path: root/kernel/audit_fsnotify.c
2016-01-22wrappers for ->i_mutex accessAl Viro
parallel to mutex_{lock,unlock,trylock,is_locked,lock_nested}, inode_foo(inode) being mutex_foo(&inode->i_mutex). Please, use those for access to ->i_mutex; over the coming cycle ->i_mutex will become rwsem, with ->lookup() done with it held only shared. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-08-06audit: clean simple fsnotify implementationRichard Guy Briggs
This is to be used to audit by executable path rules, but audit watches should be able to share this code eventually. At the moment the audit watch code is a lot more complex. That code only creates one fsnotify watch per parent directory. That 'audit_parent' in turn has a list of 'audit_watches' which contain the name, ino, dev of the specific object we care about. This just creates one fsnotify watch per object we care about. So if you watch 100 inodes in /etc this code will create 100 fsnotify watches on /etc. The audit_watch code will instead create 1 fsnotify watch on /etc (the audit_parent) and then 100 individual watches chained from that fsnotify mark. We should be able to convert the audit_watch code to do one fsnotify mark per watch and simplify things/remove a whole lot of code. After that conversion we should be able to convert the audit_fsnotify code to support that hierarchy if the optimization is necessary. Move the access to the entry for audit_match_signal() to the beginning of the audit_del_rule() function in case the entry found is the same one passed in. This will enable it to be used by audit_autoremove_mark_rule(), kill_rules() and audit_remove_parent_watches(). This is a heavily modified and merged version of two patches originally submitted by Eric Paris. Cc: Peter Moody <peter@hda3.com> Cc: Eric Paris <eparis@redhat.com> Signed-off-by: Richard Guy Briggs <rgb@redhat.com> [PM: added a space after a declaration to keep ./scripts/checkpatch happy] Signed-off-by: Paul Moore <pmoore@redhat.com>
