path: root/kernel/audit.c
2006-12-07[PATCH] Add include/linux/freezer.h and move definitions from sched.hNigel Cunningham
Move process freezing functions from include/linux/sched.h to freezer.h, so that modifications to the freezer or the kernel configuration don't require recompiling just about everything. [akpm@osdl.org: fix ueagle driver] Signed-off-by: Nigel Cunningham <nigel@suspend2.net> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-06[PATCH] kauditd_thread warning fixAndrew Morton
Squash this warning: kernel/audit.c: In function 'kauditd_thread': kernel/audit.c:367: warning: no return statement in function returning non-void We might as test kthread_should_stop(), although it's not very pointful at present. The code which starts this thread looks racy - the kernel could start multiple threads. Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] selinux: rename selinux_ctxid_to_stringStephen Smalley
Rename selinux_ctxid_to_string to selinux_sid_to_string to be consistent with other interfaces. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-11[PATCH] sanity check audit_bufferAmy Griffis
Add sanity checks for NULL audit_buffer consistent with other audit_log* routines. Signed-off-by: Amy Griffis <amy.griffis@hp.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-08-03[PATCH] fix oops with CONFIG_AUDIT and !CONFIG_AUDITSYSCALLAmy Griffis
Always initialize the audit_inode_hash[] so we don't oops on list rules. Signed-off-by: Amy Griffis <amy.griffis@hp.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-06-29[NETLINK]: Encapsulate eff_cap usage within security framework.Darrel Goeddel
This patch encapsulates the usage of eff_cap (in netlink_skb_params) within the security framework by extending security_netlink_recv to include a required capability parameter and converting all direct usage of eff_caps outside of the lsm modules to use the interface. It also updates the SELinux implementation of the security_netlink_send and security_netlink_recv hooks to take advantage of the sid in the netlink_skb_params struct. This also enables SELinux to perform auditing of netlink capability checks. Please apply, for 2.6.18 if possible. Signed-off-by: Darrel Goeddel <dgoeddel@trustedcs.com> Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-27[PATCH] spin/rwlock init cleanupsIngo Molnar
locking init cleanups: - convert " = SPIN_LOCK_UNLOCKED" to spin_lock_init() or DEFINE_SPINLOCK() - convert rwlocks in a similar manner this patch was generated automatically. Motivation: - cleanliness - lockdep needs control of lock initialization, which the open-coded variants do not give - it's also useful for -rt and for lock debugging in general Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-20[PATCH] log more info for directory entry change eventsAmy Griffis
When an audit event involves changes to a directory entry, include a PATH record for the directory itself. A few other notable changes: - fixed audit_inode_child() hooks in fsnotify_move() - removed unused flags arg from audit_inode() - added audit log routines for logging a portion of a string Here's some sample output. before patch: type=SYSCALL msg=audit(1149821605.320:26): arch=40000003 syscall=39 success=yes exit=0 a0=bf8d3c7c a1=1ff a2=804e1b8 a3=bf8d3c7c items=1 ppid=739 pid=800 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=ttyS0 comm="mkdir" exe="/bin/mkdir" subj=root:system_r:unconfined_t:s0-s0:c0.c255 type=CWD msg=audit(1149821605.320:26): cwd="/root" type=PATH msg=audit(1149821605.320:26): item=0 name="foo" parent=164068 inode=164010 dev=03:00 mode=040755 ouid=0 ogid=0 rdev=00:00 obj=root:object_r:user_home_t:s0 after patch: type=SYSCALL msg=audit(1149822032.332:24): arch=40000003 syscall=39 success=yes exit=0 a0=bfdd9c7c a1=1ff a2=804e1b8 a3=bfdd9c7c items=2 ppid=714 pid=777 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=ttyS0 comm="mkdir" exe="/bin/mkdir" subj=root:system_r:unconfined_t:s0-s0:c0.c255 type=CWD msg=audit(1149822032.332:24): cwd="/root" type=PATH msg=audit(1149822032.332:24): item=0 name="/root" inode=164068 dev=03:00 mode=040750 ouid=0 ogid=0 rdev=00:00 obj=root:object_r:user_home_dir_t:s0 type=PATH msg=audit(1149822032.332:24): item=1 name="foo" inode=164010 dev=03:00 mode=040755 ouid=0 ogid=0 rdev=00:00 obj=root:object_r:user_home_t:s0 Signed-off-by: Amy Griffis <amy.griffis@hp.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-06-20[PATCH] audit: path-based rulesAmy Griffis
In this implementation, audit registers inotify watches on the parent directories of paths specified in audit rules. When audit's inotify event handler is called, it updates any affected rules based on the filesystem event. If the parent directory is renamed, removed, or its filesystem is unmounted, audit removes all rules referencing that inotify watch. To keep things simple, this implementation limits location-based auditing to the directory entries in an existing directory. Given a path-based rule for /foo/bar/passwd, the following table applies: passwd modified -- audit event logged passwd replaced -- audit event logged, rules list updated bar renamed -- rule removed foo renamed -- untracked, meaning that the rule now applies to the new location Audit users typically want to have many rules referencing filesystem objects, which can significantly impact filtering performance. This patch also adds an inode-number-based rule hash to mitigate this situation. The patch is relative to the audit git tree: http://kernel.org/git/?p=linux/kernel/git/viro/audit-current.git;a=summary and uses the inotify kernel API: http://lkml.org/lkml/2006/6/1/145 Signed-off-by: Amy Griffis <amy.griffis@hp.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-06-20[PATCH] minor audit updatesSerge E. Hallyn
Just a few minor proposed updates. Only the last one will actually affect behavior. The rest are just misleading code. Several AUDIT_SET functions return 'old' value, but only return value <0 is checked for. So just return 0. propagate audit_set_rate_limit and audit_set_backlog_limit error values In audit_buffer_free, the audit_freelist_count was being incremented even when we discard the return buffer, so audit_freelist_count can end up wrong. This could cause the actual freelist to shrink over time, eventually threatening to degrate audit performance. Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-06-20[PATCH] collect sid of those who send signals to auditdAl Viro
2006-06-20[PATCH] execve argument loggingAl Viro
2006-06-20[PATCH] fix deadlocks in AUDIT_LIST/AUDIT_LIST_RULESAl Viro
We should not send a pile of replies while holding audit_netlink_mutex since we hold the same mutex when we receive commands. As the result, we can get blocked while sending and sit there holding the mutex while auditctl is unable to send the next command and get around to receiving what we'd sent. Solution: create skb and put them into a queue instead of sending; once we are done, send what we've got on the list. The former can be done synchronously while we are handling AUDIT_LIST or AUDIT_LIST_RULES; we are holding audit_netlink_mutex at that point. The latter is done asynchronously and without messing with audit_netlink_mutex. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-05-01[PATCH] More user space subject labelsSteve Grubb
Hi, The patch below builds upon the patch sent earlier and adds subject label to all audit events generated via the netlink interface. It also cleans up a few other minor things. Signed-off-by: Steve Grubb <sgrubb@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-05-01[PATCH] Reworked patch for labels on user space messagesSteve Grubb
The below patch should be applied after the inode and ipc sid patches. This patch is a reworking of Tim's patch that has been updated to match the inode and ipc patches since its similar. [updated: > Stephen Smalley also wanted to change a variable from isec to tsec in the > user sid patch. ] Signed-off-by: Steve Grubb <sgrubb@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-05-01[PATCH] support for context based audit filtering, part 2Darrel Goeddel
This patch provides the ability to filter audit messages based on the elements of the process' SELinux context (user, role, type, mls sensitivity, and mls clearance). It uses the new interfaces from selinux to opaquely store information related to the selinux context and to filter based on that information. It also uses the callback mechanism provided by selinux to refresh the information when a new policy is loaded. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-03-31[PATCH] Don't pass boot parameters to argv_init[]OGAWA Hirofumi
The boot cmdline is parsed in parse_early_param() and parse_args(,unknown_bootoption). And __setup() is used in obsolete_checksetup(). start_kernel() -> parse_args() -> unknown_bootoption() -> obsolete_checksetup() If __setup()'s callback (->setup_func()) returns 1 in obsolete_checksetup(), obsolete_checksetup() thinks a parameter was handled. If ->setup_func() returns 0, obsolete_checksetup() tries other ->setup_func(). If all ->setup_func() that matched a parameter returns 0, a parameter is seted to argv_init[]. Then, when runing /sbin/init or init=app, argv_init[] is passed to the app. If the app doesn't ignore those arguments, it will warning and exit. This patch fixes a wrong usage of it, however fixes obvious one only. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-20[PATCH] fix audit_init failure pathAmy Griffis
Make audit_init() failure path handle situations where the audit_panic() action is not AUDIT_FAIL_PANIC (default is AUDIT_FAIL_PRINTK). Other uses of audit_sock are not reached unless audit's netlink message handler is properly registered. Bug noticed by Peter Staubach. Signed-off-by: Amy Griffis <amy.griffis@hp.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-03-20[PATCH] EXPORT_SYMBOL patch for audit_log, audit_log_start, audit_log_end ↵lorenzo@gnu.org
and audit_format Hi, This is a trivial patch that enables the possibility of using some auditing functions within loadable kernel modules (ie. inside a Linux Security Module). _ Make the audit_log_start, audit_log_end, audit_format and audit_log interfaces available to Loadable Kernel Modules, thus making possible the usage of the audit framework inside LSMs, etc. Signed-off-by: <Lorenzo Hernández García-Hierro <lorenzo@gnu.org>> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-03-20[PATCH] sem2mutex: audit_netlink_semIngo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-03-20[PATCH] audit string fields interface + consumerAmy Griffis
Updated patch to dynamically allocate audit rule fields in kernel's internal representation. Added unlikely() calls for testing memory allocation result. Amy Griffis wrote: [Wed Jan 11 2006, 02:02:31PM EST] > Modify audit's kernel-userspace interface to allow the specification > of string fields in audit rules. > > Signed-off-by: Amy Griffis <amy.griffis@hp.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> (cherry picked from 5ffc4a863f92351b720fe3e9c5cd647accff9e03 commit)
2006-03-20[PATCH] Fix audit record filtering with !CONFIG_AUDITSYSCALLDavid Woodhouse
This fixes the per-user and per-message-type filtering when syscall auditing isn't enabled. [AV: folded followup fix from the same author] Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-03-20[PATCH] Capture selinux subject/object context information.Dustin Kirkland
This patch extends existing audit records with subject/object context information. Audit records associated with filesystem inodes, ipc, and tasks now contain SELinux label information in the field "subj" if the item is performing the action, or in "obj" if the item is the receiver of an action. These labels are collected via hooks in SELinux and appended to the appropriate record in the audit code. This additional information is required for Common Criteria Labeled Security Protection Profile (LSPP). [AV: fixed kmalloc flags use] [folded leak fixes] [folded cleanup from akpm (kfree(NULL)] [folded audit_inode_context() leak fix] [folded akpm's fix for audit_ipc_perm() definition in case of !CONFIG_AUDIT] Signed-off-by: Dustin Kirkland <dustin.kirkland@us.ibm.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-03-20[PATCH] Exclude messages by message typeDustin Kirkland
- Add a new, 5th filter called "exclude". - And add a new field AUDIT_MSGTYPE. - Define a new function audit_filter_exclude() that takes a message type as input and examines all rules in the filter. It returns '1' if the message is to be excluded, and '0' otherwise. - Call the audit_filter_exclude() function near the top of audit_log_start() just after asserting audit_initialized. If the message type is not to be audited, return NULL very early, before doing a lot of work. [combined with followup fix for bug in original patch, Nov 4, same author] [combined with later renaming AUDIT_FILTER_EXCLUDE->AUDIT_FILTER_TYPE and audit_filter_exclude() -> audit_filter_type()] Signed-off-by: Dustin Kirkland <dustin.kirkland@us.ibm.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-03-20[PATCH] Define new range of userspace messages.Steve Grubb
The attached patch updates various items for the new user space messages. Please apply. Signed-off-by: Steve Grubb <sgrubb@redhat.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-03-20[PATCH] AUDIT: kerneldoc for kernel/audit*.cRandy Dunlap
- add kerneldoc for non-static functions; - don't init static data to 0; - limit lines to < 80 columns; - fix long-format style; - delete whitespace at end of some lines; (chrisw: resend and update to current audit-2.6 tree) Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Chris Wright <chrisw@osdl.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-01-18[PATCH] EDAC: atomic scrub operationsAlan Cox
EDAC requires a way to scrub memory if an ECC error is found and the chipset does not do the work automatically. That means rewriting memory locations atomically with respect to all CPUs _and_ bus masters. That means we can't use atomic_add(foo, 0) as it gets optimised for non-SMP This adds a function to include/asm-foo/atomic.h for the platforms currently supported which implements a scrub of a mapped block. It also adjusts a few other files include order where atomic.h is included before types.h as this now causes an error as atomic_scrub uses u32. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] kernel/: small cleanupsAdrian Bunk
This patch contains the following cleanups: - make needlessly global functions static - every file should include the headers containing the prototypes for it's global functions Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-12[PATCH] Add try_to_freeze to kauditdPierre Ossman
kauditd was causing suspends to fail because it refused to freeze. Adding a try_to_freeze() to its sleep loop solves the issue. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Acked-by: Pavel Machek <pavel@suse.cz> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] gfp_t: kernel/*Al Viro
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-13Merge master.kernel.org:/pub/scm/linux/kernel/git/dwmw2/audit-2.6 Linus Torvalds
2005-08-29[NETLINK]: Add "groups" argument to netlink_kernel_createPatrick McHardy
Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETLINK]: Add properly module refcounting for kernel netlink sockets.Harald Welte
- Remove bogus code for compiling netlink as module - Add module refcounting support for modules implementing a netlink protocol - Add support for autoloading modules that implement a netlink protocol as soon as someone opens a socket for that protocol Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-17AUDIT: Prevent duplicate syscall rulesAmy Griffis
The following patch against audit.81 prevents duplicate syscall rules in a given filter list by walking the list on each rule add. I also removed the unused struct audit_entry in audit.c and made the static inlines in auditsc.c consistent. Signed-off-by: Amy Griffis <amy.griffis@hp.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-07-18AUDIT: Reduce contention in audit_serial()David Woodhouse
... by generating serial numbers only if an audit context is actually _used_, rather than doing so at syscall entry even when the context isn't necessarily marked auditable. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-07-15AUDIT: Fix livelock in audit_serial().David Woodhouse
The tricks with atomic_t were bizarre. Just do it sensibly instead. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-07-13[AUDIT] Fix sparse warning about gfp_mask typeVictor Fusco
Fix the sparse warning "implicit cast to nocast type" Signed-off-by: Victor Fusco <victor@cetuc.puc-rio.br> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-07-02AUDIT: Stop waiting for backlog after audit_panic() happensDavid Woodhouse
We force a rate-limit on auditable events by making them wait for space on the backlog queue. However, if auditd really is AWOL then this could potentially bring the entire system to a halt, depending on the audit rules in effect. Firstly, make sure the wait time is honoured correctly -- it's the maximum time the process should wait, rather than the time to wait _each_ time round the loop. We were getting re-woken _each_ time a packet was dequeued, and the timeout was being restarted each time. Secondly, reset the wait time after audit_panic() is called. In general this will be reset to zero, to allow progress to be made. If the system is configured to _actually_ panic on audit_panic() then that will already have happened; otherwise we know that audit records are being lost anyway. These two tunables can't be exposed via AUDIT_GET and AUDIT_SET because those aren't particularly well-designed. It probably should have been done by sysctls or sysfs anyway -- one for a later patch. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-06-24AUDIT: Use KERN_NOTICE for printk of audit recordsDavid Woodhouse
They aren't errors. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-06-24AUDIT: Clean up user message filteringDavid Woodhouse
Don't look up the task by its pid and then use the syscall filtering helper. Just implement our own filter helper which operates solely on the information in the netlink_skb_parms. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-06-22AUDIT: Remove stray declaration of tsk from audit_receive_msg().David Woodhouse
It's not used any more. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-06-22AUDIT: Wait for backlog to clear when generating messages.David Woodhouse
Add a gfp_mask to audit_log_start() and audit_log(), to reduce the amount of GFP_ATOMIC allocation -- most of it doesn't need to be GFP_ATOMIC. Also if the mask includes __GFP_WAIT, then wait up to 60 seconds for the auditd backlog to clear instead of immediately abandoning the message. The timeout should probably be made configurable, but for now it'll suffice that it only happens if auditd is actually running. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-06-22AUDIT: Optimise the audit-disabled case for discarding user messagesDavid Woodhouse
Also exempt USER_AVC message from being discarded to preserve existing behaviour for SE Linux. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-06-21AUDIT: Spawn kernel thread to list filter rules.David Woodhouse
If we have enough rules to fill the netlink buffer space, it'll deadlock because auditctl isn't ever actually going to read from the socket until we return, and we aren't going to return until it reads... so we spawn a kernel thread to spew out the list and then exit. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-06-20AUDIT: Drop user-generated messages immediately while auditing disabled.David Woodhouse
2005-06-19AUDIT: Allow filtering of user messagesDavid Woodhouse
Turn the field from a bitmask to an enumeration and add a list to allow filtering of messages generated by userspace. We also define a list for file system watches in anticipation of that feature. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-05-23AUDIT: Unify auid reporting, put arch before syscall numberDavid Woodhouse
These changes make processing of audit logs easier. Based on a patch from Steve Grubb <sgrubb@redhat.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-05-21AUDIT: Assign serial number to non-syscall messagesDavid Woodhouse
Move audit_serial() into audit.c and use it to generate serial numbers on messages even when there is no audit context from syscall auditing. This allows us to disambiguate audit records when more than one is generated in the same millisecond. Based on a patch by Steve Grubb after he observed the problem. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-05-21AUDIT: Fix inconsistent use of loginuid vs. auid, signed vs. unsigned Steve Grubb
The attached patch changes all occurrences of loginuid to auid. It also changes everything to %u that is an unsigned type. Signed-off-by: Steve Grubb <sgrubb@redhat.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
