commit 8fe45924387be6b5c1be59a7eb330790c61d5d10 upstream.
When iterating through a map, we need to find a key that does not exist
in the map so map_get_next_key will give us the first key of the map.
This often requires a lot of guessing in production systems.
This patch makes map_get_next_key return the first key when the key
pointer in the parameter is NULL.
Signed-off-by: Teng Qin <qinteng@fb.com>
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
Signed-off-by: Chenbo Feng <fengc@google.com>
Cc: Lorenzo Colitti <lorenzo@google.com>
commit 0fa4fe85f4724fff89b09741c437cbee9cf8b008 upstream.
The current check statement in BPF syscall will do a capability check
for CAP_SYS_ADMIN before checking sysctl_unprivileged_bpf_disabled. This
code path will trigger unnecessary security hooks on capability checking
and cause false alarms on unprivileged process trying to get CAP_SYS_ADMIN
access. This can be resolved by simply switch the order of the statement
and CAP_SYS_ADMIN is not required anyway if unprivileged bpf syscall is
allowed.
Acked-by: Lorenzo Colitti <lorenzo@google.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
[ upstream commit 32fff239de37ef226d5b66329dd133f64d63b22d ]
syszbot managed to trigger RCU detected stalls in
bpf_array_free_percpu()
It takes time to allocate a huge percpu map, but even more time to free
it.
Since we run in process context, use cond_resched() to yield cpu if
needed.
Fixes: a10423b87a7e ("bpf: introduce BPF_MAP_TYPE_PERCPU_ARRAY map")
Reported-by: syzbot <syzkaller@googlegroups.com>
[ upstream commit 9c2d63b843a5c8a8d0559cc067b5398aa5ec3ffc ]
syzkaller recently triggered OOM during percpu map allocation;
while there is work in progress by Dennis Zhou to add __GFP_NORETRY
semantics for percpu allocator under pressure, there seems also a
missing bpf_map_precharge_memlock() check in array map allocation.
Given today the actual bpf_map_charge_memlock() happens after the
find_and_alloc_map() in syscall path, the bpf_map_precharge_memlock()
is there to bail out early before we go and do the map setup work
when we find that we hit the limits anyway. Therefore add this for
array map as well.
Fixes: 6c9059817432 ("bpf: pre-allocate hash map elements")
Reported-by: syzbot+adb03f3f0bb57ce3acda@syzkaller.appspotmail.com
Cc: Dennis Zhou <dennisszhou@gmail.com>
[ upstream commit a316338cb71a3260201490e615f2f6d5c0d8fb2c ]
trie_alloc() always needs to have BPF_F_NO_PREALLOC passed in via
attr->map_flags, since it does not support preallocation yet. We
check the flag, but we never copy the flag into trie->map.map_flags,
which is later on exposed into fdinfo and used by loaders such as
iproute2. Latter uses this in bpf_map_selfcheck_pinned() to test
whether a pinned map has the same spec as the one from the BPF obj
file and if not, bails out, which is currently the case for lpm
since it exposes always 0 as flags.
Also copy over flags in array_map_alloc() and stack_map_alloc().
They always have to be 0 right now, but we should make sure to not
miss to copy them over at a later point in time when we add actual
flags for them to use.
Fixes: b95a5c4db09b ("bpf: add a longest prefix match trie map implementation")
Reported-by: Jarno Rajahalme <jarno@covalent.io>
Acked-by: Alexei Starovoitov <ast@kernel.org>
[ upstream commit f37a8cb84cce18762e8f86a70bd6a49a66ab964c ]
Alexei found that verifier does not reject stores into context
via BPF_ST instead of BPF_STX. And while looking at it, we
also should not allow XADD variant of BPF_STX.
The context rewriter is only assuming either BPF_LDX_MEM- or
BPF_STX_MEM-type operations, thus reject anything other than
that so that assumptions in the rewriter properly hold. Add
test cases as well for BPF selftests.
Fixes: d691f9e8d440 ("bpf: allow programs to write to certain skb fields")
Reported-by: Alexei Starovoitov <ast@kernel.org>
[ upstream commit 68fda450a7df51cff9e5a4d4a4d9d0d5f2589153 ]
due to some JITs doing if (src_reg == 0) check in 64-bit mode
for div/mod operations mask upper 32-bits of src register
before doing the check
Fixes: 622582786c9e ("net: filter: x86: internal BPF JIT")
Fixes: 7a12b5031c6b ("sparc64: Add eBPF JIT.")
Reported-by: syzbot+48340bb518e88849e2e3@syzkaller.appspotmail.com
[ upstream commit c366287ebd698ef5e3de300d90cd62ee9ee7373e ]
Divides by zero are not nice, lets avoid them if possible.
Also do_div() seems not needed when dealing with 32bit operands,
but this seems a minor detail.
Fixes: bd4cf0ed331a ("net: filter: rework/optimize internal BPF interpreter's instruction set")
[ upstream commit 7891a87efc7116590eaba57acc3c422487802c6f ]
The following snippet was throwing an 'unknown opcode cc' warning
in BPF interpreter:
0: (18) r0 = 0x0
2: (7b) *(u64 *)(r10 -16) = r0
3: (cc) (u32) r0 s>>= (u32) r0
4: (95) exit
Although a number of JITs do support BPF_ALU | BPF_ARSH | BPF_{K,X}
generation, not all of them do and interpreter does neither. We can
leave existing ones and implement it later in bpf-next for the
remaining ones, but reject this properly in verifier for the time
being.
Fixes: 17a5267067f3 ("bpf: verifier (add verifier core)")
Reported-by: syzbot+93c4904c5c70348a6890@syzkaller.appspotmail.com
[ upstream commit 290af86629b25ffd1ed6232c4e9107da031705cb ]
The BPF interpreter has been used as part of the spectre 2 attack CVE-2017-5715.
A quote from goolge project zero blog:
"At this point, it would normally be necessary to locate gadgets in
the host kernel code that can be used to actually leak data by reading
from an attacker-controlled location, shifting and masking the result
appropriately and then using the result of that as offset to an
attacker-controlled address for a load. But piecing gadgets together
and figuring out which ones work in a speculation context seems annoying.
So instead, we decided to use the eBPF interpreter, which is built into
the host kernel - while there is no legitimate way to invoke it from inside
a VM, the presence of the code in the host kernel's text section is sufficient
to make it usable for the attack, just like with ordinary ROP gadgets."
To make attacker job harder introduce BPF_JIT_ALWAYS_ON config
option that removes interpreter from the kernel in favor of JIT-only mode.
So far eBPF JIT is supported by:
x64, arm64, arm32, sparc64, s390, powerpc64, mips64
The start of JITed program is randomized and code page is marked as read-only.
In addition "constant blinding" can be turned on with net.core.bpf_jit_harden
v2->v3:
- move __bpf_prog_ret0 under ifdef (Daniel)
v1->v2:
- fix init order, test_bpf and cBPF (Daniel's feedback)
- fix offloaded bpf (Jakub's feedback)
- add 'return 0' dummy in case something can invoke prog->bpf_func
- retarget bpf tree. For bpf-next the patch would need one extra hunk.
It will be sent when the trees are merged back to net-next
Considered doing:
int bpf_jit_enable __read_mostly = BPF_EBPF_JIT_DEFAULT;
but it seems better to land the patch as-is and in bpf-next remove
bpf_jit_enable global variable from all JITs, consolidate in one place
and remove this jit_init() function.
[ upstream commit 90caccdd8cc0215705f18b92771b449b01e2474a ]
- bpf prog_array just like all other types of bpf array accepts 32-bit index.
Clarify that in the comment.
- fix x64 JIT of bpf_tail_call which was incorrectly loading 8 instead of 4 bytes
- tighten corresponding check in the interpreter to stay consistent
The JIT bug can be triggered after introduction of BPF_F_NUMA_NODE flag
in commit 96eabe7a40aa in 4.14. Before that the map_flags would stay zero and
though JIT code is wrong it will check bounds correctly.
Hence two fixes tags. All other JITs don't have this problem.
Fixes: 96eabe7a40aa ("bpf: Allow selecting numa node during map creation")
Fixes: b52f00e6a715 ("x86: bpf_jit: implement bpf_tail_call() helper")
Acked-by: Martin KaFai Lau <kafai@fb.com>
Reviewed-by: Eric Dumazet <edumazet@google.com>
commit bbeb6e4323dad9b5e0ee9f60c223dd532e2403b1 upstream.
syzkaller tried to alloc a map with 0xfffffffd entries out of a userns,
and thus unprivileged. With the recently added logic in b2157399cc98
("bpf: prevent out-of-bounds speculation") we round this up to the next
power of two value for max_entries for unprivileged such that we can
apply proper masking into potentially zeroed out map slots.
However, this will generate an index_mask of 0xffffffff, and therefore
a + 1 will let this overflow into new max_entries of 0. This will pass
allocation, etc, and later on map access we still enforce on the original
attr->max_entries value which was 0xfffffffd, therefore triggering GPF
all over the place. Thus bail out on overflow in such case.
Moreover, on 32 bit archs roundup_pow_of_two() can also not be used,
since fls_long(max_entries - 1) can result in 32 and 1UL << 32 in 32 bit
space is undefined. Therefore, do this by hand in a 64 bit variable.
This fixes all the issues triggered by syzkaller's reproducers.
Fixes: b2157399cc98 ("bpf: prevent out-of-bounds speculation")
Reported-by: syzbot+b0efb8e572d01bce1ae0@syzkaller.appspotmail.com
Reported-by: syzbot+6c15e9744f75f2364773@syzkaller.appspotmail.com
Reported-by: syzbot+d2f5524fb46fd3b312ee@syzkaller.appspotmail.com
Reported-by: syzbot+61d23c95395cc90dbc2b@syzkaller.appspotmail.com
Reported-by: syzbot+0d363c942452cca68c01@syzkaller.appspotmail.com
commit b2157399cc9898260d6031c5bfe45fe137c1fbe7 upstream.
Under speculation, CPUs may mis-predict branches in bounds checks. Thus,
memory accesses under a bounds check may be speculated even if the
bounds check fails, providing a primitive for building a side channel.
To avoid leaking kernel data round up array-based maps and mask the index
after bounds check, so speculated load with out of bounds index will load
either valid value from the array or zero from the padded area.
Unconditionally mask index for all array types even when max_entries
are not rounded to power of 2 for root user.
When map is created by unpriv user generate a sequence of bpf insns
that includes AND operation to make sure that JITed code includes
the same 'index & index_mask' operation.
If prog_array map is created by unpriv user replace
bpf_tail_call(ctx, map, index);
with
if (index >= max_entries) {
index &= map->index_mask;
(along with roundup to power 2) to prevent out-of-bounds speculation.
There is secondary redundant 'if (index >= max_entries)' in the interpreter
and in all JITs, but they can be optimized later if necessary.
Other array-like maps (cpumap, devmap, sockmap, perf_event_array, cgroup_array)
cannot be used by unpriv, so no changes there.
That fixes bpf side of "Variant 1: bounds check bypass (CVE-2017-5753)" on
all architectures with and without JIT.
v2->v3:
Daniel noticed that attack potentially can be crafted via syscall commands
without loading the program, so add masking to those paths as well.
Acked-by: John Fastabend <john.fastabend@gmail.com>
Cc: Jiri Slaby <jslaby@suse.cz>
[ Backported to 4.9 - gregkh ]
commit 79741b3bdec01a8628368fbcfccc7d189ed606cb upstream.
reduce indent and make it iterate over instructions similar to
convert_ctx_accesses(). Also convert hard BUG_ON into soft verifier error.
[Backported to 4.9.y - gregkh]
commit e245c5c6a5656e4d61aa7bb08e9694fd6e5b2b9d upstream.
no functional change.
move fixup_bpf_calls() to verifier.c
it's being refactored in the next patch
[backported to 4.9 - gregkh]
An UNKNOWN_VALUE is not supposed to be derived from a pointer, unless
pointer leaks are allowed. Therefore, states_equal() must not treat
a state with a pointer in a register as "equal" to a state with an
UNKNOWN_VALUE in that register.
This was fixed differently upstream, but the code around here was
largely rewritten in 4.14 by commit f1174f77b50c "bpf/verifier: rework
value tracking". The bug can be detected by the bpf/verifier sub-test
"pointer/scalar confusion in state equality check (way 1)".
Cc: Edward Cree <ecree@solarflare.com>
Cc: Jann Horn <jannh@google.com>
Cc: Alexei Starovoitov <ast@kernel.org>
Cc: Daniel Borkmann <daniel@iogearbox.net>
[ Upstream commit 95a762e2c8c942780948091f8f2a4f32fce1ac6f ]
Distinguish between
BPF_ALU64|BPF_MOV|BPF_K (load 32-bit immediate, sign-extended to 64-bit)
and BPF_ALU|BPF_MOV|BPF_K (load 32-bit immediate, zero-padded to 64-bit);
only perform sign extension in the first case.
Starting with v4.14, this is exploitable by unprivileged users as long as
the unprivileged_bpf_disabled sysctl isn't set.
Debian assigned CVE-2017-16995 for this issue.
v3:
- add CVE number (Ben Hutchings)
Fixes: 484611357c19 ("bpf: allow access into map value arrays")
Signed-off-by: Jann Horn <jannh@google.com>
Acked-by: Edward Cree <ecree@solarflare.com>
Reject programs that compute wildly out-of-bounds stack pointers.
Otherwise, pointers can be computed with an offset that doesn't fit into an
`int`, causing security issues in the stack memory access check (as well as
signed integer overflow during offset addition).
This is a fix specifically for the v4.9 stable tree because the mainline
code looks very different at this point.
Fixes: 7bca0a9702edf ("bpf: enhance verifier to understand stack pointer arithmetic")
[ Upstream commit c131187db2d3fa2f8bf32fdf4e9a4ef805168467 ]
when the verifier detects that register contains a runtime constant
and it's compared with another constant it will prune exploration
of the branch that is guaranteed not to be taken at runtime.
This is all correct, but malicious program may be constructed
in such a way that it always has a constant comparison and
the other branch is never taken under any conditions.
In this case such path through the program will not be explored
by the verifier. It won't be taken at run-time either, but since
all instructions are JITed the malicious program may cause JITs
to complain about using reserved fields, etc.
To fix the issue we have to track the instructions explored by
the verifier and sanitize instructions that are dead at run time
with NOPs. We cannot reject such dead code, since llvm generates
it for valid C code, since it doesn't do as much data flow
analysis as the verifier does.
[ Upstream commit 8041902dae5299c1f194ba42d14383f734631009 ]
convert_ctx_accesses() replaces single bpf instruction with a set of
instructions. Adjust corresponding insn_aux_data while patching.
It's needed to make sure subsequent 'for(all insn)' loops
have matching insn and insn_aux_data.
[ Upstream commit 89ad2fa3f043a1e8daae193bcb5fe34d5f8caf28 ]
pcpu_freelist_pop() needs the same lockdep awareness than
pcpu_freelist_populate() to avoid a false positive.
[ INFO: SOFTIRQ-safe -> SOFTIRQ-unsafe lock order detected ]
switchto-defaul/12508 [HC0[0]:SC0[6]:HE0:SE0] is trying to acquire:
(&htab->buckets[i].lock){......}, at: [<ffffffff9dc099cb>] __htab_percpu_map_update_elem+0x1cb/0x300
and this task is already holding:
(dev_queue->dev->qdisc_class ?: &qdisc_tx_lock#2){+.-...}, at: [<ffffffff9e135848>] __dev_queue_xmit+0
x868/0x1240
which would create a new lock dependency:
(dev_queue->dev->qdisc_class ?: &qdisc_tx_lock#2){+.-...} -> (&htab->buckets[i].lock){......}
but this new dependency connects a SOFTIRQ-irq-safe lock:
... which became SOFTIRQ-irq-safe at:
[<ffffffff9db5931b>] __lock_acquire+0x42b/0x1f10
[<ffffffff9db5b32c>] lock_acquire+0xbc/0x1b0
[<ffffffff9da05e38>] _raw_spin_lock+0x38/0x50
[<ffffffff9e135848>] __dev_queue_xmit+0x868/0x1240
[<ffffffff9e136240>] dev_queue_xmit+0x10/0x20
[<ffffffff9e1965d9>] ip_finish_output2+0x439/0x590
[<ffffffff9e197410>] ip_finish_output+0x150/0x2f0
[<ffffffff9e19886d>] ip_output+0x7d/0x260
[<ffffffff9e19789e>] ip_local_out+0x5e/0xe0
[<ffffffff9e197b25>] ip_queue_xmit+0x205/0x620
[<ffffffff9e1b8398>] tcp_transmit_skb+0x5a8/0xcb0
[<ffffffff9e1ba152>] tcp_write_xmit+0x242/0x1070
[<ffffffff9e1baffc>] __tcp_push_pending_frames+0x3c/0xf0
[<ffffffff9e1b3472>] tcp_rcv_established+0x312/0x700
[<ffffffff9e1c1acc>] tcp_v4_do_rcv+0x11c/0x200
[<ffffffff9e1c3dc2>] tcp_v4_rcv+0xaa2/0xc30
[<ffffffff9e191107>] ip_local_deliver_finish+0xa7/0x240
[<ffffffff9e191a36>] ip_local_deliver+0x66/0x200
[<ffffffff9e19137d>] ip_rcv_finish+0xdd/0x560
[<ffffffff9e191e65>] ip_rcv+0x295/0x510
[<ffffffff9e12ff88>] __netif_receive_skb_core+0x988/0x1020
[<ffffffff9e130641>] __netif_receive_skb+0x21/0x70
[<ffffffff9e1306ff>] process_backlog+0x6f/0x230
[<ffffffff9e132129>] net_rx_action+0x229/0x420
[<ffffffff9da07ee8>] __do_softirq+0xd8/0x43d
[<ffffffff9e282bcc>] do_softirq_own_stack+0x1c/0x30
[<ffffffff9dafc2f5>] do_softirq+0x55/0x60
[<ffffffff9dafc3a8>] __local_bh_enable_ip+0xa8/0xb0
[<ffffffff9db4c727>] cpu_startup_entry+0x1c7/0x500
[<ffffffff9daab333>] start_secondary+0x113/0x140
to a SOFTIRQ-irq-unsafe lock:
(&head->lock){+.+...}
... which became SOFTIRQ-irq-unsafe at:
... [<ffffffff9db5971f>] __lock_acquire+0x82f/0x1f10
[<ffffffff9dc0b7fa>] pcpu_freelist_pop+0x7a/0xb0
[<ffffffff9dc08b2c>] htab_map_alloc+0x50c/0x5f0
[<ffffffff9dc00dc5>] SyS_bpf+0x265/0x1200
[<ffffffff9e28195f>] entry_SYSCALL_64_fastpath+0x12/0x17
Chain exists of:
dev_queue->dev->qdisc_class ?: &qdisc_tx_lock#2 --> &htab->buckets[i].lock --> &head->lock
Possible interrupt unsafe locking scenario:
CPU0 CPU1
lock(&head->lock);
local_irq_disable();
lock(dev_queue->dev->qdisc_class ?: &qdisc_tx_lock#2);
lock(&htab->buckets[i].lock);
<Interrupt>
*** DEADLOCK ***
Fixes: e19494edab82 ("bpf: introduce percpu_freelist")
[ Upstream commit e67b8a685c7c984e834e3181ef4619cd7025a136 ]
Neither ___bpf_prog_run nor the JITs accept it.
Also adds a new test case.
Signed-off-by: Edward Cree <ecree@solarflare.com>
[ Upstream commit 9305706c2e808ae59f1eb201867f82f1ddf6d7a6 ]
We have to subtract the src max from the dst min, and vice-versa, since
(e.g.) the smallest result comes from the largest subtrahend.
[ Upstream commit 4cabc5b186b5427b9ee5a7495172542af105f02b ]
Edward reported that there's an issue in min/max value bounds
tracking when signed and unsigned compares both provide hints
on limits when having unknown variables. E.g. a program such
as the following should have been rejected:
0: (7a) *(u64 *)(r10 -8) = 0
1: (bf) r2 = r10
2: (07) r2 += -8
3: (18) r1 = 0xffff8a94cda93400
5: (85) call bpf_map_lookup_elem#1
6: (15) if r0 == 0x0 goto pc+7
R0=map_value(ks=8,vs=8,id=0),min_value=0,max_value=0 R10=fp
7: (7a) *(u64 *)(r10 -16) = -8
8: (79) r1 = *(u64 *)(r10 -16)
9: (b7) r2 = -1
10: (2d) if r1 > r2 goto pc+3
R0=map_value(ks=8,vs=8,id=0),min_value=0,max_value=0 R1=inv,min_value=0
R2=imm-1,max_value=18446744073709551615,min_align=1 R10=fp
11: (65) if r1 s> 0x1 goto pc+2
R0=map_value(ks=8,vs=8,id=0),min_value=0,max_value=0 R1=inv,min_value=0,max_value=1
12: (0f) r0 += r1
13: (72) *(u8 *)(r0 +0) = 0
R0=map_value_adj(ks=8,vs=8,id=0),min_value=0,max_value=1 R1=inv,min_value=0,max_value=1
14: (b7) r0 = 0
15: (95) exit
What happens is that in the first part ...
9: (b7) r2 = -1
... r1 carries an unsigned value, and is compared as unsigned
against a register carrying an immediate. Verifier deduces in
reg_set_min_max() that since the compare is unsigned and operation
is greater than (>), that in the fall-through/false case, r1's
minimum bound must be 0 and maximum bound must be r2. Latter is
larger than the bound and thus max value is reset back to being
'invalid' aka BPF_REGISTER_MAX_RANGE. Thus, r1 state is now
'R1=inv,min_value=0'. The subsequent test ...
... is a signed compare of r1 with immediate value 1. Here,
verifier deduces in reg_set_min_max() that since the compare
is signed this time and operation is greater than (>), that
in the fall-through/false case, we can deduce that r1's maximum
bound must be 1, meaning with prior test, we result in r1 having
the following state: R1=inv,min_value=0,max_value=1. Given that
the actual value this holds is -8, the bounds are wrongly deduced.
When this is being added to r0 which holds the map_value(_adj)
type, then subsequent store access in above case will go through
check_mem_access() which invokes check_map_access_adj(), that
will then probe whether the map memory is in bounds based
on the min_value and max_value as well as access size since
the actual unknown value is min_value <= x <= max_value; commit
fce366a9dd0d ("bpf, verifier: fix alu ops against map_value{,
_adj} register types") provides some more explanation on the
semantics.
It's worth to note in this context that in the current code,
min_value and max_value tracking are used for two things, i)
dynamic map value access via check_map_access_adj() and since
commit 06c1c049721a ("bpf: allow helpers access to variable memory")
ii) also enforced at check_helper_mem_access() when passing a
memory address (pointer to packet, map value, stack) and length
pair to a helper and the length in this case is an unknown value
defining an access range through min_value/max_value in that
case. The min_value/max_value tracking is /not/ used in the
direct packet access case to track ranges. However, the issue
also affects case ii), for example, the following crafted program
based on the same principle must be rejected as well:
0: (b7) r2 = 0
1: (bf) r3 = r10
2: (07) r3 += -512
3: (7a) *(u64 *)(r10 -16) = -8
4: (79) r4 = *(u64 *)(r10 -16)
5: (b7) r6 = -1
6: (2d) if r4 > r6 goto pc+5
R1=ctx R2=imm0,min_value=0,max_value=0,min_align=2147483648 R3=fp-512
R4=inv,min_value=0 R6=imm-1,max_value=18446744073709551615,min_align=1 R10=fp
7: (65) if r4 s> 0x1 goto pc+4
R4=inv,min_value=0,max_value=1 R6=imm-1,max_value=18446744073709551615,min_align=1
R10=fp
8: (07) r4 += 1
9: (b7) r5 = 0
10: (6a) *(u16 *)(r10 -512) = 0
11: (85) call bpf_skb_load_bytes#26
12: (b7) r0 = 0
13: (95) exit
Meaning, while we initialize the max_value stack slot that the
verifier thinks we access in the [1,2] range, in reality we
pass -7 as length which is interpreted as u32 in the helper.
Thus, this issue is relevant also for the case of helper ranges.
Resetting both bounds in check_reg_overflow() in case only one
of them exceeds limits is also not enough as similar test can be
created that uses values which are within range, thus also here
learned min value in r1 is incorrect when mixed with later signed
test to create a range:
1: (bf) r2 = r10
2: (07) r2 += -8
3: (18) r1 = 0xffff880ad081fa00
9: (b7) r2 = 2
10: (3d) if r2 >= r1 goto pc+3
R0=map_value(ks=8,vs=8,id=0),min_value=0,max_value=0 R1=inv,min_value=3
R2=imm2,min_value=2,max_value=2,min_align=2 R10=fp
11: (65) if r1 s> 0x4 goto pc+2
R1=inv,min_value=3,max_value=4 R2=imm2,min_value=2,max_value=2,min_align=2 R10=fp
12: (0f) r0 += r1
R0=map_value_adj(ks=8,vs=8,id=0),min_value=3,max_value=4
14: (b7) r0 = 0
15: (95) exit
This leaves us with two options for fixing this: i) to invalidate
all prior learned information once we switch signed context, ii)
to track min/max signed and unsigned boundaries separately as
done in [0]. (Given latter introduces major changes throughout
the whole verifier, it's rather net-next material, thus this
patch follows option i), meaning we can derive bounds either
from only signed tests or only unsigned tests.) There is still the
case of adjust_reg_min_max_vals(), where we adjust bounds on ALU
operations, meaning programs like the following where boundaries
on the reg get mixed in context later on when bounds are merged
on the dst reg must get rejected, too:
1: (bf) r2 = r10
2: (07) r2 += -8
3: (18) r1 = 0xffff89b2bf87ce00
6: (15) if r0 == 0x0 goto pc+6
9: (b7) r2 = 2
10: (3d) if r2 >= r1 goto pc+2
11: (b7) r7 = 1
12: (65) if r7 s> 0x0 goto pc+2
R2=imm2,min_value=2,max_value=2,min_align=2 R7=imm1,max_value=0 R10=fp
13: (b7) r0 = 0
14: (95) exit
from 12 to 15: R0=map_value(ks=8,vs=8,id=0),min_value=0,max_value=0
R1=inv,min_value=3 R2=imm2,min_value=2,max_value=2,min_align=2 R7=imm1,min_value=1 R10=fp
15: (0f) r7 += r1
16: (65) if r7 s> 0x4 goto pc+2
R2=imm2,min_value=2,max_value=2,min_align=2 R7=inv,min_value=4,max_value=4 R10=fp
17: (0f) r0 += r7
18: (72) *(u8 *)(r0 +0) = 0
R0=map_value_adj(ks=8,vs=8,id=0),min_value=4,max_value=4 R1=inv,min_value=3
19: (b7) r0 = 0
20: (95) exit
Meaning, in adjust_reg_min_max_vals() we must also reset range
values on the dst when src/dst registers have mixed signed/
unsigned derived min/max value bounds with one unbounded value
as otherwise they can be added together deducing false boundaries.
Once both boundaries are established from either ALU ops or
compare operations w/o mixing signed/unsigned insns, then they
can safely be added to other regs also having both boundaries
established. Adding regs with one unbounded side to a map value
where the bounded side has been learned w/o mixing ops is
possible, but the resulting map value won't recover from that,
meaning such op is considered invalid on the time of actual
access. Invalid bounds are set on the dst reg in case i) src reg,
or ii) in case dst reg already had them. The only way to recover
would be to perform i) ALU ops but only 'add' is allowed on map
value types or ii) comparisons, but these are disallowed on
pointers in case they span a range. This is fine as only BPF_JEQ
and BPF_JNE may be performed on PTR_TO_MAP_VALUE_OR_NULL registers
which potentially turn them into PTR_TO_MAP_VALUE type depending
on the branch, so only here min/max value cannot be invalidated
for them.
In terms of state pruning, value_from_signed is considered
as well in states_equal() when dealing with adjusted map values.
With regards to breaking existing programs, there is a small
risk, but use-cases are rather quite narrow where this could
occur and mixing compares probably unlikely.
Joint work with Josef and Edward.
[0] https://lists.iovisor.org/pipermail/iovisor-dev/2017-June/000822.html
Reported-by: Edward Cree <ecree@solarflare.com>
Signed-off-by: Josef Bacik <jbacik@fb.com>
[ Upstream commit fce366a9dd0ddc47e7ce05611c266e8574a45116 ]
While looking into map_value_adj, I noticed that alu operations
directly on the map_value() resp. map_value_adj() register (any
alu operation on a map_value() register will turn it into a
map_value_adj() typed register) are not sufficiently protected
against some of the operations. Two non-exhaustive examples are
provided that the verifier needs to reject:
i) BPF_AND on r0 (map_value_adj):
0: (bf) r2 = r10
1: (07) r2 += -8
2: (7a) *(u64 *)(r2 +0) = 0
3: (18) r1 = 0xbf842a00
6: (15) if r0 == 0x0 goto pc+2
R0=map_value(ks=8,vs=48,id=0),min_value=0,max_value=0 R10=fp
7: (57) r0 &= 8
8: (7a) *(u64 *)(r0 +0) = 22
R0=map_value_adj(ks=8,vs=48,id=0),min_value=0,max_value=8 R10=fp
9: (95) exit
from 6 to 9: R0=inv,min_value=0,max_value=0 R10=fp
9: (95) exit
processed 10 insns
ii) BPF_ADD in 32 bit mode on r0 (map_value_adj):
0: (bf) r2 = r10
1: (07) r2 += -8
3: (18) r1 = 0xc24eee00
7: (04) (u32) r0 += (u32) 0
R0=map_value_adj(ks=8,vs=48,id=0),min_value=0,max_value=0 R10=fp
9: (95) exit
9: (95) exit
processed 10 insns
Issue is, while min_value / max_value boundaries for the access
are adjusted appropriately, we change the pointer value in a way
that cannot be sufficiently tracked anymore from its origin.
Operations like BPF_{AND,OR,DIV,MUL,etc} on a destination register
that is PTR_TO_MAP_VALUE{,_ADJ} was probably unintended, in fact,
all the test cases coming with 484611357c19 ("bpf: allow access
into map value arrays") perform BPF_ADD only on the destination
register that is PTR_TO_MAP_VALUE_ADJ.
Only for UNKNOWN_VALUE register types such operations make sense,
f.e. with unknown memory content fetched initially from a constant
offset from the map value memory into a register. That register is
then later tested against lower / upper bounds, so that the verifier
can then do the tracking of min_value / max_value, and properly
check once that UNKNOWN_VALUE register is added to the destination
register with type PTR_TO_MAP_VALUE{,_ADJ}. This is also what the
original use-case is solving. Note, tracking on what is being
added is done through adjust_reg_min_max_vals() and later access
to the map value enforced with these boundaries and the given offset
from the insn through check_map_access_adj().
Tests will fail for non-root environment due to prohibited pointer
arithmetic, in particular in check_alu_op(), we bail out on the
is_pointer_value() check on the dst_reg (which is false in root
case as we allow for pointer arithmetic via env->allow_ptr_leaks).
Similarly to PTR_TO_PACKET, one way to fix it is to restrict the
allowed operations on PTR_TO_MAP_VALUE{,_ADJ} registers to 64 bit
mode BPF_ADD. The test_verifier suite runs fine after the patch
and it also rejects mentioned test cases.
Reviewed-by: Josef Bacik <jbacik@fb.com>
[ Upstream commit 3c2ce60bdd3d57051bf85615deec04a694473840 ]
Current limits with regards to processing program paths do not
really reflect today's needs anymore due to programs becoming
more complex and verifier smarter, keeping track of more data
such as const ALU operations, alignment tracking, spilling of
PTR_TO_MAP_VALUE_ADJ registers, and other features allowing for
smarter matching of what LLVM generates.
This also comes with the side-effect that we result in fewer
opportunities to prune search states and thus often need to do
more work to prove safety than in the past due to different
register states and stack layout where we mismatch. Generally,
it's quite hard to determine what caused a sudden increase in
complexity, it could be caused by something as trivial as a
single branch somewhere at the beginning of the program where
LLVM assigned a stack slot that is marked differently throughout
other branches and thus causing a mismatch, where verifier
then needs to prove safety for the whole rest of the program.
Subsequently, programs with even less than half the insn size
limit can get rejected. We noticed that while some programs
load fine under pre 4.11, they get rejected due to hitting
limits on more recent kernels. We saw that in the vast majority
of cases (90+%) pruning failed due to register mismatches. In
case of stack mismatches, majority of cases failed due to
different stack slot types (invalid, spill, misc) rather than
differences in spilled registers.
This patch makes pruning more aggressive by also adding markers
that sit at conditional jumps as well. Currently, we only mark
jump targets for pruning. For example in direct packet access,
these are usually error paths where we bail out. We found that
adding these markers, it can reduce number of processed insns
by up to 30%. Another option is to ignore reg->id in probing
PTR_TO_MAP_VALUE_OR_NULL registers, which can help pruning
slightly as well by up to 7% observed complexity reduction as
stand-alone. Meaning, if a previous path with register type
PTR_TO_MAP_VALUE_OR_NULL for map X was found to be safe, then
in the current state a PTR_TO_MAP_VALUE_OR_NULL register for
the same map X must be safe as well. Last but not least the
patch also adds a scheduling point and bumps the current limit
for instructions to be processed to a more adequate value.
[ Upstream commit 43188702b3d98d2792969a3377a30957f05695e6 ]
Currently the verifier does not track imm across alu operations when
the source register is of unknown type. This adds additional pattern
matching to catch this and track imm. We've seen LLVM generating this
pattern while working on cilium.
Signed-off-by: John Fastabend <john.fastabend@gmail.com>
commit 6bdf6abc56b53103324dfd270a86580306e1a232 upstream.
Leaking kernel addresses on unpriviledged is generally disallowed,
for example, verifier rejects the following:
0: (b7) r0 = 0
1: (18) r2 = 0xffff897e82304400
3: (7b) *(u64 *)(r1 +48) = r2
R2 leaks addr into ctx
Doing pointer arithmetic on them is also forbidden, so that they
don't turn into unknown value and then get leaked out. However,
there's xadd as a special case, where we don't check the src reg
for being a pointer register, e.g. the following will pass:
0: (b7) r0 = 0
1: (7b) *(u64 *)(r1 +48) = r0
2: (18) r2 = 0xffff897e82304400 ; map
4: (db) lock *(u64 *)(r1 +48) += r2
5: (95) exit
We could store the pointer into skb->cb, loose the type context,
and then read it out from there again to leak it eventually out
of a map value. Or more easily in a different variant, too:
0: (bf) r6 = r1
1: (7a) *(u64 *)(r10 -8) = 0
2: (bf) r2 = r10
3: (07) r2 += -8
4: (18) r1 = 0x0
6: (85) call bpf_map_lookup_elem#1
7: (15) if r0 == 0x0 goto pc+3
R0=map_value(ks=8,vs=8,id=0),min_value=0,max_value=0 R6=ctx R10=fp
8: (b7) r3 = 0
9: (7b) *(u64 *)(r0 +0) = r3
10: (db) lock *(u64 *)(r0 +0) += r6
11: (b7) r0 = 0
12: (95) exit
from 7 to 11: R0=inv,min_value=0,max_value=0 R6=ctx R10=fp
11: (b7) r0 = 0
12: (95) exit
Prevent this by checking xadd src reg for pointer types. Also
add a couple of test cases related to this.
Fixes: 1be7f75d1668 ("bpf: enable non-root eBPF programs")
[ Upstream commit d407bd25a204bd66b7346dde24bd3d37ef0e0b05 ]
This patch adds two helpers, bpf_map_area_alloc() and bpf_map_area_free(),
that are to be used for map allocations. Using kmalloc() for very large
allocations can cause excessive work within the page allocator, so i) fall
back earlier to vmalloc() when the attempt is considered costly anyway,
and even more importantly ii) don't trigger OOM killer with any of the
allocators.
Since this is based on a user space request, for example, when creating
maps with element pre-allocation, we really want such requests to fail
instead of killing other user space processes.
Also, don't spam the kernel log with warnings should any of the allocations
fail under pressure. Given that, we can make backend selection in
bpf_map_area_alloc() generic, and convert all maps over to use this API
for spots with potentially large allocation requests.
Note, replacing the one kmalloc_array() is fine as overflow checks happen
earlier in htab_map_alloc(), since it must also protect the multiplication
for vmalloc() should kmalloc_array() fail.
[ Upstream commit 0d0e57697f162da4aa218b5feafe614fb666db07 ]
The patch fixes two things at once:
1) It checks the env->allow_ptr_leaks and only prints the map address to
the log if we have the privileges to do so, otherwise it just dumps 0
as we would when kptr_restrict is enabled on %pK. Given the latter is
off by default and not every distro sets it, I don't want to rely on
this, hence the 0 by default for unprivileged.
2) Printing of ldimm64 in the verifier log is currently broken in that
we don't print the full immediate, but only the 32 bit part of the
first insn part for ldimm64. Thus, fix this up as well; it's okay to
access, since we verified all ldimm64 earlier already (including just
constants) through replace_map_fd_with_map_ptr().
Fixes: cbd357008604 ("bpf: verifier (add ability to receive verification log)")
Reported-by: Jann Horn <jannh@google.com>
[ Upstream commit 332270fdc8b6fba07d059a9ad44df9e1a2ad4529 ]
llvm 4.0 and above generates the code like below:
440: (b7) r1 = 15
441: (05) goto pc+73
515: (79) r6 = *(u64 *)(r10 -152)
516: (bf) r7 = r10
517: (07) r7 += -112
518: (bf) r2 = r7
519: (0f) r2 += r1
520: (71) r1 = *(u8 *)(r8 +0)
521: (73) *(u8 *)(r2 +45) = r1
and the verifier complains "R2 invalid mem access 'inv'" for insn #521.
This is because verifier marks register r2 as unknown value after #519
where r2 is a stack pointer and r1 holds a constant value.
Teach verifier to recognize "stack_ptr + imm" and
"stack_ptr + reg with const val" as valid stack_ptr with new offset.
Signed-off-by: Yonghong Song <yhs@fb.com>
[ Upstream commit b1977682a3858b5584ffea7cfb7bd863f68db18d ]
llvm can optimize the 'if (ptr > data_end)' checks to be in the order
slightly different than the original C code which will confuse verifier.
Like:
if (ptr + 16 > data_end)
return TC_ACT_SHOT;
// may be followed by
if (ptr + 14 > data_end)
return TC_ACT_SHOT;
while llvm can see that 'ptr' is valid for all 16 bytes,
the verifier could not.
Fix verifier logic to account for such case and add a test.
Reported-by: Huapeng Zhou <hzhou@fb.com>
Fixes: 969bf05eb3ce ("bpf: direct packet access")
[ Upstream commit 6760bf2ddde8ad64f8205a651223a93de3a35494 ]
Martin reported a verifier issue that hit the BUG_ON() for his
test case in the mark_reg_unknown_value() function:
[ 202.861380] kernel BUG at kernel/bpf/verifier.c:467!
[ 203.291109] Call Trace:
[ 203.296501] [<ffffffff811364d5>] mark_map_reg+0x45/0x50
[ 203.308225] [<ffffffff81136558>] mark_map_regs+0x78/0x90
[ 203.320140] [<ffffffff8113938d>] do_check+0x226d/0x2c90
[ 203.331865] [<ffffffff8113a6ab>] bpf_check+0x48b/0x780
[ 203.343403] [<ffffffff81134c8e>] bpf_prog_load+0x27e/0x440
[ 203.355705] [<ffffffff8118a38f>] ? handle_mm_fault+0x11af/0x1230
[ 203.369158] [<ffffffff812d8188>] ? security_capable+0x48/0x60
[ 203.382035] [<ffffffff811351a4>] SyS_bpf+0x124/0x960
[ 203.393185] [<ffffffff810515f6>] ? __do_page_fault+0x276/0x490
[ 203.406258] [<ffffffff816db320>] entry_SYSCALL_64_fastpath+0x13/0x94
This issue got uncovered after the fix in a08dd0da5307 ("bpf: fix
regression on verifier pruning wrt map lookups"). The reason why it
wasn't noticed before was, because as mentioned in a08dd0da5307,
mark_map_regs() was doing the id matching incorrectly based on the
uncached regs[regno].id. So, in the first loop, we walked all regs
and as soon as we found regno == i, then this reg's id was cleared
when calling mark_reg_unknown_value() thus that every subsequent
register was probed against id of 0 (which, in combination with the
PTR_TO_MAP_VALUE_OR_NULL type is an invalid condition that no other
register state can hold), and therefore wasn't type transitioned such
as in the spilled register case for the second loop.
Now since that got fixed, it turned out that 57a09bf0a416 ("bpf:
Detect identical PTR_TO_MAP_VALUE_OR_NULL registers") used
mark_reg_unknown_value() incorrectly for the spilled regs, and thus
hitting the BUG_ON() in some cases due to regno >= MAX_BPF_REG.
Although spilled regs have the same type as the non-spilled regs
for the verifier state, that is, struct bpf_reg_state, they are
semantically different from the non-spilled regs. In other words,
there can be up to 64 (MAX_BPF_STACK / BPF_REG_SIZE) spilled regs
in the stack, for example, register R<x> could have been spilled by
the program to stack location X, Y, Z, and in mark_map_regs() we
need to scan these stack slots of type STACK_SPILL for potential
registers that we have to transition from PTR_TO_MAP_VALUE_OR_NULL.
Therefore, depending on the location, the spilled_regs regno can
be a lot higher than just MAX_BPF_REG's value since we operate on
stack instead. The reset in mark_reg_unknown_value() itself is
just fine, only that the BUG_ON() was inappropriate for this. Fix
it by making a __mark_reg_unknown_value() version that can be
called from mark_map_reg() generically; we know for the non-spilled
case that the regno is always < MAX_BPF_REG anyway.
Fixes: 57a09bf0a416 ("bpf: Detect identical PTR_TO_MAP_VALUE_OR_NULL registers")
Reported-by: Martin KaFai Lau <kafai@fb.com>
[ Upstream commit a08dd0da5307ba01295c8383923e51e7997c3576 ]
Commit 57a09bf0a416 ("bpf: Detect identical PTR_TO_MAP_VALUE_OR_NULL
registers") introduced a regression where existing programs stopped
loading due to reaching the verifier's maximum complexity limit,
whereas prior to this commit they were loading just fine; the affected
program has roughly 2k instructions.
What was found is that state pruning couldn't be performed effectively
anymore due to mismatches of the verifier's register state, in particular
in the id tracking. It doesn't mean that 57a09bf0a416 is incorrect per
se, but rather that verifier needs to perform a lot more work for the
same program with regards to involved map lookups.
Since commit 57a09bf0a416 is only about tracking registers with type
PTR_TO_MAP_VALUE_OR_NULL, the id is only needed to follow registers
until they are promoted through pattern matching with a NULL check to
either PTR_TO_MAP_VALUE or UNKNOWN_VALUE type. After that point, the
id becomes irrelevant for the transitioned types.
For UNKNOWN_VALUE, id is already reset to 0 via mark_reg_unknown_value(),
but not so for PTR_TO_MAP_VALUE where id is becoming stale. It's even
transferred further into other types that don't make use of it. Among
others, one example is where UNKNOWN_VALUE is set on function call
return with RET_INTEGER return type.
states_equal() will then fall through the memcmp() on register state;
note that the second memcmp() uses offsetofend(), so the id is part of
that since d2a4dd37f6b4 ("bpf: fix state equivalence"). But the bisect
pointed already to 57a09bf0a416, where we really reach beyond complexity
limit. What I found was that states_equal() often failed in this
case due to id mismatches in spilled regs with registers in type
PTR_TO_MAP_VALUE. Unlike non-spilled regs, spilled regs just perform
a memcmp() on their reg state and don't have any other optimizations
in place, therefore also id was relevant in this case for making a
pruning decision.
We can safely reset id to 0 as well when converting to PTR_TO_MAP_VALUE.
For the affected program, it resulted in a ~17 fold reduction of
complexity and let the program load fine again. Selftest suite also
runs fine. The only other place where env->id_gen is used currently is
through direct packet access, but for these cases id is long living, thus
a different scenario.
Also, the current logic in mark_map_regs() is not fully correct when
marking NULL branch with UNKNOWN_VALUE. We need to cache the destination
reg's id in any case. Otherwise, once we marked that reg as UNKNOWN_VALUE,
it's id is reset and any subsequent registers that hold the original id
and are of type PTR_TO_MAP_VALUE_OR_NULL won't be marked UNKNOWN_VALUE
anymore, since mark_map_reg() reuses the uncached regs[regno].id that
was just overridden. Note, we don't need to cache it outside of
mark_map_regs(), since it's called once on this_branch and the other
time on other_branch, which are both two independent verifier states.
A test case for this is added here, too.
Acked-by: Thomas Graf <tgraf@suug.ch>
[ Upstream commit d2a4dd37f6b41fbcad76efbf63124eb3126c66fe ]
Commmits 57a09bf0a416 ("bpf: Detect identical PTR_TO_MAP_VALUE_OR_NULL registers")
and 484611357c19 ("bpf: allow access into map value arrays") by themselves
are correct, but in combination they make state equivalence ignore 'id' field
of the register state which can lead to accepting invalid program.
[ Upstream commit 57a09bf0a416700676e77102c28f9cfcb48267e0 ]
A BPF program is required to check the return register of a
map_elem_lookup() call before accessing memory. The verifier keeps
track of this by converting the type of the result register from
PTR_TO_MAP_VALUE_OR_NULL to PTR_TO_MAP_VALUE after a conditional
jump ensures safety. This check is currently exclusively performed
for the result register 0.
In the event the compiler reorders instructions, BPF_MOV64_REG
instructions may be moved before the conditional jump which causes
them to keep their type PTR_TO_MAP_VALUE_OR_NULL to which the
verifier objects when the register is accessed:
0: (b7) r1 = 10
1: (7b) *(u64 *)(r10 -8) = r1
2: (bf) r2 = r10
3: (07) r2 += -8
4: (18) r1 = 0x59c00000
6: (85) call 1
7: (bf) r4 = r0
8: (15) if r0 == 0x0 goto pc+1
R0=map_value(ks=8,vs=8) R4=map_value_or_null(ks=8,vs=8) R10=fp
9: (7a) *(u64 *)(r4 +0) = 0
R4 invalid mem access 'map_value_or_null'
This commit extends the verifier to keep track of all identical
PTR_TO_MAP_VALUE_OR_NULL registers after a map_elem_lookup() by
assigning them an ID and then marking them all when the conditional
jump is observed.
Signed-off-by: Thomas Graf <tgraf@suug.ch>
If we have a branch that looks something like this
int foo = map->value;
if (condition) {
foo += blah;
} else {
foo = bar;
map->array[foo] = baz;
We will incorrectly assume that the !condition branch is equal to the condition
branch as the register for foo will be UNKNOWN_VALUE in both cases. We need to
adjust this logic to only do this if we didn't do a varlen access after we
processed the !condition branch, otherwise we have different ranges and need to
check the other branch as well.
I made some invalid assumptions with BPF_AND and BPF_MOD that could result in
invalid accesses to bpf map entries. Fix this up by doing a few things
1) Kill BPF_MOD support. This doesn't actually get used by the compiler in real
life and just adds extra complexity.
2) Fix the logic for BPF_AND, don't allow AND of negative numbers and set the
minimum value to 0 for positive AND's.
3) Don't do operations on the ranges if they are set to the limits, as they are
by definition undefined, and allowing arithmetic operations on those values
could make them appear valid when they really aren't.
This fixes the testcase provided by Jann as well as a few other theoretical
problems.
In map_create(), we first find and create the map, then once that
suceeded, we charge it to the user's RLIMIT_MEMLOCK, and then fetch
a new anon fd through anon_inode_getfd(). The problem is, once the
latter fails f.e. due to RLIMIT_NOFILE limit, then we only destruct
the map via map->ops->map_free(), but without uncharging the previously
locked memory first. That means that the user_struct allocation is
leaked as well as the accounted RLIMIT_MEMLOCK memory not released.
Make the label names in the fix consistent with bpf_prog_load().
Fixes: aaac3ba95e4c ("bpf: charge user for creation of BPF maps and programs")
Commit a6ed3ea65d98 ("bpf: restore behavior of bpf_map_update_elem")
added an extra per-cpu reserve to the hash table map to restore old
behaviour from pre prealloc times. When non-prealloc is in use for a
map, then problem is that once a hash table extra element has been
linked into the hash-table, and the hash table is destroyed due to
refcount dropping to zero, then htab_map_free() -> delete_all_elements()
will walk the whole hash table and drop all elements via htab_elem_free().
The problem is that the element from the extra reserve is first fed
to the wrong backend allocator and eventually freed twice.
Fixes: a6ed3ea65d98 ("bpf: restore behavior of bpf_map_update_elem")
Pull more vfs updates from Al Viro:
">rename2() work from Miklos + current_time() from Deepa"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
fs: Replace current_fs_time() with current_time()
fs: Replace CURRENT_TIME_SEC with current_time() for inode timestamps
fs: Replace CURRENT_TIME with current_time() for inode timestamps
fs: proc: Delete inode time initializations in proc_alloc_inode()
vfs: Add current_time() api
vfs: add note about i_op->rename changes to porting
fs: rename "rename2" i_op to "rename"
vfs: remove unused i_op->rename
fs: make remaining filesystems use .rename2
libfs: support RENAME_NOREPLACE in simple_rename()
fs: support RENAME_NOREPLACE for local filesystems
ncpfs: fix unused variable warning
Suppose you have a map array value that is something like this
struct foo {
unsigned iter;
int array[SOME_CONSTANT];
You can easily insert this into an array, but you cannot modify the contents of
foo->array[] after the fact. This is because we have no way to verify we won't
go off the end of the array at verification time. This patch provides a start
for this work. We accomplish this by keeping track of a minimum and maximum
value a register could be while we're checking the code. Then at the time we
try to do an access into a MAP_VALUE we verify that the maximum offset into that
region is a valid access into that memory region. So in practice, code such as
this
unsigned index = 0;
if (foo->iter >= SOME_CONSTANT)
foo->iter = index;
else
index = foo->iter++;
foo->array[index] = bar;
would be allowed, as we can verify that index will always be between 0 and
SOME_CONSTANT-1. If you wish to use signed values you'll have to have an extra
check to make sure the index isn't less than 0, or do something like index %=
SOME_CONSTANT.
put_cpu_var takes the percpu data, not the data returned from
get_cpu_var.
This doesn't change the behavior.
Cc: Tejun Heo <tj@kernel.org>
Signed-off-by: Shaohua Li <shli@fb.com>
Acked-by: Tejun Heo <tj@kernel.org>
CURRENT_TIME macro is not appropriate for filesystems as it
doesn't use the right granularity for filesystem timestamps.
Use current_time() instead.
CURRENT_TIME is also not y2038 safe.
This is also in preparation for the patch that transitions
vfs timestamps to use 64 bit time and hence make them
y2038 safe. As part of the effort current_time() will be
extended to do range checks. Hence, it is necessary for all
file system timestamps to use current_time(). Also,
current_time() will be transitioned along with vfs to be
y2038 safe.
Note that whenever a single call to current_time() is used
to change timestamps in different inodes, it is because they
share the same time granularity.
Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Acked-by: Felipe Balbi <balbi@kernel.org>
Acked-by: Steven Whitehouse <swhiteho@redhat.com>
Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Acked-by: David Sterba <dsterba@suse.com>
This prevent future potential pointer leaks when an unprivileged eBPF
program will read a pointer value from its context. Even if
is_valid_access() returns a pointer type, the eBPF verifier replace it
with UNKNOWN_VALUE. The register value that contains a kernel address is
then allowed to leak. Moreover, this fix allows unprivileged eBPF
programs to use functions with (legitimate) pointer arguments.
Not an issue currently since reg_type is only set for PTR_TO_PACKET or
PTR_TO_PACKET_END in XDP and TC programs that can only be loaded as
privileged. For now, the only unprivileged eBPF program allowed is for
socket filtering and all the types from its context are UNKNOWN_VALUE.
However, this fix is important for future unprivileged eBPF programs
which could use pointers in their context.
Signed-off-by: Mickaël Salaün <mic@digikod.net>
When running as parser interpret BPF_LD | BPF_IMM | BPF_DW
instructions as loading CONST_IMM with the value stored
in imm. The verifier will continue not recognizing those
due to concerns about search space/program complexity
increase.
Signed-off-by: Jakub Kicinski <jakub.kicinski@netronome.com>
Advanced JIT compilers and translators may want to use
eBPF verifier as a base for parsers or to perform custom
checks and validations.
Add ability for external users to invoke the verifier
and provide callbacks to be invoked for every intruction
checked. For now only add most basic callback for
per-instruction pre-interpretation checks is added. More
advanced users may also like to have per-instruction post
callback and state comparison callback.
Move verifier's internal structures to a header file and
prefix their names with bpf_ to avoid potential namespace
conflicts. Those structures will soon be used by external
analyzers.
Storing state in reserved fields of instructions makes
it impossible to run verifier on programs already
marked as read-only. Allocate and use an array of
per-instruction state instead.
While touching the error path rename and move existing
jump target.
Suggested-by: Alexei Starovoitov <ast@kernel.org>
This work implements direct packet access for helpers and direct packet
write in a similar fashion as already available for XDP types via commits
4acf6c0b84c9 ("bpf: enable direct packet data write for xdp progs") and
6841de8b0d03 ("bpf: allow helpers access the packet directly"), and as a
complementary feature to the already available direct packet read for tc
(cls/act) programs.
For enabling this, we need to introduce two helpers, bpf_skb_pull_data()
and bpf_csum_update(). The first is generally needed for both, read and
write, because they would otherwise only be limited to the current linear
skb head. Usually, when the data_end test fails, programs just bail out,
or, in the direct read case, use bpf_skb_load_bytes() as an alternative
to overcome this limitation. If such data sits in non-linear parts, we
can just pull them in once with the new helper, retest and eventually
access them.
At the same time, this also makes sure the skb is uncloned, which is, of
course, a necessary condition for direct write. As this needs to be an
invariant for the write part only, the verifier detects writes and adds
a prologue that is calling bpf_skb_pull_data() to effectively unclone the
skb from the very beginning in case it is indeed cloned. The heuristic
makes use of a similar trick that was done in 233577a22089 ("net: filter:
constify detection of pkt_type_offset"). This comes at zero cost for other
programs that do not use the direct write feature. Should a program use
this feature only sparsely and has read access for the most parts with,
for example, drop return codes, then such write action can be delegated
to a tail called program for mitigating this cost of potential uncloning
to a late point in time where it would have been paid similarly with the
bpf_skb_store_bytes() as well. Advantage of direct write is that the
writes are inlined whereas the helper cannot make any length assumptions
and thus needs to generate a call to memcpy() also for small sizes, as well
as cost of helper call itself with sanity checks are avoided. Plus, when
direct read is already used, we don't need to cache or perform rechecks
on the data boundaries (due to verifier invalidating previous checks for
helpers that change skb->data), so more complex programs using rewrites
can benefit from switching to direct read plus write.
For direct packet access to helpers, we save the otherwise needed copy into
a temp struct sitting on stack memory when use-case allows. Both facilities
are enabled via may_access_direct_pkt_data() in verifier. For now, we limit
this to map helpers and csum_diff, and can successively enable other helpers
where we find it makes sense. Helpers that definitely cannot be allowed for
this are those part of bpf_helper_changes_skb_data() since they can change
underlying data, and those that write into memory as this could happen for
packet typed args when still cloned. bpf_csum_update() helper accommodates
for the fact that we need to fixup checksum_complete when using direct write
instead of bpf_skb_store_bytes(), meaning the programs can use available
helpers like bpf_csum_diff(), and implement csum_add(), csum_sub(),
csum_block_add(), csum_block_sub() equivalents in eBPF together with the
new helper. A usage example will be provided for iproute2's examples/bpf/
directory.
