commit 6d4f151acf9a4f6fab09b615f246c717ddedcf0c upstream.
Anatoly has been fuzzing with kBdysch harness and reported a KASAN
slab oob in one of the outcomes:
[ 77.359642] BUG: KASAN: slab-out-of-bounds in bpf_skb_load_helper_8_no_cache+0x71/0x130
[ 77.360463] Read of size 4 at addr ffff8880679bac68 by task bpf/406
[ 77.361119]
[ 77.361289] CPU: 2 PID: 406 Comm: bpf Not tainted 5.5.0-rc2-xfstests-00157-g2187f215eba #1
[ 77.362134] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.12.0-1 04/01/2014
[ 77.362984] Call Trace:
[ 77.363249] dump_stack+0x97/0xe0
[ 77.363603] print_address_description.constprop.0+0x1d/0x220
[ 77.364251] ? bpf_skb_load_helper_8_no_cache+0x71/0x130
[ 77.365030] ? bpf_skb_load_helper_8_no_cache+0x71/0x130
[ 77.365860] __kasan_report.cold+0x37/0x7b
[ 77.366365] ? bpf_skb_load_helper_8_no_cache+0x71/0x130
[ 77.366940] kasan_report+0xe/0x20
[ 77.367295] bpf_skb_load_helper_8_no_cache+0x71/0x130
[ 77.367821] ? bpf_skb_load_helper_8+0xf0/0xf0
[ 77.368278] ? mark_lock+0xa3/0x9b0
[ 77.368641] ? kvm_sched_clock_read+0x14/0x30
[ 77.369096] ? sched_clock+0x5/0x10
[ 77.369460] ? sched_clock_cpu+0x18/0x110
[ 77.369876] ? bpf_skb_load_helper_8+0xf0/0xf0
[ 77.370330] ___bpf_prog_run+0x16c0/0x28f0
[ 77.370755] __bpf_prog_run32+0x83/0xc0
[ 77.371153] ? __bpf_prog_run64+0xc0/0xc0
[ 77.371568] ? match_held_lock+0x1b/0x230
[ 77.371984] ? rcu_read_lock_held+0xa1/0xb0
[ 77.372416] ? rcu_is_watching+0x34/0x50
[ 77.372826] sk_filter_trim_cap+0x17c/0x4d0
[ 77.373259] ? sock_kzfree_s+0x40/0x40
[ 77.373648] ? __get_filter+0x150/0x150
[ 77.374059] ? skb_copy_datagram_from_iter+0x80/0x280
[ 77.374581] ? do_raw_spin_unlock+0xa5/0x140
[ 77.375025] unix_dgram_sendmsg+0x33a/0xa70
[ 77.375459] ? do_raw_spin_lock+0x1d0/0x1d0
[ 77.375893] ? unix_peer_get+0xa0/0xa0
[ 77.376287] ? __fget_light+0xa4/0xf0
[ 77.376670] __sys_sendto+0x265/0x280
[ 77.377056] ? __ia32_sys_getpeername+0x50/0x50
[ 77.377523] ? lock_downgrade+0x350/0x350
[ 77.377940] ? __sys_setsockopt+0x2a6/0x2c0
[ 77.378374] ? sock_read_iter+0x240/0x240
[ 77.378789] ? __sys_socketpair+0x22a/0x300
[ 77.379221] ? __ia32_sys_socket+0x50/0x50
[ 77.379649] ? mark_held_locks+0x1d/0x90
[ 77.380059] ? trace_hardirqs_on_thunk+0x1a/0x1c
[ 77.380536] __x64_sys_sendto+0x74/0x90
[ 77.380938] do_syscall_64+0x68/0x2a0
[ 77.381324] entry_SYSCALL_64_after_hwframe+0x49/0xbe
[ 77.381878] RIP: 0033:0x44c070
After further debugging, turns out while in case of other helper functions
we disallow passing modified ctx, the special case of ld/abs/ind instruction
which has similar semantics (except r6 being the ctx argument) is missing
such check. Modified ctx is impossible here as bpf_skb_load_helper_8_no_cache()
and others are expecting skb fields in original position, hence, add
check_ctx_reg() to reject any modified ctx. Issue was first introduced back
in f1174f77b50c ("bpf/verifier: rework value tracking").
Fixes: f1174f77b50c ("bpf/verifier: rework value tracking")
Reported-by: Anatoly Trosinenko <anatoly.trosinenko@gmail.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
Link: https://lore.kernel.org/bpf/20200106215157.3553-1-daniel@iogearbox.net
commit 58990d1ff3f7896ee341030e9a7c2e4002570683 upstream.
As commit 28e33f9d78ee ("bpf: disallow arithmetic operations on
context pointer") already describes, f1174f77b50c ("bpf/verifier:
rework value tracking") removed the specific white-listed cases
we had previously where we would allow for pointer arithmetic in
order to further generalize it, and allow e.g. context access via
modified registers. While the dereferencing of modified context
pointers had been forbidden through 28e33f9d78ee, syzkaller did
recently manage to trigger several KASAN splats for slab out of
bounds access and use after frees by simply passing a modified
context pointer to a helper function which would then do the bad
access since verifier allowed it in adjust_ptr_min_max_vals().
Rejecting arithmetic on ctx pointer in adjust_ptr_min_max_vals()
generally could break existing programs as there's a valid use
case in tracing in combination with passing the ctx to helpers as
bpf_probe_read(), where the register then becomes unknown at
verification time due to adding a non-constant offset to it. An
access sequence may look like the following:
offset = args->filename; /* field __data_loc filename */
bpf_probe_read(&dst, len, (char *)args + offset); // args is ctx
There are two options: i) we could special case the ctx and as
soon as we add a constant or bounded offset to it (hence ctx type
wouldn't change) we could turn the ctx into an unknown scalar, or
ii) we generalize the sanity test for ctx member access into a
small helper and assert it on the ctx register that was passed
as a function argument. Fwiw, latter is more obvious and less
complex at the same time, and one case that may potentially be
legitimate in future for ctx member access at least would be for
ctx to carry a const offset. Therefore, fix follows approach
from ii) and adds test cases to BPF kselftests.
Reported-by: syzbot+3d0b2441dbb71751615e@syzkaller.appspotmail.com
Reported-by: syzbot+c8504affd4fdd0c1b626@syzkaller.appspotmail.com
Reported-by: syzbot+e5190cb881d8660fb1a3@syzkaller.appspotmail.com
Reported-by: syzbot+efae31b384d5badbd620@syzkaller.appspotmail.com
Acked-by: Alexei Starovoitov <ast@kernel.org>
Acked-by: Yonghong Song <yhs@fb.com>
Acked-by: Edward Cree <ecree@solarflare.com>
[ Upstream commit 352d20d611414715353ee65fc206ee57ab1a6984 ]
In bpf/syscall.c, map_create() first set map->usercnt to 1, a file
descriptor is supposed to return to userspace. When bpf_map_new_fd()
fails, drop the refcount.
Fixes: bd5f5f4ecb78 ("bpf: Add BPF_MAP_GET_FD_BY_ID")
Signed-off-by: Peng Sun <sironhide0null@gmail.com>
Acked-by: Martin KaFai Lau <kafai@fb.com>
[ Upstream commit 781e62823cb81b972dc8652c1827205cda2ac9ac ]
In bpf/syscall.c, bpf_map_get_fd_by_id() use bpf_map_inc_not_zero()
to increase the refcount, both map->refcnt and map->usercnt. Then, if
bpf_map_new_fd() fails, should handle map->usercnt too.
[ Upstream commit f592f804831f1cf9d1f9966f58c80f150e6829b5 ]
The dev_map_notification() removes interface in devmap if
unregistering interface's ifindex is same.
But only checking ifindex is not enough because other netns can have
same ifindex. so that wrong interface selection could occurred.
Hence netdev pointer comparison code is added.
v2: compare netdev pointer instead of using net_eq() (Daniel Borkmann)
v1: Initial patch
Fixes: 2ddf71e23cc2 ("net: add notifier hooks for devmap bpf map")
Signed-off-by: Taehee Yoo <ap420073@gmail.com>
Acked-by: Song Liu <songliubraving@fb.com>
commit c751798aa224fadc5124b49eeb38fb468c0fa039 upstream.
syzkaller managed to trigger the warning in bpf_jit_free() which checks via
bpf_prog_kallsyms_verify_off() for potentially unlinked JITed BPF progs
in kallsyms, and subsequently trips over GPF when walking kallsyms entries:
8021q: adding VLAN 0 to HW filter on device batadv0
WARNING: CPU: 0 PID: 9869 at kernel/bpf/core.c:810 bpf_jit_free+0x1e8/0x2a0
Kernel panic - not syncing: panic_on_warn set ...
CPU: 0 PID: 9869 Comm: kworker/0:7 Not tainted 5.0.0-rc8+ #1
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Workqueue: events bpf_prog_free_deferred
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x113/0x167 lib/dump_stack.c:113
panic+0x212/0x40b kernel/panic.c:214
__warn.cold.8+0x1b/0x38 kernel/panic.c:571
report_bug+0x1a4/0x200 lib/bug.c:186
fixup_bug arch/x86/kernel/traps.c:178 [inline]
do_error_trap+0x11b/0x200 arch/x86/kernel/traps.c:271
do_invalid_op+0x36/0x40 arch/x86/kernel/traps.c:290
invalid_op+0x14/0x20 arch/x86/entry/entry_64.S:973
RIP: 0010:bpf_jit_free+0x1e8/0x2a0
Code: 02 4c 89 e2 83 e2 07 38 d0 7f 08 84 c0 0f 85 86 00 00 00 48 ba 00 02 00 00 00 00 ad de 0f b6 43 02 49 39 d6 0f 84 5f fe ff ff <0f> 0b e9 58 fe ff ff 48 b8 00 00 00 00 00 fc ff df 4c 89 e2 48 c1
RSP: 0018:ffff888092f67cd8 EFLAGS: 00010202
RAX: 0000000000000007 RBX: ffffc90001947000 RCX: ffffffff816e9d88
RDX: dead000000000200 RSI: 0000000000000008 RDI: ffff88808769f7f0
RBP: ffff888092f67d00 R08: fffffbfff1394059 R09: fffffbfff1394058
R10: fffffbfff1394058 R11: ffffffff89ca02c7 R12: ffffc90001947002
R13: ffffc90001947020 R14: ffffffff881eca80 R15: ffff88808769f7e8
BUG: unable to handle kernel paging request at fffffbfff400d000
#PF error: [normal kernel read fault]
PGD 21ffee067 P4D 21ffee067 PUD 21ffed067 PMD 9f942067 PTE 0
Oops: 0000 [#1] PREEMPT SMP KASAN
RIP: 0010:bpf_get_prog_addr_region kernel/bpf/core.c:495 [inline]
RIP: 0010:bpf_tree_comp kernel/bpf/core.c:558 [inline]
RIP: 0010:__lt_find include/linux/rbtree_latch.h:115 [inline]
RIP: 0010:latch_tree_find include/linux/rbtree_latch.h:208 [inline]
RIP: 0010:bpf_prog_kallsyms_find+0x107/0x2e0 kernel/bpf/core.c:632
Code: 00 f0 ff ff 44 38 c8 7f 08 84 c0 0f 85 fa 00 00 00 41 f6 45 02 01 75 02 0f 0b 48 39 da 0f 82 92 00 00 00 48 89 d8 48 c1 e8 03 <42> 0f b6 04 30 84 c0 74 08 3c 03 0f 8e 45 01 00 00 8b 03 48 c1 e0
Upon further debugging, it turns out that whenever we trigger this
issue, the kallsyms removal in bpf_prog_ksym_node_del() was /skipped/
but yet bpf_jit_free() reported that the entry is /in use/.
Problem is that symbol exposure via bpf_prog_kallsyms_add() but also
perf_event_bpf_event() were done /after/ bpf_prog_new_fd(). Once the
fd is exposed to the public, a parallel close request came in right
before we attempted to do the bpf_prog_kallsyms_add().
Given at this time the prog reference count is one, we start to rip
everything underneath us via bpf_prog_release() -> bpf_prog_put().
The memory is eventually released via deferred free, so we're seeing
that bpf_jit_free() has a kallsym entry because we added it from
bpf_prog_load() but /after/ bpf_prog_put() from the remote CPU.
Therefore, move both notifications /before/ we install the fd. The
issue was never seen between bpf_prog_alloc_id() and bpf_prog_new_fd()
because upon bpf_prog_get_fd_by_id() we'll take another reference to
the BPF prog, so we're still holding the original reference from the
bpf_prog_load().
Fixes: 6ee52e2a3fe4 ("perf, bpf: Introduce PERF_RECORD_BPF_EVENT")
Fixes: 74451e66d516 ("bpf: make jited programs visible in traces")
Reported-by: syzbot+bd3bba6ff3fcea7a6ec6@syzkaller.appspotmail.com
Cc: Song Liu <songliubraving@fb.com>
Signed-off-by: Zubin Mithra <zsm@chromium.org>
[ Upstream commit fdadd04931c2d7cd294dc5b2b342863f94be53a3 ]
Michael and Sandipan report:
Commit ede95a63b5 introduced a bpf_jit_limit tuneable to limit BPF
JIT allocations. At compile time it defaults to PAGE_SIZE * 40000,
and is adjusted again at init time if MODULES_VADDR is defined.
For ppc64 kernels, MODULES_VADDR isn't defined, so we're stuck with
the compile-time default at boot-time, which is 0x9c400000 when
using 64K page size. This overflows the signed 32-bit bpf_jit_limit
value:
root@ubuntu:/tmp# cat /proc/sys/net/core/bpf_jit_limit
-1673527296
and can cause various unexpected failures throughout the network
stack. In one case `strace dhclient eth0` reported:
setsockopt(5, SOL_SOCKET, SO_ATTACH_FILTER, {len=11, filter=0x105dd27f8},
16) = -1 ENOTSUPP (Unknown error 524)
and similar failures can be seen with tools like tcpdump. This doesn't
always reproduce however, and I'm not sure why. The more consistent
failure I've seen is an Ubuntu 18.04 KVM guest booted on a POWER9
host would time out on systemd/netplan configuring a virtio-net NIC
with no noticeable errors in the logs.
Given this and also given that in near future some architectures like
arm64 will have a custom area for BPF JIT image allocations we should
get rid of the BPF_JIT_LIMIT_DEFAULT fallback / default entirely. For
4.21, we have an overridable bpf_jit_alloc_exec(), bpf_jit_free_exec()
so therefore add another overridable bpf_jit_alloc_exec_limit() helper
function which returns the possible size of the memory area for deriving
the default heuristic in bpf_jit_charge_init().
Like bpf_jit_alloc_exec() and bpf_jit_free_exec(), the new
bpf_jit_alloc_exec_limit() assumes that module_alloc() is the default
JIT memory provider, and therefore in case archs implement their custom
module_alloc() we use MODULES_{END,_VADDR} for limits and otherwise for
vmalloc_exec() cases like on ppc64 we use VMALLOC_{END,_START}.
Additionally, for archs supporting large page sizes, we should change
the sysctl to be handled as long to not run into sysctl restrictions
in future.
Fixes: ede95a63b5e8 ("bpf: add bpf_jit_limit knob to restrict unpriv allocations")
Reported-by: Sandipan Das <sandipan@linux.ibm.com>
Reported-by: Michael Roth <mdroth@linux.vnet.ibm.com>
Tested-by: Michael Roth <mdroth@linux.vnet.ibm.com>
commit ede95a63b5e84ddeea6b0c473b36ab8bfd8c6ce3 upstream.
Rick reported that the BPF JIT could potentially fill the entire module
space with BPF programs from unprivileged users which would prevent later
attempts to load normal kernel modules or privileged BPF programs, for
example. If JIT was enabled but unsuccessful to generate the image, then
before commit 290af86629b2 ("bpf: introduce BPF_JIT_ALWAYS_ON config")
we would always fall back to the BPF interpreter. Nowadays in the case
where the CONFIG_BPF_JIT_ALWAYS_ON could be set, then the load will abort
with a failure since the BPF interpreter was compiled out.
Add a global limit and enforce it for unprivileged users such that in case
of BPF interpreter compiled out we fail once the limit has been reached
or we fall back to BPF interpreter earlier w/o using module mem if latter
was compiled in. In a next step, fair share among unprivileged users can
be resolved in particular for the case where we would fail hard once limit
is reached.
Fixes: 290af86629b2 ("bpf: introduce BPF_JIT_ALWAYS_ON config")
Fixes: 0a14842f5a3c ("net: filter: Just In Time compiler for x86-64")
Co-Developed-by: Rick Edgecombe <rick.p.edgecombe@intel.com>
Cc: Jann Horn <jannh@google.com>
Cc: LKML <linux-kernel@vger.kernel.org>
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit fa9dd599b4dae841924b022768354cfde9affecb upstream.
Having a pure_initcall() callback just to permanently enable BPF
JITs under CONFIG_BPF_JIT_ALWAYS_ON is unnecessary and could leave
a small race window in future where JIT is still disabled on boot.
Since we know about the setting at compilation time anyway, just
initialize it properly there. Also consolidate all the individual
bpf_jit_enable variables into a single one and move them under one
location. Moreover, don't allow for setting unspecified garbage
values on them.
[bwh: Backported to 4.14 as dependency of commit 2e4a30983b0f
"bpf: restrict access to core bpf sysctls":
- Adjust context]
[ Upstream commit aee450cbe482a8c2f6fa5b05b178ef8b8ff107ca ]
Compiling kernel/bpf/core.c with W=1 causes a flood of warnings:
kernel/bpf/core.c:1198:65: warning: initialized field overwritten [-Woverride-init]
1198 | #define BPF_INSN_3_TBL(x, y, z) [BPF_##x | BPF_##y | BPF_##z] = true
kernel/bpf/core.c:1087:2: note: in expansion of macro 'BPF_INSN_3_TBL'
1087 | INSN_3(ALU, ADD, X), \
kernel/bpf/core.c:1202:3: note: in expansion of macro 'BPF_INSN_MAP'
1202 | BPF_INSN_MAP(BPF_INSN_2_TBL, BPF_INSN_3_TBL),
kernel/bpf/core.c:1198:65: note: (near initialization for 'public_insntable[12]')
98 copies of the above.
The attached patch silences the warnings, because we *know* we're overwriting
the default initializer. That leaves bpf/core.c with only 6 other warnings,
which become more visible in comparison.
Signed-off-by: Valdis Kletnieks <valdis.kletnieks@vt.edu>
Acked-by: Andrii Nakryiko <andriin@fb.com>
commit 2baae3545327632167c0180e9ca1d467416f1919 upstream.
synchronize_rcu() is fine when the rcu callbacks only need
to free memory (kfree_rcu() or direct kfree() call rcu call backs)
__dev_map_entry_free() is a bit more complex, so we need to make
sure that call queued __dev_map_entry_free() callbacks have completed.
sysbot report:
BUG: KASAN: use-after-free in dev_map_flush_old kernel/bpf/devmap.c:365
[inline]
BUG: KASAN: use-after-free in __dev_map_entry_free+0x2a8/0x300
kernel/bpf/devmap.c:379
Read of size 8 at addr ffff8801b8da38c8 by task ksoftirqd/1/18
CPU: 1 PID: 18 Comm: ksoftirqd/1 Not tainted 4.17.0+ #39
Google 01/01/2011
Call Trace:
dump_stack+0x1b9/0x294 lib/dump_stack.c:113
print_address_description+0x6c/0x20b mm/kasan/report.c:256
kasan_report_error mm/kasan/report.c:354 [inline]
kasan_report.cold.7+0x242/0x2fe mm/kasan/report.c:412
__asan_report_load8_noabort+0x14/0x20 mm/kasan/report.c:433
dev_map_flush_old kernel/bpf/devmap.c:365 [inline]
__dev_map_entry_free+0x2a8/0x300 kernel/bpf/devmap.c:379
__rcu_reclaim kernel/rcu/rcu.h:178 [inline]
rcu_do_batch kernel/rcu/tree.c:2558 [inline]
invoke_rcu_callbacks kernel/rcu/tree.c:2818 [inline]
__rcu_process_callbacks kernel/rcu/tree.c:2785 [inline]
rcu_process_callbacks+0xe9d/0x1760 kernel/rcu/tree.c:2802
__do_softirq+0x2e0/0xaf5 kernel/softirq.c:284
run_ksoftirqd+0x86/0x100 kernel/softirq.c:645
smpboot_thread_fn+0x417/0x870 kernel/smpboot.c:164
kthread+0x345/0x410 kernel/kthread.c:240
ret_from_fork+0x3a/0x50 arch/x86/entry/entry_64.S:412
Allocated by task 6675:
save_stack+0x43/0xd0 mm/kasan/kasan.c:448
set_track mm/kasan/kasan.c:460 [inline]
kasan_kmalloc+0xc4/0xe0 mm/kasan/kasan.c:553
kmem_cache_alloc_trace+0x152/0x780 mm/slab.c:3620
kmalloc include/linux/slab.h:513 [inline]
kzalloc include/linux/slab.h:706 [inline]
dev_map_alloc+0x208/0x7f0 kernel/bpf/devmap.c:102
find_and_alloc_map kernel/bpf/syscall.c:129 [inline]
map_create+0x393/0x1010 kernel/bpf/syscall.c:453
__do_sys_bpf kernel/bpf/syscall.c:2351 [inline]
__se_sys_bpf kernel/bpf/syscall.c:2328 [inline]
__x64_sys_bpf+0x303/0x510 kernel/bpf/syscall.c:2328
do_syscall_64+0x1b1/0x800 arch/x86/entry/common.c:290
Freed by task 26:
__kasan_slab_free+0x11a/0x170 mm/kasan/kasan.c:521
kasan_slab_free+0xe/0x10 mm/kasan/kasan.c:528
__cache_free mm/slab.c:3498 [inline]
kfree+0xd9/0x260 mm/slab.c:3813
dev_map_free+0x4fa/0x670 kernel/bpf/devmap.c:191
bpf_map_free_deferred+0xba/0xf0 kernel/bpf/syscall.c:262
process_one_work+0xc64/0x1b70 kernel/workqueue.c:2153
worker_thread+0x181/0x13a0 kernel/workqueue.c:2296
The buggy address belongs to the object at ffff8801b8da37c0
which belongs to the cache kmalloc-512 of size 512
The buggy address is located 264 bytes inside of
512-byte region [ffff8801b8da37c0, ffff8801b8da39c0)
The buggy address belongs to the page:
page:ffffea0006e368c0 count:1 mapcount:0 mapping:ffff8801da800940
index:0xffff8801b8da3540
flags: 0x2fffc0000000100(slab)
raw: 02fffc0000000100 ffffea0007217b88 ffffea0006e30cc8 ffff8801da800940
raw: ffff8801b8da3540 ffff8801b8da3040 0000000100000004 0000000000000000
page dumped because: kasan: bad access detected
Memory state around the buggy address:
ffff8801b8da3780: fc fc fc fc fc fc fc fc fb fb fb fb fb fb fb fb
ffff8801b8da3800: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
> ffff8801b8da3880: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff8801b8da3900: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff8801b8da3980: fb fb fb fb fb fb fb fb fc fc fc fc fc fc fc fc
Fixes: 546ac1ffb70d ("bpf: add devmap, a map for storing net device references")
Reported-by: syzbot+457d3e2ffbcf31aee5c0@syzkaller.appspotmail.com
Acked-by: Toke Høiland-Jørgensen <toke@redhat.com>
Acked-by: Jesper Dangaard Brouer <brouer@redhat.com>
commit 50b045a8c0ccf44f76640ac3eea8d80ca53979a3 upstream.
One of the biggest issues we face right now with picking LRU map over
regular hash table is that a map walk out of user space, for example,
to just dump the existing entries or to remove certain ones, will
completely mess up LRU eviction heuristics and wrong entries such
as just created ones will get evicted instead. The reason for this
is that we mark an entry as "in use" via bpf_lru_node_set_ref() from
system call lookup side as well. Thus upon walk, all entries are
being marked, so information of actual least recently used ones
are "lost".
In case of Cilium where it can be used (besides others) as a BPF
based connection tracker, this current behavior causes disruption
upon control plane changes that need to walk the map from user space
to evict certain entries. Discussion result from bpfconf [0] was that
we should simply just remove marking from system call side as no
good use case could be found where it's actually needed there.
Therefore this patch removes marking for regular LRU and per-CPU
flavor. If there ever should be a need in future, the behavior could
be selected via map creation flag, but due to mentioned reason we
avoid this here.
[0] http://vger.kernel.org/bpfconf.html
Fixes: 29ba732acbee ("bpf: Add BPF_MAP_TYPE_LRU_HASH")
Fixes: 8f8449384ec3 ("bpf: Add BPF_MAP_TYPE_LRU_PERCPU_HASH")
commit c6110222c6f49ea68169f353565eb865488a8619 upstream.
Add a callback map_lookup_elem_sys_only() that map implementations
could use over map_lookup_elem() from system call side in case the
map implementation needs to handle the latter differently than from
the BPF data path. If map_lookup_elem_sys_only() is set, this will
be preferred pick for map lookups out of user space. This hook is
used in a follow-up fix for LRU map, but once development window
opens, we can convert other map types from map_lookup_elem() (here,
the one called upon BPF_MAP_LOOKUP_ELEM cmd is meant) over to use
the callback to simplify and clean up the latter.
commit 3612af783cf52c74a031a2f11b82247b2599d3cd upstream.
Marek reported that he saw an issue with the below snippet in that
timing measurements where off when loaded as unpriv while results
were reasonable when loaded as privileged:
uint64_t a = bpf_ktime_get_ns();
uint64_t b = bpf_ktime_get_ns();
uint64_t delta = b - a;
if ((int64_t)delta > 0) {
Turns out there is a bug where a corner case is missing in the fix
d3bd7413e0ca ("bpf: fix sanitation of alu op with pointer / scalar
type from different paths"), namely fixup_bpf_calls() only checks
whether aux has a non-zero alu_state, but it also needs to test for
the case of BPF_ALU_NON_POINTER since in both occasions we need to
skip the masking rewrite (as there is nothing to mask).
Fixes: d3bd7413e0ca ("bpf: fix sanitation of alu op with pointer / scalar type from different paths")
Reported-by: Marek Majkowski <marek@cloudflare.com>
Reported-by: Arthur Fabre <afabre@cloudflare.com>
Link: https://lore.kernel.org/netdev/CAJPywTJqP34cK20iLM5YmUMz9KXQOdu1-+BZrGMAGgLuBWz7fg@mail.gmail.com/T/
Signed-off-by: Balbir Singh <sblbir@amzn.com>
commit 0803278b0b4d8eeb2b461fb698785df65a725d9e upstream.
Syzkaller hit 'KASAN: use-after-free Write in sanitize_ptr_alu' bug.
Call trace:
dump_stack+0xbf/0x12e
print_address_description+0x6a/0x280
kasan_report+0x237/0x360
sanitize_ptr_alu+0x85a/0x8d0
adjust_ptr_min_max_vals+0x8f2/0x1ca0
adjust_reg_min_max_vals+0x8ed/0x22e0
do_check+0x1ca6/0x5d00
bpf_check+0x9ca/0x2570
bpf_prog_load+0xc91/0x1030
__se_sys_bpf+0x61e/0x1f00
do_syscall_64+0xc8/0x550
Fault injection trace:
kfree+0xea/0x290
free_func_state+0x4a/0x60
free_verifier_state+0x61/0xe0
push_stack+0x216/0x2f0 <- inject failslab
sanitize_ptr_alu+0x2b1/0x8d0
When kzalloc() fails in push_stack(), free_verifier_state() will free
current verifier state. As push_stack() returns, dst_reg was restored
if ptr_is_dst_reg is false. However, as member of the cur_state,
dst_reg is also freed, and error occurs when dereferencing dst_reg.
Simply fix it by testing ret of push_stack() before restoring dst_reg.
Fixes: 979d63d50c0c ("bpf: prevent out of bounds speculation on pointer arithmetic")
Signed-off-by: Xu Yu <xuyu@linux.alibaba.com>
commit 9d5564ddcf2a0f5ba3fa1c3a1f8a1b59ad309553 upstream.
During review I noticed that inner meta map setup for map in
map is buggy in that it does not propagate all needed data
from the reference map which the verifier is later accessing.
In particular one such case is index masking to prevent out of
bounds access under speculative execution due to missing the
map's unpriv_array/index_mask field propagation. Fix this such
that the verifier is generating the correct code for inlined
lookups in case of unpriviledged use.
Before patch (test_verifier's 'map in map access' dump):
# bpftool prog dump xla id 3
0: (62) *(u32 *)(r10 -4) = 0
1: (bf) r2 = r10
2: (07) r2 += -4
3: (18) r1 = map[id:4]
5: (07) r1 += 272 |
6: (61) r0 = *(u32 *)(r2 +0) |
7: (35) if r0 >= 0x1 goto pc+6 | Inlined map in map lookup
8: (54) (u32) r0 &= (u32) 0 | with index masking for
9: (67) r0 <<= 3 | map->unpriv_array.
10: (0f) r0 += r1 |
11: (79) r0 = *(u64 *)(r0 +0) |
12: (15) if r0 == 0x0 goto pc+1 |
13: (05) goto pc+1 |
14: (b7) r0 = 0 |
15: (15) if r0 == 0x0 goto pc+11
16: (62) *(u32 *)(r10 -4) = 0
17: (bf) r2 = r10
18: (07) r2 += -4
19: (bf) r1 = r0
20: (07) r1 += 272 |
21: (61) r0 = *(u32 *)(r2 +0) | Index masking missing (!)
22: (35) if r0 >= 0x1 goto pc+3 | for inner map despite
23: (67) r0 <<= 3 | map->unpriv_array set.
24: (0f) r0 += r1 |
25: (05) goto pc+1 |
26: (b7) r0 = 0 |
27: (b7) r0 = 0
28: (95) exit
After patch:
# bpftool prog dump xla id 1
1: (bf) r2 = r10
2: (07) r2 += -4
3: (18) r1 = map[id:2]
5: (07) r1 += 272 |
7: (35) if r0 >= 0x1 goto pc+6 | Same inlined map in map lookup
8: (54) (u32) r0 &= (u32) 0 | with index masking due to
10: (0f) r0 += r1 |
14: (b7) r0 = 0 |
15: (15) if r0 == 0x0 goto pc+12
17: (bf) r2 = r10
18: (07) r2 += -4
19: (bf) r1 = r0
22: (35) if r0 >= 0x1 goto pc+4 | Now fixed inlined inner map
23: (54) (u32) r0 &= (u32) 0 | lookup with proper index masking
24: (67) r0 <<= 3 | for map->unpriv_array.
25: (0f) r0 += r1 |
26: (05) goto pc+1 |
27: (b7) r0 = 0 |
28: (b7) r0 = 0
29: (95) exit
Fixes: b2157399cc98 ("bpf: prevent out-of-bounds speculation")
Signed-off-by: Vallish Vaidyeshwara <vallish@amazon.com>
commit d3bd7413e0ca40b60cf60d4003246d067cafdeda upstream.
While 979d63d50c0c ("bpf: prevent out of bounds speculation on pointer
arithmetic") took care of rejecting alu op on pointer when e.g. pointer
came from two different map values with different map properties such as
value size, Jann reported that a case was not covered yet when a given
alu op is used in both "ptr_reg += reg" and "numeric_reg += reg" from
different branches where we would incorrectly try to sanitize based
on the pointer's limit. Catch this corner case and reject the program
instead.
Reported-by: Jann Horn <jannh@google.com>
commit 979d63d50c0c0f7bc537bf821e056cc9fe5abd38 upstream.
Jann reported that the original commit back in b2157399cc98
("bpf: prevent out-of-bounds speculation") was not sufficient
to stop CPU from speculating out of bounds memory access:
While b2157399cc98 only focussed on masking array map access
for unprivileged users for tail calls and data access such
that the user provided index gets sanitized from BPF program
and syscall side, there is still a more generic form affected
from BPF programs that applies to most maps that hold user
data in relation to dynamic map access when dealing with
unknown scalars or "slow" known scalars as access offset, for
example:
- Load a map value pointer into R6
- Load an index into R7
- Do a slow computation (e.g. with a memory dependency) that
loads a limit into R8 (e.g. load the limit from a map for
high latency, then mask it to make the verifier happy)
- Exit if R7 >= R8 (mispredicted branch)
- Load R0 = R6[R7]
- Load R0 = R6[R0]
For unknown scalars there are two options in the BPF verifier
where we could derive knowledge from in order to guarantee
safe access to the memory: i) While </>/<=/>= variants won't
allow to derive any lower or upper bounds from the unknown
scalar where it would be safe to add it to the map value
pointer, it is possible through ==/!= test however. ii) another
option is to transform the unknown scalar into a known scalar,
for example, through ALU ops combination such as R &= <imm>
followed by R |= <imm> or any similar combination where the
original information from the unknown scalar would be destroyed
entirely leaving R with a constant. The initial slow load still
precedes the latter ALU ops on that register, so the CPU
executes speculatively from that point. Once we have the known
scalar, any compare operation would work then. A third option
only involving registers with known scalars could be crafted
as described in [0] where a CPU port (e.g. Slow Int unit)
would be filled with many dependent computations such that
the subsequent condition depending on its outcome has to wait
for evaluation on its execution port and thereby executing
speculatively if the speculated code can be scheduled on a
different execution port, or any other form of mistraining
as described in [1], for example. Given this is not limited
to only unknown scalars, not only map but also stack access
is affected since both is accessible for unprivileged users
and could potentially be used for out of bounds access under
speculation.
In order to prevent any of these cases, the verifier is now
sanitizing pointer arithmetic on the offset such that any
out of bounds speculation would be masked in a way where the
pointer arithmetic result in the destination register will
stay unchanged, meaning offset masked into zero similar as
in array_index_nospec() case. With regards to implementation,
there are three options that were considered: i) new insn
for sanitation, ii) push/pop insn and sanitation as inlined
BPF, iii) reuse of ax register and sanitation as inlined BPF.
Option i) has the downside that we end up using from reserved
bits in the opcode space, but also that we would require
each JIT to emit masking as native arch opcodes meaning
mitigation would have slow adoption till everyone implements
it eventually which is counter-productive. Option ii) and iii)
have both in common that a temporary register is needed in
order to implement the sanitation as inlined BPF since we
are not allowed to modify the source register. While a push /
pop insn in ii) would be useful to have in any case, it
requires once again that every JIT needs to implement it
first. While possible, amount of changes needed would also
be unsuitable for a -stable patch. Therefore, the path which
has fewer changes, less BPF instructions for the mitigation
and does not require anything to be changed in the JITs is
option iii) which this work is pursuing. The ax register is
already mapped to a register in all JITs (modulo arm32 where
it's mapped to stack as various other BPF registers there)
and used in constant blinding for JITs-only so far. It can
be reused for verifier rewrites under certain constraints.
The interpreter's tmp "register" has therefore been remapped
into extending the register set with hidden ax register and
reusing that for a number of instructions that needed the
prior temporary variable internally (e.g. div, mod). This
allows for zero increase in stack space usage in the interpreter,
and enables (restricted) generic use in rewrites otherwise as
long as such a patchlet does not make use of these instructions.
The sanitation mask is dynamic and relative to the offset the
map value or stack pointer currently holds.
There are various cases that need to be taken under consideration
for the masking, e.g. such operation could look as follows:
ptr += val or val += ptr or ptr -= val. Thus, the value to be
sanitized could reside either in source or in destination
register, and the limit is different depending on whether
the ALU op is addition or subtraction and depending on the
current known and bounded offset. The limit is derived as
follows: limit := max_value_size - (smin_value + off). For
subtraction: limit := umax_value + off. This holds because
we do not allow any pointer arithmetic that would
temporarily go out of bounds or would have an unknown
value with mixed signed bounds where it is unclear at
verification time whether the actual runtime value would
be either negative or positive. For example, we have a
derived map pointer value with constant offset and bounded
one, so limit based on smin_value works because the verifier
requires that statically analyzed arithmetic on the pointer
must be in bounds, and thus it checks if resulting
smin_value + off and umax_value + off is still within map
value bounds at time of arithmetic in addition to time of
access. Similarly, for the case of stack access we derive
the limit as follows: MAX_BPF_STACK + off for subtraction
and -off for the case of addition where off := ptr_reg->off +
ptr_reg->var_off.value. Subtraction is a special case for
the masking which can be in form of ptr += -val, ptr -= -val,
or ptr -= val. In the first two cases where we know that
the value is negative, we need to temporarily negate the
value in order to do the sanitation on a positive value
where we later swap the ALU op, and restore original source
register if the value was in source.
The sanitation of pointer arithmetic alone is still not fully
sufficient as is, since a scenario like the following could
happen ...
PTR += 0x1000 (e.g. K-based imm)
PTR -= BIG_NUMBER_WITH_SLOW_COMPARISON
PTR += 0x1000
... which under speculation could end up as ...
PTR += 0x1000
PTR -= 0 [ truncated by mitigation ]
PTR += 0x1000
... and therefore still access out of bounds. To prevent such
case, the verifier is also analyzing safety for potential out
of bounds access under speculative execution. Meaning, it is
also simulating pointer access under truncation. We therefore
"branch off" and push the current verification state after the
ALU operation with known 0 to the verification stack for later
analysis. Given the current path analysis succeeded it is
likely that the one under speculation can be pruned. In any
case, it is also subject to existing complexity limits and
therefore anything beyond this point will be rejected. In
terms of pruning, it needs to be ensured that the verification
state from speculative execution simulation must never prune
a non-speculative execution path, therefore, we mark verifier
state accordingly at the time of push_stack(). If verifier
detects out of bounds access under speculative execution from
one of the possible paths that includes a truncation, it will
reject such program.
Given we mask every reg-based pointer arithmetic for
unprivileged programs, we've been looking into how it could
affect real-world programs in terms of size increase. As the
majority of programs are targeted for privileged-only use
case, we've unconditionally enabled masking (with its alu
restrictions on top of it) for privileged programs for the
sake of testing in order to check i) whether they get rejected
in its current form, and ii) by how much the number of
instructions and size will increase. We've tested this by
using Katran, Cilium and test_l4lb from the kernel selftests.
For Katran we've evaluated balancer_kern.o, Cilium bpf_lxc.o
and an older test object bpf_lxc_opt_-DUNKNOWN.o and l4lb
we've used test_l4lb.o as well as test_l4lb_noinline.o. We
found that none of the programs got rejected by the verifier
with this change, and that impact is rather minimal to none.
balancer_kern.o had 13,904 bytes (1,738 insns) xlated and
7,797 bytes JITed before and after the change. Most complex
program in bpf_lxc.o had 30,544 bytes (3,817 insns) xlated
and 18,538 bytes JITed before and after and none of the other
tail call programs in bpf_lxc.o had any changes either. For
the older bpf_lxc_opt_-DUNKNOWN.o object we found a small
increase from 20,616 bytes (2,576 insns) and 12,536 bytes JITed
before to 20,664 bytes (2,582 insns) and 12,558 bytes JITed
after the change. Other programs from that object file had
similar small increase. Both test_l4lb.o had no change and
remained at 6,544 bytes (817 insns) xlated and 3,401 bytes
JITed and for test_l4lb_noinline.o constant at 5,080 bytes
(634 insns) xlated and 3,313 bytes JITed. This can be explained
in that LLVM typically optimizes stack based pointer arithmetic
by using K-based operations and that use of dynamic map access
is not overly frequent. However, in future we may decide to
optimize the algorithm further under known guarantees from
branch and value speculation. Latter seems also unclear in
terms of prediction heuristics that today's CPUs apply as well
as whether there could be collisions in e.g. the predictor's
Value History/Pattern Table for triggering out of bounds access,
thus masking is performed unconditionally at this point but could
be subject to relaxation later on. We were generally also
brainstorming various other approaches for mitigation, but the
blocker was always lack of available registers at runtime and/or
overhead for runtime tracking of limits belonging to a specific
pointer. Thus, we found this to be minimally intrusive under
given constraints.
With that in place, a simple example with sanitized access on
unprivileged load at post-verification time looks as follows:
# bpftool prog dump xlated id 282
28: (79) r1 = *(u64 *)(r7 +0)
29: (79) r2 = *(u64 *)(r7 +8)
30: (57) r1 &= 15
31: (79) r3 = *(u64 *)(r0 +4608)
32: (57) r3 &= 1
33: (47) r3 |= 1
34: (2d) if r2 > r3 goto pc+19
35: (b4) (u32) r11 = (u32) 20479 |
36: (1f) r11 -= r2 | Dynamic sanitation for pointer
37: (4f) r11 |= r2 | arithmetic with registers
38: (87) r11 = -r11 | containing bounded or known
39: (c7) r11 s>>= 63 | scalars in order to prevent
40: (5f) r11 &= r2 | out of bounds speculation.
41: (0f) r4 += r11 |
42: (71) r4 = *(u8 *)(r4 +0)
43: (6f) r4 <<= r1
For the case where the scalar sits in the destination register
as opposed to the source register, the following code is emitted
for the above example:
16: (b4) (u32) r11 = (u32) 20479
17: (1f) r11 -= r2
18: (4f) r11 |= r2
19: (87) r11 = -r11
20: (c7) r11 s>>= 63
21: (5f) r2 &= r11
22: (0f) r2 += r0
23: (61) r0 = *(u32 *)(r2 +0)
JIT blinding example with non-conflicting use of r10:
d5: je 0x0000000000000106 _
d7: mov 0x0(%rax),%edi |
da: mov $0xf153246,%r10d | Index load from map value and
e0: xor $0xf153259,%r10 | (const blinded) mask with 0x1f.
e7: and %r10,%rdi |_
ea: mov $0x2f,%r10d |
f0: sub %rdi,%r10 | Sanitized addition. Both use r10
f3: or %rdi,%r10 | but do not interfere with each
f6: neg %r10 | other. (Neither do these instructions
f9: sar $0x3f,%r10 | interfere with the use of ax as temp
fd: and %r10,%rdi | in interpreter.)
100: add %rax,%rdi |_
103: mov 0x0(%rdi),%eax
Tested that it fixes Jann's reproducer, and also checked that test_verifier
and test_progs suite with interpreter, JIT and JIT with hardening enabled
on x86-64 and arm64 runs successfully.
[0] Speculose: Analyzing the Security Implications of Speculative
Execution in CPUs, Giorgi Maisuradze and Christian Rossow,
https://arxiv.org/pdf/1801.04084.pdf
[1] A Systematic Evaluation of Transient Execution Attacks and
Defenses, Claudio Canella, Jo Van Bulck, Michael Schwarz,
Moritz Lipp, Benjamin von Berg, Philipp Ortner, Frank Piessens,
Dmitry Evtyushkin, Daniel Gruss,
https://arxiv.org/pdf/1811.05441.pdf
[some checkpatch cleanups and backported to 4.14 by sblbir]
commit b7137c4eab85c1cf3d46acdde90ce1163b28c873 upstream.
In check_map_access() we probe actual bounds through __check_map_access()
with offset of reg->smin_value + off for lower bound and offset of
reg->umax_value + off for the upper bound. However, even though the
reg->smin_value could have a negative value, the final result of the
sum with off could be positive when pointer arithmetic with known and
unknown scalars is combined. In this case we reject the program with
an error such as "R<x> min value is negative, either use unsigned index
or do a if (index >=0) check." even though the access itself would be
fine. Therefore extend the check to probe whether the actual resulting
reg->smin_value + off is less than zero.
[backported to 4.14 sblbir]
commit 9d7eceede769f90b66cfa06ad5b357140d5141ed upstream.
For unknown scalars of mixed signed bounds, meaning their smin_value is
negative and their smax_value is positive, we need to reject arithmetic
with pointer to map value. For unprivileged the goal is to mask every
map pointer arithmetic and this cannot reliably be done when it is
unknown at verification time whether the scalar value is negative or
positive. Given this is a corner case, the likelihood of breaking should
be very small.
commit e4298d25830a866cc0f427d4bccb858e76715859 upstream.
Restrict stack pointer arithmetic for unprivileged users in that
arithmetic itself must not go out of bounds as opposed to the actual
access later on. Therefore after each adjust_ptr_min_max_vals() with
a stack pointer as a destination we simulate a check_stack_access()
of 1 byte on the destination and once that fails the program is
rejected for unprivileged program loads. This is analog to map
value pointer arithmetic and needed for masking later on.
commit 0d6303db7970e6f56ae700fa07e11eb510cda125 upstream.
Restrict map value pointer arithmetic for unprivileged users in that
access later on. Therefore after each adjust_ptr_min_max_vals() with a
map value pointer as a destination it will simulate a check_map_access()
of 1 byte on the destination and once that fails the program is rejected
for unprivileged program loads. We use this later on for masking any
pointer arithmetic with the remainder of the map value space. The
likelihood of breaking any existing real-world unprivileged eBPF
program is very small for this corner case.
commit 9b73bfdd08e73231d6a90ae6db4b46b3fbf56c30 upstream.
Right now we are using BPF ax register in JIT for constant blinding as
well as in interpreter as temporary variable. Verifier will not be able
to use it simply because its use will get overridden from the former in
bpf_jit_blind_insn(). However, it can be made to work in that blinding
will be skipped if there is prior use in either source or destination
register on the instruction. Taking constraints of ax into account, the
verifier is then open to use it in rewrites under some constraints. Note,
ax register already has mappings in every eBPF JIT.
commit 144cd91c4c2bced6eb8a7e25e590f6618a11e854 upstream.
This change moves the on-stack 64 bit tmp variable in ___bpf_prog_run()
into the hidden ax register. The latter is currently only used in JITs
for constant blinding as a temporary scratch register, meaning the BPF
interpreter will never see the use of ax. Therefore it is safe to use
it for the cases where tmp has been used earlier. This is needed to later
on allow restricted hidden use of ax in both interpreter and JITs.
commit c08435ec7f2bc8f4109401f696fd55159b4b40cb upstream.
Move prev_insn_idx and insn_idx from the do_check() function into
the verifier environment, so they can be read inside the various
helper functions for handling the instructions. It's easier to put
this into the environment rather than changing all call-sites only
to pass it along. insn_idx is useful in particular since this later
on allows to hold state in env->insn_aux_data[env->insn_idx].
[Backported to 4.14 by sblbir]
commit 12a3cc8424fe1237aaeb982dec4f0914ddd22f3e upstream.
fix incorrect stack state prints in print_verifier_state()
Fixes: 638f5b90d460 ("bpf: reduce verifier memory consumption")
Acked-by: John Fastabend <john.fastabend@gmail.com>
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
commit 8c01c4f896aa3404af948880dcb29a2d51c833dc upstream.
do_check() can fail early without allocating env->cur_state under
memory pressure. Syzkaller found the stack below on the linux-next
tree because of this.
kasan: CONFIG_KASAN_INLINE enabled
kasan: GPF could be caused by NULL-ptr deref or user memory access
general protection fault: 0000 [#1] SMP KASAN
Dumping ftrace buffer:
(ftrace buffer empty)
Modules linked in:
CPU: 1 PID: 27062 Comm: syz-executor5 Not tainted 4.14.0-rc7+ #106
task: ffff8801c2c74700 task.stack: ffff8801c3e28000
RIP: 0010:free_verifier_state kernel/bpf/verifier.c:347 [inline]
RIP: 0010:bpf_check+0xcf4/0x19c0 kernel/bpf/verifier.c:4533
RSP: 0018:ffff8801c3e2f5c8 EFLAGS: 00010202
RAX: dffffc0000000000 RBX: 00000000fffffff4 RCX: 0000000000000000
RDX: 0000000000000070 RSI: ffffffff817d5aa9 RDI: 0000000000000380
RBP: ffff8801c3e2f668 R08: 0000000000000000 R09: 1ffff100387c5d9f
R10: 00000000218c4e80 R11: ffffffff85b34380 R12: ffff8801c4dc6a28
R13: 0000000000000000 R14: ffff8801c4dc6a00 R15: ffff8801c4dc6a20
FS: 00007f311079b700(0000) GS:ffff8801db300000(0000) knlGS:0000000000000000
CR2: 00000000004d4a24 CR3: 00000001cbcd0000 CR4: 00000000001406e0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
bpf_prog_load+0xcbb/0x18e0 kernel/bpf/syscall.c:1166
SYSC_bpf kernel/bpf/syscall.c:1690 [inline]
SyS_bpf+0xae9/0x4620 kernel/bpf/syscall.c:1652
entry_SYSCALL_64_fastpath+0x1f/0xbe
RIP: 0033:0x452869
RSP: 002b:00007f311079abe8 EFLAGS: 00000212 ORIG_RAX: 0000000000000141
RAX: ffffffffffffffda RBX: 0000000000758020 RCX: 0000000000452869
RDX: 0000000000000030 RSI: 0000000020168000 RDI: 0000000000000005
RBP: 00007f311079aa20 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000212 R12: 00000000004b7550
R13: 00007f311079ab58 R14: 00000000004b7560 R15: 0000000000000000
Code: df 48 c1 ea 03 80 3c 02 00 0f 85 e6 0b 00 00 4d 8b 6e 20 48 b8 00 00 00 00 00 fc ff df 49 8d bd 80 03 00 00 48 89 fa 48 c1 ea 03 <80> 3c 02 00 0f 85 b6 0b 00 00 49 8b bd 80 03 00 00 e8 d6 0c 26
RIP: free_verifier_state kernel/bpf/verifier.c:347 [inline] RSP: ffff8801c3e2f5c8
RIP: bpf_check+0xcf4/0x19c0 kernel/bpf/verifier.c:4533 RSP: ffff8801c3e2f5c8
---[ end trace c8d37f339dc64004 ]---
Fixes: 1969db47f8d0 ("bpf: fix verifier memory leaks")
Signed-off-by: Craig Gallek <kraig@google.com>
commit 1969db47f8d0e800397abd4ee4e8d27d2b578587 upstream.
Signed-off-by: Alexei Starovoitov <ast@fb.com>
commit 638f5b90d46016372a8e3e0a434f199cc5e12b8c upstream.
the verifier got progressively smarter over time and size of its internal
state grew as well. Time to reduce the memory consumption.
Before:
sizeof(struct bpf_verifier_state) = 6520
After:
sizeof(struct bpf_verifier_state) = 896
It's done by observing that majority of BPF programs use little to
no stack whereas verifier kept all of 512 stack slots ready always.
Instead dynamically reallocate struct verifier state when stack
access is detected.
Runtime difference before vs after is within a noise.
The number of processed instructions stays the same.
Cc: jakub.kicinski@netronome.com
[ Upstream commit 1da6c4d9140cb7c13e87667dc4e1488d6c8fc10f ]
syzkaller was able to generate the following UAF in bpf:
BUG: KASAN: use-after-free in lookup_last fs/namei.c:2269 [inline]
BUG: KASAN: use-after-free in path_lookupat.isra.43+0x9f8/0xc00 fs/namei.c:2318
Read of size 1 at addr ffff8801c4865c47 by task syz-executor2/9423
CPU: 0 PID: 9423 Comm: syz-executor2 Not tainted 4.20.0-rc1-next-20181109+
#110
Google 01/01/2011
Call Trace:
dump_stack+0x244/0x39d lib/dump_stack.c:113
print_address_description.cold.7+0x9/0x1ff mm/kasan/report.c:256
kasan_report.cold.8+0x242/0x309 mm/kasan/report.c:412
__asan_report_load1_noabort+0x14/0x20 mm/kasan/report.c:430
filename_lookup+0x26a/0x520 fs/namei.c:2348
user_path_at_empty+0x40/0x50 fs/namei.c:2608
user_path include/linux/namei.h:62 [inline]
do_mount+0x180/0x1ff0 fs/namespace.c:2980
ksys_mount+0x12d/0x140 fs/namespace.c:3258
__do_sys_mount fs/namespace.c:3272 [inline]
__se_sys_mount fs/namespace.c:3269 [inline]
__x64_sys_mount+0xbe/0x150 fs/namespace.c:3269
do_syscall_64+0x1b9/0x820 arch/x86/entry/common.c:290
RIP: 0033:0x457569
Code: fd b3 fb ff c3 66 2e 0f 1f 84 00 00 00 00 00 66 90 48 89 f8 48 89 f7
48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff
ff 0f 83 cb b3 fb ff c3 66 2e 0f 1f 84 00 00 00 00
RSP: 002b:00007fde6ed96c78 EFLAGS: 00000246 ORIG_RAX: 00000000000000a5
RAX: ffffffffffffffda RBX: 0000000000000005 RCX: 0000000000457569
RDX: 0000000020000040 RSI: 0000000020000000 RDI: 0000000000000000
RBP: 000000000072bf00 R08: 0000000020000340 R09: 0000000000000000
R10: 0000000000200000 R11: 0000000000000246 R12: 00007fde6ed976d4
R13: 00000000004c2c24 R14: 00000000004d4990 R15: 00000000ffffffff
Allocated by task 9424:
kasan_kmalloc+0xc7/0xe0 mm/kasan/kasan.c:553
__do_kmalloc mm/slab.c:3722 [inline]
__kmalloc_track_caller+0x157/0x760 mm/slab.c:3737
kstrdup+0x39/0x70 mm/util.c:49
bpf_symlink+0x26/0x140 kernel/bpf/inode.c:356
vfs_symlink+0x37a/0x5d0 fs/namei.c:4127
do_symlinkat+0x242/0x2d0 fs/namei.c:4154
__do_sys_symlink fs/namei.c:4173 [inline]
__se_sys_symlink fs/namei.c:4171 [inline]
__x64_sys_symlink+0x59/0x80 fs/namei.c:4171
Freed by task 9425:
__kasan_slab_free+0x102/0x150 mm/kasan/kasan.c:521
kfree+0xcf/0x230 mm/slab.c:3817
bpf_evict_inode+0x11f/0x150 kernel/bpf/inode.c:565
evict+0x4b9/0x980 fs/inode.c:558
iput_final fs/inode.c:1550 [inline]
iput+0x674/0xa90 fs/inode.c:1576
do_unlinkat+0x733/0xa30 fs/namei.c:4069
__do_sys_unlink fs/namei.c:4110 [inline]
__se_sys_unlink fs/namei.c:4108 [inline]
__x64_sys_unlink+0x42/0x50 fs/namei.c:4108
In this scenario path lookup under RCU is racing with the final
unlink in case of symlinks. As Linus puts it in his analysis:
[...] We actually RCU-delay the inode freeing itself, but
when we do the final iput(), the "evict()" function is called
synchronously. Now, the simple fix would seem to just RCU-delay
the kfree() of the symlink data in bpf_evict_inode(). Maybe
that's the right thing to do. [...]
Al suggested to piggy-back on the ->destroy_inode() callback in
order to implement RCU deferral there which can then kfree() the
inode->i_link eventually right before putting inode back into
inode cache. By reusing free_inode_nonrcu() from there we can
avoid the need for our own inode cache and just reuse generic
one as we currently do.
And in-fact on top of all this we should just get rid of the
bpf_evict_inode() entirely. This means truncate_inode_pages_final()
and clear_inode() will then simply be called by the fs core via
evict(). Dropping the reference should really only be done when
inode is unhashed and nothing reachable anymore, so it's better
also moved into the final ->destroy_inode() callback.
Fixes: 0f98621bef5d ("bpf, inode: add support for symlinks and fix mtime/ctime")
Reported-by: syzbot+fb731ca573367b7f6564@syzkaller.appspotmail.com
Reported-by: syzbot+a13e5ead792d6df37818@syzkaller.appspotmail.com
Reported-by: syzbot+7a8ba368b47fdefca61e@syzkaller.appspotmail.com
Suggested-by: Al Viro <viro@zeniv.linux.org.uk>
Analyzed-by: Linus Torvalds <torvalds@linux-foundation.org>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Link: https://lore.kernel.org/lkml/0000000000006946d2057bbd0eef@google.com/T/
Signed-off-by: Sasha Levin (Microsoft) <sashal@kernel.org>
[ Upstream commit a89fac57b5d080771efd4d71feaae19877cf68f0 ]
Lockdep warns about false positive:
[ 12.492084] 00000000e6b28347 (&head->lock){+...}, at: pcpu_freelist_push+0x2a/0x40
[ 12.492696] but this lock was taken by another, HARDIRQ-safe lock in the past:
[ 12.493275] (&rq->lock){-.-.}
[ 12.493276]
[ 12.493276]
[ 12.493276] and interrupts could create inverse lock ordering between them.
[ 12.493276]
[ 12.494435]
[ 12.494435] other info that might help us debug this:
[ 12.494979] Possible interrupt unsafe locking scenario:
[ 12.494979]
[ 12.495518] CPU0 CPU1
[ 12.495879] ---- ----
[ 12.496243] lock(&head->lock);
[ 12.496502] local_irq_disable();
[ 12.496969] lock(&rq->lock);
[ 12.497431] lock(&head->lock);
[ 12.497890] <Interrupt>
[ 12.498104] lock(&rq->lock);
[ 12.498368]
[ 12.498368] *** DEADLOCK ***
[ 12.498368]
[ 12.498837] 1 lock held by dd/276:
[ 12.499110] #0: 00000000c58cb2ee (rcu_read_lock){....}, at: trace_call_bpf+0x5e/0x240
[ 12.499747]
[ 12.499747] the shortest dependencies between 2nd lock and 1st lock:
[ 12.500389] -> (&rq->lock){-.-.} {
[ 12.500669] IN-HARDIRQ-W at:
[ 12.500934] _raw_spin_lock+0x2f/0x40
[ 12.501373] scheduler_tick+0x4c/0xf0
[ 12.501812] update_process_times+0x40/0x50
[ 12.502294] tick_periodic+0x27/0xb0
[ 12.502723] tick_handle_periodic+0x1f/0x60
[ 12.503203] timer_interrupt+0x11/0x20
[ 12.503651] __handle_irq_event_percpu+0x43/0x2c0
[ 12.504167] handle_irq_event_percpu+0x20/0x50
[ 12.504674] handle_irq_event+0x37/0x60
[ 12.505139] handle_level_irq+0xa7/0x120
[ 12.505601] handle_irq+0xa1/0x150
[ 12.506018] do_IRQ+0x77/0x140
[ 12.506411] ret_from_intr+0x0/0x1d
[ 12.506834] _raw_spin_unlock_irqrestore+0x53/0x60
[ 12.507362] __setup_irq+0x481/0x730
[ 12.507789] setup_irq+0x49/0x80
[ 12.508195] hpet_time_init+0x21/0x32
[ 12.508644] x86_late_time_init+0xb/0x16
[ 12.509106] start_kernel+0x390/0x42a
[ 12.509554] secondary_startup_64+0xa4/0xb0
[ 12.510034] IN-SOFTIRQ-W at:
[ 12.510305] _raw_spin_lock+0x2f/0x40
[ 12.510772] try_to_wake_up+0x1c7/0x4e0
[ 12.511220] swake_up_locked+0x20/0x40
[ 12.511657] swake_up_one+0x1a/0x30
[ 12.512070] rcu_process_callbacks+0xc5/0x650
[ 12.512553] __do_softirq+0xe6/0x47b
[ 12.512978] irq_exit+0xc3/0xd0
[ 12.513372] smp_apic_timer_interrupt+0xa9/0x250
[ 12.513876] apic_timer_interrupt+0xf/0x20
[ 12.514343] default_idle+0x1c/0x170
[ 12.514765] do_idle+0x199/0x240
[ 12.515159] cpu_startup_entry+0x19/0x20
[ 12.515614] start_kernel+0x422/0x42a
[ 12.516045] secondary_startup_64+0xa4/0xb0
[ 12.516521] INITIAL USE at:
[ 12.516774] _raw_spin_lock_irqsave+0x38/0x50
[ 12.517258] rq_attach_root+0x16/0xd0
[ 12.517685] sched_init+0x2f2/0x3eb
[ 12.518096] start_kernel+0x1fb/0x42a
[ 12.518525] secondary_startup_64+0xa4/0xb0
[ 12.518986] }
[ 12.519132] ... key at: [<ffffffff82b7bc28>] __key.71384+0x0/0x8
[ 12.519649] ... acquired at:
[ 12.519892] pcpu_freelist_pop+0x7b/0xd0
[ 12.520221] bpf_get_stackid+0x1d2/0x4d0
[ 12.520563] ___bpf_prog_run+0x8b4/0x11a0
[ 12.520887]
[ 12.521008] -> (&head->lock){+...} {
[ 12.521292] HARDIRQ-ON-W at:
[ 12.521539] _raw_spin_lock+0x2f/0x40
[ 12.521950] pcpu_freelist_push+0x2a/0x40
[ 12.522396] bpf_get_stackid+0x494/0x4d0
[ 12.522828] ___bpf_prog_run+0x8b4/0x11a0
[ 12.523296] INITIAL USE at:
[ 12.523537] _raw_spin_lock+0x2f/0x40
[ 12.523944] pcpu_freelist_populate+0xc0/0x120
[ 12.524417] htab_map_alloc+0x405/0x500
[ 12.524835] __do_sys_bpf+0x1a3/0x1a90
[ 12.525253] do_syscall_64+0x4a/0x180
[ 12.525659] entry_SYSCALL_64_after_hwframe+0x49/0xbe
[ 12.526167] }
[ 12.526311] ... key at: [<ffffffff838f7668>] __key.13130+0x0/0x8
[ 12.526812] ... acquired at:
[ 12.527047] __lock_acquire+0x521/0x1350
[ 12.527371] lock_acquire+0x98/0x190
[ 12.527680] _raw_spin_lock+0x2f/0x40
[ 12.527994] pcpu_freelist_push+0x2a/0x40
[ 12.528325] bpf_get_stackid+0x494/0x4d0
[ 12.528645] ___bpf_prog_run+0x8b4/0x11a0
[ 12.528970]
[ 12.529092]
[ 12.529092] stack backtrace:
[ 12.529444] CPU: 0 PID: 276 Comm: dd Not tainted 5.0.0-rc3-00018-g2fa53f892422 #475
[ 12.530043] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.11.0-2.el7 04/01/2014
[ 12.530750] Call Trace:
[ 12.530948] dump_stack+0x5f/0x8b
[ 12.531248] check_usage_backwards+0x10c/0x120
[ 12.531598] ? ___bpf_prog_run+0x8b4/0x11a0
[ 12.531935] ? mark_lock+0x382/0x560
[ 12.532229] mark_lock+0x382/0x560
[ 12.532496] ? print_shortest_lock_dependencies+0x180/0x180
[ 12.532928] __lock_acquire+0x521/0x1350
[ 12.533271] ? find_get_entry+0x17f/0x2e0
[ 12.533586] ? find_get_entry+0x19c/0x2e0
[ 12.533902] ? lock_acquire+0x98/0x190
[ 12.534196] lock_acquire+0x98/0x190
[ 12.534482] ? pcpu_freelist_push+0x2a/0x40
[ 12.534810] _raw_spin_lock+0x2f/0x40
[ 12.535099] ? pcpu_freelist_push+0x2a/0x40
[ 12.535432] pcpu_freelist_push+0x2a/0x40
[ 12.535750] bpf_get_stackid+0x494/0x4d0
[ 12.536062] ___bpf_prog_run+0x8b4/0x11a0
It has been explained that is a false positive here:
https://lkml.org/lkml/2018/7/25/756
Recap:
- stackmap uses pcpu_freelist
- The lock in pcpu_freelist is a percpu lock
- stackmap is only used by tracing bpf_prog
- A tracing bpf_prog cannot be run if another bpf_prog
has already been running (ensured by the percpu bpf_prog_active counter).
Eric pointed out that this lockdep splats stops other
legit lockdep splats in selftests/bpf/test_progs.c.
Fix this by calling local_irq_save/restore for stackmap.
Another false positive had also been worked around by calling
local_irq_save in commit 89ad2fa3f043 ("bpf: fix lockdep splat").
That commit added unnecessary irq_save/restore to fast path of
bpf hash map. irqs are already disabled at that point, since htab
is holding per bucket spin_lock with irqsave.
Let's reduce overhead for htab by introducing __pcpu_freelist_push/pop
function w/o irqsave and convert pcpu_freelist_push/pop to irqsave
to be used elsewhere (right now only in stackmap).
It stops lockdep false positive in stackmap with a bit of acceptable overhead.
Fixes: 557c0c6e7df8 ("bpf: convert stackmap to pre-allocation")
Reported-by: Naresh Kamboju <naresh.kamboju@linaro.org>
Reported-by: Eric Dumazet <eric.dumazet@gmail.com>
commit af86ca4e3088fe5eacf2f7e58c01fa68ca067672 upstream.
Detect code patterns where malicious 'speculative store bypass' can be used
and sanitize such patterns.
39: (bf) r3 = r10
40: (07) r3 += -216
41: (79) r8 = *(u64 *)(r7 +0) // slow read
42: (7a) *(u64 *)(r10 -72) = 0 // verifier inserts this instruction
43: (7b) *(u64 *)(r8 +0) = r3 // this store becomes slow due to r8
44: (79) r1 = *(u64 *)(r6 +0) // cpu speculatively executes this load
45: (71) r2 = *(u8 *)(r1 +0) // speculatively arbitrary 'load byte'
// is now sanitized
Above code after x86 JIT becomes:
e5: mov %rbp,%rdx
e8: add $0xffffffffffffff28,%rdx
ef: mov 0x0(%r13),%r14
f3: movq $0x0,-0x48(%rbp)
fb: mov %rdx,0x0(%r14)
ff: mov 0x0(%rbx),%rdi
103: movzbq 0x0(%rdi),%rsi
[bwh: Backported to 4.14:
- Add bpf_verifier_env parameter to check_stack_write()
- Look up stack slot_types with state->stack_slot_type[] rather than
state->stack[].slot_type[]
- Drop bpf_verifier_env argument to verbose()
- Adjust context]
commit 1ae80cf31938c8f77c37a29bbe29e7f1cd492be8 upstream.
The map-in-map frequently serves as a mechanism for atomic
snapshotting of state that a BPF program might record. The current
implementation is dangerous to use in this way, however, since
userspace has no way of knowing when all programs that might have
retrieved the "old" value of the map may have completed.
This change ensures that map update operations on map-in-map map types
always wait for all references to the old map to drop before returning
to userspace.
Signed-off-by: Daniel Colascione <dancol@google.com>
Reviewed-by: Joel Fernandes (Google) <joel@joelfernandes.org>
[fengc@google.com: 4.14 backport: adjust context]
Signed-off-by: Chenbo Feng <fengc@google.com>
commit 0962590e553331db2cc0aef2dc35c57f6300dbbe upstream.
ALU operations on pointers such as scalar_reg += map_value_ptr are
handled in adjust_ptr_min_max_vals(). Problem is however that map_ptr
and range in the register state share a union, so transferring state
through dst_reg->range = ptr_reg->range is just buggy as any new
map_ptr in the dst_reg is then truncated (or null) for subsequent
checks. Fix this by adding a raw member and use it for copying state
over to dst_reg.
Cc: Edward Cree <ecree@solarflare.com>
[ Upstream commit ba6b8de423f8d0dee48d6030288ed81c03ddf9f0 ]
Relying on map_release hook to decrement the reference counts when a
map is removed only works if the map is not being pinned. In the
pinned case the ref is decremented immediately and the BPF programs
released. After this BPF programs may not be in-use which is not
what the user would expect.
This patch moves the release logic into bpf_map_put_uref() and brings
sockmap in-line with how a similar case is handled in prog array maps.
Fixes: 3d9e952697de ("bpf: sockmap, fix leaking maps with attached but not detached progs")
Signed-off-by: John Fastabend <john.fastabend@gmail.com>
commit b799207e1e1816b09e7a5920fbb2d5fcf6edd681 upstream.
When I wrote commit 468f6eafa6c4 ("bpf: fix 32-bit ALU op verification"), I
assumed that, in order to emulate 64-bit arithmetic with 32-bit logic, it
is sufficient to just truncate the output to 32 bits; and so I just moved
the register size coercion that used to be at the start of the function to
the end of the function.
That assumption is true for almost every op, but not for 32-bit right
shifts, because those can propagate information towards the least
significant bit. Fix it by always truncating inputs for 32-bit ops to 32
bits.
Also get rid of the coerce_reg_to_size() after the ALU op, since that has
no effect.
Fixes: 468f6eafa6c4 ("bpf: fix 32-bit ALU op verification")
Signed-off-by: Jann Horn <jannh@google.com>
[ Upstream commit 9b2e0388bec8ec5427403e23faff3b58dd1c3200 ]
When sockmap code is using the stream parser it also handles the write
space events in order to handle the case where (a) verdict redirects
skb to another socket and (b) the sockmap then sends the skb but due
to memory constraints (or other EAGAIN errors) needs to do a retry.
But the initial code missed a third case where the
skb_send_sock_locked() triggers an sk_wait_event(). A typically case
would be when sndbuf size is exceeded. If this happens because we
do not pass the write_space event to the lower layers we never wake
up the event and it will wait for sndtimeo. Which as noted in ktls
fix may be rather large and look like a hang to the user.
To reproduce the best test is to reduce the sndbuf size and send
1B data chunks to stress the memory handling. To fix this pass the
event from the upper layer to the lower layer.
[ Upstream commit ed2b82c03dc187018307c7c6bf9299705f3db383 ]
Decrement the number of elements in the map in case the allocation
of a new node fails.
Fixes: 6c9059817432 ("bpf: pre-allocate hash map elements")
Signed-off-by: Mauricio Vasquez B <mauricio.vasquez@polito.it>
[ Upstream commit ab7f5bf0928be2f148d000a6eaa6c0a36e74750e ]
Comments in the verifier refer to free_bpf_prog_info() which
seems to have never existed in tree. Replace it with
free_used_maps().
Signed-off-by: Jakub Kicinski <jakub.kicinski@netronome.com>
Reviewed-by: Quentin Monnet <quentin.monnet@netronome.com>
[ Upstream commit 3d9e952697de89b53227f06d4241f275eb99cfc4 ]
When a program is attached to a map we increment the program refcnt
to ensure that the program is not removed while it is potentially
being referenced from sockmap side. However, if this same program
also references the map (this is a reasonably common pattern in
my programs) then the verifier will also increment the maps refcnt
from the verifier. This is to ensure the map doesn't get garbage
collected while the program has a reference to it.
So we are left in a state where the map holds the refcnt on the
program stopping it from being removed and releasing the map refcnt.
And vice versa the program holds a refcnt on the map stopping it
from releasing the refcnt on the prog.
All this is fine as long as users detach the program while the
map fd is still around. But, if the user omits this detach command
we are left with a dangling map we can no longer release.
To resolve this when the map fd is released decrement the program
references and remove any reference from the map to the program.
This fixes the issue with possibly dangling map and creates a
user side API constraint. That is, the map fd must be held open
for programs to be attached to a map.
Fixes: 174a79ff9515 ("bpf: sockmap with sk redirect support")
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
commit 0fa4fe85f4724fff89b09741c437cbee9cf8b008 upstream.
The current check statement in BPF syscall will do a capability check
for CAP_SYS_ADMIN before checking sysctl_unprivileged_bpf_disabled. This
code path will trigger unnecessary security hooks on capability checking
and cause false alarms on unprivileged process trying to get CAP_SYS_ADMIN
access. This can be resolved by simply switch the order of the statement
and CAP_SYS_ADMIN is not required anyway if unprivileged bpf syscall is
allowed.
Acked-by: Lorenzo Colitti <lorenzo@google.com>
[ upstream commit ca36960211eb228bcbc7aaebfa0d027368a94c60 ]
The requirements around atomic_add() / atomic64_add() resp. their
JIT implementations differ across architectures. E.g. while x86_64
seems just fine with BPF's xadd on unaligned memory, on arm64 it
triggers via interpreter but also JIT the following crash:
[ 830.864985] Unable to handle kernel paging request at virtual address ffff8097d7ed6703
[ 830.916161] Internal error: Oops: 96000021 [#1] SMP
[ 830.984755] CPU: 37 PID: 2788 Comm: test_verifier Not tainted 4.16.0-rc2+ #8
[ 830.991790] Hardware name: Huawei TaiShan 2280 /BC11SPCD, BIOS 1.29 07/17/2017
[ 830.998998] pstate: 80400005 (Nzcv daif +PAN -UAO)
[ 831.003793] pc : __ll_sc_atomic_add+0x4/0x18
[ 831.008055] lr : ___bpf_prog_run+0x1198/0x1588
[ 831.012485] sp : ffff00001ccabc20
[ 831.015786] x29: ffff00001ccabc20 x28: ffff8017d56a0f00
[ 831.021087] x27: 0000000000000001 x26: 0000000000000000
[ 831.026387] x25: 000000c168d9db98 x24: 0000000000000000
[ 831.031686] x23: ffff000008203878 x22: ffff000009488000
[ 831.036986] x21: ffff000008b14e28 x20: ffff00001ccabcb0
[ 831.042286] x19: ffff0000097b5080 x18: 0000000000000a03
[ 831.047585] x17: 0000000000000000 x16: 0000000000000000
[ 831.052885] x15: 0000ffffaeca8000 x14: 0000000000000000
[ 831.058184] x13: 0000000000000000 x12: 0000000000000000
[ 831.063484] x11: 0000000000000001 x10: 0000000000000000
[ 831.068783] x9 : 0000000000000000 x8 : 0000000000000000
[ 831.074083] x7 : 0000000000000000 x6 : 000580d428000000
[ 831.079383] x5 : 0000000000000018 x4 : 0000000000000000
[ 831.084682] x3 : ffff00001ccabcb0 x2 : 0000000000000001
[ 831.089982] x1 : ffff8097d7ed6703 x0 : 0000000000000001
[ 831.095282] Process test_verifier (pid: 2788, stack limit = 0x0000000018370044)
[ 831.102577] Call trace:
[ 831.105012] __ll_sc_atomic_add+0x4/0x18
[ 831.108923] __bpf_prog_run32+0x4c/0x70
[ 831.112748] bpf_test_run+0x78/0xf8
[ 831.116224] bpf_prog_test_run_xdp+0xb4/0x120
[ 831.120567] SyS_bpf+0x77c/0x1110
[ 831.123873] el0_svc_naked+0x30/0x34
[ 831.127437] Code: 97fffe97 17ffffec 00000000 f9800031 (885f7c31)
Reason for this is because memory is required to be aligned. In
case of BPF, we always enforce alignment in terms of stack access,
but not when accessing map values or packet data when the underlying
arch (e.g. arm64) has CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS set.
xadd on packet data that is local to us anyway is just wrong, so
forbid this case entirely. The only place where xadd makes sense in
fact are map values; xadd on stack is wrong as well, but it's been
around for much longer. Specifically enforce strict alignment in case
of xadd, so that we handle this case generically and avoid such crashes
in the first place.
Fixes: 17a5267067f3 ("bpf: verifier (add verifier core)")
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
[ upstream commit 32fff239de37ef226d5b66329dd133f64d63b22d ]
syszbot managed to trigger RCU detected stalls in
bpf_array_free_percpu()
It takes time to allocate a huge percpu map, but even more time to free
it.
Since we run in process context, use cond_resched() to yield cpu if
needed.
Fixes: a10423b87a7e ("bpf: introduce BPF_MAP_TYPE_PERCPU_ARRAY map")
Reported-by: syzbot <syzkaller@googlegroups.com>
[ upstream commit 6c5f61023c5b0edb0c8a64c902fe97c6453b1852 ]
Commit 9a3efb6b661f ("bpf: fix memory leak in lpm_trie map_free callback function")
fixed a memory leak and removed unnecessary locks in map_free callback function.
Unfortrunately, it introduced a lockdep warning. When lockdep checking is turned on,
running tools/testing/selftests/bpf/test_lpm_map will have:
[ 98.294321] =============================
[ 98.294807] WARNING: suspicious RCU usage
[ 98.295359] 4.16.0-rc2+ #193 Not tainted
[ 98.295907] -----------------------------
[ 98.296486] /home/yhs/work/bpf/kernel/bpf/lpm_trie.c:572 suspicious rcu_dereference_check() usage!
[ 98.297657]
[ 98.297657] other info that might help us debug this:
[ 98.297657]
[ 98.298663]
[ 98.298663] rcu_scheduler_active = 2, debug_locks = 1
[ 98.299536] 2 locks held by kworker/2:1/54:
[ 98.300152] #0: ((wq_completion)"events"){+.+.}, at: [<00000000196bc1f0>] process_one_work+0x157/0x5c0
[ 98.301381] #1: ((work_completion)(&map->work)){+.+.}, at: [<00000000196bc1f0>] process_one_work+0x157/0x5c0
Since actual trie tree removal happens only after no other
accesses to the tree are possible, replacing
rcu_dereference_protected(*slot, lockdep_is_held(&trie->lock))
with
rcu_dereference_protected(*slot, 1)
fixed the issue.
Fixes: 9a3efb6b661f ("bpf: fix memory leak in lpm_trie map_free callback function")
Reported-by: Eric Dumazet <edumazet@google.com>
Suggested-by: Eric Dumazet <edumazet@google.com>
Signed-off-by: Yonghong Song <yhs@fb.com>
Reviewed-by: Eric Dumazet <edumazet@google.com>
[ upstream commit 9a3efb6b661f71d5675369ace9257833f0e78ef3 ]
There is a memory leak happening in lpm_trie map_free callback
function trie_free. The trie structure itself does not get freed.
Also, trie_free function did not do synchronize_rcu before freeing
various data structures. This is incorrect as some rcu_read_lock
region(s) for lookup, update, delete or get_next_key may not complete yet.
The fix is to add synchronize_rcu in the beginning of trie_free.
The useless spin_lock is removed from this function as well.
Fixes: b95a5c4db09b ("bpf: add a longest prefix match trie map implementation")
Reported-by: Mathieu Malaterre <malat@debian.org>
Reported-by: Alexei Starovoitov <ast@kernel.org>
Tested-by: Mathieu Malaterre <malat@debian.org>
[ upstream commit 9c2d63b843a5c8a8d0559cc067b5398aa5ec3ffc ]
syzkaller recently triggered OOM during percpu map allocation;
while there is work in progress by Dennis Zhou to add __GFP_NORETRY
semantics for percpu allocator under pressure, there seems also a
missing bpf_map_precharge_memlock() check in array map allocation.
Given today the actual bpf_map_charge_memlock() happens after the
find_and_alloc_map() in syscall path, the bpf_map_precharge_memlock()
is there to bail out early before we go and do the map setup work
when we find that we hit the limits anyway. Therefore add this for
array map as well.
Reported-by: syzbot+adb03f3f0bb57ce3acda@syzkaller.appspotmail.com
Cc: Dennis Zhou <dennisszhou@gmail.com>
[ Upstream commit 5731a879d03bdaa00265f8ebc32dfd0e65d25276 ]
Add psock NULL check to handle a racing sock event that can get the
sk_callback_lock before this case but after xchg happens causing the
refcnt to hit zero and sock user data (psock) to be null and queued
for garbage collection.
Also add a comment in the code because this is a bit subtle and
not obvious in my opinion.
commit 6f16101e6a8b4324c36e58a29d9e0dbb287cdedb upstream.
syzkaller generated a BPF proglet and triggered a warning with
the following:
0: (b7) r0 = 0
1: (d5) if r0 s<= 0x0 goto pc+0
R0=inv0 R1=ctx(id=0,off=0,imm=0) R10=fp0
2: (1f) r0 -= r1
verifier internal error: known but bad sbounds
What happens is that in the first insn, r0's min/max value
are both 0 due to the immediate assignment, later in the jsle
test the bounds are updated for the min value in the false
path, meaning, they yield smin_val = 1, smax_val = 0, and when
ctx pointer is subtracted from r0, verifier bails out with the
internal error and throwing a WARN since smin_val != smax_val
for the known constant.
For min_val > max_val scenario it means that reg_set_min_max()
and reg_set_min_max_inv() (which both refine existing bounds)
demonstrated that such branch cannot be taken at runtime.
In above scenario for the case where it will be taken, the
existing [0, 0] bounds are kept intact. Meaning, the rejection
is not due to a verifier internal error, and therefore the
WARN() is not necessary either.
We could just reject such cases in adjust_{ptr,scalar}_min_max_vals()
when either known scalars have smin_val != smax_val or
umin_val != umax_val or any scalar reg with bounds
smin_val > smax_val or umin_val > umax_val. However, there
may be a small risk of breakage of buggy programs, so handle
this more gracefully and in adjust_{ptr,scalar}_min_max_vals()
just taint the dst reg as unknown scalar when we see ops with
such kind of src reg.
Reported-by: syzbot+6d362cadd45dc0a12ba4@syzkaller.appspotmail.com
commit 4950276672fce5c241857540f8561c440663673d upstream.
Patch series "kmemcheck: kill kmemcheck", v2.
As discussed at LSF/MM, kill kmemcheck.
KASan is a replacement that is able to work without the limitation of
kmemcheck (single CPU, slow). KASan is already upstream.
We are also not aware of any users of kmemcheck (or users who don't
consider KASan as a suitable replacement).
The only objection was that since KASAN wasn't supported by all GCC
versions provided by distros at that time we should hold off for 2
years, and try again.
Now that 2 years have passed, and all distros provide gcc that supports
KASAN, kill kmemcheck again for the very same reasons.
This patch (of 4):
Remove kmemcheck annotations, and calls to kmemcheck from the kernel.
[alexander.levin@verizon.com: correctly remove kmemcheck call from dma_map_sg_attrs]
Link: http://lkml.kernel.org/r/20171012192151.26531-1-alexander.levin@verizon.com
Link: http://lkml.kernel.org/r/20171007030159.22241-2-alexander.levin@verizon.com
Cc: Alexander Potapenko <glider@google.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Tim Hansen <devtimhansen@gmail.com>
Cc: Vegard Nossum <vegardno@ifi.uio.no>
[ upstream commit f37a8cb84cce18762e8f86a70bd6a49a66ab964c ]
Alexei found that verifier does not reject stores into context
via BPF_ST instead of BPF_STX. And while looking at it, we
also should not allow XADD variant of BPF_STX.
The context rewriter is only assuming either BPF_LDX_MEM- or
BPF_STX_MEM-type operations, thus reject anything other than
that so that assumptions in the rewriter properly hold. Add
test cases as well for BPF selftests.
Fixes: d691f9e8d440 ("bpf: allow programs to write to certain skb fields")
