path: root/kernel/Makefile
2013-12-13KEYS: Remove files generated when SYSTEM_TRUSTED_KEYRING=yKirill Tkhai
Always remove generated SYSTEM_TRUSTED_KEYRING files while doing make mrproper. Signed-off-by: Kirill Tkhai <tkhai@yandex.ru> Signed-off-by: David Howells <dhowells@redhat.com>
2013-12-13X.509: Fix certificate gatheringDavid Howells
Fix the gathering of certificates from both the source tree and the build tree to correctly calculate the pathnames of all the certificates. The problem was that if the default generated cert, signing_key.x509, didn't exist then it would not have a path attached and if it did, it would have a path attached. This means that the contents of kernel/.x509.list would change between the first compilation in a directory and the second. After the second it would remain stable because the signing_key.x509 file exists. The consequence was that the kernel would get relinked unconditionally on the second recompilation. The second recompilation would also show something like this: X.509 certificate list changed CERTS kernel/x509_certificate_list - Including cert /home/torvalds/v2.6/linux/signing_key.x509 AS kernel/system_certificates.o LD kernel/built-in.o which is why the relink would happen. Unfortunately, it isn't a simple matter of just sticking a path on the front of the filename of the certificate in the build directory as make can't then work out how to build it. So the path has to be prepended to the name for sorting and duplicate elimination and then removed for the make rule if it is in the build tree. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: David Howells <dhowells@redhat.com>
2013-11-21Merge branch 'for-linus2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "In this patchset, we finally get an SELinux update, with Paul Moore taking over as maintainer of that code. Also a significant update for the Keys subsystem, as well as maintenance updates to Smack, IMA, TPM, and Apparmor" and since I wanted to know more about the updates to key handling, here's the explanation from David Howells on that: "Okay. There are a number of separate bits. I'll go over the big bits and the odd important other bit, most of the smaller bits are just fixes and cleanups. If you want the small bits accounting for, I can do that too. (1) Keyring capacity expansion. KEYS: Consolidate the concept of an 'index key' for key access KEYS: Introduce a search context structure KEYS: Search for auth-key by name rather than target key ID Add a generic associative array implementation. KEYS: Expand the capacity of a keyring Several of the patches are providing an expansion of the capacity of a keyring. Currently, the maximum size of a keyring payload is one page. Subtract a small header and then divide up into pointers, that only gives you ~500 pointers on an x86_64 box. However, since the NFS idmapper uses a keyring to store ID mapping data, that has proven to be insufficient to the cause. Whatever data structure I use to handle the keyring payload, it can only store pointers to keys, not the keys themselves because several keyrings may point to a single key. This precludes inserting, say, and rb_node struct into the key struct for this purpose. I could make an rbtree of records such that each record has an rb_node and a key pointer, but that would use four words of space per key stored in the keyring. It would, however, be able to use much existing code. I selected instead a non-rebalancing radix-tree type approach as that could have a better space-used/key-pointer ratio. I could have used the radix tree implementation that we already have and insert keys into it by their serial numbers, but that means any sort of search must iterate over the whole radix tree. Further, its nodes are a bit on the capacious side for what I want - especially given that key serial numbers are randomly allocated, thus leaving a lot of empty space in the tree. So what I have is an associative array that internally is a radix-tree with 16 pointers per node where the index key is constructed from the key type pointer and the key description. This means that an exact lookup by type+description is very fast as this tells us how to navigate directly to the target key. I made the data structure general in lib/assoc_array.c as far as it is concerned, its index key is just a sequence of bits that leads to a pointer. It's possible that someone else will be able to make use of it also. FS-Cache might, for example. (2) Mark keys as 'trusted' and keyrings as 'trusted only'. KEYS: verify a certificate is signed by a 'trusted' key KEYS: Make the system 'trusted' keyring viewable by userspace KEYS: Add a 'trusted' flag and a 'trusted only' flag KEYS: Separate the kernel signature checking keyring from module signing These patches allow keys carrying asymmetric public keys to be marked as being 'trusted' and allow keyrings to be marked as only permitting the addition or linkage of trusted keys. Keys loaded from hardware during kernel boot or compiled into the kernel during build are marked as being trusted automatically. New keys can be loaded at runtime with add_key(). They are checked against the system keyring contents and if their signatures can be validated with keys that are already marked trusted, then they are marked trusted also and can thus be added into the master keyring. Patches from Mimi Zohar make this usable with the IMA keyrings also. (3) Remove the date checks on the key used to validate a module signature. X.509: Remove certificate date checks It's not reasonable to reject a signature just because the key that it was generated with is no longer valid datewise - especially if the kernel hasn't yet managed to set the system clock when the first module is loaded - so just remove those checks. (4) Make it simpler to deal with additional X.509 being loaded into the kernel. KEYS: Load *.x509 files into kernel keyring KEYS: Have make canonicalise the paths of the X.509 certs better to deduplicate The builder of the kernel now just places files with the extension ".x509" into the kernel source or build trees and they're concatenated by the kernel build and stuffed into the appropriate section. (5) Add support for userspace kerberos to use keyrings. KEYS: Add per-user_namespace registers for persistent per-UID kerberos caches KEYS: Implement a big key type that can save to tmpfs Fedora went to, by default, storing kerberos tickets and tokens in tmpfs. We looked at storing it in keyrings instead as that confers certain advantages such as tickets being automatically deleted after a certain amount of time and the ability for the kernel to get at these tokens more easily. To make this work, two things were needed: (a) A way for the tickets to persist beyond the lifetime of all a user's sessions so that cron-driven processes can still use them. The problem is that a user's session keyrings are deleted when the session that spawned them logs out and the user's user keyring is deleted when the UID is deleted (typically when the last log out happens), so neither of these places is suitable. I've added a system keyring into which a 'persistent' keyring is created for each UID on request. Each time a user requests their persistent keyring, the expiry time on it is set anew. If the user doesn't ask for it for, say, three days, the keyring is automatically expired and garbage collected using the existing gc. All the kerberos tokens it held are then also gc'd. (b) A key type that can hold really big tickets (up to 1MB in size). The problem is that Active Directory can return huge tickets with lots of auxiliary data attached. We don't, however, want to eat up huge tracts of unswappable kernel space for this, so if the ticket is greater than a certain size, we create a swappable shmem file and dump the contents in there and just live with the fact we then have an inode and a dentry overhead. If the ticket is smaller than that, we slap it in a kmalloc()'d buffer" * 'for-linus2' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (121 commits) KEYS: Fix keyring content gc scanner KEYS: Fix error handling in big_key instantiation KEYS: Fix UID check in keyctl_get_persistent() KEYS: The RSA public key algorithm needs to select MPILIB ima: define '_ima' as a builtin 'trusted' keyring ima: extend the measurement list to include the file signature kernel/system_certificate.S: use real contents instead of macro GLOBAL() KEYS: fix error return code in big_key_instantiate() KEYS: Fix keyring quota misaccounting on key replacement and unlink KEYS: Fix a race between negating a key and reading the error set KEYS: Make BIG_KEYS boolean apparmor: remove the "task" arg from may_change_ptraced_domain() apparmor: remove parent task info from audit logging apparmor: remove tsk field from the apparmor_audit_struct apparmor: fix capability to not use the current task, during reporting Smack: Ptrace access check mode ima: provide hash algo info in the xattr ima: enable support for larger default filedata hash algorithms ima: define kernel parameter 'ima_template=' to change configured default ima: add Kconfig default measurement list template ...
2013-11-06locking: Move the lglocks code to kernel/locking/Peter Zijlstra
Suggested-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-amd6pg1mif6tikbyktfvby3y@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-11-06locking: Move the rwsem code to kernel/locking/Peter Zijlstra
Notably: changed lib/rwsem* targets from lib- to obj-, no idea about the ramifications of that. Suggested-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-g0kynfh5feriwc6p3h6kpbw6@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-11-06locking: Move the rtmutex code to kernel/locking/Peter Zijlstra
Suggested-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-p9ijt8div0hwldexwfm4nlhj@git.kernel.org [ Fixed build failure in kernel/rcu/tree_plugin.h. ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-11-06locking: Move the semaphore core to kernel/locking/Peter Zijlstra
Suggested-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-vmw5sf6vzmua1z6nx1cg69h2@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-11-06locking: Move the spinlock code to kernel/locking/Peter Zijlstra
Suggested-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-b81ol0z3mon45m51o131yc9j@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-11-06locking: Move the lockdep code to kernel/locking/Peter Zijlstra
Suggested-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-wl7s3tta5isufzfguc23et06@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-11-06locking: Move the mutex code to kernel/locking/Peter Zijlstra
Suggested-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-1ditvncg30dgbpvrz2bxfmke@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-11-06Merge branch 'sched/core' into core/locking, to prepare the kernel/locking/ ↵Ingo Molnar
file move Conflicts: kernel/Makefile There are conflicts in kernel/Makefile due to file moving in the scheduler tree - resolve them. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-11-06sched: Move wait.c into kernel/sched/Peter Zijlstra
Suggested-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/n/tip-5q5yqvdaen0rmapwloeaotx3@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-10-15rcu: Move RCU-related source code to kernel/rcu directoryPaul E. McKenney
Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Ingo Molnar <mingo@kernel.org>
2013-09-25KEYS: Separate the kernel signature checking keyring from module signingDavid Howells
Separate the kernel signature checking keyring from module signing so that it can be used by code other than the module-signing code. Signed-off-by: David Howells <dhowells@redhat.com>
2013-09-25KEYS: Have make canonicalise the paths of the X.509 certs better to deduplicateDavid Howells
Have make canonicalise the paths of the X.509 certificates before we sort them as this allows $(sort) to better remove duplicates. Signed-off-by: David Howells <dhowells@redhat.com>
2013-09-25KEYS: Load *.x509 files into kernel keyringDavid Howells
Load all the files matching the pattern "*.x509" that are to be found in kernel base source dir and base build dir into the module signing keyring. The "extra_certificates" file is then redundant. Signed-off-by: David Howells <dhowells@redhat.com>
2013-09-13Remove GENERIC_HARDIRQ config optionMartin Schwidefsky
After the last architecture switched to generic hard irqs the config options HAVE_GENERIC_HARDIRQS & GENERIC_HARDIRQS and the related code for !CONFIG_GENERIC_HARDIRQS can be removed. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-07-31printk: move to separate directory for easier modificationJoe Perches
Make it easier to break up printk into bite-sized chunks. Remove printk path/filename from comment. Signed-off-by: Joe Perches <joe@perches.com> Cc: Samuel Thibault <samuel.thibault@ens-lyon.org> Cc: Ming Lei <ming.lei@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09reboot: move shutdown/reboot related functions to kernel/reboot.cRobin Holt
This patch is preparatory. It moves reboot related syscall, etc functions from kernel/sys.c to kernel/reboot.c. Signed-off-by: Robin Holt <holt@sgi.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Russ Anderson <rja@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-05Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull mudule updates from Rusty Russell: "We get rid of the general module prefix confusion with a binary config option, fix a remove/insert race which Never Happens, and (my favorite) handle the case when we have too many modules for a single commandline. Seriously, the kernel is full, please go away!" * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: modpost: fix unwanted VMLINUX_SYMBOL_STR expansion X.509: Support parse long form of length octets in Authority Key Identifier module: don't unlink the module until we've removed all exposure. kernel: kallsyms: memory override issue, need check destination buffer length MODSIGN: do not send garbage to stderr when enabling modules signature modpost: handle huge numbers of modules. modpost: add -T option to read module names from file/stdin. modpost: minor cleanup. genksyms: pass symbol-prefix instead of arch module: fix symbol versioning with symbol prefixes CONFIG_SYMBOL_PREFIX: cleanup.
2013-04-11MODSIGN: do not send garbage to stderr when enabling modules signatureDavid Cohen
When compiling kernel with -jN (N > 1), all warning/error messages printed while openssl is generating key pair may get mixed dots and other symbols openssl sends to stderr. This patch makes sure openssl logs go to default stdout. Example of the garbage on stderr: crypto/anubis.c:581: warning: ‘inter’ is used uninitialized in this function Generating a 4096 bit RSA private key ......... drivers/gpu/drm/i915/i915_gem_gtt.c: In function ‘gen6_ggtt_insert_entries’: drivers/gpu/drm/i915/i915_gem_gtt.c:440: warning: ‘addr’ may be used uninitialized in this function .net/mac80211/tx.c: In function ‘ieee80211_subif_start_xmit’: net/mac80211/tx.c:1780: warning: ‘chanctx_conf’ may be used uninitialized in this function ..drivers/isdn/hardware/mISDN/hfcpci.c: In function ‘hfcpci_softirq’: .....drivers/isdn/hardware/mISDN/hfcpci.c:2298: warning: ignoring return value of ‘driver_for_each_device’, declared with attribute warn_unused_result Signed-off-by: David Cohen <david.a.cohen@intel.com> Reviewed-by: mark gross <mark.gross@intel.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-04-08idle: Provide a generic entry point for the idle codeThomas Gleixner
For now this calls cpu_idle(), but in the long run we want to move the cpu bringup code to the core and therefor we add a state argument. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Reviewed-by: Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Magnus Damm <magnus.damm@gmail.com> Link: http://lkml.kernel.org/r/20130321215233.583190032@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-02-27Merge branch 'akpm' (final batch from Andrew)Linus Torvalds
Merge third patch-bumb from Andrew Morton: "This wraps me up for -rc1. - Lots of misc stuff and things which were deferred/missed from patchbombings 1 & 2. - ocfs2 things - lib/scatterlist - hfsplus - fatfs - documentation - signals - procfs - lockdep - coredump - seqfile core - kexec - Tejun's large IDR tree reworkings - ipmi - partitions - nbd - random() things - kfifo - tools/testing/selftests updates - Sasha's large and pointless hlist cleanup" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (163 commits) hlist: drop the node parameter from iterators kcmp: make it depend on CHECKPOINT_RESTORE selftests: add a simple doc tools/testing/selftests/Makefile: rearrange targets selftests/efivarfs: add create-read test selftests/efivarfs: add empty file creation test selftests: add tests for efivarfs kfifo: fix kfifo_alloc() and kfifo_init() kfifo: move kfifo.c from kernel/ to lib/ arch Kconfig: centralise CONFIG_ARCH_NO_VIRT_TO_BUS w1: add support for DS2413 Dual Channel Addressable Switch memstick: move the dereference below the NULL test drivers/pps/clients/pps-gpio.c: use devm_kzalloc Documentation/DMA-API-HOWTO.txt: fix typo include/linux/eventfd.h: fix incorrect filename is a comment mtd: mtd_stresstest: use prandom_bytes() mtd: mtd_subpagetest: convert to use prandom library mtd: mtd_speedtest: use prandom_bytes mtd: mtd_pagetest: convert to use prandom library mtd: mtd_oobtest: convert to use prandom library ...
2013-02-27kcmp: make it depend on CHECKPOINT_RESTORECyrill Gorcunov
Since kcmp syscall has been implemented (initially on x86 architecture) a number of other archs wire it up as well: xtensa, sparc, sh, s390, mips, microblaze, m68k (not taking into account those who uses <asm-generic/unistd.h> for syscall numbers definitions). But the Makefile, which turns kcmp.o generation on still depends on former config-x86. Thus get rid of this limitation and make kcmp.o depend on CHECKPOINT_RESTORE option. Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Andrey Vagin <avagin@openvz.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-27kfifo: move kfifo.c from kernel/ to lib/Stefani Seibold
Move kfifo.c from kernel/ to lib/ Signed-off-by: Stefani Seibold <stefani@seibold.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-27Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild changes from Michal Marek: - Alias generation in modpost is cross-compile safe. - kernel/timeconst.h is now generated using a bc script instead of perl. - scripts/link-vmlinux.sh now works with an alternative $KCONFIG_CONFIG. - destination-y for exported headers is supported in Kbuild files again. - depmod is called with -P $CONFIG_SYMBOL_PREFIX on architectures that need it. - CONFIG_DEBUG_INFO_REDUCED disables var-tracking - scripts/setlocalversion works with too much translated locales ;) * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kbuild: Fix reading of .config in link-vmlinux.sh kbuild: Unset language specific variables in setlocalversion script Kbuild: Disable var tracking with CONFIG_DEBUG_INFO_REDUCED depmod: pass -P $CONFIG_SYMBOL_PREFIX kbuild: Fix destination-y for installed headers scripts/link-vmlinux.sh: source variables from KCONFIG_CONFIG kernel: Replace timeconst.pl with a bc script mod/file2alias: make modalias generation safe for cross compiling
2013-02-16kernel: Replace timeconst.pl with a bc scriptH. Peter Anvin
bc is the standard tool for multi-precision arithmetic. We switched to Perl because akpm reported a hard-to-reproduce build hang, which was very odd because affected and unaffected machines were all running the same version of GNU bc. Unfortunately switching to Perl required a really ugly "canning" mechanism to support Perl < 5.8 installations lacking the Math::BigInt module. It was recently pointed out to me that some very old versions of GNU make had problems with pipes in subshells, which was indeed the construct used in the Makefile rules in that version of the patch; Perl didn't need it so switching to Perl fixed the problem for unrelated reasons. With the problem (hopefully) root-caused, we can switch back to bc and do the arbitrary-precision arithmetic naturally. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: Andrew Morton <akpm@linux-foundation.org> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-01-25MODSIGN: Simplify Makefile with a Kconfig helperMichal Marek
Signed-off-by: Michal Marek <mmarek@suse.cz> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-12-19Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module update from Rusty Russell: "Nothing all that exciting; a new module-from-fd syscall for those who want to verify the source of the module (ChromeOS) and/or use standard IMA on it or other security hooks." * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: MODSIGN: Fix kbuild output when using default extra_certificates MODSIGN: Avoid using .incbin in C source modules: don't hand 0 to vmalloc. module: Remove a extra null character at the top of module->strtab. ASN.1: Use the ASN1_LONG_TAG and ASN1_INDEFINITE_LENGTH constants ASN.1: Define indefinite length marker constant moduleparam: use __UNIQUE_ID() __UNIQUE_ID() MODSIGN: Add modules_sign make target powerpc: add finit_module syscall. ima: support new kernel module syscall add finit_module syscall to asm-generic ARM: add finit_module syscall to ARM security: introduce kernel_module_from_file hook module: add flags arg to sys_finit_module() module: add syscall to load module from fd
2012-12-14MODSIGN: Fix kbuild output when using default extra_certificatesMichal Marek
Reported-by: Peter Foley <pefoley2@verizon.net> Signed-off-by: Michal Marek <mmarek@suse.cz> Acked-by: Peter Foley <pefoley2@verizon.net> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-12-14MODSIGN: Avoid using .incbin in C sourceTakashi Iwai
Using the asm .incbin statement in C sources breaks any gcc wrapper which assumes that preprocessed C source is self-contained. Use a separate .S file to include the siging key and certificate. [ This means we no longer need SYMBOL_PREFIX which is defined in kernel.h from cbdbf2abb7844548a7d7a6a2ae7af6b6fbcea401, so I removed it -- RR ] Tested-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: James Hogan <james.hogan@imgtec.com>
2012-12-03Merge branch 'rcu/next' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu into core/rcu Conflicts: arch/x86/kernel/ptrace.c Pull the latest RCU tree from Paul E. McKenney: " The major features of this series are: 1. A first version of no-callbacks CPUs. This version prohibits offlining CPU 0, but only when enabled via CONFIG_RCU_NOCB_CPU=y. Relaxing this constraint is in progress, but not yet ready for prime time. These commits were posted to LKML at https://lkml.org/lkml/2012/10/30/724, and are at branch rcu/nocb. 2. Changes to SRCU that allows statically initialized srcu_struct structures. These commits were posted to LKML at https://lkml.org/lkml/2012/10/30/296, and are at branch rcu/srcu. 3. Restructuring of RCU's debugfs output. These commits were posted to LKML at https://lkml.org/lkml/2012/10/30/341, and are at branch rcu/tracing. 4. Additional CPU-hotplug/RCU improvements, posted to LKML at https://lkml.org/lkml/2012/10/30/327, and are at branch rcu/hotplug. Note that the commit eliminating __stop_machine() was judged to be too-high of risk, so is deferred to 3.9. 5. Changes to RCU's idle interface, most notably a new module parameter that redirects normal grace-period operations to their expedited equivalents. These were posted to LKML at https://lkml.org/lkml/2012/10/30/739, and are at branch rcu/idle. 6. Additional diagnostics for RCU's CPU stall warning facility, posted to LKML at https://lkml.org/lkml/2012/10/30/315, and are at branch rcu/stall. The most notable change reduces the default RCU CPU stall-warning time from 60 seconds to 21 seconds, so that it once again happens sooner than the softlockup timeout. 7. Documentation updates, which were posted to LKML at https://lkml.org/lkml/2012/10/30/280, and are at branch rcu/doc. A couple of late-breaking changes were posted at https://lkml.org/lkml/2012/11/16/634 and https://lkml.org/lkml/2012/11/16/547. 8. Miscellaneous fixes, which were posted to LKML at https://lkml.org/lkml/2012/10/30/309, along with a late-breaking change posted at Fri, 16 Nov 2012 11:26:25 -0800 with message-ID <20121116192625.GA447@linux.vnet.ibm.com>, but which lkml.org seems to have missed. These are at branch rcu/fixes. 9. Finally, a fix for an lockdep-RCU splat was posted to LKML at https://lkml.org/lkml/2012/11/7/486. This is at rcu/next. " Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-11-30context_tracking: New context tracking susbsystemFrederic Weisbecker
Create a new subsystem that probes on kernel boundaries to keep track of the transitions between level contexts with two basic initial contexts: user or kernel. This is an abstraction of some RCU code that use such tracking to implement its userspace extended quiescent state. We need to pull this up from RCU into this new level of indirection because this tracking is also going to be used to implement an "on demand" generic virtual cputime accounting. A necessary step to shutdown the tick while still accounting the cputime. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Li Zhong <zhong@linux.vnet.ibm.com> Cc: Gilad Ben-Yossef <gilad@benyossef.com> Reviewed-by: Steven Rostedt <rostedt@goodmis.org> [ paulmck: fix whitespace error and email address. ] Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2012-10-25Makefile: Documentation for external tool should be correctH. Peter Anvin
If one includes documentation for an external tool, it should be correct. This is not: 1. Overriding the input to rngd should typically be neither necessary nor desired. This is especially so since newer versions of rngd support a number of different *types* of sources. 2. The default kernel-exported device is called /dev/hwrng not /dev/hwrandom nor /dev/hw_random (both of which were used in the past; however, kernel and udev seem to have converged on /dev/hwrng.) Overall it is better if the documentation for rngd is kept with rngd rather than in a kernel Makefile. Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Cc: David Howells <dhowells@redhat.com> Cc: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-14Merge branch 'modules-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module signing support from Rusty Russell: "module signing is the highlight, but it's an all-over David Howells frenzy..." Hmm "Magrathea: Glacier signing key". Somebody has been reading too much HHGTTG. * 'modules-next' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (37 commits) X.509: Fix indefinite length element skip error handling X.509: Convert some printk calls to pr_devel asymmetric keys: fix printk format warning MODSIGN: Fix 32-bit overflow in X.509 certificate validity date checking MODSIGN: Make mrproper should remove generated files. MODSIGN: Use utf8 strings in signer's name in autogenerated X.509 certs MODSIGN: Use the same digest for the autogen key sig as for the module sig MODSIGN: Sign modules during the build process MODSIGN: Provide a script for generating a key ID from an X.509 cert MODSIGN: Implement module signature checking MODSIGN: Provide module signing public keys to the kernel MODSIGN: Automatically generate module signing keys if missing MODSIGN: Provide Kconfig options MODSIGN: Provide gitignore and make clean rules for extra files MODSIGN: Add FIPS policy module: signature checking hook X.509: Add a crypto key parser for binary (DER) X.509 certificates MPILIB: Provide a function to read raw data into an MPI X.509: Add an ASN.1 decoder X.509: Add simple ASN.1 grammar compiler ...
2012-10-10MODSIGN: Make mrproper should remove generated files.Rusty Russell
It doesn't, because the clean targets don't include kernel/Makefile, and because two files were missing from the list. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-10MODSIGN: Use utf8 strings in signer's name in autogenerated X.509 certsDavid Howells
Place an indication that the certificate should use utf8 strings into the x509.genkey template generated by kernel/Makefile. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-10MODSIGN: Use the same digest for the autogen key sig as for the module sigDavid Howells
Use the same digest type for the autogenerated key signature as for the module signature so that the hash algorithm is guaranteed to be present in the kernel. Without this, the X.509 certificate loader may reject the X.509 certificate so generated because it was self-signed and the signature will be checked against itself - but this won't work if the digest algorithm must be loaded as a module. The symptom is that the key fails to load with the following message emitted into the kernel log: MODSIGN: Problem loading in-kernel X.509 certificate (-65) the error in brackets being -ENOPKG. What you should see is something like: MODSIGN: Loaded cert 'Magarathea: Glacier signing key: 9588321144239a119d3406d4c4cf1fbae1836fa0' Note that this doesn't apply to certificates that are not self-signed as we don't check those currently as they require the parent CA certificate to be available. Reported-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-10MODSIGN: Provide module signing public keys to the kernelDavid Howells
Include a PGP keyring containing the public keys required to perform module verification in the kernel image during build and create a special keyring during boot which is then populated with keys of crypto type holding the public keys found in the PGP keyring. These can be seen by root: [root@andromeda ~]# cat /proc/keys 07ad4ee0 I----- 1 perm 3f010000 0 0 crypto modsign.0: RSA 87b9b3bd [] 15c7f8c3 I----- 1 perm 1f030000 0 0 keyring .module_sign: 1/4 ... It is probably worth permitting root to invalidate these keys, resulting in their removal and preventing further modules from being loaded with that key. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-10MODSIGN: Automatically generate module signing keys if missingDavid Howells
Automatically generate keys for module signing if they're absent so that allyesconfig doesn't break. The builder should consider generating their own key and certificate, however, so that the keys are appropriately named. The private key for the module signer should be placed in signing_key.priv (unencrypted!) and the public key in an X.509 certificate as signing_key.x509. If a transient key is desired for signing the modules, a config file for 'openssl req' can be placed in x509.genkey, looking something like the following: [ req ] default_bits = 4096 distinguished_name = req_distinguished_name prompt = no x509_extensions = myexts [ req_distinguished_name ] O = Magarathea CN = Glacier signing key emailAddress = slartibartfast@magrathea.h2g2 [ myexts ] basicConstraints=critical,CA:FALSE keyUsage=digitalSignature subjectKeyIdentifier=hash authorityKeyIdentifier=hash The build process will use this to configure: openssl req -new -nodes -utf8 -sha1 -days 36500 -batch \ -x509 -config x509.genkey \ -outform DER -out signing_key.x509 \ -keyout signing_key.priv to generate the key. Note that it is required that the X.509 certificate have a subjectKeyIdentifier and an authorityKeyIdentifier. Without those, the certificate will be rejected. These can be used to check the validity of a certificate. Note that 'make distclean' will remove signing_key.{priv,x509} and x509.genkey, whether or not they were generated automatically. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-10module: signature checking hookRusty Russell
We do a very simple search for a particular string appended to the module (which is cache-hot and about to be SHA'd anyway). There's both a config option and a boot parameter which control whether we accept or fail with unsigned modules and modules that are signed with an unknown key. If module signing is enabled, the kernel will be tainted if a module is loaded that is unsigned or has a signature for which we don't have the key. (Useful feedback and tweaks by David Howells <dhowells@redhat.com>) Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-01Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf update from Ingo Molnar: "Lots of changes in this cycle as well, with hundreds of commits from over 30 contributors. Most of the activity was on the tooling side. Higher level changes: - New 'perf kvm' analysis tool, from Xiao Guangrong. - New 'perf trace' system-wide tracing tool - uprobes fixes + cleanups from Oleg Nesterov. - Lots of patches to make perf build on Android out of box, from Irina Tirdea - Extend ftrace function tracing utility to be more dynamic for its users. It allows for data passing to the callback functions, as well as reading regs as if a breakpoint were to trigger at function entry. The main goal of this patch series was to allow kprobes to use ftrace as an optimized probe point when a probe is placed on an ftrace nop. With lots of help from Masami Hiramatsu, and going through lots of iterations, we finally came up with a good solution. - Add cpumask for uncore pmu, use it in 'stat', from Yan, Zheng. - Various tracing updates from Steve Rostedt - Clean up and improve 'perf sched' performance by elliminating lots of needless calls to libtraceevent. - Event group parsing support, from Jiri Olsa - UI/gtk refactorings and improvements from Namhyung Kim - Add support for non-tracepoint events in perf script python, from Feng Tang - Add --symbols to 'script', similar to the one in 'report', from Feng Tang. Infrastructure enhancements and fixes: - Convert the trace builtins to use the growing evsel/evlist tracepoint infrastructure, removing several open coded constructs like switch like series of strcmp to dispatch events, etc. Basically what had already been showcased in 'perf sched'. - Add evsel constructor for tracepoints, that uses libtraceevent just to parse the /format events file, use it in a new 'perf test' to make sure the libtraceevent format parsing regressions can be more readily caught. - Some strange errors were happening in some builds, but not on the next, reported by several people, problem was some parser related files, generated during the build, didn't had proper make deps, fix from Eric Sandeen. - Introduce struct and cache information about the environment where a perf.data file was captured, from Namhyung Kim. - Fix handling of unresolved samples when --symbols is used in 'report', from Feng Tang. - Add union member access support to 'probe', from Hyeoncheol Lee. - Fixups to die() removal, from Namhyung Kim. - Render fixes for the TUI, from Namhyung Kim. - Don't enable annotation in non symbolic view, from Namhyung Kim. - Fix pipe mode in 'report', from Namhyung Kim. - Move related stats code from stat to util/, will be used by the 'stat' kvm tool, from Xiao Guangrong. - Remove die()/exit() calls from several tools. - Resolve vdso callchains, from Jiri Olsa - Don't pass const char pointers to basename, so that we can unconditionally use libgen.h and thus avoid ifdef BIONIC lines, from David Ahern - Refactor hist formatting so that it can be reused with the GTK browser, From Namhyung Kim - Fix build for another rbtree.c change, from Adrian Hunter. - Make 'perf diff' command work with evsel hists, from Jiri Olsa. - Use the only field_sep var that is set up: symbol_conf.field_sep, fix from Jiri Olsa. - .gitignore compiled python binaries, from Namhyung Kim. - Get rid of die() in more libtraceevent places, from Namhyung Kim. - Rename libtraceevent 'private' struct member to 'priv' so that it works in C++, from Steven Rostedt - Remove lots of exit()/die() calls from tools so that the main perf exit routine can take place, from David Ahern - Fix x86 build on x86-64, from David Ahern. - {int,str,rb}list fixes from Suzuki K Poulose - perf.data header fixes from Namhyung Kim - Allow user to indicate objdump path, needed in cross environments, from Maciek Borzecki - Fix hardware cache event name generation, fix from Jiri Olsa - Add round trip test for sw, hw and cache event names, catching the problem Jiri fixed, after Jiri's patch, the test passes successfully. - Clean target should do clean for lib/traceevent too, fix from David Ahern - Check the right variable for allocation failure, fix from Namhyung Kim - Set up evsel->tp_format regardless of evsel->name being set already, fix from Namhyung Kim - Oprofile fixes from Robert Richter. - Remove perf_event_attr needless version inflation, from Jiri Olsa - Introduce libtraceevent strerror like error reporting facility, from Namhyung Kim - Add pmu mappings to perf.data header and use event names from cmd line, from Robert Richter - Fix include order for bison/flex-generated C files, from Ben Hutchings - Build fixes and documentation corrections from David Ahern - Assorted cleanups from Robert Richter - Let O= makes handle relative paths, from Steven Rostedt - perf script python fixes, from Feng Tang. - Initial bash completion support, from Frederic Weisbecker - Allow building without libelf, from Namhyung Kim. - Support DWARF CFI based unwind to have callchains when %bp based unwinding is not possible, from Jiri Olsa. - Symbol resolution fixes, while fixing support PPC64 files with an .opt ELF section was the end goal, several fixes for code that handles all architectures and cleanups are included, from Cody Schafer. - Assorted fixes for Documentation and build in 32 bit, from Robert Richter - Cache the libtraceevent event_format associated to each evsel early, so that we avoid relookups, i.e. calling pevent_find_event repeatedly when processing tracepoint events. [ This is to reduce the surface contact with libtraceevents and make clear what is that the perf tools needs from that lib: so far parsing the common and per event fields. ] - Don't stop the build if the audit libraries are not installed, fix from Namhyung Kim. - Fix bfd.h/libbfd detection with recent binutils, from Markus Trippelsdorf. - Improve warning message when libunwind devel packages not present, from Jiri Olsa" * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (282 commits) perf trace: Add aliases for some syscalls perf probe: Print an enum type variable in "enum variable-name" format when showing accessible variables perf tools: Check libaudit availability for perf-trace builtin perf hists: Add missing period_* fields when collapsing a hist entry perf trace: New tool perf evsel: Export the event_format constructor perf evsel: Introduce rawptr() method perf tools: Use perf_evsel__newtp in the event parser perf evsel: The tracepoint constructor should store sys:name perf evlist: Introduce set_filter() method perf evlist: Renane set_filters method to apply_filters perf test: Add test to check we correctly parse and match syscall open parms perf evsel: Handle endianity in intval method perf evsel: Know if byte swap is needed perf tools: Allow handling a NULL cpu_map as meaning "all cpus" perf evsel: Improve tracepoint constructor setup tools lib traceevent: Fix error path on pevent_parse_event perf test: Fix build failure trace: Move trace event enable from fs_initcall to core_initcall tracing: Add an option for disabling markers ...
2012-09-13trace: Stop compiling in trace_clock unconditionallyJosh Triplett
Commit 56449f437 "tracing: make the trace clocks available generally", in April 2009, made trace_clock available unconditionally, since CONFIG_X86_DS used it too. Commit faa4602e47 "x86, perf, bts, mm: Delete the never used BTS-ptrace code", in March 2010, removed CONFIG_X86_DS, and now only CONFIG_RING_BUFFER (split out from CONFIG_TRACING for general use) has a dependency on trace_clock. So, only compile in trace_clock with CONFIG_RING_BUFFER or CONFIG_TRACING enabled. Link: http://lkml.kernel.org/r/20120903024513.GA19583@leaf Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-08-13hotplug: Fix UP bug in smpboot hotplug codePaul E. McKenney
Because kernel subsystems need their per-CPU kthreads on UP systems as well as on SMP systems, the smpboot hotplug kthread functions must be provided in UP builds as well as in SMP builds. This commit therefore adds smpboot.c to UP builds and excludes irrelevant code via #ifdef. Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-06-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs changes from Al Viro. "A lot of misc stuff. The obvious groups: * Miklos' atomic_open series; kills the damn abuse of ->d_revalidate() by NFS, which was the major stumbling block for all work in that area. * ripping security_file_mmap() and dealing with deadlocks in the area; sanitizing the neighborhood of vm_mmap()/vm_munmap() in general. * ->encode_fh() switched to saner API; insane fake dentry in mm/cleancache.c gone. * assorted annotations in fs (endianness, __user) * parts of Artem's ->s_dirty work (jff2 and reiserfs parts) * ->update_time() work from Josef. * other bits and pieces all over the place. Normally it would've been in two or three pull requests, but signal.git stuff had eaten a lot of time during this cycle ;-/" Fix up trivial conflicts in Documentation/filesystems/vfs.txt (the 'truncate_range' inode method was removed by the VM changes, the VFS update adds an 'update_time()' method), and in fs/btrfs/ulist.[ch] (due to sparse fix added twice, with other changes nearby). * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (95 commits) nfs: don't open in ->d_revalidate vfs: retry last component if opening stale dentry vfs: nameidata_to_filp(): don't throw away file on error vfs: nameidata_to_filp(): inline __dentry_open() vfs: do_dentry_open(): don't put filp vfs: split __dentry_open() vfs: do_last() common post lookup vfs: do_last(): add audit_inode before open vfs: do_last(): only return EISDIR for O_CREAT vfs: do_last(): check LOOKUP_DIRECTORY vfs: do_last(): make ENOENT exit RCU safe vfs: make follow_link check RCU safe vfs: do_last(): use inode variable vfs: do_last(): inline walk_component() vfs: do_last(): make exit RCU safe vfs: split do_lookup() Btrfs: move over to use ->update_time fs: introduce inode operation ->update_time reiserfs: get rid of resierfs_sync_super reiserfs: mark the superblock as dirty a bit later ...
2012-05-31Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull second pile of signal handling patches from Al Viro: "This one is just task_work_add() series + remaining prereqs for it. There probably will be another pull request from that tree this cycle - at least for helpers, to get them out of the way for per-arch fixes remaining in the tree." Fix trivial conflict in kernel/irq/manage.c: the merge of Andrew's pile had brought in commit 97fd75b7b8e0 ("kernel/irq/manage.c: use the pr_foo() infrastructure to prefix printks") which changed one of the pr_err() calls that this merge moves around. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: keys: kill task_struct->replacement_session_keyring keys: kill the dummy key_replace_session_keyring() keys: change keyctl_session_to_parent() to use task_work_add() genirq: reimplement exit_irq_thread() hook via task_work_add() task_work_add: generic process-context callbacks avr32: missed _TIF_NOTIFY_RESUME on one of do_notify_resume callers parisc: need to check NOTIFY_RESUME when exiting from syscall move key_repace_session_keyring() into tracehook_notify_resume() TIF_NOTIFY_RESUME is defined on all targets now
2012-05-31syscalls, x86: add __NR_kcmp syscallCyrill Gorcunov
While doing the checkpoint-restore in the user space one need to determine whether various kernel objects (like mm_struct-s of file_struct-s) are shared between tasks and restore this state. The 2nd step can be solved by using appropriate CLONE_ flags and the unshare syscall, while there's currently no ways for solving the 1st one. One of the ways for checking whether two tasks share e.g. mm_struct is to provide some mm_struct ID of a task to its proc file, but showing such info considered to be not that good for security reasons. Thus after some debates we end up in conclusion that using that named 'comparison' syscall might be the best candidate. So here is it -- __NR_kcmp. It takes up to 5 arguments - the pids of the two tasks (which characteristics should be compared), the comparison type and (in case of comparison of files) two file descriptors. Lookups for pids are done in the caller's PID namespace only. At moment only x86 is supported and tested. [akpm@linux-foundation.org: fix up selftests, warnings] [akpm@linux-foundation.org: include errno.h] [akpm@linux-foundation.org: tweak comment text] Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Andrey Vagin <avagin@openvz.org> Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Glauber Costa <glommer@parallels.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Tejun Heo <tj@kernel.org> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Vasiliy Kulikov <segoon@openwall.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Valdis.Kletnieks@vt.edu Cc: Michal Marek <mmarek@suse.cz> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29brlocks/lglocks: turn into functionsAndi Kleen
lglocks and brlocks are currently generated with some complicated macros in lglock.h. But there's no reason to not just use common utility functions and put all the data into a common data structure. Since there are at least two users it makes sense to share this code in a library. This is also easier maintainable than a macro forest. This will also make it later possible to dynamically allocate lglocks and also use them in modules (this would both still need some additional, but now straightforward, code) [akpm@linux-foundation.org: checkpatch fixes] Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-23task_work_add: generic process-context callbacksOleg Nesterov
Provide a simple mechanism that allows running code in the (nonatomic) context of the arbitrary task. The caller does task_work_add(task, task_work) and this task executes task_work->func() either from do_notify_resume() or from do_exit(). The callback can rely on PF_EXITING to detect the latter case. "struct task_work" can be embedded in another struct, still it has "void *data" to handle the most common/simple case. This allows us to kill the ->replacement_session_keyring hack, and potentially this can have more users. Performance-wise, this adds 2 "unlikely(!hlist_empty())" checks into tracehook_notify_resume() and do_exit(). But at the same time we can remove the "replacement_session_keyring != NULL" checks from arch/*/signal.c and exit_creds(). Note: task_work_add/task_work_run abuses ->pi_lock. This is only because this lock is already used by lookup_pi_state() to synchronize with do_exit() setting PF_EXITING. Fortunately the scope of this lock in task_work.c is really tiny, and the code is unlikely anyway. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Alexander Gordeev <agordeev@redhat.com> Cc: Chris Zankel <chris@zankel.net> Cc: David Smith <dsmith@redhat.com> Cc: "Frank Ch. Eigler" <fche@redhat.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Larry Woodman <lwoodman@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Tejun Heo <tj@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-04-26smp: Add generic smpboot facilityThomas Gleixner
Start a new file, which will hold SMP and CPU hotplug related generic infrastructure. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: James E.J. Bottomley <jejb@parisc-linux.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: David S. Miller <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Richard Weinberger <richard@nod.at> Cc: x86@kernel.org Link: http://lkml.kernel.org/r/20120420124557.035417523@linutronix.de
