path: root/kernel/audit.h
2006-07-01[PATCH] add rule filterkeyAmy Griffis
Add support for a rule key, which can be used to tie audit records to audit rules. This is useful when a watched file is accessed through a link or symlink, as well as for general audit log analysis. Because this patch uses a string key instead of an integer key, there is a bit of extra overhead to do the kstrdup() when a rule fires. However, we're also allocating memory for the audit record buffer, so it's probably not that significant. I went ahead with a string key because it seems more user-friendly. Note that the user must ensure that filterkeys are unique. The kernel only checks for duplicate rules. Signed-off-by: Amy Griffis <amy.griffis@hpd.com>
2006-06-20[PATCH] log more info for directory entry change eventsAmy Griffis
When an audit event involves changes to a directory entry, include a PATH record for the directory itself. A few other notable changes: - fixed audit_inode_child() hooks in fsnotify_move() - removed unused flags arg from audit_inode() - added audit log routines for logging a portion of a string Here's some sample output. before patch: type=SYSCALL msg=audit(1149821605.320:26): arch=40000003 syscall=39 success=yes exit=0 a0=bf8d3c7c a1=1ff a2=804e1b8 a3=bf8d3c7c items=1 ppid=739 pid=800 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=ttyS0 comm="mkdir" exe="/bin/mkdir" subj=root:system_r:unconfined_t:s0-s0:c0.c255 type=CWD msg=audit(1149821605.320:26): cwd="/root" type=PATH msg=audit(1149821605.320:26): item=0 name="foo" parent=164068 inode=164010 dev=03:00 mode=040755 ouid=0 ogid=0 rdev=00:00 obj=root:object_r:user_home_t:s0 after patch: type=SYSCALL msg=audit(1149822032.332:24): arch=40000003 syscall=39 success=yes exit=0 a0=bfdd9c7c a1=1ff a2=804e1b8 a3=bfdd9c7c items=2 ppid=714 pid=777 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=ttyS0 comm="mkdir" exe="/bin/mkdir" subj=root:system_r:unconfined_t:s0-s0:c0.c255 type=CWD msg=audit(1149822032.332:24): cwd="/root" type=PATH msg=audit(1149822032.332:24): item=0 name="/root" inode=164068 dev=03:00 mode=040750 ouid=0 ogid=0 rdev=00:00 obj=root:object_r:user_home_dir_t:s0 type=PATH msg=audit(1149822032.332:24): item=1 name="foo" inode=164010 dev=03:00 mode=040755 ouid=0 ogid=0 rdev=00:00 obj=root:object_r:user_home_t:s0 Signed-off-by: Amy Griffis <amy.griffis@hp.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-06-20[PATCH] audit: path-based rulesAmy Griffis
In this implementation, audit registers inotify watches on the parent directories of paths specified in audit rules. When audit's inotify event handler is called, it updates any affected rules based on the filesystem event. If the parent directory is renamed, removed, or its filesystem is unmounted, audit removes all rules referencing that inotify watch. To keep things simple, this implementation limits location-based auditing to the directory entries in an existing directory. Given a path-based rule for /foo/bar/passwd, the following table applies: passwd modified -- audit event logged passwd replaced -- audit event logged, rules list updated bar renamed -- rule removed foo renamed -- untracked, meaning that the rule now applies to the new location Audit users typically want to have many rules referencing filesystem objects, which can significantly impact filtering performance. This patch also adds an inode-number-based rule hash to mitigate this situation. The patch is relative to the audit git tree: http://kernel.org/git/?p=linux/kernel/git/viro/audit-current.git;a=summary and uses the inotify kernel API: http://lkml.org/lkml/2006/6/1/145 Signed-off-by: Amy Griffis <amy.griffis@hp.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-06-20[PATCH] collect sid of those who send signals to auditdAl Viro
2006-06-20[PATCH] fix deadlocks in AUDIT_LIST/AUDIT_LIST_RULESAl Viro
We should not send a pile of replies while holding audit_netlink_mutex since we hold the same mutex when we receive commands. As the result, we can get blocked while sending and sit there holding the mutex while auditctl is unable to send the next command and get around to receiving what we'd sent. Solution: create skb and put them into a queue instead of sending; once we are done, send what we've got on the list. The former can be done synchronously while we are handling AUDIT_LIST or AUDIT_LIST_RULES; we are holding audit_netlink_mutex at that point. The latter is done asynchronously and without messing with audit_netlink_mutex. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-05-01[PATCH] support for context based audit filtering, part 2Darrel Goeddel
This patch provides the ability to filter audit messages based on the elements of the process' SELinux context (user, role, type, mls sensitivity, and mls clearance). It uses the new interfaces from selinux to opaquely store information related to the selinux context and to filter based on that information. It also uses the callback mechanism provided by selinux to refresh the information when a new policy is loaded. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-03-20[PATCH] sem2mutex: audit_netlink_semIngo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-03-20[PATCH] audit string fields interface + consumerAmy Griffis
Updated patch to dynamically allocate audit rule fields in kernel's internal representation. Added unlikely() calls for testing memory allocation result. Amy Griffis wrote: [Wed Jan 11 2006, 02:02:31PM EST] > Modify audit's kernel-userspace interface to allow the specification > of string fields in audit rules. > > Signed-off-by: Amy Griffis <amy.griffis@hp.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> (cherry picked from 5ffc4a863f92351b720fe3e9c5cd647accff9e03 commit)
2006-03-20[PATCH] Fix audit record filtering with !CONFIG_AUDITSYSCALLDavid Woodhouse
This fixes the per-user and per-message-type filtering when syscall auditing isn't enabled. [AV: folded followup fix from the same author] Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
