path: root/kernel/cpuset.c
2013-02-20Merge branch 'for-3.9-cpuset' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cpuset changes from Tejun Heo: - Synchornization has seen a lot of changes with focus on decoupling cpuset synchronization from cgroup internal locking. After this change, there only remain a couple of mostly trivial dependencies on cgroup_lock outside cgroup core proper. cgroup_lock is scheduled to be unexported in this devel cycle. This will finally remove the fragile locking order around cgroup (cgroup locking wants to / should be one of the outermost but yet has been acquired from deep inside individual controllers). - At this point, Li is most knowlegeable with cpuset and taking over the maintainership of cpuset. * 'for-3.9-cpuset' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: cpuset: drop spurious retval assignment in proc_cpuset_show() cpuset: fix RCU lockdep splat cpuset: update MAINTAINERS cpuset: remove cpuset->parent cpuset: replace cpuset->stack_list with cpuset_for_each_descendant_pre() cpuset: replace cgroup_mutex locking with cpuset internal locking cpuset: schedule hotplug propagation from cpuset_attach() if the cpuset is empty cpuset: pin down cpus and mems while a task is being attached cpuset: make CPU / memory hotplug propagation asynchronous cpuset: drop async_rebuild_sched_domains() cpuset: don't nest cgroup_mutex inside get_online_cpus() cpuset: reorganize CPU / memory hotplug handling cpuset: cleanup cpuset[_can]_attach() cpuset: introduce cpuset_for_each_child() cpuset: introduce CS_ONLINE cpuset: introduce ->css_on/offline() cpuset: remove fast exit path from remove_tasks_in_empty_cpuset() cpuset: remove unused cpuset_unlock()
2013-02-18cpuset: fix cpuset_print_task_mems_allowed() vs rename() raceLi Zefan
rename() will change dentry->d_name. The result of this race can be worse than seeing partially rewritten name, but we might access a stale pointer because rename() will re-allocate memory to hold a longer name. It's safe in the protection of dentry->d_lock. v2: check NULL dentry before acquiring dentry lock. Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable@vger.kernel.org
2013-01-15cpuset: drop spurious retval assignment in proc_cpuset_show()Li Zefan
proc_cpuset_show() has a spurious -EINVAL assignment which does nothing. Remove it. This patch doesn't make any functional difference. tj: Rewrote patch description. Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-01-15cpuset: fix RCU lockdep splatLi Zefan
5d21cc2db040d01f8c19b8602f6987813e1176b4 ("cpuset: replace cgroup_mutex locking with cpuset internal locking") incorrectly converted proc_cpuset_show() from cgroup_lock() to cpuset_mutex. proc_cpuset_show() is accessing cgroup hierarchy proper to determine cgroup path which can't be protected by cpuset_mutex. This triggered the following RCU warning. =============================== [ INFO: suspicious RCU usage. ] 3.8.0-rc3-next-20130114-sasha-00016-ga107525-dirty #262 Tainted: G W ------------------------------- include/linux/cgroup.h:534 suspicious rcu_dereference_check() usage! other info that might help us debug this: rcu_scheduler_active = 1, debug_locks = 1 2 locks held by trinity/7514: #0: (&p->lock){+.+.+.}, at: [<ffffffff812b06aa>] seq_read+0x3a/0x3e0 #1: (cpuset_mutex){+.+...}, at: [<ffffffff811abae4>] proc_cpuset_show+0x84/0x190 stack backtrace: Pid: 7514, comm: trinity Tainted: G W +3.8.0-rc3-next-20130114-sasha-00016-ga107525-dirty #262 Call Trace: [<ffffffff81182cab>] lockdep_rcu_suspicious+0x10b/0x120 [<ffffffff811abb71>] proc_cpuset_show+0x111/0x190 [<ffffffff812b0827>] seq_read+0x1b7/0x3e0 [<ffffffff812b0670>] ? seq_lseek+0x110/0x110 [<ffffffff8128b4fb>] do_loop_readv_writev+0x4b/0x90 [<ffffffff8128b776>] do_readv_writev+0xf6/0x1d0 [<ffffffff8128b8ee>] vfs_readv+0x3e/0x60 [<ffffffff8128b960>] sys_readv+0x50/0xd0 [<ffffffff83d33d18>] tracesys+0xe1/0xe6 The operation can be performed under RCU read lock. Replace cpuset_mutex locking with RCU read locking. tj: Rewrote patch description. Reported-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-01-07cpuset: remove cpuset->parentTejun Heo
cgroup already tracks the hierarchy. Follow cgroup->parent to find the parent and drop cpuset->parent. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Michal Hocko <mhocko@suse.cz> Acked-by: Li Zefan <lizefan@huawei.com>
2013-01-07cpuset: replace cpuset->stack_list with cpuset_for_each_descendant_pre()Tejun Heo
Implement cpuset_for_each_descendant_pre() and replace the cpuset-specific tree walking using cpuset->stack_list with it. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Michal Hocko <mhocko@suse.cz> Acked-by: Li Zefan <lizefan@huawei.com>
2013-01-07cpuset: replace cgroup_mutex locking with cpuset internal lockingTejun Heo
Supposedly for historical reasons, cpuset depends on cgroup core for locking. It depends on cgroup_mutex in cgroup callbacks and grabs cgroup_mutex from other places where it wants to be synchronized. This is majorly messy and highly prone to introducing circular locking dependency especially because cgroup_mutex is supposed to be one of the outermost locks. As previous patches already plugged possible races which may happen by decoupling from cgroup_mutex, replacing cgroup_mutex with cpuset specific cpuset_mutex is mostly straight-forward. Introduce cpuset_mutex, replace all occurrences of cgroup_mutex with it, and add cpuset_mutex locking to places which inherited cgroup_mutex from cgroup core. The only complication is from cpuset wanting to initiate task migration when a cpuset loses all cpus or memory nodes. Task migration may go through full cgroup and all subsystem locking and should be initiated without holding any cpuset specific lock; however, a previous patch already made hotplug handled asynchronously and moving the task migration part outside other locks is easy. cpuset_propagate_hotplug_workfn() now invokes remove_tasks_in_empty_cpuset() without holding any lock. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2013-01-07cpuset: schedule hotplug propagation from cpuset_attach() if the cpuset is emptyTejun Heo
cpuset is scheduled to be decoupled from cgroup_lock which will make hotplug handling race with task migration. cpus or mems will be allowed to go offline between ->can_attach() and ->attach(). If hotplug takes down all cpus or mems of a cpuset while attach is in progress, ->attach() may end up putting tasks into an empty cpuset. This patchset makes ->attach() schedule hotplug propagation if the cpuset is empty after attaching is complete. This will move the tasks to the nearest ancestor which can execute and the end result would be as if hotplug handling happened after the tasks finished attaching. cpuset_write_resmask() now also flushes cpuset_propagate_hotplug_wq to wait for propagations scheduled directly by cpuset_attach(). This currently doesn't make any functional difference as everything is protected by cgroup_mutex but enables decoupling the locking. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2013-01-07cpuset: pin down cpus and mems while a task is being attachedTejun Heo
cpuset is scheduled to be decoupled from cgroup_lock which will make configuration updates race with task migration. Any config update will be allowed to happen between ->can_attach() and ->attach(). If such config update removes either all cpus or mems, by the time ->attach() is called, the condition verified by ->can_attach(), that the cpuset is capable of hosting the tasks, is no longer true. This patch adds cpuset->attach_in_progress which is incremented from ->can_attach() and decremented when the attach operation finishes either successfully or not. validate_change() treats cpusets w/ non-zero ->attach_in_progress like cpusets w/ tasks and refuses to remove all cpus or mems from it. This currently doesn't make any functional difference as everything is protected by cgroup_mutex but enables decoupling the locking. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2013-01-07cpuset: make CPU / memory hotplug propagation asynchronousTejun Heo
cpuset_hotplug_workfn() has been invoking cpuset_propagate_hotplug() directly to propagate hotplug updates to !root cpusets; however, this has the following problems. * cpuset locking is scheduled to be decoupled from cgroup_mutex, cgroup_mutex will be unexported, and cgroup_attach_task() will do cgroup locking internally, so propagation can't synchronously move tasks to a parent cgroup while walking the hierarchy. * We can't use cgroup generic tree iterator because propagation to each cpuset may sleep. With propagation done asynchronously, we can lose the rather ugly cpuset specific iteration. Convert cpuset_propagate_hotplug() to cpuset_propagate_hotplug_workfn() and execute it from newly added cpuset->hotplug_work. The work items are run on an ordered workqueue, so the propagation order is preserved. cpuset_hotplug_workfn() schedules all propagations while holding cgroup_mutex and waits for completion without cgroup_mutex. Each in-flight propagation holds a reference to the cpuset->css. This patch doesn't cause any functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2013-01-07cpuset: drop async_rebuild_sched_domains()Tejun Heo
In general, we want to make cgroup_mutex one of the outermost locks and be able to use get_online_cpus() and friends from cgroup methods. With cpuset hotplug made async, get_online_cpus() can now be nested inside cgroup_mutex. Currently, cpuset avoids nesting get_online_cpus() inside cgroup_mutex by bouncing sched_domain rebuilding to a work item. As such nesting is allowed now, remove the workqueue bouncing code and always rebuild sched_domains synchronously. This also nests sched_domains_mutex inside cgroup_mutex, which is intended and should be okay. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2013-01-07cpuset: don't nest cgroup_mutex inside get_online_cpus()Tejun Heo
CPU / memory hotplug path currently grabs cgroup_mutex from hotplug event notifications. We want to separate cpuset locking from cgroup core and make cgroup_mutex outer to hotplug synchronization so that, among other things, mechanisms which depend on get_online_cpus() can be used from cgroup callbacks. In general, we want to keep cgroup_mutex the outermost lock to minimize locking interactions among different controllers. Convert cpuset_handle_hotplug() to cpuset_hotplug_workfn() and schedule it from the hotplug notifications. As the function can already handle multiple mixed events without any input, converting it to a work function is mostly trivial; however, one complication is that cpuset_update_active_cpus() needs to update sched domains synchronously to reflect an offlined cpu to avoid confusing the scheduler. This is worked around by falling back to the the default single sched domain synchronously before scheduling the actual hotplug work. This makes sched domain rebuilt twice per CPU hotplug event but the operation isn't that heavy and a lot of the second operation would be noop for systems w/ single sched domain, which is the common case. This decouples cpuset hotplug handling from the notification callbacks and there can be an arbitrary delay between the actual event and updates to cpusets. Scheduler and mm can handle it fine but moving tasks out of an empty cpuset may race against writes to the cpuset restoring execution resources which can lead to confusing behavior. Flush hotplug work item from cpuset_write_resmask() to avoid such confusions. v2: Synchronous sched domain rebuilding using the fallback sched domain added. This fixes various issues caused by confused scheduler putting tasks on a dead CPU, including the one reported by Li Zefan. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2013-01-07cpuset: reorganize CPU / memory hotplug handlingTejun Heo
Reorganize hotplug path to prepare for async hotplug handling. * Both CPU and memory hotplug handlings are collected into a single function - cpuset_handle_hotplug(). It doesn't take any argument but compares the current setttings of top_cpuset against what's actually available to determine what happened. This function directly updates top_cpuset. If there are CPUs or memory nodes which are taken down, cpuset_propagate_hotplug() in invoked on all !root cpusets. * cpuset_propagate_hotplug() is responsible for updating the specified cpuset so that it doesn't include any resource which isn't available to top_cpuset. If no CPU or memory is left after update, all tasks are moved to the nearest ancestor with both resources. * update_tasks_cpumask() and update_tasks_nodemask() are now always called after cpus or mems masks are updated even if the cpuset doesn't have any task. This is for brevity and not expected to have any measureable effect. * cpu_active_mask and N_HIGH_MEMORY are read exactly once per cpuset_handle_hotplug() invocation, all cpusets share the same view of what resources are available, and cpuset_handle_hotplug() can handle multiple resources going up and down. These properties will allow async operation. The reorganization, while drastic, is equivalent and shouldn't cause any behavior difference. This will enable making hotplug handling async and remove get_online_cpus() -> cgroup_mutex nesting. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2013-01-07cpuset: cleanup cpuset[_can]_attach()Tejun Heo
cpuset_can_attach() prepare global variables cpus_attach and cpuset_attach_nodemask_{to|from} which are used by cpuset_attach(). There is no reason to prepare in cpuset_can_attach(). The same information can be accessed from cpuset_attach(). Move the prepartion logic from cpuset_can_attach() to cpuset_attach() and make the global variables static ones inside cpuset_attach(). With this change, there's no reason to keep cpuset_attach_nodemask_{from|to} global. Move them inside cpuset_attach(). Unfortunately, we need to keep cpus_attach global as it can't be allocated from cpuset_attach(). v2: cpus_attach not converted to cpumask_t as per Li Zefan and Rusty Russell. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com> Cc: Rusty Russell <rusty@rustcorp.com.au>
2013-01-07cpuset: introduce cpuset_for_each_child()Tejun Heo
Instead of iterating cgroup->children directly, introduce and use cpuset_for_each_child() which wraps cgroup_for_each_child() and performs online check. As it uses the generic iterator, it requires RCU read locking too. As cpuset is currently protected by cgroup_mutex, non-online cpusets aren't visible to all the iterations and this patch currently doesn't make any functional difference. This will be used to de-couple cpuset locking from cgroup core. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2013-01-07cpuset: introduce CS_ONLINETejun Heo
Add CS_ONLINE which is set from css_online() and cleared from css_offline(). This will enable using generic cgroup iterator while allowing decoupling cpuset from cgroup internal locking. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2013-01-07cpuset: introduce ->css_on/offline()Tejun Heo
Add cpuset_css_on/offline() and rearrange css init/exit such that, * Allocation and clearing to the default values happen in css_alloc(). Allocation now uses kzalloc(). * Config inheritance and registration happen in css_online(). * css_offline() undoes what css_online() did. * css_free() frees. This doesn't introduce any visible behavior changes. This will help cleaning up locking. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2013-01-07cpuset: remove fast exit path from remove_tasks_in_empty_cpuset()Tejun Heo
The function isn't that hot, the overhead of missing the fast exit is low, the test itself depends heavily on cgroup internals, and it's gonna be a hindrance when trying to decouple cpuset locking from cgroup core. Remove the fast exit path. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2013-01-07cpuset: remove unused cpuset_unlock()Tejun Heo
2012-12-12cpuset: use N_MEMORY instead N_HIGH_MEMORYLai Jiangshan
N_HIGH_MEMORY stands for the nodes that has normal or high memory. N_MEMORY stands for the nodes that has any memory. The code here need to handle with the nodes which have memory, we should use N_MEMORY instead. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: Hillf Danton <dhillf@gmail.com> Signed-off-by: Wen Congyang <wency@cn.fujitsu.com> Cc: Christoph Lameter <cl@linux.com> Cc: Lin Feng <linfeng@cn.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-11-19cgroup, cpuset: remove cgroup_subsys->post_clone()Tejun Heo
Currently CGRP_CPUSET_CLONE_CHILDREN triggers ->post_clone(). Now that clone_children is cpuset specific, there's no reason to have this rather odd option activation mechanism in cgroup core. cpuset can check the flag from its ->css_allocate() and take the necessary action. Move cpuset_post_clone() logic to the end of cpuset_css_alloc() and remove cgroup_subsys->post_clone(). Loosely based on Glauber's "generalize post_clone into post_create" patch. Signed-off-by: Tejun Heo <tj@kernel.org> Original-patch-by: Glauber Costa <glommer@parallels.com> Original-patch: <1351686554-22592-2-git-send-email-glommer@parallels.com> Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com> Acked-by: Li Zefan <lizefan@huawei.com> Cc: Glauber Costa <glommer@parallels.com>
2012-11-19cgroup: rename ->create/post_create/pre_destroy/destroy() to ↵Tejun Heo
->css_alloc/online/offline/free() Rename cgroup_subsys css lifetime related callbacks to better describe what their roles are. Also, update documentation. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2012-07-24cpusets: Remove/update outdated commentsSrivatsa S. Bhat
cpuset_track_online_cpus() is no longer present. So remove the outdated comment and replace it with reference to cpuset_update_active_cpus() which is its equivalent. Also, we don't lack memory hot-unplug anymore. And David Rientjes pointed out how it is dealt with. So update that comment as well. Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20120524141700.3692.98192.stgit@srivatsabhat.in.ibm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-07-24cpusets, hotplug: Restructure functions that are invoked during hotplugSrivatsa S. Bhat
Separate out the cpuset related handling for CPU/Memory online/offline. This also helps us exploit the most obvious and basic level of optimization that any notification mechanism (CPU/Mem online/offline) has to offer us: "We *know* why we have been invoked. So stop pretending that we are lost, and do only the necessary amount of processing!". And while at it, rename scan_for_empty_cpusets() to scan_cpusets_upon_hotplug(), which is more appropriate considering how it is restructured. Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20120524141650.3692.48637.stgit@srivatsabhat.in.ibm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-07-24cpusets, hotplug: Implement cpuset tree traversal in a helper functionSrivatsa S. Bhat
At present, the functions that deal with cpusets during CPU/Mem hotplug are quite messy, since a lot of the functionality is mixed up without clear separation. And this takes a toll on optimization as well. For example, the function cpuset_update_active_cpus() is called on both CPU offline and CPU online events; and it invokes scan_for_empty_cpusets(), which makes sense only for CPU offline events. And hence, the current code ends up unnecessarily traversing the cpuset tree during CPU online also. As a first step towards cleaning up those functions, encapsulate the cpuset tree traversal in a helper function, so as to facilitate upcoming changes. Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20120524141635.3692.893.stgit@srivatsabhat.in.ibm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-07-24CPU hotplug, cpusets, suspend: Don't modify cpusets during suspend/resumeSrivatsa S. Bhat
In the event of CPU hotplug, the kernel modifies the cpusets' cpus_allowed masks as and when necessary to ensure that the tasks belonging to the cpusets have some place (online CPUs) to run on. And regular CPU hotplug is destructive in the sense that the kernel doesn't remember the original cpuset configurations set by the user, across hotplug operations. However, suspend/resume (which uses CPU hotplug) is a special case in which the kernel has the responsibility to restore the system (during resume), to exactly the same state it was in before suspend. In order to achieve that, do the following: 1. Don't modify cpusets during suspend/resume. At all. In particular, don't move the tasks from one cpuset to another, and don't modify any cpuset's cpus_allowed mask. So, simply ignore cpusets during the CPU hotplug operations that are carried out in the suspend/resume path. 2. However, cpusets and sched domains are related. We just want to avoid altering cpusets alone. So, to keep the sched domains updated, build a single sched domain (containing all active cpus) during each of the CPU hotplug operations carried out in s/r path, effectively ignoring the cpusets' cpus_allowed masks. (Since userspace is frozen while doing all this, it will go unnoticed.) 3. During the last CPU online operation during resume, build the sched domains by looking up the (unaltered) cpusets' cpus_allowed masks. That will bring back the system to the same original state as it was in before suspend. Ultimately, this will not only solve the cpuset problem related to suspend resume (ie., restores the cpusets to exactly what it was before suspend, by not touching it at all) but also speeds up suspend/resume because we avoid running cpuset update code for every CPU being offlined/onlined. Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20120524141611.3692.20155.stgit@srivatsabhat.in.ibm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-05-22Merge branch 'for-3.5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup updates from Tejun Heo: "cgroup file type addition / removal is updated so that file types are added and removed instead of individual files so that dynamic file type addition / removal can be implemented by cgroup and used by controllers. blkio controller changes which will come through block tree are dependent on this. Other changes include res_counter cleanup and disallowing kthread / PF_THREAD_BOUND threads to be attached to non-root cgroups. There's a reported bug with the file type addition / removal handling which can lead to oops on cgroup umount. The issue is being looked into. It shouldn't cause problems for most setups and isn't a security concern." Fix up trivial conflict in Documentation/feature-removal-schedule.txt * 'for-3.5' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (21 commits) res_counter: Account max_usage when calling res_counter_charge_nofail() res_counter: Merge res_counter_charge and res_counter_charge_nofail cgroups: disallow attaching kthreadd or PF_THREAD_BOUND threads cgroup: remove cgroup_subsys->populate() cgroup: get rid of populate for memcg cgroup: pass struct mem_cgroup instead of struct cgroup to socket memcg cgroup: make css->refcnt clearing on cgroup removal optional cgroup: use negative bias on css->refcnt to block css_tryget() cgroup: implement cgroup_rm_cftypes() cgroup: introduce struct cfent cgroup: relocate __d_cgrp() and __d_cft() cgroup: remove cgroup_add_file[s]() cgroup: convert memcg controller to the new cftype interface memcg: always create memsw files if CONFIG_CGROUP_MEM_RES_CTLR_SWAP cgroup: convert all non-memcg controllers to the new cftype interface cgroup: relocate cftype and cgroup_subsys definitions in controllers cgroup: merge cft_release_agent cftype array into the base files array cgroup: implement cgroup_add_cftypes() and friends cgroup: build list of all cgroups under a given cgroupfs_root cgroup: move cgroup_clear_directory() call out of cgroup_populate_dir() ...
2012-04-02Merge tag 'for-linus' of git://github.com/rustyrussell/linuxLinus Torvalds
Pull cpumask cleanups from Rusty Russell: "(Somehow forgot to send this out; it's been sitting in linux-next, and if you don't want it, it can sit there another cycle)" I'm a sucker for things that actually delete lines of code. Fix up trivial conflict in arch/arm/kernel/kprobes.c, where Rusty fixed a user of &cpu_online_map to be cpu_online_mask, but that code got deleted by commit b21d55e98ac2 ("ARM: 7332/1: extract out code patch function from kprobes"). * tag 'for-linus' of git://github.com/rustyrussell/linux: cpumask: remove old cpu_*_map. documentation: remove references to cpu_*_map. drivers/cpufreq/db8500-cpufreq: remove references to cpu_*_map. remove references to cpu_*_map in arch/
2012-04-01cgroup: convert all non-memcg controllers to the new cftype interfaceTejun Heo
Convert debug, freezer, cpuset, cpu_cgroup, cpuacct, net_prio, blkio, net_cls and device controllers to use the new cftype based interface. Termination entry is added to cftype arrays and populate callbacks are replaced with cgroup_subsys->base_cftypes initializations. This is functionally identical transformation. There shouldn't be any visible behavior change. memcg is rather special and will be converted separately. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <paul@paulmenage.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Vivek Goyal <vgoyal@redhat.com>
2012-03-29Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar. * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: cpusets: Remove an unused variable sched/rt: Improve pick_next_highest_task_rt() sched: Fix select_fallback_rq() vs cpu_active/cpu_online sched/x86/smp: Do not enable IRQs over calibrate_delay() sched: Fix compiler warning about declared inline after use MAINTAINERS: Update email address for SCHEDULER and PERF EVENTS
2012-03-29documentation: remove references to cpu_*_map.Rusty Russell
This has been obsolescent for a while, fix documentation and misc comments. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-03-28cpusets: Remove an unused variableDan Carpenter
We don't use "cpu" any more after 2baab4e904 "sched: Fix select_fallback_rq() vs cpu_active/cpu_online". Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: Paul Menage <paul@paulmenage.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20120328104608.GD29022@elgon.mountain Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-03-27sched: Fix select_fallback_rq() vs cpu_active/cpu_onlinePeter Zijlstra
Commit 5fbd036b55 ("sched: Cleanup cpu_active madness"), which was supposed to finally sort the cpu_active mess, instead uncovered more. Since CPU_STARTING is ran before setting the cpu online, there's a (small) window where the cpu has active,!online. If during this time there's a wakeup of a task that used to reside on that cpu select_task_rq() will use select_fallback_rq() to compute an alternative cpu to run on since we find !online. select_fallback_rq() however will compute the new cpu against cpu_active, this means that it can return the same cpu it started out with, the !online one, since that cpu is in fact marked active. This results in us trying to scheduling a task on an offline cpu and triggering a WARN in the IPI code. The solution proposed by Chuansheng Liu of setting cpu_active in set_cpu_online() is buggy, firstly not all archs actually use set_cpu_online(), secondly, not all archs call set_cpu_online() with IRQs disabled, this means we would introduce either the same race or the race from fd8a7de17 ("x86: cpu-hotplug: Prevent softirq wakeup on wrong CPU") -- albeit much narrower. [ By setting online first and active later we have a window of online,!active, fresh and bound kthreads have task_cpu() of 0 and since cpu0 isn't in tsk_cpus_allowed() we end up in select_fallback_rq() which excludes !active, resulting in a reset of ->cpus_allowed and the thread running all over the place. ] The solution is to re-work select_fallback_rq() to require active _and_ online. This makes the active,!online case work as expected, OTOH archs running CPU_STARTING after setting online are now vulnerable to the issue from fd8a7de17 -- these are alpha and blackfin. Reported-by: Chuansheng Liu <chuansheng.liu@intel.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Frysinger <vapier@gentoo.org> Cc: linux-alpha@vger.kernel.org Link: http://lkml.kernel.org/n/tip-hubqk1i10o4dpvlm06gq7v6j@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-03-21cpuset: mm: reduce large amounts of memory barrier related damage v3Mel Gorman
Commit c0ff7453bb5c ("cpuset,mm: fix no node to alloc memory when changing cpuset's mems") wins a super prize for the largest number of memory barriers entered into fast paths for one commit. [get|put]_mems_allowed is incredibly heavy with pairs of full memory barriers inserted into a number of hot paths. This was detected while investigating at large page allocator slowdown introduced some time after 2.6.32. The largest portion of this overhead was shown by oprofile to be at an mfence introduced by this commit into the page allocator hot path. For extra style points, the commit introduced the use of yield() in an implementation of what looks like a spinning mutex. This patch replaces the full memory barriers on both read and write sides with a sequence counter with just read barriers on the fast path side. This is much cheaper on some architectures, including x86. The main bulk of the patch is the retry logic if the nodemask changes in a manner that can cause a false failure. While updating the nodemask, a check is made to see if a false failure is a risk. If it is, the sequence number gets bumped and parallel allocators will briefly stall while the nodemask update takes place. In a page fault test microbenchmark, oprofile samples from __alloc_pages_nodemask went from 4.53% of all samples to 1.15%. The actual results were 3.3.0-rc3 3.3.0-rc3 rc3-vanilla nobarrier-v2r1 Clients 1 UserTime 0.07 ( 0.00%) 0.08 (-14.19%) Clients 2 UserTime 0.07 ( 0.00%) 0.07 ( 2.72%) Clients 4 UserTime 0.08 ( 0.00%) 0.07 ( 3.29%) Clients 1 SysTime 0.70 ( 0.00%) 0.65 ( 6.65%) Clients 2 SysTime 0.85 ( 0.00%) 0.82 ( 3.65%) Clients 4 SysTime 1.41 ( 0.00%) 1.41 ( 0.32%) Clients 1 WallTime 0.77 ( 0.00%) 0.74 ( 4.19%) Clients 2 WallTime 0.47 ( 0.00%) 0.45 ( 3.73%) Clients 4 WallTime 0.38 ( 0.00%) 0.37 ( 1.58%) Clients 1 Flt/sec/cpu 497620.28 ( 0.00%) 520294.53 ( 4.56%) Clients 2 Flt/sec/cpu 414639.05 ( 0.00%) 429882.01 ( 3.68%) Clients 4 Flt/sec/cpu 257959.16 ( 0.00%) 258761.48 ( 0.31%) Clients 1 Flt/sec 495161.39 ( 0.00%) 517292.87 ( 4.47%) Clients 2 Flt/sec 820325.95 ( 0.00%) 850289.77 ( 3.65%) Clients 4 Flt/sec 1020068.93 ( 0.00%) 1022674.06 ( 0.26%) MMTests Statistics: duration Sys Time Running Test (seconds) 135.68 132.17 User+Sys Time Running Test (seconds) 164.2 160.13 Total Elapsed Time (seconds) 123.46 120.87 The overall improvement is small but the System CPU time is much improved and roughly in correlation to what oprofile reported (these performance figures are without profiling so skew is expected). The actual number of page faults is noticeably improved. For benchmarks like kernel builds, the overall benefit is marginal but the system CPU time is slightly reduced. To test the actual bug the commit fixed I opened two terminals. The first ran within a cpuset and continually ran a small program that faulted 100M of anonymous data. In a second window, the nodemask of the cpuset was continually randomised in a loop. Without the commit, the program would fail every so often (usually within 10 seconds) and obviously with the commit everything worked fine. With this patch applied, it also worked fine so the fix should be functionally equivalent. Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Miao Xie <miaox@cn.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Christoph Lameter <cl@linux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-02cgroup: remove cgroup_subsys argument from callbacksLi Zefan
The argument is not used at all, and it's not necessary, because a specific callback handler of course knows which subsys it belongs to. Now only ->pupulate() takes this argument, because the handlers of this callback always call cgroup_add_file()/cgroup_add_files(). So we reduce a few lines of code, though the shrinking of object size is minimal. 16 files changed, 113 insertions(+), 162 deletions(-) text data bss dec hex filename 5486240 656987 7039960 13183187 c928d3 vmlinux.o.orig 5486170 656987 7039960 13183117 c9288d vmlinux.o Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2012-01-09Merge branch 'for-3.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup * 'for-3.3' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (21 commits) cgroup: fix to allow mounting a hierarchy by name cgroup: move assignement out of condition in cgroup_attach_proc() cgroup: Remove task_lock() from cgroup_post_fork() cgroup: add sparse annotation to cgroup_iter_start() and cgroup_iter_end() cgroup: mark cgroup_rmdir_waitq and cgroup_attach_proc() as static cgroup: only need to check oldcgrp==newgrp once cgroup: remove redundant get/put of task struct cgroup: remove redundant get/put of old css_set from migrate cgroup: Remove unnecessary task_lock before fetching css_set on migration cgroup: Drop task_lock(parent) on cgroup_fork() cgroups: remove redundant get/put of css_set from css_set_check_fetched() resource cgroups: remove bogus cast cgroup: kill subsys->can_attach_task(), pre_attach() and attach_task() cgroup, cpuset: don't use ss->pre_attach() cgroup: don't use subsys->can_attach_task() or ->attach_task() cgroup: introduce cgroup_taskset and use it in subsys->can_attach(), cancel_attach() and attach() cgroup: improve old cgroup handling in cgroup_attach_proc() cgroup: always lock threadgroup during migration threadgroup: extend threadgroup_lock() to cover exit and exec threadgroup: rename signal->threadgroup_fork_lock to ->group_rwsem ... Fix up conflict in kernel/cgroup.c due to commit e0197aae59e5: "cgroups: fix a css_set not found bug in cgroup_attach_proc" that already mentioned that the bug is fixed (differently) in Tejun's cgroup patchset. This one, in other words.
2011-12-20cpusets: stall when updating mems_allowed for mempolicy or disjoint nodemaskDavid Rientjes
Kernels where MAX_NUMNODES > BITS_PER_LONG may temporarily see an empty nodemask in a tsk's mempolicy if its previous nodemask is remapped onto a new set of allowed cpuset nodes where the two nodemasks, as a result of the remap, are now disjoint. c0ff7453bb5c ("cpuset,mm: fix no node to alloc memory when changing cpuset's mems") adds get_mems_allowed() to prevent the set of allowed nodes from changing for a thread. This causes any update to a set of allowed nodes to stall until put_mems_allowed() is called. This stall is unncessary, however, if at least one node remains unchanged in the update to the set of allowed nodes. This was addressed by 89e8a244b97e ("cpusets: avoid looping when storing to mems_allowed if one node remains set"), but it's still possible that an empty nodemask may be read from a mempolicy because the old nodemask may be remapped to the new nodemask during rebind. To prevent this, only avoid the stall if there is no mempolicy for the thread being changed. This is a temporary solution until all reads from mempolicy nodemasks can be guaranteed to not be empty without the get_mems_allowed() synchronization. Also moves the check for nodemask intersection inside task_lock() so that tsk->mems_allowed cannot change. This ensures that nothing can set this tsk's mems_allowed out from under us and also protects tsk->mempolicy. Reported-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Paul Menage <paul@paulmenage.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-12-12cgroup, cpuset: don't use ss->pre_attach()Tejun Heo
->pre_attach() is supposed to be called before migration, which is observed during process migration but task migration does it the other way around. The only ->pre_attach() user is cpuset which can do the same operaitons in ->can_attach(). Collapse cpuset_pre_attach() into cpuset_can_attach(). -v2: Patch contamination from later patch removed. Spotted by Paul Menage. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Paul Menage <paul@paulmenage.org> Cc: Li Zefan <lizf@cn.fujitsu.com>
2011-12-12cgroup: don't use subsys->can_attach_task() or ->attach_task()Tejun Heo
Now that subsys->can_attach() and attach() take @tset instead of @task, they can handle per-task operations. Convert ->can_attach_task() and ->attach_task() users to use ->can_attach() and attach() instead. Most converions are straight-forward. Noteworthy changes are, * In cgroup_freezer, remove unnecessary NULL assignments to unused methods. It's useless and very prone to get out of sync, which already happened. * In cpuset, PF_THREAD_BOUND test is checked for each task. This doesn't make any practical difference but is conceptually cleaner. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <paul@paulmenage.org> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: James Morris <jmorris@namei.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org>
2011-12-12cgroup: introduce cgroup_taskset and use it in subsys->can_attach(), ↵Tejun Heo
cancel_attach() and attach() Currently, there's no way to pass multiple tasks to cgroup_subsys methods necessitating the need for separate per-process and per-task methods. This patch introduces cgroup_taskset which can be used to pass multiple tasks and their associated cgroups to cgroup_subsys methods. Three methods - can_attach(), cancel_attach() and attach() - are converted to use cgroup_taskset. This unifies passed parameters so that all methods have access to all information. Conversions in this patchset are identical and don't introduce any behavior change. -v2: documentation updated as per Paul Menage's suggestion. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Paul Menage <paul@paulmenage.org> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: James Morris <jmorris@namei.org>
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-11-02cpusets: avoid looping when storing to mems_allowed if one node remains setDavid Rientjes
{get,put}_mems_allowed() exist so that general kernel code may locklessly access a task's set of allowable nodes without having the chance that a concurrent write will cause the nodemask to be empty on configurations where MAX_NUMNODES > BITS_PER_LONG. This could incur a significant delay, however, especially in low memory conditions because the page allocator is blocking and reclaim requires get_mems_allowed() itself. It is not atypical to see writes to cpuset.mems take over 2 seconds to complete, for example. In low memory conditions, this is problematic because it's one of the most imporant times to change cpuset.mems in the first place! The only way a task's set of allowable nodes may change is through cpusets by writing to cpuset.mems and when attaching a task to a generic code is not reading the nodemask with get_mems_allowed() at the same time, and then clearing all the old nodes. This prevents the possibility that a reader will see an empty nodemask at the same time the writer is storing a new nodemask. If at least one node remains unchanged, though, it's possible to simply set all new nodes and then clear all the old nodes. Changing a task's nodemask is protected by cgroup_mutex so it's guaranteed that two threads are not changing the same task's nodemask at the same time, so the nodemask is guaranteed to be stored before another thread changes it and determines whether a node remains set or not. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Miao Xie <miaox@cn.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Paul Menage <paul@paulmenage.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31kernel: Map most files to use export.h instead of module.hPaul Gortmaker
The changed files were only including linux/module.h for the EXPORT_SYMBOL infrastructure, and nothing else. Revector them onto the isolated export header for faster compile times. Nothing to see here but a whole lot of instances of: -#include <linux/module.h> +#include <linux/export.h> This commit is only changing the kernel dir; next targets will probably be mm, fs, the arch dirs, etc. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26cpusets: randomize node rotor used in cpuset_mem_spread_node()Michal Hocko
[ This patch has already been accepted as commit 0ac0c0d0f837 but later reverted (commit 35926ff5fba8) because it itroduced arch specific __node_random which was defined only for x86 code so it broke other archs. This is a followup without any arch specific code. Other than that there are no functional changes.] Some workloads that create a large number of small files tend to assign too many pages to node 0 (multi-node systems). Part of the reason is that the rotor (in cpuset_mem_spread_node()) used to assign nodes starts at node 0 for newly created tasks. This patch changes the rotor to be initialized to a random node number of the cpuset. [akpm@linux-foundation.org: fix layout] [Lee.Schermerhorn@hp.com: Define stub numa_random() for !NUMA configuration] [mhocko@suse.cz: Make it arch independent] [akpm@linux-foundation.org: fix CONFIG_NUMA=y, MAX_NUMNODES>1 build] Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Michal Hocko <mhocko@suse.cz> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Paul Menage <menage@google.com> Cc: Jack Steiner <steiner@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: David Rientjes <rientjes@google.com> Cc: Jack Steiner <steiner@sgi.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Paul Menage <menage@google.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Robin Holt <holt@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-28cpuset: Fix cpuset_cpus_allowed_fallback(), don't update tsk->rt.nr_cpus_allowedKOSAKI Motohiro
The rule is, we have to update tsk->rt.nr_cpus_allowed if we change tsk->cpus_allowed. Otherwise RT scheduler may confuse. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/4DD4B3FA.5060901@jp.fujitsu.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-05-26cgroup: remove the ns_cgroupDaniel Lezcano
The ns_cgroup is an annoying cgroup at the namespace / cgroup frontier and leads to some problems: * cgroup creation is out-of-control * cgroup name can conflict when pids are looping * it is not possible to have a single process handling a lot of namespaces without falling in a exponential creation time * we may want to create a namespace without creating a cgroup The ns_cgroup was replaced by a compatibility flag 'clone_children', where a newly created cgroup will copy the parent cgroup values. The userspace has to manually create a cgroup and add a task to the 'tasks' file. This patch removes the ns_cgroup as suggested in the following thread: https://lists.linux-foundation.org/pipermail/containers/2009-June/018616.html The 'cgroup_clone' function is removed because it is no longer used. This is a userspace-visible change. Commit 45531757b45c ("cgroup: notify ns_cgroup deprecated") (merged into 2.6.27) caused the kernel to emit a printk warning users that the feature is planned for removal. Since that time we have heard from XXX users who were affected by this. Signed-off-by: Daniel Lezcano <daniel.lezcano@free.fr> Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Jamal Hadi Salim <hadi@cyberus.ca> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Acked-by: Matt Helsley <matthltc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26cgroups: add per-thread subsystem callbacksBen Blum
Add cgroup subsystem callbacks for per-thread attachment in atomic contexts Add can_attach_task(), pre_attach(), and attach_task() as new callbacks for cgroups's subsystem interface. Unlike can_attach and attach, these are for per-thread operations, to be called potentially many times when attaching an entire threadgroup. Also, the old "bool threadgroup" interface is removed, as replaced by this. All subsystems are modified for the new interface - of note is cpuset, which requires from/to nodemasks for attach to be globally scoped (though per-cpuset would work too) to persist from its pre_attach to attach_task and attach. This is a pre-patch for cgroup-procs-writable.patch. Signed-off-by: Ben Blum <bblum@andrew.cmu.edu> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Reviewed-by: Paul Menage <menage@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: David Rientjes <rientjes@google.com> Cc: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-11sched: Dynamic sched_domain::levelPeter Zijlstra
Remove the SD_LV_ enum and use dynamic level assignments. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/20110407122942.969433965@chello.nl Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-03-23cpuset: hold callback_mutex in cpuset_post_clone()Li Zefan
Chaning cpuset->mems/cpuset->cpus should be protected under callback_mutex. cpuset_clone() doesn't follow this rule. It's ok because it's called when creating and initializing a cgroup, but we'd better hold the lock to avoid subtil break in the future. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Acked-by: David Rientjes <rientjes@google.com> Cc: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
