In older kernels (before v3.10) ipc_rcu_hdr->refcount was non-atomic int.
There was possuble double-free bug: do_msgsnd() calls ipc_rcu_putref() under
msq->q_perm->lock and RCU, while freequeue() calls it while it holds only
'rw_mutex', so there is no sinchronization between them. Two function
decrements '2' non-atomically, they both can get '0' as result.
do_msgsnd() freequeue()
msq = msg_lock_check(ns, msqid);
ipc_rcu_getref(msq);
msg_unlock(msq);
schedule();
(caller locks spinlock)
expunge_all(msq, -EIDRM);
ss_wakeup(&msq->q_senders, 1);
msg_rmid(ns, msq);
msg_unlock(msq);
ipc_lock_by_ptr(&msq->q_perm);
ipc_rcu_putref(msq); ipc_rcu_putref(msq);
< both may get get --(...)->refcount == 0 >
This patch locks ipc_lock and RCU around ipc_rcu_putref in freequeue.
( RCU protects memory for spin_unlock() )
Similar bugs might be in other users of ipc_rcu_putref().
In the mainline this has been fixed in v3.10 indirectly in commmit
6062a8dc0517bce23e3c2f7d2fea5e22411269a3
("ipc,sem: fine grained locking for semtimedop") by Rik van Riel.
That commit optimized locking and converted refcount into atomic.
I'm not sure that anybody should care about this bug: it's very-very unlikely
and no longer exists in actual mainline. I've found this just by looking into
the code, probably this never happens in real life.
Signed-off-by: Konstantin Khlebnikov <k.khlebnikov@samsung.com>
commit 4e9b45a19241354daec281d7a785739829b52359 upstream.
On 64 bit systems the test for negative message sizes is bogus as the
size, which may be positive when evaluated as a long, will get truncated
to an int when passed to load_msg(). So a long might very well contain a
positive value but when truncated to an int it would become negative.
That in combination with a small negative value of msg_ctlmax (which will
be promoted to an unsigned type for the comparison against msgsz, making
it a big positive value and therefore make it pass the check) will lead to
two problems: 1/ The kmalloc() call in alloc_msg() will allocate a too
small buffer as the addition of alen is effectively a subtraction. 2/ The
copy_from_user() call in load_msg() will first overflow the buffer with
userland data and then, when the userland access generates an access
violation, the fixup handler copy_user_handle_tail() will try to fill the
remainder with zeros -- roughly 4GB. That almost instantly results in a
system crash or reset.
,-[ Reproducer (needs to be run as root) ]--
| #include <sys/stat.h>
| #include <sys/msg.h>
| #include <unistd.h>
| #include <fcntl.h>
| int main(void) {
| long msg = 1;
| int fd;
| fd = open("/proc/sys/kernel/msgmax", O_WRONLY);
| write(fd, "-1", 2);
| close(fd);
| msgsnd(0, &msg, 0xfffffff0, IPC_NOWAIT);
| return 0;
Fix the issue by preventing msgsz from getting truncated by consistently
using size_t for the message length. This way the size checks in
do_msgsnd() could still be passed with a negative value for msg_ctlmax but
we would fail on the buffer allocation in that case and error out.
Also change the type of m_ts from int to size_t to avoid similar nastiness
in other code paths -- it is used in similar constructs, i.e. signed vs.
unsigned checks. It should never become negative under normal
circumstances, though.
Setting msg_ctlmax to a negative value is an odd configuration and should
be prevented. As that might break existing userland, it will be handled
in a separate commit so it could easily be reverted and reworked without
reintroducing the above described bug.
Hardening mechanisms for user copy operations would have catched that bug
early -- e.g. checking slab object sizes on user copy operations as the
usercopy feature of the PaX patch does. Or, for that matter, detect the
long vs. int sign change due to truncation, as the size overflow plugin
of the very same patch does.
[akpm@linux-foundation.org: fix i386 min() warnings]
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: Pax Team <pageexec@freemail.hu>
Cc: Davidlohr Bueso <davidlohr@hp.com>
Cc: Brad Spengler <spender@grsecurity.net>
Cc: Manfred Spraul <manfred@colorfullife.com>
[bwh: Backported to 3.2:
- Adjust context
- Drop changes to alloc_msg() and copy_msg(), which don't exist]
commit d69f3bad4675ac519d41ca2b11e1c00ca115cecd upstream.
Trying to run an application which was trying to put data into half of
memory using shmget(), we found that having a shmall value below 8EiB-8TiB
would prevent us from using anything more than 8TiB. By setting
kernel.shmall greater than 8EiB-8TiB would make the job work.
In the newseg() function, ns->shm_tot which, at 8TiB is INT_MAX.
ipc/shm.c:
458 static int newseg(struct ipc_namespace *ns, struct ipc_params *params)
459 {
465 int numpages = (size + PAGE_SIZE -1) >> PAGE_SHIFT;
474 if (ns->shm_tot + numpages > ns->shm_ctlall)
475 return -ENOSPC;
[akpm@linux-foundation.org: make ipc/shm.c:newseg()'s numpages size_t, not int]
Signed-off-by: Robin Holt <holt@sgi.com>
Reported-by: Alex Thorlton <athorlton@sgi.com>
commit 245132643e1cfcd145bbc86a716c1818371fcb93 upstream.
Commit cc39c6a9bbde ("mm: account skipped entries to avoid looping in
find_get_pages") correctly fixed an infinite loop; but left a problem
that find_get_pages() on shmem would return 0 (appearing to callers to
mean end of tree) when it meets a run of nr_pages swap entries.
The only uses of find_get_pages() on shmem are via pagevec_lookup(),
called from invalidate_mapping_pages(), and from shmctl SHM_UNLOCK's
scan_mapping_unevictable_pages(). The first is already commented, and
not worth worrying about; but the second can leave pages on the
Unevictable list after an unusual sequence of swapping and locking.
Fix that by using shmem_find_get_pages_and_swap() (then ignoring the
swap) instead of pagevec_lookup().
But I don't want to contaminate vmscan.c with shmem internals, nor
shmem.c with LRU locking. So move scan_mapping_unevictable_pages() into
shmem.c, renaming it shmem_unlock_mapping(); and rename
check_move_unevictable_page() to check_move_unevictable_pages(), looping
down an array of pages, oftentimes under the same lock.
Leave out the "rotate unevictable list" block: that's a leftover from
when this was used for /proc/sys/vm/scan_unevictable_pages, whose flawed
handling involved looking at pages at tail of LRU.
Was there significance to the sequence first ClearPageUnevictable, then
test page_evictable, then SetPageUnevictable here? I think not, we're
under LRU lock, and have no barriers between those.
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Cc: Minchan Kim <minchan.kim@gmail.com>
Cc: Shaohua Li <shaohua.li@intel.com>
Cc: Michel Lespinasse <walken@google.com>
commit 85046579bde15e532983438f86b36856e358f417 upstream.
scan_mapping_unevictable_pages() is used to make SysV SHM_LOCKed pages
evictable again once the shared memory is unlocked. It does this with
pagevec_lookup()s across the whole object (which might occupy most of
memory), and takes 300ms to unlock 7GB here. A cond_resched() every
PAGEVEC_SIZE pages would be good.
However, KOSAKI-san points out that this is called under shmem.c's
info->lock, and it's also under shm.c's shm_lock(), both spinlocks.
There is no strong reason for that: we need to take these pages off the
unevictable list soonish, but those locks are not required for it.
So move the call to scan_mapping_unevictable_pages() from shmem.c's
unlock handling up to shm.c's unlock handling. Remove the recently
added barrier, not needed now we have spin_unlock() before the scan.
Use get_file(), with subsequent fput(), to make sure we have a reference
to mapping throughout scan_mapping_unevictable_pages(): that's something
that was previously guaranteed by the shm_lock().
Remove shmctl's lru_add_drain_all(): we don't fault in pages at SHM_LOCK
time, and we lazily discover them to be Unevictable later, so it serves
no purpose for SHM_LOCK; and serves no purpose for SHM_UNLOCK, since
pages still on pagevec are not marked Unevictable.
The original code avoided redundant rescans by checking VM_LOCKED flag
at its level: now avoid them by checking shp's SHM_LOCKED.
The original code called scan_mapping_unevictable_pages() on a locked
area at shm_destroy() time: perhaps we once had accounting cross-checks
which required that, but not now, so skip the overhead and just let
inode eviction deal with them.
Put check_move_unevictable_page() and scan_mapping_unevictable_pages()
under CONFIG_SHMEM (with stub for the TINY case when ramfs is used),
more as comment than to save space; comment them used for SHM_UNLOCK.
include/linux/sem.h contains several structures that are only used within
ipc/sem.c.
The patch moves them into ipc/sem.c - there is no need to expose the
structures to the whole kernel.
No functional changes, only whitespace cleanups and 80-char per line
fixes.
Signed-off-by: Manfred Spraul <manfred@colorfullife.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
semtimedop() does not handle spurious wakeups, it returns -EINTR to user
space. Most other schedule() users would just loop and not return to user
space. The patch adds such a loop to semtimedop()
Reported-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
sys_semtimedop() may return -EIDRM although the semaphore operation
completed successfully:
thread 1: thread 2:
semtimedop(), sleeps
semop():
* acquires sem_lock()
semtimedop() woken up due to timeout
sem_lock() loops
* notices that thread 2 could be completed.
* performs the operations that thread 2 is sleeping on.
* marks the semaphore operation as IN_WAKEUP
* drops sem_lock(), does wakeup, sets return code to 0
* thread delayed due to interrupt, whatever
* returns to user space
* thread still delayed
semctl(IPC_RMID)
* ipc_rmid(), ipcp->deleted=1
* drops sem_lock()
* thread finally continues - but seem_lock()
now fails due to ipcp->deleted == 1
* returns -EIDRM instead of 0
The fix is trivial: Always use the return code in queue.status.
In real world, the race probably doesn't matter:
If the semaphore array is destroyed, the app is probably not interested
if the last operation succeeded or was already cancelled.
Fix the wrong use of schedule_hrtimeout_range_clock() in wq_sleep(),
although it is harmless for the syscall mq_timed* now. It was introduced
by 9ca7d8e ("mqueue: Convert message queue timeout to use hrtimers").
Signed-off-by: Wanlong Gao <gaowanlong@cn.fujitsu.com>
Cc: Carsten Emde <C.Emde@osadl.org>
This isn't really critical any more, since other patches (commit
298507d4d2cf: "shm: optimize exit_shm()") have caused us to not actually
need to touch the rw_mutex unless there are actual shm segments
associated with the namespace, but we really should do tne shm_init_ns()
earlier than we do now.
This, together with commit 288d5abec831 ("Boot up with usermodehelper
disabled") will mean that we really do initialize the initial ipc
namespace data structure before we run any tasks.
Tested-by: Marc Zyngier <marc.zyngier@arm.com>
We may optimistically check .in_use == 0 without holding the rw_mutex:
it's the common case, and if it's zero, there certainly won't be any
segments associated with us.
After taking the lock, the idr_for_each() will do the right thing, so we
could now drop the re-check inside the lock without any real cost. But
it won't hurt.
Signed-off-by: Vasiliy Kulikov <segoon@openwall.com>
Commit 4c677e2eefdb ("shm: optimize locking and ipc_namespace getting")
introduced a copy-paste bug. Due to the bug cycle optimizations were
disabled.
shm_lock() does a lookup of shm segment in shm_ids(ns).ipcs_idr, which
is redundant as we already know shmid_kernel address. An actual lock is
also not required for reads until we really want to destroy the segment.
exit_shm() and shm_destroy_orphaned() may avoid the loop by checking
whether there is at least one segment in current ipc_namespace.
The check of nsproxy and ipc_ns against NULL is redundant as exit_shm()
is called from do_exit() before the call to exit_notify(), so the
dereferencing current->nsproxy->ipc_ns is guaranteed to be safe.
Reported-by: Oleg Nesterov <oleg@redhat.com>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
shm_try_destroy_orphaned() and shm_try_destroy_current() didn't handle
the case of separate PID namespaces, but a single IPC namespace. If
there are tasks with the same PID values using the same shmem object,
the wrong destroy decision could be reached.
On shm segment creation store the pointer to the creator task in
shmid_kernel->shm_creator field and zero it on task exit. Then
use the ->shm_creator insread of shm_cprid in both functions. As
shmid_kernel object is already locked at this stage, no additional
locking is needed.
Add support for the shm_rmid_forced sysctl. If set to 1, all shared
memory objects in current ipc namespace will be automatically forced to
use IPC_RMID.
The POSIX way of handling shmem allows one to create shm objects and
call shmdt(), leaving shm object associated with no process, thus
consuming memory not counted via rlimits.
With shm_rmid_forced=1 the shared memory object is counted at least for
one process, so OOM killer may effectively kill the fat process holding
the shared memory.
It obviously breaks POSIX - some programs relying on the feature would
stop working. So set shm_rmid_forced=1 only if you're sure nobody uses
"orphaned" memory. Use shm_rmid_forced=0 by default for compatability
reasons.
The feature was previously impemented in -ow as a configure option.
[akpm@linux-foundation.org: fix documentation, per Randy]
[akpm@linux-foundation.org: fix warning]
[akpm@linux-foundation.org: readability/conventionality tweaks]
[akpm@linux-foundation.org: fix shm_rmid_forced/shm_forced_rmid confusion, use standard comment layout]
Cc: Randy Dunlap <rdunlap@xenotime.net>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: "Serge E. Hallyn" <serge.hallyn@canonical.com>
Cc: Daniel Lezcano <daniel.lezcano@free.fr>
Cc: Tejun Heo <tj@kernel.org>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Solar Designer <solar@openwall.com>
We return ENOMEM from mqueue_get_inode even when we have enough memory.
Namely in case the system rlimit of mqueue was reached. This error
propagates to mq_queue and user sees the error unexpectedly. So fix
this up to properly return EMFILE as described in the manpage:
EMFILE The process already has the maximum number of files and
message queues open.
instead of:
ENOMEM Insufficient memory.
With the previous patch we just switch to ERR_PTR/PTR_ERR/IS_ERR error
handling here.
If new_inode fails to allocate an inode we need only to return with
NULL. But now we test the opposite and have all the work in a nested
block. So do the opposite to save one indentation level (and remove
unnecessary line breaks).
This is only a preparation/cleanup for the next patch where we fix up
return values from mqueue_get_inode.
If a semaphore array is removed and in parallel a sleeping task is woken
up (signal or timeout, does not matter), then the woken up task does not
wait until wake_up_sem_queue_do() is completed. This will cause crashes,
because wake_up_sem_queue_do() will read from a stale pointer.
The fix is simple: Regardless of anything, always call get_queue_result().
This function waits until wake_up_sem_queue_do() has finished it's task.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=27142
Reported-by: Yuriy Yevtukhov <yuriy@ucoz.com>
Reported-by: Harald Laabs <kernel@dasr.de>
Cc: <stable@kernel.org> [2.6.35+]
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (107 commits)
vfs: use ERR_CAST for err-ptr tossing in lookup_instantiate_filp
isofs: Remove global fs lock
jffs2: fix IN_DELETE_SELF on overwriting rename() killing a directory
fix IN_DELETE_SELF on overwriting rename() on ramfs et.al.
mm/truncate.c: fix build for CONFIG_BLOCK not enabled
fs:update the NOTE of the file_operations structure
Remove dead code in dget_parent()
AFS: Fix silly characters in a comment
switch d_add_ci() to d_splice_alias() in "found negative" case as well
simplify gfs2_lookup()
jfs_lookup(): don't bother with . or ..
get rid of useless dget_parent() in btrfs rename() and link()
get rid of useless dget_parent() in fs/btrfs/ioctl.c
fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlers
drivers: fix up various ->llseek() implementations
fs: handle SEEK_HOLE/SEEK_DATA properly in all fs's that define their own llseek
Ext4: handle SEEK_HOLE/SEEK_DATA generically
Btrfs: implement our own ->llseek
fs: add SEEK_HOLE and SEEK_DATA flags
reiserfs: make reiserfs default to barrier=flush
Fix up trivial conflicts in fs/xfs/linux-2.6/xfs_super.c due to the new
shrinker callout for the inode cache, that clashed with the xfs code to
start the periodic workers later.
Btrfs needs to be able to control how filemap_write_and_wait_range() is called
in fsync to make it less of a painful operation, so push down taking i_mutex and
the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some
file systems can drop taking the i_mutex altogether it seems, like ext3 and
ocfs2. For correctness sake I just pushed everything down in all cases to make
sure that we keep the current behavior the same for everybody, and then each
individual fs maintainer can make up their mind about what to do from there.
Thanks,
Acked-by: Jan Kara <jack@suse.cz>
Signed-off-by: Josef Bacik <josef@redhat.com>
The rcu callback ipc_immediate_free() just calls a kfree(),
so we use kfree_rcu() instead of the call_rcu(ipc_immediate_free).
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
The rcu callback free_un() just calls a kfree(),
so we use kfree_rcu() instead of the call_rcu(free_un).
The type of vma->vm_flags is 'unsigned long'. Neither 'int' nor
'unsigned int'. This patch fixes such misuse.
[ Changed to use a typedef - we'll extend it to cover more cases
later, since there has been discussion about making it a 64-bit
type.. - Linus ]
Acked-by: Daniel Lezcano <daniel.lezcano@free.fr>
Fix ipc/util.c kernel-doc warnings:
Warning(ipc/util.c:336): No description found for parameter 'ns'
Warning(ipc/util.c:620): No description found for parameter 'ns'
Warning(ipc/util.c:790): No description found for parameter 'ns'
Reviewed-by: Jesper Juhl <jj@chaosbits.net>
commit b515498 ("userns: add a user namespace owner of ipc ns") added a
user namespace owner of ipc ns, but it also introduced a use after free in
free_ipc_ns().
Signed-off-by: Xiaotian Feng <dfeng@redhat.com>
Acked-by: "Serge E. Hallyn" <serge.hallyn@canonical.com>
CAP_IPC_OWNER and CAP_IPC_LOCK can be checked against current_user_ns(),
because the resource comes from current's own ipc namespace.
setuid/setgid are to uids in own namespace, so again checks can be against
current_user_ns().
Changelog:
Jan 11: Use task_ns_capable() in place of sched_capable().
Jan 11: Use nsown_capable() as suggested by Bastian Blank.
Jan 11: Clarify (hopefully) some logic in futex and sched.c
Feb 15: use ns_capable for ipc, not nsown_capable
Feb 23: let copy_ipcs handle setting ipc_ns->user_ns
Feb 23: pass ns down rather than taking it from current
Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com>
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
Changelog:
Feb 15: Don't set new ipc->user_ns if we didn't create a new
ipc_ns.
Feb 23: Move extern declaration to ipc_namespace.h, and group
fwd declarations at top.
RCU free the struct inode. This will allow:
- Subsequent store-free path walking patch. The inode must be consulted for
permissions when walking, so an RCU inode reference is a must.
- sb_inode_list_lock to be moved inside i_lock because sb list walkers who want
to take i_lock no longer need to take sb_inode_list_lock to walk the list in
the first place. This will simplify and optimize locking.
- Could remove some nested trylock loops in dcache code
- Could potentially simplify things a bit in VM land. Do not need to take the
page lock to follow page->mapping.
The downsides of this is the performance cost of using RCU. In a simple
creat/unlink microbenchmark, performance drops by about 10% due to inability to
reuse cache-hot slab objects. As iterations increase and RCU freeing starts
kicking over, this increases to about 20%.
In cases where inode lifetimes are longer (ie. many inodes may be allocated
during the average life span of a single inode), a lot of this cache reuse is
not applicable, so the regression caused by this patch is smaller.
The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU,
however this adds some complexity to list walking and store-free path walking,
so I prefer to implement this at a later date, if it is shown to be a win in
real situations. I haven't found a regression in any non-micro benchmark so I
doubt it will be a problem.
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
The shmid_ds structure is copied to userland with shm_unused{,2,3}
fields unitialized. It leads to leaking of contents of kernel stack
memory.
Signed-off-by: Vasiliy Kulikov <segooon@gmail.com>
Acked-by: Al Viro <viro@ZenIV.linux.org.uk>
Cc: stable@kernel.org
This takes care of leaking uninitialized kernel stack memory to
userspace from non-zeroed fields in structs in compat ipc functions.
Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com>
The kernel currently provides no functionality to analyze the RSS and swap
space usage of each individual sysvipc shared memory segment.
This patch adds this info for each existing shm segment by extending the
output of /proc/sysvipc/shm by two columns for RSS and swap.
Since shmctl(SHM_INFO) already provides a similiar calculation (it
currently sums up all RSS/swap info for all segments), I did split out a
static function which is now used by the /proc/sysvipc/shm output and
shmctl(SHM_INFO).
SAP products (esp. the SAP Netweaver ABAP Kernel) uses lots of big shared
memory segments (we often have Linux systems with >= 16GB shm usage).
Sometimes we get customer reports about "slow" system responses and while
looking into their configurations we often find massive swapping activity
on the system. With this patch it's now easy to see from the command line
if and which shm segments gets swapped out (and how much) and can more
easily give recommendations for system tuning. Without the patch it's
currently not possible to do such shm analysis at all.
Also...
Add some spaces in front of the "size" field for 64bit kernels to get the
columns correct if you cat the contents of the file. In
sysvipc_shm_proc_show() the kernel prints the size value in "SPEC_SIZE"
format, which is defined like this:
#if BITS_PER_LONG <= 32
#define SIZE_SPEC "%10lu"
#else
#define SIZE_SPEC "%21lu"
#endif
So, if the header is not adjusted, the columns are not correctly aligned.
I actually tested this on 32- and 64-bit and it seems correct now.
Signed-off-by: Helge Deller <deller@gmx.de>
Instead of always assigning an increasing inode number in new_inode
move the call to assign it into those callers that actually need it.
For now callers that need it is estimated conservatively, that is
the call is added to all filesystems that do not assign an i_ino
by themselves. For a few more filesystems we can avoid assigning
any inode number given that they aren't user visible, and for others
it could be done lazily when an inode number is actually needed,
but that's left for later patches.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Clones an existing reference to inode; caller must already hold one.
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl:
vfs: make no_llseek the default
vfs: don't use BKL in default_llseek
llseek: automatically add .llseek fop
libfs: use generic_file_llseek for simple_attr
mac80211: disallow seeks in minstrel debug code
lirc: make chardev nonseekable
viotape: use noop_llseek
raw: use explicit llseek file operations
ibmasmfs: use generic_file_llseek
spufs: use llseek in all file operations
arm/omap: use generic_file_llseek in iommu_debug
lkdtm: use generic_file_llseek in debugfs
net/wireless: use generic_file_llseek in debugfs
drm: use noop_llseek
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
The semctl syscall has several code paths that lead to the leakage of
uninitialized kernel stack memory (namely the IPC_INFO, SEM_INFO,
IPC_STAT, and SEM_STAT commands) during the use of the older, obsolete
version of the semid_ds struct.
The copy_semid_to_user() function declares a semid_ds struct on the stack
and copies it back to the user without initializing or zeroing the
"sem_base", "sem_pending", "sem_pending_last", and "undo" pointers,
allowing the leakage of 16 bytes of kernel stack memory.
The code is still reachable on 32-bit systems - when calling semctl()
newer glibc's automatically OR the IPC command with the IPC_64 flag, but
invoking the syscall directly allows users to use the older versions of
the struct.
Signed-off-by: Dan Rosenberg <dan.j.rosenberg@gmail.com>
... and since the inodes are never hashed, we can use default ->drop_inode()
just fine.
The last change to improve the scalability moved the actual wake-up out of
the section that is protected by spin_lock(sma->sem_perm.lock).
This means that IN_WAKEUP can be in queue.status even when the spinlock is
acquired by the current task. Thus the same loop that is performed when
queue.status is read without the spinlock acquired must be performed when
the spinlock is acquired.
Thanks to kamezawa.hiroyu@jp.fujitsu.com for noticing lack of the memory
barrier.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=16255
[akpm@linux-foundation.org: clean up kerneldoc, checkpatch warning and whitespace]
Reported-by: Luca Tettamanti <kronos.it@gmail.com>
Tested-by: Luca Tettamanti <kronos.it@gmail.com>
Reported-by: Christoph Lameter <cl@linux-foundation.org>
Cc: Maciej Rutecki <maciej.rutecki@gmail.com>
It never hashes them anyway and does final iput() immediately
afterwards. With ->drop_inode() being generic_delete_inode()...
Use ERR_CAST(x) rather than ERR_PTR(PTR_ERR(x)). The former makes more
clear what is the purpose of the operation, which otherwise looks like a
no-op.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
type T;
T x;
identifier f;
T f (...) { <+...
- ERR_PTR(PTR_ERR(x))
+ x
expression x;
+ ERR_CAST(x)
// </smpl>
ipc/sem.c begins with a 15 year old description about bugs in the initial
implementation in Linux-1.0. The patch replaces that with a top level
description of the current code.
A TODO could be derived from this text:
The opengroup man page for semop() does not mandate FIFO. Thus there is
no need for a semaphore array list of pending operations.
If
- this list is removed
- the per-semaphore array spinlock is removed (possible if there is no
list to protect)
- sem_otime is moved into the semaphores and calculated on demand during
semctl()
then the array would be read-mostly - which would significantly improve
scaling for applications that use semaphore arrays with lots of entries.
The price would be expensive semctl() calls:
for(i=0;i<sma->sem_nsems;i++) spin_lock(sma->sem_lock);
<do stuff>
for(i=0;i<sma->sem_nsems;i++) spin_unlock(sma->sem_lock);
I'm not sure if the complexity is worth the effort, thus here is the
documentation of the current behavior first.
Cc: Chris Mason <chris.mason@oracle.com>
Cc: Zach Brown <zach.brown@oracle.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
Cc: Nick Piggin <npiggin@suse.de>
The wake-up part of semtimedop() consists out of two steps:
- the right tasks must be identified.
- they must be woken up.
Right now, both steps run while the array spinlock is held. This patch
reorders the code and moves the actual wake_up_process() behind the point
where the spinlock is dropped.
The code also moves setting sem->sem_otime to one place: It does not make
sense to set the last modify time multiple times.
[akpm@linux-foundation.org: repair kerneldoc]
[akpm@linux-foundation.org: fix uninitialised retval]
The following series of patches tries to fix the spinlock contention
reported by Chris Mason - his benchmark exposes problems of the current
code:
- In the worst case, the algorithm used by update_queue() is O(N^2).
Bulk wake-up calls can enter this worst case. The patch series fix
that.
Note that the benchmark app doesn't expose the problem, it just should
be fixed: Real world apps might do the wake-ups in another order than
perfect FIFO.
- The part of the code that runs within the semaphore array spinlock is
significantly larger than necessary.
The patch series fixes that. This change is responsible for the main
improvement.
- The cacheline with the spinlock is also used for a variable that is
read in the hot path (sem_base) and for a variable that is unnecessarily
written to multiple times (sem_otime). The last step of the series
cacheline-aligns the spinlock.
This patch:
The SysV semaphore code allows to perform multiple operations on all
semaphores in the array as atomic operations. After a modification,
update_queue() checks which of the waiting tasks can complete.
The algorithm that is used to identify the tasks is O(N^2) in the worst
case. For some cases, it is simple to avoid the O(N^2).
The patch adds a detection logic for some cases, especially for the case
of an array where all sleeping tasks are single sembuf operations and a
multi-sembuf operation is used to wake up multiple tasks.
A big database application uses that approach.
The patch fixes wakeup due to semctl(,,SETALL,) - the initial version of
the patch breaks that.
[akpm@linux-foundation.org: make do_smart_update() static]
SHRT_MAX and SHRT_MIN
- C99 knows about USHRT_MAX/SHRT_MAX/SHRT_MIN, not
USHORT_MAX/SHORT_MAX/SHORT_MIN.
- Make SHRT_MIN of type s16, not int, for consistency.
[akpm@linux-foundation.org: fix drivers/dma/timb_dma.c]
[akpm@linux-foundation.org: fix security/keys/keyring.c]
Acked-by: WANG Cong <xiyou.wangcong@gmail.com>
* 'timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
clocksource: Add clocksource_register_hz/khz interface
posix-cpu-timers: Optimize run_posix_cpu_timers()
time: Remove xtime_cache
hrtimers: Provide schedule_hrtimeout for CLOCK_REALTIME
timers: Introduce the concept of timer slack for legacy timers
ntp: Remove tickadj
ntp: Make time_adjust static
time: Add xtime, wall_to_monotonic to feature-removal-schedule
timer: Try to survive timer callback preempt_count leak
timer: Split out timer function call
timer: Print function name for timer callbacks modifying preemption count
time: Clean up warp_clock()
cpu-timers: Avoid iterating over all threads in fastpath_timer_check()
cpu-timers: Change SIGEV_NONE timer implementation
cpu-timers: Return correct previous timer reload value
cpu-timers: Cleanup arm_timer()
cpu-timers: Simplify RLIMIT_CPU handling
