commit d694ad62bf539dbb20a0899ac2a954555f9e4a83 upstream.
If a semaphore array is removed and in parallel a sleeping task is woken
up (signal or timeout, does not matter), then the woken up task does not
wait until wake_up_sem_queue_do() is completed. This will cause crashes,
because wake_up_sem_queue_do() will read from a stale pointer.
The fix is simple: Regardless of anything, always call get_queue_result().
This function waits until wake_up_sem_queue_do() has finished it's task.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=27142
Reported-by: Yuriy Yevtukhov <yuriy@ucoz.com>
Reported-by: Harald Laabs <kernel@dasr.de>
Signed-off-by: Manfred Spraul <manfred@colorfullife.com>
The type of vma->vm_flags is 'unsigned long'. Neither 'int' nor
'unsigned int'. This patch fixes such misuse.
[ Changed to use a typedef - we'll extend it to cover more cases
later, since there has been discussion about making it a 64-bit
type.. - Linus ]
Acked-by: Daniel Lezcano <daniel.lezcano@free.fr>
Fix ipc/util.c kernel-doc warnings:
Warning(ipc/util.c:336): No description found for parameter 'ns'
Warning(ipc/util.c:620): No description found for parameter 'ns'
Warning(ipc/util.c:790): No description found for parameter 'ns'
Reviewed-by: Jesper Juhl <jj@chaosbits.net>
commit b515498 ("userns: add a user namespace owner of ipc ns") added a
user namespace owner of ipc ns, but it also introduced a use after free in
free_ipc_ns().
Signed-off-by: Xiaotian Feng <dfeng@redhat.com>
Acked-by: "Serge E. Hallyn" <serge.hallyn@canonical.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Daniel Lezcano <daniel.lezcano@free.fr>
CAP_IPC_OWNER and CAP_IPC_LOCK can be checked against current_user_ns(),
because the resource comes from current's own ipc namespace.
setuid/setgid are to uids in own namespace, so again checks can be against
current_user_ns().
Changelog:
Jan 11: Use task_ns_capable() in place of sched_capable().
Jan 11: Use nsown_capable() as suggested by Bastian Blank.
Jan 11: Clarify (hopefully) some logic in futex and sched.c
Feb 15: use ns_capable for ipc, not nsown_capable
Feb 23: let copy_ipcs handle setting ipc_ns->user_ns
Feb 23: pass ns down rather than taking it from current
Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com>
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
Changelog:
Feb 15: Don't set new ipc->user_ns if we didn't create a new
ipc_ns.
Feb 23: Move extern declaration to ipc_namespace.h, and group
fwd declarations at top.
RCU free the struct inode. This will allow:
- Subsequent store-free path walking patch. The inode must be consulted for
permissions when walking, so an RCU inode reference is a must.
- sb_inode_list_lock to be moved inside i_lock because sb list walkers who want
to take i_lock no longer need to take sb_inode_list_lock to walk the list in
the first place. This will simplify and optimize locking.
- Could remove some nested trylock loops in dcache code
- Could potentially simplify things a bit in VM land. Do not need to take the
page lock to follow page->mapping.
The downsides of this is the performance cost of using RCU. In a simple
creat/unlink microbenchmark, performance drops by about 10% due to inability to
reuse cache-hot slab objects. As iterations increase and RCU freeing starts
kicking over, this increases to about 20%.
In cases where inode lifetimes are longer (ie. many inodes may be allocated
during the average life span of a single inode), a lot of this cache reuse is
not applicable, so the regression caused by this patch is smaller.
The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU,
however this adds some complexity to list walking and store-free path walking,
so I prefer to implement this at a later date, if it is shown to be a win in
real situations. I haven't found a regression in any non-micro benchmark so I
doubt it will be a problem.
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
The shmid_ds structure is copied to userland with shm_unused{,2,3}
fields unitialized. It leads to leaking of contents of kernel stack
memory.
Signed-off-by: Vasiliy Kulikov <segooon@gmail.com>
Acked-by: Al Viro <viro@ZenIV.linux.org.uk>
Cc: stable@kernel.org
This takes care of leaking uninitialized kernel stack memory to
userspace from non-zeroed fields in structs in compat ipc functions.
Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com>
Cc: Manfred Spraul <manfred@colorfullife.com>
Cc: <stable@kernel.org>
The kernel currently provides no functionality to analyze the RSS and swap
space usage of each individual sysvipc shared memory segment.
This patch adds this info for each existing shm segment by extending the
output of /proc/sysvipc/shm by two columns for RSS and swap.
Since shmctl(SHM_INFO) already provides a similiar calculation (it
currently sums up all RSS/swap info for all segments), I did split out a
static function which is now used by the /proc/sysvipc/shm output and
shmctl(SHM_INFO).
SAP products (esp. the SAP Netweaver ABAP Kernel) uses lots of big shared
memory segments (we often have Linux systems with >= 16GB shm usage).
Sometimes we get customer reports about "slow" system responses and while
looking into their configurations we often find massive swapping activity
on the system. With this patch it's now easy to see from the command line
if and which shm segments gets swapped out (and how much) and can more
easily give recommendations for system tuning. Without the patch it's
currently not possible to do such shm analysis at all.
Also...
Add some spaces in front of the "size" field for 64bit kernels to get the
columns correct if you cat the contents of the file. In
sysvipc_shm_proc_show() the kernel prints the size value in "SPEC_SIZE"
format, which is defined like this:
#if BITS_PER_LONG <= 32
#define SIZE_SPEC "%10lu"
#else
#define SIZE_SPEC "%21lu"
#endif
So, if the header is not adjusted, the columns are not correctly aligned.
I actually tested this on 32- and 64-bit and it seems correct now.
Signed-off-by: Helge Deller <deller@gmx.de>
Instead of always assigning an increasing inode number in new_inode
move the call to assign it into those callers that actually need it.
For now callers that need it is estimated conservatively, that is
the call is added to all filesystems that do not assign an i_ino
by themselves. For a few more filesystems we can avoid assigning
any inode number given that they aren't user visible, and for others
it could be done lazily when an inode number is actually needed,
but that's left for later patches.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Clones an existing reference to inode; caller must already hold one.
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl:
vfs: make no_llseek the default
vfs: don't use BKL in default_llseek
llseek: automatically add .llseek fop
libfs: use generic_file_llseek for simple_attr
mac80211: disallow seeks in minstrel debug code
lirc: make chardev nonseekable
viotape: use noop_llseek
raw: use explicit llseek file operations
ibmasmfs: use generic_file_llseek
spufs: use llseek in all file operations
arm/omap: use generic_file_llseek in iommu_debug
lkdtm: use generic_file_llseek in debugfs
net/wireless: use generic_file_llseek in debugfs
drm: use noop_llseek
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
The semctl syscall has several code paths that lead to the leakage of
uninitialized kernel stack memory (namely the IPC_INFO, SEM_INFO,
IPC_STAT, and SEM_STAT commands) during the use of the older, obsolete
version of the semid_ds struct.
The copy_semid_to_user() function declares a semid_ds struct on the stack
and copies it back to the user without initializing or zeroing the
"sem_base", "sem_pending", "sem_pending_last", and "undo" pointers,
allowing the leakage of 16 bytes of kernel stack memory.
The code is still reachable on 32-bit systems - when calling semctl()
newer glibc's automatically OR the IPC command with the IPC_64 flag, but
invoking the syscall directly allows users to use the older versions of
the struct.
Signed-off-by: Dan Rosenberg <dan.j.rosenberg@gmail.com>
... and since the inodes are never hashed, we can use default ->drop_inode()
just fine.
The last change to improve the scalability moved the actual wake-up out of
the section that is protected by spin_lock(sma->sem_perm.lock).
This means that IN_WAKEUP can be in queue.status even when the spinlock is
acquired by the current task. Thus the same loop that is performed when
queue.status is read without the spinlock acquired must be performed when
the spinlock is acquired.
Thanks to kamezawa.hiroyu@jp.fujitsu.com for noticing lack of the memory
barrier.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=16255
[akpm@linux-foundation.org: clean up kerneldoc, checkpatch warning and whitespace]
Reported-by: Luca Tettamanti <kronos.it@gmail.com>
Tested-by: Luca Tettamanti <kronos.it@gmail.com>
Reported-by: Christoph Lameter <cl@linux-foundation.org>
Cc: Maciej Rutecki <maciej.rutecki@gmail.com>
It never hashes them anyway and does final iput() immediately
afterwards. With ->drop_inode() being generic_delete_inode()...
Use ERR_CAST(x) rather than ERR_PTR(PTR_ERR(x)). The former makes more
clear what is the purpose of the operation, which otherwise looks like a
no-op.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
type T;
T x;
identifier f;
T f (...) { <+...
- ERR_PTR(PTR_ERR(x))
+ x
expression x;
+ ERR_CAST(x)
// </smpl>
ipc/sem.c begins with a 15 year old description about bugs in the initial
implementation in Linux-1.0. The patch replaces that with a top level
description of the current code.
A TODO could be derived from this text:
The opengroup man page for semop() does not mandate FIFO. Thus there is
no need for a semaphore array list of pending operations.
If
- this list is removed
- the per-semaphore array spinlock is removed (possible if there is no
list to protect)
- sem_otime is moved into the semaphores and calculated on demand during
semctl()
then the array would be read-mostly - which would significantly improve
scaling for applications that use semaphore arrays with lots of entries.
The price would be expensive semctl() calls:
for(i=0;i<sma->sem_nsems;i++) spin_lock(sma->sem_lock);
<do stuff>
for(i=0;i<sma->sem_nsems;i++) spin_unlock(sma->sem_lock);
I'm not sure if the complexity is worth the effort, thus here is the
documentation of the current behavior first.
Cc: Chris Mason <chris.mason@oracle.com>
Cc: Zach Brown <zach.brown@oracle.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
Cc: Nick Piggin <npiggin@suse.de>
The wake-up part of semtimedop() consists out of two steps:
- the right tasks must be identified.
- they must be woken up.
Right now, both steps run while the array spinlock is held. This patch
reorders the code and moves the actual wake_up_process() behind the point
where the spinlock is dropped.
The code also moves setting sem->sem_otime to one place: It does not make
sense to set the last modify time multiple times.
[akpm@linux-foundation.org: repair kerneldoc]
[akpm@linux-foundation.org: fix uninitialised retval]
The following series of patches tries to fix the spinlock contention
reported by Chris Mason - his benchmark exposes problems of the current
code:
- In the worst case, the algorithm used by update_queue() is O(N^2).
Bulk wake-up calls can enter this worst case. The patch series fix
that.
Note that the benchmark app doesn't expose the problem, it just should
be fixed: Real world apps might do the wake-ups in another order than
perfect FIFO.
- The part of the code that runs within the semaphore array spinlock is
significantly larger than necessary.
The patch series fixes that. This change is responsible for the main
improvement.
- The cacheline with the spinlock is also used for a variable that is
read in the hot path (sem_base) and for a variable that is unnecessarily
written to multiple times (sem_otime). The last step of the series
cacheline-aligns the spinlock.
This patch:
The SysV semaphore code allows to perform multiple operations on all
semaphores in the array as atomic operations. After a modification,
update_queue() checks which of the waiting tasks can complete.
The algorithm that is used to identify the tasks is O(N^2) in the worst
case. For some cases, it is simple to avoid the O(N^2).
The patch adds a detection logic for some cases, especially for the case
of an array where all sleeping tasks are single sembuf operations and a
multi-sembuf operation is used to wake up multiple tasks.
A big database application uses that approach.
The patch fixes wakeup due to semctl(,,SETALL,) - the initial version of
the patch breaks that.
[akpm@linux-foundation.org: make do_smart_update() static]
SHRT_MAX and SHRT_MIN
- C99 knows about USHRT_MAX/SHRT_MAX/SHRT_MIN, not
USHORT_MAX/SHORT_MAX/SHORT_MIN.
- Make SHRT_MIN of type s16, not int, for consistency.
[akpm@linux-foundation.org: fix drivers/dma/timb_dma.c]
[akpm@linux-foundation.org: fix security/keys/keyring.c]
Acked-by: WANG Cong <xiyou.wangcong@gmail.com>
* 'timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
clocksource: Add clocksource_register_hz/khz interface
posix-cpu-timers: Optimize run_posix_cpu_timers()
time: Remove xtime_cache
mqueue: Convert message queue timeout to use hrtimers
hrtimers: Provide schedule_hrtimeout for CLOCK_REALTIME
timers: Introduce the concept of timer slack for legacy timers
ntp: Remove tickadj
ntp: Make time_adjust static
time: Add xtime, wall_to_monotonic to feature-removal-schedule
timer: Try to survive timer callback preempt_count leak
timer: Split out timer function call
timer: Print function name for timer callbacks modifying preemption count
time: Clean up warp_clock()
cpu-timers: Avoid iterating over all threads in fastpath_timer_check()
cpu-timers: Change SIGEV_NONE timer implementation
cpu-timers: Return correct previous timer reload value
cpu-timers: Cleanup arm_timer()
cpu-timers: Simplify RLIMIT_CPU handling
In case of aborting because we reach the maximum amount of memory which
can be allocated to message queues per user (RLIMIT_MSGQUEUE), we would
try to free the message area twice when bailing out: first by the error
handling code itself, and then later when cleaning up the inode through
delete_inode().
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Reason: Further posix_cpu_timer patches depend on mainline changes
The message queue functions mq_timedsend() and mq_timedreceive()
have not yet been converted to use the hrtimer interface.
This patch replaces the call to schedule_timeout() by a call to
schedule_hrtimeout() and transforms the expiration time from
timespec to ktime as required.
[ tglx: Fixed whitespace wreckage ]
Signed-off-by: Carsten Emde <C.Emde@osadl.org>
Tested-by: Pradyumna Sampath <pradysam@gmail.com>
Cc: Arjan van de Veen <arjan@infradead.org>
LKML-Reference: <20100402204331.715783034@osadl.org>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
I chased down a fail on ppc64 on 2.6.34-rc2 where an application that
uses shared memory was getting a SEGV.
Commit baed7fc9b580bd3fb8252ff1d9b36eaf1f86b670 ("Add generic sys_ipc
wrapper") changed the second argument from an unsigned long to an int.
When we call shmget the system call wrappers for sys_ipc will sign
extend second (ie the size) which truncates it. It took a while to
track down because the call succeeds and strace shows the untruncated
The patch below changes second from an int to an unsigned long which
fixes shmget on ppc64 (and I assume s390, sparc64 and mips64).
I assume the function prototypes for the other IPC methods would cause us
to sign or zero extend second where appropriate (avoiding any security
issues). Come to think of it, the syscall wrappers for each method should do
that for us as well.
Make sure compiler won't do weird things with limits. E.g. fetching them
twice may return 2 different values after writable limits are implemented.
I.e. either use rlimit helpers added in
3e10e716abf3c71bdb5d86b8f507f9e72236c9cd ("resource: add helpers for
fetching rlimits") or ACCESS_ONCE if not applicable.
Add a generic implementation of the ipc demultiplexer syscall. Except for
s390 and sparc64 all implementations of the sys_ipc are nearly identical.
There are slight differences in the types of the parameters, where mips
and powerpc as the only 64-bit architectures with sys_ipc use unsigned
long for the "third" argument as it gets casted to a pointer later, while
it traditionally is an "int" like most other paramters. frv goes even
further and uses unsigned long for all parameters execept for "ptr" which
is a pointer type everywhere. The change from int to unsigned long for
"third" and back to "int" for the others on frv should be fine due to the
in-register calling conventions for syscalls (we already had a similar
issue with the generic sys_ptrace), but I'd prefer to have the arch
maintainers looks over this in details.
Except for that h8300, m68k and m68knommu lack an impplementation of the
semtimedop sub call which this patch adds, and various architectures have
gets used - at least on i386 it seems superflous as the compat code on
x86-64 and ia64 doesn't even bother to implement it.
[akpm@linux-foundation.org: add sys_ipc to sys_ni.c]
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Reviewed-by: H. Peter Anvin <hpa@zytor.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Andreas Schwab <schwab@linux-m68k.org>
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Acked-by: Kyle McMartin <kyle@mcmartin.ca>
... postponing assignments until they're needed. Doesn't change code size.
It reduces code size:
9925 72 16 10013 271d ipc/mqueue-BEFORE.o
9885 72 16 9973 26f5 ipc/mqueue-AFTER.o
Code size reduction:
9941 72 16 10029 272d ipc/mqueue-BEFORE.o
9925 72 16 10013 271d ipc/mqueue-AFTER.o
... and abort earlier if we couldn't allocate the message pointers array,
avoiding the u->mq_bytes accounting logic.
9949 72 16 10037 2735 ipc/mqueue-BEFORE.o
9941 72 16 10029 272d ipc/mqueue-AFTER.o
We leak fd on lookup_one_len() failure
Commit c4caa778157dbbf04116f0ac2111e389b5cd7a29 ("file
->get_unmapped_area() shouldn't duplicate work of get_unmapped_area()")
broke SYSV SHM for NOMMU by taking away the pointer to
shm_get_unmapped_area() from shm_file_operations.
Put it back conditionally on CONFIG_MMU=n.
file->f_ops->get_unmapped_area() is used to find out the base address for a
mapping of a mappable chardev device or mappable memory-based file (such as a
ramfs file). It needs to be called prior to file->f_ops->mmap() being called.
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Cc: Greg Ungerer <gerg@snapgear.com>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (38 commits)
direct I/O fallback sync simplification
ocfs: stop using do_sync_mapping_range
cleanup blockdev_direct_IO locking
make generic_acl slightly more generic
sanitize xattr handler prototypes
libfs: move EXPORT_SYMBOL for d_alloc_name
vfs: force reval of target when following LAST_BIND symlinks (try #7)
ima: limit imbalance msg
Untangling ima mess, part 3: kill dead code in ima
Untangling ima mess, part 2: deal with counters
Untangling ima mess, part 1: alloc_file()
O_TRUNC open shouldn't fail after file truncation
ima: call ima_inode_free ima_inode_free
IMA: clean up the IMA counts updating code
ima: only insert at inode creation time
ima: valid return code from ima_inode_alloc
fs: move get_empty_filp() deffinition to internal.h
Sanitize exec_permission_lite()
Kill cached_lookup() and real_lookup()
Kill path_lookup_open()
Trivial conflicts in fs/direct-io.c
* do ima_get_count() in __dentry_open()
* stop doing that in followups
* move ima_path_check() to right after nameidata_to_filp()
* don't bump counters on it
There are 2 groups of alloc_file() callers:
* ones that are followed by ima_counts_get
* ones giving non-regular files
So let's pull that ima_counts_get() into alloc_file();
it's a no-op in case of non-regular files.
... and have the caller grab both mnt and dentry; kill
leak in infiniband, while we are at it.
This line is unreachable, remove it.
[akpm@linux-foundation.org: remove unneeded initialisation of `err']
Signed-off-by: WANG Cong <amwang@redhat.com>
If multiple simple decrements on the same semaphore are pending, then the
current code scans all decrement operations, even if the semaphore value
is already 0.
The patch optimizes that: if the semaphore value is 0, then there is no
need to scan the q->alter entries.
Note that this is a common case: It happens if 100 decrements by one are
pending and now an increment by one increases the semaphore value from 0
to 1. Without this patch, all 100 entries are scanned. With the patch,
only one entry is scanned, then woken up. Then the new rule triggers and
the scanning is aborted, without looking at the remaining 99 tasks.
With this patch, single sop increment/decrement by 1 are now O(1).
(same as with Nick's patch)
Cc: Pierre Peiffer <peifferp@gmail.com>
sysv sem has the concept of semaphore arrays that consist out of multiple
semaphores. Atomic operations that affect multiple semaphores are
supported.
The patch optimizes single semaphore operation calls that affect only one
semaphore: It's not necessary to scan all pending operations, it is
sufficient to scan the per-semaphore list.
The idea is from Nick Piggin version of an ipc sem improvement, the
implementation is different: The code tries to keep as much common code as
possible.
As the result, the patch is simpler, but optimizes fewer cases.
Based on Nick's findings:
supported.
The patch is the first step for optimizing simple, single semaphore
operations: In addition to the global list of all pending operations, a
2nd, per-semaphore list with the simple operations is added.
Note: this patch does not make sense by itself, the new list is used
nowhere.
