pid value in mqueue do_notify()Sukadev Bhattiprolu
If a process registers for asynchronous notification on a POSIX message queue, it gets a signal and a siginfo_t structure when a message arrives on the message queue. The si_pid in the siginfo_t structure is set to the PID of the process that sent the message to the message queue. The principle is the following: . when mq_notify(SIGEV_SIGNAL) is called, the caller registers for notification when a msg arrives. The associated pid structure is stroed into inode_info->notify_owner. Let's call this process P1. . when mq_send() is called by say P2, P2 sends a signal to P1 to notify him about msg arrival. The way .si_pid is set today is not correct, since it doesn't take into account the fact that the process that is sending the message might not be in the same namespace as the notified one. This patch proposes to set si_pid to the sender's pid into the notify_owner namespace. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Acked-by: Oleg Nesterov <oleg@redhat.com> Cc: Roland McGrath <roland@redhat.com> Cc: Bastian Blank <bastian@waldi.eu.org> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
