path: root/kernel/Kconfig.preempt
2005-06-25[PATCH] sched: voluntary kernel preemptionIngo Molnar
This patch adds a new preemption model: 'Voluntary Kernel Preemption'. The 3 models can be selected from a new menu: (X) No Forced Preemption (Server) ( ) Voluntary Kernel Preemption (Desktop) ( ) Preemptible Kernel (Low-Latency Desktop) we still default to the stock (Server) preemption model. Voluntary preemption works by adding a cond_resched() (reschedule-if-needed) call to every might_sleep() check. It is lighter than CONFIG_PREEMPT - at the cost of not having as tight latencies. It represents a different latency/complexity/overhead tradeoff. It has no runtime impact at all if disabled. Here are size stats that show how the various preemption models impact the kernel's size: text data bss dec hex filename 3618774 547184 179896 4345854 424ffe vmlinux.stock 3626406 547184 179896 4353486 426dce vmlinux.voluntary +0.2% 3748414 548640 179896 4476950 445016 vmlinux.preempt +3.5% voluntary-preempt is +0.2% of .text, preempt is +3.5%. This feature has been tested for many months by lots of people (and it's also included in the RHEL4 distribution and earlier variants were in Fedora as well), and it's intended for users and distributions who dont want to use full-blown CONFIG_PREEMPT for one reason or another. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] enable PREEMPT_BKL on !PREEMPT+SMP tooIngo Molnar
The only sane way to clean up the current 3 lock_kernel() variants seems to be to remove the spinlock-based BKL implementations altogether, and to keep the semaphore-based one only. If we dont want to do that for whatever reason then i'm afraid we have to live with the current complexity. (but i'm open for other cleanup suggestions as well.) To explore this possibility we'll (at a minimum) have to know whether the semaphore-based BKL works fine on plain SMP too. The patch below enables this. The patch may make sense in isolation as well, as it might bring performance benefits: code that would formerly spin on the BKL spinlock will now schedule away and give up the CPU. It might introduce performance regressions as well, if any performance-critical code uses the BKL heavily and gets overscheduled due to the semaphore. I very much hope there is no such performance-critical codepath left though. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] consolidate PREEMPT options into kernel/Kconfig.preemptIngo Molnar
This patch consolidates the CONFIG_PREEMPT and CONFIG_PREEMPT_BKL preemption options into kernel/Kconfig.preempt. This, besides reducing source-code, also enables more centralized tweaking of preemption related options. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
