path: root/kernel/Kconfig.preempt
2012-03-06kconfig-preempt-rt-full.patchv3.2.9-rt16Thomas Gleixner
2012-03-06rt-preempt-base-config.patchThomas Gleixner
2011-06-10sched: Isolate preempt counting in its own config optionFrederic Weisbecker
Create a new CONFIG_PREEMPT_COUNT that handles the inc/dec of preempt count offset independently. So that the offset can be updated by preempt_disable() and preempt_enable() even without the need for CONFIG_PREEMPT beeing set. This prepares to make CONFIG_DEBUG_SPINLOCK_SLEEP working with !CONFIG_PREEMPT where it currently doesn't detect code that sleeps inside explicit preemption disabled sections. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl>
2008-12-25rcu: provide RCU options on non-preempt architectures tooIngo Molnar
Impact: build fix Some old architectures still do not use kernel/Kconfig.preempt, so the moving of the RCU options there broke their build: In file included from /home/mingo/tip/include/linux/sem.h:81, from /home/mingo/tip/include/linux/sched.h:69, from /home/mingo/tip/arch/alpha/kernel/asm-offsets.c:9: /home/mingo/tip/include/linux/rcupdate.h:62:2: error: #error "Unknown RCU implementation specified to kernel configuration" Move these options back to init/Kconfig, which every architecture includes. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-18"Tree RCU": scalable classic RCU implementationPaul E. McKenney
This patch fixes a long-standing performance bug in classic RCU that results in massive internal-to-RCU lock contention on systems with more than a few hundred CPUs. Although this patch creates a separate flavor of RCU for ease of review and patch maintenance, it is intended to replace classic RCU. This patch still handles stress better than does mainline, so I am still calling it ready for inclusion. This patch is against the -tip tree. Nevertheless, experience on an actual 1000+ CPU machine would still be most welcome. Most of the changes noted below were found while creating an rcutiny (which should permit ejecting the current rcuclassic) and while doing detailed line-by-line documentation. Updates from v9 (http://lkml.org/lkml/2008/12/2/334): o Fixes from remainder of line-by-line code walkthrough, including comment spelling, initialization, undesirable narrowing due to type conversion, removing redundant memory barriers, removing redundant local-variable initialization, and removing redundant local variables. I do not believe that any of these fixes address the CPU-hotplug issues that Andi Kleen was seeing, but please do give it a whirl in case the machine is smarter than I am. A writeup from the walkthrough may be found at the following URL, in case you are suffering from terminal insomnia or masochism: http://www.kernel.org/pub/linux/kernel/people/paulmck/tmp/rcutree-walkthrough.2008.12.16a.pdf o Made rcutree tracing use seq_file, as suggested some time ago by Lai Jiangshan. o Added a .csv variant of the rcudata debugfs trace file, to allow people having thousands of CPUs to drop the data into a spreadsheet. Tested with oocalc and gnumeric. Updated documentation to suit. Updates from v8 (http://lkml.org/lkml/2008/11/15/139): o Fix a theoretical race between grace-period initialization and force_quiescent_state() that could occur if more than three jiffies were required to carry out the grace-period initialization. Which it might, if you had enough CPUs. o Apply Ingo's printk-standardization patch. o Substitute local variables for repeated accesses to global variables. o Fix comment misspellings and redundant (but harmless) increments of ->n_rcu_pending (this latter after having explicitly added it). o Apply checkpatch fixes. Updates from v7 (http://lkml.org/lkml/2008/10/10/291): o Fixed a number of problems noted by Gautham Shenoy, including the cpu-stall-detection bug that he was having difficulty convincing me was real. ;-) o Changed cpu-stall detection to wait for ten seconds rather than three in order to reduce false positive, as suggested by Ingo Molnar. o Produced a design document (http://lwn.net/Articles/305782/). The act of writing this document uncovered a number of both theoretical and "here and now" bugs as noted below. o Fix dynticks_nesting accounting confusion, simplify WARN_ON() condition, fix kerneldoc comments, and add memory barriers in dynticks interface functions. o Add more data to tracing. o Remove unused "rcu_barrier" field from rcu_data structure. o Count calls to rcu_pending() from scheduling-clock interrupt to use as a surrogate timebase should jiffies stop counting. o Fix a theoretical race between force_quiescent_state() and grace-period initialization. Yes, initialization does have to go on for some jiffies for this race to occur, but given enough CPUs... Updates from v6 (http://lkml.org/lkml/2008/9/23/448): o Fix a number of checkpatch.pl complaints. o Apply review comments from Ingo Molnar and Lai Jiangshan on the stall-detection code. o Fix several bugs in !CONFIG_SMP builds. o Fix a misspelled config-parameter name so that RCU now announces at boot time if stall detection is configured. o Run tests on numerous combinations of configurations parameters, which after the fixes above, now build and run correctly. Updates from v5 (http://lkml.org/lkml/2008/9/15/92, bad subject line): o Fix a compiler error in the !CONFIG_FANOUT_EXACT case (blew a changeset some time ago, and finally got around to retesting this option). o Fix some tracing bugs in rcupreempt that caused incorrect totals to be printed. o I now test with a more brutal random-selection online/offline script (attached). Probably more brutal than it needs to be on the people reading it as well, but so it goes. o A number of optimizations and usability improvements: o Make rcu_pending() ignore the grace-period timeout when there is no grace period in progress. o Make force_quiescent_state() avoid going for a global lock in the case where there is no grace period in progress. o Rearrange struct fields to improve struct layout. o Make call_rcu() initiate a grace period if RCU was idle, rather than waiting for the next scheduling clock interrupt. o Invoke rcu_irq_enter() and rcu_irq_exit() only when idle, as suggested by Andi Kleen. I still don't completely trust this change, and might back it out. o Make CONFIG_RCU_TRACE be the single config variable manipulated for all forms of RCU, instead of the prior confusion. o Document tracing files and formats for both rcupreempt and rcutree. Updates from v4 for those missing v5 given its bad subject line: o Separated dynticks interface so that NMIs and irqs call separate functions, greatly simplifying it. In particular, this code no longer requires a proof of correctness. ;-) o Separated dynticks state out into its own per-CPU structure, avoiding the duplicated accounting. o The case where a dynticks-idle CPU runs an irq handler that invokes call_rcu() is now correctly handled, forcing that CPU out of dynticks-idle mode. o Review comments have been applied (thank you all!!!). For but one example, fixed the dynticks-ordering issue that Manfred pointed out, saving me much debugging. ;-) o Adjusted rcuclassic and rcupreempt to handle dynticks changes. Attached is an updated patch to Classic RCU that applies a hierarchy, greatly reducing the contention on the top-level lock for large machines. This passes 10-hour concurrent rcutorture and online-offline testing on 128-CPU ppc64 without dynticks enabled, and exposes some timekeeping bugs in presence of dynticks (exciting working on a system where "sleep 1" hangs until interrupted...), which were fixed in the 2.6.27 kernel. It is getting more reliable than mainline by some measures, so the next version will be against -tip for inclusion. See also Manfred Spraul's recent patches (or his earlier work from 2004 at http://marc.info/?l=linux-kernel&m=108546384711797&w=2). We will converge onto a common patch in the fullness of time, but are currently exploring different regions of the design space. That said, I have already gratefully stolen quite a few of Manfred's ideas. This patch provides CONFIG_RCU_FANOUT, which controls the bushiness of the RCU hierarchy. Defaults to 32 on 32-bit machines and 64 on 64-bit machines. If CONFIG_NR_CPUS is less than CONFIG_RCU_FANOUT, there is no hierarchy. By default, the RCU initialization code will adjust CONFIG_RCU_FANOUT to balance the hierarchy, so strongly NUMA architectures may choose to set CONFIG_RCU_FANOUT_EXACT to disable this balancing, allowing the hierarchy to be exactly aligned to the underlying hardware. Up to two levels of hierarchy are permitted (in addition to the root node), allowing up to 16,384 CPUs on 32-bit systems and up to 262,144 CPUs on 64-bit systems. I just know that I am going to regret saying this, but this seems more than sufficient for the foreseeable future. (Some architectures might wish to set CONFIG_RCU_FANOUT=4, which would limit such architectures to 64 CPUs. If this becomes a real problem, additional levels can be added, but I doubt that it will make a significant difference on real hardware.) In the common case, a given CPU will manipulate its private rcu_data structure and the rcu_node structure that it shares with its immediate neighbors. This can reduce both lock and memory contention by multiple orders of magnitude, which should eliminate the need for the strange manipulations that are reported to be required when running Linux on very large systems. Some shortcomings: o More bugs will probably surface as a result of an ongoing line-by-line code inspection. Patches will be provided as required. o There are probably hangs, rcutorture failures, &c. Seems quite stable on a 128-CPU machine, but that is kind of small compared to 4096 CPUs. However, seems to do better than mainline. Patches will be provided as required. o The memory footprint of this version is several KB larger than rcuclassic. A separate UP-only rcutiny patch will be provided, which will reduce the memory footprint significantly, even compared to the old rcuclassic. One such patch passes light testing, and has a memory footprint smaller even than rcuclassic. Initial reaction from various embedded guys was "it is not worth it", so am putting it aside. Credits: o Manfred Spraul for ideas, review comments, and bugs spotted, as well as some good friendly competition. ;-) o Josh Triplett, Ingo Molnar, Peter Zijlstra, Mathieu Desnoyers, Lai Jiangshan, Andi Kleen, Andy Whitcroft, and Andrew Morton for reviews and comments. o Thomas Gleixner for much-needed help with some timer issues (see patches below). o Jon M. Tollefson, Tim Pepper, Andrew Theurer, Jose R. Santos, Andy Whitcroft, Darrick Wong, Nishanth Aravamudan, Anton Blanchard, Dave Kleikamp, and Nathan Lynch for keeping machines alive despite my heavy abuse^Wtesting. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-03-10rcu: move PREEMPT_RCU config option back under PREEMPTPaul E. McKenney
The original preemptible-RCU patch put the choice between classic and preemptible RCU into kernel/Kconfig.preempt, which resulted in build failures on machines not supporting CONFIG_PREEMPT. This choice was therefore moved to init/Kconfig, which worked, but placed the choice between classic and preemptible RCU at the top level, a very obtuse choice indeed. This patch changes from the Kconfig "choice" mechanism to a pair of booleans, only one of which (CONFIG_PREEMPT_RCU) is user-visible, and is located in kernel/Kconfig.preempt, where one would expect it to be. The other (CONFIG_CLASSIC_RCU) is in init/Kconfig so that it is available to all architectures, hopefully avoiding build breakage. Thanks to Roman Zippel for suggesting this approach. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Dipankar Sarma <dipankar@in.ibm.com> Cc: Josh Triplett <josh@freedesktop.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-25sched: remove the !PREEMPT_BKL codeIngo Molnar
remove the !PREEMPT_BKL code. this removes 160 lines of legacy code. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-25sched: make PREEMPT_BKL the defaultIngo Molnar
make PREEMPT_BKL the default. precursor to removal of the !PREEMPT_BKL code. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-25Preempt-RCU: implementationPaul E. McKenney
This patch implements a new version of RCU which allows its read-side critical sections to be preempted. It uses a set of counter pairs to keep track of the read-side critical sections and flips them when all tasks exit read-side critical section. The details of this implementation can be found in this paper - http://www.rdrop.com/users/paulmck/RCU/OLSrtRCU.2006.08.11a.pdf and the article- http://lwn.net/Articles/253651/ This patch was developed as a part of the -rt kernel development and meant to provide better latencies when read-side critical sections of RCU don't disable preemption. As a consequence of keeping track of RCU readers, the readers have a slight overhead (optimizations in the paper). This implementation co-exists with the "classic" RCU implementations and can be switched to at compiler. Also includes RCU tracing summarized in debugfs. [ akpm@linux-foundation.org: build fixes on non-preempt architectures ] Signed-off-by: Gautham R Shenoy <ego@in.ibm.com> Signed-off-by: Dipankar Sarma <dipankar@in.ibm.com> Signed-off-by: Paul E. McKenney <paulmck@us.ibm.com> Reviewed-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-17Move PREEMPT_NOTIFIERS into an always-included KconfigAvi Kivity
Kconfig.preempt is not included on some archs (for example, m68k). On those archs, the Kconfig machinery complains that KVM selects an undefined symbol PREEMPT_NOTIFIERS (which lives in Kconfig.preempt). So move the offending symbol into a Kconfig file which is included by everyone. Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Avi Kivity <avi@qumranet.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-26[PATCH] sched: arch preempt notifier mechanismAvi Kivity
This adds a general mechanism whereby a task can request the scheduler to notify it whenever it is preempted or scheduled back in. This allows the task to swap any special-purpose registers like the fpu or Intel's VT registers. Signed-off-by: Avi Kivity <avi@qumranet.com> [ mingo@elte.hu: fixes, cleanups ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-05-09Fix trivial typos in Kconfig* filesDavid Sterba
Fix several typos in help text in Kconfig* files. Signed-off-by: David Sterba <dave@jikos.cz> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-06-25[PATCH] sched: voluntary kernel preemptionIngo Molnar
This patch adds a new preemption model: 'Voluntary Kernel Preemption'. The 3 models can be selected from a new menu: (X) No Forced Preemption (Server) ( ) Voluntary Kernel Preemption (Desktop) ( ) Preemptible Kernel (Low-Latency Desktop) we still default to the stock (Server) preemption model. Voluntary preemption works by adding a cond_resched() (reschedule-if-needed) call to every might_sleep() check. It is lighter than CONFIG_PREEMPT - at the cost of not having as tight latencies. It represents a different latency/complexity/overhead tradeoff. It has no runtime impact at all if disabled. Here are size stats that show how the various preemption models impact the kernel's size: text data bss dec hex filename 3618774 547184 179896 4345854 424ffe vmlinux.stock 3626406 547184 179896 4353486 426dce vmlinux.voluntary +0.2% 3748414 548640 179896 4476950 445016 vmlinux.preempt +3.5% voluntary-preempt is +0.2% of .text, preempt is +3.5%. This feature has been tested for many months by lots of people (and it's also included in the RHEL4 distribution and earlier variants were in Fedora as well), and it's intended for users and distributions who dont want to use full-blown CONFIG_PREEMPT for one reason or another. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] enable PREEMPT_BKL on !PREEMPT+SMP tooIngo Molnar
The only sane way to clean up the current 3 lock_kernel() variants seems to be to remove the spinlock-based BKL implementations altogether, and to keep the semaphore-based one only. If we dont want to do that for whatever reason then i'm afraid we have to live with the current complexity. (but i'm open for other cleanup suggestions as well.) To explore this possibility we'll (at a minimum) have to know whether the semaphore-based BKL works fine on plain SMP too. The patch below enables this. The patch may make sense in isolation as well, as it might bring performance benefits: code that would formerly spin on the BKL spinlock will now schedule away and give up the CPU. It might introduce performance regressions as well, if any performance-critical code uses the BKL heavily and gets overscheduled due to the semaphore. I very much hope there is no such performance-critical codepath left though. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] consolidate PREEMPT options into kernel/Kconfig.preemptIngo Molnar
This patch consolidates the CONFIG_PREEMPT and CONFIG_PREEMPT_BKL preemption options into kernel/Kconfig.preempt. This, besides reducing source-code, also enables more centralized tweaking of preemption related options. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
