Linux 3.1.9
Makefile
Change-Id: I22227ab33ba7ddaba8e6fe049393c58a83d73648
commit 0d19ea866562e46989412a0676412fa0983c9ce7 upstream.
If we mount a hierarchy with a specified name, the name is unique,
and we can use it to mount the hierarchy without specifying its
set of subsystem names. This feature is documented is
Documentation/cgroups/cgroups.txt section 2.3
Here's an example:
# mount -t cgroup -o cpuset,name=myhier xxx /cgroup1
# mount -t cgroup -o name=myhier xxx /cgroup2
But it was broken by commit 32a8cf235e2f192eb002755076994525cdbaa35a
(cgroup: make the mount options parsing more accurate)
This fixes the regression.
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
commit e0197aae59e55c06db172bfbe1a1cdb8c0e1cab3 upstream.
There is a BUG when migrating a PF_EXITING proc. Since css_set_prefetch()
is not called for the PF_EXITING case, find_existing_css_set() will return
NULL inside cgroup_task_migrate() causing a BUG.
This bug is easy to reproduce. Create a zombie and echo its pid to
cgroup.procs.
$ cat zombie.c
\#include <unistd.h>
int main()
if (fork())
pause();
return 0;
We are hitting this bug pretty regularly on ChromeOS.
This bug is already fixed by Tejun Heo's cgroup patchset which is
targetted for the next merge window:
https://lkml.org/lkml/2011/11/1/356
I've create a smaller patch here which just fixes this bug so that a
fix can be merged into the current release and stable.
Signed-off-by: Mandeep Singh Baines <msb@chromium.org>
Downstream-Bug-Report: http://crosbug.com/23953
Reviewed-by: Li Zefan <lizf@cn.fujitsu.com>
Cc: containers@lists.linux-foundation.org
Cc: cgroups@vger.kernel.org
Cc: Paul Menage <paul@paulmenage.org>
Cc: Olof Johansson <olofj@chromium.org>
Change-Id: I61bf2d48574d6ce5418b988e9547937c2efdd084
Reviewed-on: http://git-master/r/74185
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
cgroup.procs.
$ cat zombie.c
int main()
if (fork())
pause();
return 0;
Rather than using explicit euid == 0 checks when trying to move
tasks into a cgroup via CFS, move permission checks into each
specific cgroup subsystem. If a subsystem does not specify a
'allow_attach' handler, then we fall back to doing our checks
the old way.
Use the 'allow_attach' handler for the 'cpu' cgroup to allow
non-root processes to add arbitrary processes to a 'cpu' cgroup
if it has the CAP_SYS_NICE capability set.
This version of the patch adds a 'allow_attach' handler instead
of reusing the 'can_attach' handler. If the 'can_attach' handler
is reused, a new cgroup that implements 'can_attach' but not
the permission checks could end up with no permission checks
at all.
Change-Id: Icfa950aa9321d1ceba362061d32dc7dfa2c64f0c
Original-Author: San Mehat <san@google.com>
Signed-off-by: Colin Cross <ccross@android.com>
This reverts commit 1d38bc7d0523af2233b4280e2aeab34c6a076665.
Change-Id: I2c5066b696cbdd5ca117ed74718bcb7e70e878e7
synchronize_rcu can be very expensive, averaging 100 ms in
some cases. In cgroup_attach_task, it is used to prevent
a task->cgroups pointer dereferenced in an RCU read side
critical section from being invalidated, by delaying the
call to put_css_set until after an RCU grace period.
To avoid the call to synchronize_rcu, make the put_css_set
call rcu-safe by moving the deletion of the css_set links
into free_css_set_work, scheduled by the rcu callback
free_css_set_rcu.
The decrement of the cgroup refcount is no longer
synchronous with the call to put_css_set, which can result
in the cgroup refcount staying positive after the last call
to cgroup_attach_task returns. To allow the cgroup to be
deleted with cgroup_rmdir synchronously after
cgroup_attach_task, have rmdir check the refcount of all
associated css_sets. If cgroup_rmdir is called on a cgroup
for which the css_sets all have refcount zero but the
cgroup refcount is nonzero, reuse the rmdir waitqueue to
block the rmdir until free_css_set_work is called.
Changes the meaning of CGRP_RELEASABLE to be set on any cgroup
that has ever had a task or cgroup in it, or had css_get called
on it. The bit is set in cgroup_attach_task, cgroup_create,
and __css_get. It is not necessary to set the bit in
cgroup_fork, as the task is either in the root cgroup, in
which can never be released, or the task it was forked from
already set the bit in croup_attach_task.
'can_attach' handler, then we fall back to doing our checks the old way.
This way non-root processes can add arbitrary processes to
a cgroup if all the registered subsystems on that cgroup agree.
Also change explicit euid == 0 check to CAP_SYS_ADMIN
Signed-off-by: San Mehat <san@google.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (54 commits)
tpm_nsc: Fix bug when loading multiple TPM drivers
tpm: Move tpm_tis_reenable_interrupts out of CONFIG_PNP block
tpm: Fix compilation warning when CONFIG_PNP is not defined
TOMOYO: Update kernel-doc.
tpm: Fix a typo
tpm_tis: Probing function for Intel iTPM bug
tpm_tis: Fix the probing for interrupts
tpm_tis: Delay ACPI S3 suspend while the TPM is busy
tpm_tis: Re-enable interrupts upon (S3) resume
tpm: Fix display of data in pubek sysfs entry
tpm_tis: Add timeouts sysfs entry
tpm: Adjust interface timeouts if they are too small
tpm: Use interface timeouts returned from the TPM
tpm_tis: Introduce durations sysfs entry
tpm: Adjust the durations if they are too small
tpm: Use durations returned from TPM
TOMOYO: Enable conditional ACL.
TOMOYO: Allow using argv[]/envp[] of execve() as conditions.
TOMOYO: Allow using executable's realpath and symlink's target as conditions.
TOMOYO: Allow using owner/group etc. of file objects as conditions.
Fix up trivial conflict in security/tomoyo/realpath.c
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
fs: Merge split strings
treewide: fix potentially dangerous trailing ';' in #defined values/expressions
uwb: Fix misspelling of neighbourhood in comment
net, netfilter: Remove redundant goto in ebt_ulog_packet
trivial: don't touch files that are removed in the staging tree
lib/vsprintf: replace link to Draft by final RFC number
doc: Kconfig: `to be' -> `be'
doc: Kconfig: Typo: square -> squared
doc: Konfig: Documentation/power/{pm => apm-acpi}.txt
drivers/net: static should be at beginning of declaration
drivers/media: static should be at beginning of declaration
drivers/i2c: static should be at beginning of declaration
XTENSA: static should be at beginning of declaration
SH: static should be at beginning of declaration
MIPS: static should be at beginning of declaration
ARM: static should be at beginning of declaration
rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check
Update my e-mail address
PCIe ASPM: forcedly -> forcibly
gma500: push through device driver tree
Fix up trivial conflicts:
- arch/arm/mach-ep93xx/dma-m2p.c (deleted)
- drivers/gpio/gpio-ep93xx.c (renamed and context nearby)
- drivers/net/r8169.c (just context changes)
convert the last remaining caller to inode_permission()
Since ca5ecddf (rcu: define __rcu address space modifier for sparse)
rcu_dereference_check use rcu_read_lock_held as a part of condition
automatically so callers do not have to do that as well.
We recently found that in some configurations SELinux was blocking the ability
for cgroupfs to be mounted. The reason for this is because cgroupfs creates
files and directories during the get_sb() call and also uses lookup_one_len()
during that same get_sb() call. This is a problem since the security
subsystem cannot initialize the superblock and the inodes in that filesystem
until after the get_sb() call returns. Thus we leave the inodes in
an unitialized state during get_sb(). For the vast majority of filesystems
this is not an issue, but since cgroupfs uses lookup_on_len() it does
search permission checks on the directories in the path it walks. Since the
inode security state is not set up SELinux does these checks as if the inodes
were 'unlabeled.'
Many 'normal' userspace process do not have permission to interact with
unlabeled inodes. The solution presented here is to do the permission checks
of path walk and inode creation as the kernel rather than as the task that
called mount. Since the kernel has permission to read/write/create
unlabeled inodes the get_sb() call will complete successfully and the SELinux
code will be able to initialize the superblock and those inodes created during
the get_sb() call.
This appears to be the same solution used by other filesystems such as devtmpfs
to solve the same issue and should thus have no negative impact on other LSMs
which currently work.
Signed-off-by: Eric Paris <eparis@redhat.com>
Acked-by: Paul Menage <menage@google.com>
Signed-off-by: James Morris <jmorris@namei.org>
The ns_cgroup is an annoying cgroup at the namespace / cgroup frontier and
leads to some problems:
* cgroup creation is out-of-control
* cgroup name can conflict when pids are looping
* it is not possible to have a single process handling a lot of
namespaces without falling in a exponential creation time
* we may want to create a namespace without creating a cgroup
The ns_cgroup was replaced by a compatibility flag 'clone_children',
where a newly created cgroup will copy the parent cgroup values.
The userspace has to manually create a cgroup and add a task to
the 'tasks' file.
This patch removes the ns_cgroup as suggested in the following thread:
https://lists.linux-foundation.org/pipermail/containers/2009-June/018616.html
The 'cgroup_clone' function is removed because it is no longer used.
This is a userspace-visible change. Commit 45531757b45c ("cgroup: notify
ns_cgroup deprecated") (merged into 2.6.27) caused the kernel to emit a
printk warning users that the feature is planned for removal. Since that
time we have heard from XXX users who were affected by this.
Signed-off-by: Daniel Lezcano <daniel.lezcano@free.fr>
Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Jamal Hadi Salim <hadi@cyberus.ca>
Acked-by: Matt Helsley <matthltc@us.ibm.com>
Convert cgroup_attach_proc to use flex_array.
The cgroup_attach_proc implementation requires a pre-allocated array to
store task pointers to atomically move a thread-group, but asking for a
monolithic array with kmalloc() may be unreliable for very large groups.
Using flex_array provides the same functionality with less risk of
failure.
This is a post-patch for cgroup-procs-write.patch.
Signed-off-by: Ben Blum <bblum@andrew.cmu.edu>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Li Zefan <lizf@cn.fujitsu.com>
Cc: Matt Helsley <matthltc@us.ibm.com>
Reviewed-by: Paul Menage <menage@google.com>
Cc: Miao Xie <miaox@cn.fujitsu.com>
Make procs file writable to move all threads by tgid at once.
Add functionality that enables users to move all threads in a threadgroup
at once to a cgroup by writing the tgid to the 'cgroup.procs' file. This
current implementation makes use of a per-threadgroup rwsem that's taken
for reading in the fork() path to prevent newly forking threads within the
threadgroup from "escaping" while the move is in progress.
Add cgroup subsystem callbacks for per-thread attachment in atomic contexts
Add can_attach_task(), pre_attach(), and attach_task() as new callbacks
for cgroups's subsystem interface. Unlike can_attach and attach, these
are for per-thread operations, to be called potentially many times when
attaching an entire threadgroup.
Also, the old "bool threadgroup" interface is removed, as replaced by
this. All subsystems are modified for the new interface - of note is
cpuset, which requires from/to nodemasks for attach to be globally scoped
(though per-cpuset would work too) to persist from its pre_attach to
attach_task and attach.
This is a pre-patch for cgroup-procs-writable.patch.
The rcu callback __free_css_id_cb() just calls a kfree(),
so we use kfree_rcu() instead of the call_rcu(__free_css_id_cb).
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
The rcu callback free_cgroup_rcu() just calls a kfree(),
so we use kfree_rcu() instead of the call_rcu(free_cgroup_rcu).
The rcu callback free_css_set_rcu() just calls a kfree(),
so we use kfree_rcu() instead of the call_rcu(free_css_set_rcu).
list_del() leaves poison in the prev and next pointers. The next
list_empty() will compare those poisons, and say the list isn't empty.
Any list operations that assume the node is on a list because of such a
check will be fooled into dereferencing poison. One needs to INIT the
node after the del, and fortunately there's already a wrapper for that -
list_del_init().
Some of the dels are followed by deallocations, so can be ignored, and one
can be merged with an add to make a move. Apart from that, I erred on the
side of caution in making nodes list_empty()-queriable.
Signed-off-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
Acked-by: Kirill A. Shutemov <kirill@shutemov.name>
Cc: <stable@kernel.org>
This kernel patch adds the ability to filter monitoring based on
container groups (cgroups). This is for use in per-cpu mode only.
The cgroup to monitor is passed as a file descriptor in the pid
argument to the syscall. The file descriptor must be opened to
the cgroup name in the cgroup filesystem. For instance, if the
cgroup name is foo and cgroupfs is mounted in /cgroup, then the
file descriptor is opened to /cgroup/foo. Cgroup mode is
activated by passing PERF_FLAG_PID_CGROUP in the flags argument
to the syscall.
For instance to measure in cgroup foo on CPU1 assuming
cgroupfs is mounted under /cgroup:
struct perf_event_attr attr;
int cgroup_fd, fd;
cgroup_fd = open("/cgroup/foo", O_RDONLY);
fd = perf_event_open(&attr, cgroup_fd, 1, -1, PERF_FLAG_PID_CGROUP);
close(cgroup_fd);
Signed-off-by: Stephane Eranian <eranian@google.com>
[ added perf_cgroup_{exit,attach} ]
LKML-Reference: <4d590250.114ddf0a.689e.4482@mx.google.com>
Make the ::exit method act like ::attach, it is after all very nearly
the same thing.
The bug had no effect on correctness - fixing it is an optimization for
the scheduler. Also, later perf-cgroups patches rely on it.
LKML-Reference: <1297160655.13327.92.camel@laptop>
git://git.kernel.org/pub/scm/linux/kernel/git/npiggin/linux-npiggin
* 'vfs-scale-working' of git://git.kernel.org/pub/scm/linux/kernel/git/npiggin/linux-npiggin:
kernel: fix hlist_bl again
cgroups: Fix a lockdep warning at cgroup removal
fs: namei fix ->put_link on wrong inode in do_filp_open
cgroup can't use simple_lookup(), since that'd override its desired ->d_op.
Tested-by: Li Zefan <lizf@cn.fujitsu.com>
Commit 2fd6b7f5 ("fs: dcache scale subdirs") forgot to annotate a dentry
lock, which caused a lockdep warning.
Reported-by: Valdis Kletnieks <Valdis.Kletnieks@vt.edu>
switching it to s_d_op allows to kill the cgroup_lookup() kludge.
Reduce some branches and memory accesses in dcache lookup by adding dentry
flags to indicate common d_ops are set, rather than having to check them.
This saves a pointer memory access (dentry->d_op) in common path lookup
situations, and saves another pointer load and branch in cases where we
have d_op but not the particular operation.
Patched with:
git grep -E '[.>]([[:space:]])*d_op([[:space:]])*=' | xargs sed -e 's/\([^\t ]*\)->d_op = \(.*\);/d_set_d_op(\1, \2);/' -e 's/\([^\t ]*\)\.d_op = \(.*\);/d_set_d_op(\&\1, \2);/' -i
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
dget_locked was a shortcut to avoid the lazy lru manipulation when we already
held dcache_lock (lru manipulation was relatively cheap at that point).
However, how that the lru lock is an innermost one, we never hold it at any
caller, so the lock cost can now be avoided. We already have well working lazy
dcache LRU, so it should be fine to defer LRU manipulations to scan time.
dcache_lock no longer protects anything. remove it.
Protect d_subdirs and d_child with d_lock, except in filesystems that aren't
using dcache_lock for these anyway (eg. using i_mutex).
Note: if we change the locking rule in future so that ->d_child protection is
provided only with ->d_parent->d_lock, it may allow us to reduce some locking.
But it would be an exception to an otherwise regular locking scheme, so we'd
have to see some good results. Probably not worthwhile.
Make d_count non-atomic and protect it with d_lock. This allows us to ensure a
0 refcount dentry remains 0 without dcache_lock. It is also fairly natural when
we start protecting many other dentry members with d_lock.
Change d_delete from a dentry deletion notification to a dentry caching
advise, more like ->drop_inode. Require it to be constant and idempotent,
and not take d_lock. This is how all existing filesystems use the callback
anyway.
This makes fine grained dentry locking of dput and dentry lru scanning
much simpler.
Switching d_op on a live dentry is racy in general, so avoid it. In this case
it is a negative dentry, which is safer, but there are still concurrent ops
which may be called on d_op in that case (eg. d_revalidate). So in general
a filesystem may not do this. Fix cgroupfs so as not to do this.
Function "strcpy" is used without check for maximum allowed source string
length and could cause destination string overflow. Check for string
length is added before using "strcpy". Function now is return error if
source string length is more than a maximum.
akpm: presently considered NotABug, but add the check for general
future-safeness and robustness.
Signed-off-by: Evgeny Kuznetsov <EXT-Eugeny.Kuznetsov@nokia.com>
Current behavior:
(1) When we mount a cgroup, we can specify the 'all' option which
means to enable all the cgroup subsystems. This is the default option
when no option is specified.
(2) If we want to mount a cgroup with a subset of the supported cgroup
subsystems, we have to specify a subsystems name list for the mount
option.
(3) If we specify another option like 'noprefix' or 'release_agent',
the actual code wants the 'all' or a subsystem name option specified
also. Not critical but a bit not friendly as we should assume (1) in
this case.
(4) Logically, the 'all' option is mutually exclusive with a subsystem
name, but this is not detected.
In other words:
succeed : mount -t cgroup -o all,freezer cgroup /cgroup
=> is it 'all' or 'freezer' ?
fails : mount -t cgroup -o noprefix cgroup /cgroup
=> succeed if we do '-o noprefix,all'
The following patches consolidate a bit the mount options check.
New behavior:
(1) untouched
(2) untouched
(3) the 'all' option will be by default when specifying other than
(4) raises an error
In other words:
fails : mount -t cgroup -o all,freezer cgroup /cgroup
succeed : mount -t cgroup -o noprefix cgroup /cgroup
For the sake of lisibility, the if ... then ... else ... if ...
indentation when parsing the options has been changed to:
if ... then
continue
fi
Cc: Balbir Singh <balbir@linux.vnet.ibm.com>
The ns_cgroup is a control group interacting with the namespaces. When a
new namespace is created, a corresponding cgroup is automatically created
too. The cgroup name is the pid of the process who did 'unshare' or the
child of 'clone'.
This cgroup is tied with the namespace because it prevents a process to
escape the control group and use the post_clone callback, so the child
cgroup inherits the values of the parent cgroup.
Unfortunately, the more we use this cgroup and the more we are facing
problems with it:
(1) when a process unshares, the cgroup name may conflict with a
previous cgroup with the same pid, so unshare or clone return -EEXIST
(2) the cgroup creation is out of control because there may have an
application creating several namespaces where the system will
automatically create several cgroups in his back and let them on the
cgroupfs (eg. a vrf based on the network namespace).
(3) the mix of (1) and (2) force an administrator to regularly check
and clean these cgroups.
This patchset removes the ns_cgroup by adding a new flag to the cgroup and
the cgroupfs mount option. It enables the copy of the parent cgroup when
a child cgroup is created. We can then safely remove the ns_cgroup as
this flag brings a compatibility. We have now to manually create and add
the task to a cgroup, which is consistent with the cgroup framework.
This patch:
Sent as an answer to a previous thread around the ns_cgroup.
https://lists.linux-foundation.org/pipermail/containers/2009-June/018627.html
It adds a control file 'clone_children' for a cgroup. This control file
is a boolean specifying if the child cgroup should be a clone of the
parent cgroup or not. The default value is 'false'.
This flag makes the child cgroup to call the post_clone callback of all
the subsystem, if it is available.
At present, the cpuset is the only one which had implemented the
post_clone callback.
The option can be set at mount time by specifying the 'clone_children'
mount option.
Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Instead of always assigning an increasing inode number in new_inode
move the call to assign it into those callers that actually need it.
For now callers that need it is estimated conservatively, that is
the call is added to all filesystems that do not assign an i_ino
by themselves. For a few more filesystems we can avoid assigning
any inode number given that they aren't user visible, and for others
it could be done lazily when an inode number is actually needed,
but that's left for later patches.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
* 'vfs' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: (30 commits)
BKL: remove BKL from freevxfs
BKL: remove BKL from qnx4
autofs4: Only declare function when CONFIG_COMPAT is defined
autofs: Only declare function when CONFIG_COMPAT is defined
ncpfs: Lock socket in ncpfs while setting its callbacks
fs/locks.c: prepare for BKL removal
BKL: Remove BKL from ncpfs
BKL: Remove BKL from OCFS2
BKL: Remove BKL from squashfs
BKL: Remove BKL from jffs2
BKL: Remove BKL from ecryptfs
BKL: Remove BKL from afs
BKL: Remove BKL from USB gadgetfs
BKL: Remove BKL from autofs4
BKL: Remove BKL from isofs
BKL: Remove BKL from fat
BKL: Remove BKL from ext2 filesystem
BKL: Remove BKL from do_new_mount()
BKL: Remove BKL from cgroup
BKL: Remove BKL from NTFS
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-2.6-rcu into core/rcu
The BKL is only used in remount_fs and get_sb that are both protected by
the superblocks s_umount rw_semaphore. Therefore it is safe to remove the
BKL entirely.
Signed-off-by: Jan Blunck <jblunck@infradead.org>
This patch is a preparation necessary to remove the BKL from do_new_mount().
It explicitly adds calls to lock_kernel()/unlock_kernel() around
get_sb/fill_super operations for filesystems that still uses the BKL.
I've read through all the code formerly covered by the BKL inside
do_kern_mount() and have satisfied myself that it doesn't need the BKL
any more.
do_kern_mount() is already called without the BKL when mounting the rootfs
and in nfsctl. do_kern_mount() calls vfs_kern_mount(), which is called
from various places without BKL: simple_pin_fs(), nfs_do_clone_mount()
through nfs_follow_mountpoint(), afs_mntpt_do_automount() through
afs_mntpt_follow_link(). Both later functions are actually the filesystems
follow_link inode operation. vfs_kern_mount() is calling the specified
get_sb function and lets the filesystem do its job by calling the given
fill_super function.
Therefore I think it is safe to push down the BKL from the VFS to the
low-level filesystems get_sb/fill_super operation.
[arnd: do not add the BKL to those file systems that already
don't use it elsewhere]
Cc: Matthew Wilcox <matthew@wil.cx>
Add cgroup_attach_task_all()
The existing cgroup_attach_task_current_cg() API is called by a thread to
attach another thread to all of its cgroups; this is unsuitable for cases
where a privileged task wants to attach itself to the cgroups of a less
privileged one, since the call must be made from the context of the target
task.
This patch adds a more generic cgroup_attach_task_all() API that allows
both the source task and to-be-moved task to be specified.
cgroup_attach_task_current_cg() becomes a specialization of the more
generic new function.
[menage@google.com: rewrote changelog]
[akpm@linux-foundation.org: address reviewer comments]
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Tested-by: Alex Williamson <alex.williamson@redhat.com>
Cc: Ben Blum <bblum@google.com>
Cc: Sridhar Samudrala <sri@us.ibm.com>
The original code didn't leave enough space for a NULL terminator. These
strings are copied with strcpy() into fixed length buffers in
cgroup_root_from_opts().
Acked-by: Serge E. Hallyn <serge@hallyn.com>
Reviewd-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Paul Menage <menage@google.com>
Cc: Ben Blum <bblum@andrew.cmu.edu>
We really shouldn't be asking userspace to create new root filesystems.
So follow along with all of the other in-kernel filesystems, and provide
a mount point in sysfs.
For cgroupfs, this should be in /sys/fs/cgroup/ This change provides
that mount point when the cgroup filesystem is registered in the kernel.
Acked-by: Dhaval Giani <dhaval.giani@gmail.com>
Cc: Lennart Poettering <lennart@poettering.net>
Cc: Kay Sievers <kay.sievers@vrfy.org>
