path: root/kernel/audit.c
2016-10-04Merge branch 'stable-4.9' of git://git.infradead.org/users/pcmoore/auditLinus Torvalds
Pull audit updates from Paul Moore: "Another relatively small pull request for v4.9 with just two patches. The patch from Richard updates the list of features we support and report back to userspace; this should have been sent earlier with the rest of the v4.8 patches but it got lost in my inbox. The second patch fixes a problem reported by our Android friends where we weren't very consistent in recording PIDs" * 'stable-4.9' of git://git.infradead.org/users/pcmoore/audit: audit: add exclude filter extension to feature bitmap audit: consistently record PIDs with task_tgid_nr()
2016-08-30audit: consistently record PIDs with task_tgid_nr()Paul Moore
Unfortunately we record PIDs in audit records using a variety of methods despite the correct way being the use of task_tgid_nr(). This patch converts all of these callers, except for the case of AUDIT_SET in audit_receive_msg() (see the comment in the code). Reported-by: Jeff Vander Stoep <jeffv@google.com> Signed-off-by: Paul Moore <paul@paul-moore.com>
2016-07-29Merge branch 'stable-4.8' of git://git.infradead.org/users/pcmoore/auditLinus Torvalds
Pull audit updates from Paul Moore: "Six audit patches for 4.8. There are a couple of style and minor whitespace tweaks for the logs, as well as a minor fixup to catch errors on user filter rules, however the major improvements are a fix to the s390 syscall argument masking code (reviewed by the nice s390 folks), some consolidation around the exclude filtering (less code, always a win), and a double-fetch fix for recording the execve arguments" * 'stable-4.8' of git://git.infradead.org/users/pcmoore/audit: audit: fix a double fetch in audit_log_single_execve_arg() audit: fix whitespace in CWD record audit: add fields to exclude filter by reusing user filter s390: ensure that syscall arguments are properly masked on s390 audit: fix some horrible switch statement style crimes audit: fixup: log on errors from filter user rules
2016-06-29Merge branch 'stable-4.7' of git://git.infradead.org/users/pcmoore/auditLinus Torvalds
Pull audit fixes from Paul Moore: "Two small patches to fix audit problems in 4.7-rcX: the first fixes a potential kref leak, the second removes some header file noise. The first is an important bug fix that really should go in before 4.7 is released, the second is not critical, but falls into the very-nice- to-have category so I'm including in the pull request. Both patches are straightforward, self-contained, and pass our testsuite without problem" * 'stable-4.7' of git://git.infradead.org/users/pcmoore/audit: audit: move audit_get_tty to reduce scope and kabi changes audit: move calcs after alloc and check when logging set loginuid
2016-06-28audit: move audit_get_tty to reduce scope and kabi changesRichard Guy Briggs
The only users of audit_get_tty and audit_put_tty are internal to audit, so move it out of include/linux/audit.h to kernel.h and create a proper function rather than inlining it. This also reduces kABI changes. Suggested-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Richard Guy Briggs <rgb@redhat.com> [PM: line wrapped description] Signed-off-by: Paul Moore <paul@paul-moore.com>
2016-06-27audit: add fields to exclude filter by reusing user filterRichard Guy Briggs
RFE: add additional fields for use in audit filter exclude rules https://github.com/linux-audit/audit-kernel/issues/5 Re-factor and combine audit_filter_type() with audit_filter_user() to use audit_filter_user_rules() to enable the exclude filter to additionally filter on PID, UID, GID, AUID, LOGINUID_SET, SUBJ_*. The process of combining the similar audit_filter_user() and audit_filter_type() functions, required inverting the meaning and including the ALWAYS action of the latter. Include audit_filter_user_rules() into audit_filter(), removing unneeded logic in the process. Keep the check to quit early if the list is empty. Signed-off-by: Richard Guy Briggs <rgb@redhat.com> [PM: checkpatch.pl fixes - whitespace damage, wrapped description] Signed-off-by: Paul Moore <paul@paul-moore.com>
2016-05-18Merge branch 'stable-4.7' of git://git.infradead.org/users/pcmoore/auditLinus Torvalds
Pull audit updates from Paul Moore: "Four small audit patches for 4.7. Two are simple cleanups around the audit thread management code, one adds a tty field to AUDIT_LOGIN events, and the final patch makes tty_name() usable regardless of CONFIG_TTY. Nothing controversial, and it all passes our regression test" * 'stable-4.7' of git://git.infradead.org/users/pcmoore/audit: tty: provide tty_name() even without CONFIG_TTY audit: add tty field to LOGIN event audit: we don't need to __set_current_state(TASK_RUNNING) audit: cleanup prune_tree_thread
2016-04-26audit: add tty field to LOGIN eventRichard Guy Briggs
The tty field was missing from AUDIT_LOGIN events. Refactor code to create a new function audit_get_tty(), using it to replace the call in audit_log_task_info() and to add it to audit_log_set_loginuid(). Lock and bump the kref to protect it, adding audit_put_tty() alias to decrement it. Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Paul Moore <paul@paul-moore.com>
2016-04-04audit: we don't need to __set_current_state(TASK_RUNNING)Paul Moore
Remove the calls to __set_current_state() to mark the task as running and do some related cleanup in wait_for_auditd() to limit the amount of work we do when we aren't going to reschedule the current task. Signed-off-by: Paul Moore <paul@paul-moore.com>
2016-03-19Merge branch 'stable-4.6' of git://git.infradead.org/users/pcmoore/auditLinus Torvalds
Pull audit updates from Paul Moore: "A small set of patches for audit this time; just three in total and one is a spelling fix. The two patches with actual content are designed to help prevent new instances of auditd from displacing an existing, functioning auditd and to generate a log of the attempt. Not to worry, dead/stuck auditd instances can still be replaced by a new instance without problem. Nothing controversial, and everything passes our regression suite" * 'stable-4.6' of git://git.infradead.org/users/pcmoore/audit: audit: Fix typo in comment audit: log failed attempts to change audit_pid configuration audit: stop an old auditd being starved out by a new auditd
2016-01-27tty: audit: Handle tty audit enable atomicallyPeter Hurley
The audit_tty and audit_tty_log_passwd fields are actually bool values, so merge into single memory location to access atomically. NB: audit log operations may still occur after tty audit is disabled which is consistent with the existing functionality Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-01-27tty: audit: Combine push functionsPeter Hurley
tty_audit_push() and tty_audit_push_current() perform identical tasks; eliminate the tty_audit_push() implementation and the tty_audit_push_current() name. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-01-25audit: log failed attempts to change audit_pid configurationRichard Guy Briggs
Failed attempts to change the audit_pid configuration are not presently logged. One case is an attempt to starve an old auditd by starting up a new auditd when the old one is still alive and active. The other case is an attempt to orphan a new auditd when an old auditd shuts down. Log both as AUDIT_CONFIG_CHANGE messages with failure result. Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Paul Moore <pmoore@redhat.com>
2016-01-25audit: stop an old auditd being starved out by a new auditdRichard Guy Briggs
Nothing prevents a new auditd starting up and replacing a valid audit_pid when an old auditd is still running, effectively starving out the old auditd since audit_pid no longer points to the old valid auditd. If no message to auditd has been attempted since auditd died unnaturally or got killed, audit_pid will still indicate it is alive. There isn't an easy way to detect if an old auditd is still running on the existing audit_pid other than attempting to send a message to see if it fails. An -ECONNREFUSED almost certainly means it disappeared and can be replaced. Other errors are not so straightforward and may indicate transient problems that will resolve themselves and the old auditd will recover. Yet others will likely need manual intervention for which a new auditd will not solve the problem. Send a new message type (AUDIT_REPLACE) to the old auditd containing a u32 with the PID of the new auditd. If the audit replace message succeeds (or doesn't fail with certainty), fail to register the new auditd and return an error (-EEXIST). This is expected to make the patch preventing an old auditd orphaning a new auditd redundant. V3: Switch audit message type from 1000 to 1300 block. Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Paul Moore <pmoore@redhat.com>
2016-01-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: - EVM gains support for loading an x509 cert from the kernel (EVM_LOAD_X509), into the EVM trusted kernel keyring. - Smack implements 'file receive' process-based permission checking for sockets, rather than just depending on inode checks. - Misc enhancments for TPM & TPM2. - Cleanups and bugfixes for SELinux, Keys, and IMA. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (41 commits) selinux: Inode label revalidation performance fix KEYS: refcount bug fix ima: ima_write_policy() limit locking IMA: policy can be updated zero times selinux: rate-limit netlink message warnings in selinux_nlmsg_perm() selinux: export validatetrans decisions gfs2: Invalid security labels of inodes when they go invalid selinux: Revalidate invalid inode security labels security: Add hook to invalidate inode security labels selinux: Add accessor functions for inode->i_security security: Make inode argument of inode_getsecid non-const security: Make inode argument of inode_getsecurity non-const selinux: Remove unused variable in selinux_inode_init_security keys, trusted: seal with a TPM2 authorization policy keys, trusted: select hash algorithm for TPM2 chips keys, trusted: fix: *do not* allow duplicate key options tpm_ibmvtpm: properly handle interrupted packet receptions tpm_tis: Tighten IRQ auto-probing tpm_tis: Refactor the interrupt setup tpm_tis: Get rid of the duplicate IRQ probing code ...
2016-01-13audit: Delete unnecessary checks before two function callsMarkus Elfring
The functions consume_skb() and kfree_skb() test whether their argument is NULL and then return immediately. Thus the tests around their calls are not needed. This issue was detected by using the Coccinelle software. Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> [PM: tweak patch prefix] Signed-off-by: Paul Moore <pmoore@redhat.com>
2016-01-13audit: wake up threads if queue switched from limited to unlimitedRichard Guy Briggs
If the audit_backlog_limit is changed from a limited value to an unlimited value (zero) while the queue was overflowed, wake up the audit_backlog_wait queue to allow those processes to continue. Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Paul Moore <pmoore@redhat.com>
2016-01-13audit: include auditd's threads in audit_log_start() wait exceptionRichard Guy Briggs
Should auditd spawn threads, allow all members of its thread group to use the audit_backlog_limit reserves to bypass the queue limits too. Signed-off-by: Richard Guy Briggs <rgb@redhat.com> [PM: minor upstream merge tweaks] Signed-off-by: Paul Moore <pmoore@redhat.com>
2016-01-13audit: remove audit_backlog_wait_overflowPaul Moore
It seems much more obvious and readable to simply use "0". Signed-off-by: Paul Moore <pmoore@redhat.com>
2016-01-13audit: don't needlessly reset valid wait timeRichard Guy Briggs
After auditd has recovered from an overflowed queue, the first process that doesn't use reserves to make it through the queue checks should reset the audit backlog wait time to the configured value. After that, there is no need to keep resetting it. Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Paul Moore <pmoore@redhat.com>
2015-12-24security: Make inode argument of inode_getsecid non-constAndreas Gruenbacher
Make the inode argument of the inode_getsecid hook non-const so that we can use it to revalidate invalid security labels. Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Paul Moore <pmoore@redhat.com>
2015-11-06mm, page_alloc: distinguish between being unable to sleep, unwilling to ↵Mel Gorman
sleep and avoiding waking kswapd __GFP_WAIT has been used to identify atomic context in callers that hold spinlocks or are in interrupts. They are expected to be high priority and have access one of two watermarks lower than "min" which can be referred to as the "atomic reserve". __GFP_HIGH users get access to the first lower watermark and can be called the "high priority reserve". Over time, callers had a requirement to not block when fallback options were available. Some have abused __GFP_WAIT leading to a situation where an optimisitic allocation with a fallback option can access atomic reserves. This patch uses __GFP_ATOMIC to identify callers that are truely atomic, cannot sleep and have no alternative. High priority users continue to use __GFP_HIGH. __GFP_DIRECT_RECLAIM identifies callers that can sleep and are willing to enter direct reclaim. __GFP_KSWAPD_RECLAIM to identify callers that want to wake kswapd for background reclaim. __GFP_WAIT is redefined as a caller that is willing to enter direct reclaim and wake kswapd for background reclaim. This patch then converts a number of sites o __GFP_ATOMIC is used by callers that are high priority and have memory pools for those requests. GFP_ATOMIC uses this flag. o Callers that have a limited mempool to guarantee forward progress clear __GFP_DIRECT_RECLAIM but keep __GFP_KSWAPD_RECLAIM. bio allocations fall into this category where kswapd will still be woken but atomic reserves are not used as there is a one-entry mempool to guarantee progress. o Callers that are checking if they are non-blocking should use the helper gfpflags_allow_blocking() where possible. This is because checking for __GFP_WAIT as was done historically now can trigger false positives. Some exceptions like dm-crypt.c exist where the code intent is clearer if __GFP_DIRECT_RECLAIM is used instead of the helper due to flag manipulations. o Callers that built their own GFP flags instead of starting with GFP_KERNEL and friends now also need to specify __GFP_KSWAPD_RECLAIM. The first key hazard to watch out for is callers that removed __GFP_WAIT and was depending on access to atomic reserves for inconspicuous reasons. In some cases it may be appropriate for them to use __GFP_HIGH. The second key hazard is callers that assembled their own combination of GFP flags instead of starting with something like GFP_KERNEL. They may now wish to specify __GFP_KSWAPD_RECLAIM. It's almost certainly harmless if it's missed in most cases as other activity will wake kswapd. Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Vitaly Wool <vitalywool@gmail.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-04audit: make audit_log_common_recv_msg() a void functionPaul Moore
It always returns zero and no one is checking the return value. Signed-off-by: Paul Moore <pmoore@redhat.com>
2015-11-04audit: removing unused variableSaurabh Sengar
Variable rc in not required as it is just used for unchanged for return, and return is always 0 in the function. Signed-off-by: Saurabh Sengar <saurabh.truth@gmail.com> [PM: fixed spelling errors in description] Signed-off-by: Paul Moore <pmoore@redhat.com>
2015-11-04audit: audit_string_contains_control can be booleanYaowei Bai
This patch makes audit_string_contains_control return bool to improve readability due to this particular function only using either one or zero as its return value. Signed-off-by: Yaowei Bai <bywxiaobai@163.com> [PM: tweaked subject line] Signed-off-by: Paul Moore <pmoore@redhat.com>
2015-11-04audit: try harder to send to auditd upon netlink failureRichard Guy Briggs
There are several reports of the kernel losing contact with auditd when it is, in fact, still running. When this happens, kernel syslogs show: "audit: *NO* daemon at audit_pid=<pid>" although auditd is still running, and is apparently happy, listening on the netlink socket. The pid in the "*NO* daemon" message matches the pid of the running auditd process. Restarting auditd solves this. The problem appears to happen randomly, and doesn't seem to be strongly correlated to the rate of audit events being logged. The problem happens fairly regularly (every few days), but not yet reproduced to order. On production kernels, BUG_ON() is a no-op, so any error will trigger this. Commit 34eab0a7cd45 ("audit: prevent an older auditd shutdown from orphaning a newer auditd startup") eliminates one possible cause. This isn't the case here, since the PID in the error message and the PID of the running auditd match. The primary expected cause of error here is -ECONNREFUSED when the audit daemon goes away, when netlink_getsockbyportid() can't find the auditd portid entry in the netlink audit table (or there is no receive function). If -EPERM is returned, that situation isn't likely to be resolved in a timely fashion without administrator intervention. In both cases, reset the audit_pid. This does not rule out a race condition. SELinux is expected to return zero since this isn't an INET or INET6 socket. Other LSMs may have other return codes. Log the error code for better diagnosis in the future. In the case of -ENOMEM, the situation could be temporary, based on local or general availability of buffers. -EAGAIN should never happen since the netlink audit (kernel) socket is set to MAX_SCHEDULE_TIMEOUT. -ERESTARTSYS and -EINTR are not expected since this kernel thread is not expected to receive signals. In these cases (or any other unexpected ones for now), report the error and re-schedule the thread, retrying up to 5 times. v2: Removed BUG_ON(). Moved comma in pr_*() statements. Removed audit_strerror() text. Reported-by: Vipin Rathor <v.rathor@gmail.com> Reported-by: <ctcard@hotmail.com> Signed-off-by: Richard Guy Briggs <rgb@redhat.com> [PM: applied rgb's fixup patch to correct audit_log_lost() format issues] Signed-off-by: Paul Moore <pmoore@redhat.com>
2015-09-08Merge branch 'upstream' of git://git.infradead.org/users/pcmoore/auditLinus Torvalds
Pull audit update from Paul Moore: "This is one of the larger audit patchsets in recent history, consisting of eight patches and almost 400 lines of changes. The bulk of the patchset is the new "audit by executable" functionality which allows admins to set an audit watch based on the executable on disk. Prior to this, admins could only track an application by PID, which has some obvious limitations. Beyond the new functionality we also have some refcnt fixes and a few minor cleanups" * 'upstream' of git://git.infradead.org/users/pcmoore/audit: fixup: audit: implement audit by executable audit: implement audit by executable audit: clean simple fsnotify implementation audit: use macros for unset inode and device values audit: make audit_del_rule() more robust audit: fix uninitialized variable in audit_add_rule() audit: eliminate unnecessary extra layer of watch parent references audit: eliminate unnecessary extra layer of watch references
2015-08-06audit: use macros for unset inode and device valuesRichard Guy Briggs
Clean up a number of places were casted magic numbers are used to represent unset inode and device numbers in preparation for the audit by executable path patch set. Signed-off-by: Richard Guy Briggs <rgb@redhat.com> [PM: enclosed the _UNSET macros in parentheses for ./scripts/checkpatch] Signed-off-by: Paul Moore <pmoore@redhat.com>
2015-06-27Merge branch 'upstream' of git://git.infradead.org/users/pcmoore/auditLinus Torvalds
Pull audit updates from Paul Moore: "Four small audit patches for v4.2, all bug fixes. Only 10 lines of change this time so very unremarkable, the patch subject lines pretty much tell the whole story" * 'upstream' of git://git.infradead.org/users/pcmoore/audit: audit: Fix check of return value of strnlen_user() audit: obsolete audit_context check is removed in audit_filter_rules() audit: fix for typo in comment to function audit_log_link_denied() lsm: rename duplicate labels in LSM_AUDIT_DATA_TASK audit message type
2015-05-29audit: fix for typo in comment to function audit_log_link_denied()Shailendra Verma
Signed-off-by: Shailendra Verma <shailendra.capricorn@gmail.com> [PM: tweaked subject line] Signed-off-by: Paul Moore <pmoore@redhat.com>
2015-04-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull fourth vfs update from Al Viro: "d_inode() annotations from David Howells (sat in for-next since before the beginning of merge window) + four assorted fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: RCU pathwalk breakage when running into a symlink overmounting something fix I_DIO_WAKEUP definition direct-io: only inc/dec inode->i_dio_count for file systems fs/9p: fix readdir() VFS: assorted d_backing_inode() annotations VFS: fs/inode.c helpers: d_inode() annotations VFS: fs/cachefiles: d_backing_inode() annotations VFS: fs library helpers: d_inode() annotations VFS: assorted weird filesystems: d_inode() annotations VFS: normal filesystems (and lustre): d_inode() annotations VFS: security/: d_inode() annotations VFS: security/: d_backing_inode() annotations VFS: net/: d_inode() annotations VFS: net/unix: d_backing_inode() annotations VFS: kernel/: d_inode() annotations VFS: audit: d_backing_inode() annotations VFS: Fix up some ->d_inode accesses in the chelsio driver VFS: Cachefiles should perform fs modifications on the top layer only VFS: AF_UNIX sockets should call mknod on the top layer only
2015-04-22Merge branch 'upstream' of git://git.infradead.org/users/pcmoore/auditLinus Torvalds
Pull audit fixes from Paul Moore: "Seven audit patches for v4.1, all bug fixes. The largest, and perhaps most significant commit helps resolve some memory pressure issues related to the inode cache and audit, there are also a few small commits which help resolve some timing issues with the audit log queue, and the rest fall into the always popular "code clean-up" category. In general, nothing really substantial, just a nice set of maintenance patches" * 'upstream' of git://git.infradead.org/users/pcmoore/audit: audit: Remove condition which always evaluates to false audit: reduce mmap_sem hold for mm->exe_file audit: consolidate handling of mm->exe_file audit: code clean up audit: don't reset working wait time accidentally with auditd audit: don't lose set wait time on first successful call to audit_log_start() audit: move the tree pruning to a dedicated thread
2015-04-15VFS: audit: d_backing_inode() annotationsDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-03-13audit: Remove condition which always evaluates to falsePranith Kumar
After commit 3e1d0bb6224f019893d1c498cc3327559d183674 ("audit: Convert int limit uses to u32"), by converting an int to u32, few conditions will always evaluate to false. These warnings were emitted during compilation: kernel/audit.c: In function ‘audit_set_enabled’: kernel/audit.c:347:2: warning: comparison of unsigned expression < 0 is always false [-Wtype-limits] if (state < AUDIT_OFF || state > AUDIT_LOCKED) ^ kernel/audit.c: In function ‘audit_receive_msg’: kernel/audit.c:880:9: warning: comparison of unsigned expression < 0 is always false [-Wtype-limits] if (s.backlog_wait_time < 0 || The following patch removes those unnecessary conditions. Signed-off-by: Pranith Kumar <bobby.prani@gmail.com> Signed-off-by: Paul Moore <pmoore@redhat.com>
2015-02-23audit: reduce mmap_sem hold for mm->exe_fileDavidlohr Bueso
The mm->exe_file is currently serialized with mmap_sem (shared) in order to both safely (1) read the file and (2) audit it via audit_log_d_path(). Good users will, on the other hand, make use of the more standard get_mm_exe_file(), requiring only holding the mmap_sem to read the value, and relying on reference counting to make sure that the exe file won't dissapear underneath us. Additionally, upon NULL return of get_mm_exe_file, we also call audit_log_format(ab, " exe=(null)"). Signed-off-by: Davidlohr Bueso <dbueso@suse.de> [PM: tweaked subject line] Signed-off-by: Paul Moore <pmoore@redhat.com>
2015-02-23audit: consolidate handling of mm->exe_fileDavidlohr Bueso
This patch adds a audit_log_d_path_exe() helper function to share how we handle auditing of the exe_file's path. Used by both audit and auditsc. No functionality is changed. Signed-off-by: Davidlohr Bueso <dbueso@suse.de> [PM: tweaked subject line] Signed-off-by: Paul Moore <pmoore@redhat.com>
2015-02-23audit: code clean upAmeen Ali
Fixed a coding style issue (unnecessary parentheses , unnecessary braces) Signed-off-by: Ameen-Ali <Ameenali023@gmail.com> [PM: tweaked subject line] Signed-off-by: Paul Moore <pmoore@redhat.com>
2015-02-23audit: don't reset working wait time accidentally with auditdRichard Guy Briggs
During a queue overflow condition while we are waiting for auditd to drain the queue to make room for regular messages, we don't want a successful auditd that has bypassed the queue check to reset the backlog wait time. Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Paul Moore <pmoore@redhat.com>
2015-02-23audit: don't lose set wait time on first successful call to audit_log_start()Richard Guy Briggs
Copy the set wait time to a working value to avoid losing the set value if the queue overflows. Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Paul Moore <pmoore@redhat.com>
2014-12-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix double SKB free in bluetooth 6lowpan layer, from Jukka Rissanen. 2) Fix receive checksum handling in enic driver, from Govindarajulu Varadarajan. 3) Fix NAPI poll list corruption in virtio_net and caif_virtio, from Herbert Xu. Also, add code to detect drivers that have this mistake in the future. 4) Fix doorbell endianness handling in mlx4 driver, from Amir Vadai. 5) Don't clobber IP6CB() before xfrm6_policy_check() is called in TCP input path,f rom Nicolas Dichtel. 6) Fix MPLS action validation in openvswitch, from Pravin B Shelar. 7) Fix double SKB free in vxlan driver, also from Pravin. 8) When we scrub a packet, which happens when we are switching the context of the packet (namespace, etc.), we should reset the secmark. From Thomas Graf. 9) ->ndo_gso_check() needs to do more than return true/false, it also has to allow the driver to clear netdev feature bits in order for the caller to be able to proceed properly. From Jesse Gross. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (62 commits) genetlink: A genl_bind() to an out-of-range multicast group should not WARN(). netlink/genetlink: pass network namespace to bind/unbind ne2k-pci: Add pci_disable_device in error handling bonding: change error message to debug message in __bond_release_one() genetlink: pass multicast bind/unbind to families netlink: call unbind when releasing socket netlink: update listeners directly when removing socket genetlink: pass only network namespace to genl_has_listeners() netlink: rename netlink_unbind() to netlink_undo_bind() net: Generalize ndo_gso_check to ndo_features_check net: incorrect use of init_completion fixup neigh: remove next ptr from struct neigh_table net: xilinx: Remove unnecessary temac_property in the driver net: phy: micrel: use generic config_init for KSZ8021/KSZ8031 net/core: Handle csum for CHECKSUM_COMPLETE VXLAN forwarding openvswitch: fix odd_ptr_err.cocci warnings Bluetooth: Fix accepting connections when not using mgmt Bluetooth: Fix controller configuration with HCI_QUIRK_INVALID_BDADDR brcmfmac: Do not crash if platform data is not populated ipw2200: select CFG80211_WEXT ...
2014-12-27netlink/genetlink: pass network namespace to bind/unbindJohannes Berg
Netlink families can exist in multiple namespaces, and for the most part multicast subscriptions are per network namespace. Thus it only makes sense to have bind/unbind notifications per network namespace. To achieve this, pass the network namespace of a given client socket to the bind/unbind functions. Also do this in generic netlink, and there also make sure that any bind for multicast groups that only exist in init_net is rejected. This isn't really a problem if it is accepted since a client in a different namespace will never receive any notifications from such a group, but it can confuse the family if not rejected (it's also possible to silently (without telling the family) accept it, but it would also have to be ignored on unbind so families that take any kind of action on bind/unbind won't do unnecessary work for invalid clients like that. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-23Merge branch 'upstream' of git://git.infradead.org/users/pcmoore/auditLinus Torvalds
Pull audit fixes from Paul Moore: "Four patches to fix various problems with the audit subsystem, all are fairly small and straightforward. One patch fixes a problem where we weren't using the correct gfp allocation flags (GFP_KERNEL regardless of context, oops), one patch fixes a problem with old userspace tools (this was broken for a while), one patch fixes a problem where we weren't recording pathnames correctly, and one fixes a problem with PID based filters. In general I don't think there is anything controversial with this patchset, and it fixes some rather unfortunate bugs; the allocation flag one can be particularly scary looking for users" * 'upstream' of git://git.infradead.org/users/pcmoore/audit: audit: restore AUDIT_LOGINUID unset ABI audit: correctly record file names with different path name types audit: use supplied gfp_mask from audit_buffer in kauditd_send_multicast_skb audit: don't attempt to lookup PIDs when changing PID filtering audit rules
2014-12-19audit: use supplied gfp_mask from audit_buffer in kauditd_send_multicast_skbRichard Guy Briggs
Eric Paris explains: Since kauditd_send_multicast_skb() gets called in audit_log_end(), which can come from any context (aka even a sleeping context) GFP_KERNEL can't be used. Since the audit_buffer knows what context it should use, pass that down and use that. See: https://lkml.org/lkml/2014/12/16/542 BUG: sleeping function called from invalid context at mm/slab.c:2849 in_atomic(): 1, irqs_disabled(): 0, pid: 885, name: sulogin 2 locks held by sulogin/885: #0: (&sig->cred_guard_mutex){+.+.+.}, at: [<ffffffff91152e30>] prepare_bprm_creds+0x28/0x8b #1: (tty_files_lock){+.+.+.}, at: [<ffffffff9123e787>] selinux_bprm_committing_creds+0x55/0x22b CPU: 1 PID: 885 Comm: sulogin Not tainted 3.18.0-next-20141216 #30 Hardware name: Dell Inc. Latitude E6530/07Y85M, BIOS A15 06/20/2014 ffff880223744f10 ffff88022410f9b8 ffffffff916ba529 0000000000000375 ffff880223744f10 ffff88022410f9e8 ffffffff91063185 0000000000000006 0000000000000000 0000000000000000 0000000000000000 ffff88022410fa38 Call Trace: [<ffffffff916ba529>] dump_stack+0x50/0xa8 [<ffffffff91063185>] ___might_sleep+0x1b6/0x1be [<ffffffff910632a6>] __might_sleep+0x119/0x128 [<ffffffff91140720>] cache_alloc_debugcheck_before.isra.45+0x1d/0x1f [<ffffffff91141d81>] kmem_cache_alloc+0x43/0x1c9 [<ffffffff914e148d>] __alloc_skb+0x42/0x1a3 [<ffffffff914e2b62>] skb_copy+0x3e/0xa3 [<ffffffff910c263e>] audit_log_end+0x83/0x100 [<ffffffff9123b8d3>] ? avc_audit_pre_callback+0x103/0x103 [<ffffffff91252a73>] common_lsm_audit+0x441/0x450 [<ffffffff9123c163>] slow_avc_audit+0x63/0x67 [<ffffffff9123c42c>] avc_has_perm+0xca/0xe3 [<ffffffff9123dc2d>] inode_has_perm+0x5a/0x65 [<ffffffff9123e7ca>] selinux_bprm_committing_creds+0x98/0x22b [<ffffffff91239e64>] security_bprm_committing_creds+0xe/0x10 [<ffffffff911515e6>] install_exec_creds+0xe/0x79 [<ffffffff911974cf>] load_elf_binary+0xe36/0x10d7 [<ffffffff9115198e>] search_binary_handler+0x81/0x18c [<ffffffff91153376>] do_execveat_common.isra.31+0x4e3/0x7b7 [<ffffffff91153669>] do_execve+0x1f/0x21 [<ffffffff91153967>] SyS_execve+0x25/0x29 [<ffffffff916c61a9>] stub_execve+0x69/0xa0 Cc: stable@vger.kernel.org #v3.16-rc1 Reported-by: Valdis Kletnieks <Valdis.Kletnieks@vt.edu> Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Tested-by: Valdis Kletnieks <Valdis.Kletnieks@vt.edu> Signed-off-by: Paul Moore <pmoore@redhat.com>
2014-12-13Merge branch 'upstream' of git://git.infradead.org/users/pcmoore/auditLinus Torvalds
Pull audit updates from Paul Moore: "Two small patches from the audit next branch; only one of which has any real significant code changes, the other is simply a MAINTAINERS update for audit. The single code patch is pretty small and rather straightforward, it changes the audit "version" number reported to userspace from an integer to a bitmap which is used to indicate the functionality of the running kernel. This really doesn't have much impact on the kernel, but it will make life easier for the audit userspace folks. Thankfully we were still on a version number which allowed us to do this without breaking userspace" * 'upstream' of git://git.infradead.org/users/pcmoore/audit: audit: convert status version to a feature bitmap audit: add Paul Moore to the MAINTAINERS entry
2014-12-09Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler updates from Ingo Molnar: "The main changes in this cycle are: - 'Nested Sleep Debugging', activated when CONFIG_DEBUG_ATOMIC_SLEEP=y. This instruments might_sleep() checks to catch places that nest blocking primitives - such as mutex usage in a wait loop. Such bugs can result in hard to debug races/hangs. Another category of invalid nesting that this facility will detect is the calling of blocking functions from within schedule() -> sched_submit_work() -> blk_schedule_flush_plug(). There's some potential for false positives (if secondary blocking primitives themselves are not ready yet for this facility), but the kernel will warn once about such bugs per bootup, so the warning isn't much of a nuisance. This feature comes with a number of fixes, for problems uncovered with it, so no messages are expected normally. - Another round of sched/numa optimizations and refinements, for CONFIG_NUMA_BALANCING=y. - Another round of sched/dl fixes and refinements. Plus various smaller fixes and cleanups" * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (54 commits) sched: Add missing rcu protection to wake_up_all_idle_cpus sched/deadline: Introduce start_hrtick_dl() for !CONFIG_SCHED_HRTICK sched/numa: Init numa balancing fields of init_task sched/deadline: Remove unnecessary definitions in cpudeadline.h sched/cpupri: Remove unnecessary definitions in cpupri.h sched/deadline: Fix rq->dl.pushable_tasks bug in push_dl_task() sched/fair: Fix stale overloaded status in the busiest group finding logic sched: Move p->nr_cpus_allowed check to select_task_rq() sched/completion: Document when to use wait_for_completion_io_*() sched: Update comments about CLONE_NEWUTS and CLONE_NEWIPC sched/fair: Kill task_struct::numa_entry and numa_group::task_list sched: Refactor task_struct to use numa_faults instead of numa_* pointers sched/deadline: Don't check CONFIG_SMP in switched_from_dl() sched/deadline: Reschedule from switched_from_dl() after a successful pull sched/deadline: Push task away if the deadline is equal to curr during wakeup sched/deadline: Add deadline rq status print sched/deadline: Fix artificial overrun introduced by yield_task_dl() sched/rt: Clean up check_preempt_equal_prio() sched/core: Use dl_bw_of() under rcu_read_lock_sched() sched: Check if we got a shallowest_idle_cpu before searching for least_loaded_cpu ...
2014-12-09Merge branch 'next' into upstream for v3.19Paul Moore
2014-11-17audit: convert status version to a feature bitmapRichard Guy Briggs
The version field defined in the audit status structure was found to have limitations in terms of its expressibility of features supported. This is distict from the get/set features call to be able to command those features that are present. Converting this field from a version number to a feature bitmap will allow distributions to selectively backport and support certain features and will allow upstream to be able to deprecate features in the future. It will allow userspace clients to first query the kernel for which features are actually present and supported. Currently, EINVAL is returned rather than EOPNOTSUP, which isn't helpful in determining if there was an error in the command, or if it simply isn't supported yet. Past features are not represented by this bitmap, but their use may be converted to EOPNOTSUP if needed in the future. Since "version" is too generic to convert with a #define, use a union in the struct status, introducing the member "feature_bitmap" unionized with "version". Convert existing AUDIT_VERSION_* macros over to AUDIT_FEATURE_BITMAP* counterparts, leaving the former for backwards compatibility. Signed-off-by: Richard Guy Briggs <rgb@redhat.com> [PM: minor whitespace tweaks] Signed-off-by: Paul Moore <pmoore@redhat.com>
2014-11-13Merge branch 'stable-3.18' of git://git.infradead.org/users/pcmoore/auditLinus Torvalds
Pull audit fixes from Paul Moore: "After he sent the initial audit pull request for 3.18, Eric asked me to take over the management of the audit tree, hence this pull request to fix a couple of problems with audit. As you can see below, the changes are minimal: adding some whitespace to a string so userspace parses it correctly, and fixing a problem with audit's usage of fsnotify that was causing audit watch rules to be lost. Neither of these patches were very controversial on the mailing lists and they fix real problems, getting them into 3.18 would be a good thing" * 'stable-3.18' of git://git.infradead.org/users/pcmoore/audit: audit: keep inode pinned audit: AUDIT_FEATURE_CHANGE message format missing delimiting space
2014-11-04audit, sched/wait: Fixup kauditd_thread() wait loopPeter Zijlstra
The kauditd_thread wait loop is a bit iffy; it has a number of problems: - calls try_to_freeze() before schedule(); you typically want the thread to re-evaluate the sleep condition when unfreezing, also freeze_task() issues a wakeup. - it unconditionally does the {add,remove}_wait_queue(), even when the sleep condition is false. Use wait_event_freezable() that does the right thing. Reported-by: Mike Galbraith <umgwanakikbuti@gmail.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Eric Paris <eparis@redhat.com> Cc: oleg@redhat.com Cc: Eric Paris <eparis@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/20141002102251.GA6324@worktop.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-10-30audit: AUDIT_FEATURE_CHANGE message format missing delimiting spaceRichard Guy Briggs
Add a space between subj= and feature= fields to make them parsable. Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Cc: stable@vger.kernel.org Signed-off-by: Paul Moore <pmoore@redhat.com>
