path: root/kernel/Kconfig.instrumentation
2007-12-06Tiny clean-up of OPROFILE/KPROBES configurationLinus Torvalds
Make the Kconfig.instrumentation file a bit easier on the eyes, and use the new ARCH_SUPPORTS_OPROFILE for x86[-64]. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-06Fix oprofile configuration breakageRalf Baechle
The cleanup 09cadedbdc01f1a4bea1f427d4fb4642eaa19da9 broke the oprofile configuration for MIPS by allowing oprofile support to be built for kernel models where oprofile doesn't have a chance in hell to work. Just a dependecy list on a number of architectures is - surprise - broken and should as per past discussions probably in most considered to be broken in most cases. So I introduce a dependency for the oprofile configuration on ARCH_SUPPORTS_OPROFILE. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-03uml: add !UML dependenciesAl Viro
The previous commit ("uml: keep UML Kconfig in sync with x86") is not enough, unfortunately. If we go that way, we need to add dependencies on !UML for several options. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Linux Kernel MarkersMathieu Desnoyers
The marker activation functions sits in kernel/marker.c. A hash table is used to keep track of the registered probes and armed markers, so the markers within a newly loaded module that should be active can be activated at module load time. marker_query has been removed. marker_get_first, marker_get_next and marker_release should be used as iterators on the markers. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Acked-by: "Frank Ch. Eigler" <fche@redhat.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Mike Mason <mmlnx@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Combine instrumentation menus in kernel/Kconfig.instrumentationMathieu Desnoyers
Quoting Randy: "It seems sad that this patch sources Kconfig.marker, a 7-line file, 20-something times. Yes, you (we) don't want to put those 7 lines into 20-something different files, so sourcing is the right thing. However, what you did for avr32 seems more on the right track to me: make _one_ Instrumentation support menu that includes PROFILING, OPROFILE, KPROBES, and MARKERS and then use (source) that in all of the arches." Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
