path: root/kernel/cpu.c
2005-11-28[PATCH] clean up lock_cpu_hotplug() in cpufreqAshok Raj
There are some callers in cpufreq hotplug notify path that the lowest function calls lock_cpu_hotplug(). The lock is already held during cpu_up() and cpu_down() calls when the notify calls are broadcast to registered clients. Ideally if possible, we could disable_preempt() at the highest caller and make sure we dont sleep in the path down in cpufreq->driver_target() calls but the calls are so intertwined and cumbersome to cleanup. Hence we consistently use lock_cpu_hotplug() and unlock_cpu_hotplug() in all places. - Removed export of cpucontrol semaphore and made it static. - removed explicit uses of up/down with lock_cpu_hotplug() so we can keep track of the the callers in same thread context and just keep refcounts without calling a down() that causes a deadlock. - Removed current_in_hotplug() uses - Removed PF_HOTPLUG_CPU in sched.h introduced for the current_in_hotplug() temporary workaround. Tested with insmod of cpufreq_stat.ko, and logical online/offline to make sure we dont have any hang situations. Signed-off-by: Ashok Raj <ashok.raj@intel.com> Cc: Zwane Mwaikambo <zwane@linuxpower.ca> Cc: Shaohua Li <shaohua.li@intel.com> Cc: "Siddha, Suresh B" <suresh.b.siddha@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] cpu hotplug: fix locking in cpufreq driversAshok Raj
When calling target drivers to set frequency, we take cpucontrol lock. When we modified the code to accomodate CPU hotplug, there was an attempt to take a double lock of cpucontrol leading to a deadlock. Since the current thread context is already holding the cpucontrol lock, we dont need to make another attempt to acquire it. Now we leave a trace in current->flags indicating current thread already is under cpucontrol lock held, so we dont attempt to do this another time. Thanks to Andrew Morton for the beating:-) From: Brice Goglin <Brice.Goglin@ens-lyon.org> Build fix (akpm: this patch is still unpleasant. Ashok continues to look for a cleaner solution, doesn't he? ;)) Signed-off-by: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Brice Goglin <Brice.Goglin@ens-lyon.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] create and destroy cpufreq sysfs entries based on cpu notifiersAshok Raj
cpufreq entries in sysfs should only be populated when CPU is online state. When we either boot with maxcpus=x and then boot the other cpus by echoing to sysfs online file, these entries should be created and destroyed when CPU_DEAD is notified. Same treatement as cache entries under sysfs. We place the processor in the lowest frequency, so hw managed P-State transitions can still work on the other threads to save power. Primary goal was to just make these directories appear/disapper dynamically. There is one in this patch i had to do, which i really dont like myself but probably best if someone handling the cpufreq infrastructure could give this code right treatment if this is not acceptable. I guess its probably good for the first cut. - Converting lock_cpu_hotplug()/unlock_cpu_hotplug() to disable/enable preempt. The locking was smack in the middle of the notification path, when the hotplug is already holding the lock. I tried another solution to avoid this so avoid taking locks if we know we are from notification path. The solution was getting very ugly and i decided this was probably good for this iteration until someone who understands cpufreq could do a better job than me. (akpm: export cpucontrol to GPL modules: drivers/cpufreq/cpufreq_stats.c now does lock_cpu_hotplug()) Signed-off-by: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Dave Jones <davej@codemonkey.org.uk> Cc: Zwane Mwaikambo <zwane@holomorphy.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] i386 CPU hotplugZwane Mwaikambo
(The i386 CPU hotplug patch provides infrastructure for some work which Pavel is doing as well as for ACPI S3 (suspend-to-RAM) work which Li Shaohua <shaohua.li@intel.com> is doing) The following provides i386 architecture support for safely unregistering and registering processors during runtime, updated for the current -mm tree. In order to avoid dumping cpu hotplug code into kernel/irq/* i dropped the cpu_online check in do_IRQ() by modifying fixup_irqs(). The difference being that on cpu offline, fixup_irqs() is called before we clear the cpu from cpu_online_map and a long delay in order to ensure that we never have any queued external interrupts on the APICs. There are additional changes to s390 and ppc64 to account for this change. 1) Add CONFIG_HOTPLUG_CPU 2) disable local APIC timer on dead cpus. 3) Disable preempt around irq balancing to prevent CPUs going down. 4) Print irq stats for all possible cpus. 5) Debugging check for interrupts on offline cpus. 6) Hacky fixup_irqs() to redirect irqs when cpus go off/online. 7) play_dead() for offline cpus to spin inside. 8) Handle offline cpus set in flush_tlb_others(). 9) Grab lock earlier in smp_call_function() to prevent CPUs going down. 10) Implement __cpu_disable() and __cpu_die(). 11) Enable local interrupts in cpu_enable() after fixup_irqs() 12) Don't fiddle with NMI on dead cpu, but leave intact on other cpus. 13) Program IRQ affinity whilst cpu is still in cpu_online_map on offline. Signed-off-by: Zwane Mwaikambo <zwane@linuxpower.ca> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
