path: root/ipc
2013-05-13ipc: sysv shared memory limited to 8TiBRobin Holt
commit d69f3bad4675ac519d41ca2b11e1c00ca115cecd upstream. Trying to run an application which was trying to put data into half of memory using shmget(), we found that having a shmall value below 8EiB-8TiB would prevent us from using anything more than 8TiB. By setting kernel.shmall greater than 8EiB-8TiB would make the job work. In the newseg() function, ns->shm_tot which, at 8TiB is INT_MAX. ipc/shm.c: 458 static int newseg(struct ipc_namespace *ns, struct ipc_params *params) 459 { ... 465 int numpages = (size + PAGE_SIZE -1) >> PAGE_SHIFT; ... 474 if (ns->shm_tot + numpages > ns->shm_ctlall) 475 return -ENOSPC; [akpm@linux-foundation.org: make ipc/shm.c:newseg()'s numpages size_t, not int] Signed-off-by: Robin Holt <holt@sgi.com> Reported-by: Alex Thorlton <athorlton@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-01-25SHM_UNLOCK: fix Unevictable pages stranded after swapHugh Dickins
commit 245132643e1cfcd145bbc86a716c1818371fcb93 upstream. Commit cc39c6a9bbde ("mm: account skipped entries to avoid looping in find_get_pages") correctly fixed an infinite loop; but left a problem that find_get_pages() on shmem would return 0 (appearing to callers to mean end of tree) when it meets a run of nr_pages swap entries. The only uses of find_get_pages() on shmem are via pagevec_lookup(), called from invalidate_mapping_pages(), and from shmctl SHM_UNLOCK's scan_mapping_unevictable_pages(). The first is already commented, and not worth worrying about; but the second can leave pages on the Unevictable list after an unusual sequence of swapping and locking. Fix that by using shmem_find_get_pages_and_swap() (then ignoring the swap) instead of pagevec_lookup(). But I don't want to contaminate vmscan.c with shmem internals, nor shmem.c with LRU locking. So move scan_mapping_unevictable_pages() into shmem.c, renaming it shmem_unlock_mapping(); and rename check_move_unevictable_page() to check_move_unevictable_pages(), looping down an array of pages, oftentimes under the same lock. Leave out the "rotate unevictable list" block: that's a leftover from when this was used for /proc/sys/vm/scan_unevictable_pages, whose flawed handling involved looking at pages at tail of LRU. Was there significance to the sequence first ClearPageUnevictable, then test page_evictable, then SetPageUnevictable here? I think not, we're under LRU lock, and have no barriers between those. Signed-off-by: Hugh Dickins <hughd@google.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Shaohua Li <shaohua.li@intel.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michel Lespinasse <walken@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-25SHM_UNLOCK: fix long unpreemptible sectionHugh Dickins
commit 85046579bde15e532983438f86b36856e358f417 upstream. scan_mapping_unevictable_pages() is used to make SysV SHM_LOCKed pages evictable again once the shared memory is unlocked. It does this with pagevec_lookup()s across the whole object (which might occupy most of memory), and takes 300ms to unlock 7GB here. A cond_resched() every PAGEVEC_SIZE pages would be good. However, KOSAKI-san points out that this is called under shmem.c's info->lock, and it's also under shm.c's shm_lock(), both spinlocks. There is no strong reason for that: we need to take these pages off the unevictable list soonish, but those locks are not required for it. So move the call to scan_mapping_unevictable_pages() from shmem.c's unlock handling up to shm.c's unlock handling. Remove the recently added barrier, not needed now we have spin_unlock() before the scan. Use get_file(), with subsequent fput(), to make sure we have a reference to mapping throughout scan_mapping_unevictable_pages(): that's something that was previously guaranteed by the shm_lock(). Remove shmctl's lru_add_drain_all(): we don't fault in pages at SHM_LOCK time, and we lazily discover them to be Unevictable later, so it serves no purpose for SHM_LOCK; and serves no purpose for SHM_UNLOCK, since pages still on pagevec are not marked Unevictable. The original code avoided redundant rescans by checking VM_LOCKED flag at its level: now avoid them by checking shp's SHM_LOCKED. The original code called scan_mapping_unevictable_pages() on a locked area at shm_destroy() time: perhaps we once had accounting cross-checks which required that, but not now, so skip the overhead and just let inode eviction deal with them. Put check_move_unevictable_page() and scan_mapping_unevictable_pages() under CONFIG_SHMEM (with stub for the TINY case when ramfs is used), more as comment than to save space; comment them used for SHM_UNLOCK. Signed-off-by: Hugh Dickins <hughd@google.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Shaohua Li <shaohua.li@intel.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michel Lespinasse <walken@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09... and the same kind of leak for mqueueAl Viro
2011-11-02ipc/sem.c: remove private structures from public header fileManfred Spraul
include/linux/sem.h contains several structures that are only used within ipc/sem.c. The patch moves them into ipc/sem.c - there is no need to expose the structures to the whole kernel. No functional changes, only whitespace cleanups and 80-char per line fixes. Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-02ipc/sem.c: handle spurious wakeupsManfred Spraul
semtimedop() does not handle spurious wakeups, it returns -EINTR to user space. Most other schedule() users would just loop and not return to user space. The patch adds such a loop to semtimedop() Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Reported-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-02ipc/sem.c: fix return code race with semop vs. semop +semctl(IPC_RMID)Manfred Spraul
sys_semtimedop() may return -EIDRM although the semaphore operation completed successfully: thread 1: thread 2: semtimedop(), sleeps semop(): * acquires sem_lock() semtimedop() woken up due to timeout sem_lock() loops * notices that thread 2 could be completed. * performs the operations that thread 2 is sleeping on. * marks the semaphore operation as IN_WAKEUP * drops sem_lock(), does wakeup, sets return code to 0 * thread delayed due to interrupt, whatever * returns to user space * thread still delayed semctl(IPC_RMID) * acquires sem_lock() * ipc_rmid(), ipcp->deleted=1 * drops sem_lock() * thread finally continues - but seem_lock() now fails due to ipcp->deleted == 1 * returns -EIDRM instead of 0 The fix is trivial: Always use the return code in queue.status. In real world, the race probably doesn't matter: If the semaphore array is destroyed, the app is probably not interested if the last operation succeeded or was already cancelled. Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Mike Galbraith <efault@gmx.de> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31ipc/mqueue.c: fix wrong use of schedule_hrtimeout_range_clock()Wanlong Gao
Fix the wrong use of schedule_hrtimeout_range_clock() in wq_sleep(), although it is harmless for the syscall mq_timed* now. It was introduced by 9ca7d8e ("mqueue: Convert message queue timeout to use hrtimers"). Signed-off-by: Wanlong Gao <gaowanlong@cn.fujitsu.com> Cc: Carsten Emde <C.Emde@osadl.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-04Do 'shm_init_ns()' in an early pure_initcallLinus Torvalds
This isn't really critical any more, since other patches (commit 298507d4d2cf: "shm: optimize exit_shm()") have caused us to not actually need to touch the rw_mutex unless there are actual shm segments associated with the namespace, but we really should do tne shm_init_ns() earlier than we do now. This, together with commit 288d5abec831 ("Boot up with usermodehelper disabled") will mean that we really do initialize the initial ipc namespace data structure before we run any tasks. Tested-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-03shm: optimize exit_shm()Vasiliy Kulikov
We may optimistically check .in_use == 0 without holding the rw_mutex: it's the common case, and if it's zero, there certainly won't be any segments associated with us. After taking the lock, the idr_for_each() will do the right thing, so we could now drop the re-check inside the lock without any real cost. But it won't hurt. Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-03shm: fix wrong testsVasiliy Kulikov
Commit 4c677e2eefdb ("shm: optimize locking and ipc_namespace getting") introduced a copy-paste bug. Due to the bug cycle optimizations were disabled. Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-30shm: optimize locking and ipc_namespace gettingVasiliy Kulikov
shm_lock() does a lookup of shm segment in shm_ids(ns).ipcs_idr, which is redundant as we already know shmid_kernel address. An actual lock is also not required for reads until we really want to destroy the segment. exit_shm() and shm_destroy_orphaned() may avoid the loop by checking whether there is at least one segment in current ipc_namespace. The check of nsproxy and ipc_ns against NULL is redundant as exit_shm() is called from do_exit() before the call to exit_notify(), so the dereferencing current->nsproxy->ipc_ns is guaranteed to be safe. Reported-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-30shm: handle separate PID namespaces caseVasiliy Kulikov
shm_try_destroy_orphaned() and shm_try_destroy_current() didn't handle the case of separate PID namespaces, but a single IPC namespace. If there are tasks with the same PID values using the same shmem object, the wrong destroy decision could be reached. On shm segment creation store the pointer to the creator task in shmid_kernel->shm_creator field and zero it on task exit. Then use the ->shm_creator insread of shm_cprid in both functions. As shmid_kernel object is already locked at this stage, no additional locking is needed. Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26ipc: introduce shm_rmid_forced sysctlVasiliy Kulikov
Add support for the shm_rmid_forced sysctl. If set to 1, all shared memory objects in current ipc namespace will be automatically forced to use IPC_RMID. The POSIX way of handling shmem allows one to create shm objects and call shmdt(), leaving shm object associated with no process, thus consuming memory not counted via rlimits. With shm_rmid_forced=1 the shared memory object is counted at least for one process, so OOM killer may effectively kill the fat process holding the shared memory. It obviously breaks POSIX - some programs relying on the feature would stop working. So set shm_rmid_forced=1 only if you're sure nobody uses "orphaned" memory. Use shm_rmid_forced=0 by default for compatability reasons. The feature was previously impemented in -ow as a configure option. [akpm@linux-foundation.org: fix documentation, per Randy] [akpm@linux-foundation.org: fix warning] [akpm@linux-foundation.org: readability/conventionality tweaks] [akpm@linux-foundation.org: fix shm_rmid_forced/shm_forced_rmid confusion, use standard comment layout] Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: "Serge E. Hallyn" <serge.hallyn@canonical.com> Cc: Daniel Lezcano <daniel.lezcano@free.fr> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Solar Designer <solar@openwall.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26ipc/mqueue.c: fix mq_open() return valueJiri Slaby
We return ENOMEM from mqueue_get_inode even when we have enough memory. Namely in case the system rlimit of mqueue was reached. This error propagates to mq_queue and user sees the error unexpectedly. So fix this up to properly return EMFILE as described in the manpage: EMFILE The process already has the maximum number of files and message queues open. instead of: ENOMEM Insufficient memory. With the previous patch we just switch to ERR_PTR/PTR_ERR/IS_ERR error handling here. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26ipc/mqueue.c: refactor failure handlingJiri Slaby
If new_inode fails to allocate an inode we need only to return with NULL. But now we test the opposite and have all the work in a nested block. So do the opposite to save one indentation level (and remove unnecessary line breaks). This is only a preparation/cleanup for the next patch where we fix up return values from mqueue_get_inode. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25ipc/sem.c: fix race with concurrent semtimedop() timeouts and IPC_RMIDManfred Spraul
If a semaphore array is removed and in parallel a sleeping task is woken up (signal or timeout, does not matter), then the woken up task does not wait until wake_up_sem_queue_do() is completed. This will cause crashes, because wake_up_sem_queue_do() will read from a stale pointer. The fix is simple: Regardless of anything, always call get_queue_result(). This function waits until wake_up_sem_queue_do() has finished it's task. Addresses https://bugzilla.kernel.org/show_bug.cgi?id=27142 Reported-by: Yuriy Yevtukhov <yuriy@ucoz.com> Reported-by: Harald Laabs <kernel@dasr.de> Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: <stable@kernel.org> [2.6.35+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (107 commits) vfs: use ERR_CAST for err-ptr tossing in lookup_instantiate_filp isofs: Remove global fs lock jffs2: fix IN_DELETE_SELF on overwriting rename() killing a directory fix IN_DELETE_SELF on overwriting rename() on ramfs et.al. mm/truncate.c: fix build for CONFIG_BLOCK not enabled fs:update the NOTE of the file_operations structure Remove dead code in dget_parent() AFS: Fix silly characters in a comment switch d_add_ci() to d_splice_alias() in "found negative" case as well simplify gfs2_lookup() jfs_lookup(): don't bother with . or .. get rid of useless dget_parent() in btrfs rename() and link() get rid of useless dget_parent() in fs/btrfs/ioctl.c fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlers drivers: fix up various ->llseek() implementations fs: handle SEEK_HOLE/SEEK_DATA properly in all fs's that define their own llseek Ext4: handle SEEK_HOLE/SEEK_DATA generically Btrfs: implement our own ->llseek fs: add SEEK_HOLE and SEEK_DATA flags reiserfs: make reiserfs default to barrier=flush ... Fix up trivial conflicts in fs/xfs/linux-2.6/xfs_super.c due to the new shrinker callout for the inode cache, that clashed with the xfs code to start the periodic workers later.
2011-07-20fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlersJosef Bacik
Btrfs needs to be able to control how filemap_write_and_wait_range() is called in fsync to make it less of a painful operation, so push down taking i_mutex and the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some file systems can drop taking the i_mutex altogether it seems, like ext3 and ocfs2. For correctness sake I just pushed everything down in all cases to make sure that we keep the current behavior the same for everybody, and then each individual fs maintainer can make up their mind about what to do from there. Thanks, Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20ipc,rcu: Convert call_rcu(ipc_immediate_free) to kfree_rcu()Lai Jiangshan
The rcu callback ipc_immediate_free() just calls a kfree(), so we use kfree_rcu() instead of the call_rcu(ipc_immediate_free). Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-07-20ipc,rcu: Convert call_rcu(free_un) to kfree_rcu()Lai Jiangshan
The rcu callback free_un() just calls a kfree(), so we use kfree_rcu() instead of the call_rcu(free_un). Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Manfred Spraul <manfred@colorfullife.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-05-26mm: don't access vm_flags as 'int'KOSAKI Motohiro
The type of vma->vm_flags is 'unsigned long'. Neither 'int' nor 'unsigned int'. This patch fixes such misuse. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> [ Changed to use a typedef - we'll extend it to cover more cases later, since there has been discussion about making it a 64-bit type.. - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-10ns proc: Add support for the ipc namespaceEric W. Biederman
Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2011-03-27ipc: fix util.c kernel-doc warningsRandy Dunlap
Fix ipc/util.c kernel-doc warnings: Warning(ipc/util.c:336): No description found for parameter 'ns' Warning(ipc/util.c:620): No description found for parameter 'ns' Warning(ipc/util.c:790): No description found for parameter 'ns' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Reviewed-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-25ipcns: fix use after free in free_ipc_ns()Xiaotian Feng
commit b515498 ("userns: add a user namespace owner of ipc ns") added a user namespace owner of ipc ns, but it also introduced a use after free in free_ipc_ns(). Signed-off-by: Xiaotian Feng <dfeng@redhat.com> Acked-by: "Serge E. Hallyn" <serge.hallyn@canonical.com> Acked-by: David Howells <dhowells@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Daniel Lezcano <daniel.lezcano@free.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23userns: user namespaces: convert several capable() callsSerge E. Hallyn
CAP_IPC_OWNER and CAP_IPC_LOCK can be checked against current_user_ns(), because the resource comes from current's own ipc namespace. setuid/setgid are to uids in own namespace, so again checks can be against current_user_ns(). Changelog: Jan 11: Use task_ns_capable() in place of sched_capable(). Jan 11: Use nsown_capable() as suggested by Bastian Blank. Jan 11: Clarify (hopefully) some logic in futex and sched.c Feb 15: use ns_capable for ipc, not nsown_capable Feb 23: let copy_ipcs handle setting ipc_ns->user_ns Feb 23: pass ns down rather than taking it from current [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23userns: add a user namespace owner of ipc nsSerge E. Hallyn
Changelog: Feb 15: Don't set new ipc->user_ns if we didn't create a new ipc_ns. Feb 23: Move extern declaration to ipc_namespace.h, and group fwd declarations at top. Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-07fs: icache RCU free inodesNick Piggin
RCU free the struct inode. This will allow: - Subsequent store-free path walking patch. The inode must be consulted for permissions when walking, so an RCU inode reference is a must. - sb_inode_list_lock to be moved inside i_lock because sb list walkers who want to take i_lock no longer need to take sb_inode_list_lock to walk the list in the first place. This will simplify and optimize locking. - Could remove some nested trylock loops in dcache code - Could potentially simplify things a bit in VM land. Do not need to take the page lock to follow page->mapping. The downsides of this is the performance cost of using RCU. In a simple creat/unlink microbenchmark, performance drops by about 10% due to inability to reuse cache-hot slab objects. As iterations increase and RCU freeing starts kicking over, this increases to about 20%. In cases where inode lifetimes are longer (ie. many inodes may be allocated during the average life span of a single inode), a lot of this cache reuse is not applicable, so the regression caused by this patch is smaller. The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU, however this adds some complexity to list walking and store-free path walking, so I prefer to implement this at a later date, if it is shown to be a win in real situations. I haven't found a regression in any non-micro benchmark so I doubt it will be a problem. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-10-30ipc: shm: fix information leak to userlandVasiliy Kulikov
The shmid_ds structure is copied to userland with shm_unused{,2,3} fields unitialized. It leads to leaking of contents of kernel stack memory. Signed-off-by: Vasiliy Kulikov <segooon@gmail.com> Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-29switch get_sb_ns() usersAl Viro
2010-10-27ipc: initialize structure memory to zero for compat functionsDan Rosenberg
This takes care of leaking uninitialized kernel stack memory to userspace from non-zeroed fields in structs in compat ipc functions. Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27ipc/shm.c: add RSS and swap size information to /proc/sysvipc/shmHelge Deller
The kernel currently provides no functionality to analyze the RSS and swap space usage of each individual sysvipc shared memory segment. This patch adds this info for each existing shm segment by extending the output of /proc/sysvipc/shm by two columns for RSS and swap. Since shmctl(SHM_INFO) already provides a similiar calculation (it currently sums up all RSS/swap info for all segments), I did split out a static function which is now used by the /proc/sysvipc/shm output and shmctl(SHM_INFO). SAP products (esp. the SAP Netweaver ABAP Kernel) uses lots of big shared memory segments (we often have Linux systems with >= 16GB shm usage). Sometimes we get customer reports about "slow" system responses and while looking into their configurations we often find massive swapping activity on the system. With this patch it's now easy to see from the command line if and which shm segments gets swapped out (and how much) and can more easily give recommendations for system tuning. Without the patch it's currently not possible to do such shm analysis at all. Also... Add some spaces in front of the "size" field for 64bit kernels to get the columns correct if you cat the contents of the file. In sysvipc_shm_proc_show() the kernel prints the size value in "SPEC_SIZE" format, which is defined like this: #if BITS_PER_LONG <= 32 #define SIZE_SPEC "%10lu" #else #define SIZE_SPEC "%21lu" #endif So, if the header is not adjusted, the columns are not correctly aligned. I actually tested this on 32- and 64-bit and it seems correct now. Signed-off-by: Helge Deller <deller@gmx.de> Cc: Manfred Spraul <manfred@colorfullife.com> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-25fs: do not assign default i_ino in new_inodeChristoph Hellwig
Instead of always assigning an increasing inode number in new_inode move the call to assign it into those callers that actually need it. For now callers that need it is estimated conservatively, that is the call is added to all filesystems that do not assign an i_ino by themselves. For a few more filesystems we can avoid assigning any inode number given that they aren't user visible, and for others it could be done lazily when an inode number is actually needed, but that's left for later patches. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25new helper: ihold()Al Viro
Clones an existing reference to inode; caller must already hold one. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-22Merge branch 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: vfs: make no_llseek the default vfs: don't use BKL in default_llseek llseek: automatically add .llseek fop libfs: use generic_file_llseek for simple_attr mac80211: disallow seeks in minstrel debug code lirc: make chardev nonseekable viotape: use noop_llseek raw: use explicit llseek file operations ibmasmfs: use generic_file_llseek spufs: use llseek in all file operations arm/omap: use generic_file_llseek in iommu_debug lkdtm: use generic_file_llseek in debugfs net/wireless: use generic_file_llseek in debugfs drm: use noop_llseek
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-10-01sys_semctl: fix kernel stack leakageDan Rosenberg
The semctl syscall has several code paths that lead to the leakage of uninitialized kernel stack memory (namely the IPC_INFO, SEM_INFO, IPC_STAT, and SEM_STAT commands) during the use of the older, obsolete version of the semid_ds struct. The copy_semid_to_user() function declares a semid_ds struct on the stack and copies it back to the user without initializing or zeroing the "sem_base", "sem_pending", "sem_pending_last", and "undo" pointers, allowing the leakage of 16 bytes of kernel stack memory. The code is still reachable on 32-bit systems - when calling semctl() newer glibc's automatically OR the IPC command with the IPC_64 flag, but invoking the syscall directly allows users to use the older versions of the struct. Signed-off-by: Dan Rosenberg <dan.j.rosenberg@gmail.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09switch mqueue to ->evict_inode()Al Viro
... and since the inodes are never hashed, we can use default ->drop_inode() just fine. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-07-20ipc/sem.c: bugfix for semop() not reporting successful operationManfred Spraul
The last change to improve the scalability moved the actual wake-up out of the section that is protected by spin_lock(sma->sem_perm.lock). This means that IN_WAKEUP can be in queue.status even when the spinlock is acquired by the current task. Thus the same loop that is performed when queue.status is read without the spinlock acquired must be performed when the spinlock is acquired. Thanks to kamezawa.hiroyu@jp.fujitsu.com for noticing lack of the memory barrier. Addresses https://bugzilla.kernel.org/show_bug.cgi?id=16255 [akpm@linux-foundation.org: clean up kerneldoc, checkpatch warning and whitespace] Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Reported-by: Luca Tettamanti <kronos.it@gmail.com> Tested-by: Luca Tettamanti <kronos.it@gmail.com> Reported-by: Christoph Lameter <cl@linux-foundation.org> Cc: Maciej Rutecki <maciej.rutecki@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-06-04mqueue doesn't need make_bad_inode()Al Viro
It never hashes them anyway and does final iput() immediately afterwards. With ->drop_inode() being generic_delete_inode()... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27drop unused dentry argument to ->fsyncChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27ipc/sem.c: use ERR_CASTJulia Lawall
Use ERR_CAST(x) rather than ERR_PTR(PTR_ERR(x)). The former makes more clear what is the purpose of the operation, which otherwise looks like a no-op. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ type T; T x; identifier f; @@ T f (...) { <+... - ERR_PTR(PTR_ERR(x)) + x ...+> } @@ expression x; @@ - ERR_PTR(PTR_ERR(x)) + ERR_CAST(x) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27ipc/sem.c: update description of the implementationManfred Spraul
ipc/sem.c begins with a 15 year old description about bugs in the initial implementation in Linux-1.0. The patch replaces that with a top level description of the current code. A TODO could be derived from this text: The opengroup man page for semop() does not mandate FIFO. Thus there is no need for a semaphore array list of pending operations. If - this list is removed - the per-semaphore array spinlock is removed (possible if there is no list to protect) - sem_otime is moved into the semaphores and calculated on demand during semctl() then the array would be read-mostly - which would significantly improve scaling for applications that use semaphore arrays with lots of entries. The price would be expensive semctl() calls: for(i=0;i<sma->sem_nsems;i++) spin_lock(sma->sem_lock); <do stuff> for(i=0;i<sma->sem_nsems;i++) spin_unlock(sma->sem_lock); I'm not sure if the complexity is worth the effort, thus here is the documentation of the current behavior first. Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Zach Brown <zach.brown@oracle.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27ipc/sem.c: move wake_up_process out of the spinlock sectionManfred Spraul
The wake-up part of semtimedop() consists out of two steps: - the right tasks must be identified. - they must be woken up. Right now, both steps run while the array spinlock is held. This patch reorders the code and moves the actual wake_up_process() behind the point where the spinlock is dropped. The code also moves setting sem->sem_otime to one place: It does not make sense to set the last modify time multiple times. [akpm@linux-foundation.org: repair kerneldoc] [akpm@linux-foundation.org: fix uninitialised retval] Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Zach Brown <zach.brown@oracle.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27ipc/sem.c: optimize update_queue() for bulk wakeup callsManfred Spraul
The following series of patches tries to fix the spinlock contention reported by Chris Mason - his benchmark exposes problems of the current code: - In the worst case, the algorithm used by update_queue() is O(N^2). Bulk wake-up calls can enter this worst case. The patch series fix that. Note that the benchmark app doesn't expose the problem, it just should be fixed: Real world apps might do the wake-ups in another order than perfect FIFO. - The part of the code that runs within the semaphore array spinlock is significantly larger than necessary. The patch series fixes that. This change is responsible for the main improvement. - The cacheline with the spinlock is also used for a variable that is read in the hot path (sem_base) and for a variable that is unnecessarily written to multiple times (sem_otime). The last step of the series cacheline-aligns the spinlock. This patch: The SysV semaphore code allows to perform multiple operations on all semaphores in the array as atomic operations. After a modification, update_queue() checks which of the waiting tasks can complete. The algorithm that is used to identify the tasks is O(N^2) in the worst case. For some cases, it is simple to avoid the O(N^2). The patch adds a detection logic for some cases, especially for the case of an array where all sleeping tasks are single sembuf operations and a multi-sembuf operation is used to wake up multiple tasks. A big database application uses that approach. The patch fixes wakeup due to semctl(,,SETALL,) - the initial version of the patch breaks that. [akpm@linux-foundation.org: make do_smart_update() static] Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Zach Brown <zach.brown@oracle.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25kernel-wide: replace USHORT_MAX, SHORT_MAX and SHORT_MIN with USHRT_MAX, ↵Alexey Dobriyan
SHRT_MAX and SHRT_MIN - C99 knows about USHRT_MAX/SHRT_MAX/SHRT_MIN, not USHORT_MAX/SHORT_MAX/SHORT_MIN. - Make SHRT_MIN of type s16, not int, for consistency. [akpm@linux-foundation.org: fix drivers/dma/timb_dma.c] [akpm@linux-foundation.org: fix security/keys/keyring.c] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-19Merge branch 'timers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: clocksource: Add clocksource_register_hz/khz interface posix-cpu-timers: Optimize run_posix_cpu_timers() time: Remove xtime_cache mqueue: Convert message queue timeout to use hrtimers hrtimers: Provide schedule_hrtimeout for CLOCK_REALTIME timers: Introduce the concept of timer slack for legacy timers ntp: Remove tickadj ntp: Make time_adjust static time: Add xtime, wall_to_monotonic to feature-removal-schedule timer: Try to survive timer callback preempt_count leak timer: Split out timer function call timer: Print function name for timer callbacks modifying preemption count time: Clean up warp_clock() cpu-timers: Avoid iterating over all threads in fastpath_timer_check() cpu-timers: Change SIGEV_NONE timer implementation cpu-timers: Return correct previous timer reload value cpu-timers: Cleanup arm_timer() cpu-timers: Simplify RLIMIT_CPU handling
2010-05-11mqueue: fix kernel BUG caused by double free() on mq_open()André Goddard Rosa
In case of aborting because we reach the maximum amount of memory which can be allocated to message queues per user (RLIMIT_MSGQUEUE), we would try to free the message area twice when bailing out: first by the error handling code itself, and then later when cleaning up the inode through delete_inode(). Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-10Merge branch 'linus' into timers/coreThomas Gleixner
Reason: Further posix_cpu_timer patches depend on mainline changes Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
