[ Upstream commit 70c4cf17e445264453bc5323db3e50aa0ac9e81f ]
In audit_rule_change(), audit_data_to_entry() is firstly invoked to
translate the payload data to the kernel's rule representation. In
audit_data_to_entry(), depending on the audit field type, an audit tree may
be created in audit_make_tree(), which eventually invokes kmalloc() to
allocate the tree. Since this tree is a temporary tree, it will be then
freed in the following execution, e.g., audit_add_rule() if the message
type is AUDIT_ADD_RULE or audit_del_rule() if the message type is
AUDIT_DEL_RULE. However, if the message type is neither AUDIT_ADD_RULE nor
AUDIT_DEL_RULE, i.e., the default case of the switch statement, this
temporary tree is not freed.
To fix this issue, only allocate the tree when the type is AUDIT_ADD_RULE
or AUDIT_DEL_RULE.
Signed-off-by: Wenwen Wang <wang6495@umn.edu>
Reviewed-by: Richard Guy Briggs <rgb@redhat.com>
Signed-off-by: Paul Moore <paul@paul-moore.com>
[ Upstream commit 23bcc480dac204c7dbdf49d96b2c918ed98223c2 ]
Current implementation of auditing by executable name only implements
the 'equal' operator. This patch extends it to also support the 'not
equal' operator.
See: https://github.com/linux-audit/audit-kernel/issues/53
Signed-off-by: Ondrej Mosnacek <omosnace@redhat.com>
We were setting the portid incorrectly in the netlink message headers,
fix that to always be 0 (nlmsg_pid = 0).
The excess ; after the closing parenthesis is just code-noise it has no
and can be removed.
Signed-off-by: Nicholas Mc Guire <der.herr@hofr.at>
[PM: tweak subject line]
Define AUDIT_SESSIONID in the uapi and add support for specifying user
filters based on the session ID. Also add the new session ID filter
to the feature bitmap so userspace knows it is available.
https://github.com/linux-audit/audit-kernel/issues/4
RFE: add a session ID filter to the kernel's user filter
Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
[PM: combine multiple patches from Richard into this one]
The AUDIT_CONFIG_CHANGE events sometimes use a op= field. The current
code logs the value of the field with quotes. This field is documented
to not be encoded, so it should not have quotes.
Signed-off-by: Steve Grubb <sgrubb@redhat.com>
[PM: reformatted commit description to make checkpatch.pl happy]
RFE: add additional fields for use in audit filter exclude rules
Re-factor and combine audit_filter_type() with audit_filter_user() to
use audit_filter_user_rules() to enable the exclude filter to
additionally filter on PID, UID, GID, AUID, LOGINUID_SET, SUBJ_*.
The process of combining the similar audit_filter_user() and
audit_filter_type() functions, required inverting the meaning and
including the ALWAYS action of the latter.
Include audit_filter_user_rules() into audit_filter(), removing
unneeded logic in the process.
Keep the check to quit early if the list is empty.
[PM: checkpatch.pl fixes - whitespace damage, wrapped description]
In commit 724e4fcc the intention was to pass any errors back from
audit_filter_user_rules() to audit_filter_user(). Add that code.
Signed-off-by: Weiyuan <weiyuan.wei@huawei.com>
Signed-off-by: Scott Matheina <scott@matheina.com>
[PM: fixed subject line]
Signed-off-by: Paul Moore <pmoore@redhat.com>
This adds the ability audit the actions of a not-yet-running process.
This patch implements the ability to filter on the executable path. Instead of
just hard coding the ino and dev of the executable we care about at the moment
the rule is inserted into the kernel, use the new audit_fsnotify
infrastructure to manage this dynamically. This means that if the filename
does not yet exist but the containing directory does, or if the inode in
question is unlinked and creat'd (aka updated) the rule will just continue to
work. If the containing directory is moved or deleted or the filesystem is
unmounted, the rule is deleted automatically. A future enhancement would be to
have the rule survive across directory disruptions.
This is a heavily modified version of a patch originally submitted by Eric
Paris with some ideas from Peter Moody.
Cc: Peter Moody <peter@hda3.com>
Cc: Eric Paris <eparis@redhat.com>
[PM: minor whitespace clean to satisfy ./scripts/checkpatch]
This is to be used to audit by executable path rules, but audit watches should
be able to share this code eventually.
At the moment the audit watch code is a lot more complex. That code only
creates one fsnotify watch per parent directory. That 'audit_parent' in
turn has a list of 'audit_watches' which contain the name, ino, dev of
the specific object we care about. This just creates one fsnotify watch
per object we care about. So if you watch 100 inodes in /etc this code
will create 100 fsnotify watches on /etc. The audit_watch code will
instead create 1 fsnotify watch on /etc (the audit_parent) and then 100
individual watches chained from that fsnotify mark.
We should be able to convert the audit_watch code to do one fsnotify
mark per watch and simplify things/remove a whole lot of code. After
that conversion we should be able to convert the audit_fsnotify code to
support that hierarchy if the optimization is necessary.
Move the access to the entry for audit_match_signal() to the beginning of
the audit_del_rule() function in case the entry found is the same one passed
in. This will enable it to be used by audit_autoremove_mark_rule(),
kill_rules() and audit_remove_parent_watches().
This is a heavily modified and merged version of two patches originally
submitted by Eric Paris.
[PM: added a space after a declaration to keep ./scripts/checkpatch happy]
Move the access to the entry for audit_match_signal() to earlier in the
function in case the entry found is the same one passed in. This will enable
it to be used by audit_remove_mark_rule().
[PM: tweaked subject line as it no longer made sense after multiple revs]
As reported by the 0-Day testing service:
kernel/auditfilter.c: In function 'audit_rule_change':
>> kernel/auditfilter.c:864:6: warning: 'err' may be used uninit...
int err;
Cc: Richard Guy Briggs <rgb@redhat.com>
The audit watch count was imbalanced, adding an unnecessary layer of watch
references. Only add the second reference when it is added to a parent.
Pull audit fix from Paul Moore:
"Just one patch from the audit tree for v3.20, and a very minor one at
that.
The patch simply removes an old, unused field from the audit_krule
structure, a private audit-only struct. In audit related news, we did
a proper overhaul of the audit pathname code and removed the nasty
getname()/putname() hacks for audit, you should see those patches in
Al's vfs tree if you haven't already.
That's it for audit this time, let's hope for a quiet -rcX series"
* 'upstream' of git://git.infradead.org/users/pcmoore/audit:
audit: remove vestiges of vers_ops
Should have been removed with commit 18900909 ("audit: remove the old
depricated kernel interface").
Pull audit fixes from Paul Moore:
"Four patches to fix various problems with the audit subsystem, all are
fairly small and straightforward.
One patch fixes a problem where we weren't using the correct gfp
allocation flags (GFP_KERNEL regardless of context, oops), one patch
fixes a problem with old userspace tools (this was broken for a
while), one patch fixes a problem where we weren't recording pathnames
correctly, and one fixes a problem with PID based filters.
In general I don't think there is anything controversial with this
patchset, and it fixes some rather unfortunate bugs; the allocation
flag one can be particularly scary looking for users"
audit: restore AUDIT_LOGINUID unset ABI
audit: correctly record file names with different path name types
audit: use supplied gfp_mask from audit_buffer in kauditd_send_multicast_skb
audit: don't attempt to lookup PIDs when changing PID filtering audit rules
A regression was caused by commit 780a7654cee8:
audit: Make testing for a valid loginuid explicit.
(which in turn attempted to fix a regression caused by e1760bd)
When audit_krule_to_data() fills in the rules to get a listing, there was a
missing clause to convert back from AUDIT_LOGINUID_SET to AUDIT_LOGINUID.
This broke userspace by not returning the same information that was sent and
expected.
The rule:
auditctl -a exit,never -F auid=-1
gives:
auditctl -l
LIST_RULES: exit,never f24=0 syscall=all
when it should give:
LIST_RULES: exit,never auid=-1 (0xffffffff) syscall=all
Tag it so that it is reported the same way it was set. Create a new
private flags audit_krule field (pflags) to store it that won't interact with
the public one from the API.
Cc: stable@vger.kernel.org # v3.10-rc1+
Commit f1dc4867 ("audit: anchor all pid references in the initial pid
namespace") introduced a find_vpid() call when adding/removing audit
rules with PID/PPID filters; unfortunately this is problematic as
find_vpid() only works if there is a task with the associated PID
alive on the system. The following commands demonstrate a simple
reproducer.
# auditctl -D
# auditctl -l
# autrace /bin/true
# auditctl -l
This patch resolves the problem by simply using the PID provided by
the user without any additional validation, e.g. no calls to check to
see if the task/PID exists.
Cc: stable@vger.kernel.org # 3.15
Acked-by: Eric Paris <eparis@redhat.com>
Pull audit updates from Eric Paris:
"So this change across a whole bunch of arches really solves one basic
problem. We want to audit when seccomp is killing a process. seccomp
hooks in before the audit syscall entry code. audit_syscall_entry
took as an argument the arch of the given syscall. Since the arch is
part of what makes a syscall number meaningful it's an important part
of the record, but it isn't available when seccomp shoots the
syscall...
For most arch's we have a better way to get the arch (syscall_get_arch)
So the solution was two fold: Implement syscall_get_arch() everywhere
there is audit which didn't have it. Use syscall_get_arch() in the
seccomp audit code. Having syscall_get_arch() everywhere meant it was
a useless flag on the stack and we could get rid of it for the typical
syscall entry.
The other changes inside the audit system aren't grand, fixed some
records that had invalid spaces. Better locking around the task comm
field. Removing some dead functions and structs. Make some things
static. Really minor stuff"
* git://git.infradead.org/users/eparis/audit: (31 commits)
audit: rename audit_log_remove_rule to disambiguate for trees
audit: cull redundancy in audit_rule_change
audit: WARN if audit_rule_change called illegally
audit: put rule existence check in canonical order
next: openrisc: Fix build
audit: get comm using lock to avoid race in string printing
audit: remove open_arg() function that is never used
audit: correct AUDIT_GET_FEATURE return message type
audit: set nlmsg_len for multicast messages.
audit: use union for audit_field values since they are mutually exclusive
audit: invalid op= values for rules
audit: use atomic_t to simplify audit_serial()
kernel/audit.c: use ARRAY_SIZE instead of sizeof/sizeof[0]
audit: reduce scope of audit_log_fcaps
audit: reduce scope of audit_net_id
audit: arm64: Remove the audit arch argument to audit_syscall_entry
arm64: audit: Add audit hook in syscall_trace_enter/exit()
audit: x86: drop arch from __audit_syscall_entry() interface
sparc: implement is_32bit_task
sparc: properly conditionalize use of TIF_32BIT
Re-factor audit_rule_change() to reduce the amount of code redundancy and
simplify the logic.
Signed-off-by: Eric Paris <eparis@redhat.com>
Use same rule existence check order as audit_make_tree(), audit_to_watch(),
update_lsm_rule() for legibility.
Since only one of val, uid, gid and lsm* are used at any given time, combine
them to reduce the size of the struct audit_field.
Various audit events dealing with adding, removing and updating rules result in
invalid values set for the op keys which result in embedded spaces in op=
values.
The invalid values are
op="add rule" set in kernel/auditfilter.c
op="remove rule" set in kernel/auditfilter.c
op="remove rule" set in kernel/audit_tree.c
op="updated rules" set in kernel/audit_watch.c
op="remove rule" set in kernel/audit_watch.c
Replace the space in the above values with an underscore character ('_').
Coded-by: Burn Alting <burn@swtf.dyndns.org>
kcalloc manages count*sizeof overflow.
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Pull audit updates from Eric Paris.
* git://git.infradead.org/users/eparis/audit: (28 commits)
AUDIT: make audit_is_compat depend on CONFIG_AUDIT_COMPAT_GENERIC
audit: renumber AUDIT_FEATURE_CHANGE into the 1300 range
audit: do not cast audit_rule_data pointers pointlesly
AUDIT: Allow login in non-init namespaces
audit: define audit_is_compat in kernel internal header
kernel: Use RCU_INIT_POINTER(x, NULL) in audit.c
sched: declare pid_alive as inline
audit: use uapi/linux/audit.h for AUDIT_ARCH declarations
syscall_get_arch: remove useless function arguments
audit: remove stray newline from audit_log_execve_info() audit_panic() call
audit: remove stray newlines from audit_log_lost messages
audit: include subject in login records
audit: remove superfluous new- prefix in AUDIT_LOGIN messages
audit: allow user processes to log from another PID namespace
audit: anchor all pid references in the initial pid namespace
audit: convert PPIDs to the inital PID namespace.
pid: get pid_t ppid of task in init_pid_ns
audit: rename the misleading audit_get_context() to audit_take_context()
audit: Add generic compat syscall support
audit: Add CONFIG_HAVE_ARCH_AUDITSYSCALL
For some sort of legacy support audit_rule is a subset of (and first
entry in) audit_rule_data. We don't actually need or use audit_rule.
We just do a cast from one to the other for no gain what so ever. Stop
the crazy casting.
Store and log all PIDs with reference to the initial PID namespace and
use the access functions task_pid_nr() and task_tgid_nr() for task->pid
and task->tgid.
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
(informed by ebiederman's c776b5d2)
In perverse cases of file descriptor passing the current network
namespace of a process and the network namespace of a socket used by
that socket may differ. Therefore use the network namespace of the
appropiate socket to ensure replies always go to the appropiate
socket.
Acked-by: Richard Guy Briggs <rgb@redhat.com>
While reading through 3.14-rc1 I found a pretty siginficant mishandling
of network namespaces in the recent audit changes.
In struct audit_netlink_list and audit_reply add a reference to the
network namespace of the caller and remove the userspace pid of the
caller. This cleanly remembers the callers network namespace, and
removes a huge class of races and nasty failure modes that can occur
when attempting to relook up the callers network namespace from a pid_t
(including the caller's network namespace changing, pid wraparound, and
the pid simply not being present).
The kbuild test robot reported:
> tree: git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace.git for-next
> head: 6f285b19d09f72e801525f5eea1bdad22e559bf0
> commit: 6f285b19d09f72e801525f5eea1bdad22e559bf0 [2/2] audit: Send replies in the proper network namespace.
> reproduce: make htmldocs
> >> Warning(kernel/audit.c:575): No description found for parameter 'request_skb'
> >> Warning(kernel/audit.c:575): Excess function parameter 'portid' description in 'audit_send_reply'
> >> Warning(kernel/auditfilter.c:1074): No description found for parameter 'request_skb'
> >> Warning(kernel/auditfilter.c:1074): Excess function parameter 'portid' description in 'audit_list_rules_s
Which was caused by my failure to update the kdoc annotations when I
updated the functions. Fix that small oversight now.
Add pr_fmt to prefix "audit: " to output
Convert printk(KERN_<LEVEL> to pr_<level>
Coalesce formats
socket.
pid_t (including the caller's network namespace changing, pid
wraparound, and the pid simply not being present).
An error on an AUDIT_NEVER rule disabled logging on that rule.
On error on AUDIT_NEVER rules, log.
Right now the sessionid value in the kernel is a combination of u32,
int, and unsigned int. Just use unsigned int throughout.
audit_receive_msg() needlessly contained a fallthrough case that called
audit_receive_filter(), containing no common code between the cases. Separate
them to make the logic clearer. Refactor AUDIT_LIST_RULES, AUDIT_ADD_RULE,
AUDIT_DEL_RULE cases to create audit_rule_change(), audit_list_rules_send()
functions. This should not functionally change the logic.
Convert audit from only listening in init_net to use register_pernet_subsys()
to dynamically manage the netlink socket list.
Normally, netlink ports use the PID of the userspace process as the port ID.
If the PID is already in use by a port, the kernel will allocate another port
ID to avoid conflict. Re-name all references to netlink ports from pid to
portid to reflect this reality and avoid confusion with actual PIDs. Ports
use the __u32 type, so re-type all portids accordingly.
(This patch is very similar to ebiederman's 5deadd69)
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
commit ab61d38ed8cf670946d12dc46b9198b521c790ea tried to merge the
invalid filter checking into a single function. However AUDIT_INODE
filters were not verified in the new generic checker. Thus such rules
were being denied even though they were perfectly valid.
Ex:
$ auditctl -a exit,always -F arch=b64 -S open -F key=/foo -F inode=6955 -F devmajor=9 -F devminor=1
Error sending add rule data request (Invalid argument)
SFR reported this 2013-05-15:
> After merging the final tree, today's linux-next build (i386 defconfig)
> produced this warning:
> kernel/auditfilter.c: In function 'audit_data_to_entry':
> kernel/auditfilter.c:426:3: warning: this decimal constant is unsigned only
> in ISO C90 [enabled by default]
> Introduced by commit 780a7654cee8 ("audit: Make testing for a valid
> loginuid explicit") from Linus' tree.
Replace this decimal constant in the code with a macro to make it more readable
(add to the unsigned cast to quiet the warning).
Use proper decimal type for comparison with u32.
Compilation warning was introduced by 780a7654 ("audit: Make testing for
a valid loginuid explicit.")
kernel/auditfilter.c:426:3: warning: this decimal constant is unsigned only in ISO C90 [enabled by default]
if ((f->type == AUDIT_LOGINUID) && (f->val == 4294967295)) {
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
If both 'tree' and 'watch' are valid we must call audit_put_tree(), just
like the preceding code within audit_add_rule().
Signed-off-by: Chen Gang <gang.chen@asianux.com>
kernel/auditfilter.c:426: warning: this decimal constant is unsigned only in ISO C90
Signed-off-by: Raphael S. Carvalho <raphael.scarv@gmail.com>
Fix kernel-doc warnings in kernel/auditfilter.c:
Warning(kernel/auditfilter.c:1029): Excess function parameter 'loginuid' description in 'audit_receive_filter'
Warning(kernel/auditfilter.c:1029): Excess function parameter 'sessionid' description in 'audit_receive_filter'
Warning(kernel/auditfilter.c:1029): Excess function parameter 'sid' description in 'audit_receive_filter'
Pull audit changes from Eric Paris:
"Al used to send pull requests every couple of years but he told me to
just start pushing them to you directly.
Our touching outside of core audit code is pretty straight forward. A
couple of interface changes which hit net/. A simple argument bug
calling audit functions in namei.c and the removal of some assembly
branch prediction code on ppc"
audit: fix message spacing printing auid
Revert "audit: move kaudit thread start from auditd registration to kaudit init"
audit: vfs: fix audit_inode call in O_CREAT case of do_last
audit: fix event coverage of AUDIT_ANOM_LINK
audit: use spin_lock in audit_receive_msg to process tty logging
audit: do not needlessly take a lock in tty_audit_exit
audit: do not needlessly take a spinlock in copy_signal
audit: add an option to control logging of passwords with pam_tty_audit
audit: use spin_lock_irqsave/restore in audit tty code
helper for some session id stuff
audit: use a consistent audit helper to log lsm information
audit: push loginuid and sessionid processing down
audit: stop pushing loginid, uid, sessionid as arguments
audit: remove the old depricated kernel interface
audit: make validity checking generic
audit: allow checking the type of audit message in the user filter
audit: fix build break when AUDIT_DEBUG == 2
audit: remove duplicate export of audit_enabled
Audit: do not print error when LSMs disabled
audit rule additions containing "-F auid!=4294967295" were failing
with EINVAL because of a regression caused by e1760bd.
Apparently some userland audit rule sets want to know if loginuid uid
has been set and are using a test for auid != 4294967295 to determine
that.
In practice that is a horrible way to ask if a value has been set,
because it relies on subtle implementation details and will break
every time the uid implementation in the kernel changes.
So add a clean way to test if the audit loginuid has been set, and
silently convert the old idiom to the cleaner and more comprehensible
new idiom.
Cc: <stable@vger.kernel.org> # 3.7
Reported-By: Richard Guy Briggs <rgb@redhat.com>
Tested-by: Richard Guy Briggs <rgb@redhat.com>
