commit b290ebe2c46d01b742b948ce03f09e8a3efb9a92 upstream.
Fix the one describing what this function is and add one more - about
locking absence around pid namespaces loop.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
This just makes the acct_proces walk the pid namespaces from current up to
the top and account a task in each with the accounting turned on.
ns->parent access if safe lockless, since current it still alive and holds
its namespace, which in turn holds its parent.
Cc: Balbir Singh <balbir@in.ibm.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
All the bsd_acct_strcts with opened accounting are linked into a global
list. So, the acct_auto_close(_mnt) walks one and drops the accounting
for each.
Allocate the structure on the first call to sys_acct(). After this each
namespace, that ordered the accounting, will live with this structure till
its own death.
Two notes
- routines, that close the accounting on fs umount time use
the init_pid_ns's acct by now;
- accounting routine accounts to dying task's namespace
(also by now).
This adds the appropriate pointer to all the internal (i.e. static)
functions that work with global acct instance. API calls pass a global
instance to them (while we still have such).
Mostly this is a s/acct_globals./acct->/ over the file.
Don't use per-bsd-acct-struct lock, but work with a global one.
This lock is taken for short periods, so it doesn't seem it'll become a
bottleneck, but it will allow us to easily avoid many locking difficulties
in the future.
So this is a mostly s/acct_globals.lock/acct_lock/ over the file.
We're going to have many bsd_acct_struct instances, not just one, so the
timer (currently working with a global one) has to know which one to work
with.
Use a handy setup_timer macro for it (thanks to Oleg for one).
The acct_process does not accept any arguments actually.
After I fixed access to task->tgid in kernel/acct.c, Oleg pointed out some
bad side effects with this accounting vs pid namespaces interaction. I.e.
when some task in pid namespace sets this accounting up, this blocks all
the others from doing the same. Restricting this to init namespace only
could help, but didn't look a graceful solution.
So here is the approach to make this accounting work with pid namespaces
properly.
The idea is simple - when a task dies it accounts itself in each namespace
it is visible from and which set the accounting up.
For example here are the commands run and the output of lastcomm from init
and sub namespaces:
init_ns# accton pacct
sub_ns# accton pacct (this is a different file - sub ns is run in
a chroot-ed environment)
init_ns# cat /dev/null
sub_ns# ls /dev/null
init_ns# accton
sub_ns# accton
sub_ns# lastcomm -f pacct
ls 0 [136,0] 0.00 secs Thu May 15 10:30
accton 0 [136,0] 0.00 secs Thu May 15 10:30
init_ns# lastcomm -f pacct
accton root pts/0 0.00 secs Thu May 15 14:30 << got from sub
cat root pts/1 0.00 secs Thu May 15 14:30
ls root pts/0 0.00 secs Thu May 15 14:30 << got from sub
accton root pts/1 0.00 secs Thu May 15 14:30
That was the summary, the details are in patches.
This patch:
It will be visible in pid_namespace.h file, so fix its name to look better
outside the acct.c file.
In case we're accounting from a sub-namespace, the tgids reported will not
refer to the right namespace.
Save the pid_namespace we're accounting in on the acct_glbs and use it in
do_acct_process.
Two less :) places using the task_struct.tgid member.
Cc: Oleg Nesterov <oleg@tv-sign.ru>
Cc: "Paul E. McKenney" <paulmck@us.ibm.com>
This is minor, but dereferencing even current real_parent is not safe on debug
kernels, since the memory, this points to, can be unmapped - RCU protection is
required.
Besides, the tgid field is deprecated and is to be replaced with task_tgid_xxx
call (the 2nd patch), so RCU will be required anyway.
The ac_ppid field reported in process accounting records
should match what getppid() would have returned to that
process, regardless of whether a debugger is attached.
Signed-off-by: Roland McGrath <roland@redhat.com>
fix kernel/acct.c comment.
noticed by Lin Tan. Comment suggested by Olaf Kirch.
also see:
http://bugzilla.kernel.org/show_bug.cgi?id=8220
Reported-by: tammy000@gmail.com
Lots of converting spaces to tabs.
Signed-off-by: Daniel Walker <dwalker@mvista.com>
This avoids use of the kernel-internal "xtime" variable directly outside
of the actual time-related functions. Instead, use the helper functions
that we already have available to us.
This doesn't actually change any behaviour, but this will allow us to
fix the fact that "xtime" isn't updated very often with CONFIG_NO_HZ
(because much of the realtime information is maintained as separate
offsets to 'xtime'), which has caused interfaces that use xtime directly
to get a time that is out of sync with the real-time clock by up to a
third of a second or so.
Signed-off-by: John Stultz <johnstul@us.ibm.com>
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in
linux/kernel/.
Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu>
No need to take the global tty_mutex, signal->tty->driver can't go away while
we are holding ->siglock.
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Fix the locking of signal->tty.
Use ->sighand->siglock to protect ->signal->tty; this lock is already used
by most other members of ->signal/->sighand. And unless we are 'current'
or the tasklist_lock is held we need ->siglock to access ->signal anyway.
(NOTE: sys_unshare() is broken wrt ->sighand locking rules)
Note that tty_mutex is held over tty destruction, so while holding
tty_mutex any tty pointer remains valid. Otherwise the lifetime of ttys
are governed by their open file handles. This leaves some holes for tty
access from signal->tty (or any other non file related tty access).
It solves the tty SLAB scribbles we were seeing.
(NOTE: the change from group_send_sig_info to __group_send_sig_info needs to
be examined by someone familiar with the security framework, I think
it is safe given the SEND_SIG_PRIV from other __group_send_sig_info
invocations)
[schwidefsky@de.ibm.com: 3270 fix]
[akpm@osdl.org: various post-viro fixes]
Acked-by: Alan Cox <alan@redhat.com>
Cc: Prarit Bhargava <prarit@redhat.com>
Cc: Chris Wright <chrisw@sous-sol.org>
Cc: Roland McGrath <roland@redhat.com>
Cc: Stephen Smalley <sds@tycho.nsa.gov>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Jan Kara <jack@ucw.cz>
Name some of the remaning 'old_style_spin_init' locks
There were a few accounting data/macros that are used in CSA but are #ifdef'ed
inside CONFIG_BSD_PROCESS_ACCT. This patch is to change those ifdef's from
CONFIG_BSD_PROCESS_ACCT to CONFIG_TASK_XACCT. A few defines are moved from
kernel/acct.c and include/linux/acct.h to kernel/tsacct.c and
include/linux/tsacct_kern.h.
Signed-off-by: Jay Lan <jlan@sgi.com>
Cc: Shailabh Nagar <nagar@watson.ibm.com>
Cc: Jes Sorensen <jes@sgi.com>
Cc: Chris Sturtivant <csturtiv@sgi.com>
Cc: Tony Ernst <tee@sgi.com>
Cc: Guillaume Thouvenin <guillaume.thouvenin@bull.net>
Add tty locking around the audit and accounting code.
The whole current->signal-> locking is all deeply strange but it's for
someone else to sort out. Add rather than replace the lock for acct.c
Signed-off-by: Alan Cox <alan@redhat.com>
Acked-by: Arjan van de Ven <arjan@linux.intel.com>
IRQs must be disabled before taking ->siglock.
Noticed by lockdep.
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Cc: Arjan van de Ven <arjan@infradead.org>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
Fix kernel-doc parameters in kernel/
Warning(/var/linsrc/linux-2617-g9//kernel/auditsc.c:1376): No description found for parameter 'u_abs_timeout'
Warning(/var/linsrc/linux-2617-g9//kernel/auditsc.c:1420): No description found for parameter 'u_msg_prio'
Warning(/var/linsrc/linux-2617-g9//kernel/auditsc.c:1420): No description found for parameter 'u_abs_timeout'
Warning(/var/linsrc/linux-2617-g9//kernel/acct.c:526): No description found for parameter 'pacct'
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
kernel/acct.c:579:19: warning: non-ANSI function declaration of function 'acct_process'
In current 2.6.17 implementation, signal_struct refered from task_struct is
used for per-process data structure. The pacct facility also uses it as a
per-process data structure to store stime, utime, minflt, majflt. But those
members are saved in __exit_signal(). It's too late.
For example, if some threads exits at same time, pacct facility has a
possibility to drop accountings for a part of those threads. (see, the
following 'The results of original 2.6.17 kernel') I think accounting
information should be completely collected into the per-process data structure
before writing out an accounting record.
This patch fixes this matter. Accumulation of stime, utime, minflt and majflt
are done before generating accounting record.
[mingo@elte.hu: fix acct_collect() siglock bug found by lockdep]
Signed-off-by: KaiGai Kohei <kaigai@ak.jp.nec.com>
process
When pacct facility generate an 'ac_flag' field in accounting record, it
refers a task_struct of the thread which died last in the process. But any
other task_structs are ignored.
Therefore, pacct facility drops ASU flag even if root-privilege operations are
used by any other threads except the last one. In addition, AFORK flag is
always set when the thread of group-leader didn't die last, although this
process has called execve() after fork().
We have a same matter in ac_exitcode. The recorded ac_exitcode is an exit
code of the last thread in the process. There is a possibility this exitcode
is not the group leader's one.
The pacct facility need an i/o operation when an accounting record is
generated. There is a possibility to wake OOM killer up. If OOM killer is
activated, it kills some processes to make them release process memory
regions.
But acct_process() is called in the killed processes context before calling
exit_mm(), so those processes cannot release own memory. In the results, any
processes stop in this point and it finally cause a system stall.
copy_process() appears to be the only caller of acct_clear_integrals() and
does not pass in NULL task pointers. Remove the unecessary check.
Signed-off-by: Matt Helsley <matthltc@us.ibm.com>
Give the statfs superblock operation a dentry pointer rather than a superblock
pointer.
This complements the get_sb() patch. That reduced the significance of
sb->s_root, allowing NFS to place a fake root there. However, NFS does
require a dentry to use as a target for the statfs operation. This permits
the root in the vfsmount to be used instead.
linux/mount.h has been added where necessary to make allyesconfig build
successfully.
Interest has also been expressed for use with the FUSE and XFS filesystems.
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Cc: Nathan Scott <nathans@sgi.com>
I noticed a bug on the process accounting facility. In multi-threading
process, some data would be recorded incorrectly when the group_leader dies
earlier than one or more threads. The attached patch fixes this problem.
See below. 'bugacct' is a test program that create a worker thread after 4
seconds sleeping, then the group_leader dies soon. The worker thread
consume CPU/Memory for 6 seconds, then exit. We can estimate 10 seconds as
etime and 6 seconds as stime + utime. This is a sample program which the
group_leader dies earlier than other threads.
The results of same binary execution on different kernel are below.
-- accounted records --------------------
| btime | utime | stime | etime | minflt | majflt | comm |
original | 13:16:40 | 0.00 | 0.00 | 6.10 | 171 | 0 | bugacct |
patched | 13:20:21 | 5.83 | 0.18 | 10.03 | 32776 | 0 | bugacct |
(*) bugacct allocates 128MB memory, thus 128MB / 4KB = 32768 of minflt is
appropriate.
-- Test results in original kernel ------
$ date; time -p ./bugacct
Tue Mar 28 13:16:36 JST 2006 <- But pacct said btime is 13:16:40
real 10.11 <- But pacct said etime is 6.10
user 5.96 <- But pacct said utime is 0.00
sys 0.14 <- But pacct said stime is 0.00
-- Test results in patched kernel -------
Tue Mar 28 13:20:21 JST 2006
real 10.04
user 5.83
sys 0.19
In the original 2.6.16 kernel, pacct records btime, utime, stime, etime and
minflt incorrectly. In my opinion, this problem is caused by an assumption
that group_leader dies last.
The following section calculates process running time for etime and btime.
But it means running time of the thread that dies last, not process. The
start_time of the first thread in the process (group_leader) should be
reduced from uptime to calculate etime and btime correctly.
---- do_acct_process() in kernel/acct.c:
/* calculate run_time in nsec*/
do_posix_clock_monotonic_gettime(&uptime);
run_time = (u64)uptime.tv_sec*NSEC_PER_SEC + uptime.tv_nsec;
run_time -= (u64)current->start_time.tv_sec*NSEC_PER_SEC
+ current->start_time.tv_nsec;
The following section calculates stime and utime of the process.
But it might count the utime and stime of the group_leader duplicatly
and ignore the utime and stime of the thread dies last, when one or
more threads remain after group_leader dead.
The ac_utime should be calculated as the sum of the signal->utime
and utime of the thread dies last. The ac_stime should be done also.
jiffies = cputime_to_jiffies(cputime_add(current->group_leader->utime,
current->signal->utime));
ac.ac_utime = encode_comp_t(jiffies_to_AHZ(jiffies));
jiffies = cputime_to_jiffies(cputime_add(current->group_leader->stime,
current->signal->stime));
ac.ac_stime = encode_comp_t(jiffies_to_AHZ(jiffies));
The part of the minflt/majflt calculation has same problem.
This patch solves those problems, I think.
- Move capable() from sched.h to capability.h;
- Use <linux/capability.h> where capable() is used
(in include/, block/, ipc/, kernel/, a few drivers/,
mm/, security/, & sound/;
many more drivers/ to go)
There are some more places where the use of cputime_t instead of an integer
type and the associated macros is necessary for the virtual cputime accounting
on s390. Affected are the s390 specific appldata code and BSD process
accounting.
The way we currently deal with quota and process accounting that might
keep vfsmount busy at umount time is inherently broken; we try to turn
them off just in case (not quite correctly, at that) and
a) pray umount doesn't fail (otherwise they'll stay turned off)
b) pray nobody doesn anything funny just as we turn quota off
Moreover, LSM provides hooks for doing the same sort of broken logics.
The proper way to deal with that is to introduce the second kind of
reference to vfsmount. Semantics:
- when the last normal reference is dropped, all special ones are
converted to normal ones and if there had been any, cleanup is done.
- normal reference can be cloned into a special one
- special reference can be converted to normal one; that's a no-op if
we'd already passed the point of no return (i.e. mntput() had
converted special references to normal and started cleanup).
The way it works: e.g. starting process accounting converts the vfsmount
reference pinned by the opened file into special one and turns it back
to normal when it gets shut down; acct_auto_close() is done when no
normal references are left. That way it does *not* obstruct umount(2)
and it silently gets turned off when the last normal reference to
vfsmount is gone. Which is exactly what we want...
The same should be done by LSM module that holds some internal
references to vfsmount and wants to shut them down on umount - it should
make them special and security_sb_umount_close() will be called exactly
when the last normal reference to vfsmount is gone.
quota handling is even simpler - we don't use normal file IO anymore, so
there's no need to hold vfsmounts at all. DQUOT_OFF() is done from
deactivate_super(), where it really belongs.
I was lazy when we added anon_rss, and chose to change as few places as
possible. So currently each anonymous page has to be counted twice, in rss
and in anon_rss. Which won't be so good if those are atomic counts in some
configurations.
Change that around: keep file_rss and anon_rss separately, and add them
together (with get_mm_rss macro) when the total is needed - reading two
atomics is much cheaper than updating two atomics. And update anon_rss
upfront, typically in memory.c, not tucked away in page_add_anon_rmap.
Signed-off-by: Hugh Dickins <hugh@veritas.com>
for kernel/acct.c:
- fix typos
- add kerneldoc for non-static functions
There is a problem in the accounting subsystem in the kernel can not
correctly handle files larger than 2GB. The output file containing the
process accounting data can grow very large if the system is large enough
and active enough. If the 2GB limit is reached, then the system simply
stops storing process accounting data.
Another annoying problem is that once the system reaches this 2GB limit,
then every process which exits will receive a signal, SIGXFSZ. This signal
is generated because an attempt was made to write beyond the limit for the
file descriptor. This signal makes it look like every process has exited
due to a signal, when in fact, they have not.
The solution is to add the O_LARGEFILE flag to the list of flags used to
open the accounting file. The rest of the accounting support is already
largefile safe.
The changes were tested by constructing a large file (just short of 2GB),
enabling accounting, and then running enough commands to cause the
accounting data generated to increase the size of the file to 2GB. Without
the changes, the file grows to 2GB and the last command run in the test
script appears to exit due a signal when it has not. With the changes,
things work as expected and quietly.
There are some user level changes required so that it can deal with
largefiles, but those are being handled separately.
Signed-off-by: Peter Staubach <staubach@redhat.com>
infrastructure for it.
Let it rip!
