path: root/kernel/cpu.c
2014-06-11sched: Fix hotplug vs. set_cpus_allowed_ptr()Lai Jiangshan
commit 6acbfb96976fc3350e30d964acb1dbbdf876d55e upstream. Lai found that: WARNING: CPU: 1 PID: 13 at arch/x86/kernel/smp.c:124 native_smp_send_reschedule+0x2d/0x4b() ... migration_cpu_stop+0x1d/0x22 was caused by set_cpus_allowed_ptr() assuming that cpu_active_mask is always a sub-set of cpu_online_mask. This isn't true since 5fbd036b552f ("sched: Cleanup cpu_active madness"). So set active and online at the same time to avoid this particular problem. Fixes: 5fbd036b552f ("sched: Cleanup cpu_active madness") Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Gautham R. Shenoy <ego@linux.vnet.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michael wang <wangyun@linux.vnet.ibm.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Toshi Kani <toshi.kani@hp.com> Link: http://lkml.kernel.org/r/53758B12.8060609@cn.fujitsu.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-12CPU hotplug: provide a generic helper to disable/enable CPU hotplugSrivatsa S. Bhat
There are instances in the kernel where we would like to disable CPU hotplug (from sysfs) during some important operation. Today the freezer code depends on this and the code to do it was kinda tailor-made for that. Restructure the code and make it generic enough to be useful for other usecases too. Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Robin Holt <holt@sgi.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Russ Anderson <rja@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Shawn Guo <shawn.guo@linaro.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-19Merge branch 'smp-hotplug-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull preparatory smp/hotplug patches from Ingo Molnar: "Some early preparatory changes for the WIP hotplug rework by Thomas Gleixner." * 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: stop_machine: Use smpboot threads stop_machine: Store task reference in a separate per cpu variable smpboot: Allow selfparking per cpu threads
2013-02-14stop_machine: Use smpboot threadsThomas Gleixner
Use the smpboot thread infrastructure. Mark the stopper thread selfparking and park it after it has finished the take_cpu_down() work. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Arjan van de Veen <arjan@infradead.org> Cc: Paul Turner <pjt@google.com> Cc: Richard Weinberger <rw@linutronix.de> Cc: Magnus Damm <magnus.damm@gmail.com> Link: http://lkml.kernel.org/r/20130131120741.686315164@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-01-27cputime: Use accessors to read task cputime statsFrederic Weisbecker
This is in preparation for the full dynticks feature. While remotely reading the cputime of a task running in a full dynticks CPU, we'll need to do some extra-computation. This way we can account the time it spent tickless in userspace since its last cputime snapshot. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Li Zhong <zhong@linux.vnet.ibm.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de>
2012-12-11Merge branch 'x86-bsp-hotplug-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 BSP hotplug changes from Ingo Molnar: "This tree enables CPU#0 (the boot processor) to be onlined/offlined on x86, just like any other CPU. Enabled on Intel CPUs for now. Allowing this required the identification and fixing of latent CPU#0 assumptions (such as CPU#0 initializations, etc.) in the x86 architecture code, plus the identification of barriers to BSP-offlining, such as active PIC interrupts which can only be serviced on the BSP. It's behind a default-off option, and there's a debug option that allows the automatic testing of this feature. The motivation of this feature is to allow and prepare for true CPU-hotplug hardware support: recent changes to MCE support enable us to detect a deteriorating but not yet hard-failing L1/L2 cache on a CPU that could be soft-unplugged - or a failing L3 cache on a multi-socket system. Note that true hardware hot-plug is not yet fully enabled by this, because that requires a special platform wakeup sequence to be sent to the freshly powered up CPU#0. Future patches for this are planned, once such a platform exists. Chicken and egg" * 'x86-bsp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, topology: Debug CPU0 hotplug x86/i387.c: Initialize thread xstate only on CPU0 only once x86, hotplug: Handle retrigger irq by the first available CPU x86, hotplug: The first online processor saves the MTRR state x86, hotplug: During CPU0 online, enable x2apic, set_numa_node. x86, hotplug: Wake up CPU0 via NMI instead of INIT, SIPI, SIPI x86-32, hotplug: Add start_cpu0() entry point to head_32.S x86-64, hotplug: Add start_cpu0() entry point to head_64.S kernel/cpu.c: Add comment for priority in cpu_hotplug_pm_callback x86, hotplug, suspend: Online CPU0 for suspend or hibernate x86, hotplug: Support functions for CPU0 online/offline x86, topology: Don't offline CPU0 if any PIC irq can not be migrated out of it x86, Kconfig: Add config switch for CPU0 hotplug doc: Add x86 CPU0 online/offline feature
2012-11-15ACPI / processor: prevent cpu from becoming onlineYasuaki Ishimatsu
Even if acpi_processor_handle_eject() offlines cpu, there is a chance to online the cpu after that. So the patch closes the window by using get/put_online_cpus(). Why does the patch change _cpu_up() logic? The patch cares the race of hot-remove cpu and _cpu_up(). If the patch does not change it, there is the following race. hot-remove cpu | _cpu_up() ------------------------------------- ------------------------------------ call acpi_processor_handle_eject() | call cpu_down() | call get_online_cpus() | | call cpu_hotplug_begin() and stop here call arch_unregister_cpu() | call acpi_unmap_lsapic() | call put_online_cpus() | | start and continue _cpu_up() return acpi_processor_remove() | continue hot-remove the cpu | So _cpu_up() can continue to itself. And hot-remove cpu can also continue itself. If the patch changes _cpu_up() logic, the race disappears as below: hot-remove cpu | _cpu_up() ----------------------------------------------------------------------- call acpi_processor_handle_eject() | call cpu_down() | call get_online_cpus() | | call cpu_hotplug_begin() and stop here call arch_unregister_cpu() | call acpi_unmap_lsapic() | cpu's cpu_present is set | to false by set_cpu_present()| call put_online_cpus() | | start _cpu_up() | check cpu_present() and return -EINVAL return acpi_processor_remove() | continue hot-remove the cpu | Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Reviewed-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Reviewed-by: Toshi Kani <toshi.kani@hp.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-11-14kernel/cpu.c: Add comment for priority in cpu_hotplug_pm_callbackFenghua Yu
cpu_hotplug_pm_callback should have higher priority than bsp_pm_callback which depends on cpu_hotplug_pm_callback to disable cpu hotplug to avoid race during bsp online checking. This is to hightlight the priorities between the two callbacks in case people may overlook the order. Ideally the priorities should be defined in macro/enum instead of fixed values. To do that, a seperate patchset may be pushed which will touch serveral other generic files and is out of scope of this patchset. Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> Link: http://lkml.kernel.org/r/1352835171-3958-7-git-send-email-fenghua.yu@intel.com Reviewed-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2012-10-09CPU hotplug, debug: detect imbalance between get_online_cpus() and ↵Srivatsa S. Bhat
put_online_cpus() The synchronization between CPU hotplug readers and writers is achieved by means of refcounting, safeguarded by the cpu_hotplug.lock. get_online_cpus() increments the refcount, whereas put_online_cpus() decrements it. If we ever hit an imbalance between the two, we end up compromising the guarantees of the hotplug synchronization i.e, for example, an extra call to put_online_cpus() can end up allowing a hotplug reader to execute concurrently with a hotplug writer. So, add a WARN_ON() in put_online_cpus() to detect such cases where the refcount can go negative, and also attempt to fix it up, so that we can continue to run. Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Reviewed-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-01Merge branch 'x86-asm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86/asm changes from Ingo Molnar: "The one change that stands out is the alternatives patching change that prevents us from ever patching back instructions from SMP to UP: this simplifies things and speeds up CPU hotplug. Other than that it's smaller fixes, cleanups and improvements." * 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86: Unspaghettize do_trap() x86_64: Work around old GAS bug x86: Use REP BSF unconditionally x86: Prefer TZCNT over BFS x86/64: Adjust types of temporaries used by ffs()/fls()/fls64() x86: Drop unnecessary kernel_eflags variable on 64-bit x86/smp: Don't ever patch back to UP if we unplug cpus
2012-08-23x86/smp: Don't ever patch back to UP if we unplug cpusRusty Russell
We still patch SMP instructions to UP variants if we boot with a single CPU, but not at any other time. In particular, not if we unplug CPUs to return to a single cpu. Paul McKenney points out: mean offline overhead is 6251/48=130.2 milliseconds. If I remove the alternatives_smp_switch() from the offline path [...] the mean offline overhead is 550/42=13.1 milliseconds Basically, we're never going to get those 120ms back, and the code is pretty messy. We get rid of: 1) The "smp-alt-once" boot option. It's actually "smp-alt-boot", the documentation is wrong. It's now the default. 2) The skip_smp_alternatives flag used by suspend. 3) arch_disable_nonboot_cpus_begin() and arch_disable_nonboot_cpus_end() which were only used to set this one flag. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul McKenney <paul.mckenney@us.ibm.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/87vcgwwive.fsf@rustcorp.com.au Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-08-13smpboot: Provide infrastructure for percpu hotplug threadsThomas Gleixner
Provide a generic interface for setting up and tearing down percpu threads. On registration the threads for already online cpus are created and started. On deregistration (modules) the threads are stoppped. During hotplug operations the threads are created, started, parked and unparked. The datastructure for registration provides a pointer to percpu storage space and optional setup, cleanup, park, unpark functions. These functions are called when the thread state changes. Each implementation has to provide a function which is queried and returns whether the thread should run and the thread function itself. The core code handles all state transitions and avoids duplicated code in the call sites. [ paulmck: Preemption leak fix ] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Reviewed-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/20120716103948.352501068@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-07-31mm/hotplug: correctly setup fallback zonelists when creating new pgdatJiang Liu
When hotadd_new_pgdat() is called to create new pgdat for a new node, a fallback zonelist should be created for the new node. There's code to try to achieve that in hotadd_new_pgdat() as below: /* * The node we allocated has no zone fallback lists. For avoiding * to access not-initialized zonelist, build here. */ mutex_lock(&zonelists_mutex); build_all_zonelists(pgdat, NULL); mutex_unlock(&zonelists_mutex); But it doesn't work as expected. When hotadd_new_pgdat() is called, the new node is still in offline state because node_set_online(nid) hasn't been called yet. And build_all_zonelists() only builds zonelists for online nodes as: for_each_online_node(nid) { pg_data_t *pgdat = NODE_DATA(nid); build_zonelists(pgdat); build_zonelist_cache(pgdat); } Though we hope to create zonelist for the new pgdat, but it doesn't. So add a new parameter "pgdat" the build_all_zonelists() to build pgdat for the new pgdat too. Signed-off-by: Jiang Liu <liuj97@gmail.com> Signed-off-by: Xishi Qiu <qiuxishi@huawei.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Michal Hocko <mhocko@suse.cz> Cc: Minchan Kim <minchan@kernel.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Tony Luck <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Keping Chen <chenkeping@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-31kernel/cpu.c: document clear_tasks_mm_cpumask()Anton Vorontsov
Add more comments on clear_tasks_mm_cpumask, plus adds a runtime check: the function is only suitable for offlined CPUs, and if called inappropriately, the kernel should scream aloud. [akpm@linux-foundation.org: tweak comment: s/walks up/walks/, use 80 cols] Suggested-by: Andrew Morton <akpm@linux-foundation.org> Suggested-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Anton Vorontsov <anton.vorontsov@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-31cpu: introduce clear_tasks_mm_cpumask() helperAnton Vorontsov
Many architectures clear tasks' mm_cpumask like this: read_lock(&tasklist_lock); for_each_process(p) { if (p->mm) cpumask_clear_cpu(cpu, mm_cpumask(p->mm)); } read_unlock(&tasklist_lock); Depending on the context, the code above may have several problems, such as: 1. Working with task->mm w/o getting mm or grabing the task lock is dangerous as ->mm might disappear (exit_mm() assigns NULL under task_lock(), so tasklist lock is not enough). 2. Checking for process->mm is not enough because process' main thread may exit or detach its mm via use_mm(), but other threads may still have a valid mm. This patch implements a small helper function that does things correctly, i.e.: 1. We take the task's lock while whe handle its mm (we can't use get_task_mm()/mmput() pair as mmput() might sleep); 2. To catch exited main thread case, we use find_lock_task_mm(), which walks up all threads and returns an appropriate task (with task lock held). Also, Per Peter Zijlstra's idea, now we don't grab tasklist_lock in the new helper, instead we take the rcu read lock. We can do this because the function is called after the cpu is taken down and marked offline, so no new tasks will get this cpu set in their mm mask. Signed-off-by: Anton Vorontsov <anton.vorontsov@linaro.org> Cc: Richard Weinberger <richard@nod.at> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-03smp, idle: Allocate idle thread for each possible cpu during bootSuresh Siddha
percpu areas are already allocated during boot for each possible cpu. percpu idle threads can be considered as an extension of the percpu areas, and allocate them for each possible cpu during boot. This will eliminate the need for workqueue based idle thread allocation. In future we can move the idle thread area into the percpu area too. [ tglx: Moved the loop into smpboot.c and added an error check when the init code failed to allocate an idle thread for a cpu which should be onlined ] Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Tejun Heo <tj@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: venki@google.com Link: http://lkml.kernel.org/r/1334966930.28674.245.camel@sbsiddha-desk.sc.intel.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-26smp: Provide generic idle thread allocationThomas Gleixner
All SMP architectures have magic to fork the idle task and to store it for reusage when cpu hotplug is enabled. Provide a generic infrastructure for it. Create/reinit the idle thread for the cpu which is brought up in the generic code and hand the thread pointer to the architecture code via __cpu_up(). Note, that fork_idle() is called via a workqueue, because this guarantees that the idle thread does not get a reference to a user space VM. This can happen when the boot process did not bring up all possible cpus and a later cpu_up() is initiated via the sysfs interface. In that case fork_idle() would be called in the context of the user space task and take a reference on the user space VM. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: James E.J. Bottomley <jejb@parisc-linux.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: David S. Miller <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Richard Weinberger <richard@nod.at> Cc: x86@kernel.org Acked-by: Venkatesh Pallipadi <venki@google.com> Link: http://lkml.kernel.org/r/20120420124557.102478630@linutronix.de
2012-04-26smp: Add generic smpboot facilityThomas Gleixner
Start a new file, which will hold SMP and CPU hotplug related generic infrastructure. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: James E.J. Bottomley <jejb@parisc-linux.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: David S. Miller <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Richard Weinberger <richard@nod.at> Cc: x86@kernel.org Link: http://lkml.kernel.org/r/20120420124557.035417523@linutronix.de
2012-04-26smp: Add task_struct argument to __cpu_up()Thomas Gleixner
Preparatory patch to make the idle thread allocation for secondary cpus generic. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: James E.J. Bottomley <jejb@parisc-linux.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: David S. Miller <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Richard Weinberger <richard@nod.at> Cc: x86@kernel.org Link: http://lkml.kernel.org/r/20120420124556.964170564@linutronix.de
2012-01-08Merge branch 'pm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm * 'pm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (76 commits) PM / Hibernate: Implement compat_ioctl for /dev/snapshot PM / Freezer: fix return value of freezable_schedule_timeout_killable() PM / shmobile: Allow the A4R domain to be turned off at run time PM / input / touchscreen: Make st1232 use device PM QoS constraints PM / QoS: Introduce dev_pm_qos_add_ancestor_request() PM / shmobile: Remove the stay_on flag from SH7372's PM domains PM / shmobile: Don't include SH7372's INTCS in syscore suspend/resume PM / shmobile: Add support for the sh7372 A4S power domain / sleep mode PM: Drop generic_subsys_pm_ops PM / Sleep: Remove forward-only callbacks from AMBA bus type PM / Sleep: Remove forward-only callbacks from platform bus type PM: Run the driver callback directly if the subsystem one is not there PM / Sleep: Make pm_op() and pm_noirq_op() return callback pointers PM/Devfreq: Add Exynos4-bus device DVFS driver for Exynos4210/4212/4412. PM / Sleep: Merge internal functions in generic_ops.c PM / Sleep: Simplify generic system suspend callbacks PM / Hibernate: Remove deprecated hibernation snapshot ioctls PM / Sleep: Fix freezer failures due to racy usermodehelper_is_disabled() ARM: S3C64XX: Implement basic power domain support PM / shmobile: Use common always on power domain governor ... Fix up trivial conflict in fs/xfs/xfs_buf.c due to removal of unused XBT_FORCE_SLEEP bit
2012-01-06Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (40 commits) sched/tracing: Add a new tracepoint for sleeptime sched: Disable scheduler warnings during oopses sched: Fix cgroup movement of waking process sched: Fix cgroup movement of newly created process sched: Fix cgroup movement of forking process sched: Remove cfs bandwidth period check in tg_set_cfs_period() sched: Fix load-balance lock-breaking sched: Replace all_pinned with a generic flags field sched: Only queue remote wakeups when crossing cache boundaries sched: Add missing rcu_dereference() around ->real_parent usage [S390] fix cputime overflow in uptime_proc_show [S390] cputime: add sparse checking and cleanup sched: Mark parent and real_parent as __rcu sched, nohz: Fix missing RCU read lock sched, nohz: Set the NOHZ_BALANCE_KICK flag for idle load balancer sched, nohz: Fix the idle cpu check in nohz_idle_balance sched: Use jump_labels for sched_feat sched/accounting: Fix parameter passing in task_group_account_field sched/accounting: Fix user/system tick double accounting sched/accounting: Re-use scheduler statistics for the root cgroup ... Fix up conflicts in - arch/ia64/include/asm/cputime.h, include/asm-generic/cputime.h usecs_to_cputime64() vs the sparse cleanups - kernel/sched/fair.c, kernel/time/tick-sched.c scheduler changes in multiple branches
2011-12-15[S390] cputime: add sparse checking and cleanupMartin Schwidefsky
Make cputime_t and cputime64_t nocast to enable sparse checking to detect incorrect use of cputime. Drop the cputime macros for simple scalar operations. The conversion macros are still needed. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-12-12cpu: Export cpu_up()Paul E. McKenney
Building rcutorture as a module requires cpu_up() as well as cpu_down() exported, so apply EXPORT_SYMBOL_GPL(). Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2011-11-23CPU: Add right qualifiers for alloc_frozen_cpus() and cpu_hotplug_pm_sync_init()Fenghua Yu
Add __init for functions alloc_frozen_cpus() and cpu_hotplug_pm_sync_init() because they are only called during boot time. Add static for function cpu_hotplug_pm_sync_init() because its scope is limited in this file only. Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> Acked-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-11-04PM / Sleep: Fix race between CPU hotplug and freezerSrivatsa S. Bhat
The CPU hotplug notifications sent out by the _cpu_up() and _cpu_down() functions depend on the value of the 'tasks_frozen' argument passed to them (which indicates whether tasks have been frozen or not). (Examples for such CPU hotplug notifications: CPU_ONLINE, CPU_ONLINE_FROZEN, CPU_DEAD, CPU_DEAD_FROZEN). Thus, it is essential that while the callbacks for those notifications are running, the state of the system with respect to the tasks being frozen or not remains unchanged, *throughout that duration*. Hence there is a need for synchronizing the CPU hotplug code with the freezer subsystem. Since the freezer is involved only in the Suspend/Hibernate call paths, this patch hooks the CPU hotplug code to the suspend/hibernate notifiers PM_[SUSPEND|HIBERNATE]_PREPARE and PM_POST_[SUSPEND|HIBERNATE] to prevent the race between CPU hotplug and freezer, thus ensuring that CPU hotplug notifications will always be run with the state of the system really being what the notifications indicate, _throughout_ their execution time. Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-10-31kernel: Map most files to use export.h instead of module.hPaul Gortmaker
The changed files were only including linux/module.h for the EXPORT_SYMBOL infrastructure, and nothing else. Revector them onto the isolated export header for faster compile times. Nothing to see here but a whole lot of instances of: -#include <linux/module.h> +#include <linux/export.h> This commit is only changing the kernel dir; next targets will probably be mm, fs, the arch dirs, etc. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-03-22kernel/cpu.c: fix many errors related to style.Michael Rodriguez
Change the printk() calls to have the KERN_INFO/KERN_ERROR stuff, and fixes other coding style errors. Not _all_ of them are gone, though. [akpm@linux-foundation.org: revert the bits I disagree with] Signed-off-by: Michael Rodriguez <dkingston02@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-06Merge branches 'x86-alternatives-for-linus', 'x86-fpu-for-linus', ↵Linus Torvalds
'x86-hwmon-for-linus', 'x86-paravirt-for-linus', 'core-locking-for-linus' and 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-alternatives-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, suspend: Avoid unnecessary smp alternatives switch during suspend/resume * 'x86-fpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86-64, asm: Use fxsaveq/fxrestorq in more places * 'x86-hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, hwmon: Add core threshold notification to therm_throt.c * 'x86-paravirt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, paravirt: Use native_halt on a halt, not native_safe_halt * 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: locking, lockdep: Convert sprintf_symbol to %pS * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: irq: Better struct irqaction layout
2010-12-13x86, suspend: Avoid unnecessary smp alternatives switch during suspend/resumeSuresh Siddha
During suspend, we disable all the non boot cpus. And during resume we bring them all back again. So no need to do alternatives_smp_switch() in between. On my core 2 based laptop, this speeds up the suspend path by 15msec and the resume path by 5 msec (suspend/resume speed up differences can be attributed to the different P-states that the cpu is in during suspend/resume). Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> LKML-Reference: <1290557500.4946.8.camel@sbsiddha-MOBL3.sc.intel.com> Cc: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-11-23cpu: Remove incorrect BUG_ONPeter Zijlstra
Oleg mentioned that there is no actual guarantee the dying cpu's migration thread is actually finished running when we get there, so replace the BUG_ON() with a spinloop waiting for it. Reported-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-11-23cpu: Remove unused variableDhaval Giani
GCC warns us about: kernel/cpu.c: In function ‘take_cpu_down’: kernel/cpu.c:200:15: warning: unused variable ‘cpu’ This variable is unused since param->hcpu is directly used later on in cpu_notify. Signed-off-by: Dhaval Giani <dhaval_giani@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1290091494.1145.5.camel@gondor.retis> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-11-18sched: Simplify cpu-hot-unplug task migrationPeter Zijlstra
While discussing the need for sched_idle_next(), Oleg remarked that since try_to_wake_up() ensures sleeping tasks will end up running on a sane cpu, we can do away with migrate_live_tasks(). If we then extend the existing hack of migrating current from CPU_DYING to migrating the full rq worth of tasks from CPU_DYING, the need for the sched_idle_next() abomination disappears as well, since idle will be the only possible thread left after the migration thread stops. This greatly simplifies the hot-unplug task migration path, as can be seen from the resulting code reduction (and about half the new lines are comments). Suggested-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1289851597.2109.547.camel@laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-06-08sched: adjust when cpu_active and cpuset configurations are updated during ↵Tejun Heo
cpu on/offlining Currently, when a cpu goes down, cpu_active is cleared before CPU_DOWN_PREPARE starts and cpuset configuration is updated from a default priority cpu notifier. When a cpu is coming up, it's set before CPU_ONLINE but cpuset configuration again is updated from the same cpu notifier. For cpu notifiers, this presents an inconsistent state. Threads which a CPU_DOWN_PREPARE notifier expects to be bound to the CPU can be migrated to other cpus because the cpu is no more inactive. Fix it by updating cpu_active in the highest priority cpu notifier and cpuset configuration in the second highest when a cpu is coming up. Down path is updated similarly. This guarantees that all other cpu notifiers see consistent cpu_active and cpuset configuration. cpuset_track_online_cpus() notifier is converted to cpuset_update_active_cpus() which just updates the configuration and now called from cpuset_cpu_[in]active() notifiers registered from sched_init_smp(). If cpuset is disabled, cpuset_update_active_cpus() degenerates into partition_sched_domains() making separate notifier for !CONFIG_CPUSETS unnecessary. This problem is triggered by cmwq. During CPU_DOWN_PREPARE, hotplug callback creates a kthread and kthread_bind()s it to the target cpu, and the thread is expected to run on that cpu. * Ingo's test discovered __cpuinit/exit markups were incorrect. Fixed. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Menage <menage@google.com>
2010-06-01fix cpu_chain section mismatch...Daniel J Blueman
In commit e9fb7631ebcd ("cpu-hotplug: introduce cpu_notify(), __cpu_notify(), cpu_notify_nofail()") the new helper functions access cpu_chain. As a result, it shouldn't be marked __cpuinitdata (via section mismatch warning). Alternatively, the helper functions should be forced inline, or marked __ref or __cpuinit. In the meantime, this patch silences the warning the trivial way. Signed-off-by: Daniel J Blueman <daniel.blueman@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-30CPU: Avoid using unititialized error variable in disable_nonboot_cpus()Rafael J. Wysocki
If there's only one CPU online when disable_nonboot_cpus() is called, the error variable will not be initialized and that may lead to erroneous behavior. Fix this issue by initializing error in disable_nonboot_cpus() as appropriate. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27Avoid warning when CPU hotplug isn't enabledLinus Torvalds
Commit e9fb7631ebcd ("cpu-hotplug: introduce cpu_notify(), __cpu_notify(), cpu_notify_nofail()") also introduced this annoying warning: kernel/cpu.c:157: warning: 'cpu_notify_nofail' defined but not used when CONFIG_HOTPLUG_CPU wasn't set. So move that helper inside the #ifdef CONFIG_HOTPLUG_CPU region, and simplify it while at it. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27cpuhotplug: do not need cpu_hotplug_begin() when CONFIG_HOTPLUG_CPU=nLai Jiangshan
Since when CONFIG_HOTPLUG_CPU=n, get_online_cpus() do nothing, so we don't need cpu_hotplug_begin() either. This patch moves cpu_hotplug_begin()/cpu_hotplug_done() into the code block of CONFIG_HOTPLUG_CPU=y. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Gautham R Shenoy <ego@in.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27cpu-hotplug: return better errno on cpu hotplug failureAkinobu Mita
Currently, onlining or offlining a CPU failure by one of the cpu notifiers error always cause -EINVAL error. (i.e. writing 0 or 1 to /sys/devices/system/cpu/cpuX/online gets EINVAL) To get better error reporting rather than always getting -EINVAL, This changes cpu_notify() to return -errno value with notifier_to_errno() and fix the callers. Now that cpu notifiers can return encapsulate errno value. Currently, all cpu hotplug notifiers return NOTIFY_OK, NOTIFY_BAD, or NOTIFY_DONE. So cpu_notify() can returns 0 or -EPERM with this change for now. (notifier_to_errno(NOTIFY_OK) == 0, notifier_to_errno(NOTIFY_DONE) == 0, notifier_to_errno(NOTIFY_BAD) == -EPERM) Forthcoming patches convert several cpu notifiers to return encapsulate errno value with notifier_from_errno(). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27cpu-hotplug: introduce cpu_notify(), __cpu_notify(), cpu_notify_nofail()Akinobu Mita
No functional change. These are just wrappers of raw_cpu_notifier_call_chain. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25mem-hotplug: fix potential race while building zonelist for new populated zoneHaicheng Li
Add global mutex zonelists_mutex to fix the possible race: CPU0 CPU1 CPU2 (1) zone->present_pages += online_pages; (2) build_all_zonelists(); (3) alloc_page(); (4) free_page(); (5) build_all_zonelists(); (6) __build_all_zonelists(); (7) zone->pageset = alloc_percpu(); In step (3,4), zone->pageset still points to boot_pageset, so bad things may happen if 2+ nodes are in this state. Even if only 1 node is accessing the boot_pageset, (3) may still consume too much memory to fail the memory allocations in step (7). Besides, atomic operation ensures alloc_percpu() in step (7) will never fail since there is a new fresh memory block added in step(6). [haicheng.li@linux.intel.com: hold zonelists_mutex when build_all_zonelists] Signed-off-by: Haicheng Li <haicheng.li@linux.intel.com> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Reviewed-by: Andi Kleen <andi.kleen@intel.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25mem-hotplug: avoid multiple zones sharing same boot strapping boot_pagesetHaicheng Li
For each new populated zone of hotadded node, need to update its pagesets with dynamically allocated per_cpu_pageset struct for all possible CPUs: 1) Detach zone->pageset from the shared boot_pageset at end of __build_all_zonelists(). 2) Use mutex to protect zone->pageset when it's still shared in onlined_pages() Otherwises, multiple zones of different nodes would share same boot strapping boot_pageset for same CPU, which will finally cause below kernel panic: ------------[ cut here ]------------ kernel BUG at mm/page_alloc.c:1239! invalid opcode: 0000 [#1] SMP ... Call Trace: [<ffffffff811300c1>] __alloc_pages_nodemask+0x131/0x7b0 [<ffffffff81162e67>] alloc_pages_current+0x87/0xd0 [<ffffffff81128407>] __page_cache_alloc+0x67/0x70 [<ffffffff811325f0>] __do_page_cache_readahead+0x120/0x260 [<ffffffff81132751>] ra_submit+0x21/0x30 [<ffffffff811329c6>] ondemand_readahead+0x166/0x2c0 [<ffffffff81132ba0>] page_cache_async_readahead+0x80/0xa0 [<ffffffff8112a0e4>] generic_file_aio_read+0x364/0x670 [<ffffffff81266cfa>] nfs_file_read+0xca/0x130 [<ffffffff8117b20a>] do_sync_read+0xfa/0x140 [<ffffffff8117bf75>] vfs_read+0xb5/0x1a0 [<ffffffff8117c151>] sys_read+0x51/0x80 [<ffffffff8103c032>] system_call_fastpath+0x16/0x1b RIP [<ffffffff8112ff13>] get_page_from_freelist+0x883/0x900 RSP <ffff88000d1e78a8> ---[ end trace 4bda28328b9990db ] [akpm@linux-foundation.org: merge fix] Signed-off-by: Haicheng Li <haicheng.li@linux.intel.com> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Reviewed-by: Andi Kleen <andi.kleen@intel.com> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25cpu/mem hotplug: enable CPUs online before local memory onlineminskey guo
Enable users to online CPUs even if the CPUs belongs to a numa node which doesn't have onlined local memory. The zonlists(pg_data_t.node_zonelists[]) of a numa node are created either in system boot/init period, or at the time of local memory online. For a numa node without onlined local memory, its zonelists are not initialized at present. As a result, any memory allocation operations executed by CPUs within this node will fail. In fact, an out-of-memory error is triggered when attempt to online CPUs before memory comes to online. This patch tries to create zonelists for such numa nodes, so that the memory allocation for this node can be fallback'ed to other nodes. [akpm@linux-foundation.org: remove unneeded export] [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: minskey guo<chaohong.guo@intel.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-06stop_machine: reimplement using cpu_stopTejun Heo
Reimplement stop_machine using cpu_stop. As cpu stoppers are guaranteed to be available for all online cpus, stop_machine_create/destroy() are no longer necessary and removed. With resource management and synchronization handled by cpu_stop, the new implementation is much simpler. Asking the cpu_stop to execute the stop_cpu() state machine on all online cpus with cpu hotplug disabled is enough. stop_machine itself doesn't need to manage any global resources anymore, so all per-instance information is rolled into struct stop_machine_data and the mutex and all static data variables are removed. The previous implementation created and destroyed RT workqueues as necessary which made stop_machine() calls highly expensive on very large machines. According to Dimitri Sivanich, preventing the dynamic creation/destruction makes booting faster more than twice on very large machines. cpu_stop resources are preallocated for all online cpus and should have the same effect. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Dimitri Sivanich <sivanich@sgi.com>
2010-04-15Merge branch 'linus' into sched/coreIngo Molnar
Merge reason: merge the latest fixes, update to -rc4. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-02sched: _cpu_down(): Don't play with current->cpus_allowedOleg Nesterov
_cpu_down() changes the current task's affinity and then recovers it at the end. The problems are well known: we can't restore old_allowed if it was bound to the now-dead-cpu, and we can race with the userspace which can change cpu-affinity during unplug. _cpu_down() should not play with current->cpus_allowed at all. Instead, take_cpu_down() can migrate the caller of _cpu_down() after __cpu_disable() removes the dying cpu from cpu_online_mask. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20100315091023.GA9148@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-06kernel/cpu.c: delete deprecated definition in cpu_up()Chen Gong
Additional_cpus is only supported for IA64 now. X86_64 should not be included. Signed-off-by: Chen Gong <gong.chen@linux.intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-28sched: Correct printk whitespace in warning from cpu down task checkFrans Pop
Due to an incorrect line break the output currently contains tabs. Also remove trailing space. The actual output that logcheck sent me looked like this: Task events/1 (pid = 10) is on cpu 1^I^I^I^I(state = 1, flags = 84208040) After this patch it becomes: Task events/1 (pid = 10) is on cpu 1 (state = 1, flags = 84208040) Signed-off-by: Frans Pop <elendilplanet.nl> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <201001251456.34996.elendil@planet.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
