audit now gets a mark in the should_send_event and handle_event
functions. Rather than look up the mark themselves audit should just use
the mark it was handed.
Signed-off-by: Eric Paris <eparis@redhat.com>
With the change of fsnotify to use srcu walking the marks list instead of
walking the global groups list we now know the mark in question. The code can
send the mark to the group's handling functions and the groups won't have to
find those marks themselves.
Al explains that calling dentry_open() with a mnt/dentry pair is only
garunteed to be safe if they are already used in an open struct file. To
make sure this is the case don't store and use a struct path in fsnotify,
always use a struct file.
currently all marking is done by functions in inode-mark.c. Some of this
is pretty generic and should be instead done in a generic function and we
should only put the inode specific code in inode-mark.c
All callers to fsnotify_find_mark_entry() except one take and
release inode->i_lock around the call. Take the lock inside
fsnotify_find_mark_entry() instead.
Signed-off-by: Andreas Gruenbacher <agruen@suse.de>
the _entry portion of fsnotify functions is useless. Drop it.
The name is long and it serves no real purpose. So rename
fsnotify_mark_entry to just fsnotify_mark.
To ensure that a group will not duplicate events when it receives it based
on the vfsmount and the inode should_send_event test we should distinguish
those two cases. We pass a vfsmount to this function so groups can make
their own determinations.
Nothing uses the mask argument to fsnotify_alloc_group. This patch drops
that argument.
Currently the audit watch group always sets a mask equal to all events it
might care about. We instead should only set the group mask if we are
actually watching inodes. This should be a perf win when audit watches are
compiled in.
fsnotify_obtain_group was intended to be able to find an already existing
group. Nothing uses that functionality. This just renames it to
fsnotify_alloc_group so it is clear what it is doing.
The original fsnotify interface has a group-num which was intended to be
able to find a group after it was added. I no longer think this is a
necessary thing to do and so we remove the group_num.
fanotify is going to need to look at file->private_data to know if an event
should be sent or not. This passes the data (which might be a file,
dentry, inode, or none) to the should_send function calls so fanotify can
get that information when available
fanotify is only interested in event types which contain enough information
to open the original file in the context of the fanotify listener. Since
fanotify may not want to send events if that data isn't present we pass
the data type to the should_send_event function call so fanotify can express
its lack of interest.
Audit watch init and fsnotify init both use subsys_initcall() but since the
audit watch code is linked in before the fsnotify code the audit watch code
would be using the fsnotify srcu struct before it was initialized. This
patch fixes that problem by moving audit watch init to device_initcall() so
it happens after fsnotify is ready.
Tested-by : Sachin Sant <sachinp@in.ibm.com>
This patch allows a task to add a second fsnotify mark to an inode for the
same group. This mark will be added to the end of the inode's list and
this will never be found by the stand fsnotify_find_mark() function. This
is useful if a user wants to add a new mark before removing the old one.
deleting audit watch rules is not currently done under audit_filter_mutex.
It was done this way because we could not hold the mutex during inotify
manipulation. Since we are using fsnotify we don't need to do the extra
get/put pair nor do we need the private list on which to store the parents
while they are about to be freed.
fsnotify can handle mutexes to be held across all fsnotify operations since
it deals strickly in spinlocks. This can simplify and reduce some of the
audit_filter_mutex taking and dropping.
Audit currently uses inotify to pin inodes in core and to detect when
watched inodes are deleted or unmounted. This patch uses fsnotify instead
of inotify.
No real changes, just cleanup to the audit_watch split patch which we done
with minimal code changes for easy review. Now fix interfaces to make
things work better.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
pahole showed that struct audit_watch had two holes:
struct audit_watch {
atomic_t count; /* 0 4 */
/* XXX 4 bytes hole, try to pack */
char * path; /* 8 8 */
dev_t dev; /* 16 4 */
long unsigned int ino; /* 24 8 */
struct audit_parent * parent; /* 32 8 */
struct list_head wlist; /* 40 16 */
struct list_head rules; /* 56 16 */
/* --- cacheline 1 boundary (64 bytes) was 8 bytes ago --- */
/* size: 72, cachelines: 2, members: 7 */
/* sum members: 64, holes: 2, sum holes: 8 */
/* last cacheline: 8 bytes */
}; /* definitions: 1 */
by moving dev after count we save 8 bytes, actually improving cacheline
usage. There are typically very few of these in the kernel so it won't be
a large savings, but it's a good thing no matter what.
A number of places in the audit system we send an op= followed by a string
that includes spaces. Somehow this works but it's just wrong. This patch
moves all of those that I could find to be quoted.
Example:
Change From: type=CONFIG_CHANGE msg=audit(1244666690.117:31): auid=0 ses=1
subj=unconfined_u:unconfined_r:auditctl_t:s0-s0:c0.c1023 op=remove rule
key="number2" list=4 res=0
Change To: type=CONFIG_CHANGE msg=audit(1244666690.117:31): auid=0 ses=1
subj=unconfined_u:unconfined_r:auditctl_t:s0-s0:c0.c1023 op="remove rule"
audit_get_nd() is only used by audit_watch and could be more cleanly
implemented by having the audit watch functions call it when needed rather
than making the generic audit rule parsing code deal with those objects.
In preparation for converting audit to use fsnotify instead of inotify we
seperate the inode watching code into it's own file. This is similar to
how the audit tree watching code is already seperated into audit_tree.c
