path: root/kernel/audit.c
2010-10-30audit: Use rcu for task lookup protectionThomas Gleixner
Protect the task lookups in audit_receive_msg() with rcu_read_lock() instead of tasklist_lock and use lock/unlock_sighand to protect against the exit race. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Eric Paris <eparis@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-30audit: Do not send uninitialized data for AUDIT_TTY_GETThomas Gleixner
audit_receive_msg() sends uninitialized data for AUDIT_TTY_GET when the task was not found. Send reply only when task was found. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-30audit: Call tty_audit_push_task() outside preempt disabledThomas Gleixner
While auditing all tasklist_lock read_lock sites I stumbled over the following call chain: audit_prepare_user_tty() read_lock(&tasklist_lock); tty_audit_push_task(); mutex_lock(&buf->mutex); --> buf->mutex is locked with preemption disabled. Solve this by acquiring a reference to the task struct under rcu_read_lock and call tty_audit_push_task outside of the preempt disabled region. Move all code which needs to be protected by sighand lock into tty_audit_push_task() and use lock/unlock_sighand as we do not hold tasklist_lock. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Eric Paris <eparis@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-30audit: make functions staticStephen Hemminger
I was doing some namespace checks and found some simple stuff in audit that could be cleaned up. Make some functions static, and put const on make_reply payload arg. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-10Merge branch 'for-linus' of git://git.infradead.org/users/eparis/notifyLinus Torvalds
* 'for-linus' of git://git.infradead.org/users/eparis/notify: (132 commits) fanotify: use both marks when possible fsnotify: pass both the vfsmount mark and inode mark fsnotify: walk the inode and vfsmount lists simultaneously fsnotify: rework ignored mark flushing fsnotify: remove global fsnotify groups lists fsnotify: remove group->mask fsnotify: remove the global masks fsnotify: cleanup should_send_event fanotify: use the mark in handler functions audit: use the mark in handler functions dnotify: use the mark in handler functions inotify: use the mark in handler functions fsnotify: send fsnotify_mark to groups in event handling functions fsnotify: Exchange list heads instead of moving elements fsnotify: srcu to protect read side of inode and vfsmount locks fsnotify: use an explicit flag to indicate fsnotify_destroy_mark has been called fsnotify: use _rcu functions for mark list traversal fsnotify: place marks on object in order of group memory address vfs/fsnotify: fsnotify_close can delay the final work in fput fsnotify: store struct file not struct path ... Fix up trivial delete/modify conflict in fs/notify/inotify/inotify.c.
2010-07-28Audit: clean up the audit_watch splitEric Paris
No real changes, just cleanup to the audit_watch split patch which we done with minimal code changes for easy review. Now fix interfaces to make things work better. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-20drop_monitor: convert some kfree_skb call sites to consume_skbNeil Horman
Convert a few calls from kfree_skb to consume_skb Noticed while I was working on dropwatch that I was detecting lots of internal skb drops in several places. While some are legitimate, several were not, freeing skbs that were at the end of their life, rather than being discarded due to an error. This patch converts those calls sites from using kfree_skb to consume_skb, which quiets the in-kernel drop_monitor code from detecting them as drops. Tested successfully by myself Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-05Fix misspelling of "should" and "shouldn't" in comments.Adam Buchbinder
Some comments misspell "should" or "shouldn't"; this fixes them. No code changes. Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-24Audit: send signal info if selinux is disabledEric Paris
Audit will not respond to signal requests if selinux is disabled since it is unable to translate the 0 sid from the sending process to a context. This patch just doesn't send the context info if there isn't any. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-24Fix rule eviction order for AUDIT_DIRAl Viro
If syscall removes the root of subtree being watched, we definitely do not want the rules refering that subtree to be destroyed without the syscall in question having a chance to match them. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-24Audit: clean up all op= output to include string quotingEric Paris
A number of places in the audit system we send an op= followed by a string that includes spaces. Somehow this works but it's just wrong. This patch moves all of those that I could find to be quoted. Example: Change From: type=CONFIG_CHANGE msg=audit(1244666690.117:31): auid=0 ses=1 subj=unconfined_u:unconfined_r:auditctl_t:s0-s0:c0.c1023 op=remove rule key="number2" list=4 res=0 Change To: type=CONFIG_CHANGE msg=audit(1244666690.117:31): auid=0 ses=1 subj=unconfined_u:unconfined_r:auditctl_t:s0-s0:c0.c1023 op="remove rule" key="number2" list=4 res=0 Signed-off-by: Eric Paris <eparis@redhat.com>
2009-06-23audit: seperate audit inode watches into a subfileEric Paris
In preparation for converting audit to use fsnotify instead of inotify we seperate the inode watching code into it's own file. This is similar to how the audit tree watching code is already seperated into audit_tree.c Signed-off-by: Eric Paris <eparis@redhat.com>
2009-06-23Audit: clean up audit_receive_skbEric Paris
audit_receive_skb is hard to clearly parse what it is doing to the netlink message. Clean the function up so it is easy and clear to see what is going on. Signed-off-by: Eric Paris <eparis@redhat.com>
2009-06-23Audit: cleanup netlink mesg handlingEric Paris
The audit handling of netlink messages is all over the place. Clean things up, use predetermined macros, generally make it more readable. Signed-off-by: Eric Paris <eparis@redhat.com>
2009-06-23Audit: unify the printk of an skb when auditd not aroundEric Paris
Remove code duplication of skb printk when auditd is not around in userspace to deal with this message. Signed-off-by: Eric Paris <eparis@redhat.com>
2009-04-05Audit: remove spaces from audit_log_d_pathEric Paris
audit_log_d_path had spaces in the strings which would be emitted on the error paths. This patch simply replaces those spaces with an _ or removes the needless spaces entirely. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-05audit: ignore terminating NUL in AUDIT_USER_TTY messagesMiloslav Trmac
AUDIT_USER_TTY, like all other messages sent from user-space, is sent NUL-terminated. Unlike other user-space audit messages, which come only from trusted sources, AUDIT_USER_TTY messages are processed using audit_log_n_untrustedstring(). This patch modifies AUDIT_USER_TTY handling to ignore the trailing NUL and use the "quoted_string" representation of the message if possible. Signed-off-by: Miloslav Trmac <mitr@redhat.com> Cc: Eric Paris <eparis@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Steve Grubb <sgrubb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-05Audit: fix handling of 'strings' with NULL charactersMiloslav Trmac
currently audit_log_n_untrustedstring() uses audit_string_contains_control() to check if the 'string' has any control characters. If the 'string' has an embedded NULL audit_string_contains_control() will return that the data has no control characters and will then pass the string to audit_log_n_string with the total length, not the length up to the first NULL. audit_log_n_string() does a memcpy of the entire length and so the actual audit record emitted may then contain a NULL and then whatever random memory is after the NULL. Since we want to log the entire octet stream (if we can't trust the data to be a string we can't trust that a NULL isn't actually a part of it) we should just consider NULL as a control character. If the caller is certain they want to stop at the first NULL they should be using audit_log_untrustedstring. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-12-09[PATCH] fix broken timestamps in AVC generated by kernel threadsAl Viro
Timestamp in audit_context is valid only if ->in_syscall is set. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-12-09[PATCH] Audit: make audit=0 actually turn off auditEric Paris
Currently audit=0 on the kernel command line does absolutely nothing. Audit always loads and always uses its resources such as creating the kernel netlink socket. This patch causes audit=0 to actually disable audit. Audit will use no resources and starting the userspace auditd daemon will not cause the kernel audit system to activate. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-08-01[PATCH] Fix the bug of using AUDIT_STATUS_RATE_LIMIT when set fail, no error ↵zhangxiliang
output. When the "status_get->mask" is "AUDIT_STATUS_RATE_LIMIT || AUDIT_STATUS_BACKLOG_LIMIT". If "audit_set_rate_limit" fails and "audit_set_backlog_limit" succeeds, the "err" value will be greater than or equal to 0. It will miss the failure of rate set. Signed-off-by: Zhang Xiliang <zhangxiliang@cn.fujitsu.com> Acked-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-08-01kernel/audit.c control character detection is off-by-oneVesa-Matti J Kari
Hello, According to my understanding there is an off-by-one bug in the function: audit_string_contains_control() in: kernel/audit.c Patch is included. I do not know from how many places the function is called from, but for example, SELinux Access Vector Cache tries to log untrusted filenames via call path: avc_audit() audit_log_untrustedstring() audit_log_n_untrustedstring() audit_string_contains_control() If audit_string_contains_control() detects control characters, then the string is hex-encoded. But the hex=0x7f dec=127, DEL-character, is not detected. I guess this could have at least some minor security implications, since a user can create a filename with 0x7f in it, causing logged filename to possibly look different when someone reads it on the terminal. Signed-off-by: Vesa-Matti Kari <vmkari@cc.helsinki.fi> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-06-24[PATCH] remove useless argument type in audit_filter_user()Peng Haitao
The second argument "type" is not used in audit_filter_user(), so I think that type can be removed. If I'm wrong, please tell me. Signed-off-by: Peng Haitao <penght@cn.fujitsu.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-06-24[PATCH] kernel/audit.c: nlh->nlmsg_type is gotten more than oncePeng Haitao
The first argument "nlh->nlmsg_type" of audit_receive_filter() should be modified to "msg_type" in audit_receive_msg(). Signed-off-by: Peng Haitao <penght@cn.fujitsu.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-05-17[patch 1/1] audit_send_reply(): fix error-path memory leakAndrew Morton
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=10663 Reporter: Daniel Marjamki <danielm77@spray.se> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-28[patch 2/2] Use find_task_by_vpid in audit codePavel Emelyanov
The pid to lookup a task by is passed inside audit code via netlink message. Thanks to Denis Lunev, netlink packets are now (since 2.6.24) _always_ processed in the context of the sending task. So this is correct to lookup the task with find_task_by_vpid() here. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-28[PATCH 2/2] audit: fix sparse shadowed variable warningsHarvey Harrison
Use msglen as the identifier. kernel/audit.c:724:10: warning: symbol 'len' shadows an earlier one kernel/audit.c:575:8: originally declared here Don't use ino_f to check the inode field at the end of the functions. kernel/auditfilter.c:429:22: warning: symbol 'f' shadows an earlier one kernel/auditfilter.c:420:21: originally declared here kernel/auditfilter.c:542:22: warning: symbol 'f' shadows an earlier one kernel/auditfilter.c:529:21: originally declared here i always used as a counter for a for loop and initialized to zero before use. Eliminate the inner i variables. kernel/auditsc.c:1295:8: warning: symbol 'i' shadows an earlier one kernel/auditsc.c:1152:6: originally declared here kernel/auditsc.c:1320:7: warning: symbol 'i' shadows an earlier one kernel/auditsc.c:1152:6: originally declared here Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-28Audit: standardize string audit interfacesEric Paris
This patch standardized the string auditing interfaces. No userspace changes will be visible and this is all just cleanup and consistancy work. We have the following string audit interfaces to use: void audit_log_n_hex(struct audit_buffer *ab, const unsigned char *buf, size_t len); void audit_log_n_string(struct audit_buffer *ab, const char *buf, size_t n); void audit_log_string(struct audit_buffer *ab, const char *buf); void audit_log_n_untrustedstring(struct audit_buffer *ab, const char *string, size_t n); void audit_log_untrustedstring(struct audit_buffer *ab, const char *string); This may be the first step to possibly fixing some of the issues that people have with the string output from the kernel audit system. But we still don't have an agreed upon solution to that problem. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-28Audit: stop deadlock from signals under loadEric Paris
A deadlock is possible between kauditd and auditd under load if auditd receives a signal. When auditd receives a signal it sends a netlink message to the kernel asking for information about the sender of the signal. In that same context the audit system will attempt to send a netlink message back to the userspace auditd. If kauditd has already filled the socket buffer (see netlink_attachskb()) auditd will now put itself to sleep waiting for room to send the message. Since auditd is responsible for draining that socket we have a deadlock. The fix, since the response from the kernel does not need to be synchronous is to send the signal information back to auditd in a separate thread. And thus auditd can continue to drain the audit queue normally. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-28Audit: save audit_backlog_limit audit messages in case auditd comes backEric Paris
This patch causes the kernel audit subsystem to store up to audit_backlog_limit messages for use by auditd if it ever appears sometime in the future in userspace. This is useful to collect audit messages during bootup and even when auditd is stopped. This is NOT a reliable mechanism, it does not ever call audit_panic, nor should it. audit_log_lost()/audit_panic() are called during the normal delivery mechanism. The messages are still sent to printk/syslog as usual and if too many messages appear to be queued they will be silently discarded. I liked doing it by default, but this patch only uses the queue in question if it was booted with audit=1 or if the kernel was built enabling audit by default. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-28Audit: collect sessionid in netlink messagesEric Paris
Previously I added sessionid output to all audit messages where it was available but we still didn't know the sessionid of the sender of netlink messages. This patch adds that information to netlink messages so we can audit who sent netlink messages. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-19Audit: internally use the new LSM audit hooksAhmed S. Darwish
Convert Audit to use the new LSM Audit hooks instead of the exported SELinux interface. Basically, use: security_audit_rule_init secuirty_audit_rule_free security_audit_rule_known security_audit_rule_match instad of (respectively) : selinux_audit_rule_init selinux_audit_rule_free audit_rule_has_selinux selinux_audit_rule_match Signed-off-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Ahmed S. Darwish <darwish.07@gmail.com> Acked-by: James Morris <jmorris@namei.org>
2008-04-19Audit: use new LSM hooks instead of SELinux exportsAhmed S. Darwish
Stop using the following exported SELinux interfaces: selinux_get_inode_sid(inode, sid) selinux_get_ipc_sid(ipcp, sid) selinux_get_task_sid(tsk, sid) selinux_sid_to_string(sid, ctx, len) kfree(ctx) and use following generic LSM equivalents respectively: security_inode_getsecid(inode, secid) security_ipc_getsecid*(ipcp, secid) security_task_getsecid(tsk, secid) security_sid_to_secctx(sid, ctx, len) security_release_secctx(ctx, len) Call security_release_secctx only if security_secid_to_secctx succeeded. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Ahmed S. Darwish <darwish.07@gmail.com> Acked-by: James Morris <jmorris@namei.org> Reviewed-by: Paul Moore <paul.moore@hp.com>
2008-03-28audit: silence two kerneldoc warnings in kernel/audit.cDave Jones
Silence two kerneldoc warnings. Warning(kernel/audit.c:1276): No description found for parameter 'string' Warning(kernel/audit.c:1276): No description found for parameter 'len' [also fix a typo for bonus points] Signed-off-by: Dave Jones <davej@codemonkey.org.uk> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-20audit: netlink socket can be auto-bound to pid other than current->pid (v2)Pavel Emelyanov
From: Pavel Emelyanov <xemul@openvz.org> This patch is based on the one from Thomas. The kauditd_thread() calls the netlink_unicast() and passes the audit_pid to it. The audit_pid, in turn, is received from the user space and the tool (I've checked the audit v1.6.9) uses getpid() to pass one in the kernel. Besides, this tool doesn't bind the netlink socket to this id, but simply creates it allowing the kernel to auto-bind one. That's the preamble. The problem is that netlink_autobind() _does_not_ guarantees that the socket will be auto-bound to the current pid. Instead it uses the current pid as a hint to start looking for a free id. So, in case of conflict, the audit messages can be sent to a wrong socket. This can happen (it's unlikely, but can be) in case some task opens more than one netlink sockets and then the audit one starts - in this case the audit's pid can be busy and its socket will be bound to another id. The proposal is to introduce an audit_nlk_pid in audit subsys, that will point to the netlink socket to send packets to. It will most often be equal to audit_pid. The socket id can be got from the skb's netlink CB right in the audit_receive_msg. The audit_nlk_pid reset to 0 is not required, since all the decisions are taken based on audit_pid value only. Later, if the audit tools will bind the socket themselves, the kernel will have to provide a way to setup the audit_nlk_pid as well. A good side effect of this patch is that audit_pid can later be converted to struct pid, as it is not longer safe to use pid_t-s in the presence of pid namespaces. But audit code still uses the tgid from task_struct in the audit_signal_info and in the audit_filter_syscall. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Eric Paris <eparis@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-01[PATCH] drop EOE records from printkSteve Grubb
Hi, While we are looking at the printk issue, I see that its printk'ing the EOE (end of event) records which is really not something that we need in syslog. Its really intended for the realtime audit event stream handled by the audit daemon. So, lets avoid printk'ing that record type. Signed-off-by: Steve Grubb <sgrubb@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-03-01[RFC] AUDIT: do not panic when printk loses messagesEric Paris
On the latest kernels if one was to load about 15 rules, set the failure state to panic, and then run service auditd stop the kernel will panic. This is because auditd stops, then the script deletes all of the rules. These deletions are sent as audit messages out of the printk kernel interface which is already known to be lossy. These will overun the default kernel rate limiting (10 really fast messages) and will call audit_panic(). The same effect can happen if a slew of avc's come through while auditd is stopped. This can be fixed a number of ways but this patch fixes the problem by just not panicing if auditd is not running. We know printk is lossy and if the user chooses to set the failure mode to panic and tries to use printk we can't make any promises no matter how hard we try, so why try? At least in this way we continue to get lost message accounting and will eventually know that things went bad. The other change is to add a new call to audit_log_lost() if auditd disappears. We already pulled the skb off the queue and couldn't send it so that message is lost. At least this way we will account for the last message and panic if the machine is configured to panic. This code path should only be run if auditd dies for unforeseen reasons. If auditd closes correctly audit_pid will get set to 0 and we won't walk this code path. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-02-14d_path: Make d_path() use a struct pathJan Blunck
d_path() is used on a <dentry,vfsmount> pair. Lets use a struct path to reflect this. [akpm@linux-foundation.org: fix build in mm/memory.c] Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Bryan Wu <bryan.wu@analog.com> Acked-by: Christoph Hellwig <hch@infradead.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14d_path: Use struct path in struct avc_audit_dataJan Blunck
audit_log_d_path() is a d_path() wrapper that is used by the audit code. To use a struct path in audit_log_d_path() I need to embed it into struct avc_audit_data. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Christoph Hellwig <hch@infradead.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01[AUDIT] ratelimit printk messages auditEric Paris
some printk messages from the audit system can become excessive. This patch ratelimits those messages. It was found that messages, such as the audit backlog lost printk message could flood the logs to the point that a machine could take an nmi watchdog hit or otherwise become unresponsive. Signed-off-by: Eric Paris <eparis@redhat.com>
2008-02-01[patch 2/2] audit: complement va_copy with va_end()Richard Knutsson
Complement va_copy() with va_end(). Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2008-02-01[patch 1/2] kernel/audit.c: warning fixAndrew Morton
kernel/audit.c: In function 'audit_log_start': kernel/audit.c:1133: warning: 'serial' may be used uninitialized in this function Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2008-02-01[AUDIT] create context if auditing was ever enabledEric Paris
Disabling audit at runtime by auditctl doesn't mean that we can stop allocating contexts for new processes; we don't want to miss them when that sucker is reenabled. (based on work from Al Viro in the RHEL kernel series) Signed-off-by: Eric Paris <eparis@redhat.com>
2008-02-01[AUDIT] clean up audit_receive_msg()Eric Paris
generally clean up audit_receive_msg() don't free random memory if selinux_sid_to_string fails for some reason. Move generic auditing to a helper function Signed-off-by: Eric Paris <eparis@redhat.com>
2008-02-01[AUDIT] make audit=0 really stop audit messagesEric Paris
Some audit messages (namely configuration changes) are still emitted even if the audit subsystem has been explicitly disabled. This patch turns those messages off as well. Signed-off-by: Eric Paris <eparis@redhat.com>
2008-02-01[AUDIT] break large execve argument logging into smaller messagesEric Paris
execve arguments can be quite large. There is no limit on the number of arguments and a 4G limit on the size of an argument. this patch prints those aruguments in bite sized pieces. a userspace size limitation of 8k was discovered so this keeps messages around 7.5k single arguments larger than 7.5k in length are split into multiple records and can be identified as aX[Y]= Signed-off-by: Eric Paris <eparis@redhat.com>
2008-02-01[AUDIT] include audit type in audit message when using printkEric Paris
Currently audit drops the audit type when an audit message goes through printk instead of the audit deamon. This is a minor annoyance in that the audit type is no longer part of the message and the information the audit type conveys needs to be carried in, or derived from the message data. The attached patch includes the type number as part of the printk. Admittedly it isn't the type name that the audit deamon provides but I think this is better than dropping the type completely. Signed-pff-by: John Johansen <jjohansen@suse.de> Signed-off-by: Eric Paris <eparis@redhat.com>
2008-01-31[AUDIT]: Increase skb->truesize in audit_expandHerbert Xu
The recent UDP patch exposed this bug in the audit code. It was calling pskb_expand_head without increasing skb->truesize. The caller of pskb_expand_head needs to do so because that function is designed to be called in places where truesize is already fixed and therefore it doesn't update its value. Because the audit system is using it in a place where the truesize has not yet been fixed, it needs to update its value manually. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-21[PATCH] audit: watching subtreesAl Viro
New kind of audit rule predicates: "object is visible in given subtree". The part that can be sanely implemented, that is. Limitations: * if you have hardlink from outside of tree, you'd better watch it too (or just watch the object itself, obviously) * if you mount something under a watched tree, tell audit that new chunk should be added to watched subtrees * if you umount something in a watched tree and it's still mounted elsewhere, you will get matches on events happening there. New command tells audit to recalculate the trees, trimming such sources of false positives. Note that it's _not_ about path - if something mounted in several places (multiple mount, bindings, different namespaces, etc.), the match does _not_ depend on which one we are using for access. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
