commit b4c30aad39805902cf5b855aa8a8b22d728ad057 upstream.
Several leaks in audit_tree didn't get caught by commit
318b6d3d7ddbcad3d6867e630711b8a705d873d7, including the leak on normal
exit in case of multiple rules refering to the same chunk.
commit 6f5d51148921c242680a7a1d9913384a30ab3cbe upstream.
... aka "Al had badly fscked up when writing that thing and nobody
noticed until Eric had fixed leaks that used to mask the breakage".
The function essentially creates a copy of old array sans one element
and replaces the references to elements of original (they are on cyclic
lists) with those to corresponding elements of new one. After that the
old one is fair game for freeing.
First of all, there's a dumb braino: when we get to list_replace_init we
use indices for wrong arrays - position in new one with the old array
and vice versa.
Another bug is more subtle - termination condition is wrong if the
element to be excluded happens to be the last one. We shouldn't go
until we fill the new array, we should go until we'd finished the old
one. Otherwise the element we are trying to kill will remain on the
cyclic lists...
That crap used to be masked by several leaks, so it was not quite
trivial to hit. Eric had fixed some of those leaks a while ago and the
shit had hit the fan...
commit 8f7b0ba1c853919b85b54774775f567f30006107 upstream.
Inotify watch removals suck violently.
To kick the watch out we need (in this order) inode->inotify_mutex and
ih->mutex. That's fine if we have a hold on inode; however, for all
other cases we need to make damn sure we don't race with umount. We can
*NOT* just grab a reference to a watch - inotify_unmount_inodes() will
happily sail past it and we'll end with reference to inode potentially
outliving its superblock.
Ideally we just want to grab an active reference to superblock if we
can; that will make sure we won't go into inotify_umount_inodes() until
we are done. Cleanup is just deactivate_super().
However, that leaves a messy case - what if we *are* racing with
umount() and active references to superblock can't be acquired anymore?
We can bump ->s_count, grab ->s_umount, which will almost certainly wait
until the superblock is shut down and the watch in question is pining
for fjords. That's fine, but there is a problem - we might have hit the
window between ->s_active getting to 0 / ->s_count - below S_BIAS (i.e.
the moment when superblock is past the point of no return and is heading
for shutdown) and the moment when deactivate_super() acquires
->s_umount.
We could just do drop_super() yield() and retry, but that's rather
antisocial and this stuff is luser-triggerable. OTOH, having grabbed
->s_umount and having found that we'd got there first (i.e. that
->s_root is non-NULL) we know that we won't race with
inotify_umount_inodes().
So we could grab a reference to watch and do the rest as above, just
with drop_super() instead of deactivate_super(), right? Wrong. We had
to drop ih->mutex before we could grab ->s_umount. So the watch
could've been gone already.
That still can be dealt with - we need to save watch->wd, do idr_find()
and compare its result with our pointer. If they match, we either have
the damn thing still alive or we'd lost not one but two races at once,
the watch had been killed and a new one got created with the same ->wd
at the same address. That couldn't have happened in inotify_destroy(),
but inotify_rm_wd() could run into that. Still, "new one got created"
is not a problem - we have every right to kill it or leave it alone,
whatever's more convenient.
So we can use idr_find(...) == watch && watch->inode->i_sb == sb as
"grab it and kill it" check. If it's been our original watch, we are
fine, if it's a newcomer - nevermind, just pretend that we'd won the
race and kill the fscker anyway; we are safe since we know that its
superblock won't be going away.
And yes, this is far beyond mere "not very pretty"; so's the entire
concept of inotify to start with.
Acked-by: Greg KH <greg@kroah.com>
All uses of list_for_each_rcu() can be profitably replaced by the
easier-to-use list_for_each_entry_rcu(). This patch makes this change
for the Audit system, in preparation for removing the list_for_each_rcu()
API entirely. This time with well-formed SOB.
* Add path_put() functions for releasing a reference to the dentry and
vfsmount of a struct path in the right order
* Switch from path_release(nd) to path_put(&nd->path)
* Rename dput_path() to path_put_conditional()
[akpm@linux-foundation.org: fix cifs]
Signed-off-by: Jan Blunck <jblunck@suse.de>
Signed-off-by: Andreas Gruenbacher <agruen@suse.de>
Acked-by: Christoph Hellwig <hch@lst.de>
Cc: <linux-fsdevel@vger.kernel.org>
Cc: Steven French <sfrench@us.ibm.com>
This is the central patch of a cleanup series. In most cases there is no good
reason why someone would want to use a dentry for itself. This series reflects
that fact and embeds a struct path into nameidata.
Together with the other patches of this series
- it enforced the correct order of getting/releasing the reference count on
<dentry,vfsmount> pairs
- it prepares the VFS for stacking support since it is essential to have a
struct path in every place where the stack can be traversed
- it reduces the overall code size:
without patch series:
5321639 858418 715768 6895825 6938d1 vmlinux
with patch series:
5320026 858418 715768 6894212 693284 vmlinux
This patch:
Switch from nd->{dentry,mnt} to nd->path.{dentry,mnt} everywhere.
[akpm@linux-foundation.org: fix smack]
Cc: Casey Schaufler <casey@schaufler-ca.com>
New kind of audit rule predicates: "object is visible in given subtree".
The part that can be sanely implemented, that is. Limitations:
* if you have hardlink from outside of tree, you'd better watch
it too (or just watch the object itself, obviously)
* if you mount something under a watched tree, tell audit
that new chunk should be added to watched subtrees
* if you umount something in a watched tree and it's still mounted
elsewhere, you will get matches on events happening there. New command
tells audit to recalculate the trees, trimming such sources of false
positives.
Note that it's _not_ about path - if something mounted in several places
(multiple mount, bindings, different namespaces, etc.), the match does
_not_ depend on which one we are using for access.
